add_hash_point(CubitPoint *point_ptr) | FacetQueryEngine | [private, static] |
bodies_overlap(BodySM *body_ptr_1, BodySM *body_ptr_2) const | FacetQueryEngine | [virtual] |
can_delete_bodies(DLIList< Body * >body_list) | FacetQueryEngine | |
copy_body(Body *body_ptr) | FacetQueryEngine | |
create_facet_bounding_box(BodySM *bodySM, CubitBox &bbox) | FacetQueryEngine | |
create_super_facet_bounding_box(DLIList< BodySM * > &body_list, CubitBox &super_box) | FacetQueryEngine | |
curve_is_on_ignored_surface(Curve *, Surface *) | GeometryQueryEngine | [inline, virtual] |
delete_hash_points() | FacetQueryEngine | [private, static] |
delete_instance() | FacetQueryEngine | [static] |
delete_solid_model_entities(DLIList< BodySM * > &body_list) const | FacetQueryEngine | [virtual] |
delete_solid_model_entities(BodySM *body_ptr) const | FacetQueryEngine | [virtual] |
delete_solid_model_entities(Surface *surf_ptr) const | FacetQueryEngine | [virtual] |
delete_solid_model_entities(Curve *curve_ptr) const | FacetQueryEngine | [virtual] |
delete_solid_model_entities(TBPoint *point_ptr) const | FacetQueryEngine | [virtual] |
GeometryQueryEngine::delete_solid_model_entities(GeometryEntity *ref_entity_ptr) const | GeometryQueryEngine | [virtual] |
delete_topology_bridge(TopologyBridge *bridge) const | GeometryQueryEngine | [virtual] |
dump_facets(FILE *fp, DLIList< CubitFacet * > &facet_list, DLIList< CubitFacetEdge * > &edge_list, DLIList< CubitPoint * > &point_list) | FacetQueryEngine | |
ensure_is_ascii_stl_file(FILE *fp, CubitBoolean &is_ascii) | FacetQueryEngine | |
entity_entity_distance(GeometryEntity *ref_entity_ptr1, GeometryEntity *ref_entity_ptr2, CubitVector &pos1, CubitVector &pos2, double &distance) | FacetQueryEngine | [virtual] |
entity_extrema(DLIList< GeometryEntity * > &entity_list, const CubitVector *dir1, const CubitVector *dir2, const CubitVector *dir3, CubitVector &extrema, GeometryEntity *&extrema_entity_ptr) | FacetQueryEngine | [virtual] |
entity_type_info() const | FacetQueryEngine | [virtual] |
export_facets(DLIList< CubitFacet * > &facet_list, char *filename) | FacetQueryEngine | [static] |
export_solid_model(DLIList< TopologyBridge * > &bridge_list, const char *file_name, Model_File_Type file_type, const CubitString &cubit_version, ModelExportOptions &export_options) | FacetQueryEngine | [virtual] |
export_solid_model(DLIList< TopologyBridge * > &bridge_list, char *&p_buffer, int &n_buffer_size, bool b_export_buffer) | FacetQueryEngine | [inline, virtual] |
FacetQueryEngine() | FacetQueryEngine | [protected] |
FacetSurface class | FacetQueryEngine | [friend] |
fire_ray(CubitVector &origin, CubitVector &direction, DLIList< TopologyBridge * > &at_entity_list, DLIList< double > &ray_params, int max_hits, double ray_radius, DLIList< TopologyBridge * > *hit_entity_list=0) const | FacetQueryEngine | [virtual] |
FQE_MAJOR_VERSION | FacetQueryEngine | [private, static] |
FQE_MINOR_VERSION | FacetQueryEngine | [private, static] |
FQE_SUBMINOR_VERSION | FacetQueryEngine | [private, static] |
gather_all_facet_entities(DLIList< FacetBody * > &facet_bodies, DLIList< FacetLump * > &facet_lumps, DLIList< FacetShell * > &facet_shells, DLIList< FacetSurface * > &facet_surfaces, DLIList< FacetLoop * > &facet_loops, DLIList< FacetCoEdge * > &facet_coedges, DLIList< FacetCurve * > &facet_curves, DLIList< FacetPoint * > &facet_points) | FacetQueryEngine | |
gather_facets(DLIList< FacetSurface * > facet_surfaces, DLIList< FacetCurve * > facet_curves, DLIList< FacetPoint * > facet_points, DLIList< CubitFacet * > &facet_list, DLIList< CubitFacetEdge * > &edge_list, DLIList< CubitPoint * > &point_list) | FacetQueryEngine | |
get_all_hash_points(DLIList< CubitPoint * > &point_list) | FacetQueryEngine | [private, static] |
