cgma
FacetGeometryCreator Class Reference
#include <FacetGeometryCreator.hpp>
List of all members.
Public Member Functions
 FacetGeometryCreator ()
 FacetGeometryCreator (DLIList< FacetEntity * > &face_list, DLIList< FacetEntity * > &edge_list, DLIList< FacetEntity * > &point_list)
 ~FacetGeometryCreator ()
void print_me ()
void print_me ()
Private Member Functions
void set_up_tool_datas ()
void delete_tool_datas ()
CubitStatus create_volume_boundaries (DLIList< FacetSurfaceMesh * > &facet_surface_sheets, CubitBoolean use_feature_angle, double min_dot, CubitBoolean split_surfaces)
CubitStatus create_surface_boundaries (DLIList< FacetSurfaceMesh * > &facet_surface_list, DLIList< FacetCurveMesh * > &facet_curve_list, CubitBoolean use_feature_angle, double min_dot)
CubitStatus create_curve_boundaries (DLIList< FacetCurveMesh * > &facet_curve_list, DLIList< FacetPointMesh * > &facet_point_list)
CubitStatus classify_edge (FacetEntity *edge_ptr, DLIList< FacetCurveMesh * > &facet_curve_list, FacetSurfaceMesh *fsm_ptr)
CubitStatus classify_point (CubitPoint *point_ptr, DLIList< FacetPointMesh * > &facet_point_list, FacetCurveMesh *fcm_ptr)
CubitStatus build_geometry (DLIList< FacetSurfaceMesh * > &facet_surface_list, DLIList< FacetCurveMesh * > &facet_curve_list, DLIList< FacetPointMesh * > &facet_point_list, int interp_order, CubitBoolean use_feature_angle, double min_dot, CubitBoolean smooth_non_manifold, CubitBoolean split_surfaces)
CubitStatus build_point_geometry (DLIList< FacetPointMesh * > &facet_point_list)
CubitStatus build_curve_geometry (DLIList< FacetCurveMesh * > &facet_curve_list)
CubitStatus build_loop_geometry (DLIList< FacetCurveMesh * > &facet_curve_list, FacetSurfaceMesh *fsm_ptr, DLIList< LoopSM * > &loop_list, int &ncurves)
CubitStatus build_surface_geometry (DLIList< FacetSurfaceMesh * > &facet_surface_list, int interp_order, double min_dot)
CubitStatus init_hash_curves ()
void delete_hash_curves ()
int get_curve_hash_key (DLIList< FacetSurfaceMesh * > *bsm_list_ptr)
CubitStatus init_hash_points ()
void delete_hash_points ()
int get_point_hash_key (DLIList< FacetCurveMesh * > *bsm_list_ptr)
CubitStatus clean_geometry (CubitBoolean smooth_non_manifold, CubitBoolean split_surfaces, CubitBoolean use_feature_angle, double min_dot, DLIList< FacetCurveMesh * > &facet_curve_list)
Private Attributes
DLIList< FacetEntity * > faceList
DLIList< FacetEntity * > edgeList
DLIList< FacetEntity * > pointList
DLIList< FacetSurfaceMesh * > facetSurfaceList
DLIList< FacetCurveMesh * > facetCurveList
DLIList< FacetPointMesh * > facetPointList
DLIList< FacetCurveMesh * > * hashCurveArray
int hashCurveSize
DLIList< FacetPointMesh * > * hashPointArray
int hashPointSize
Detailed Description
Definition at line 33 of file FacetGeometryCreator.hpp.
FacetGeometryCreator::FacetGeometryCreator ( DLIList< FacetEntity * > &  face_list,
DLIList< FacetEntity * > &  edge_list,
DLIList< FacetEntity * > &  point_list
Definition at line 51 of file FacetGeometryCreator.cpp.
  faceList = face_list;
  edgeList = edge_list;
  pointList = point_list;
  set_up_tool_datas();
  hashCurveArray = NULL;
  hashCurveSize = 0;
  hashPointArray = NULL;
  hashPointSize = 0;
Definition at line 111 of file FacetGeometryCreator.cpp.
  delete_tool_datas();
  int ii;
    //clean up any data remaining.
  for (ii = facetPointList.size(); ii > 0; ii-- )
    delete facetPointList.remove();
  for (ii = facetCurveList.size(); ii > 0; ii-- )
    delete facetCurveList.remove();
  for (ii = facetSurfaceList.size(); ii > 0; ii-- )
    delete facetSurfaceList.remove();
Member Function Documentation
CubitStatus FacetGeometryCreator::build_curve_geometry ( DLIList< FacetCurveMesh * > &  facet_curve_list) [private]
Definition at line 803 of file FacetGeometryCreator.cpp.
