cgma
CATag.hpp
00001
00024 #ifndef CA_TAG_HPP
00025 #define CA_TAG_HPP
00026
00027 #include <typeinfo>
00028 #if !defined(_WIN32)
00029 using std::type_info;
00030 #endif
00031
00032 #include "iGeom.h"
00033 #include "CubitAttrib.hpp"
00034 #include "DLIList.hpp"
00035 #include "CubitDefines.h"
00036
00037 #include <string>
00038 #include <map>
00039 #include <vector>
00040
00041 #ifdef ITAPS_SHIM
00042 typedef struct iGeom_Instance_Private *iGeom_Instance;
00043 # include "iGeom_binding.h"
00044 #endif
00045
00046 #define ARRAY_IN_DECL(a, b) \
00047   a const* b, const int b ## _size
00048
00049 #define ARRAY_INOUT_DECL(a, b) \
00050   a **b, int *b ## _allocated, int *b ## _size
00051
00052 class RefEntity;
00053 class RefGroup;
00054 class CATag;
00055
00056 class CGMTagManager
00057 {
00058 public:
00059 #ifdef ITAPS_SHIM
00060   iGeom_vtable *vtable;
00061 #endif
00062
00063   friend class CATag;
00064
00065   ~CGMTagManager();
00066
00067   struct TagInfo
00068   {
00069     int tagLength;
00070     std::string tagName;
00071     int tagType;
00072     char *defaultValue;
00073     bool isActive;
00074   };
00075
00076   static CubitAttrib* CATag_creator(RefEntity* entity, const CubitSimpleAttrib &p_csa);
00077
00078   iBase_ErrorType createTag (/*in*/ const char *tag_name,
00079                              /*in*/ const int tag_size,
00080                              /*in*/ const int tag_type,
00081                              /*in*/ char* default_value,
00082                              /*out*/ long *tag_handle);
00083
00084   iBase_ErrorType destroyTag (/*in*/ const long tag_handle,
00085                               /*in*/ const bool forced);
00086
00087   const char *getTagName (/*in*/ const long tag_handle);
00088
00089   int getTagSize (/*in*/ const long tag_handle);
00090
00091   long getTagHandle (/*in*/ const char *tag_name);
00092
00093   int getTagType (/*in*/ const long tag_handle);
00094
00095   iBase_ErrorType getArrData ( ARRAY_IN_DECL(RefEntity*, entity_handles),
00096                               /*in*/ const long tag_handle,
00097                               /*inout*/ ARRAY_INOUT_DECL(char, tag_value));
00098
00099   iBase_ErrorType setArrData (/*in*/ ARRAY_IN_DECL(RefEntity*, entity_handles),
00100                               /*in*/ const long tag_handle,
00101                               /*in*/ const char *tag_values,
00102                               const int tag_values_size);
00103
00104   iBase_ErrorType rmvArrTag (/*in*/ ARRAY_IN_DECL(RefEntity*, entity_handles),
00105                              /*in*/ const long tag_handle);
00106
00107   iBase_ErrorType getAllTags (/*in*/ const RefEntity* entity_handle,
00108                               /*inout*/ ARRAY_INOUT_DECL(long, tag_handles));
00109
00110   std::vector<RefGroup*> *pc_list(RefEntity *gentity, int list_no,
00111                                   const bool create_if_missing);
00112
00113   void pc_list(RefEntity *gentity, std::vector<RefGroup*> *&parents,
00114                std::vector<RefGroup*> *&children,
00115                const bool create_if_missing);
00116
00117   void get_pc_groups(RefGroup *this_grp, const int p_or_c, const int num_hops,
00118                      std::vector<RefGroup *> &group_ptrs);
00119
00120   iBase_ErrorType create_csa_tag(const char *tag_name, long *tag_handle);
00121
00122   iBase_ErrorType set_csa_tag(RefEntity *this_ent,
00123                               long tag_handle,
00124                               CubitSimpleAttrib *csa_ptr);
00125
00126   static inline CGMTagManager& instance()
00127   {
00128     static CGMTagManager static_instance;
00129     return static_instance;
00130   }
00131
00132 private:
00133   CGMTagManager();
00134
00135   int CATag_att_type;
00136   long pcTag;
00137   std::vector<TagInfo> tagInfo;
00138   static TagInfo* const presetTagInfo;
00139   static const int numPresetTag;
00140   std::map<std::string, long> tagNameMap;
00141   static const char *CATag_NAME;
00142   static const char *CATag_NAME_INTERNAL;
00143   RefGroup *interfaceGroup;
00144
00145   bool getPresetTagData(const RefEntity *entity, const long tag_num,
00146                         char *tag_value, int &tag_size);
00147
00148   iBase_ErrorType setPresetTagData(RefEntity *entity, const long tag_num,
00149                                    const char *tag_value, const int tag_size);
00150
00151   CATag *get_catag(RefEntity *ent,
00152                    const bool create_if_missing = false);
00153
00154   long pc_tag(const bool create_if_missing = false);
00155
00156   RefGroup *interface_group(const bool create_if_missing = true);
00157
00158   CubitSimpleAttrib* get_simple_attrib( RefEntity* entity, const char* name );
00159 };
00160
00161 class CATag: public CubitAttrib
00162 {
00163 private:
00164   friend class CGMTagManager;
00165
00166   std::map<int, void*> tagData;
00167
00168   CGMTagManager *myManager;
00169
00170   CATag(CGMTagManager *manager, RefEntity *owner);
00171
00172   CATag(CGMTagManager *manager, RefEntity *owner, CubitSimpleAttrib *csa_ptr);
00173     //- create a CATag from a simple attribute
00174
00175 public:
00176
00177   virtual ~CATag();
00178
00179     //HEADER- RTTI and safe casting functions.
00180   virtual const type_info& entity_type_info() const
00181     { return typeid(CATag);}
00182     //R- The geometric modeler type
00183     //- This function returns the type of the geometric modeler.
00184
00185   CubitStatus actuate() {return CUBIT_SUCCESS;}
00186
00187   CubitStatus update();
00188
00189   CubitStatus reset();
00190
00191   CubitSimpleAttrib split_owner() { CubitSimpleAttrib sa; return sa; }
00192
00193   void merge_owner(CubitAttrib *deletable_attrib) {}
00194
00195   CubitSimpleAttrib cubit_simple_attrib();
00196
00197   int int_attrib_type() {return myManager->CATag_att_type;}
00198
00199   void add_csa_data(CubitSimpleAttrib *csa_ptr);
00200
00201   void print();
00202
00203   iBase_ErrorType get_tag_data(long tag_num, void *tag_data);
00204
00205   iBase_ErrorType set_tag_data(long tag_num, const void *tag_data,
00206                                const bool can_shallow_copy = false);
00207
00208   void remove_tag(long tag_num);
00209 };
00210
00211 #endif
00212
