cgma
partest.cpp File Reference
#include <iostream>
#include <stdio.h>
#include <string.h>
#include <sys/resource.h>
#include <unistd.h>
#include <fcntl.h>
#include <stdlib.h>
#include "CGMmpi.h"
#include "iGeom.h"
Defines
#define IGEOM_ASSERT(ierr)   if (ierr!=0) printf("igeom assert\n");
#define IGEOM_NULL   0
#define STRINGIFY(S)   XSTRINGIFY(S)
#define XSTRINGIFY(S)   #S
Functions
void util_getrusage (struct rusage &r_usage)
int main (int argc, char *argv[])
Define Documentation
#define IGEOM_ASSERT (   ierr)    if (ierr!=0) printf("igeom assert\n");
Definition at line 18 of file partest.cpp.
Definition at line 19 of file partest.cpp.
#define STRINGIFY (   S)    XSTRINGIFY(S)
Definition at line 21 of file partest.cpp.
#define XSTRINGIFY (   S)    #S
Definition at line 22 of file partest.cpp.
Function Documentation
int main ( int  argc,
char *  argv[]
Definition at line 26 of file partest.cpp.
  int rank, size;
  MPI_Init(&argc, &argv);
  MPI_Comm_rank( MPI_COMM_WORLD, &rank );
  MPI_Comm_size( MPI_COMM_WORLD, &size );
  printf("Hello\n");
  iGeom_Instance igeom;
  int ierr;
  igeom = IGEOM_NULL;
  iGeom_newGeom("PARALLEL", &igeom, &ierr, 8);
  IGEOM_ASSERT(ierr);
  // check command line arg
  const char* filename = 0;
  int nMethod = 1;
  std::string options;
  if (argc == 3) {
    filename = argv[1];
    nMethod = atoi(argv[2]);
  else {
    if (rank == 0) {
      printf("Usage: %s [<filename>] [<send_methond>]\n", argv[0]);
      printf("No file specified.  Defaulting to: %s\n", "Moto.brep");
      printf("No send method specified.  Defaulting to: read_delete\n");
    filename = STRINGIFY(SRCDIR)"/../test/Moto.brep";
    nMethod = 1;
  // set geometry send method
  if (nMethod == 0) options += "PARALLEL=READ;";
  else if (nMethod == 1) options += "PARALLEL=READ_DELETE;";
  else if (nMethod == 2) options += "PARALLEL=BCAST;";
  else if (nMethod == 3) options += "PARALLEL=BCAST_DELETE;";
  else if (nMethod == 4) options += "PARALLEL=SCATTER;";
  else if (nMethod == 5) options += "PARALLEL=SCATTER_DELETE;";
  else if (nMethod == 6) options += "PARALLEL=READ_PARALLEL;";
  else {
    printf("Send method %d is not supported. Defaulting to: read_delete\n", nMethod);
    options = "READ_DELETE;";
  // do body partitioning with round robin distribution
  options += "PARTITION=GEOM_DIMENSION;PARTITION_VAL=3;PARTITION_DISTRIBUTE;";
  struct rusage r_usage;
  long int rss_before, rss_after, size_before, size_after;
  static size_t pagesize = getpagesize();
  if (rank == 0) {
    util_getrusage(r_usage);
    rss_before = r_usage.ru_maxrss*pagesize;
    size_before = r_usage.ru_idrss*pagesize;
  double tStart = MPI_Wtime();
  iGeom_load(igeom, filename, options.c_str(), &ierr, strlen(filename), options.length());
  MPI_Barrier(MPI_COMM_WORLD);
  double tEnd = MPI_Wtime();
  if (rank == 0) {
    rss_after = r_usage.ru_maxrss*pagesize;
    size_after = r_usage.ru_idrss*pagesize;
    printf("proc=%d, rss_before=%ld, size_before=%ld\n", rank, rss_before, size_before);
    printf("proc=%d, rss_after=%ld, size_after=%ld\n", rank, rss_after, size_after);
  IGEOM_ASSERT(ierr);
  printf("Done. Geometry load time is %f\n", tEnd - tStart);
  MPI_Finalize();
void util_getrusage ( struct rusage &  r_usage)
Definition at line 105 of file partest.cpp.
  getrusage(RUSAGE_SELF, &r_usage);
  // this machine doesn't return rss - try going to /proc
  // print the file name to open
  if (r_usage.ru_maxrss == 0) {
    char file_str[4096], dum_str[4096];
    int file_ptr = -1, file_len;
    file_ptr = open("/proc/self/stat", O_RDONLY);
    file_len = read(file_ptr, file_str, sizeof(file_str)-1);
    if (file_len == 0) return;
    close(file_ptr);
    file_str[file_len] = '\0';
    // read the preceeding fields and the ones we really want...
    int dum_int;
    unsigned int dum_uint, vm_size, rss;
    static int page_size = getpagesize();
    int num_fields = sscanf(file_str,
                "%d " // pid
                "%s " // comm
                "%c " // state
                "%d %d %d %d %d " // ppid, pgrp, session, tty, tpgid
                "%u %u %u %u %u " // flags, minflt, cminflt, majflt, cmajflt
                "%d %d %d %d %d %d " // utime, stime, cutime, cstime, counter, priority
                "%u %u " // timeout, itrealvalue
                "%d " // starttime
                "%u %u", // vsize, rss
                &dum_int,
                dum_str,
                dum_str,
                &dum_int, &dum_int, &dum_int, &dum_int, &dum_int,
                &dum_uint, &dum_uint, &dum_uint, &dum_uint, &dum_uint,
                &dum_int, &dum_int, &dum_int, &dum_int, &dum_int, &dum_int,
                &dum_int,
                &vm_size, &rss);
    if (num_fields == 24) {
      r_usage.ru_maxrss = rss/page_size;
      r_usage.ru_idrss = vm_size/page_size;
