cgma
CubitCompat.hpp File Reference
#include "CubitDefines.h"
Functions
CubitStatus CubitCompat_import_solid_model (const char *file_name, const char *file_type, const char *logfile_name=NULL, CubitBoolean heal_step=CUBIT_TRUE, CubitBoolean import_bodies=CUBIT_TRUE, CubitBoolean import_surfaces=CUBIT_TRUE, CubitBoolean import_curves=CUBIT_TRUE, CubitBoolean import_vertices=CUBIT_TRUE, CubitBoolean free_surfaces=CUBIT_TRUE, DLIList< RefEntity * > *imported_entities=NULL)
CubitStatus CubitCompat_export_solid_model (DLIList< RefEntity * > &ref_entity_list, const char *filename, const char *filetype, int &num_ents_exported, const CubitString &cubit_version, const char *logfile_name=NULL)
Function Documentation
CubitStatus CubitCompat_export_solid_model ( DLIList< RefEntity * > &  ref_entity_list,
const char *  filename,
const char *  filetype,
int &  num_ents_exported,
const CubitString cubit_version,
const char *  logfile_name = NULL
Definition at line 70 of file CubitCompat.cpp.
//  const bool print_results = false;
//  const bool merge_globally = false;
//  const bool no_assembly_level_features = false;
  ModelExportOptions CubitCompat_opts = {1, logfile_name ? logfile_name : "" };
  return GeometryQueryTool::instance()->export_solid_model(
           ref_entity_list,
           filename,
           CubitCompat_file_type(filetype),
           num_ents_exported,
           cubit_version,
           CubitCompat_opts );
CubitStatus CubitCompat_import_solid_model ( const char *  file_name,
const char *  file_type,
const char *  logfile_name = NULL,
CubitBoolean  heal_step = CUBIT_TRUE,
CubitBoolean  import_bodies = CUBIT_TRUE,
CubitBoolean  import_surfaces = CUBIT_TRUE,
CubitBoolean  import_curves = CUBIT_TRUE,
CubitBoolean  import_vertices = CUBIT_TRUE,
CubitBoolean  free_surfaces = CUBIT_TRUE,
DLIList< RefEntity * > *  imported_entities = NULL
Definition at line 37 of file CubitCompat.cpp.
  ModelImportOptions CubitCompat_opts = { heal_step,
                                        print_results,
                                        import_bodies,
                                        import_surfaces,
                                        import_curves,
                                        import_vertices,
                                        free_surfaces,
                                        merge_globally,
                                        no_assembly_level_features,
  return GeometryQueryTool::instance()->import_solid_model(
           file_name,
           CubitCompat_file_type(file_type),
           CubitCompat_opts,
           imported_entities );