  CubitStatus stat = CUBIT_SUCCESS;
  int kk;
  for ( kk = facet_curve_list.size(); kk > 0; kk-- )
    FacetCurveMesh *fcm_ptr = facet_curve_list.get_and_step();
    Curve *curv_ptr = fcm_ptr->get_geometric_curve();
    if (curv_ptr == NULL)
      DLIList<FacetPointMesh*> fpoint_list = fcm_ptr->get_points( );
      FacetPointMesh *fpm0_ptr = fpoint_list.get_and_step();
      FacetPointMesh *fpm1_ptr = fpoint_list.get_and_step();
      CubitPoint *start_point, *end_point;
      fcm_ptr->get_ends( start_point, end_point );
      if (fpm0_ptr->get_facets() != start_point)
        FacetPointMesh *temp_ptr;
        temp_ptr = fpm0_ptr;
        fpm0_ptr = fpm1_ptr;
        fpm1_ptr = temp_ptr;
      PointSM *start_ptr = (PointSM *) fpm0_ptr->get_geometric_point();
      PointSM *end_ptr = (PointSM *) fpm1_ptr->get_geometric_point();
      // if this is a curve without a parent surface then handle it
      // differently.  (Curves with parents use the surface to evaluate to
      // With only a curve, it must evaluate to the curve)
      DLIList<FacetSurfaceMesh*> fsm_list = fcm_ptr->get_surfaces();
      if (fsm_list.size() == 0)
        DLIList<FacetEntity*> facet_list;
        DLIList<CubitPoint*> point_list;  // needs to be filled in
        facet_list = fcm_ptr->get_facets();
        DLIList<CubitFacetEdge*> edge_list;
        CAST_LIST( facet_list, edge_list, CubitFacetEdge );
        if (stat != CUBIT_SUCCESS)
          return stat;
        stat = FacetQueryEngine::instance()->make_facet_curve( start_ptr, end_ptr,
        edge_list, point_list,
        curv_ptr );
        if (stat == CUBIT_SUCCESS)
          CurveSM *curvsm_ptr = CAST_TO( curv_ptr, CurveSM );
          GeometryQueryTool::instance()->make_free_RefEdge( curvsm_ptr );
      else
        curv_ptr );
        if ( curv_ptr == NULL || stat != CUBIT_SUCCESS )
          PRINT_ERROR("Problems building mesh based curves.\n");
          return stat;
      fcm_ptr->assign_geometric_curve(curv_ptr);
  return stat;
CubitStatus FacetGeometryCreator::build_geometry ( DLIList< FacetSurfaceMesh * > &  facet_surface_list,
DLIList< FacetCurveMesh * > &  facet_curve_list,
DLIList< FacetPointMesh * > &  facet_point_list,
int  interp_order,
double  min_dot,
) [private]
Definition at line 741 of file FacetGeometryCreator.cpp.
  stat = build_point_geometry( facet_point_list );
    stat = build_curve_geometry( facet_curve_list );
    stat = build_surface_geometry( facet_surface_list,
                                   interp_order, min_dot );
    if (interp_order == 4)
      stat = clean_geometry( smooth_non_manifold, split_surfaces,
                           use_feature_angle, min_dot, facet_curve_list );
  return stat;
int  interp_order,
double  min_dot,
) [private]
CubitStatus FacetGeometryCreator::build_loop_geometry ( DLIList< FacetCurveMesh * > &  facet_curve_list,
FacetSurfaceMesh *  fsm_ptr,
DLIList< LoopSM * > &  loop_list,
int &  ncurves
) [private]
Definition at line 872 of file FacetGeometryCreator.cpp.
