cgma
FacetQueryEngine Class Reference
#include <FacetQueryEngine.hpp>
Inheritance diagram for FacetQueryEngine:
GeometryQueryEngine
List of all members.
Public Member Functions
virtual ~FacetQueryEngine ()
const char * modeler_type ()
int get_major_version ()
int get_minor_version ()
int get_subminor_version ()
CubitString get_engine_version_string ()
virtual const std::type_info & entity_type_info () const
virtual CubitBoolean is_solid_modeler_type () const
CubitBoolean can_delete_bodies (DLIList< Body * >body_list)
virtual TBPointmake_Point (GeometryType point_type, CubitVector const &point) const
virtual Curvemake_Curve (Curve *) const
virtual Curvemake_Curve (TBPoint const *, TBPoint const *, RefFace *, CubitVector *) const
virtual Curvemake_Curve (GeometryType, TBPoint const *, TBPoint const *, DLIList< CubitVector * > &, RefFace *) const
virtual Curvemake_Curve (GeometryType, TBPoint const *, TBPoint const *, CubitVector const *, CubitSense) const
virtual Surfacemake_Surface (Surface *, DLIList< Loop * > &, CubitBoolean) const
virtual Surfacemake_Surface (GeometryType, DLIList< Curve * > &, DLIList< Loop * > &, Surface *) const
virtual Lumpmake_Lump (GeometryType, DLIList< Surface * > &) const
virtual BodySMmake_BodySM (Surface *) const
virtual BodySMmake_BodySM (DLIList< Lump * > &) const
Bodycopy_body (Body *body_ptr)
virtual CubitStatus get_graphics (BodySM *bodysm, GMem *g_mem, std::vector< Surface * > &surface_to_facets_vector, std::vector< TopologyBridge * > &vertex_edge_to_point_vector, std::vector< std::pair< TopologyBridge *, std::pair< int, int > > > &facet_edges_on_curves, unsigned short normal_tolerance, double distance_tolerance, double max_edge_length) const
virtual CubitStatus get_graphics (Surface *surface_ptr, GMem *gMem, unsigned short normal_tolerance, double distance_tolerance, double max_edge_length) const
virtual CubitStatus get_graphics (Curve *curve_ptr, GMem *gMem, double angle_tolerance=0, double distance_tolerance=0, double max_edge_length=0) const
virtual CubitStatus get_isoparametric_points (Surface *, int &, int &, GMem *&) const
virtual CubitStatus get_u_isoparametric_points (Surface *ref_face_ptr, double v, int &n, GMem *&gMem) const
virtual CubitStatus get_v_isoparametric_points (Surface *ref_face_ptr, double u, int &n, GMem *&gMem) const
virtual CubitStatus transform_vec_position (CubitVector const &, BodySM *, CubitVector &) const
virtual CubitStatus get_intersections (Curve *, CubitVector &point1, CubitVector &, DLIList< CubitVector > &, CubitBoolean, CubitBoolean)
virtual CubitStatus get_intersections (Curve *, Curve *, DLIList< CubitVector > &, CubitBoolean, CubitBoolean)
virtual CubitStatus get_intersections (Curve *ref_edge1, Curve *ref_edge2, DLIList< CubitVector > &intersection_list, double offset, CubitBoolean ext_first=CUBIT_TRUE)
virtual CubitStatus get_intersections (Curve *ref_edge, Surface *ref_face, DLIList< CubitVector > &intersection_list, CubitBoolean bounded=CUBIT_FALSE)
virtual CubitStatus entity_extrema (DLIList< GeometryEntity * > &entity_list, const CubitVector *dir1, const CubitVector *dir2, const CubitVector *dir3, CubitVector &extrema, GeometryEntity *&extrema_entity_ptr)
virtual CubitStatus entity_entity_distance (GeometryEntity *ref_entity_ptr1, GeometryEntity *ref_entity_ptr2, CubitVector &pos1, CubitVector &pos2, double &distance)
virtual CubitStatus export_solid_model (DLIList< TopologyBridge * > &bridge_list, const char *file_name, Model_File_Type file_type, const CubitString &cubit_version, ModelExportOptions &export_options)
virtual CubitStatus export_solid_model (DLIList< TopologyBridge * > &bridge_list, char *&p_buffer, int &n_buffer_size, bool b_export_buffer)
virtual CubitStatus save_temp_geom_file (DLIList< TopologyBridge * > &ref_entity_list, const char *file_name, const CubitString &cubit_version, CubitString &created_file, CubitString &created_file_type)
virtual CubitStatus import_solid_model (const char *file_name, Model_File_Type file_type, DLIList< TopologyBridge * > &imported_entities, ModelImportOptions &import_options)
virtual CubitStatus import_solid_model (DLIList< TopologyBridge * > &imported_entities, const char *pBuffer, const int n_buffer_size)
virtual void delete_solid_model_entities (DLIList< BodySM * > &body_list) const
virtual CubitStatus delete_solid_model_entities (BodySM *body_ptr) const
virtual CubitStatus delete_solid_model_entities (Surface *surf_ptr) const
virtual CubitStatus delete_solid_model_entities (Curve *curve_ptr) const
virtual CubitStatus delete_solid_model_entities (TBPoint *point_ptr) const
virtual CubitStatus fire_ray (CubitVector &origin, CubitVector &direction, DLIList< TopologyBridge * > &at_entity_list, DLIList< double > &ray_params, int max_hits, double ray_radius, DLIList< TopologyBridge * > *hit_entity_list=0) const
virtual double get_sme_resabs_tolerance () const
virtual double set_sme_resabs_tolerance (double new_resabs)
virtual CubitStatus set_int_option (const char *opt_name, int val)
virtual CubitStatus set_dbl_option (const char *opt_name, double val)
virtual CubitStatus set_str_option (const char *opt_name, const char *val)
CubitStatus ensure_is_ascii_stl_file (FILE *fp, CubitBoolean &is_ascii)
CubitStatus read_facets_stl_tolerance (DLIList< CubitFacet * > &tfacet_list, DLIList< CubitPoint * > &point_list, const char *file_name, int &npoints, int &ntri, long &seek_address, double tolerance)
CubitStatus read_facets_stl (DLIList< CubitFacet * > &tfacet_list, DLIList< CubitPoint * > &point_list, const char *file_name, int &npoints, int &ntri, long &seek_address)
CubitStatus import_facets (const char *file_name, CubitBoolean use_feature_angle, double feature_angle, double tolerance, int interp_order, CubitBoolean smooth_non_manifold, CubitBoolean split_surfaces, CubitBoolean stitch, CubitBoolean improve, DLIList< CubitQuadFacet * > &quad_facet_list, DLIList< CubitFacet * > &tri_facet_list, DLIList< Surface * > &surface_list, FacetFileFormat file_format=CUBIT_FACET_FILE)
CubitBoolean is_close (CubitVector &this_point, DLIList< CubitFacet * > &facet_list, CubitFacet *&lastFacet, double tol)
CubitStatus gather_all_facet_entities (DLIList< FacetBody * > &facet_bodies, DLIList< FacetLump * > &facet_lumps, DLIList< FacetShell * > &facet_shells, DLIList< FacetSurface * > &facet_surfaces, DLIList< FacetLoop * > &facet_loops, DLIList< FacetCoEdge * > &facet_coedges, DLIList< FacetCurve * > &facet_curves, DLIList< FacetPoint * > &facet_points)
CubitStatus save_facets (FILE *fp, DLIList< FacetSurface * > facet_surfaces, DLIList< FacetCurve * > facet_curves, DLIList< FacetPoint * > facet_points)
CubitStatus save_eval_tools (FILE *fp, DLIList< FacetSurface * > facet_surfaces, DLIList< FacetCurve * > facet_curves)
CubitStatus dump_facets (FILE *fp, DLIList< CubitFacet * > &facet_list, DLIList< CubitFacetEdge * > &edge_list, DLIList< CubitPoint * > &point_list)
CubitStatus gather_facets (DLIList< FacetSurface * > facet_surfaces, DLIList< FacetCurve * > facet_curves, DLIList< FacetPoint * > facet_points, DLIList< CubitFacet * > &facet_list, DLIList< CubitFacetEdge * > &edge_list, DLIList< CubitPoint * > &point_list)
CubitStatus restore_eval_tools (FILE *fp, unsigned int endian, int num_facets, int num_edges, int num_points, CubitFacet **facets, CubitFacetEdge **edges, CubitPoint **points, int &num_cfet, int &num_fet, CurveFacetEvalTool **&cfeval_tools, FacetEvalTool **&feval_tools)
CubitStatus create_super_facet_bounding_box (DLIList< BodySM * > &body_list, CubitBox &super_box)
CubitStatus create_facet_bounding_box (BodySM *bodySM, CubitBox &bbox)
CubitStatus restore_transform (BodySM *body)
CubitStatus translate (BodySM *body, const CubitVector &offset)
CubitStatus rotate (BodySM *body, const CubitVector &axis, double angle)
CubitStatus scale (BodySM *body, double factor)
CubitStatus scale (BodySM *body, const CubitVector &factors)
CubitStatus reflect (BodySM *body, const CubitVector &axis)
CubitStatus translate (GeometryEntity *ent, const CubitVector &offset)
CubitStatus rotate (GeometryEntity *ent, const CubitVector &axis, double degrees)
CubitStatus scale (GeometryEntity *ent, double factor)
CubitStatus scale (GeometryEntity *ent, const CubitVector &factors)
CubitStatus reflect (GeometryEntity *ent, const CubitVector &axis)
CubitStatus get_connected_patch (DLIList< FacetSurface * > &remaining_surfs, DLIList< FacetSurface * > &output_patch)
virtual CubitBoolean bodies_overlap (BodySM *body_ptr_1, BodySM *body_ptr_2) const
virtual CubitBoolean volumes_overlap (Lump *lump_ptr_1, Lump *lump_ptr_2) const
virtual CubitStatus get_point_containment (DLIList< BodySM * > &bodysm_list, DLIList< CubitVector > &point_list, double tolerance, bool allow_pts_in_multiple_bodies, std::vector< std::pair< BodySM *, std::vector< int > > > &bodysm_to_pt_indices)
Static Public Member Functions
static FacetQueryEngineinstance ()
static void delete_instance ()
static CubitStatus make_facets (int *conn, int nfacets, DLIList< CubitQuadFacet * > &facet_list)
static CubitStatus make_facets (int *conn, int nfacets, DLIList< CubitFacet * > &facet_list)
static CubitStatus read_facets (const char *file_name, int *&conn, int &npoints, int &nquad, int &ntri, FacetFileFormat file_format=CUBIT_FACET_FILE)
static CubitStatus read_cholla_file (const char *file_name, double &feature_angle, DLIList< CubitPoint * > &point_list, DLIList< CubitFacet * > &facet_list)
static CubitStatus export_facets (DLIList< CubitFacet * > &facet_list, char *filename)
Protected Member Functions
 FacetQueryEngine ()
Private Member Functions
CubitStatus import_solid_model (FILE *file_ptr, DLIList< TopologyBridge * > &imported_entities)
CubitStatus write_topology (FILE *file_ptr, DLIList< FacetBody * > &facet_bodies, DLIList< FacetLump * > &facet_lumps, DLIList< FacetShell * > &facet_shells, DLIList< FacetSurface * > &facet_surfaces, DLIList< FacetLoop * > &facet_loops, DLIList< FacetCoEdge * > &facet_coedges, DLIList< FacetCurve * > &facet_curves, DLIList< FacetPoint * > &facet_points)
CubitStatus restore_topology (FILE *file_ptr, unsigned int endian, int num_points, CubitPoint **points_array, int num_cfet, CurveFacetEvalTool **cfev_array, int num_fet, FacetEvalTool **fev_array, DLIList< TopologyBridge * > &imported_entities)
CubitStatus restore_facets (FILE *file_ptr, unsigned int endian, int &num_facets, int &num_edges, int &num_points, CubitPoint **&points_array, int &num_cfet, int &num_fet, CurveFacetEvalTool **&cfet_array, FacetEvalTool **&fet_array)
CubitStatus read_facets (FILE *fp, unsigned int endian, int &num_facets, int &num_edges, int &num_points, CubitFacet **&facets, CubitFacetEdge **&edges, CubitPoint **&points)
Static Private Member Functions
static CubitStatus init_hash_points (int num_points)
static CubitStatus add_hash_point (CubitPoint *point_ptr)
static CubitPointget_hash_point (int id)
static void delete_hash_points ()
static int get_hash_key (int id)
static CubitStatus get_all_hash_points (DLIList< CubitPoint * > &point_list)
Static Private Attributes
static FacetQueryEngineinstance_ = NULL
static int hashPointSize = 0
static DLIList< CubitPoint * > * hashPointArray = NULL
static const int FQE_MAJOR_VERSION = 10
static const int FQE_MINOR_VERSION = 0
static const int FQE_SUBMINOR_VERSION = 0
Friends
class FacetSurface
Detailed Description
Definition at line 92 of file FacetQueryEngine.hpp.
Definition at line 125 of file FacetQueryEngine.cpp.
  instance_ = NULL;
Definition at line 115 of file FacetQueryEngine.cpp.
  GeometryQueryTool::instance()->add_gqe( this );
Member Function Documentation
CubitStatus FacetQueryEngine::add_hash_point ( CubitPoint point_ptr) [static, private]
Definition at line 4388 of file FacetQueryEngine.cpp.
  int id = point_ptr->id();
  int key = get_hash_key( id );
  hashPointArray[key].append( point_ptr );
  return CUBIT_SUCCESS;
CubitBoolean FacetQueryEngine::bodies_overlap ( BodySM body_ptr_1,
BodySM body_ptr_2
) const [virtual]
Implements GeometryQueryEngine.
Definition at line 5243 of file FacetQueryEngine.cpp.
  PRINT_ERROR("Currently, Cubit is unable to determine overlap for Facet-based geometry.\n");
  return CUBIT_FALSE;
    //The following should work, but due to bug 5599, we are not
    // using it.  Having this code in the default would cause the
    // GeometryPowerTool to rely on Facetbool, which isn't robust
    // yet.
FacetboolInterface *fbint;
CubitFacetboolOp op = CUBIT_FB_INTERSECTION;
bool keep_old = true;
CubitStatus status;
BodySM* body_out = 0;
bool intersection_found;
  fbint = new FacetboolInterface;
  status = fbint->dofacetboolean_2bodies(body_ptr_1,body_ptr_2,body_out,
                                       keep_old,intersection_found,op);
  if ( status == CUBIT_FAILURE ) return CUBIT_FALSE;
  else return CUBIT_TRUE;
Definition at line 146 of file FacetQueryEngine.cpp.
  CubitBoolean delete_ok = CUBIT_TRUE;
  int ii;
  for (ii=0; ii<body_list.size() && delete_ok; ii++)
    Body *body_ptr = body_list.get_and_step();
    // Extract the BODY from Body
    FacetBody* fbody_ptr = CAST_TO(body_ptr->get_body_sm_ptr(), FacetBody);
    if (fbody_ptr)
      delete_ok = fbody_ptr->can_be_deleted(body_list);
  return delete_ok;
Definition at line 333 of file FacetQueryEngine.cpp.
  BodySM* bodysm_ptr = body_ptr->get_body_sm_ptr();
  FacetBody *facet_body_ptr = CAST_TO(bodysm_ptr, FacetBody);
  if (!facet_body_ptr)
    PRINT_ERROR("Attempt to copy mesh-based geometry Body.  This body is not MBG.");
    return (Body*)NULL;
  TopologyBridge *top_bridge;
  GeometryModifyTool::instance()->prepare_for_copy( body_ptr, top_bridge );
  BodySM* osme_body_ptr = (BodySM*)facet_body_ptr->copy();
  if (!osme_body_ptr)
    GeometryModifyTool::instance()->clean_up_from_copy_failure( top_bridge );
    PRINT_ERROR("Failed to copy mesh-based geometry Body");
    return (Body*)NULL;
  TopologyBridge *tb = (TopologyBridge*)osme_body_ptr;
  GeometryModifyTool::instance()->finish_copy( tb, bodysm_ptr );
  Body *new_body_ptr = GeometryQueryTool::instance()->make_Body( osme_body_ptr );
  return new_body_ptr;
Definition at line 5148 of file FacetQueryEngine.cpp.
  FacetBody *fbody_ptr;
  int j;
  DLIList<FacetSurface*> facet_surf_list;
  DLIList<CubitFacet*> facet_list;
  DLIList<CubitPoint*> point_list;
  FacetSurface *facet_surface;
  CubitBox surf_bbox, total_box;
  CubitStatus status = CUBIT_FAILURE;
    fbody_ptr = dynamic_cast<FacetBody *>(bodySM);
    fbody_ptr->get_surfaces(facet_surf_list);
    for ( j = 0; j < facet_surf_list.size(); j++ ) {
      facet_surface = facet_surf_list.get_and_step();
      facet_list.clean_out();
      point_list.clean_out();
      facet_surface->get_my_facets(facet_list,point_list);
      status = FacetDataUtil::get_bbox_of_points(point_list,surf_bbox);
      if ( j == 0 )
        total_box = surf_bbox;
      else
        total_box |= surf_bbox;
  bbox = total_box;
  return status;
Definition at line 5125 of file FacetQueryEngine.cpp.
BodySM *bodySM;
int i;
CubitStatus status = CUBIT_SUCCESS;
  body_list.reset();
  for ( i = 0; i < body_list.size(); i++ ) {
    bodySM = body_list.get_and_step();
    create_facet_bounding_box(bodySM,super_box);
  return status;
void FacetQueryEngine::delete_hash_points ( ) [static, private]
Definition at line 4425 of file FacetQueryEngine.cpp.
  if (hashPointArray)
   delete [] hashPointArray;
  hashPointArray = NULL;
  hashPointSize = 0;
Definition at line 130 of file FacetQueryEngine.cpp.
  if( NULL != instance_ )
    delete instance_;
    instance_ = NULL;
void FacetQueryEngine::delete_solid_model_entities ( DLIList< BodySM * > &  body_list) const [virtual]
Definition at line 2266 of file FacetQueryEngine.cpp.
  BodySM* BodyPtr = NULL;
  for (int i = 0; i < BodyList.size(); i++ )
    BodyPtr = BodyList.get_and_step();
    this->delete_solid_model_entities(BodyPtr);
  return;
Definition at line 2288 of file FacetQueryEngine.cpp.