get_allint_version() | GeometryQueryEngine | [virtual] |
get_connected_patch(DLIList< FacetSurface * > &remaining_surfs, DLIList< FacetSurface * > &output_patch) | FacetQueryEngine | |
get_engine_version_string() | FacetQueryEngine | [virtual] |
get_graphics(BodySM *bodysm, GMem *g_mem, std::vector< Surface * > &surface_to_facets_vector, std::vector< TopologyBridge * > &vertex_edge_to_point_vector, std::vector< std::pair< TopologyBridge *, std::pair< int, int > > > &facet_edges_on_curves, unsigned short normal_tolerance, double distance_tolerance, double max_edge_length) const | FacetQueryEngine | [virtual] |
get_graphics(Surface *surface_ptr, GMem *gMem, unsigned short normal_tolerance, double distance_tolerance, double max_edge_length) const | FacetQueryEngine | [virtual] |
get_graphics(Curve *curve_ptr, GMem *gMem, double angle_tolerance=0, double distance_tolerance=0, double max_edge_length=0) const | FacetQueryEngine | [virtual] |
GeometryQueryEngine::get_graphics(Surface *surface_ptr, GMem *gmem, std::vector< TopologyBridge * > &vertex_edge_to_point_vector, std::vector< std::pair< TopologyBridge *, std::pair< int, int > > > &facet_edges_on_curves, unsigned short normal_tolerance=15, double distance_tolerance=0.0, double max_edge_length=0.0) const | GeometryQueryEngine | [virtual] |
get_hash_key(int id) | FacetQueryEngine | [private, static] |
get_hash_point(int id) | FacetQueryEngine | [private, static] |
get_intersections(Curve *, CubitVector &point1, CubitVector &, DLIList< CubitVector > &, CubitBoolean, CubitBoolean) | FacetQueryEngine | [virtual] |
get_intersections(Curve *, Curve *, DLIList< CubitVector > &, CubitBoolean, CubitBoolean) | FacetQueryEngine | [virtual] |
get_intersections(Curve *ref_edge1, Curve *ref_edge2, DLIList< CubitVector > &intersection_list, double offset, CubitBoolean ext_first=CUBIT_TRUE) | FacetQueryEngine | [virtual] |
get_intersections(Curve *ref_edge, Surface *ref_face, DLIList< CubitVector > &intersection_list, CubitBoolean bounded=CUBIT_FALSE) | FacetQueryEngine | [virtual] |
GeometryQueryEngine::get_intersections(Curve *ref_edge1, CubitVector &point1, CubitVector &point2, DLIList< CubitVector > &intersection_list, bool bounded=false, bool closest=false)=0 | GeometryQueryEngine | [pure virtual] |
GeometryQueryEngine::get_intersections(Curve *ref_edge1, Curve *ref_edge2, DLIList< CubitVector > &intersection_list, bool bounded=false, bool closest=false)=0 | GeometryQueryEngine | [pure virtual] |
GeometryQueryEngine::get_intersections(Curve *curve, Surface *surface, DLIList< CubitVector > &intersection_list, bool bounded=false)=0 | GeometryQueryEngine | [pure virtual] |
get_isoparametric_points(Surface *, int &, int &, GMem *&) const | FacetQueryEngine | [virtual] |
get_major_version() | FacetQueryEngine | [virtual] |
get_minor_version() | FacetQueryEngine | [virtual] |
get_ordered_loops(RefFace *, DLIList< Loop * > &) const | GeometryQueryEngine | [inline, virtual] |
get_point_containment(DLIList< BodySM * > &bodysm_list, DLIList< CubitVector > &point_list, double tolerance, bool allow_pts_in_multiple_bodies, std::vector< std::pair< BodySM *, std::vector< int > > > &bodysm_to_pt_indices) | FacetQueryEngine | [virtual] |
get_sme_resabs_tolerance() const | FacetQueryEngine | [virtual] |
get_subminor_version() | FacetQueryEngine | [virtual] |
get_u_isoparametric_points(Surface *ref_face_ptr, double v, int &n, GMem *&gMem) const | FacetQueryEngine | [virtual] |
get_underlying_bridges(TopologyBridge *bridge_ptr, DLIList< TopologyBridge * > &bridge_list) | GeometryQueryEngine | [virtual] |
get_underlying_curves(Curve *curve_ptr, DLIList< TopologyBridge * > &curve_list) | GeometryQueryEngine | [virtual] |