  // find the first unused curve on the list.  Use that as the starting curve
  // in the loop
  ncurves = 0;
  int ii, jj;
  int found = 0;
  FacetCurveMesh *fcm_ptr = NULL;
  for(ii=0; ii<facet_curve_list.size() && !found; ii++)
    if (fcm_ptr->get_flag() == 0)
      found = 1;
  if (!found)
    return CUBIT_FAILURE;  // all the curves have already been used in this surface
  // get the first mesh edge on the first curve. use it to determine the
  // orientation of the curve with respect to the surface
  DLIList<FacetEntity*> facet_list = fcm_ptr->get_facets();
  FacetEntity *facet_ptr = facet_list.get();
  CubitFacetEdge *edge_ptr = CAST_TO( facet_ptr, CubitFacetEdge );
  if (!edge_ptr)
    return CUBIT_FAILURE; // facet edges are not on the list ????
  // get the adjacent face on this surface
  DLIList<FacetEntity*> adj_face_list;
  FacetEntity *face_ptr = NULL;
  edge_ptr->get_parents( adj_face_list );
  found = 0;
  for ( jj = 0; jj < adj_face_list.size() && !found; jj++ )
    face_ptr = adj_face_list.get_and_step();
    TDGeomFacet *td_gm_face = TDGeomFacet::get_geom_facet(face_ptr);
    DLIList<FacetSurfaceMesh*> fsurf_list;
    td_gm_face->get_facet_surfs( fsurf_list );
    FacetSurfaceMesh *face_fsm_ptr = fsurf_list.get();
    if(face_fsm_ptr == fsm_ptr)
      found = 1;
  if (!found)
    return CUBIT_FAILURE;  // didn't find an adj face on the surface ???
  // determine orientation of nodes on this mesh face
  CubitPoint *start_ptr, *end_ptr;
  fcm_ptr->get_ends( start_ptr, end_ptr );
  end_ptr = edge_ptr->other_point( start_ptr );
  if (end_ptr == NULL)
    return CUBIT_FAILURE;  // the edge list may not be ordered correctly??
  CubitPoint *points[3];
  CubitFacet *tri_ptr = CAST_TO( face_ptr, CubitFacet );
  tri_ptr->points( points[0], points[1], points[2] );
  found = 0;
  CubitSense orientation;
  for ( jj = 0; jj < 3 && !found; jj++ )
    if (points[jj] == start_ptr)
      int next_jj = (jj + 1)%3;
      int prev_jj = (jj + 2)%3;
      if(points[next_jj] == end_ptr)
        found = 1;
        orientation = CUBIT_FORWARD;
      else if(points[prev_jj] == end_ptr)
        found = 1;
        orientation = CUBIT_REVERSED;
  if (!found)
    return CUBIT_FAILURE;  // couldn't determine the orientation
  // create a new coedge
  CoEdgeSM *coedge_ptr = NULL;
  stat = GeometryModifyTool::instance()->make_facet_coedge( (CurveSM*)curv_ptr, orientation,
                                                      coedge_ptr );
  if ( coedge_ptr == NULL || stat != CUBIT_SUCCESS )
    PRINT_ERROR("Problems building mesh based coedges.\n");
    return stat;
  // start a list of coedges for this loop
  DLIList<CoEdgeSM*> coedge_list;
  coedge_list.append( coedge_ptr );
  fcm_ptr->set_flag(1);
  FacetCurveMesh *last_fcm_ptr = fcm_ptr;
  // loop through and determine the rest of the coedges based on the
  // orientation of the first curve in the loop
  FacetEntity *n0_ptr, *n1_ptr;
  if (orientation == CUBIT_FORWARD)
    n0_ptr = start_ptr;
    n1_ptr = end_ptr;
  else
    n1_ptr = start_ptr;
    n0_ptr = end_ptr;
  while (n0_ptr != n1_ptr)
    // find the next curve in the loop
    int ntimes = 0;
    found = 0;
    while(!found)
      for ( jj = 0; jj < facet_curve_list.size() && !found; jj++)
        if (last_fcm_ptr != fcm_ptr && (fcm_ptr->get_flag() == 0 || ntimes > 0))
          if (start_ptr == n1_ptr)
            found = 1;
            n1_ptr = end_ptr;
          else if (end_ptr == n1_ptr)
            found = 1;
            n1_ptr = start_ptr;
      if (!found)
        // in this special case - we have gone through the whole list without
        // finding the next curve on the loop.  In the first pass we have assumed
        // that each curve is only used once.  This may not be the case.  Go
        // back and see of we can find a curve that has already been used that
        // will work.  If we fail the second time through, then we fail!
        ntimes++;
        if (ntimes > 1)
          // return CUBIT_FAILURE;  // didn't find the next curve in the loop
          // DEBUG ONLY -- THIS NEEDS TO BE FIXED
          goto create_loop;
    coedge_ptr = NULL;
                                                         coedge_ptr );
      return stat;
    if (coedge_list.size() > 2*facet_curve_list.size())
      return CUBIT_FAILURE;  // more curves in the loop than their are curves ????