  FacetBody* fbody = dynamic_cast<FacetBody*>(bodysm);
  if (!fbody)
    return CUBIT_FAILURE;
  DLIList<FacetLump*> lumps;
  DLIList<FacetShell*> shells;
  DLIList<FacetSurface*> surfaces;
  fbody->get_lumps(lumps);
  fbody->disconnect_all_lumps();
  delete fbody;
  for (int i = lumps.size(); i--; )
    FacetLump* lump = lumps.get_and_step();
    shells.clean_out();
    lump->get_shells(shells);
    lump->disconnect_all_shells();
    delete lump;
    for (int j = shells.size(); j--; )
      FacetShell* shell = shells.get_and_step();
      surfaces.clean_out();
      shell->get_surfaces(surfaces);
      shell->disconnect_all_surfaces();
      delete shell;
      for (int k = surfaces.size(); k--; )
        FacetSurface* surface = surfaces.get_and_step();
        if (!surface->has_parent_shell())
          delete_solid_model_entities(surface);
Definition at line 2342 of file FacetQueryEngine.cpp.
  FacetSurface* fsurf = dynamic_cast<FacetSurface*>(surface);
  if (!fsurf || fsurf->has_parent_shell())
  DLIList<FacetLoop*> loops;
  DLIList<FacetCoEdge*> coedges;
  fsurf->get_loops(loops);
  fsurf->disconnect_all_loops();
  delete fsurf;
  for (int i = loops.size(); i--; )
    FacetLoop* loop = loops.get_and_step();
    coedges.clean_out();
    loop->get_coedges(coedges);
    loop->disconnect_all_coedges();
    delete loop;
    for (int j = coedges.size(); j--; )
      FacetCoEdge* coedge = coedges.get_and_step();
      FacetCurve* curve = dynamic_cast<FacetCurve*>(coedge->curve());
      if (curve)
        curve->disconnect_coedge(coedge);
        if (!curve->has_parent_coedge())
          delete_solid_model_entities(curve);
      delete coedge;
Definition at line 2392 of file FacetQueryEngine.cpp.
  FacetCurve* fcurve = dynamic_cast<FacetCurve*>(curve);
  if (!fcurve || fcurve->has_parent_coedge())
  FacetPoint* start = dynamic_cast<FacetPoint*>(fcurve->start_point());
  FacetPoint*   end = dynamic_cast<FacetPoint*>(fcurve->end_point()  );
  if (start == end )
      end = NULL;
  if (start)
    start->disconnect_curve(fcurve);
    if (!start->has_parent_curve())
      delete_solid_model_entities(start);
  if (end)
    end->disconnect_curve(fcurve);
    if (!end->has_parent_curve())
      delete_solid_model_entities(end);
  delete curve;
Definition at line 2432 of file FacetQueryEngine.cpp.
  FacetPoint* fpoint = dynamic_cast<FacetPoint*>(point);
  if (!fpoint || fpoint->has_parent_curve())
  delete point;
CubitStatus FacetQueryEngine::dump_facets ( FILE *  fp,
DLIList< CubitFacet * > &  facet_list,
DLIList< CubitFacetEdge * > &  edge_list,
DLIList< CubitPoint * > &  point_list
Definition at line 4674 of file FacetQueryEngine.cpp.
  NCubitFile::CIOWrapper cio(fp);
  typedef NCubitFile::UnsignedInt32 UnsignedInt32;
  // Gather CubitPoint Data
  int npoints = point_list.size();
  int nnormals = 0;
  double* uvs_array = new double [npoints * 3];
  double* coord_array  = new double [npoints * 3];
  //double* du_array = new double [npoints * 3];
  //double* dv_array = new double [npoints * 3];
  int c_zero_points = 0;
  int c_zero_int_data_size = 0;
  int c_zero_double_data_size = 0;
  int ii;
  DLIList<CubitPoint*> has_td_boundary_point;
  DLIList<CubitPoint*> points_with_normal;
  TDFacetBoundaryPoint *td_fbp;
  CubitPoint *cp_ptr;
  CubitVector coord, *normal;
  point_list.reset();
  for (ii=0; ii<point_list.size(); ii++)
    cp_ptr = point_list.get_and_step();
    // write out uVal, vVal, sizeVal
    uvs_array[ii*3] = cp_ptr->u();
    uvs_array[ii*3+1] = cp_ptr->v();
    uvs_array[ii*3+2] = cp_ptr->size();
    // coordinates
    coord = cp_ptr->coordinates();
    coord_array[ii*3]   = coord.x();
    coord_array[ii*3+1] = coord.y();
    coord_array[ii*3+2] = coord.z();
    // surfNormal
    if( cp_ptr->normal_ptr() )
      points_with_normal.append( cp_ptr );
    // surfU
    du = cp_ptr->du();
    du_array[ii*3]   = du.x();
    du_array[ii*3+1] = du.y();
    du_array[ii*3+2] = du.z();
    // surfV
    dv = cp_ptr->dv();
    dv_array[ii*3]   = dv.x();
    dv_array[ii*3+1] = dv.y();
    dv_array[ii*3+2] = dv.z(); */
    if ((td_fbp = TDFacetBoundaryPoint::get_facet_boundary_point( cp_ptr ))!= NULL)
      has_td_boundary_point.append( cp_ptr );
      c_zero_points++;
      td_fbp->get_boundary_point_data_size( c_zero_int_data_size,
                                            c_zero_double_data_size );
  // Normals
  nnormals = points_with_normal.size();
  double* normal_array = NULL;
  int* normal_ids = NULL;
  points_with_normal.reset();
  if( nnormals > 0 )
    normal_array = new double [nnormals* 3];
    normal_ids = new int[nnormals];
    for( ii=0; ii<nnormals; ii++)
      cp_ptr = points_with_normal.get_and_step();
      normal_ids[ii] = cp_ptr->id();
      normal = cp_ptr->normal_ptr();
      normal_array[ii*3]   = normal->x();
      normal_array[ii*3+1] = normal->y();
      normal_array[ii*3+2] = normal->z();
  // write arrays  --CubitPoint
  cio.Write(reinterpret_cast<UnsignedInt32*>(&npoints), 1);
  if( npoints > 0 )
    cio.Write(coord_array, npoints*3);
    cio.Write(uvs_array, npoints*3);
  // clean up
  delete [] uvs_array;
  delete [] coord_array;
  uvs_array = NULL;
  coord_array = NULL;
  // write normals & ids of points to which normals belong
  cio.Write( reinterpret_cast<UnsignedInt32*>(&nnormals), 1 );
  if( nnormals > 0 )
    cio.Write(normal_array, nnormals*3);
    cio.Write(reinterpret_cast<UnsignedInt32*>(normal_ids), nnormals);
    delete [] normal_array;
    delete [] normal_ids;
    normal_ids = NULL;
  // Gather CubitFacetEdge Data
  int jj, idx;
  int nedges = edge_list.size();
  int nctrl_pts = nedges * NUM_EDGE_CPTS;
  CubitFacetEdge *edge_ptr;
  CubitVector *edge_ctrl_pts;
  double* control_points = new double [nctrl_pts * 3];
  UnsignedInt32* edge_vert_array = new UnsignedInt32 [nedges * 2];
  for(ii=0; ii<nedges; ii++)
    // pointArray[2]
    edge_ptr = edge_list.get_and_step();
    edge_vert_array[ii*2] = edge_ptr->point(0)->id();
    edge_vert_array[ii*2+1] = edge_ptr->point(1)->id();
    edge_ctrl_pts = edge_ptr->control_points();
    // controlPoints[3]
    if (nctrl_pts > 0)
      if (!edge_ctrl_pts)
        nctrl_pts = 0;
        continue;
      for(jj=0; jj<NUM_EDGE_CPTS; jj++)
        idx = (ii*NUM_EDGE_CPTS+jj)*3;
        control_points[idx]   = edge_ctrl_pts[jj].x();
        control_points[idx+1] = edge_ctrl_pts[jj].y();
        control_points[idx+2] = edge_ctrl_pts[jj].z();
  // write arrays  --CubitFacetEdge
  cio.Write(reinterpret_cast<UnsignedInt32*>(&nedges), 1);
  if( nedges > 0 )
    cio.Write(edge_vert_array, nedges*2 );
    cio.Write(reinterpret_cast<UnsignedInt32*>(&nctrl_pts), 1);
    if (nctrl_pts > 0)
      cio.Write(control_points, nctrl_pts*3);
  // clean up
  delete [] edge_vert_array;
  delete [] control_points;
  edge_vert_array = NULL;
  control_points = NULL;
  // Gather CubitFacet Data
  int nfacets = facet_list.size();
  nctrl_pts = nfacets * NUM_TRI_CPTS;
  CubitFacet *facet_ptr;
  CubitVector *facet_ctrl_pts;
  UnsignedInt32* facet_edge_array = new UnsignedInt32 [nfacets * 3];
  int *int_data = new int[ nfacets * 2 ];
  facet_list.reset();
  for (ii=0; ii<nfacets; ii++)
    facet_ptr = facet_list.get_and_step();
    // is Flat and isBackwards
    int_data[ii*2] = facet_ptr->is_flat();
    int_data[ii*2+1] = facet_ptr->is_backwards();
    // edgeArray[3]
    facet_edge_array[ii*3]   = facet_ptr->edge(0)->id();
    facet_edge_array[ii*3+1] = facet_ptr->edge(1)->id();
    facet_edge_array[ii*3+2] = facet_ptr->edge(2)->id();
    facet_ctrl_pts = facet_ptr->control_points();
    if(nctrl_pts > 0)
      if (!facet_ctrl_pts)
        nctrl_pts = 0;
        continue;
      for(jj=0; jj<NUM_TRI_CPTS; jj++)
        idx = (ii*NUM_TRI_CPTS+jj)*3;
        control_points[idx]   = facet_ctrl_pts[jj].x();
        control_points[idx+1] = facet_ctrl_pts[jj].y();
        control_points[idx+2] = facet_ctrl_pts[jj].z();
  cio.Write(reinterpret_cast<UnsignedInt32*>(&nfacets), 1);
  if( nfacets > 0 )
    cio.Write(facet_edge_array, nfacets*3);
    cio.Write( reinterpret_cast<UnsignedInt32*>(int_data), nfacets*2 );
    if (nctrl_pts > 0)
  // clean up
  delete [] facet_edge_array;
  delete [] int_data;
  facet_edge_array = NULL;
  int_data = NULL;
  // At points along the boundary (C0 continuity) there may be
  // multiple normals.  Write this data too.  First gether it
  // into two arrays and then dump.
  cio.Write(reinterpret_cast<UnsignedInt32*>(&c_zero_points), 1);
  if (c_zero_points > 0)
    int *c_zero_int_data = new int [c_zero_int_data_size];
    double *c_zero_double_data = new double [c_zero_double_data_size];
    point_list.reset();
    int iidx = 0;
    int didx = 0;
    point_list.reset();
      td_fbp = TDFacetBoundaryPoint::get_facet_boundary_point( cp_ptr );
      if (td_fbp != NULL)
        td_fbp->get_boundary_point_data( c_zero_int_data,
                                         c_zero_double_data,
                                         iidx, didx );
    // dump the int data array
    cio.Write(reinterpret_cast<UnsignedInt32*>(&c_zero_int_data_size), 1);
    //convert to UnsignedInt32
    UnsignedInt32 *c_zero_int32_data = new UnsignedInt32 [c_zero_int_data_size];
    for (ii=0; ii<c_zero_int_data_size; ii++)
      c_zero_int32_data[ii] = (UnsignedInt32)c_zero_int_data[ii];
    cio.Write(c_zero_int32_data, c_zero_int_data_size);
    // dump the double array
    cio.Write(reinterpret_cast<UnsignedInt32*>(&c_zero_double_data_size), 1);
    cio.Write(c_zero_double_data, c_zero_double_data_size);
    // clean up
    delete [] c_zero_int_data;
    delete [] c_zero_int32_data;
    delete [] c_zero_double_data;
Definition at line 2728 of file FacetQueryEngine.cpp.
  char line[128]="";
  if (fgets(line, 128, fp)==NULL)
  if (strlen(line)==127)
  unsigned int dummy_int=0;
  // One of the functions called by isspace() has an assert that can fail in debug mode if
  // line[dummy_int] is negative so check for it here.
  while (line[dummy_int] > -1 && isspace(line[dummy_int]) && dummy_int < strlen(line))
    dummy_int++;
  if (strlen(line)-dummy_int>5)
    if (tolower(line[dummy_int++])=='f' &&
      tolower(line[dummy_int++])=='a' &&
      tolower(line[dummy_int++])=='c' &&
      tolower(line[dummy_int++])=='e' &&
      tolower(line[dummy_int])=='t')
      dummy_int=0;
      while (isspace(line[dummy_int])&& dummy_int<strlen(line))
        dummy_int++;
        if (tolower(line[dummy_int++])=='o' &&
          tolower(line[dummy_int++])=='u' &&
          tolower(line[dummy_int++])=='t' &&
          tolower(line[dummy_int])=='r')
          dummy_int=0;
          while (isspace(line[dummy_int])&& dummy_int<strlen(line)) {
            dummy_int++;
          if (strlen(line)-dummy_int>6)
            if (tolower(line[dummy_int++])=='v' &&
              tolower(line[dummy_int++])=='r' &&
              tolower(line[dummy_int])=='x')
              is_ascii=CUBIT_TRUE;
CubitStatus FacetQueryEngine::entity_entity_distance ( GeometryEntity ref_entity_ptr1,
GeometryEntity ref_entity_ptr2,
CubitVector pos1,
CubitVector pos2,
double &  distance
) [virtual]
Definition at line 824 of file FacetQueryEngine.cpp.
  PRINT_ERROR("Option not supported for mesh based geometry.\n");
CubitStatus FacetQueryEngine::entity_extrema ( DLIList< GeometryEntity * > &  entity_list,
const CubitVector dir1,
const CubitVector dir2,
const CubitVector dir3,
CubitVector extrema,
GeometryEntity *&  extrema_entity_ptr
) [virtual]
Definition at line 807 of file FacetQueryEngine.cpp.
const std::type_info & FacetQueryEngine::entity_type_info ( ) const [virtual]
Definition at line 195 of file FacetQueryEngine.cpp.
   return typeid(*this);
CubitStatus FacetQueryEngine::export_facets ( DLIList< CubitFacet * > &  facet_list,
char *  filename
) [static]
Definition at line 4271 of file FacetQueryEngine.cpp.
  // open the file for writing
  FILE *fp = fopen(filename, "w");
  if (!fp)
    PRINT_ERROR("Couldn't open file %s for writing.\n", filename);
  // make list of all points
  CubitPoint *point_ptr;
  DLIList<CubitPoint*>temp_point_list;
  int ii, jj;
  for (ii=0; ii<facet_list.size(); ii++)
    for(jj=0; jj<3; jj++)
      point_ptr = facet_ptr->point(jj);
      point_ptr->marked(-1);
      temp_point_list.append(point_ptr);
  // assign ids to points and make list unique
  int id = 0;
  DLIList<CubitPoint*>point_list;
  for (ii=0; ii<temp_point_list.size(); ii++)
    point_ptr = temp_point_list.get_and_step();
    if (point_ptr->marked() == -1)
      point_ptr->marked(id++);
      point_list.append( point_ptr );
  // write the points
  CubitVector coords;
  fprintf(fp, "%d\n", point_list.size());
  point_list.reset();
  for(ii=0; ii<point_list.size(); ii++)
    point_ptr = point_list.get_and_step();
    coords = point_ptr->coordinates();
    fprintf(fp,"%d %f %f %f\n", ii, coords.x(), coords.y(), coords.z());
  // write the facets
  int indx[3];
  fprintf(fp, "%d\n", facet_list.size());
    for (jj=0; jj<3; jj++)
      indx[jj] = facet_ptr->point(jj)->marked();
    fprintf(fp,"%d %d %d %d\n", ii, indx[0], indx[1], indx[2]);
  //- unmark the points
    point_list.get_and_step()->marked(0);
  fclose(fp);
CubitStatus FacetQueryEngine::export_solid_model ( DLIList< TopologyBridge * > &  bridge_list,
const char *  file_name,
const CubitString cubit_version,
ModelExportOptions export_options
) [virtual]
R CubitStatus R- CUBIT_SUCCESS/CUBIT_FAILURE I ref_entity_list I- A list of RefEntities to be exported or saved to a file. I file_name I- The name of the file to write to. I file_type I- An optional type of file.
  • Export the current CUBIT geometry (everything in the Model) to a
  • solid model format. Valid file types are:
  • "IGES" -- IGES file
  • "STEP" -- STEP file I logfile_name I- Optional - name of logfile.
  • No logfile gets created for SAB/SAT files, but for IGES and
  • STEP file a logfile always gets created. Default filenames
  • are assigned if one is not given (iges_export.log, step_export.log).
  • The function returns CUBIT_FAILURE if anything goes wrong with
  • export - improper file type, inaccessible file, mismatch between
  • the underlying representation and file type. It returns
  • CUBIT_SUCCESS if everything goes well.
