cgma
r_w.cpp
00001
00010 #undef NDEBUG
00011 #include <cassert>
00012 #include <string>
00013 #include <cctype>
00014 #include <Standard_Version.hxx>
00015
00016 #include "GeometryModifyTool.hpp"
00017 #include "GeometryQueryTool.hpp"
00018 #include "CubitMessage.hpp"
00019 #include "Body.hpp"
00020 #include "RefVolume.hpp"
00021 #include "RefFace.hpp"
00022 #include "RefEdge.hpp"
00023 #include "RefVertex.hpp"
00024 #include "InitCGMA.hpp"
00025 #include "CubitCompat.hpp"
00026
00027 #include <algorithm>
00028
00029 #ifndef SRCDIR
00030 # define SRCDIR .
00031 #endif
00032
00033 #define STRINGIFY_(X) #X
00034 #define STRINGIFY(X) STRINGIFY_(X)
00035 #define SRCPATH STRINGIFY(SRCDIR) "/"
00036
00037 // forward declare some functions used and defined later
00038 CubitStatus read_geometry(int, char **, bool local = false);
00039 CubitStatus make_Point();
00040 // macro for printing a separator line
00041 #define PRINT_SEPARATOR   PRINT_INFO("=======================================\n");
00042
00043 int findString(const char *filename, std::string search)
00044 {
00045   std::ifstream Myfile;
00046   Myfile.open (filename);
00047   int found = 0;
00048   std::string line;
00049   size_t offset;
00050   if(Myfile.is_open())
00051   {
00052     while(!Myfile.eof())
00053     {
00054       getline(Myfile,line);
00055       if ((offset = line.find(search, 0)) != std::string::npos)
00056         found ++;
00057     }
00058     Myfile.close();
00059   }
00060   return found;
00061 }
00062 // main program - initialize, then send to proper function
00063 int main (int argc, char **argv)
00064 {
00065   CubitStatus status = InitCGMA::initialize_cgma("OCC");
00066   if (CUBIT_SUCCESS != status) return 1;
00067
00068   //Do make point.
00069   status = make_Point();
00070   if (status == CUBIT_FAILURE)
00071      PRINT_INFO("Operation Failed");
00072
00073   int ret_val = ( CubitMessage::instance()->error_count() );
00074   if ( ret_val > 0 )
00075   {
00076     PRINT_ERROR("Errors found during Mergechk session.\n");
00077   }
00078   return ret_val;
00079
00080 }
00081
00082 std::string type_from_file_name( const std::string& filename )
00083 {
00084   size_t dot_pos = filename.find_last_of( '.' );
00085   if (dot_pos == std::string::npos)
00086     return std::string();
00087
00088   std::string extension = filename.substr( dot_pos + 1 );
00089   std::transform( extension.begin(), extension.end(), extension.begin(), ::tolower );
00090   if (extension == "occ" || extension == "brep")
00091     return "OCC";
00092   else if (extension == "step" || extension == "stp")
00093     return "STEP";
00094   else if (extension == "iges" || extension == "igs")
00095     return "IGES";
00096   else
00097     return std::string();
00098 }
00099
00104 CubitStatus read_geometry(int num_files, const char **argv, bool local)
00105 {
00106   CubitStatus status = CUBIT_SUCCESS;
00107   GeometryQueryTool *gti = GeometryQueryTool::instance();
00108   assert(gti);
00109   int i;
00110
00111   PRINT_SEPARATOR;
00112
00113   for (i = 0; i < num_files; i++) {
00114     std::string type = type_from_file_name( argv[i] );
00115     if (type.empty()) // just guess OCC
00116       type = "OCC";
00117     std::string filename( local ? "./" : SRCPATH );
00118     char const* local_name = argv[i];
00119     filename += local_name;
00120     status = CubitCompat_import_solid_model(filename.c_str(), type.c_str());
00121     if (status != CUBIT_SUCCESS) {
00122       PRINT_ERROR("Problems reading geometry file %s.\n", filename.c_str());
00123       abort();
00124     }
00125   }
00126   PRINT_SEPARATOR;
00127
00128   return CUBIT_SUCCESS;
