cgma
CubitSimpleAttrib.hpp
00001 //- Class: CubitSimpleAttrib
00002 //- Owner: Greg Nielson
00003 //- Description: This class is used to carry information from
00004 //-              the cubit attribute classes to the solid model
00005 //-               attributes.
00006 //- Checked By:
00007 //- Version: $Id:
00008
00009 #ifndef CUBIT_SIMPLE_ATTRIB_HPP
00010 #define CUBIT_SIMPLE_ATTRIB_HPP
00011
00012 #if defined(_MSC_VER)
00013 #pragma warning(push)
00014 #pragma warning(disable : 4251)  // hide warnings about template dll exports
00015 #endif
00016
00017 #include "CubitString.hpp"
00018 #include "CubitDefines.h"
00019 #include <vector>
00020 #include "CGMGeomConfigure.h"
00021 #include <new>
00022
00023 class CUBIT_GEOM_EXPORT CubitSimpleAttrib {
00024 private:
00025
00026   std::vector<CubitString> stringDataList;  // List of CubitString attribute data
00027
00028   std::vector<double> doubleDataList;  // List of double attribute data
00029
00030   std::vector<int> intDataList;  // List of int attribute data
00031
00032   static CubitBoolean pushAttribs;
00033     //- if true, when saving attributes, push them to non-primary bridges
00034     //- on merged ref entities
00035
00036 public:
00037
00038   // returns whether this CSA is valid (it is invalid if the data is empty)
00039   bool isEmpty() const;
00040
00041   CubitSimpleAttrib();
00042   //- default constructor
00043
00044   explicit CubitSimpleAttrib(const CubitString new_character_type,
00045                              const CubitString new_string_data = CubitString(),
00046                              const CubitString new_more_string_data = CubitString(),
00047                              const int* new_integer_data = NULL,
00048                              const double* new_double_data = NULL);
00049   //- constructor
00050
00051   explicit CubitSimpleAttrib(const std::vector<CubitString> *string_list,
00052                              const std::vector<double> *double_list = NULL,
00053                              const std::vector<int> *int_list = NULL);
00054   //- constructor
00055
00056   CubitSimpleAttrib(const CubitSimpleAttrib& csa_ptr);
00057     //- copy constructor, sort of
00058
00059   ~CubitSimpleAttrib();
00060    //- destructor
00061
00062   CubitSimpleAttrib& operator=(const CubitSimpleAttrib &other);
00063
00064   CubitString character_type() const;
00065   //- returns the type of attribute from the first item in the string list
00066
00067   static void initialize_settings();
00068
00069   const std::vector<CubitString>& string_data_list() const {return stringDataList;}
00070   std::vector<CubitString>& string_data_list() {return stringDataList;}
00071
00072   void string_data_list( const std::vector<CubitString>& new_list);
00073
00074   const std::vector<double>& double_data_list() const {return doubleDataList;}
00075   std::vector<double>& double_data_list() {return doubleDataList;}
00076
00077   void double_data_list(const std::vector<double>& new_list);
00078
00079   const std::vector<int>& int_data_list() const {return intDataList;}
00080   std::vector<int>& int_data_list() {return intDataList;}
00081
00082   void int_data_list(const std::vector<int>& new_list);
00083
00084
00085   bool operator==(const CubitSimpleAttrib& other) const;
00086     //- return true if the two csa's are equivalent
00087
00088   void print() const;
00089     //- print the contents of this simpleattrib
00090
00091   static CubitBoolean get_push_attribs() {return pushAttribs;};
00092   static void set_push_attribs(CubitBoolean flag) {pushAttribs = flag;};
00093     //- get/set pushAttribs
00094
00095 };
00096
00097
00098 #if defined(_MSC_VER)
00099 #pragma warning(pop)
00100 #endif
00101
00102 #endif
00103
00104
00105
00106
00107
00108
00109
00110