Definition at line 880 of file FacetQueryEngine.cpp.
  if(  file_type != FACET_TYPE )
  DLIList<FacetBody*>    facet_bodies;
  DLIList<FacetLump*>    facet_lumps;
  DLIList<FacetShell*>   facet_shells;
  DLIList<FacetSurface*> facet_surfaces;
  DLIList<FacetLoop*>    facet_loops;
  DLIList<FacetCoEdge*>  facet_coedges;
  DLIList<FacetCurve*>   facet_curves;
  DLIList<FacetPoint*>   facet_points;
  DLIList<TopologyBridge*> ref_entities_handled;
  int i;
  //Collect all free entities (bodies, curves, vertices )
  ref_entity_list.reset();
  for(i=ref_entity_list.size(); i>0; i--)
    TopologyBridge* ref_entity_ptr = ref_entity_list.get();
    CubitBoolean handled = CUBIT_TRUE;
    //if it is a Vertex
    if( FacetPoint* pt = CAST_TO( ref_entity_ptr, FacetPoint) )
      facet_points.append( pt );
    //if it is a Curve
    else if( FacetCurve* curve = CAST_TO( ref_entity_ptr, FacetCurve) )
      facet_curves.append( curve );
    //if it is a Surface -- I don't think you can ever have a free surface
    //without it being a Body
    else if( FacetSurface* surf = CAST_TO( ref_entity_ptr, FacetSurface) )
      facet_surfaces.append( surf );
    //if it is a Body
    else if( FacetBody* body = CAST_TO( ref_entity_ptr, FacetBody ) )
      facet_bodies.append( body );
    else
      handled = CUBIT_FALSE;
    if( handled == CUBIT_TRUE )
      ref_entities_handled.append( ref_entity_ptr );
      ref_entity_list.change_to(NULL);
    ref_entity_list.step();
  ref_entity_list.remove_all_with_value(NULL);
  int free_body_count = facet_bodies.size();
  int free_curve_count = facet_curves.size();
  int free_point_count = facet_points.size();
  //if nothing to write out...return
  if( free_body_count == 0 && free_curve_count == 0 && free_point_count == 0)
  //get file pointer
  FILE *file_ptr = fopen( file_name, "wb" );
  //get all child entities from the bodies, curves, & vertices
  gather_all_facet_entities( facet_bodies, facet_lumps,
                             facet_shells, facet_surfaces,
                             facet_loops, facet_coedges,
                             facet_curves, facet_points );
  //create a wrapper object for writing
  CIOWrapper file_writer( file_ptr );
  // write out file type "MESHED_BASED_GEOMETRY"
  file_writer.BeginWriteBlock(0);
  file_writer.Write( "MESH_BASED_GEOMETRY", 19 );
  // write out Endian value
  UnsignedInt32 endian_value = CCubitFile::mintNativeEndian;
  file_writer.Write( &endian_value, 1 );
  // write out version #
  UnsignedInt32 version = 1;
  file_writer.Write( &version, 1 );
  //save the facets (geometry info )
  CubitStatus status;
  status = save_facets( file_ptr, facet_surfaces, facet_curves, facet_points );
  if( status == CUBIT_FAILURE ) return CUBIT_FAILURE;
  //write out topology and attributes
  status = write_topology( file_ptr,
  if( free_body_count || free_curve_count || free_point_count )
      PRINT_INFO( "\nExported:" );
   int flg = 0;
   if( free_body_count )
      if( flg )PRINT_INFO( "         " );else flg=1;
      if( DEBUG_FLAG( 153 ) )
        if( free_body_count == 1 )
           PRINT_INFO( "%4d Facet Body\n", free_body_count );
        else
           PRINT_INFO( "%4d Facet Bodies\n", free_body_count );
      if( facet_lumps.size() == 1 )
         PRINT_INFO( "%4d Facet Volume\n", facet_lumps.size() );
      else
         PRINT_INFO( "%4d Facet Volumes\n", facet_lumps.size() );
   if( free_curve_count )
      if( free_curve_count == 1 )
         PRINT_INFO( "%4d Facet Curve\n", free_curve_count );
      else
         PRINT_INFO( "%4d Facet Curves\n", free_curve_count );
   if( free_point_count )
      if( free_point_count == 1 )
         PRINT_INFO( "%4d Facet Point\n", free_point_count );
      else
         PRINT_INFO( "%4d Facet Points\n", free_point_count );
   PRINT_INFO( "\n" );
  fclose( file_ptr );
virtual CubitStatus FacetQueryEngine::export_solid_model ( DLIList< TopologyBridge * > &  bridge_list,
char *&  p_buffer,
int &  n_buffer_size,
) [inline, virtual]
Definition at line 263 of file FacetQueryEngine.hpp.
{return CUBIT_FAILURE;}
CubitStatus FacetQueryEngine::fire_ray ( CubitVector origin,
CubitVector direction,
DLIList< TopologyBridge * > &  at_entity_list,
DLIList< double > &  ray_params,
int  max_hits,
double  ray_radius,
DLIList< TopologyBridge * > *  hit_entity_list = 0
) const [virtual]
Definition at line 2442 of file FacetQueryEngine.cpp.
  TopologyBridge *bridge_ptr;
  int i, j;
  bool hit = false;
  DLIList<double> tmp_ray_params;
  DLIList<FacetSurface*> at_surface_list;
  DLIList<FacetCurve*> at_curve_list;
  DLIList<FacetPoint*> at_point_list;
  if( ray_radius == 0.0 )
      ray_radius = get_sme_resabs_tolerance();
  at_entity_list.reset();
  for (i=0; i<at_entity_list.size(); i++)
      hit = false;
      bridge_ptr = at_entity_list.get_and_step();
      //determine which type of geometry we have. body, lump, face, curve?
      if (CAST_TO(bridge_ptr, FacetBody))
          FacetBody* f_body = CAST_TO(bridge_ptr, FacetBody);
          DLIList<Surface*> surface_list;
          f_body->surfaces(surface_list);
      else if (CAST_TO(bridge_ptr, FacetLump))
          FacetLump* f_lump = CAST_TO(bridge_ptr, FacetLump);
          PRINT_INFO("Found FacetLump.\n");
          DLIList<FacetSurface*> f_surface_list;
          f_lump->get_surfaces(f_surface_list);
          at_surface_list.merge_unique(f_surface_list);
      else if (CAST_TO(bridge_ptr, Surface))
          FacetSurface* f_surface = CAST_TO(bridge_ptr, FacetSurface);
          f_surface->get_my_facets(facet_list, point_list);
          //PRINT_INFO("There are %d facets.\n", facet_list.size());
          //RTree<CubitFacet*> rtree(ray_radius);
          //for (j=0; j<facet_list.size(); j++)
            //  rtree.add(facet_list.get_and_step();
          //DLIList<CubitFacet*> facet_list1;
          //CubitBox range_box();
          //make range box for the ray
          //rtree.find(range_box, facet_list1);
          CubitVector* intersection_pt = new CubitVector();
          double distance;
              if (hit)
                  break;
              CubitFacet* facet = facet_list.get_and_step();
              // Find intersection of ray with triangle
              int rv = FacetEvalTool::intersect_ray(origin, direction, facet, intersection_pt, distance);
              switch (rv)
              case -1:
                  //PRINT_INFO("Facet is degenerate (segment or point).\n");
                  break;
              case 0:
                  //PRINT_INFO("Ray does not intersect the facet.\n");
                  break;
              case 1:
                      hit = true;
                      if (hit_entity_list)
                          hit_entity_list->append(bridge_ptr);
                      ray_params.append(distance);
                      //PRINT_INFO("Ray intersects facet at %f, %f, %f.\n", intersection_pt->x(), intersection_pt->y(), intersection_pt->z());
                      continue;
              case 2:
                  //PRINT_INFO("Ray is in same plane as the facet.\n");
                  break;
          if (intersection_pt)
              delete intersection_pt;
      else if (CAST_TO(bridge_ptr, Curve))
          FacetCurve* f_curve = CAST_TO(bridge_ptr, FacetCurve);
          DLIList<CubitFacetEdge*> facet_edge_list;
          f_curve->get_facets(facet_edge_list);
          //PRINT_INFO("There are %d facetedges.\n", facet_edge_list.size());
          double distance;
          for (j=0; j<facet_edge_list.size(); j++)
              if (hit)
                  break;
              CubitFacetEdge* facet_edge = facet_edge_list.get_and_step();
              int rv = FacetEvalTool::intersect_ray(origin, direction, facet_edge, intersection_pt, distance);
              switch (rv)
              case -1:
                  break;
              case 0:
                  //PRINT_INFO("Ray does not intersect the facet edge.\n");
                  break;
              case 1:
                      hit = true;
                      continue;
              case 2:
                  //PRINT_INFO("Ray is parallel to the facet.\n");
                  break;
      else if (CAST_TO(bridge_ptr, FacetPoint))
          FacetPoint* f_point = CAST_TO(bridge_ptr, FacetPoint);
          at_point_list.append_unique(f_point);
      else
          ;//PRINT_INFO("Cast error in FacetQueryEngine::fire_ray.\n");
CubitStatus FacetQueryEngine::gather_all_facet_entities ( DLIList< FacetBody * > &  facet_bodies,
DLIList< FacetLump * > &  facet_lumps,
DLIList< FacetShell * > &  facet_shells,
DLIList< FacetSurface * > &  facet_surfaces,
DLIList< FacetLoop * > &  facet_loops,
DLIList< FacetCoEdge * > &  facet_coedges,
DLIList< FacetCurve * > &  facet_curves,
DLIList< FacetPoint * > &  facet_points
Definition at line 1030 of file FacetQueryEngine.cpp.
  int i;
  //Collect FacetLumps from FacetBody
  for(i=0; i<facet_bodies.size(); i++)
    FacetBody *facet_body = facet_bodies.get_and_step();
    facet_body->get_lumps( facet_lumps );
  //Collect FacetShells from FacetLumps
  for(i=0; i<facet_lumps.size(); i++)
    FacetLump *facet_lump = facet_lumps.get_and_step();
    facet_lump->get_shells( facet_shells );
  //Collect FacetSurfaces from FacetShells
  for(i=0; i<facet_shells.size(); i++)
    FacetShell *facet_shell = facet_shells.get_and_step();
    facet_shell->get_surfaces( facet_surfaces );
  facet_surfaces.uniquify_ordered();
  //Collect FacetLoops from FacetSurfaces
  for(i=0; i<facet_surfaces.size(); i++)
    FacetSurface *facet_surface = facet_surfaces.get_and_step();
    facet_surface->get_loops( facet_loops );
  //Collect FacetCoEdges from FacetLoops
  for(i=0; i<facet_loops.size(); i++)
    FacetLoop *facet_loop = facet_loops.get_and_step();
    facet_loop->get_coedges( facet_coedges );
  //Collect FacetCurves from FacetCoEdges
  for( i=0; i<facet_coedges.size(); i++)
    FacetCoEdge *facet_coedge = facet_coedges.get_and_step();
    facet_coedge->get_curves( facet_curves );
  facet_curves.uniquify_ordered();
  //Collect FacetPoints from FacetCurves
  for( i=0; i<facet_curves.size(); i++)
    FacetCurve *facet_curve = facet_curves.get_and_step();
    facet_curve->get_points( facet_points );
  //uniquify lists
  facet_points.uniquify_ordered();
CubitStatus FacetQueryEngine::gather_facets ( DLIList< FacetSurface * >  facet_surfaces,
Definition at line 4951 of file FacetQueryEngine.cpp.
  int ii, jj, kk;
  FacetSurface *fsurf_ptr;
  FacetCurve *fcurv_ptr;
  FacetPoint *fpoint_ptr;
  DLIList<CubitFacet *>temp_facets;
  DLIList<CubitPoint *>temp_points;
  DLIList<CubitFacetEdge *>temp_edges;
  CubitPoint *cp_ptr;
  //unmark facets/edges/points on surface
  for(ii=facet_surfaces.size(); ii--;)
    fsurf_ptr = facet_surfaces.get_and_step();
    temp_facets.clean_out();
    temp_points.clean_out();
    fsurf_ptr->get_my_facets(temp_facets, temp_points);
    for(jj=0; jj<temp_facets.size(); jj++)
      facet_ptr = temp_facets.get_and_step();
      facet_ptr->marked( 0 );
      for (kk=0; kk<3; kk++)
        edge_ptr = facet_ptr->edge( kk );
        edge_ptr->marked( 0 );
    for (jj=0; jj<temp_points.size(); jj++)
      cp_ptr = temp_points.get_and_step();
      cp_ptr->marked( 0 );
  //unmark facet-edges/points on curves
  for(ii=facet_curves.size(); ii--; )
    fcurv_ptr = facet_curves.get_and_step();
    temp_edges.clean_out();
    fcurv_ptr->get_facets( temp_edges );
    for (jj=0; jj<temp_edges.size(); jj++)
      edge_ptr = temp_edges.get_and_step();
      edge_ptr->point( 0 )->marked( 0 );
      edge_ptr->point( 1 )->marked( 0 );
  //unmark facet-points on points
  for(ii=facet_points.size(); ii--; )
    fpoint_ptr = facet_points.get_and_step();
    if (fpoint_ptr != NULL)
      cp_ptr = fpoint_ptr->get_cubit_point();
  // make unique lists
      if (0 == facet_ptr->marked())
        facet_ptr->marked( 1 );
        facet_list.append( facet_ptr );
        if (0 == edge_ptr->marked())
          edge_ptr->marked( 1 );
          edge_list.append( edge_ptr );
      if (0 == cp_ptr->marked())
        cp_ptr->marked(1);
        point_list.append( cp_ptr );
  for(ii=facet_curves.size(); ii--;)
        edge_ptr->marked(1);
        for (kk=0; kk<2; kk++)
          cp_ptr = edge_ptr->point( kk );
            cp_ptr->marked(1);
            point_list.append(cp_ptr);
  for(ii=facet_points.size(); ii--;)
      cp_ptr->marked( 1 );
  // set the IDs of the facet entities and clear the marks
  facet_list.reset();
    facet_ptr->set_id(ii);
    facet_ptr->marked(0);
  edge_list.reset();
  for (ii=0; ii<edge_list.size(); ii++)
    edge_ptr->set_id(ii);
    edge_ptr->marked(0);
    cp_ptr->set_id(ii);
    cp_ptr->marked(0);
CubitStatus FacetQueryEngine::get_all_hash_points ( DLIList< CubitPoint * > &  point_list) [static, private]
Definition at line 4450 of file FacetQueryEngine.cpp.
  CubitStatus rv = CUBIT_SUCCESS;
  int ii, jj;
  for(jj=0; jj<hashPointSize; jj++)
    for (ii=0; ii<hashPointArray[jj].size(); ii++)
      point_ptr = hashPointArray[jj].get_and_step();
  return rv;
CubitStatus FacetQueryEngine::get_connected_patch ( DLIList< FacetSurface * > &  remaining_surfs,
DLIList< FacetSurface * > &  output_patch
Definition at line 381 of file FacetQueryEngine.cpp.
  DLIList<FacetSurface*> stack, curve_surfs;
  std::set<FacetSurface*> marked;
  DLIList<FacetCurve*> curves;
  int debug_this = 0;
  if(debug_this){
    GfxDebug::clear();
  int i;
  for (i = remaining_surfs.size(); i--; )
    marked.insert( remaining_surfs.get_and_step() );
  // Choose one surface to start with
  FacetSurface* surf = remaining_surfs.pop();
  marked.erase( surf );
  stack.append( surf );
  // Get all connected surfaces
  while( stack.size() )
    surf = stack.pop();
    if(debug_this){
      surf->get_eval_tool()->debug_draw_facets(CUBIT_BLUE_INDEX);
      GfxDebug::mouse_xforms();
    output_patch.append( surf );
    surf->get_curves( curves );
    while (curves.size())
      FacetCurve* curve = curves.pop();
      curve->get_surfaces( curve_surfs );
      if(debug_this && curve_surfs.size() < 2){
        PRINT_INFO("Curve is not connected to 2 surfaces.\n");
        curve->get_eval_tool()->debug_draw_facet_edges(CUBIT_MAGENTA_INDEX);
      while (curve_surfs.size())
        FacetSurface* curve_surf = curve_surfs.pop();
        if (marked.erase(curve_surf))
          stack.append( curve_surf );
  // Remove output surfaces from input list
  // At this point, "marked" contains all the surfaces not in "ouput_patch"
  remaining_surfs.last();
    if (marked.find(remaining_surfs.step_and_get()) == marked.end())
      remaining_surfs.change_to( 0 );
    remaining_surfs.remove_all_with_value( 0 );
Definition at line 178 of file FacetQueryEngine.cpp.
  CubitString version_string = "Facet Geometry Engine version ";
  version_string += CubitString::number(get_major_version());
  version_string += CubitString(".");
  version_string += CubitString::number(get_minor_version());
  version_string += CubitString::number(get_subminor_version());
  return version_string;
CubitStatus FacetQueryEngine::get_graphics ( BodySM bodysm,
GMem g_mem,
std::vector< Surface * > &  surface_to_facets_vector,
std::vector< TopologyBridge * > &  vertex_edge_to_point_vector,
std::vector< std::pair< TopologyBridge *, std::pair< int, int > > > &  facet_edges_on_curves,
) const [virtual]
Reimplemented from GeometryQueryEngine.
Definition at line 443 of file FacetQueryEngine.cpp.