  // create the loop
create_loop:
  LoopSM *loop_ptr = NULL;
  stat = GeometryModifyTool::instance()->make_facet_loop( coedge_list, loop_ptr );
    PRINT_ERROR("Problems building mesh based loops.\n");
    return stat;
  loop_list.append( loop_ptr );
  ncurves = coedge_list.size();
  return stat;
int &  ncurves
) [private]
CubitStatus FacetGeometryCreator::build_point_geometry ( DLIList< FacetPointMesh * > &  facet_point_list) [private]
Definition at line 772 of file FacetGeometryCreator.cpp.
  int kk;
  for ( kk = facet_point_list.size(); kk > 0; kk-- )
    FacetPointMesh *fpm_ptr = facet_point_list.get_and_step();
    Point *point_ptr = fpm_ptr->get_geometric_point();
    if (point_ptr == NULL)
      FacetEntity *facet_ptr = fpm_ptr->get_facets();
      CubitPoint *cp_ptr = CAST_TO( facet_ptr, CubitPoint );
      PointSM *point = NULL;
      stat = GeometryModifyTool::instance()->make_facet_point( cp_ptr, point );
      if ( point == NULL || stat != CUBIT_SUCCESS )
        PRINT_ERROR("Problems building mesh based points.\n");
        return stat;
      point_ptr = (Point *)point;
      fpm_ptr->assign_geometric_point(point_ptr);
  return stat;
CubitStatus FacetGeometryCreator::build_surface_geometry ( DLIList< FacetSurfaceMesh * > &  facet_surface_list,
int  interp_order,
double  min_dot
) [private]
Definition at line 1081 of file FacetGeometryCreator.cpp.
  int ii, kk;
  // make sure the facet flags have been reset
  FacetCurveMesh *fcm_ptr;
  for ( kk = facet_surface_list.size(); kk > 0; kk-- )
    FacetSurfaceMesh *fsm_ptr = facet_surface_list.get_and_step();
    fsm_ptr->reset_facet_flags();
  // now loop through surfaces and create them
  int mydebug = 0;
    int num_curves = 0;
    DLIList<FacetCurveMesh*> fcurve_list;
    fsm_ptr->get_curves( fcurve_list );
    // init flags for curves on this surface
    for (ii=0; ii< fcurve_list.size(); ii++)
      fcm_ptr = fcurve_list.get_and_step();
      fcm_ptr->set_flag(0);
      if (mydebug)
        fcm_ptr->draw();
    // generate loops - keep going until we have used all the curves in the list
    DLIList<LoopSM*> loop_list;
    while (num_curves < fcurve_list.size())
      int ncurves = 0;
      stat = build_loop_geometry( fcurve_list, fsm_ptr, loop_list, ncurves );
        PRINT_ERROR("Can't build geometric loop from facets\n");
        return stat;
      num_curves += ncurves;
    // create the surface
    Surface *surf_ptr = fsm_ptr->get_geometric_surface();
    if (surf_ptr == NULL)
      DLIList<FacetEntity*> facet_entity_list;
      fsm_ptr->get_points(point_list);
      fsm_ptr->get_facets(facet_entity_list);
      DLIList<CubitFacet*> facet_list;
      CAST_LIST( facet_entity_list, facet_list, CubitFacet );
      stat = GeometryModifyTool::instance()->make_facet_surface(facet_list,
        point_list,
        loop_list,
        interp_order,
        min_dot,
        surf_ptr);
      if ( surf_ptr == NULL || stat != CUBIT_SUCCESS )
        PRINT_ERROR("Problems building mesh based surfaces.\n");
        return stat;
      fsm_ptr->assign_geometric_surface(surf_ptr);
  return stat;
int  interp_order,
double  min_dot
) [private]
CubitStatus FacetGeometryCreator::classify_edge ( FacetEntity edge_ptr,
) [private]
Definition at line 434 of file FacetGeometryCreator.cpp.