00129 }
00130
00131 CubitStatus make_Point()
00132 {
00133   GeometryQueryTool *gti = GeometryQueryTool::instance();
00134   GeometryModifyTool *gmti = GeometryModifyTool::instance();
00135
00136   DLIList<Body*> bodies;
00137   DLIList<RefEntity*>  free_entities;
00138
00139   //Read in the geometry from iges file
00140   const char *argiges = "ex3.iges";
00141   CubitStatus status = read_geometry(1, &argiges, false);
00142   //Constructed 18 Free Curves: 1 to 18
00143   if (status == CUBIT_FAILURE) exit(1);
00144
00145   DLIList<RefEntity*> ref_entity_list;
00146   int num_ents_exported=0;
00147   const CubitString cubit_version="10.2";
00148   const char * filename = "ex3.occ";
00149   const char * filetype = "OCC";
00150
00151   CubitCompat_export_solid_model(ref_entity_list, filename, filetype,
00152                                  num_ents_exported, cubit_version);
00153
00154   //Exported:  18 OCC Curves to ex3.occ
00155   assert(num_ents_exported == 18);
00156   remove(filename);
00157
00158   filetype = "IGES";
00159   filename = "ex3export.iges";
00160   num_ents_exported=0;
00161   CubitCompat_export_solid_model(ref_entity_list, filename, filetype,
00162                                  num_ents_exported, cubit_version);
00163
00164   //Exported:  18 OCC Curves to ex3export.iges
00165   assert(num_ents_exported == 18);
00166   remove(filename);
00167
00168   filetype = "STEP";
00169   filename = "ex3export.step";
00170   num_ents_exported=0;
00171   CubitCompat_export_solid_model(ref_entity_list, filename, filetype,
00172                                  num_ents_exported, cubit_version);
00173   //Exported:  18 OCC Curves to ex3export.step
00174   assert(num_ents_exported == 18);
00175   remove(filename);
00176
00177   gti->bodies(bodies);
00178
00179   //delete all entities
00180   gti->delete_Body(bodies);
00181
00182   gti->get_free_ref_entities(free_entities);
00183
00184   for (int j = free_entities.size(); j--;)
00185     {
00186       gti->delete_RefEntity( free_entities.get_and_step());
00187     }
00188
00189
00190   const char *argiges2 = "diffuser.iges";
00191   status = read_geometry(1, &argiges2, false);
00192   //Constructed 7 Volumes: 1 to 7
00193   if (status == CUBIT_FAILURE) exit(1);
00194
00195   filetype = "OCC";
00196   ref_entity_list.clean_out();
00197   num_ents_exported=0;
00198   filename = "diffuser.occ";
00199
00200   CubitCompat_export_solid_model(ref_entity_list, filename, filetype,
00201                                  num_ents_exported, cubit_version);
00202
00203   //Exported:   7 OCC Bodies to diffuser.occ
00204   assert(num_ents_exported == 7);
00205   remove(filename);
00206
00207   gti->bodies(bodies);
00208
00209   //delete all entities
00210   gti->delete_Body(bodies);
00211
00212   free_entities.clean_out();
00213   gti->get_free_ref_entities(free_entities);
00214
00215   for (int j = free_entities.size(); j--;)
00216     {
00217       gti->delete_RefEntity( free_entities.get_and_step());
00218     }
00219
00220   const char *argstep = "proe.stp";
00221   //const char *argstep = "cub_model.step";
00222   status = read_geometry(1, &argstep, false);
00223   //Constructed 12 Volumes: 8 to 19
00224   if (status == CUBIT_FAILURE) exit(1);
00225
00226   filetype = "OCC";
00227   ref_entity_list.clean_out();
00228   num_ents_exported=0;
00229   filename = "proe.occ";
00230
00231   CubitCompat_export_solid_model(ref_entity_list, filename, filetype,
00232                                  num_ents_exported, cubit_version);
00233   //Exported:  12 OCC Bodies to proe.occ
00234   assert(num_ents_exported == 12);
00235   remove(filename);
00236