  FacetBody *facet_body = CAST_TO(bodysm, FacetBody );
  if( NULL == facet_body )
  DLIList<Surface*> surfaces;
  bodysm->surfaces( surfaces );
  //unmark all the points
  for( int i=surfaces.size(); i--; )
    Surface *tmp_surf = surfaces.get_and_step();
    FacetSurface *facet_surface = CAST_TO( tmp_surf, FacetSurface );
    DLIList<CubitPoint*> surface_points;
    facet_surface->get_my_points( surface_points );
    for( int k=surface_points.size(); k--; )
      surface_points.get_and_step()->marked(0);
  DLIList<CubitFacet*> all_facets;
  int point_index = 0;
  std::vector<CubitPoint*> all_points;
    DLIList<CubitFacet*> surface_facets;
    facet_surface->get_my_facets(surface_facets, surface_points);
    surface_facets.reset();
    all_facets += surface_facets;
      CubitPoint *tmp_pt = surface_points.get_and_step();
      if( tmp_pt->marked() == 0 )
        all_points.push_back( tmp_pt );
        point_index++;
        tmp_pt->marked( point_index );
        vertex_edge_to_point_vector.push_back( tmp_surf );
    for( int k=surface_facets.size(); k--; )
      surface_to_facets_vector.push_back( tmp_surf );
  //now stuff them into the g_mem
  g_mem->allocate_tri( all_facets.size() );
  g_mem->fListCount = all_facets.size() * 4;
  g_mem->pointListCount = all_points.size();
  GPoint* pt_itor = g_mem->point_list();
  for ( size_t i = 0; i < all_points.size(); i++ )
    CubitPoint* point = all_points[i];
    pt_itor->x = (float)point->x();
    pt_itor->y = (float)point->y();
    pt_itor->z = (float)point->z();
    pt_itor++;
   // Copy facets to Gmem
  all_facets.reset();
  int* f_itor = g_mem->facet_list();
  for ( int i = 0; i < all_facets.size(); i++ )
    *(f_itor++) = 3;
    CubitFacet* facet = all_facets.get_and_step();
    for ( int j = 0; j < 3; j++ )
      *(f_itor++) = facet->point(j)->marked() - 1;  //go back to zero-based
  //get all the curves
  DLIList<Curve*> curves;
  bodysm->curves( curves );
  for( int i=curves.size(); i--; )
    Curve *tmp_curve = curves.get_and_step();
    FacetCurve *facet_curve = CAST_TO( tmp_curve, FacetCurve );
    DLIList<CubitFacetEdge*> curve_facets;
    facet_curve->get_facets(curve_facets);
    DLIList<CubitPoint*> curve_points;
    facet_curve->get_points(curve_points);
    curve_points.reset();
    curve_facets.reset();
    for( int k=0; k<curve_points.size(); k++ )
      CubitPoint *tmp_pt = curve_points.get_and_step();
      assert( tmp_pt->marked() );
      if( k == curve_points.size() - 1 )
        break;
      int index1 = tmp_pt->marked();
      int index2 = curve_points.get()->marked();
      vertex_edge_to_point_vector[index1-1] = tmp_curve;
      facet_edges_on_curves.push_back( std::make_pair( tmp_curve, std::make_pair( index1-1, index2-1) ) );
  //get all the vertices
  DLIList<TBPoint*> points;
  bodysm->points( points );
  for( int i=points.size(); i--; )
    TBPoint *tmp_pt = points.get_and_step();
    FacetPoint *facet_point = CAST_TO( tmp_pt, FacetPoint );
    CubitPoint *cubit_pt = facet_point->get_cubit_point();
    assert( cubit_pt->marked() );
    vertex_edge_to_point_vector[cubit_pt->marked()-1] = tmp_pt;
  //reset the marks back to zero
  for ( unsigned int i = 0; i < all_points.size(); i++ )
    all_points[i]->marked(0);
CubitStatus FacetQueryEngine::get_graphics ( Surface surface_ptr,
GMem gMem,
) const [virtual]
Definition at line 589 of file FacetQueryEngine.cpp.
  if( !gMem )
    //  get the FacetSurface.
  int i;
  FacetSurface *facet_surf_ptr = CAST_TO(surface_ptr,FacetSurface);
  if( ! facet_surf_ptr )
    // get the facets for the surface
  facet_surf_ptr->get_my_facets(surface_facets, surface_points);
    // set return values, and if GMem is NULL return
    // (caller just wanted to know the counts.)
  int number_points = surface_points.size();
  int number_triangles = surface_facets.size();
    // Allocate space in GMem
  gMem->allocate_tri(number_triangles);
  gMem->fListCount = surface_facets.size() * 4;
  gMem->pointListCount = number_points;
    // Copy points to GMem
  surface_points.reset();
  GPoint* pt_itor = gMem->point_list();
  for ( i = 0; i < number_points; i++ )
    CubitPoint* point = surface_points.get_and_step();
    point->marked(i);
    pt_itor++;
  int* f_itor = gMem->facet_list();
  for ( i = 0; i < number_triangles; i++ )
    *(f_itor++) = 3;
    CubitFacet* facet = surface_facets.get_and_step();
      *(f_itor++) = facet->point(j)->marked();
    // cleanup
  while( surface_points.size() )
    surface_points.pop()->marked(0);
CubitStatus FacetQueryEngine::get_graphics ( Curve curve_ptr,
GMem gMem,
double  angle_tolerance = 0,
double  distance_tolerance = 0,
double  max_edge_length = 0
) const [virtual]
Definition at line 655 of file FacetQueryEngine.cpp.
  //  get the FacetCurve.
  FacetCurve *facet_curv_ptr = CAST_TO(curve_ptr,FacetCurve);
  facet_curv_ptr->get_facets(curve_facets);
  int number_facets = curve_facets.size();
  facet_curv_ptr->get_points(curve_points);
  int num_points = curve_points.size();
  GPoint *new_point_list = new GPoint[num_points];
  int *new_facet_list = new int [number_facets*3];
  int ii;
  CubitPoint *cur_pnt;
  for ( ii = 0; ii < num_points; ii++ )
    cur_pnt = curve_points.get();
    new_point_list[ii].x = cur_pnt->x();
    new_point_list[ii].y = cur_pnt->y();
    new_point_list[ii].z = cur_pnt->z();
      //mark the point with the index into the point list.
      //This is very important to make sure we can index these
      //points when we do the facet array.
    curve_points.get_and_step()->marked(ii);
  for ( ii = 0; ii < number_facets; ii++ )
      //All our facets are segments.  So the first value is 2.
    int index_count = 3*ii;
    new_facet_list[index_count] = 2;
    int jj = index_count + 1;
    int ll, kk;
    CubitFacetEdge *facet_ptr = curve_facets.get_and_step();
    CubitPoint *temp_point;
    for ( kk = jj, ll = 0; kk < jj+2; kk++, ll++)
      temp_point = facet_ptr->point(ll);
      int index_to_point = temp_point->marked();
      if ( index_to_point < 0 || index_to_point > num_points )
        PRINT_ERROR("Bad logic in converting edge facets to drawing facets.\n");
        delete[] new_point_list;
        delete[] new_facet_list;
      new_facet_list[kk] = index_to_point;
  gMem->replace_point_list(new_point_list, num_points, num_points);
  gMem->replace_facet_list(new_facet_list, number_facets*3, number_facets*3);
  gMem->points_consolidated(CUBIT_TRUE);
int FacetQueryEngine::get_hash_key ( int  id) [static, private]
Definition at line 4439 of file FacetQueryEngine.cpp.
  int key = id % hashPointSize;
  return key;
CubitPoint * FacetQueryEngine::get_hash_point ( int  id) [static, private]
Definition at line 4402 of file FacetQueryEngine.cpp.
  int ii;
  int found = 0;
  for (ii=0; ii<hashPointArray[key].size() && !found; ii++)
    point_ptr = hashPointArray[key].get_and_step();
    if (point_ptr->id() == id)
      return point_ptr;
  return (CubitPoint*)NULL;
Definition at line 765 of file FacetQueryEngine.cpp.
Definition at line 775 of file FacetQueryEngine.cpp.
CubitStatus FacetQueryEngine::get_intersections ( Curve ref_edge1,
Curve ref_edge2,
DLIList< CubitVector > &  intersection_list,
double  offset,
CubitBoolean  ext_first = CUBIT_TRUE
) [virtual]
Definition at line 783 of file FacetQueryEngine.cpp.
CubitStatus FacetQueryEngine::get_intersections ( Curve ref_edge,
Surface ref_face,
CubitBoolean  bounded = CUBIT_FALSE
) [virtual]
Definition at line 793 of file FacetQueryEngine.cpp.
CubitStatus FacetQueryEngine::get_isoparametric_points ( Surface ,
int &  nu,
int &  nv,
GMem *&
) const [virtual]
Definition at line 722 of file FacetQueryEngine.cpp.
  nu = nv = 0;
Definition at line 163 of file FacetQueryEngine.cpp.
  return FQE_MAJOR_VERSION;
Definition at line 168 of file FacetQueryEngine.cpp.
  return FQE_MINOR_VERSION;
CubitStatus FacetQueryEngine::get_point_containment ( DLIList< BodySM * > &  bodysm_list,
DLIList< CubitVector > &  point_list,
double  tolerance,
std::vector< std::pair< BodySM *, std::vector< int > > > &  bodysm_to_pt_indices
) [virtual]
Definition at line 5275 of file FacetQueryEngine.cpp.
  //convert all the BodySMs into FacetBodies
  DLIList<FacetBody*> body_list;
  for( int k=bodysm_list.size(); k--; )
    BodySM *body_sm = bodysm_list.get_and_step();
    FacetBody *facet_body = dynamic_cast<FacetBody*>(body_sm);
    if( !facet_body )
    body_list.append( facet_body );
  //stuff all the points into the atree
  AbstractTree<ContainmentPoint*> *atree = new RTree<ContainmentPoint*>( tolerance );
  std::vector<ContainmentPoint*> atree_nodes;
  int num_points = point_list.size();
  for( int i=0; i<num_points; i++ )
    ContainmentPoint *tmp_pt = new ContainmentPoint();
    tmp_pt->pt_coordinates = &(point_list[i]);
    tmp_pt->index = i;
    atree->add( tmp_pt );
    atree_nodes.push_back( tmp_pt );
  int num_bodies = body_list.size();
  if( num_bodies > 10 )
    char message[128];
    sprintf(message, "Point containment routine: %d points %d volumes.", num_points, num_bodies );
    AppUtil::instance()->progress_tool()->start(0, num_bodies,
      "Progress", message, TRUE, TRUE );
  //for each body
  //get the points in the bbox of the body
  for( int i=0; i<body_list.size(); i++ )
    FacetBody *facet_body = body_list[i];
    CubitBox cubit_box = facet_body->bounding_box();
    double range_ratio = cubit_box.maximum_range() / cubit_box.minimum_range();
    //find the points in the bounding box
    DLIList<ContainmentPoint*> close_pts;
    atree->find( cubit_box, close_pts );
    std::vector<int> pts_in_body;
    //if( 0 ) // old ray-shooting
    //if( 1 ) // new octree
    if( range_ratio < CUTOFF_BBOX_RANGE_RATIO && (close_pts.size() > CUTOFF_NUM_NODES /*pow( pow(2, CUTOFF_OCTREE_DEPTH), 3) */ ) ) // smart
      // build octree
      RefEntity* ref_ent = dynamic_cast<RefEntity*>( facet_body->topology_entity() );
      DLIList<RefEntity*> ref_entity_list;
      ref_entity_list.insert( ref_ent );
      CubitOctreeGeneratorVolumes octree_generator( ref_entity_list);
      octree_generator.generate_full_octree();
      for( int k=0; k<close_pts.size(); k++ )
        //ask each point if it is in the body
        CubitVector tmp_vec = *(close_pts[k]->pt_coordinates);
        CubitPointContainment pt_cont;
        pt_cont = octree_generator.point_containment( tmp_vec, tolerance );
        switch( pt_cont )
          case CUBIT_PNT_INSIDE:
            if( false == allow_pts_in_multiple_bodies )
              atree->remove( close_pts[k] );
            pts_in_body.push_back( close_pts[k]->index );
            //GfxDebug::draw_point(tmp_vec.x(), tmp_vec.y(), tmp_vec.z(), CUBIT_BLUE_INDEX);
            //PRINT_INFO(" INSIDE ");
            break;
          case CUBIT_PNT_BOUNDARY:
            pt_cont = facet_body->point_containment( tmp_vec, tolerance );
            if( CUBIT_PNT_INSIDE == pt_cont || CUBIT_PNT_BOUNDARY == pt_cont )
            //GfxDebug::draw_point(tmp_vec.x(), tmp_vec.y(), tmp_vec.z(), CUBIT_GREEN_INDEX);
            //PRINT_INFO(" BOUNDARY ");
            break;
          case CUBIT_PNT_OUTSIDE:
            // do nothing
            //GfxDebug::draw_point(tmp_vec.x(), tmp_vec.y(), tmp_vec.z(), CUBIT_RED_INDEX);
            //PRINT_INFO(" OUTSIDE ");
            break;
          default:
            break;
    else {
        CubitPointContainment pt_cont = facet_body->point_containment( tmp_vec, tolerance );
      AppUtil::instance()->progress_tool()->step();
    if(AppUtil::instance()->interrupt())
         AppUtil::instance()->progress_tool()->end();
      //clean up
       while( atree_nodes.size() )
         delete atree_nodes.back();
         atree_nodes.pop_back();
      delete atree;
    bodysm_to_pt_indices.push_back( std::make_pair( bodysm_list[i], pts_in_body ) );
  //cleanup
  delete atree;
double FacetQueryEngine::get_sme_resabs_tolerance ( ) const [virtual]
Definition at line 2605 of file FacetQueryEngine.cpp.
  return GEOMETRY_RESABS;
Definition at line 173 of file FacetQueryEngine.cpp.
CubitStatus FacetQueryEngine::get_u_isoparametric_points ( Surface ref_face_ptr,
double  v,
int &  n,
GMem *&  gMem
) const [virtual]
Definition at line 731 of file FacetQueryEngine.cpp.
CubitStatus FacetQueryEngine::get_v_isoparametric_points ( Surface ref_face_ptr,
double  u,
int &  n,
GMem *&  gMem
) const [virtual]
Definition at line 739 of file FacetQueryEngine.cpp.
CubitStatus FacetQueryEngine::import_facets ( const char *  file_name,
double  tolerance,
int  interp_order,
DLIList< CubitQuadFacet * > &  quad_facet_list,
DLIList< CubitFacet * > &  tri_facet_list,
DLIList< Surface * > &  surface_list,
FacetFileFormat  file_format = CUBIT_FACET_FILE
Definition at line 3379 of file FacetQueryEngine.cpp.
  DLIList <CubitFacet *>tfacet_list;
  DLIList <CubitQuadFacet *>qfacet_list;
  DLIList <CubitPoint *>point_list;
  ShellSM *shell_ptr;
  DLIList<ShellSM*> shell_list;
  Lump *lump_ptr;
  DLIList<Lump*> lump_list;
  BodySM *bodysm_ptr;
  Body *body_ptr;
  GeometryQueryTool *gti = GeometryQueryTool::instance();
  FacetShell* facet_shell;
  DLIList<DLIList<CubitFacet *> *> shell_facet_list;
  int ishell, ii;
  CubitBoolean is_water_tight = CUBIT_TRUE;
  // read the facets from a file
  int *conn = NULL;
  int npoints = 0;
  int nfacets = 0;
  int nquad = 0;
  int ntri = 0;
  int prev_vert;
  int prev_edge;
  int prev_face;
  int prev_vol;
  int prev_bod;
  long stl_seek_address=0;
  bool stl_multiple_parts = true;
  CubitStatus rv;
  //  Here we add the capability to read stl files with more than one part.
  while ( stl_multiple_parts == true ) {
    stl_multiple_parts = false;
    prev_vert = gti->num_ref_vertices();
    prev_edge = gti->num_ref_edges();
    prev_face = gti->num_ref_faces();
    prev_vol  = gti->num_ref_volumes();
    prev_bod  = gti->num_bodies();
    switch (file_format)
    case STL_FILE:
      tfacet_list.clean_out(); // In case there are multiple parts in the stl file
      shell_list.clean_out();
      lump_list.clean_out();
      shell_facet_list.clean_out();
      if (tolerance>0)
        rv = read_facets_stl_tolerance(tfacet_list, point_list, file_name, npoints, ntri, stl_seek_address, tolerance);
      else
        rv = read_facets_stl(tfacet_list, point_list, file_name, npoints, ntri, stl_seek_address);
      PRINT_INFO("  %d facets read.\n", ntri);
      if ( (rv == CUBIT_SUCCESS) && (stl_seek_address) > 0 ) stl_multiple_parts = true;
      nfacets = ntri;
      if (rv != CUBIT_SUCCESS)
        goto end_import_facets;
      break;
    case CUBIT_FACET_FILE:
    case AVS_FILE:
      rv = read_facets( file_name, conn, npoints, nquad, ntri, file_format );
      nfacets = ntri + nquad;
      // make cubit facet entities from the points and connectivity
      if (nquad  > 0)
        rv = make_facets(conn, nfacets, qfacet_list);
      if (ntri > 0)
        rv = make_facets(conn, nfacets, tfacet_list);
      get_all_hash_points(point_list);
      delete_hash_points();
      break;
    case CHOLLA_FILE:
      rv = read_cholla_file( file_name, feature_angle, point_list, tfacet_list );
      nquad = 0;
      ntri = tfacet_list.size();
      break;
    case FROM_FACET_LIST:
      tfacet_list = tri_facet_list;
      qfacet_list = quad_facet_list;
      if (tfacet_list.size() + qfacet_list.size() == 0)
        PRINT_ERROR("No facets found to build geometry\n");
        rv = CUBIT_FAILURE;
      break;
    default:
      assert(0); // unrecognized file format
      break;
      PRINT_ERROR("No facets read from file %s.\n", file_name);
      rv = CUBIT_FAILURE;
    else
      PRINT_INFO("Building facet-based geometry from %d facets...\n",
                  tfacet_list.size() + qfacet_list.size() );
//  if (fix)
//    rv = check_facets( point_list, tfacet_list );
    if (0)
      // Call function to generate an x-y-z file for a CTH/SPH simulation
      // the following is an exampl call...
      //make_sph( point_list, tfacet_list, 100.0, "fem1-sph100.xyz" );
    if (0)
      // This is an example of using the export_facets function.  Writes
      // a facet file of all facets in the list
        //commented out because otherwise it's a compiler warning.