  CubitStatus rv = CUBIT_SUCCESS;
  // see if we have already classified this edge (from another surface)
  TDGeomFacet *td_gm_edge = TDGeomFacet::get_geom_facet(edge_ptr);
  if (td_gm_edge->get_hit_flag() != 0)
    return rv;
  td_gm_edge->set_hit_flag(1);
  // get the surfaces adjacent to this edge
  DLIList<FacetSurfaceMesh*> this_fsurf_list;
  td_gm_edge->get_facet_surfs( this_fsurf_list );
  int this_num_adj = this_fsurf_list.size();
  // see if the surfaces defined on this face match any
  // of the existing block curves
  DLIList<FacetSurfaceMesh*> *fsurf_list_ptr;
  int found = 0;
  int key = get_curve_hash_key( &this_fsurf_list );
  int ii;
  for (ii=0; ii<hashCurveArray[key].size() && !found; ii++)
    fcm_ptr = hashCurveArray[key].get();
    // the first one checked should be the same as the last one checked (don't
    // use get_and_step here)  This should speed things up
    // check if surfaces are the same
    fsurf_list_ptr = fcm_ptr->get_surface_list_ptr( );
    int num_adj = fsurf_list_ptr->size();
    if (num_adj == this_num_adj)
      found = 1;
      int jj, kk;
      for (jj=fsurf_list_ptr->size(); jj>0 && found; jj--)
        int same_surf = 0;
        FacetSurfaceMesh *fsm_ptr = fsurf_list_ptr->get_and_step();
        for(kk=this_fsurf_list.size(); kk>0 && !same_surf; kk--)
          FacetSurfaceMesh *this_fsm_ptr = this_fsurf_list.get_and_step();
          if (this_fsm_ptr == fsm_ptr)
            same_surf = 1;
        if (!same_surf)
          found = 0;
    if (!found)
      hashCurveArray[key].step();
  // if the unique set of surfaces that this edge is associated
  // with was found to already exist for a facet curve -- add the
  // edge to the block curve
  if (found)
    // add the edge to the block curve mesh (make sure it is only added once)
    int was_added = fcm_ptr->add_facet_unique( edge_ptr );
    // add the curve to the surface (if needed)
    facet_surf_mesh_ptr->add_curve_unique( fcm_ptr );
    // add the curve to the edge
    td_gm_edge->add_facet_curve( fcm_ptr );
  // with is not found, then create a new facet curve and add the edge to it
  else
    // create it and update surface and nodeset info
    int block_id = td_gm_edge->get_block_id();
    FacetCurveMesh *new_fcm_ptr = new FacetCurveMesh( block_id );
    for (int mm=0; mm<this_num_adj; mm++)
      new_fcm_ptr->add_surface( this_fsurf_list.get_and_step() );
    // add the edge
    new_fcm_ptr->add_facet( edge_ptr );
    // update the surface with this new curve
    facet_surf_mesh_ptr->add_curve( new_fcm_ptr );
    // add the new curve to the global list
    facet_curve_list.append( new_fcm_ptr );
    td_gm_edge->add_facet_curve( new_fcm_ptr );
    // add the new curve to the hash table
    hashCurveArray[key].append( new_fcm_ptr );
  return rv;
) [private]
CubitStatus FacetGeometryCreator::classify_point ( CubitPoint point_ptr,
FacetCurveMesh *  fcm_ptr
) [private]
Definition at line 607 of file FacetGeometryCreator.cpp.
  int ii;
  int found = 0;
  TDGeomFacet *td_node = TDGeomFacet::get_geom_facet( point_ptr );
  FacetPointMesh *fpm_ptr;
  DLIList<FacetCurveMesh*> fcm_list;
  td_node->get_facet_curves(fcm_list);
  int key = get_point_hash_key( &fcm_list );
  for (ii = 0; ii < hashPointArray[key].size() && !found; ii++)
    fpm_ptr = hashPointArray[key].get();
    FacetEntity *this_point_ptr = fpm_ptr->get_facets();
    if (this_point_ptr == point_ptr)
      found = 1;
    else
      hashPointArray[key].step();
  if (found)
    fpm_ptr->add_curve( fcm_ptr );
    fcm_ptr->add_point( fpm_ptr );
  else
    FacetPointMesh *new_fpm_ptr = new FacetPointMesh();
    new_fpm_ptr->add_facet( point_ptr );
    new_fpm_ptr->add_curve( fcm_ptr );
    fcm_ptr->add_point( new_fpm_ptr );
    facet_point_list.append( new_fpm_ptr );
    hashPointArray[key].append( new_fpm_ptr );
  return CUBIT_SUCCESS;
) [private]
CubitStatus FacetGeometryCreator::clean_geometry ( CubitBoolean  smooth_non_manifold,
double  min_dot,
) [private]
Definition at line 1169 of file FacetGeometryCreator.cpp.
