cgma
#include <iostream>
#include <fstream>
#include <string>
#include <stdexcept>
#include <cctype>
#include <vector>
#include <set>
#include <map>
#include <sstream>
#include <algorithm>
#include <cassert>
#include "iGeom.h"
#include "geometry.hpp"
#include "MCNPInput.hpp"
#include "options.hpp"
#include "volumes.hpp"
#include "ProgOptions.hpp"
#include "version.hpp"
#include <RefEntityFactory.hpp>
#include <Body.hpp>
#include <GeometryQueryTool.hpp>
#include <CubitMessage.hpp>
Classes | |
class | SilentCubitMessageHandler |
class | CubitSilence |
class | GeometryContext |
class | GeometryContext::NamedGroup |
class | GeometryContext::NamedEntity |
struct | int_triple |
Typedefs | |
typedef std::vector < iBase_EntityHandle > | entity_collection_t |
Functions | |
static bool | intersectIfPossible (iGeom_Instance igm, iBase_EntityHandle h1, iBase_EntityHandle h2, iBase_EntityHandle *result, bool delete_on_failure=true) |
static bool | boundBoxesIntersect (iGeom_Instance igm, iBase_EntityHandle h1, iBase_EntityHandle h2) |
static std::vector< int_triple > | makeGridShellOfRadius (int r, int dimensions) |
void | debugSurfaceDistances (InputDeck &deck, std::ostream &out=std::cout) |
std::string | mcnp2cad_version (bool full=true) |
int | main (int argc, char *argv[]) |
Variables | |
static bool | CGMA_opt_inhibit_intersect_errs = false |
struct program_option_struct | Gopt |
typedef std::vector<iBase_EntityHandle> entity_collection_t |
Definition at line 78 of file mcnp2cad.cpp.
static bool boundBoxesIntersect | ( | iGeom_Instance | igm, |
iBase_EntityHandle | h1, | ||
iBase_EntityHandle | h2 | ||
) | [static] |
Definition at line 113 of file mcnp2cad.cpp.
{ Vector3d h1_min, h1_max, h2_min, h2_max; int igm_result; iGeom_getEntBoundBox( igm, h1, h1_min.v, h1_min.v+1, h1_min.v+2, h1_max.v, h1_max.v+1, h1_max.v+2, &igm_result ); CHECK_IGEOM( igm_result, "Getting bounding box h1" ); iGeom_getEntBoundBox( igm, h2, h2_min.v, h2_min.v+1, h2_min.v+2, h2_max.v, h2_max.v+1, h2_max.v+2, &igm_result ); CHECK_IGEOM( igm_result, "Getting bounding box h2" ); bool ret = false; for( int i = 0; i < 3 && ret == false; ++i ){ ret = ret || ( h1_min.v[i] > h2_max.v[i] ); ret = ret || ( h2_min.v[i] > h1_max.v[i] ); } return !ret; }
void debugSurfaceDistances | ( | InputDeck & | deck, |
std::ostream & | out = std::cout |
Definition at line 1110 of file mcnp2cad.cpp.
{ InputDeck::surface_card_list& surfaces = deck.getSurfaces(); for( InputDeck::surface_card_list::iterator i = surfaces.begin(); i!=surfaces.end(); ++i){ try{ const SurfaceVolume& s = makeSurface(*i); out << "S" << (*i)->getIdent() << " distance from origin: " << s.getFarthestExtentFromOrigin() << std::endl; } catch(std::runtime_error& e){ std::cerr << "Error debugging surface distances: " << e.what() << std::endl; throw; } } }
static bool intersectIfPossible | ( | iGeom_Instance | igm, |
iBase_EntityHandle | h2, | ||
iBase_EntityHandle * | result, | ||
bool | delete_on_failure = true |
) | [static] |
Definition at line 81 of file mcnp2cad.cpp.
