cgma
CubitSimpleAttrib Class Reference
#include <CubitSimpleAttrib.hpp>
List of all members.
Public Member Functions
bool isEmpty () const
 CubitSimpleAttrib ()
 CubitSimpleAttrib (const CubitString new_character_type, const CubitString new_string_data=CubitString(), const CubitString new_more_string_data=CubitString(), const int *new_integer_data=NULL, const double *new_double_data=NULL)
 CubitSimpleAttrib (const std::vector< CubitString > *string_list, const std::vector< double > *double_list=NULL, const std::vector< int > *int_list=NULL)
 CubitSimpleAttrib (const CubitSimpleAttrib &csa_ptr)
 ~CubitSimpleAttrib ()
CubitSimpleAttriboperator= (const CubitSimpleAttrib &other)
CubitString character_type () const
const std::vector< CubitString > & string_data_list () const
void string_data_list (const std::vector< CubitString > &new_list)
const std::vector< double > & double_data_list () const
void double_data_list (const std::vector< double > &new_list)
const std::vector< int > & int_data_list () const
void int_data_list (const std::vector< int > &new_list)
bool operator== (const CubitSimpleAttrib &other) const
void print () const
Static Public Member Functions
static void initialize_settings ()
static CubitBoolean get_push_attribs ()
static void set_push_attribs (CubitBoolean flag)
Private Attributes
std::vector< CubitStringstringDataList
std::vector< double > doubleDataList
std::vector< int > intDataList
Static Private Attributes
static CubitBoolean pushAttribs = CUBIT_FALSE
Detailed Description
Definition at line 23 of file CubitSimpleAttrib.hpp.
Definition at line 21 of file CubitSimpleAttrib.cpp.
CubitSimpleAttrib::CubitSimpleAttrib ( const CubitString  new_character_type,
const CubitString  new_string_data = CubitString(),
const CubitString  new_more_string_data = CubitString(),
const int *  new_integer_data = NULL,
const double *  new_double_data = NULL
) [explicit]
Definition at line 29 of file CubitSimpleAttrib.cpp.
  assert(new_character_type.length() > 0);
  stringDataList.push_back(new_character_type);
  if (new_string_data.length()) {
    stringDataList.push_back(new_string_data);
  if (new_more_string_data.length()) {
    stringDataList.push_back(new_more_string_data);
  if(new_double_data)
    doubleDataList.push_back( *new_double_data );
  if(new_integer_data)
    intDataList.push_back( *new_integer_data );
  return;
CubitSimpleAttrib::CubitSimpleAttrib ( const std::vector< CubitString > *  string_list,
const std::vector< double > *  double_list = NULL,
const std::vector< int > *  int_list = NULL
) [explicit]
Definition at line 69 of file CubitSimpleAttrib.cpp.
  if(string_list)
    this->stringDataList = *string_list;
  if(double_list)
    this->doubleDataList = *double_list;
  if(int_list)
    this->intDataList = *int_list;
Definition at line 62 of file CubitSimpleAttrib.cpp.
  this->stringDataList = csa_ptr.stringDataList;
  this->doubleDataList = csa_ptr.doubleDataList;
  this->intDataList = csa_ptr.intDataList;
Definition at line 25 of file CubitSimpleAttrib.cpp.
Member Function Documentation
Definition at line 90 of file CubitSimpleAttrib.cpp.
  if(stringDataList.size() >= 1 )
    return stringDataList[0];
  return CubitString();
const std::vector<double>& CubitSimpleAttrib::double_data_list ( ) const [inline]
Definition at line 74 of file CubitSimpleAttrib.hpp.
{return doubleDataList;}
std::vector<double>& CubitSimpleAttrib::double_data_list ( ) [inline]
Definition at line 75 of file CubitSimpleAttrib.hpp.
void CubitSimpleAttrib::double_data_list ( const std::vector< double > &  new_list)
Definition at line 104 of file CubitSimpleAttrib.cpp.
  doubleDataList = new_list;
Definition at line 91 of file CubitSimpleAttrib.hpp.
{return pushAttribs;};
const std::vector<int>& CubitSimpleAttrib::int_data_list ( ) const [inline]
Definition at line 79 of file CubitSimpleAttrib.hpp.
{return intDataList;}
std::vector<int>& CubitSimpleAttrib::int_data_list ( ) [inline]
Definition at line 80 of file CubitSimpleAttrib.hpp.
void CubitSimpleAttrib::int_data_list ( const std::vector< int > &  new_list)
Definition at line 109 of file CubitSimpleAttrib.cpp.
  intDataList = new_list;
Definition at line 55 of file CubitSimpleAttrib.cpp.
  return stringDataList.empty() &&
      doubleDataList.empty() &&
      intDataList.empty();
CubitSimpleAttrib & CubitSimpleAttrib::operator= ( const CubitSimpleAttrib other)
Definition at line 82 of file CubitSimpleAttrib.cpp.
    this->stringDataList = other.stringDataList;
    this->intDataList = other.intDataList;
    this->doubleDataList = other.doubleDataList;
    return *this;
bool CubitSimpleAttrib::operator== ( const CubitSimpleAttrib other) const
Definition at line 114 of file CubitSimpleAttrib.cpp.
  return this->stringDataList == other.stringDataList &&
         this->doubleDataList == other.doubleDataList &&
         this->intDataList == other.intDataList;
void CubitSimpleAttrib::print ( ) const
Definition at line 131 of file CubitSimpleAttrib.cpp.
  PRINT_INFO("CSA: type = %s\n", stringDataList[0].c_str());
  PRINT_INFO("String data: ");
  for ( size_t i=1; i<stringDataList.size(); i++)
    PRINT_INFO("%s;", stringDataList[i].c_str());
  if (stringDataList.size() == 0)
    PRINT_INFO("(none)");
  PRINT_INFO("\n");
  PRINT_INFO("Int data: ");
  for (size_t i=0; i<intDataList.size(); i++)
    PRINT_INFO("%d;", intDataList[i]);
  if (intDataList.size() == 0)
  PRINT_INFO("\n");
  PRINT_INFO("Double data: ");
  for (size_t i=0; i<doubleDataList.size(); i++)
    PRINT_INFO("%f;", doubleDataList[i]);
  if (doubleDataList.size() == 0)
  PRINT_INFO("\n");
static void CubitSimpleAttrib::set_push_attribs ( CubitBoolean  flag) [inline, static]
Definition at line 92 of file CubitSimpleAttrib.hpp.
{pushAttribs = flag;};
const std::vector<CubitString>& CubitSimpleAttrib::string_data_list ( ) const [inline]
Definition at line 69 of file CubitSimpleAttrib.hpp.
{return stringDataList;}
Definition at line 70 of file CubitSimpleAttrib.hpp.
void CubitSimpleAttrib::string_data_list ( const std::vector< CubitString > &  new_list)
Definition at line 99 of file CubitSimpleAttrib.cpp.
  this->stringDataList = new_list;
Member Data Documentation
std::vector<double> CubitSimpleAttrib::doubleDataList [private]
Definition at line 28 of file CubitSimpleAttrib.hpp.
std::vector<int> CubitSimpleAttrib::intDataList [private]
Definition at line 30 of file CubitSimpleAttrib.hpp.
Definition at line 32 of file CubitSimpleAttrib.hpp.
Definition at line 26 of file CubitSimpleAttrib.hpp.