  int iedge;
  FacetEntity *fedge_ptr;
  CubitFacetEdge *edge_ptr;
  DLIList <FacetEntity *> facet_list;
  DLIList<CubitFacetEdge *> feature_edge_list;
  int icurve;
  for (icurve=0; icurve<facet_curve_list.size(); icurve++)
    facet_list.clean_out();
    facet_list = fcm_ptr->get_facets( );
    for (iedge=0; iedge<facet_list.size(); iedge++)
      fedge_ptr = facet_list.get_and_step();
      edge_ptr = CAST_TO( fedge_ptr, CubitFacetEdge );
      feature_edge_list.append( edge_ptr );
  return FacetQueryEngine::instance()->fix_geometry( smooth_non_manifold,
                                                        split_surfaces,
                                                        use_feature_angle,
                                                        mindot, feature_edge_list );
double  min_dot,
) [private]
CubitStatus FacetGeometryCreator::create_curve_boundaries ( DLIList< FacetCurveMesh * > &  facet_curve_list,
) [private]
Definition at line 560 of file FacetGeometryCreator.cpp.
  // hash the points for speed
  stat = init_hash_points();
    delete_hash_points();
    return stat;
  // loop through each of the end nodes on the curves
  // Determine which point it is a part of.
  // Create a new FacetPointMesh for each point
  int ii, kk;
  for ( ii = facet_curve_list.size(); ii > 0; ii-- )
    CubitPoint *point_ptr[2];
    fcm_ptr->get_ends( point_ptr[0], point_ptr[1] );
    for ( kk = 0; kk < 2; kk++)
      stat = classify_point( point_ptr[kk], facet_point_list, fcm_ptr );
        return stat;
  return stat;
) [private]
CubitStatus FacetGeometryCreator::create_surface_boundaries ( DLIList< FacetSurfaceMesh * > &  facet_surface_list,
double  min_dot
) [private]
Definition at line 217 of file FacetGeometryCreator.cpp.
    // determine the boundaries for each surface.  One curve per surface
  int ii;
  for ( ii = facet_surface_list.size(); ii > 0; ii-- )
    if (fcurve_list.size() == 0)
      fsm_ptr->get_facets(facet_list);
      FacetSkinTool f_skin_tool;
      stat = f_skin_tool.skin_2d(facet_list, fsm_ptr);
      if ( stat != CUBIT_SUCCESS )
        return stat;
  // create a hash list of curves - to speed up classification
  stat = init_hash_curves();
    delete_hash_curves();
    return stat;
  // loop through each of the edges on the surfaces
  // Determine which curve it is a part of.
  // Create a new FacetCurveMesh for each curve
  // Curves are created wherever there is a unique set of associated
  // surfaces
  int jj, kk;
    // curently there should only be one curve list per surface
    for (jj=fcurve_list.size(); jj>0; jj--)
      FacetCurveMesh *fcm_ptr = fcurve_list.get_and_step();
      FacetEntity *edge_ptr;
      for ( kk = 0; kk < facet_list.size(); kk++)
        stat = classify_edge( edge_ptr, facet_curve_list, fsm_ptr );
          return stat;
      // delete this FacetCurveMesh - it should have been replaced by one
      // or more curves bounding this surface
      fsm_ptr->remove_curve( fcm_ptr );
  // Split these curves so that there is only one string of continuous
  // edges per curve (it will also order the edges and set the start
  // and end nodes for each curve)
  int num_curves = facet_curve_list.size();
  facet_curve_list.reset();
  for ( ii = num_curves; ii > 0 && stat == CUBIT_SUCCESS; ii-- )
    FacetCurveMesh *fcm_ptr = facet_curve_list.get();
    // if necessary mark nodes that will serve as feature breaks (vertices
    // will be generatedat them)
    if (use_feature_angle)
      stat = fcm_ptr->feature_angle( min_dot );
         return stat;
    // split the curve based on various criteria
    stat = fcm_ptr->split_curve( facet_curve_list );
    // delete this curve (new curves were created in split_curve)
    delete fcm_ptr;
    facet_curve_list.change_to(NULL);
    facet_curve_list.step();
  facet_curve_list.remove_all_with_value(NULL);
  // update the point->curve associativity
  for (ii=0; ii<facet_curve_list.size(); ii++)
    TDGeomFacet *td = TDGeomFacet::get_geom_facet( start_ptr );
    td->add_facet_curve( fcm_ptr );
    td = TDGeomFacet::get_geom_facet( end_ptr );
  return stat;
double  min_dot
) [private]
CubitStatus FacetGeometryCreator::create_volume_boundaries ( DLIList< FacetSurfaceMesh * > &  facet_surface_sheets,
double  min_dot,
) [private]
Definition at line 132 of file FacetGeometryCreator.cpp.