{ int igm_result; //#ifdef USING_CGMA if( CGMA_opt_inhibit_intersect_errs ){ CubitSilence s; iGeom_intersectEnts( igm, h1, h2, result, &igm_result); } else //#endif { iGeom_intersectEnts( igm, h1, h2, result, &igm_result); } if( igm_result == iBase_SUCCESS ){ return true; } else{ if( delete_on_failure ){ iGeom_deleteEnt( igm, h1, &igm_result); CHECK_IGEOM(igm_result, "deleting an intersection candidate"); iGeom_deleteEnt( igm, h2, &igm_result); CHECK_IGEOM(igm_result, "deleting an intersection candidate"); } return false; } }
int main | ( | int | argc, |
char * | argv[] | ||
Definition at line 1131 of file mcnp2cad.cpp.
{ // set default options Gopt.verbose = Gopt.debug = false; Gopt.infinite_lattice_extra_effort = false; Gopt.tag_materials = true; Gopt.tag_importances = true; Gopt.tag_cell_IDs = true; Gopt.make_graveyard = true; Gopt.imprint_geom = true; Gopt.merge_geom = true; Gopt.input_file = ""; Gopt.output_file = OPT_DEFAULT_OUTPUT_FILENAME; Gopt.igeom_init_options = ""; Gopt.override_tolerance = false; Gopt.uwuw_names = false; bool DiFlag = false, DoFlag = false; ProgOptions po("mcnp2cad " + mcnp2cad_version(false) + ": An MCNP geometry to CAD file converter"); po.setVersion( mcnp2cad_version() ); po.addOpt<void>("extra-effort,e","Use extra effort to get infinite lattices right (may be slow)", &Gopt.infinite_lattice_extra_effort ); po.addOpt<void>("verbose,v", "Verbose output", &Gopt.verbose ); po.addOpt<void>("debug,D", "Debugging (very verbose) output", &Gopt.debug ); po.addOpt<void>("Di", "Debug output for MCNP parsing phase only", &DiFlag); po.addOpt<void>("Do","Debug output for iGeom output phase only", &DoFlag); po.addOptionHelpHeading( "Options controlling CAD output:" ); po.addOpt<std::string>(",o", "Give name of output file. Default: " + Gopt.output_file, &Gopt.output_file ); po.addOpt<double>("tol,t", "Specify a tolerance for merging surfaces", &Gopt.specific_tolerance ); po.addOpt<void>("skip-mats,M", "Do not tag materials using group names", &Gopt.tag_materials, po.store_false ); po.addOpt<void>("skip-imps,P", "Do not tag cell importances using group names", &Gopt.tag_importances, po.store_false ); po.addOpt<void>("skip-nums,N", "Do not tag cell numbers using body names", &Gopt.tag_cell_IDs, po.store_false ); po.addOpt<void>("skip-merge,E", "Do not merge the geometry", &Gopt.merge_geom, po.store_false ); po.addOpt<void>("skip-imprint,I", "Do not imprint the geometry; implies skip-merge", &Gopt.imprint_geom, po.store_false ); po.addOpt<void>("skip-graveyard,G", "Do not bound the geometry with a `graveyard' bounding box", &Gopt.make_graveyard, po.store_false ); po.addOpt<void>("uwuw-names,U", "Use a UWUW compatible name scheme for material groups," "i.e. 'mat:mX/rho:Y' where X is material number is Y is density", &Gopt.uwuw_names, po.store_true ); //#ifdef USING_CGMA po.addOptionHelpHeading ("Options controlling CGM library:"); po.addOpt<int>("geomver","Override geometry export engine version"); po.addOptionHelpHeading (" (use --geomver 1600 for backward compatibility w/ Cubit 10.2)"); po.addOpt<void>("Cv", "Verbose messages from CGM" ); po.addOpt<void>("Cq", "Silence warning messages from CGM" ); po.addOpt<void>("CIq","Silence ERROR messages from CGM when doing intersect tests."); po.addOptionHelpHeading( " (May be useful for infinite lattices, but use cautiously)" ); //#endif po.addRequiredArg( "input_file", "Path to MCNP geometry input file", &Gopt.input_file ); po.parseCommandLine( argc, argv ); if( po.numOptSet( "tol,t" ) ){ Gopt.override_tolerance = true; if( Gopt.specific_tolerance <= 0.0 || Gopt.specific_tolerance > .1 ){ std::cerr << "Warning: you seem to have specified an unusual tolerance (" << Gopt.specific_tolerance << ")." << std::endl; } } //#ifdef USING_CGMA // Enable the info_flag only if --Cv is requested if(po.numOptSet( "Cv" )){ CubitMessage::instance()->set_info_flag( true ); } else{ CubitMessage::instance()->set_info_flag( false ); } // Silence warnings if --Cq is set if(po.numOptSet( "Cq" )){ CubitMessage::instance()->set_warning_flag( false ); } // Enable silent intersection errors if --CIq is set if(po.numOptSet( "CIq" )){ CGMA_opt_inhibit_intersect_errs = true; } //#endif if( Gopt.merge_geom && !Gopt.imprint_geom ) { std::cerr << "Warning: cannot merge geometry without imprinting, will skip merge too." << std::endl; } std::ifstream input(Gopt.input_file.c_str(), std::ios::in ); if( !input.is_open() ){ std::cerr << "Error: couldn't open file \"" << Gopt.input_file << "\"" << std::endl; return 1; } std::cout << "Reading input file..." << std::endl; // if --Di and not -D, set debugging to be true for InputDeck::build() call only if( DiFlag && !OPT_DEBUG){ Gopt.debug = true; } else{ DiFlag = false; } InputDeck& deck = InputDeck::build(input); std::cout << "Done reading input." << std::endl; // turn off debug if it was set by --Di only if( DiFlag ){ Gopt.debug = false; } if( DoFlag && !OPT_DEBUG ){ Gopt.debug = true; } if( OPT_DEBUG ){ debugSurfaceDistances( deck ); } #ifdef CGM_HAVE_FACET_ENGINE_ONLY FacetModifyEngine::set_modify_enabled(CUBIT_TRUE); #endif iGeom_Instance igm; int igm_result; iGeom_newGeom( Gopt.igeom_init_options.c_str(), &igm, &igm_result, Gopt.igeom_init_options.length() ); CHECK_IGEOM( igm_result, "Initializing iGeom"); //#ifdef USING_CGMA int export_vers; if( po.getOpt( "geomver", &export_vers) ){ if( CUBIT_SUCCESS == GeometryQueryTool::instance()->set_export_allint_version( export_vers ) ){ std::cout << "Set export engine version to " << export_vers << std::endl; } // on failure, an error message will be printed by CGM } //#endif GeometryContext context( igm, deck ); context.createGeometry(); //#ifdef USING_CGMA if( CGMA_opt_inhibit_intersect_errs && SilentCubitMessageHandler::num_dropped_errors > 0){ std::cout << "--CIq: supressed " << SilentCubitMessageHandler::num_dropped_errors << " intersection errors." << std::endl; } //#endif return 0; }
static std::vector<int_triple> makeGridShellOfRadius | ( | int | r, |
int | dimensions | ||
) | [static] |
Definition at line 601 of file mcnp2cad.cpp.
{ if( r == 0 ){ int_triple v; v.v[0] = v.v[1] = v.v[2] = 0; return std::vector<int_triple>(1,v); } else{ std::vector<int_triple> ret; int jmin = dimensions > 1 ? -r : 0; int jmax = dimensions > 1 ? r : 0; int kmin = dimensions > 2 ? -r : 0; int kmax = dimensions > 2 ? r : 0; for( int i = -r; i <= r; ++i ){ for( int j = jmin;j <= jmax; ++j ){ for( int k = kmin; k <= kmax; ++k ){ if( i == -r || i == r || j == -r || j == r || k == -r || k == r ){ int_triple v; v.v[0] = i; v.v[1] = j; v.v[2] = k; ret.push_back(v); } } } } return ret; } }
std::string mcnp2cad_version | ( | bool | full | ) |
Return the version string
Return only numbers ("1.2.3") if full is false, else dated format
Definition at line 1290 of file mcnp2cad.cpp.
{ std::stringstream str; str << (full ? "mcnp2cad version " : "") << MCNP2CAD_VERSION_MAJOR << "." << MCNP2CAD_VERSION_MINOR << "." << MCNP2CAD_VERSION_REV; if(full) str << "\nCompiled on " << __DATE__ << " at " << __TIME__ ; return str.str(); }
bool CGMA_opt_inhibit_intersect_errs = false [static] |
Definition at line 36 of file mcnp2cad.cpp.
struct program_option_struct Gopt |
Definition at line 1129 of file mcnp2cad.cpp.