//     char filename[128];
//     strcpy(filename, "my_test.facets");
//     export_facets(tfacet_list,filename);
    // split the facets into shells if needed
    rv = FacetDataUtil::split_into_shells(tfacet_list, qfacet_list,
                                          shell_facet_list, is_water_tight);
      PRINT_ERROR("Error processing facets from %s.\n", file_name);
    // if the facets aren't watertight, see if they can be merged
    if (!is_water_tight && stitch)
      rv = FacetDataUtil::stitch_facets(shell_facet_list,
                                        GEOMETRY_RESABS,
                                        is_water_tight);
        PRINT_WARNING("Couldn't stitch facets.\n");
    DLIList <CubitFacet *> *facet_list_ptr;
    if (improve)
      for (ishell = 0; ishell < shell_facet_list.size(); ishell++)
        facet_list_ptr = shell_facet_list.get_and_step();
        rv = FacetDataUtil::collapse_short_edges( *facet_list_ptr,  CUBIT_TRUE );
          PRINT_WARNING("Couldn't improve facets.\n");
    // check for consistent orientations on the facets for each shell
      rv = ChollaEngine::check_all_facet_orientations(*facet_list_ptr,
                                                      CUBIT_TRUE);
        PRINT_WARNING("Couldn't set consistent orientation for facets.\n");
      // check to see that we have a positive enclosed volume (note this only works for
      // a single shell.  Will need to do something else for multiple shells
      if (shell_facet_list.size() == 1)
        double volume = FacetEvalTool::contained_volume(*facet_list_ptr);
        if (volume < 0.0)
          FacetEvalTool::reverse_facets(*facet_list_ptr);
    // create the surface geometry
    if (!use_feature_angle)
      feature_angle = -1.0;
    std::vector< std::vector<Surface*> > list_of_shells;
      DLIList <Surface *> shell_surfaces;
      DLIList <CubitPoint *> mypoint_list;
      if(facet_list_ptr == NULL)
        rv = CUBIT_FAILURE;
      else
        rv = FacetModifyEngine::instance()->build_facet_surface( NULL,
                               *facet_list_ptr, mypoint_list,
                               feature_angle, interp_order,
                               split_surfaces, shell_surfaces);
      if (rv != CUBIT_SUCCESS || shell_surfaces.size() == 0)
        PRINT_ERROR("Couldn't build facet based geometry from facets in %s\n", file_name);
        rv = CUBIT_FAILURE;
      list_of_shells.push_back( shell_surfaces.as_vector() );
    // make a shell out of these surfaces
    if( split_surfaces ) //make a shell for each and every surface
      for( size_t k=0; k<list_of_shells.size(); k++ )
        std::vector<Surface*> shell_surfaces = list_of_shells[k];
        for( size_t i=0; i<shell_surfaces.size(); i++ )
          DLIList<Surface*> sheet_body_surfaces;
          sheet_body_surfaces.append( shell_surfaces[i] );
          rv = FacetModifyEngine::instance()->make_facet_shell(sheet_body_surfaces, shell_ptr);
          if ( shell_ptr == NULL || rv != CUBIT_SUCCESS )
            PRINT_ERROR("Problems building facet based shell entity.\n");
            rv = CUBIT_FAILURE;
          //set the sense
          facet_shell = CAST_TO( shell_ptr, FacetShell );
          FacetSurface* facet_surf = CAST_TO( sheet_body_surfaces.get(), FacetSurface );
          facet_surf->set_shell_sense( facet_shell, CUBIT_FORWARD );
          surface_list.append( sheet_body_surfaces.get() );
          shell_list.append( shell_ptr );
          rv = FacetModifyEngine::instance()->make_facet_lump(shell_list,lump_ptr);
          if ( lump_ptr == NULL || rv != CUBIT_SUCCESS )
            PRINT_ERROR("Problems building facet based lump entity.\n");
            rv = CUBIT_FAILURE;
          lump_list.append(lump_ptr);
          rv = FacetModifyEngine::instance()->make_facet_body(lump_list,bodysm_ptr);
          body_ptr = GeometryQueryTool::instance()->make_Body(bodysm_ptr);
          if ( body_ptr == NULL || rv != CUBIT_SUCCESS )
            PRINT_ERROR("Problems building facet based body entity.\n");
            rv = CUBIT_FAILURE;
    else //make a shell out of all these surfaces
        DLIList<Surface*> shell_surfaces( list_of_shells[k] );
        rv = FacetModifyEngine::instance()->make_facet_shell(shell_surfaces, shell_ptr);
          rv = CUBIT_FAILURE;
        //Set the sense for the surfaces (will be cofaces) on this shell.
        //Assumption: The sense is always forward when creating geom from facets.
        // (This may not be correct -especially with multiple shells in a body)
        for( ii = shell_surfaces.size(); ii > 0; ii-- )
          Surface* surf = shell_surfaces.get_and_step();
          FacetSurface* facet_surf = CAST_TO( surf, FacetSurface );
        surface_list += shell_surfaces;
        shell_list.append(shell_ptr);
      // make a body out of it
        rv = CUBIT_FAILURE;
        rv = CUBIT_FAILURE;
    if(gti->num_bodies() - prev_bod > 1)
         PRINT_INFO("Bodies successfully created.\n");
    else
       PRINT_INFO("Body successfully created.\n");
    PRINT_INFO("  Number of new vertices = %d\n", gti->num_ref_vertices() - prev_vert);
    PRINT_INFO("  Number of new curves = %d\n", gti->num_ref_edges() - prev_edge);
    PRINT_INFO("  Number of new surfaces = %d\n", gti->num_ref_faces() - prev_face);
    PRINT_INFO("  Number of new shells = %d\n", shell_facet_list.size());
    PRINT_INFO("  Number of new volumes = %d\n", gti->num_ref_volumes() - prev_vol);
    PRINT_INFO("  Number of new bodies = %d\n", gti->num_bodies() - prev_bod);
    if (!is_water_tight)
      PRINT_WARNING("Volume generated does not completely close. 3D meshing (ie. hex/tet) will not be permitted.\n");
      PRINT_INFO("Hint: In some cases the \"stitch\" option on the import command may correct the problem.\n");
  }  // end while ( stl_multiple_parts == true )
end_import_facets:
  if (conn != NULL)
    delete [] conn;
  for (ii=0; ii<shell_list.size(); ii++)
    delete shell_facet_list.get_and_step();
  quad_facet_list = qfacet_list;
  tri_facet_list = tfacet_list;
  return rv;
CubitStatus FacetQueryEngine::import_solid_model ( const char *  file_name,
DLIList< TopologyBridge * > &  imported_entities,
ModelImportOptions &  import_options
) [virtual]
R CubitStatus R- CUBIT_SUCCESS/CUBIT_FAILURE I file_ptr I- A pointer to the file to read (can be NULL for IGES and STEP files). I file_type I- Type of file.
  • Reads in geometry and creates the necessary Reference entities
  • associated with the input geometry.
  • Valid file types are:
  • "STEP" -- STEP file I heal_step - auto-healing of step bodies on import. This is recommended because they always need it. I import_bodies (etc...) I- Should bodies be import.
  • Function can selectively import solid bodies, free surfaces, free
  • curves, or free vertices. For example, the user may not want
  • to import any free entities.
  • import - improper file type, inaccessible file, mismatch between
Definition at line 1895 of file FacetQueryEngine.cpp.
  errno = 0;
  FILE *file_ptr = fopen(file_name, "rb");
  if (!file_ptr)
    PRINT_ERROR("Cannot open file: %s (%s)\n", file_name, strerror(errno) );
  CubitStatus status = import_solid_model(file_ptr, imported_entities );
  fclose(file_ptr);
  return status;
virtual CubitStatus FacetQueryEngine::import_solid_model ( DLIList< TopologyBridge * > &  imported_entities,
const char *  pBuffer,
) [inline, virtual]
Definition at line 280 of file FacetQueryEngine.hpp.
CubitStatus FacetQueryEngine::import_solid_model ( FILE *  file_ptr,
) [private]
Definition at line 1914 of file FacetQueryEngine.cpp.
  CubitPoint **points_array = NULL;
  CurveFacetEvalTool **cfet_array = NULL;
  FacetEvalTool **fet_array = NULL;
  int num_points, num_edges, num_facets;
  int num_cfet, num_fet;
  // read in the file type "MESHED_BASED_GEOMETRY"
  char fileType[19] = {0};
  if( fread( fileType, 1, 19, file_ptr) != 19 )
    PRINT_ERROR("Trouble reading in file type for MBG\n");
  if( strncmp( fileType, "MESH_BASED_GEOMETRY", 19 ) )
    PRINT_ERROR("Not MESH_BASED_GEOMETRY file type\n");
  // read in the endian value
  NCubitFile::CIOWrapper file_reader(file_ptr, 19, 0);
  // read in version #
  UnsignedInt32 version;
  file_reader.Read( &version, 1 );
  //Read in points/edges/facets
  CubitStatus status;
  status = restore_facets( file_ptr, file_reader.get_endian(),
                           num_facets, points_array, num_cfet,
                           num_fet, cfet_array, fet_array );
  if( status == CUBIT_FAILURE)
    PRINT_ERROR("Problems restore facets\n");
  //Restore Topology
  status = restore_topology( file_ptr, file_reader.get_endian(),
                             num_points, points_array,
                             num_cfet, cfet_array, num_fet,
                             fet_array, imported_entities);
    PRINT_ERROR("Problems restore MDB topology\n");
  if(cfet_array != NULL)
    delete [] cfet_array;
  if(fet_array != NULL)
    delete [] fet_array;
  if(points_array != NULL)
    delete [] points_array;
CubitStatus FacetQueryEngine::init_hash_points ( int  num_points) [static, private]
Definition at line 4357 of file FacetQueryEngine.cpp.
  /* === find the next highest prime number */
  hashPointSize = num_points / 10;
  int i;
  if (hashPointSize < 13) hashPointSize = 13;
  else
    i=2;
    while (i<hashPointSize*0.5 + 1) {
      if (hashPointSize % i == 0) {
        i=2;
        hashPointSize++;
      else {
        i++;
  hashPointArray = new DLIList<CubitPoint*>[hashPointSize];
Definition at line 102 of file FacetQueryEngine.cpp.
  if (instance_ == NULL ) {
      instance_ = new FacetQueryEngine;
  return instance_;
CubitBoolean FacetQueryEngine::is_close ( CubitVector this_point,
CubitFacet *&  lastFacet,
double  tol
Definition at line 4149 of file FacetQueryEngine.cpp.
  CubitBoolean isclose = CUBIT_FALSE;
  CubitBox bbox;
  CubitVector close_point;
  CubitFacet *facet;
  int ii;
  // set the first facet to be checked as the last one located
  if (lastFacet) {
    if (!facet_list.move_to(lastFacet)) {
      facet_list.reset();
  else {
    facet_list.reset();
  CubitBoolean done = CUBIT_FALSE;
  // define a bounding box around the point
  CubitVector ptmin( this_point.x() - tol,
                         this_point.y() - tol,
                               this_point.z() - tol );
    CubitVector ptmax( this_point.x() + tol,
                         this_point.y() + tol,
                               this_point.z() + tol );
  for ( ii = facet_list.size(); ii > 0 && !done; ii-- ) {
    // Try to trivially reject this facet with a bounding box test
      bbox = facet->bounding_box();
      if (ptmax.x() < bbox.minimum().x() ||
            ptmin.x() > bbox.maximum().x()) {
      continue;
    if (ptmax.y() < bbox.minimum().y() ||
            ptmin.y() > bbox.maximum().y()) {
      continue;
    if (ptmax.z() < bbox.minimum().z() ||
            ptmin.z() > bbox.maximum().z()) {
      continue;
    // Only facets that pass the bounding box test will get past here!
    // Project point to plane of the facet and determine its area coordinates
    CubitVector pt_on_plane;
    double dist_to_plane;
    FacetEvalTool::project_to_facet_plane( facet, this_point, pt_on_plane, dist_to_plane );
    CubitVector areacoord;
    FacetEvalTool::facet_area_coordinate( facet, pt_on_plane, areacoord );
    // If sign of areacoords are all positive then its inside the triangle
    // and we are done - go interpolate the point. (use an absolute
    // tolerance since the coordinates arenormalized)
    if (areacoord.x() > -GEOMETRY_RESABS &&
        areacoord.y() > -GEOMETRY_RESABS &&
        areacoord.z() > -GEOMETRY_RESABS) {
      FacetEvalTool::eval_facet( facet, areacoord, &close_point, NULL );
    // otherwise find the closest vertex or edge to the projected point
    else if (areacoord.x() < GEOMETRY_RESABS) {
      if (areacoord.y() < GEOMETRY_RESABS) {
        FacetEvalTool::eval_point( facet, 2, close_point );
      else if(areacoord.z() < GEOMETRY_RESABS) {
        FacetEvalTool::eval_point( facet, 1, close_point );
      else {
        FacetEvalTool::eval_edge( facet, 1, 2, pt_on_plane, close_point );
    else if (areacoord.y() < GEOMETRY_RESABS) {
      if (areacoord.z() < GEOMETRY_RESABS) {
        FacetEvalTool::eval_point( facet, 0, close_point );
      else {
        FacetEvalTool::eval_edge( facet, 2, 0, pt_on_plane, close_point);
    else {
      FacetEvalTool::eval_edge( facet, 0, 1, pt_on_plane, close_point );
    // keep track of the minimum distance
    double dist = sqrt(FacetEvalToolUtils::sqr(close_point.x() - this_point.x()) +
                       FacetEvalToolUtils::sqr(close_point.y() - this_point.y()) +
                       FacetEvalToolUtils::sqr(close_point.z() - this_point.z()));
    if (dist <= tol) {
      done = CUBIT_TRUE;
      isclose = CUBIT_TRUE;
      lastFacet = facet;
  return isclose;
virtual CubitBoolean FacetQueryEngine::is_solid_modeler_type ( ) const [inline, virtual]
Definition at line 127 of file FacetQueryEngine.hpp.
    {return CUBIT_FALSE;}
BodySM * FacetQueryEngine::make_BodySM ( Surface ) const [virtual]
Definition at line 311 of file FacetQueryEngine.cpp.
  return (BodySM*) NULL;
BodySM * FacetQueryEngine::make_BodySM ( DLIList< Lump * > &  ) const [virtual]
Definition at line 322 of file FacetQueryEngine.cpp.
Curve * FacetQueryEngine::make_Curve ( Curve ) const [virtual]
Definition at line 217 of file FacetQueryEngine.cpp.
  return (Curve*) NULL;
Curve * FacetQueryEngine::make_Curve ( TBPoint const *  ,
TBPoint const *  ,
RefFace ,
CubitVector
) const [virtual]
Definition at line 228 of file FacetQueryEngine.cpp.
Curve * FacetQueryEngine::make_Curve ( GeometryType  ,
TBPoint const *  ,
TBPoint const *  ,
DLIList< CubitVector * > &  ,
RefFace
) const [virtual]
Definition at line 242 of file FacetQueryEngine.cpp.
TBPoint const *  ,
TBPoint const *  ,
CubitVector const *  ,
CubitSense
) const [virtual]
Definition at line 257 of file FacetQueryEngine.cpp.
CubitStatus FacetQueryEngine::make_facets ( int *  conn,
int  nfacets,
DLIList< CubitQuadFacet * > &  facet_list
) [static]
Definition at line 2642 of file FacetQueryEngine.cpp.
  CubitQuadFacet *facet_ptr = NULL;
  CubitPoint *point0, *point1, *point2, *point3;
  // create the facet array
  for(int ii=0; ii<nfacets; ii++)
    if (conn[ii*4+2] != conn[ii*4+3])
      point0 = get_hash_point(conn[ii*4]);
      point1 = get_hash_point(conn[ii*4+1]);
      point2 = get_hash_point(conn[ii*4+2]);
      point3 = get_hash_point(conn[ii*4+3]);
      facet_ptr = new CubitQuadFacetData( point0, point1, point2, point3 );
      if (!facet_ptr)
        rv = CUBIT_FAILURE;
        return rv;
  return rv;
int  nfacets,
) [static]
Definition at line 2681 of file FacetQueryEngine.cpp.
  CubitFacet *facet_ptr = NULL;
  CubitPoint *point0, *point1, *point2;
    if (conn[ii*4+2] == conn[ii*4+3])
      if( (point0 == point1) || (point0 == point2) || (point1 == point2) ){
          PRINT_ERROR("Point used more than once in a single facet.  This is not allowed.\n");
      if( !point0 || !point1 || !point2 ){
          PRINT_ERROR("Point in facet is undefined.  This is not allowed.\n");
      facet_ptr = new CubitFacetData( point0, point1, point2 );
      if (!facet_ptr)
        rv = CUBIT_FAILURE;
        return rv;
 return rv;
Lump * FacetQueryEngine::make_Lump ( GeometryType  ,
) const [virtual]
Definition at line 299 of file FacetQueryEngine.cpp.
  return (Lump*) NULL;
TBPoint * FacetQueryEngine::make_Point ( GeometryType  point_type,
CubitVector const &  point
) const [virtual]
Definition at line 205 of file FacetQueryEngine.cpp.
  return (TBPoint*) NULL;
Surface * FacetQueryEngine::make_Surface ( Surface ,
DLIList< Loop * > &  ,
CubitBoolean
) const [virtual]
Definition at line 272 of file FacetQueryEngine.cpp.
  return (Surface*) NULL;
Surface * FacetQueryEngine::make_Surface ( GeometryType  ,
DLIList< Curve * > &  ,
Surface
) const [virtual]
Definition at line 285 of file FacetQueryEngine.cpp.
const char* FacetQueryEngine::modeler_type ( ) [inline, virtual]
Definition at line 110 of file FacetQueryEngine.hpp.
     { return "facet"; }
CubitStatus FacetQueryEngine::read_cholla_file ( const char *  file_name,
double &  feature_angle,
DLIList< CubitPoint * > &  point_list,
) [static]
Definition at line 4032 of file FacetQueryEngine.cpp.
  double angle = 135.0;
  int num_tri = 0;
  int num_quad = 0;
  int num_edge = 0;
  int num_vert = 0;
  int* tri_edge = NULL;
  int* quad_edge = NULL;
  int* edge_vert = NULL;
  double* vert = NULL;
  double* edge_ctrl_pts = NULL;
  double* tri_ctrl_pts = NULL;
  double* quad_ctrl_pts = NULL;
  int results_included = 0;
  // importMesh and resolveFaceVectors are in Cholla.h
  importMesh(file_name, &results_included, &angle, &num_tri, &num_quad, &num_edge,
             &num_vert, &tri_edge, &quad_edge, &edge_vert, &vert,
             &edge_ctrl_pts, &tri_ctrl_pts, &quad_ctrl_pts);
  feature_angle = angle;
  // create the points
  CubitPoint **point_array = new CubitPoint * [num_vert];
  double x, y, z;
  int ii;
  for (ii=0; ii<num_vert; ii++)
    x = vert[ii*3];
    y = vert[ii*3 + 1];
    z = vert[ii*3 + 2];
    point_array[ii] = (CubitPoint *) new CubitPointData( x, y, z );
    point_list.append( point_array[ii] );
  // create the edges
  CubitFacetEdge **edge_array = new CubitFacetEdge * [num_edge];
  int ip, jp;
  for (ii=0; ii<num_edge; ii++)
    ip = edge_vert[ii*2];
    jp = edge_vert[ii*2 + 1];
    assert(ip < num_vert && jp < num_vert && ip >= 0 && jp >= 0);
    edge_array[ii] = (CubitFacetEdge *) new CubitFacetEdgeData( point_array[ip],
        point_array[jp] );
  // create the tri facets
  int begin_face;
  int jj, iedge;
  CubitFacetEdge *edges[4];
  CubitQuadFacet *qfacet_ptr = NULL;
  for (ii=0; ii<num_tri; ii++)
    begin_face = 3 * ii;
      iedge = tri_edge[begin_face+jj];
      edges[jj] = edge_array[iedge];
    facet_ptr = (CubitFacet *)
      new CubitFacetData(edges[0], edges[1], edges[2]);
    facet_list.append(facet_ptr);
  // create the quad facets
  for (ii=0; ii<num_quad; ii++)
    begin_face = 4 * ii;
    for(jj=0; jj<4; jj++)
      iedge = quad_edge[begin_face+jj];
    qfacet_ptr = (CubitQuadFacet *)
      new CubitQuadFacetData(edges[0], edges[1], edges[2], edges[3]);
    facet_list.append(qfacet_ptr->get_tri_facet(0));
    facet_list.append(qfacet_ptr->get_tri_facet(1));
  // delete the temp arrays
  delete [] point_array;
  delete [] edge_array;
  delete [] tri_edge;
  delete [] quad_edge;
  delete [] edge_vert;
  delete [] vert;
  delete [] edge_ctrl_pts;
  delete [] tri_ctrl_pts;
  delete [] quad_ctrl_pts;
  return CUBIT_SUCCESS;
CubitStatus FacetQueryEngine::read_facets ( const char *  file_name,
int *&  conn,
int &  npoints,
int &  nquad,
int &  ntri,
) [static]
Definition at line 3770 of file FacetQueryEngine.cpp.
