cgma
CATag.cpp File Reference
#include <algorithm>
#include <iostream>
#include "CATag.hpp"
#include "RefEntity.hpp"
#include "RefEntityName.hpp"
#include "RefEntityFactory.hpp"
#include "CubitAttribManager.hpp"
#include "RefGroup.hpp"
#include "TDUniqueId.hpp"
#include "CGMApp.hpp"
#include "iGeomError.h"
#include "TopologyEntity.hpp"
#include "CubitMessage.hpp"
Classes
class  CSATagData
Defines
#define CHECK_SIZE(array, type, this_size, retval)
#define TAG_CHECK_SIZE(array, allocated, size)
#define RETURN(a)   {CGM_iGeom_setLastError(a); return a;}
Functions
static iBase_ErrorType tag_check_size (char *&array, int &allocated, int size)
Variables
static CGMTagManager::TagInfo preset_tag_list []
Detailed Description
Copyright 2006 Sandia Corporation. Under the terms of Contract DE-AC04-94AL85000 with Sandia Coroporation, the U.S. Government retains certain rights in this software.
This library is free software; you can redistribute it and/or modify it under the terms of the GNU Lesser General Public License as published by the Free Software Foundation; either version 2.1 of the License, or (at your option) any later version.
Author:
Tim Tautges
Jason Kraftcheck
Original file from SNL TSTT repository was named CATag.
Renamed CATag and added to ANL ITAPS repository by J.Kraftcheck, 2007-6-15
Definition in file CATag.cpp.
Define Documentation
#define CHECK_SIZE (   array,
  type,
  this_size,
  retval
Value:
if (0 == array ## _allocated || array ## _allocated < this_size) {\
    if (NULL != array) free(array); \
    array = (type*)malloc(this_size*sizeof(type));\
    array ## _allocated=this_size;\
    if (NULL == array) { \
      CGM_iGeom_setLastError(iBase_MEMORY_ALLOCATION_FAILED);\
      return retval; \
  array ## _size = this_size;
Definition at line 39 of file CATag.cpp.
#define RETURN (   a)    {CGM_iGeom_setLastError(a); return a;}
Definition at line 72 of file CATag.cpp.
#define TAG_CHECK_SIZE (   array,
  allocated,
  size
Value:
if (iBase_ErrorType tag_check_size_tmp = tag_check_size( array, allocated, size )) \
    return tag_check_size_tmp;
Definition at line 68 of file CATag.cpp.
Function Documentation
static iBase_ErrorType tag_check_size ( char *&  array,
int &  allocated,
int  size
) [inline, static]
Definition at line 51 of file CATag.cpp.
  if (!array || !allocated) {
    allocated = size;
    array = (char*)malloc(allocated);
    if (!array)
      return iBase_MEMORY_ALLOCATION_FAILED;
  else if (allocated < size) {
    return iBase_BAD_ARRAY_SIZE;
  return iBase_SUCCESS;
Variable Documentation
Initial value:
 { 0,              "",                 iBase_BYTES,   NULL,  false },
 { 32,             "NAME",             iBase_BYTES,   NULL,   true },
 { sizeof(int),    "GLOBAL_ID",        iBase_INTEGER, NULL,   true },
 { sizeof(int),    "UNIQUE_ID",        iBase_INTEGER, NULL,   true },
 { sizeof(int),    "MESH_INTERVAL",    iBase_INTEGER, NULL,   true },
 { sizeof(double), "MESH_SIZE",        iBase_DOUBLE,  NULL,   true },
 { 4,              "SIZE_FIRMNESS",    iBase_BYTES,   NULL,   true } }
Definition at line 112 of file CATag.cpp.