00237   filetype = "IGES";
00238   filename = "proeexport.iges";
00239   num_ents_exported=0;
00240   CubitCompat_export_solid_model(ref_entity_list, filename, filetype,
00241                                  num_ents_exported, cubit_version);
00242   //Exported:  12 OCC Bodies to proeexport.iges
00243   assert(num_ents_exported == 12);
00244   remove(filename);
00245
00246   filetype = "STEP";
00247   filename = "proeexport.step";
00248   num_ents_exported=0;
00249   CubitCompat_export_solid_model(ref_entity_list, filename, filetype,
00250                                  num_ents_exported, cubit_version);
00251   //Exported:  12 OCC Bodies to proeexport.step
00252   assert(num_ents_exported == 12);
00253   remove(filename);
00254
00255   gti->bodies(bodies);
00256
00257   //delete all entities
00258   gti->delete_Body(bodies);
00259   free_entities.clean_out();
00260   gti->get_free_ref_entities(free_entities);
00261
00262   for (int j = free_entities.size(); j--;)
00263     {
00264       gti->delete_RefEntity( free_entities.get_and_step());
00265     }
00266
00267   // Read in the geometry from files specified on the command line
00268   const char *argv = "stitch.name_occ";
00269   status = read_geometry(1, &argv, false);
00270   if (status == CUBIT_FAILURE) exit(1);
00271   //Read in 2 volumes.
00272
00273   filetype = "OCC";
00274   ref_entity_list.clean_out();
00275   num_ents_exported=0;
00276   filename = "beforesub.occ";
00277
00278   CubitCompat_export_solid_model(ref_entity_list, filename, filetype,
00279                                  num_ents_exported, cubit_version);
00280
00281   assert(num_ents_exported == 2);
00282   std::string search = "6 face15";
00283   int found = findString(filename, search);
00284   assert (found == 1);
00285   gti->bodies(bodies);
00286
00287   //delete all entities
00288   gti->delete_Body(bodies);
00289
00290   free_entities.clean_out();
00291   gti->get_free_ref_entities(free_entities);
00292
00293   for (int j = free_entities.size(); j--;)
00294     {
00295       gti->delete_RefEntity( free_entities.get_and_step());
00296     }
00297
00298   const char *argv1 = "beforesub.occ";
00299   status = read_geometry(1, &argv1, true);
00300   if (status == CUBIT_FAILURE) exit(1);
00301   //Read in 2 volumes.
00302   remove(filename);
00303
00304   //export the newly read-in file
00305   filename = "beforesub2.occ";
00306   ref_entity_list.clean_out();
00307   num_ents_exported = 0;
00308   CubitCompat_export_solid_model(ref_entity_list, filename, filetype,
00309                                  num_ents_exported, cubit_version);
00310
00311   assert(num_ents_exported == 2);
00312   found = findString(filename, search);
00313   assert (found == 1);
00314   remove(filename);
00315
00316   bodies.clean_out();
00317   gti->bodies(bodies);
00318   DLIList<Body*> new_bodies;
00319   DLIList<Body*> from_bodies;
00320   from_bodies.append(bodies.get());
00321   Body* tool_body = bodies.step_and_get();
00322   gmti->subtract(tool_body,from_bodies, new_bodies,
00323                        CUBIT_TRUE, CUBIT_FALSE);
00324   //Created volume(s): 24, 25
00325   //Destroyed volume(s): 22, 23
00326   double d = new_bodies.step_and_get()->measure();
00327   CubitVector v = new_bodies.get()->center_point();
00328   int n = new_bodies.get()->num_ref_faces();
00329   assert (n == 12);
00330   CubitVector test_v(5, 5,0.5);
00331   assert (v == test_v);
00332   assert (60-d < 0.000000001);
00333   //new body has 2 volumes, one has a volume = 10 and the other has a
00334   //volume = 50; each of them has 6 ref_faces, of which 3 are new and 3 are
00335   //remaining (unchanged or modified).