  // open the file
  FILE *fp = fopen(file_name, "r");
  if (fp == NULL)
    PRINT_ERROR("Could not open file %s for reading\n", file_name);
  PRINT_INFO("Reading facets...\n");
  // read the number of nodes
  int id;
  int nfacets = 0;
  int iline = 1;
  char line[128];
  if (fgets(line, 128, fp) == NULL)
    PRINT_ERROR("Format error in facet file %s on line %d\n", file_name, iline);
    fclose( fp );
  int n;
  char type_header[8];
  CubitBoolean is_off_file = CUBIT_FALSE;
  n = sscanf( line, "%s", type_header );
  if( !strcmp( type_header, "OFF" ) ||
      !strcmp( type_header, "off" ) )
    PRINT_INFO( "Reading OFF file...\n" );
    iline++;
    if (fgets(line, 128, fp) == NULL) {
      fclose( fp );
    is_off_file = CUBIT_TRUE;
  n = sscanf(line, "%d %d", &npoints, &nfacets);
  if( !is_off_file )
    if (n < 1 || ( n > 2 && file_format == CUBIT_FACET_FILE ) )
      fclose( fp );
  if (npoints <= 0)
    PRINT_ERROR("Expecting number of nodes in facet file %s on line %d\n", file_name, iline);
    fclose( fp );
  if (n==1)
    nfacets = 0;
  else if (nfacets <= 0)
    PRINT_ERROR("Format error in facet file %s on line %d reading number of facets\n", file_name, iline);
    fclose( fp );
  if (init_hash_points( npoints ) == CUBIT_FAILURE)
    PRINT_ERROR("Can't allocate memory for points in facet file %s on line %d\n", file_name, iline);
    fclose( fp );
  // read the nodes
  int ii;
  double xx, yy, zz;
  CubitPoint *new_point;
  for (ii=0; ii<npoints; ii++)
    iline++;
    if (fgets(line, 128, fp)== NULL)
      fclose( fp );
    if( is_off_file )
      n = sscanf( line, "%lf %lf %lf", &xx, &yy, &zz );
      id = ii;
      if (n != 3)
        PRINT_ERROR("Format error in OFF file %s on line %d\n", file_name, iline);
        PRINT_INFO("  Expecting 3 doubles, but instead read %d values\n", n);
        fclose( fp );
    else
      n = sscanf(line, "%d %lf %lf %lf", &id, &xx, &yy, &zz );
      if (n != 4)
        PRINT_INFO("  Expecting 1 integer and 3 doubles, but instead read %d values\n", n);
        fclose( fp );
    new_point = (CubitPoint *) new CubitPointData( xx, yy, zz );
    new_point->set_id( id );
    add_hash_point( new_point );
    // read the number of facets
  if (nfacets == 0)
    iline++;
      fclose( fp );
    n = sscanf(line, "%d", &nfacets);
    if (n != 1)
      PRINT_INFO("  Expecting <num facets>\n");
      fclose( fp );
    if (nfacets <= 0)
      fclose( fp );
  conn = new int [4*nfacets];
  if (!conn)
    PRINT_ERROR("Can't allocate memory for facets in facet file %s on line %d\n", file_name, iline);
    fclose( fp );
  ntri = nquad = 0;
  // read the facets
    iline++;
      fclose( fp );
    if( AVS_FILE == file_format )
      n = sscanf( line, "%d %*d %*s %d %d %d %d", &id, &conn[4*ii],
                  &conn[4*ii+1], &conn[4*ii+2], &conn[4*ii+3] );
      if( n < 4 || n > 5 )
        PRINT_ERROR("Format error in avs file %s on line %d reading facets\n", file_name, iline);
        PRINT_INFO("Expecting 6 or 7 values, but instead read %d values\n", n);
        fclose( fp );
        //duplicate the point
      if( n == 4 )
        conn[4*ii+3] = conn[4*ii+2];
        ntri++;
      else
        nquad++;
    else
//       if( is_off_file )
//         n = sscanf( line, "%d %d %d %d", &id, &conn[4*ii], &conn[4*ii+1],
//                     &conn[4*ii+2], &conn[4*ii+3] );
//         if (n < 4 || n > 5)
//           PRINT_ERROR("Format error in OFF file %s on line %d reading facets\n", file_name, iline);
//           PRINT_INFO("  Expecting 4 or 5 integers, but instead read %d values\n", n);
//           PRINT_INFO("  For example:  <facet_size> <i0> <i1> <i2> [<i3>]\n");
//           fclose( fp );
//           return CUBIT_FAILURE;
//           // for triangles -- duplicate the point
// //        if( n==3 )
//         if( id==3 )
//           conn[4*ii+3] = conn[4*ii+2];
//           ntri++;
//         else
//           nquad++;
//       else
        n = sscanf(line, "%d %d %d %d %d", &id, &conn[4*ii], &conn[4*ii+1],
        if (n < 4 || n > 5)
          PRINT_ERROR("Format error in facet file %s on line %d reading facets\n", file_name, iline);
          PRINT_INFO("  For example:  <id> <i0> <i1> <i2> [<i3>]\n");
          fclose( fp );
        if (n==4)
          ntri++;
        else
          nquad++;
  fclose( fp );
CubitStatus FacetQueryEngine::read_facets ( FILE *  fp,
unsigned int  endian,
int &  num_facets,
int &  num_edges,
int &  num_points,
CubitFacet **&  facets,
CubitFacetEdge **&  edges,
CubitPoint **&  points
) [private]
Definition at line 2039 of file FacetQueryEngine.cpp.
  NCubitFile::CIOWrapper cio(endian, fp );
  int ii;
  // read points
  UnsignedInt32 npoints;
  double uu,vv,ss;
  cio.Read(&npoints, 1);
  num_points = (int)npoints;
  if (num_points > 0)
    double* coord_array  = new double [num_points * 3];
    double* uvs_array = new double [num_points * 3];
    cio.Read(coord_array, npoints*3);
    cio.Read(uvs_array, npoints*3);
    // create CubitPoints
    //CubitVector normal;
    points = new CubitPoint * [num_points];
    for(ii=0; ii<num_points; ii++)
      point_ptr = (CubitPoint *) new CubitPointData( coord_array[ii*3],
                                                     coord_array[ii*3+1],
                                                     coord_array[ii*3+2] );
      points[ii] = point_ptr;
      uu = uvs_array[ii*3];
      vv = uvs_array[ii*3+1];
      ss = uvs_array[ii*3+2];
      point_ptr->set_uvs(uu, vv, ss);
    //Clean up
  //Read in Normals
  int nnormals;
  cio.Read(reinterpret_cast<UnsignedInt32*>(&nnormals), 1);
  if( nnormals > 0 )
    double* normal_array = new double [nnormals * 3];
    int* normal_ids = new int[nnormals * 3];
    cio.Read(normal_array, nnormals * 3);
    cio.Read(reinterpret_cast<UnsignedInt32*>(normal_ids), nnormals);
    CubitVector normal;
    for(ii=0; ii<nnormals; ii++)
      normal.x( normal_array[ii*3] );
      normal.y( normal_array[ii*3+1] );
      normal.z( normal_array[ii*3+2] );
      points[ normal_ids[ii] ]->normal( normal );
    //Clean up
  // read edges and edge control points
  UnsignedInt32 nedges;
  cio.Read(&nedges, 1);
  num_edges = (int)nedges;
  if (num_edges > 0)
    UnsignedInt32 *edge_vert_array = new UnsignedInt32 [nedges*2];
    cio.Read(edge_vert_array, nedges*2);
    UnsignedInt32 nctrl_pts;
    cio.Read(&nctrl_pts, 1);
    double *control_points = NULL;
    if (nctrl_pts > 0)
      control_points = new double [nctrl_pts*3];
      cio.Read(control_points, nctrl_pts*3);
    unsigned id0, id1, ii;
    edges = new CubitFacetEdge * [num_edges];
      id0 = edge_vert_array[ii*2];
      id1 = edge_vert_array[ii*2+1];
      edge_ptr = (CubitFacetEdge *) new CubitFacetEdgeData( points[id0], points[id1] );
      edges[ii] = edge_ptr;
      if (nctrl_pts > 0)
        edge_ptr->set_control_points(&control_points[ii*NUM_EDGE_CPTS*3]);
    //Clean up
  // read the facets and the facet control points
  UnsignedInt32 nfacets;
  cio.Read(&nfacets, 1);
  num_facets = (int)nfacets;
  if(num_facets > 0)
    UnsignedInt32 *facet_edge_array = new UnsignedInt32 [nfacets*3];
    cio.Read(facet_edge_array, nfacets*3);
    int *int_data = new int [nfacets*2];
    cio.Read(reinterpret_cast<UnsignedInt32*>(int_data), nfacets*2);
    if (nctrl_pts > 0)
    unsigned id0, id1, id2, ii;
    facets = new CubitFacet * [num_facets];
      id0 = facet_edge_array[ii*3];
      id1 = facet_edge_array[ii*3+1];
      id2 = facet_edge_array[ii*3+2];
      facet_ptr = (CubitFacet *) new CubitFacetData(edges[id0], edges[id1], edges[id2]);
      facets[ii] = facet_ptr;
      facet_ptr->is_flat( int_data[ii*2] );
      facet_ptr->is_backwards( int_data[ii*2+1] );
      if(nctrl_pts > 0)
        facet_ptr->set_control_points(&control_points[ii*NUM_TRI_CPTS*3]);
    //Clean up
    delete [] int_data;
    int_data = NULL;
  // read the extra info at the surface boundaries
  UnsignedInt32 num_c_zero_points = 0;
  cio.Read(&num_c_zero_points, 1);
  if (num_c_zero_points > 0)
    UnsignedInt32 c_zero_int_data_size;
    cio.Read(&c_zero_int_data_size, 1);
    if (c_zero_int_data_size <= 0)
    cio.Read(c_zero_int32_data, c_zero_int_data_size);
    unsigned int jj;
    for (jj=0; jj<c_zero_int_data_size; jj++)
      c_zero_int_data[jj] = (int) c_zero_int32_data[jj];
    UnsignedInt32 c_zero_double_data_size;
    cio.Read(&c_zero_double_data_size, 1);
    if (c_zero_double_data_size <= 0) {
    cio.Read(c_zero_double_data, c_zero_double_data_size);
    // create the facet boundary tool datas and assign to points
    int didx = 0;
    int iidx = 0;
    UnsignedInt32 zz;
    for (zz=0; zz<num_c_zero_points; zz++)
      if (didx >= (int)c_zero_double_data_size ||
          iidx >= (int)c_zero_int_data_size)
      TDFacetBoundaryPoint::new_facet_boundary_point( points, facets,
        iidx, didx, c_zero_int_data, c_zero_double_data );
    //Clean up
CubitStatus FacetQueryEngine::read_facets_stl ( DLIList< CubitFacet * > &  tfacet_list,
int &  npoints,
int &  ntri,
long &  seek_address
APPEND facet to output facet_ptr list
Definition at line 3047 of file FacetQueryEngine.cpp.
  ntri = 0;
  npoints = 0;
  if (fp == NULL)
    seek_address = 0;
  typedef std::map< CubitPoint * , int, CubitPointComparator > vMap;
  vMap mm;          // binary search tree to hold the vertices for efficiency
  vMap::iterator pos;
  bool append_to_facet_list=CUBIT_TRUE;
  CubitBoolean is_ascii=CUBIT_FALSE;
  if (!ensure_is_ascii_stl_file(fp, is_ascii))
    seek_address = 0;
    fclose(fp);
  if (is_ascii==CUBIT_TRUE)
    CubitPoint *point0,*point1,*point2;
    fclose(fp);
    fseek(fp,seek_address,SEEK_SET);
    char line[128], junk[30];
    int numverts;
    double xx[3], yy[3], zz[3];
    int linenumber, num;
    bool done, error_found, eof_found;
    linenumber = 0;
    strcpy(line,"");
    done = false;
    error_found = false;
    eof_found = false;
    while ( (strstr(line,"endsolid") == 0) && (error_found == false) ) {
      numverts = 0;
      while ( numverts < 3 ) {
        if ( fgets(line,127,fp) == 0 ) {
          linenumber++;
          eof_found = true;
          break; // EOF
        linenumber++;
//      makelowercase(line);
        int len, ij;
        len = strlen(line);
        for ( ij = 0; ij < len; ij++ )
          line[ij] = tolower(line[ij]);
        if ( strstr(line,"endsolid") != 0 ) {
          done = true;
          break; // End of part definition
        if ( strstr(line,"vertex") != 0 ) {
          num = sscanf(line,"%s %le %le %le",junk,&xx[numverts],&yy[numverts],&zz[numverts]);
          if ( num != 4 ) {
            error_found = true;
            break; // error in reading vertices
          numverts += 1;
      } // end of while ( numverts < 3 )
      if ( (eof_found == true) || (done == true)  ||
           (error_found == true) || (numverts != 3) ) break;
      point0 = (CubitPoint *) new CubitPointData(xx[0],yy[0],zz[0]);
      pos=mm.find(point0);
      if (pos==mm.end())
        mm.insert ( vMap::value_type(point0, npoints));
        point0->set_id( npoints ++ );
        //point_list is output of functionAVS
        point_list.append(point0);
      else
        delete point0;
        point0=((*pos).first);
      point1 = (CubitPoint *) new CubitPointData(xx[1],yy[1],zz[1]);
      pos=mm.find(point1);
      if (pos==mm.end())
        mm.insert ( vMap::value_type(point1, npoints));
        point1->set_id( npoints ++ );
        point_list.append(point1);
      else
        delete point1;
        point1=((*pos).first);
      point2 = (CubitPoint *) new CubitPointData(xx[2],yy[2],zz[2]);
      pos=mm.find(point2);
      if (pos==mm.end())
        mm.insert ( vMap::value_type(point2, npoints));
        point2->set_id( npoints ++ );
        point_list.append(point2);
      else
        delete point2;
        point2=((*pos).first);
      if (point0 && point1 && point2 && point0!=point1 && point1!=point2 && point2 !=point0)
      else
        append_to_facet_list=CUBIT_FALSE;
      if (!facet_ptr)
        seek_address = 0;
        fclose(fp);
      if (append_to_facet_list)
        tfacet_list.append( facet_ptr );
        ntri++;
    seek_address = 0;
    if ( eof_found == true ) {
      PRINT_WARNING("Premature end-of-file on STL file. Body may be incomplete.\n");
      fclose(fp);
    if ( error_found == true ) {
      PRINT_WARNING("Error found while reading line number %d of file %s. Body may be incomplete.\n",
              linenumber,file_name);
      fclose(fp);
    if ( done == false ) {
      fclose(fp);
    if ( (eof_found == false) && (error_found == false) && (done == true) ) {
      while ( fgets(line,127,fp) != 0 ) {
        if ( (strstr(line,"solid") != 0) && (strstr(line,"endsolid") == 0) ) {
          seek_address = ftell(fp);
//          PRINT_INFO("This STL file is a multipart file.  Only the first part was read.\n");
          break;
    fclose(fp);
  else
    fclose(fp);
    // file is closed so that it can be opened as binary
    fp = fopen(file_name, "rb");
    if (fp == NULL)
    CubitPoint *point0,
              *point1,
                *point2;
    char dummy;
    int        ii=0;    // iterates through the facets of the file
    float cur[12];      // an array to hold 48 bytes representing 1 facet
    npoints=0;          // only tri facets in stl files
    //put file pointer back where you found it
    fseek(fp, seek_address+80, SEEK_SET);
    size_t count = fread(&ntri, 4, 1, fp);
    if (count != 1) {
      PRINT_ERROR("Trouble reading in number of triangles\n");
    int distinct_ntri=ntri;
    PRINT_INFO ("Reading facets...\n");
    for (ii=0; ii<ntri; ii++) {
      // read in 1 facet
      if (fread(cur, 4, 12, fp) != 12)
        PRINT_INFO ("Abnormal file termination %s \n", file_name); break;
      count = fread(&dummy, 1, 1, fp);
        //make point
        point0 = (CubitPoint *) new CubitPointData( cur[3], cur[4], cur[5] );
        if (pos==mm.end())
        else
          delete point0;
        //make point
        point1 = (CubitPoint *) new CubitPointData( cur[6], cur[7], cur[8] );
        if (pos==mm.end())
        else
          delete point1;
        //make point
        point2 = (CubitPoint *) new CubitPointData( cur[9], cur[10], cur[11] );
        if (pos==mm.end())
        else
          delete point2;
        // this is to avoid a facet with all points on same line, which crashes CUBIT
        // because of assertion
        else
        if (!facet_ptr)
          fclose(fp);
        else
          distinct_ntri--;
    ntri=distinct_ntri;
    //reading at or past EOF
    long previous_pos = ftell(fp);
    if( feof(fp) )
      seek_address = 0;
    else
      fseek(fp, previous_pos, SEEK_SET);
    fclose(fp);
CubitStatus FacetQueryEngine::read_facets_stl_tolerance ( DLIList< CubitFacet * > &  tfacet_list,
int &  npoints,
int &  ntri,
long &  seek_address,
double  tolerance
Definition at line 2816 of file FacetQueryEngine.cpp.
  if (fp == NULL)
    seek_address = 0;
  DLIList <CubitPoint *> file_points;
  CubitPoint *current_point;
  int points_in_file=0;
  int ii;
    seek_address = 0;
    fclose(fp);
    fclose(fp);
    int numverts;
    linenumber = 0;
    strcpy(line,"");
    done = false;
    eof_found = false;
      numverts = 0;
          linenumber++;
          eof_found = true;
          break; // EOF
        linenumber++;
        int len, ij;
        len = strlen(line);
          done = true;
          if ( num != 4 ) {
            error_found = true;
          numverts += 1;
      current_point = (CubitPoint *) new CubitPointData(xx[0],yy[0],zz[0]);
      current_point->set_id(points_in_file++);
      file_points.append(current_point);
      current_point = (CubitPoint *) new CubitPointData(xx[1],yy[1],zz[1]);
      current_point = (CubitPoint *) new CubitPointData(xx[2],yy[2],zz[2]);
    seek_address = 0;
      fclose(fp);
      goto end_read_file_points;
      fclose(fp);
      fclose(fp);
          break;
    fclose(fp);
  else
    fclose(fp);
    if (fp == NULL)
    char dummy;
    float cur[12];      // an array to hold 48 bytes representing 1AVS facet
    fseek(fp, 80, SEEK_SET);
    if (count != 1) {
      // read in 1 facet
        //make point
      current_point = (CubitPoint *) new CubitPointData(cur[3],cur[4],cur[5]);
      current_point = (CubitPoint *) new CubitPointData(cur[6],cur[7],cur[8]);
      current_point = (CubitPoint *) new CubitPointData(cur[9],cur[10],cur[11]);
  fclose(fp);
// at this point all points from the file are in file_points
end_read_file_points:
  // grid search tree to hold points
  GridSearchTree * node_grid = new GridSearchTree (tolerance);
  CubitPoint
             *point0,
             *point1,
             *point2;
  CubitFacet
             *facet_ptr;
  ntri=0;
  npoints=0;
  if (file_points.size() % 3 != 0)
    PRINT_INFO("File Error.");
  for (ii = file_points.size(); ii>0; ii-=3)
    // get three points from the file_points list
    // and compare them against the data already in the
    // grid search tree; if it contains a point within
    // epsilon tolerance this point would replace the
    // current point
    point0 = node_grid->fix(file_points.get_and_step());
    point1 = node_grid->fix(file_points.get_and_step());
    point2 = node_grid->fix(file_points.get_and_step());
    if (point0 && point1 && point2 && point0 != point1 && point1!=point2 && point2!=point0 )
      facet_ptr = new CubitFacetData(point0, point1, point2);
      if (facet_ptr)
        tfacet_list.append(facet_ptr);
        ntri++;
  //delete node_grid;
CubitStatus FacetQueryEngine::reflect ( BodySM body,
const CubitVector axis
) [virtual]
Implements GeometryQueryEngine.