  // Split these surfaces so that there is only one set of continuous
  // faces per surface
  int ii;
  int num_surfaces = facet_surface_sheets.size();
  facet_surface_sheets.reset();
  for ( ii = num_surfaces; ii > 0; ii-- )
    FacetSurfaceMesh *fsm_ptr = facet_surface_sheets.get_and_step();
    // make a list of feature edges
      rv = fsm_ptr->feature_angle( min_dot, feature_edge_list );
    else
      rv = fsm_ptr->non_manifold_edges( feature_edge_list );
    if (rv != CUBIT_SUCCESS)
      return rv;
     // crack the surface at the feature edges.  create new edges and
     // points so the facet representation is discontinuous.
    rv = FacetQueryEngine::make_features( feature_edge_list, split_surfaces );
       return rv;
    // split up the surface
    rv = fsm_ptr->split_surface( facet_surface_sheets );
       return rv;
  // Clean up any edges that do not form complete loops as a result of
  // feature angle.  For this implementation we will allow features to exist
  // within the surface without defining a complete loop. -- so the next
  // piece of code is never executed.
  CubitBoolean use_complete_loops_only = CUBIT_FALSE;
  if (use_feature_angle && use_complete_loops_only)
    for ( ii = facet_surface_sheets.size(); ii > 0; ii-- )
      fsm_ptr->clean_features();
  // Now that we've broken everything into surfaces, update the surface IDs
  // on the boundary facet tool data
  if (!split_surfaces)
      fsm_ptr->update_boundary_tool_data();
  return rv;
double  min_dot,
) [private]
Definition at line 388 of file FacetGeometryCreator.cpp.
  if (hashCurveArray)
   delete [] hashCurveArray;
  hashCurveSize = 0;
Definition at line 699 of file FacetGeometryCreator.cpp.
  if (hashPointArray)
   delete [] hashPointArray;
  hashPointSize = 0;
Definition at line 87 of file FacetGeometryCreator.cpp.
  int ii;
  FacetEntity *fe_ptr;
  for (ii=0; ii<faceList.size(); ii++)
    fe_ptr = faceList.get_and_step();
    fe_ptr->delete_TD( &TDGeomFacet::is_geom_facet );
  for (ii=0; ii<edgeList.size(); ii++)
    fe_ptr = edgeList.get_and_step();
  for (ii=0; ii<pointList.size(); ii++)
    fe_ptr = pointList.get_and_step();
int FacetGeometryCreator::get_curve_hash_key ( DLIList< FacetSurfaceMesh * > *  bsm_list_ptr) [private]
Definition at line 402 of file FacetGeometryCreator.cpp.
  int key, j;
  FacetSurfaceMesh *fsm_ptr;
  if (fsm_list_ptr->size() == 0)
    key = 0;
  else
    key = INT_MAX;
    for (j=0; j<fsm_list_ptr->size(); j++)
      fsm_ptr = fsm_list_ptr->get_and_step();
      if (fsm_ptr->get_id() < key)
        key = fsm_ptr->get_id();
  key = key % hashCurveSize;
  return key;
int FacetGeometryCreator::get_point_hash_key ( DLIList< FacetCurveMesh * > *  bsm_list_ptr) [private]
Definition at line 713 of file FacetGeometryCreator.cpp.
  int key, j;
  if (fcm_list_ptr->size() == 0)
    key = 0;
  else
    key = INT_MAX;
    for (j=0; j<fcm_list_ptr->size(); j++)
      fcm_ptr = fcm_list_ptr->get_and_step();
      if (fcm_ptr->get_id() < key)
        key = fcm_ptr->get_id();
  key = key % hashPointSize;
  return key;
Definition at line 346 of file FacetGeometryCreator.cpp.
