cgma
mergetest.cc File Reference
#include "iGeom.h"
#include <iostream>
#include <set>
#include <algorithm>
#include <vector>
#include <iomanip>
#include <assert.h>
#include <string.h>
#include <math.h>
Classes
class  SimpleArray< T >
Defines
#define CHECK(STR)   if (err != iBase_SUCCESS) return print_error( STR, err, geom, __FILE__, __LINE__ )
#define STRINGIFY(S)   XSTRINGIFY(S)
#define XSTRINGIFY(S)   #S
#define ARRAY_INOUT(A)   A.ptr(), &A.capacity(), &A.size()
#define ARRAY_IN(A)   &A[0], A.size()
Typedefs
typedef iBase_TagHandle TagHandle
typedef iBase_EntityHandle GentityHandle
typedef iBase_EntitySetHandle GentitysetHandle
Functions
static bool print_error (const char *desc, int err, iGeom_Instance geom, const char *file, int line)
int main (int argc, char *argv[])
Define Documentation
#define ARRAY_IN (   A)    &A[0], A.size()
Definition at line 87 of file mergetest.cc.
#define ARRAY_INOUT (   A)    A.ptr(), &A.capacity(), &A.size()
Definition at line 86 of file mergetest.cc.
#define CHECK (   STR)    if (err != iBase_SUCCESS) return print_error( STR, err, geom, __FILE__, __LINE__ )
Definition at line 18 of file mergetest.cc.
#define STRINGIFY (   S)    XSTRINGIFY(S)
Definition at line 20 of file mergetest.cc.
#define XSTRINGIFY (   S)    #S
Definition at line 21 of file mergetest.cc.
Typedef Documentation
Definition at line 43 of file mergetest.cc.
Definition at line 44 of file mergetest.cc.
Definition at line 42 of file mergetest.cc.
Function Documentation
int main ( int  argc,
char *  argv[]
Definition at line 89 of file mergetest.cc.
    // Check command line arg
  #ifdef FORCE_OCC
    #ifndef HAVE_OCC
      #error "Cannot force use of OCC w/out OCC support"
    #endif
  std::string filename = STRINGIFY(SRCDIR) "/voltest.stp";
  std::string outfile = "merged.occ";
    std::string engine_opt = ";engine=OCC";
  #elif defined(HAVE_OCC)
  #else
    std::cerr << "for facet engine merge is not supported\n";
    return 1;
  #endif
  if (argc == 1) {
    std::cout << "Using default input file: " << filename << std::endl;
    std::cout << "Using default output file: " << outfile << std::endl;
  else if (argc >= 3) {
    filename = argv[1];
    outfile = argv[2];
  else {
    std::cerr << "Usage: " << argv[0] << " [geom_filename] [out file]" << std::endl;
    return 1;
  // initialize  geom
  int err;
  iGeom_Instance geom;
  iGeom_newGeom( engine_opt.c_str(), &geom, &err, engine_opt.length() );
    // Print out Header information
  std::cout << "\n merge utility :\n\n";
  iGeom_load( geom, &filename[0], 0, &err, filename.length(), 0 );
  CHECK( "ERROR : can not load a geometry" );
  iBase_EntitySetHandle root_set;
  iGeom_getRootSet( geom, &root_set, &err );
  CHECK( "ERROR : getRootSet failed!" );
    // print out the number of entities
  std::cout << "Model contents: " << std::endl;
  const char *gtype[] = {"vertices: ", "edges: ", "faces: ", "regions: "};
  for (int i = 0; i <= 3; ++i) {
    int count;
    iGeom_getNumOfType( geom, root_set, i, &count, &err );
    CHECK( "Error: problem getting entities after gLoad." );
    std::cout << gtype[i] << count << std::endl;
  // get volumes, and call merge
  int count;
  iGeom_getNumOfType( geom, root_set, 3, &count, &err );
  CHECK( "Error: problem getting volume numbers after gLoad." );
  SimpleArray<iBase_EntityHandle> vols;
  iGeom_getEntities( geom, root_set, 3, ARRAY_INOUT(vols), &err );
  CHECK( "Error: problem getting volumes." );
  //  now imprint
  std::cout << "\n\nImprinting...." << std::endl;
  iGeom_imprintEnts(geom, ARRAY_IN(vols),&err);
  CHECK( "Error: problem imprinting volumes." );
  std::cout << "\n\nMerging...." << std::endl;
  double dTol = 1e-4;
  iGeom_mergeEnts(geom, ARRAY_IN(vols), dTol, &err);
  CHECK( "Error: problem merging volumes." );
  iGeom_save(geom, outfile.c_str(), NULL, &err,
                strlen(outfile.c_str()), 0);
  CHECK( "Error: problem saving." );
  return 0;
static bool print_error ( const char *  desc,
int  err,
const char *  file,
int  line
) [static]
Definition at line 23 of file mergetest.cc.
  char buffer[1024];
  iGeom_getDescription( geom, buffer, sizeof(buffer) );
  buffer[sizeof(buffer)-1] = '\0';
  std::cerr << "ERROR: " << desc << std::endl
            << "  Error code: " << err << std::endl
            << "  Error desc: " << buffer << std::endl
            << "  At        : " << file << ':' << line << std::endl
  return false; // must always return false or CHECK macro will break