Definition at line 366 of file FacetQueryEngine.cpp.
  FacetBody *fbody = CAST_TO(bodysm, FacetBody);
  if (!fbody)
    PRINT_ERROR("Attempt to reflect mesh-based geometry Body.  This body is not MBG.");
  fbody->reflect( axis.x(), axis.y(), axis.z() );
CubitStatus FacetQueryEngine::reflect ( GeometryEntity ent,
) [virtual]
Definition at line 5227 of file FacetQueryEngine.cpp.
CubitStatus FacetQueryEngine::restore_eval_tools ( FILE *  fp,
int  num_facets,
int  num_edges,
int  num_points,
CubitFacet **  facets,
CubitFacetEdge **  edges,
CubitPoint **  points,
int &  num_cfet,
int &  num_fet,
CurveFacetEvalTool **&  cfeval_tools,
FacetEvalTool **&  feval_tools
Definition at line 4591 of file FacetQueryEngine.cpp.
  NCubitFile::CIOWrapper cio(endian, fp);
  int ii;
  FacetEvalTool *fsurf_ptr;
  CurveFacetEvalTool *fcurv_ptr;
  // read the number of facet eval tools
  // we are about to read from the CUB file
  cio.Read(reinterpret_cast<UnsignedInt32*>(&num_fet), 1);
  feval_tools = new FacetEvalTool *[num_fet];
  // read all the facet surface eval tools
  for (ii=0; ii<num_fet; ii++)
    // read the topo ID from the CUB file.  This will be stored as the
    // FacetEvalTool toolID and serve as the means to associate this
    // eval tool with it's topology entity
    UnsignedInt32 surf_id = 0;
    cio.Read(&surf_id, 1);
    int topo_id = (int)surf_id; */
    // read the facet eval tool data and create the tool
    fsurf_ptr  = new FacetEvalTool();
    fsurf_ptr->restore(fp, endian, num_facets,
                       num_edges, num_points,
                       facets, edges, points);
    if (fsurf_ptr == NULL)
      PRINT_ERROR("Error restoring mesh-based geometry\n");
    feval_tools[ii] = fsurf_ptr;
  // read the number of curves
  cio.Read(reinterpret_cast<UnsignedInt32*>(&num_cfet), 1);
  cfeval_tools = new CurveFacetEvalTool *[num_cfet];
  // read all the curve facet eval tools.  Same thing as surfaces
  for (ii=0; ii<num_cfet; ii++)
    fcurv_ptr = new CurveFacetEvalTool();
    fcurv_ptr->restore(fp, endian, num_edges, num_points,
                       edges, points, num_fet, feval_tools );
    if (fcurv_ptr == NULL)
    cfeval_tools[ii] = fcurv_ptr;
CubitStatus FacetQueryEngine::restore_facets ( FILE *  file_ptr,
int &  num_facets,
int &  num_edges,
int &  num_points,
CubitPoint **&  points_array,
int &  num_cfet,
int &  num_fet,
CurveFacetEvalTool **&  cfet_array,
FacetEvalTool **&  fet_array
) [private]
Definition at line 1989 of file FacetQueryEngine.cpp.
  CubitFacet **facets = NULL;
  CubitFacetEdge **edges = NULL;
  // read facets from the file and build arrays of facet entities
  rv = read_facets( fp, endian,
                    num_facets, num_edges, num_points,
                    facets,     edges,   points );
  // create the CurveFacetEvalTools and FacetEval Tools
  if (rv != CUBIT_FAILURE )
    rv = restore_eval_tools( fp, endian,
                             facets,     edges,  points,
                             num_cfet, num_fet,
  if (facets != NULL)
    delete [] facets;
  if(edges != NULL)
    delete [] edges;
  return rv;
CubitStatus FacetQueryEngine::restore_topology ( FILE *  file_ptr,
int  num_points,
CubitPoint **  points_array,
int  num_cfet,
CurveFacetEvalTool **  cfev_array,
int  num_fet,
FacetEvalTool **  fev_array,
) [private]
Definition at line 1467 of file FacetQueryEngine.cpp.
  //get file pointer
  unsigned int size;
  unsigned int i, j;
  int id, k;
  FacetPoint **facet_points;
  FacetCurve **facet_curves;
  FacetCoEdge **facet_coedges;
  FacetLoop **facet_loops;
  FacetSurface **facet_surfaces;
  FacetShell **facet_shells;
  FacetLump **facet_lumps;
  FacetBody **facet_bodies;
  FacetPoint *tmp_point;
  FacetCurve *tmp_curve;
  FacetCoEdge *tmp_coedge;
  FacetLoop *tmp_loop;
  FacetSurface *tmp_surf;
  FacetShell *tmp_shell;
  FacetLump *tmp_lump;
  FacetBody*tmp_body;
  int num_facet_points = 0;
  int num_facet_curves = 0;
  int num_facet_coedges = 0;
  int num_facet_loops = 0;
  int num_facet_surfaces = 0;
  int num_facet_shells = 0;
  int num_facet_lumps = 0;
  int num_facet_bodies = 0;
  //create a wrapper object for writing
  CIOWrapper file_reader( endian, file_ptr );
  //-----------------Read FacetPoints------------------
  // Read number of FacetPoints
  file_reader.Read( &size, 1 );
  // Allocate memory for FacetPoints
  facet_points = new FacetPoint*[size];
  for(i=0; i<size; i++)
    file_reader.Read( reinterpret_cast<UnsignedInt32*>(&id), 1 );
    if( id >= num_points || id < 0 )
      delete [] facet_points;
    tmp_point = new FacetPoint( points_array[ id ] );
    if( tmp_point == NULL )
    num_facet_points++;
    facet_points[i] = tmp_point;
    tmp_point->restore_attribs( file_ptr, endian );
  //-----------------Read FacetCurves------------------
  //Read number of FacetCurves
  // Allocate memory for FacetCurves
  facet_curves = new FacetCurve*[size];
    int data[4];
    file_reader.Read( reinterpret_cast<UnsignedInt32*>(data), 4 );
    if( data[0] >= num_facet_points || data[0] < 0 ||
        data[1] >= num_facet_points || data[1] < 0 ||
        data[3] >= num_cfet ||  data[3] < 0 )
      delete [] facet_curves;
    CubitSense sense;
    if (data[2] == -1 )
      sense = CUBIT_UNKNOWN;
    else
      sense = data[2] ? CUBIT_REVERSED : CUBIT_FORWARD;
    tmp_curve = new FacetCurve( cfev_array[ data[3] ], facet_points[ data[0] ],
                                facet_points[ data[1] ], sense );
    if( tmp_curve == NULL )
    // Add curve to FacetPoints
    facet_points[data[0]]->add_curve( tmp_curve );
    facet_points[data[1]]->add_curve( tmp_curve );
    num_facet_curves++;
    facet_curves[i] = tmp_curve;
    tmp_curve->restore_attribs( file_ptr, endian );
  //-----------------Read FacetCoEdges------------------
  //Read number of FacetCoEdges
  facet_coedges = new FacetCoEdge*[ size ];
    int data[2];
    file_reader.Read( reinterpret_cast<unsigned int*>(data), 2 );
    if( data[0] >= num_facet_curves || data[0] < 0 )
      delete [] facet_coedges;
    CubitSense sense;
    if (data[1] == -1 )
    else
      sense = data[1] ? CUBIT_REVERSED : CUBIT_FORWARD;
    tmp_coedge =  new FacetCoEdge( facet_curves[ data[0] ], sense );
    if( tmp_coedge == NULL )
    facet_coedges[i] = tmp_coedge;
    num_facet_coedges++;
    // Add FacetCoEdge to FacetCurve
    facet_curves[ data[0] ]->add_coedge( tmp_coedge );
  //-----------------Read FacetLoops------------------
  //Read number of FacetLoops
  DLIList<CoEdgeSM*> temp_coedge_list;
  facet_loops = new FacetLoop*[ size ];
    temp_coedge_list.clean_out();
    unsigned int num_coedges = 0;
    file_reader.Read( &num_coedges, 1);
    int* coedge_ids = new int[ num_coedges];
    file_reader.Read( (unsigned*)coedge_ids, num_coedges );
    for( j=0; j<num_coedges; j++)
      if( coedge_ids[j] >= num_facet_coedges || coedge_ids[j] < 0 )
        delete [] facet_loops;
      temp_coedge_list.append( facet_coedges[ coedge_ids[j] ] );
    tmp_loop = new FacetLoop( temp_coedge_list );
    if( tmp_loop == NULL)
    num_facet_loops++;
    facet_loops[i] = tmp_loop;
      facet_coedges[ coedge_ids[j] ]->add_loop( tmp_loop );
    delete [] coedge_ids;
  //-----------------Read FacetSurfaces------------------
  //Read number of FacetSurfaces
  facet_surfaces = new FacetSurface*[size];
  DLIList<LoopSM*> temp_loops;
    temp_loops.clean_out();
    int data[6];
    file_reader.Read( (unsigned int*)data, 6);
    CubitSense sense, sense0;
    if (data[0] == -1 )
    else
      sense = data[0] ? CUBIT_REVERSED : CUBIT_FORWARD;
    CubitBoolean useFacets;
    useFacets = data[1] ? CUBIT_TRUE : CUBIT_FALSE;
    // make sure FacetEvalTool ID is in range
    if( data[2] >= num_fet || data[2] < 0 )
      delete [] facet_surfaces;
    if (data[3] == -1 )
      sense0 = CUBIT_UNKNOWN;
    else
      sense0 = data[3] ? CUBIT_REVERSED : CUBIT_FORWARD;
    int num_loops = data[5];
    int* loop_ids = new int[ num_loops ];
    file_reader.Read( (unsigned*)loop_ids, num_loops );
    for( k=0; k<num_loops; k++)
      if( loop_ids[k] >= num_facet_loops ||
          loop_ids[k] < 0 )
        delete [] loop_ids;
      temp_loops.append( facet_loops[ loop_ids[k] ] );
    tmp_surf = new FacetSurface( fev_array[ data[2] ],
                                 sense, sense0,
                                 useFacets, temp_loops );
    if( tmp_surf == NULL)
    facet_surfaces[i] = tmp_surf;
    num_facet_surfaces++;
    // Add FacetSurface to FacetLoops
      facet_loops[ loop_ids[k] ]->add_surface( tmp_surf );
    delete [] loop_ids;
    tmp_surf->restore_attribs( file_ptr, endian );
  //-----------------Read FacetShells------------------
  //Read number of FacetShells
  facet_shells = new FacetShell*[size];
  DLIList<Surface*> temp_surfs;
    temp_surfs.clean_out();
    unsigned int num_surfs = 0;
    file_reader.Read( &num_surfs, 1 );
    int* surface_ids = new int[ num_surfs ];
    file_reader.Read( (unsigned*)surface_ids, num_surfs );
    for( j=0; j<num_surfs; j++)
      if( surface_ids[j] >= num_facet_surfaces ||
          surface_ids[j] < 0 )
        delete [] facet_shells;
      temp_surfs.append( facet_surfaces[ surface_ids[j] ] );
    tmp_shell = new FacetShell( temp_surfs );
    facet_shells[i] = tmp_shell;
    num_facet_shells++;
    // Add this shell to surfaces
      facet_surfaces[ surface_ids[j] ]->add_shell( tmp_shell );
    delete [] surface_ids;
  //-----------------Read FacetLumps------------------
  //Read number of FacetLumps
  facet_lumps = new FacetLump*[size];
  DLIList<ShellSM*> temp_shells;
    temp_shells.clean_out();
    unsigned int num_shells = 0;
    file_reader.Read( &num_shells, 1 );
    int* shell_ids = new int[ num_shells ];
    file_reader.Read( (unsigned*)shell_ids, num_shells );
    for( j=0; j<num_shells; j++)
      if( shell_ids[j] >= num_facet_shells )
        delete [] facet_lumps;
      temp_shells.append( facet_shells[ shell_ids[j] ] );
    tmp_lump = new FacetLump( temp_shells );
    if( tmp_lump == NULL )
    facet_lumps[i] = tmp_lump;
    num_facet_lumps++;
      facet_shells[ shell_ids[j] ]->add_lump( tmp_lump );
    delete [] shell_ids;
    tmp_lump->restore_attribs( file_ptr, endian );
  //-----------------Read FacetBodies ------------------
  //Read number of FacetBodies
  facet_bodies = new FacetBody*[size];
  DLIList<Lump*> temp_lumps;
    temp_lumps.clean_out();
    unsigned int num_lumps= 0;
    file_reader.Read( &num_lumps, 1 );
    int* lump_ids = new int[ num_lumps ];
    file_reader.Read( (unsigned*)lump_ids, num_lumps );
    for( j=0; j<num_lumps; j++)
      if( lump_ids[j] >= num_facet_lumps )
        delete [] facet_bodies;
      temp_lumps.append( facet_lumps[ lump_ids[j] ] );
    tmp_body = new FacetBody( temp_lumps );
    if( tmp_body == NULL )
    facet_bodies[i] = tmp_body;
    num_facet_bodies++;
    // Add this FacetBody to FacetLumps
      facet_lumps[ lump_ids[j] ]->add_body( tmp_body );
    delete [] lump_ids;
    //read in trans matrix
    unsigned int rows_and_cols[2];
    file_reader.Read( rows_and_cols, 2 );
    unsigned int num_rows = rows_and_cols[0];
    unsigned int num_cols = rows_and_cols[1];
    if( num_rows || num_cols)
      CubitTransformMatrix trans_matrix;
      double *trans_matrix_array;
      trans_matrix_array = new double[ num_rows*num_cols ];
      file_reader.Read( trans_matrix_array, num_rows*num_cols );
      unsigned c;
      for(j=0; j<num_rows; j++ )
        for(c=0; c<num_cols; c++)
          trans_matrix.add(j,c, trans_matrix_array[(j*num_cols)+c] );
      tmp_body->set_transforms( trans_matrix );
      delete [] trans_matrix_array;
    tmp_body->restore_attribs( file_ptr, endian );
  // Here is where we determine if the entites are free or not
  // bodies, all bodies are free
  for(k=0; k<num_facet_bodies; k++)
    imported_entities.append( facet_bodies[k] );
  // surfaces are free if they are not in a shell
  DLIList<FacetShell*> shell_list;
  for(k=0; k<num_facet_surfaces; k++)
    facet_surfaces[k]->get_shells( shell_list );
    if( shell_list.size() == 0 )
      imported_entities.append( facet_surfaces[k] );
  // curves are free if they are not associate with a coedge
  DLIList<FacetCoEdge*> coedge_list;
  for(k=0; k<num_facet_curves; k++)
    facet_curves[k]->get_coedges( coedge_list );
    if( coedge_list.size() == 0 )
      imported_entities.append( facet_curves[k] );
  // points are free if they are not associate with a curve
  DLIList<FacetCurve*> curve_list;
  for(k=0; k<num_facet_points; k++)
    curve_list.clean_out();
    facet_points[k]->get_curves( curve_list );
    if( curve_list.size() == 0 )
      imported_entities.append( facet_points[k] );
  // clean up
Definition at line 5181 of file FacetQueryEngine.cpp.
  FacetBody* facetbod = dynamic_cast<FacetBody*>(body);
  return facetbod ? facetbod->restore( ) : CUBIT_FAILURE;
CubitStatus FacetQueryEngine::rotate ( BodySM body,
const CubitVector axis,
double  angle
) [virtual]
Definition at line 5191 of file FacetQueryEngine.cpp.
  return facetbod ? facetbod->rotate( v.x(), v.y(), v.z(), a ) : CUBIT_FAILURE;
CubitStatus FacetQueryEngine::rotate ( GeometryEntity ent,
double  degrees
) [virtual]
Definition at line 5212 of file FacetQueryEngine.cpp.