00336
00337   filename = "aftersub.occ";
00338   ref_entity_list.clean_out();
00339   num_ents_exported = 0;
00340   CubitCompat_export_solid_model(ref_entity_list, filename, filetype,
00341                                  num_ents_exported, cubit_version);
00342
00343   assert(num_ents_exported == 1);
00344   search = "5 face1";
00345   found = findString(filename, search);
00346   assert (found == 1);
00347
00348   search = "5 face2";
00349   found = findString(filename, search);
00350   assert (found == 1);
00351
00352   search = "5 face3";
00353   found = findString(filename, search);
00354   assert (found == 1);
00355
00356 #if OCC_VERSION_MINOR < 6
00357   search = "5 face4";
00358   found = findString(filename, search);
00359   assert (found == 1);
00360 #endif
00361   search = "5 face5";
00362   found = findString(filename, search);
00363   assert (found == 1);
00364
00365   search = "5 face7";
00366   found = findString(filename, search);
00367   assert (found == 1);
00368
00369 #if OCC_VERSION_MINOR < 6
00370   search = "5 face8";
00371   found = findString(filename, search);
00372   assert (found == 1);
00373 #endif
00374
00375   search = "5 face9";
00376   found = findString(filename, search);
00377   assert (found == 1);
00378   remove(filename);
00379
00380   bodies.clean_out();
00381   gti->bodies(bodies);
00382   //delete all entities
00383   gti->delete_Body(bodies);
00384
00385   gti->get_free_ref_entities(free_entities);
00386   assert(free_entities.size() ==0);
00387
00388   // Read in the geometry from files specified on the command line
00389   const char *argv2 = "unite1.occ";
00390   status = read_geometry(1, &argv2, false);
00391   if (status == CUBIT_FAILURE) exit(1);
00392   //Read in 2 volumes.
00393
00394   from_bodies.clean_out();
00395   new_bodies.clean_out();
00396   gti->bodies(from_bodies);
00397   status = gmti->unite(from_bodies, new_bodies, CUBIT_FALSE);
00398   assert(status);
00399
00400   filename = "unite2.occ";
00401   ref_entity_list.clean_out();
00402   num_ents_exported = 0;
00403   CubitCompat_export_solid_model(ref_entity_list, filename, filetype,
00404                                  num_ents_exported, cubit_version);
00405
00406   assert(num_ents_exported == 1);
00407   //name attributes in unite2.occ is
00408   //CGM_ATTRIB 11 ENTITY_NAME 4 8 volume B 8 volume_B 8 volume A 8 volume_A 0 0
00409   //check that the two single volume bodys' attributes are exported as SINGLELUMP%
00410   search = "4 8 volume B 8 volume_B 8 volume A 8 volume_A";
00411   found = findString(filename, search);
00412
00413   assert (found == 1);
00414   remove(filename);
00415
00416   bodies.clean_out();
00417   gti->bodies(bodies);
00418   //delete all entities
00419   gti->delete_Body(bodies);
00420
00421   gti->get_free_ref_entities(free_entities);
00422   assert(free_entities.size() ==0);
00423
00424   // Read in the geometry from files specified on the command line
00425   const char *argv3 = "unite1.occ";
00426   status = read_geometry(1, &argv3, false);
00427   if (status == CUBIT_FAILURE) exit(1);
00428   //Read in 2 volumes.
00429
00430   //change the order of the two bodies,and unite, see the united name changed.