get_underlying_surfaces(Surface *surf_ptr, DLIList< TopologyBridge * > &surf_list) | GeometryQueryEngine | [virtual] |
get_v_isoparametric_points(Surface *ref_face_ptr, double u, int &n, GMem *&gMem) const | FacetQueryEngine | [virtual] |
get_visible_entities(TopologyBridge *hidden_tb, DLIList< TopologyBridge * > &real_tbs) | GeometryQueryEngine | [virtual] |
get_visible_entity_at_point(TopologyBridge *, CubitVector *) | GeometryQueryEngine | [inline, virtual] |
hashPointArray | FacetQueryEngine | [private, static] |
hashPointSize | FacetQueryEngine | [private, static] |
import_facets(const char *file_name, CubitBoolean use_feature_angle, double feature_angle, double tolerance, int interp_order, CubitBoolean smooth_non_manifold, CubitBoolean split_surfaces, CubitBoolean stitch, CubitBoolean improve, DLIList< CubitQuadFacet * > &quad_facet_list, DLIList< CubitFacet * > &tri_facet_list, DLIList< Surface * > &surface_list, FacetFileFormat file_format=CUBIT_FACET_FILE) | FacetQueryEngine | |
import_solid_model(const char *file_name, Model_File_Type file_type, DLIList< TopologyBridge * > &imported_entities, ModelImportOptions &import_options) | FacetQueryEngine | [virtual] |
import_solid_model(DLIList< TopologyBridge * > &imported_entities, const char *pBuffer, const int n_buffer_size) | FacetQueryEngine | [inline, virtual] |
import_solid_model(FILE *file_ptr, DLIList< TopologyBridge * > &imported_entities) | FacetQueryEngine | [private] |
init_hash_points(int num_points) | FacetQueryEngine | [private, static] |
instance_ | FacetQueryEngine | [private, static] |
is_close(CubitVector &this_point, DLIList< CubitFacet * > &facet_list, CubitFacet *&lastFacet, double tol) | FacetQueryEngine | |
is_intermediate_engine() | GeometryQueryEngine | [inline, virtual] |
is_solid_modeler_type() const | FacetQueryEngine | [inline, virtual] |
list_engine_versions(CubitString &versions) | GeometryQueryEngine | [virtual] |
make_BodySM(Surface *) const | FacetQueryEngine | [virtual] |
make_BodySM(DLIList< Lump * > &) const | FacetQueryEngine | [virtual] |
make_Curve(Curve *) const | FacetQueryEngine | [virtual] |
make_Curve(TBPoint const *, TBPoint const *, RefFace *, CubitVector *) const | FacetQueryEngine | [virtual] |
make_Curve(GeometryType, TBPoint const *, TBPoint const *, DLIList< CubitVector * > &, RefFace *) const | FacetQueryEngine | [virtual] |
make_Curve(GeometryType, TBPoint const *, TBPoint const *, CubitVector const *, CubitSense) const | FacetQueryEngine | [virtual] |
make_facets(int *conn, int nfacets, DLIList< CubitQuadFacet * > &facet_list) | FacetQueryEngine | [static] |
make_facets(int *conn, int nfacets, DLIList< CubitFacet * > &facet_list) | FacetQueryEngine | [static] |
make_Lump(GeometryType, DLIList< Surface * > &) const | FacetQueryEngine | [virtual] |
make_Point(GeometryType point_type, CubitVector const &point) const | FacetQueryEngine | [virtual] |
make_Surface(Surface *, DLIList< Loop * > &, CubitBoolean) const | FacetQueryEngine | [virtual] |
make_Surface(GeometryType, DLIList< Curve * > &, DLIList< Loop * > &, Surface *) const | FacetQueryEngine | [virtual] |
modeler_type() | FacetQueryEngine | [inline, virtual] |
read_cholla_file(const char *file_name, double &feature_angle, DLIList< CubitPoint * > &point_list, DLIList< CubitFacet * > &facet_list) | FacetQueryEngine | [static] |
read_facets(const char *file_name, int *&conn, int &npoints, int &nquad, int &ntri, FacetFileFormat file_format=CUBIT_FACET_FILE) | FacetQueryEngine | [static] |
read_facets(FILE *fp, unsigned int endian, int &num_facets, int &num_edges, int &num_points, CubitFacet **&facets, CubitFacetEdge **&edges, CubitPoint **&points) | FacetQueryEngine | [private] |
read_facets_stl(DLIList< CubitFacet * > &tfacet_list, DLIList< CubitPoint * > &point_list, const char *file_name, int &npoints, int &ntri, long &seek_address) | FacetQueryEngine | |
