cgma
split_circle.cpp File Reference
split_circle, another simple C++ driver for CGM More...
#include <cassert>
#include <iostream>
#include "GeometryModifyTool.hpp"
#include "GeometryQueryTool.hpp"
#include "CubitMessage.hpp"
#include "RefEdge.hpp"
#include "RefVertex.hpp"
#include "CastTo.hpp"
#include "InitCGMA.hpp"
#include "CubitCompat.hpp"
#include "Point.hpp"
Defines
#define SRCDIR   .
#define STRINGIFY_(X)   #X
#define STRINGIFY(X)   STRINGIFY_(X)
#define SRCPATH   STRINGIFY(SRCDIR) "/"
#define PRINT_SEPARATOR   PRINT_INFO("=======================================\n");
Functions
CubitStatus split_circle ()
int main (int argc, char **argv)
Detailed Description
This program acts as a simple driver for CGM. It reads in a geometry, and performs varies checks for bodies, surfaces, curves and vertices.
Definition in file split_circle.cpp.
Define Documentation
Definition at line 34 of file split_circle.cpp.
#define SRCDIR   .
Definition at line 24 of file split_circle.cpp.
Definition at line 29 of file split_circle.cpp.
#define STRINGIFY (   X)    STRINGIFY_(X)
Definition at line 28 of file split_circle.cpp.
#define STRINGIFY_ (   X)    #X
Definition at line 27 of file split_circle.cpp.
Function Documentation
int main ( int  argc,
char **  argv
Definition at line 39 of file split_circle.cpp.
  CubitStatus status = InitCGMA::initialize_cgma("OCC");
  if (CUBIT_SUCCESS != status) return 1;
  status = split_circle();
  if (status == CUBIT_FAILURE)
     PRINT_INFO("Operation Failed");
  int ret_val = ( CubitMessage::instance()->error_count() );
  if ( ret_val != 0 )
    PRINT_ERROR("Errors found during Mergechk session.\n");
  else
    ret_val = 0;
  return ret_val;
Definition at line 60 of file split_circle.cpp.
  GeometryQueryTool *gti = GeometryQueryTool::instance();
  GeometryModifyTool *gmti = GeometryModifyTool::instance();
  CubitVector center(0,0,0);
  CubitVector plane (0,0,1);
  RefEdge* re = gmti->create_arc(center, 3, 0, 360, plane);
  double length = re->measure();
  std::cout << "Cicle's parameter = " << length << "\n";
  CubitVector p1(0,3,0), p2(3, 0, 0), p3(0, -3, 0);
  RefVertex* v1 = gmti->make_RefVertex(p1);
  RefVertex* v2 = gmti->make_RefVertex(p2);
  RefVertex* v3 = gmti->make_RefVertex(p3);
  RefEdge* re = gmti->create_arc_three(v1, v2, v3, true);
  //Curve* curve = re->get_curve_ptr() ;
  CubitVector point(0, 3, 0);
  DLIList<CubitVector> sp_pts;
  sp_pts.append(point);
  DLIList<RefEdge*> new_ref_edges;
  gmti->split_free_curve(re, sp_pts, new_ref_edges);
  DLIList<RefEntity*>  free_entities;
  gti->get_free_ref_entities(free_entities);
  int count = 0;
  for(int i = 0; i < free_entities.size(); i++)
    RefEdge* ref_edge = dynamic_cast<RefEdge*> (free_entities.get_and_step());
    if (ref_edge)
      double d = ref_edge->measure();
      std::cout << "edge length = " << d << "\n";
      count++;
  assert( count == 2);
  std::cout << "number of free edges: " << count << " <---should be 2 free edges."<<"\n";
  return CUBIT_SUCCESS;