CubitStatus FacetQueryEngine::save_eval_tools ( FILE *  fp,
DLIList< FacetSurface * >  facet_surfaces,
DLIList< FacetCurve * >  facet_curves
Definition at line 4516 of file FacetQueryEngine.cpp.
  int ii;
  FacetSurface *fsurf_ptr;
  FacetCurve *fcurv_ptr;
  //separate out eval tools and set ids
  DLIList<CurveFacetEvalTool*> cfe_tools;
  DLIList<FacetEvalTool*> fe_tools;
  int ft_id = 0;
  int cft_id = 0;
  facet_surfaces.reset();
  for (ii=facet_surfaces.size(); ii--; )
    fsurf_ptr = facet_surfaces.get_and_step();
    FacetEvalTool *feval_tool = fsurf_ptr->get_eval_tool();
    if( feval_tool )
      feval_tool->set_output_id( ft_id++ );
      fe_tools.append( feval_tool );
  facet_curves.reset();
  for (ii=facet_curves.size(); ii--; )
    fcurv_ptr = facet_curves.get_and_step();
    CurveFacetEvalTool *ceval_tool = fcurv_ptr->get_eval_tool();
    if( ceval_tool )
      ceval_tool->set_output_id( cft_id++ );
      cfe_tools.append( ceval_tool );
  //Write out number of FacetEvalTools
  int count = fe_tools.size();
  NCubitFile::CIOWrapper cio(fp);
  cio.Write( reinterpret_cast<UnsignedInt32*>(&count), 1 );
  //Write out each FacetEvalTool
  fe_tools.reset();
  for( ii=0; ii<fe_tools.size(); ii++)
    FacetEvalTool *feval_tool = fe_tools.get_and_step();
    feval_tool->save( fp );
  //Write out number of CurveFacetEvalTools
  count = cfe_tools.size();
  //Write out each CurveFacetEvalTool
  cfe_tools.reset();
  for( ii=0; ii<cfe_tools.size(); ii++)
    CurveFacetEvalTool *ceval_tool = cfe_tools.get_and_step();
    ceval_tool->save( fp );
CubitStatus FacetQueryEngine::save_facets ( FILE *  fp,
DLIList< FacetCurve * >  facet_curves,
DLIList< FacetPoint * >  facet_points
Definition at line 4476 of file FacetQueryEngine.cpp.
  CubitStatus rv = CUBIT_SUCCESS;
  DLIList<CubitFacet *> facet_list;
  DLIList<CubitFacetEdge *> edge_list;
  DLIList<CubitPoint *> point_list;
  // get a unique list of all facets, edges and points
  rv = gather_facets(facet_surfaces, facet_curves, facet_points,
                     facet_list, edge_list, point_list );
    return rv;
  // dump the facet entities the file
  rv = dump_facets( fp, facet_list, edge_list, point_list );
    return rv;
  // dump the CurveFacetEvalTools and FacetEval Tools
  rv = save_eval_tools( fp, facet_surfaces, facet_curves );
  return rv;
CubitStatus FacetQueryEngine::save_temp_geom_file ( DLIList< TopologyBridge * > &  ref_entity_list,
const char *  filename,
const CubitString cubit_version,
CubitString created_file,
CubitString created_file_type
) [virtual]
Saves out a temporary geometry file. Entities in list must all be of same modeling engine.
Definition at line 843 of file FacetQueryEngine.cpp.
  int size_before = ref_entity_list.size();
  CubitString temp_filename(file_name);
  temp_filename += ".mbg";
  ModelExportOptions export_options;
  if( export_solid_model( ref_entity_list, temp_filename.c_str(), FACET_TYPE,
                          cubit_version, export_options ) == CUBIT_FAILURE )
    PRINT_ERROR( "Error occured while trying to save temporary MESH_BASED_GEOMETRY file\n");
  int size_after = ref_entity_list.size();
  if( size_before > size_after )
    created_file +=  temp_filename;
    created_file_type += "FACET";
CubitStatus FacetQueryEngine::scale ( BodySM body,
double  factor
) [virtual]
Definition at line 5196 of file FacetQueryEngine.cpp.
  return facetbod ? facetbod->scale( factor ) : CUBIT_FAILURE;
const CubitVector factors
) [virtual]
Definition at line 5201 of file FacetQueryEngine.cpp.
  return facetbod ? facetbod->scale( f.x(), f.y(), f.z() ) : CUBIT_FAILURE;
CubitStatus FacetQueryEngine::scale ( GeometryEntity ent,
double  factor
) [virtual]
Definition at line 5217 of file FacetQueryEngine.cpp.
) [virtual]
Definition at line 5222 of file FacetQueryEngine.cpp.
CubitStatus FacetQueryEngine::set_dbl_option ( const char *  opt_name,
double  val
) [virtual]
Definition at line 2623 of file FacetQueryEngine.cpp.
  PRINT_ERROR("FacetQueryEngine::set_dbl_option not yet implemented.\n");
CubitStatus FacetQueryEngine::set_int_option ( const char *  opt_name,
int  val
) [virtual]
Definition at line 2617 of file FacetQueryEngine.cpp.
  PRINT_ERROR("FacetQueryEngine::set_int_option not yet implemented.\n");
double FacetQueryEngine::set_sme_resabs_tolerance ( double  new_resabs) [virtual]
Definition at line 2611 of file FacetQueryEngine.cpp.
  PRINT_ERROR("FacetQueryEngine::set_sme_resabs_tolerance not yet implemented.\n");
CubitStatus FacetQueryEngine::set_str_option ( const char *  opt_name,
const char *  val
) [virtual]
Definition at line 2629 of file FacetQueryEngine.cpp.
  PRINT_ERROR("FacetQueryEngine::set_str_option not yet implemented.\n");
Definition at line 752 of file FacetQueryEngine.cpp.
  PRINT_ERROR("Option not supported for mesh based geometry.\n");
CubitStatus FacetQueryEngine::translate ( BodySM body,
const CubitVector offset
) [virtual]
Definition at line 5186 of file FacetQueryEngine.cpp.
  return facetbod ? facetbod->move( d.x(), d.y(), d.z() ) : CUBIT_FAILURE;
CubitStatus FacetQueryEngine::translate ( GeometryEntity ent,
) [virtual]
Definition at line 5207 of file FacetQueryEngine.cpp.
CubitBoolean FacetQueryEngine::volumes_overlap ( Lump lump_ptr_1,
Lump lump_ptr_2
) const [virtual]
Definition at line 5268 of file FacetQueryEngine.cpp.
  PRINT_ERROR("Currently, Cubit is unable to determine overlap for Facet-based geometry.\n");
  return CUBIT_FALSE;
CubitStatus FacetQueryEngine::write_topology ( FILE *  file_ptr,
DLIList< FacetBody * > &  facet_bodies,
DLIList< FacetLump * > &  facet_lumps,
DLIList< FacetShell * > &  facet_shells,
DLIList< FacetSurface * > &  facet_surfaces,
DLIList< FacetLoop * > &  facet_loops,
DLIList< FacetCoEdge * > &  facet_coedges,
DLIList< FacetCurve * > &  facet_curves,
DLIList< FacetPoint * > &  facet_points
) [private]
Definition at line 1108 of file FacetQueryEngine.cpp.
  int i;
  CIOWrapper file_writer( file_ptr );
  //-----------------write FacetPoints--------------
  UnsignedInt32 size = facet_points.size();
  //write out number of FacetPoints
  file_writer.Write( &size, 1 );
  facet_points.reset();
  for( i=0; i<facet_points.size(); i++)
    FacetPoint *curr_point = facet_points.get_and_step();
    int id = curr_point->get_cubit_point()->id();
    file_writer.Write( reinterpret_cast<UnsignedInt32*>(&id), 1 );
    if( curr_point->save_attribs(file_ptr) == CUBIT_FAILURE )
  //-----------------write FacetCurves--------------
  size = facet_curves.size();
  //write out number of FacetCurves
  for( i=0; i<facet_curves.size(); i++)
    FacetCurve *curr_curve = facet_curves.get_and_step();
    TBPoint *s_point, *e_point;
    s_point = curr_curve->start_point();
    e_point = curr_curve->end_point();
    int data_to_write[4];
    // get start&end points implicit ids
    FacetPoint *temp_point = NULL;
    temp_point = CAST_TO( s_point, FacetPoint );
    if( !temp_point ) assert(0);
    int found;
    found = facet_points.where_is_item( temp_point );
    if( found == -1)
      assert(0);
    data_to_write[0] = found;
    temp_point = CAST_TO( e_point, FacetPoint );
    if( found == -1)
      PRINT_ERROR("Problem saving Facet Curves\n");
    data_to_write[1] = found;
    //convert Sense info to integer
    if( curr_curve->get_sense() == CUBIT_UNKNOWN )
      data_to_write[2] = -1;
    else
      data_to_write[2] = (curr_curve->get_sense() == CUBIT_REVERSED) ? 1 : 0;
    data_to_write[3] = curr_curve->get_eval_tool()->get_output_id();
    //write the data
    file_writer.Write( reinterpret_cast<UnsignedInt32*>(data_to_write), 4 );
    if( curr_curve->save_attribs(file_ptr) == CUBIT_FAILURE )
  //-----------------write FacetCoedges--------------
  size = facet_coedges.size();
  // write out number of FacetCurves
  facet_coedges.reset();
  for( i=0; i<facet_coedges.size(); i++)
    FacetCoEdge *curr_coedge = facet_coedges.get_and_step();
    Curve *curve_sm;
    curve_sm = curr_coedge->curve();
    FacetCurve *temp_curve = NULL;
    temp_curve = CAST_TO( curve_sm, FacetCurve );
    int data_to_write[2];
    // get implicit id of this curve
    int found;
    found = facet_curves.where_is_item( temp_curve );
    if( found == -1)
      PRINT_ERROR("Problem saving Facet CoEdges\n");
    // convert sense info to integer
    if( curr_coedge->get_sense() == CUBIT_UNKNOWN )
      data_to_write[1] = -1;
    else
      data_to_write[1] = (curr_coedge->get_sense() == CUBIT_REVERSED) ? 1 : 0;
    // write out the data
    file_writer.Write( reinterpret_cast<UnsignedInt32*>(data_to_write), 2 );
  //-----------------write FacetLoops--------------
  size = facet_loops.size();
  // write out number of FacetLoops
  facet_loops.reset();
  for( i=0; i<facet_loops.size(); i++)
    FacetLoop *curr_loop = facet_loops.get_and_step();
    curr_loop->get_coedges( coedge_list );
    // get number of coedges in this loop
    UnsignedInt32 *data_to_write;
    size = coedge_list.size();
    data_to_write = new UnsignedInt32[ size + 1 ];
    data_to_write[0] = size;
    UnsignedInt32 j;
    // get implicit ids of coedges
    coedge_list.reset();
    for( j=1; j<size+1; j++)
      FacetCoEdge *temp_coedge = coedge_list.get_and_step();
      int found;
      found = facet_coedges.where_is_item( temp_coedge );
      if( found == -1)
        PRINT_ERROR("Problem saving Facet Loops\n");
      data_to_write[j] = found;
    file_writer.Write( data_to_write, size + 1);
    delete [] data_to_write;
  //-----------------write FacetSurfaces--------------
  size = facet_surfaces.size();
  // write out number of FacetSurfaces
  for( i=0; i<facet_surfaces.size(); i++)
    FacetSurface *curr_surface = facet_surfaces.get_and_step();
    DLIList<FacetLoop*> loop_list;
    curr_surface->get_loops( loop_list );
    int num_loops = loop_list.size();
    int data_to_write[6];
    // if( curr_surface->get_relative_surface_sense() == CUBIT_UNKNOWN )
//       data_to_write[0] = -1;
//     else
//       data_to_write[0] = (curr_surface->get_relative_surface_sense() == CUBIT_REVERSED) ? 1 : 0;
    data_to_write[0]=0;
    // get "useFacets"
    data_to_write[1] = 1;
    // get output id of FacetEvalTool
    data_to_write[2] = curr_surface->get_eval_tool()->get_output_id();
    // get Shell Sense stuff
    CubitSense sense0;
    curr_surface->get_shell_sense( sense0 );
    if( sense0 == CUBIT_UNKNOWN )
      data_to_write[3] = -1;
    else
      data_to_write[3] = (sense0 == CUBIT_REVERSED) ? 1 : 0;
//    if( sense1 == CUBIT_UNKNOWN )
      data_to_write[4] = -1;
//    else
//      data_to_write[4] = (sense1 == CUBIT_REVERSED) ? 1 : 0;
    // get number of loops
    data_to_write[5] = num_loops;
    file_writer.Write( reinterpret_cast<UnsignedInt32*>(data_to_write), 6 );
    // get implicit ids of loops
    if( num_loops > 0 )
      int *loop_ids = new int[num_loops];
      int j;
      loop_list.reset();
      for( j=0; j<num_loops; j++)
       FacetLoop *temp_loop = loop_list.get_and_step();
       int found;
       found = facet_loops.where_is_item( temp_loop );
       if( found == -1 )
         PRINT_ERROR("Problem saving Facet Surfaces\n");
       loop_ids[j] = found;
      // write out data
      file_writer.Write( reinterpret_cast<UnsignedInt32*>(loop_ids), num_loops );
      delete [] loop_ids;
    if( curr_surface->save_attribs(file_ptr) == CUBIT_FAILURE )
  //-----------------write FacetShells--------------
  size = facet_shells.size();
  // write out number of FacetShells
  facet_shells.reset();
  for( i=0; i<facet_shells.size(); i++)
    FacetShell *curr_shell= facet_shells.get_and_step(); //number of surfaces
    DLIList<FacetSurface*> temp_facet_surf_list;
    curr_shell->get_surfaces( temp_facet_surf_list );
    // get number of surfaces in this shell
    int num_surfs = temp_facet_surf_list.size();
    data_to_write = new UnsignedInt32[ num_surfs + 1];
    data_to_write[0] = num_surfs;
    // get implicit ids of surfaces
    int j;
    temp_facet_surf_list.reset();
    for( j=1; j<num_surfs+1; j++)
      FacetSurface *temp_facet_surface = temp_facet_surf_list.get_and_step();
      int found;
      found = facet_surfaces.where_is_item( temp_facet_surface );
      if( found == -1 )
        PRINT_ERROR("Problem saving Facet Shells\n");
    // write the data
    file_writer.Write( data_to_write, num_surfs + 1 );
  //-----------------write FacetLumps--------------
  size = facet_lumps.size();
  // write out number of FacetLumps
  facet_lumps.reset();
  for( i=0; i<facet_lumps.size(); i++)
    FacetLump *curr_lump = facet_lumps.get_and_step();
    DLIList<FacetShell*> temp_facet_shell_list;
    curr_lump->get_shells( temp_facet_shell_list );
    // get number of shells in this lump
    int num_shells= temp_facet_shell_list.size();
    data_to_write = new UnsignedInt32[ num_shells+ 1];
    data_to_write[0] = num_shells;
    //get implicit ides of the lumps in this shell
    int j;
    temp_facet_shell_list.reset();
    for( j=1; j<num_shells+1; j++)
      FacetShell *temp_facet_shell = temp_facet_shell_list.get_and_step();
      int found;
      found = facet_shells.where_is_item( temp_facet_shell );
      if( found == -1 )
        PRINT_ERROR("Problem saving Facet Lumps\n");
    //write the data
    file_writer.Write( data_to_write, num_shells + 1 );
    if( curr_lump->save_attribs(file_ptr) == CUBIT_FAILURE )
  //-----------------write FacetBodies--------------
  size = facet_bodies.size();
  // write out number of FacetBodies
  facet_bodies.reset();
  for( i=0; i<facet_bodies.size(); i++)
    FacetBody *curr_body = facet_bodies.get_and_step();
    DLIList<FacetLump*> temp_facet_lump_list;
    curr_body->get_lumps( temp_facet_lump_list );
    // get the number of lumps in this body
    int num_lumps = temp_facet_lump_list.size();
    data_to_write = new UnsignedInt32[ num_lumps + 1];
    data_to_write[0] = num_lumps;
    // get the implicit ids of the lumps in this body
    int j;
    temp_facet_lump_list.reset();
    for( j=1; j<num_lumps+1; j++)
      FacetLump *temp_facet_lump = temp_facet_lump_list.get_and_step();
      int found;
      found = facet_lumps.where_is_item( temp_facet_lump );
      if( found == -1 )
        PRINT_ERROR("Problem saving Facet Bodies\n");
    // write the data
    file_writer.Write( data_to_write, num_lumps + 1 );
    // write the transformation matrix of this body
    curr_body->get_transforms( trans_matrix );
    UnsignedInt32 num_rows  = trans_matrix.num_rows();
    UnsignedInt32 num_cols  = trans_matrix.num_cols();
    UnsignedInt32 rows_and_cols[2];
    rows_and_cols[0] = num_rows;
    rows_and_cols[1] = num_cols;
    file_writer.Write( rows_and_cols, 2 );
    //fill up the array row-by-row
    unsigned u, k = 0;
    for(u=0; u<num_rows; u++)
      for(k=0; k<num_cols; k++)
        trans_matrix_array[(u*num_cols)+k] = trans_matrix.get(u,k);
    file_writer.Write( trans_matrix_array, u*k );
    if( curr_body->save_attribs(file_ptr) == CUBIT_FAILURE )
Friends And Related Function Documentation
friend class FacetSurface [friend]
Definition at line 96 of file FacetQueryEngine.hpp.
Member Data Documentation
const int FacetQueryEngine::FQE_MAJOR_VERSION = 10 [static, private]
Definition at line 530 of file FacetQueryEngine.hpp.
const int FacetQueryEngine::FQE_MINOR_VERSION = 0 [static, private]
Definition at line 531 of file FacetQueryEngine.hpp.
const int FacetQueryEngine::FQE_SUBMINOR_VERSION = 0 [static, private]
Definition at line 532 of file FacetQueryEngine.hpp.
DLIList< CubitPoint * > * FacetQueryEngine::hashPointArray = NULL [static, private]
Definition at line 527 of file FacetQueryEngine.hpp.
int FacetQueryEngine::hashPointSize = 0 [static, private]
Definition at line 526 of file FacetQueryEngine.hpp.
FacetQueryEngine * FacetQueryEngine::instance_ = NULL [static, private]
Definition at line 517 of file FacetQueryEngine.hpp.