  /* === find the next highest prime number */
  int num_surfs = facetSurfaceList.size();
  int i;
  hashCurveSize = num_surfs;
  if (num_surfs < 30) hashCurveSize = 31;
  else
    i=2;
    while (i<hashCurveSize*0.5 + 1) {
      if (hashCurveSize % i == 0) {
        i=2;
        hashCurveSize++;
      else {
        i++;
  hashCurveArray = new DLIList<FacetCurveMesh*>[hashCurveSize];
  int key = 0;
  DLIList<FacetSurfaceMesh*> *fsm_list_ptr;
  for (i=0; i<facetCurveList.size(); i++)
    fcm_ptr = facetCurveList.get_and_step();
    fsm_list_ptr = fcm_ptr->get_surface_list_ptr();
    key = get_curve_hash_key( fsm_list_ptr );
    hashCurveArray[key].append( fcm_ptr );
Definition at line 657 of file FacetGeometryCreator.cpp.
  int num_curves = facetCurveList.size();
  int i;
  hashPointSize = num_curves;
  if (num_curves < 30) hashPointSize = 31;
  else
    i=2;
    while (i<hashPointSize*0.5 + 1) {
      if (hashPointSize % i == 0) {
        i=2;
        hashPointSize++;
      else {
        i++;
  hashPointArray = new DLIList<FacetPointMesh*>[hashPointSize];
  int key = 0;
  DLIList<FacetCurveMesh*> *fcm_list_ptr;
  for (i=0; i<facetPointList.size(); i++)
    fpm_ptr = facetPointList.get_and_step();
    fcm_list_ptr = fpm_ptr->get_curve_list_ptr();
    key = get_point_hash_key( fcm_list_ptr );
    hashPointArray[key].append( fpm_ptr );
Definition at line 1206 of file FacetGeometryCreator.cpp.
  FILE *fp = fopen( "fbg.out", "w" );
  int ii, jj, kk;
  for (ii=0; ii<facetSurfaceList.size(); ii++)
    FacetSurfaceMesh *fsm_ptr = facetSurfaceList.get_and_step();
    fprintf( fp, "*********** Surface %d ***************\n", fsm_ptr->get_id());
    DLIList<FacetCurveMesh *> fcm_list;
    fsm_ptr->get_curves( fcm_list );
    for (jj=0; jj<fcm_list.size(); jj++)
      FacetCurveMesh *fcm_ptr = fcm_list.get_and_step();
      fprintf(fp, "   Curve %d\n", fcm_ptr->get_id() );
      DLIList<FacetPointMesh *> fpm_list = fcm_ptr->get_points();
      for (kk=0; kk<fpm_list.size(); kk++)
        FacetPointMesh *fpm_ptr = fpm_list.get_and_step();
        FacetEntity *facet_point = fpm_ptr->get_facets();
        if (facet_point)
          CubitPoint *point_ptr = CAST_TO(facet_point, CubitPoint);
          CubitVector pt = point_ptr->coordinates();
          fprintf(fp, "      (%d) x = %8.4lf y = %8.4lf z = %8.4lf\n",
                  fpm_ptr->get_id(), pt.x(), pt.y(), pt.z());
  fclose(fp);
Definition at line 68 of file FacetGeometryCreator.cpp.
  int ii;
    TDGeomFacet::add_geom_facet( fe_ptr, -1 );
Member Data Documentation
DLIList< FacetCurveMesh * > FacetGeometryCreator::facetCurveList [private]
Definition at line 53 of file FacetGeometryCreator.hpp.
DLIList< FacetPointMesh * > FacetGeometryCreator::facetPointList [private]
Definition at line 54 of file FacetGeometryCreator.hpp.
DLIList< FacetSurfaceMesh * > FacetGeometryCreator::facetSurfaceList [private]
Definition at line 52 of file FacetGeometryCreator.hpp.
DLIList< FacetCurveMesh * > * FacetGeometryCreator::hashCurveArray [private]
Definition at line 56 of file FacetGeometryCreator.hpp.
Definition at line 57 of file FacetGeometryCreator.hpp.
DLIList< FacetPointMesh * > * FacetGeometryCreator::hashPointArray [private]
Definition at line 58 of file FacetGeometryCreator.hpp.
Definition at line 59 of file FacetGeometryCreator.hpp.
