cgma
CubitDirIterator Class Reference
#include <CubitDirIterator.hpp>
List of all members.
Classes
struct  Helper
Public Member Functions
 CubitDirIterator (const CubitString &path, const CubitString &pattern_match="")
virtual ~CubitDirIterator ()
void open (const CubitString &path, const CubitString &pattern_match="")
bool has_next ()
CubitString next ()
Protected Member Functions
void cleanup ()
Protected Attributes
HelpermHelper
CubitString mPattern
bool mDirs
bool atEnd
Detailed Description
Definition at line 11 of file CubitDirIterator.hpp.
CubitDirIterator::CubitDirIterator ( const CubitString path,
const CubitString pattern_match = ""
Definition at line 46 of file CubitDirIterator.cpp.
  this->mHelper = new Helper;
  open(path, pattern);
Definition at line 52 of file CubitDirIterator.cpp.
  cleanup();
  delete this->mHelper;
Member Function Documentation
void CubitDirIterator::cleanup ( ) [protected]
Definition at line 93 of file CubitDirIterator.cpp.
#ifdef _WIN32
  if(this->mHelper->mFileHandle != 0)
    FindClose(this->mHelper->mFileHandle);
  this->mHelper->mFileHandle = 0;
#else
  if(this->mHelper->mDirHandle)
    closedir(this->mHelper->mDirHandle);
  this->mHelper->mDirHandle = 0;
#endif
Definition at line 107 of file CubitDirIterator.cpp.
  return !this->atEnd;
Definition at line 112 of file CubitDirIterator.cpp.
  CubitString file;
  if(this->atEnd)
    return file;
#ifdef _WIN32
  file = CubitString::toUtf8(this->mHelper->mDirHandle.cFileName);
  BOOL result = FindNextFileW(this->mHelper->mFileHandle, &this->mHelper->mDirHandle);
  if(result == 0)
    this->atEnd = true;
#else
  file = this->mHelper->mFileHandle->d_name;
  do
    this->mHelper->mFileHandle = readdir(this->mHelper->mDirHandle);
  } while (this->mHelper->mFileHandle &&
           (mPattern.length() != 0 &&
           fnmatch(mPattern.c_str(), this->mHelper->mFileHandle->d_name, 0))
  if(this->mHelper->mFileHandle == 0)
    this->atEnd = true;
#endif
  return file;
void CubitDirIterator::open ( const CubitString path,
Definition at line 58 of file CubitDirIterator.cpp.
  cleanup();
  if(pattern.length())
    mPattern = pattern;
  else
    mPattern = "";
  this->atEnd = false;
#ifdef _WIN32
  CubitString p = path;
  if (p.get_at(p.length()-1) != '\\')
    p += "\\";
  p += mPattern.length() == 0 ? "*" : mPattern;
  this->mHelper->mFileHandle = FindFirstFileW(CubitString::toUtf16(p).c_str(), &this->mHelper->mDirHandle);
  if(this->mHelper->mFileHandle == INVALID_HANDLE_VALUE)
    this->atEnd = true;
#else
  this->mHelper->mDirHandle = opendir(path.c_str());
    do
  if(!this->mHelper->mDirHandle || !this->mHelper->mFileHandle)
    this->atEnd = true;
#endif
Member Data Documentation
bool CubitDirIterator::atEnd [protected]
Definition at line 26 of file CubitDirIterator.hpp.
bool CubitDirIterator::mDirs [protected]
Definition at line 25 of file CubitDirIterator.hpp.
Definition at line 22 of file CubitDirIterator.hpp.
Definition at line 24 of file CubitDirIterator.hpp.
