cgma
r_w.cpp File Reference
#include <cassert>
#include <string>
#include <cctype>
#include <Standard_Version.hxx>
#include "GeometryModifyTool.hpp"
#include "GeometryQueryTool.hpp"
#include "CubitMessage.hpp"
#include "Body.hpp"
#include "RefVolume.hpp"
#include "RefFace.hpp"
#include "RefEdge.hpp"
#include "RefVertex.hpp"
#include "InitCGMA.hpp"
#include "CubitCompat.hpp"
#include <algorithm>
Defines
#define SRCDIR   .
#define STRINGIFY_(X)   #X
#define STRINGIFY(X)   STRINGIFY_(X)
#define SRCPATH   STRINGIFY(SRCDIR) "/"
#define PRINT_SEPARATOR   PRINT_INFO("=======================================\n");
Functions
CubitStatus read_geometry (int, char **, bool local=false)
CubitStatus make_Point ()
int findString (const char *filename, std::string search)
int main (int argc, char **argv)
std::string type_from_file_name (const std::string &filename)
CubitStatus read_geometry (int num_files, const char **argv, bool local)
Define Documentation
Definition at line 41 of file r_w.cpp.
#define SRCDIR   .
Definition at line 30 of file r_w.cpp.
Definition at line 35 of file r_w.cpp.
#define STRINGIFY (   X)    STRINGIFY_(X)
Definition at line 34 of file r_w.cpp.
#define STRINGIFY_ (   X)    #X
Definition at line 33 of file r_w.cpp.
Function Documentation
int findString ( const char *  filename,
std::string  search
Definition at line 43 of file r_w.cpp.
  std::ifstream Myfile;
  Myfile.open (filename);
  int found = 0;
  std::string line;
  size_t offset;
  if(Myfile.is_open())
    while(!Myfile.eof())
      getline(Myfile,line);
      if ((offset = line.find(search, 0)) != std::string::npos)
        found ++;
    Myfile.close();
  return found;
int main ( int  argc,
char **  argv
Definition at line 63 of file r_w.cpp.
  CubitStatus status = InitCGMA::initialize_cgma("OCC");
  if (CUBIT_SUCCESS != status) return 1;
  //Do make point.
  status = make_Point();
  if (status == CUBIT_FAILURE)
     PRINT_INFO("Operation Failed");
  int ret_val = ( CubitMessage::instance()->error_count() );
  if ( ret_val > 0 )
    PRINT_ERROR("Errors found during Mergechk session.\n");
  return ret_val;
CubitStatus read_geometry ( int  ,
char **  ,
bool  local = false
CubitStatus read_geometry ( int  num_files,
const char **  argv,
bool  local
attribs module: list, modify attributes in a give model or models
Arguments: file name(s) of geometry files in which to look
Definition at line 104 of file r_w.cpp.
  CubitStatus status = CUBIT_SUCCESS;
  GeometryQueryTool *gti = GeometryQueryTool::instance();
  assert(gti);
  int i;
  PRINT_SEPARATOR;
  for (i = 0; i < num_files; i++) {
    std::string type = type_from_file_name( argv[i] );
    if (type.empty()) // just guess OCC
      type = "OCC";
    std::string filename( local ? "./" : SRCPATH );
    char const* local_name = argv[i];
    filename += local_name;
    status = CubitCompat_import_solid_model(filename.c_str(), type.c_str());
    if (status != CUBIT_SUCCESS) {
      PRINT_ERROR("Problems reading geometry file %s.\n", filename.c_str());
      abort();
  PRINT_SEPARATOR;
  return CUBIT_SUCCESS;
std::string type_from_file_name ( const std::string &  filename)
Definition at line 82 of file r_w.cpp.
  size_t dot_pos = filename.find_last_of( '.' );
  if (dot_pos == std::string::npos)
    return std::string();
  std::string extension = filename.substr( dot_pos + 1 );
  std::transform( extension.begin(), extension.end(), extension.begin(), ::tolower );
  if (extension == "occ" || extension == "brep")
    return "OCC";
  else if (extension == "step" || extension == "stp")
    return "STEP";
  else if (extension == "iges" || extension == "igs")
    return "IGES";
  else