00431   new_bodies.clean_out();
00432   bodies.clean_out();
00433   gti->bodies(bodies);
00434   from_bodies.clean_out();
00435   from_bodies.append(bodies.step_and_get());
00436   from_bodies.append(bodies.step_and_get());
00437
00438   status = gmti->unite(from_bodies, new_bodies, CUBIT_FALSE);
00439   assert(status);
00440   filename = "unite3.occ";
00441   ref_entity_list.clean_out();
00442   num_ents_exported = 0;
00443   CubitCompat_export_solid_model(ref_entity_list, filename, filetype,
00444                                  num_ents_exported, cubit_version);
00445   assert(num_ents_exported == 1);
00446   //CGM_ATTRIB 11 ENTITY_NAME 4 8 volume A 8 volume_A 8 volume B 8 volume_B 0 0
00447   // in unite3.occ
00448   search = "4 8 volume A 8 volume_A 8 volume B 8 volume_B";
00449   found = findString(filename, search);
00450
00451   assert (found == 1);
00452   remove(filename);
00453   bodies.clean_out();
00454   gti->bodies(bodies);
00455   //delete all entities
00456   gti->delete_Body(bodies);
00457
00458   gti->get_free_ref_entities(free_entities);
00459   assert(free_entities.size() ==0);
00460
00461     // Read in the geometry from files specified on the command line
00462   const char *argv4 = "unite4.occ";
00463   status = read_geometry(1, &argv4, false);
00464   if (status == CUBIT_FAILURE) exit(1);
00465   //Read in 2 volumes.
00466
00467   from_bodies.clean_out();
00468   new_bodies.clean_out();
00469   gti->bodies(from_bodies);
00470   status = gmti->unite(from_bodies, new_bodies, CUBIT_FALSE);
00471   assert(status);
00472
00473   filename = "unite5.occ";
00474   ref_entity_list.clean_out();
00475   num_ents_exported = 0;
00476   CubitCompat_export_solid_model(ref_entity_list, filename, filetype,
00477                                  num_ents_exported, cubit_version);
00478
00479   assert(num_ents_exported == 1);
00480   //CGM_ATTRIB 11 ENTITY_NAME 2 7 volumeA 7 volumeB 0 0 in unite5.occ
00481   search = "2 7 volumeA 7 volumeB";
00482   found = findString(filename, search);
00483
00484   assert (found == 1);
00485   remove(filename);
00486   bodies.clean_out();
00487   gti->bodies(bodies);
00488   //delete all entities
00489   gti->delete_Body(bodies);
00490
00491   gti->get_free_ref_entities(free_entities);
00492   assert(free_entities.size() ==0);
00493
00494   // Read in the geometry from files specified on the command line
00495   status = read_geometry(1, &argv4, false);
00496   if (status == CUBIT_FAILURE) exit(1);
00497   //Read in 2 volumes.
00498
00499   //change the order of the two bodies, and unite, see the name change.
00500   new_bodies.clean_out();
00501   bodies.clean_out();
00502   gti->bodies(bodies);
00503   from_bodies.clean_out();
00504   from_bodies.append(bodies.step_and_get());
00505   from_bodies.append(bodies.step_and_get());
00506
00507   status = gmti->unite(from_bodies, new_bodies, CUBIT_FALSE);
00508   assert(status);
00509   filename = "unite6.occ";
00510   ref_entity_list.clean_out();
00511   num_ents_exported = 0;
00512   CubitCompat_export_solid_model(ref_entity_list, filename, filetype,
00513                                  num_ents_exported, cubit_version);
00514   assert(num_ents_exported == 1);
00515
00516   //CGM_ATTRIB 11 ENTITY_NAME 2 7 volumeB 7 volumeA 0 0 in unite6.occ
00517   search = "2 7 volumeB 7 volumeA";
00518   found = findString(filename, search);
00519
00520   assert (found == 1);
00521   remove(filename);
00522   bodies.clean_out();
00523   gti->bodies(bodies);
00524   //delete all entities
00525   gti->delete_Body(bodies);
00526
00527   gti->get_free_ref_entities(free_entities);
00528   assert(free_entities.size() ==0);
00529   return CUBIT_SUCCESS;
00530 }