read_facets_stl_tolerance(DLIList< CubitFacet * > &tfacet_list, DLIList< CubitPoint * > &point_list, const char *file_name, int &npoints, int &ntri, long &seek_address, double tolerance) | FacetQueryEngine | |
reflect(BodySM *body, const CubitVector &axis) | FacetQueryEngine | [virtual] |
reflect(GeometryEntity *ent, const CubitVector &axis) | FacetQueryEngine | [virtual] |
restore_eval_tools(FILE *fp, unsigned int endian, int num_facets, int num_edges, int num_points, CubitFacet **facets, CubitFacetEdge **edges, CubitPoint **points, int &num_cfet, int &num_fet, CurveFacetEvalTool **&cfeval_tools, FacetEvalTool **&feval_tools) | FacetQueryEngine | |
restore_facets(FILE *file_ptr, unsigned int endian, int &num_facets, int &num_edges, int &num_points, CubitPoint **&points_array, int &num_cfet, int &num_fet, CurveFacetEvalTool **&cfet_array, FacetEvalTool **&fet_array) | FacetQueryEngine | [private] |
restore_topology(FILE *file_ptr, unsigned int endian, int num_points, CubitPoint **points_array, int num_cfet, CurveFacetEvalTool **cfev_array, int num_fet, FacetEvalTool **fev_array, DLIList< TopologyBridge * > &imported_entities) | FacetQueryEngine | [private] |
restore_transform(BodySM *body) | FacetQueryEngine | [virtual] |
rotate(BodySM *body, const CubitVector &axis, double angle) | FacetQueryEngine | [virtual] |
rotate(GeometryEntity *ent, const CubitVector &axis, double degrees) | FacetQueryEngine | [virtual] |
save_eval_tools(FILE *fp, DLIList< FacetSurface * > facet_surfaces, DLIList< FacetCurve * > facet_curves) | FacetQueryEngine | |
save_facets(FILE *fp, DLIList< FacetSurface * > facet_surfaces, DLIList< FacetCurve * > facet_curves, DLIList< FacetPoint * > facet_points) | FacetQueryEngine | |
save_temp_geom_file(DLIList< TopologyBridge * > &ref_entity_list, const char *file_name, const CubitString &cubit_version, CubitString &created_file, CubitString &created_file_type) | FacetQueryEngine | [virtual] |
scale(BodySM *body, double factor) | FacetQueryEngine | [virtual] |
scale(BodySM *body, const CubitVector &factors) | FacetQueryEngine | [virtual] |
scale(GeometryEntity *ent, double factor) | FacetQueryEngine | [virtual] |
scale(GeometryEntity *ent, const CubitVector &factors) | FacetQueryEngine | [virtual] |
set_dbl_option(const char *opt_name, double val) | FacetQueryEngine | [virtual] |
set_export_allint_version(const int version) | GeometryQueryEngine | [virtual] |
set_export_version(const int major, const int minor) | GeometryQueryEngine | [virtual] |
set_int_option(const char *opt_name, int val) | FacetQueryEngine | [virtual] |
set_sme_resabs_tolerance(double new_resabs) | FacetQueryEngine | [virtual] |
set_str_option(const char *opt_name, const char *val) | FacetQueryEngine | [virtual] |
transform_vec_position(CubitVector const &, BodySM *, CubitVector &) const | FacetQueryEngine | [virtual] |
translate(BodySM *body, const CubitVector &offset) | FacetQueryEngine | [virtual] |
translate(GeometryEntity *ent, const CubitVector &offset) | FacetQueryEngine | [virtual] |
validate_geometry_database() const | GeometryQueryEngine | [inline, virtual] |
volumes_overlap(Lump *lump_ptr_1, Lump *lump_ptr_2) const | FacetQueryEngine | [virtual] |
write_topology(FILE *file_ptr, DLIList< FacetBody * > &facet_bodies, DLIList< FacetLump * > &facet_lumps, DLIList< FacetShell * > &facet_shells, DLIList< FacetSurface * > &facet_surfaces, DLIList< FacetLoop * > &facet_loops, DLIList< FacetCoEdge * > &facet_coedges, DLIList< FacetCurve * > &facet_curves, DLIList< FacetPoint * > &facet_points) | FacetQueryEngine | [private] |
~FacetQueryEngine() | FacetQueryEngine | [virtual] |
~GeometryQueryEngine() | GeometryQueryEngine | [inline, virtual] |
