cgma
CubitFacetEdgeData Class Reference
#include <CubitFacetEdgeData.hpp>
Inheritance diagram for CubitFacetEdgeData:
CubitFacetEdge FacetEntity ToolDataUser
List of all members.
Public Member Functions
 CubitFacetEdgeData (CubitPoint *p1, CubitPoint *p2)
 CubitFacetEdgeData (CubitPoint *p1, CubitPoint *p2, CubitFacet *facet1, CubitFacet *facet2, int edge_index1, int edge_index2)
 ~CubitFacetEdgeData ()
int id ()
void set_id (int ent_id)
CubitPointpoint (int index)
CubitPointstart_node ()
CubitPointend_node ()
void set_point (CubitPoint *pt, int index)
CubitFacetadj_facet (int index)
void facets (DLIList< CubitFacet * > &facet_list)
void edges (DLIList< CubitFacetEdge * > &edge_list)
void points (DLIList< CubitPoint * > &point_list)
int num_adj_facets ()
int number_tris ()
void marked (int my_flag)
int marked ()
void add_facet (CubitFacet *facet_ptr)
CubitStatus remove_facet (CubitFacet *facet_ptr)
CubitStatus merge_edges (CubitFacetEdgeData *other_edge)
void flip ()
Private Attributes
CubitPointpointArray [2]
DLIList< CubitFacet * > adjFacetList
int entityId
Detailed Description
Definition at line 32 of file CubitFacetEdgeData.hpp.
Definition at line 29 of file CubitFacetEdgeData.cpp.
  assert( p1 && p2 );
  assert( p1 != p2 );
  pointArray[0] = p1;
  pointArray[1] = p2;
  counter_id++;
  entityId = counter_id;
  // determine adjacency (assumes facets are already defined)
  // set the edge and use on the adjacent facets
  int sense;
  int eindex;
  CubitFacet *facet_ptr;
  DLIList<CubitFacet*> facet_list;
  p1->facets( facet_list );
  CubitBoolean found;
  for(int ii=0; ii<facet_list.size(); ii++) {
    found = CUBIT_FALSE;
    facet_ptr = facet_list.get_and_step();
    for(int jj=0; jj<3 && !found; jj++)
      if (facet_ptr->point(jj) == p2)
        found = CUBIT_TRUE;
        adjFacetList.append(facet_ptr);
        eindex = facet_ptr->edge_index( p1, p2, sense );
        facet_ptr->edge( this, eindex );
        facet_ptr->edge_use( sense, eindex );
CubitFacetEdgeData::CubitFacetEdgeData ( CubitPoint p1,
CubitPoint p2,
CubitFacet facet1,
CubitFacet facet2,
int  edge_index1,
int  edge_index2
Definition at line 72 of file CubitFacetEdgeData.cpp.
  assert( p1 && p2 );
  assert( p1 != p2 );
  pointArray[0] = p1;
  pointArray[1] = p2;
  counter_id++;
  if (facet1) {
    adjFacetList.append(facet1);
    facet1->edge( this, edge_index1 );
    facet1->edge_use( 1, edge_index1 );
  if (facet2) {
    adjFacetList.append(facet2);
    facet2->edge( this, edge_index2 );
    facet2->edge_use( -1, edge_index2 );
Definition at line 102 of file CubitFacetEdgeData.cpp.
  assert(adjFacetList.size() == 0);
Member Function Documentation
void CubitFacetEdgeData::add_facet ( CubitFacet facet_ptr) [inline, virtual]
Reimplemented from CubitFacetEdge.
Definition at line 68 of file CubitFacetEdgeData.hpp.
{ adjFacetList.append(facet_ptr); }
CubitFacet * CubitFacetEdgeData::adj_facet ( int  index) [virtual]
Implements CubitFacetEdge.
Definition at line 113 of file CubitFacetEdgeData.cpp.
  if (index < 0 || index > adjFacetList.size() - 1)
    return (CubitFacet *)NULL;
  adjFacetList.reset();
  return adjFacetList.next(index);
void CubitFacetEdgeData::edges ( DLIList< CubitFacetEdge * > &  edge_list) [virtual]
Definition at line 138 of file CubitFacetEdgeData.cpp.
  edge_list.append( this );
CubitPoint* CubitFacetEdgeData::end_node ( ) [inline, virtual]
Definition at line 52 of file CubitFacetEdgeData.hpp.
{ return point(1); }
void CubitFacetEdgeData::facets ( DLIList< CubitFacet * > &  facet_list) [virtual]
Definition at line 127 of file CubitFacetEdgeData.cpp.
  facet_list += adjFacetList;
void CubitFacetEdgeData::flip ( ) [virtual]
Definition at line 213 of file CubitFacetEdgeData.cpp.
  CubitPoint* tmp = pointArray[0];
  pointArray[0] = pointArray[1];
  pointArray[1] = tmp;
  for ( int i = adjFacetList.size(); i--; )
    CubitFacet* facet = adjFacetList.get_and_step();
    int index = facet->edge_index(this);
    assert(index >= 0);
    facet->edge_use( -facet->edge_use(index), index );
  toggle_is_flipped();
int CubitFacetEdgeData::id ( ) [inline, virtual]
Definition at line 47 of file CubitFacetEdgeData.hpp.
{return entityId;}
void CubitFacetEdgeData::marked ( int  my_flag) [inline, virtual]
Definition at line 65 of file CubitFacetEdgeData.hpp.
{ set_flag(my_flag); }
int CubitFacetEdgeData::marked ( ) [inline, virtual]
Definition at line 66 of file CubitFacetEdgeData.hpp.
{ return get_flag(); }
Definition at line 181 of file CubitFacetEdgeData.cpp.
  if( other_edge == this )
    return CUBIT_SUCCESS;
  int reversed = false;
  if ( point(0) == other_edge->point(1) && point(1) == other_edge->point(0) )
    reversed = true;
  else if( point(0) != other_edge->point(0) || point(1) != other_edge->point(1) )
    return CUBIT_FAILURE;
  CubitFacetData* facet;
  while( other_edge->adjFacetList.size() )
    facet = dynamic_cast<CubitFacetData*>(other_edge->adjFacetList.pop());
    for ( int i = 0; i < 3; i++ )
      if( facet->edge(i) == other_edge )
        facet->edge( this, i );
        add_facet(facet);
        if( reversed )
          facet->edge_use( -facet->edge_use(i), i );
  delete other_edge;
int CubitFacetEdgeData::num_adj_facets ( ) [inline, virtual]
Definition at line 62 of file CubitFacetEdgeData.hpp.
    { return adjFacetList.size(); }
int CubitFacetEdgeData::number_tris ( ) [inline, virtual]
Definition at line 64 of file CubitFacetEdgeData.hpp.
{ return num_adj_facets(); }
CubitPoint* CubitFacetEdgeData::point ( int  index) [inline, virtual]
Definition at line 50 of file CubitFacetEdgeData.hpp.
{ return pointArray[index]; };
void CubitFacetEdgeData::points ( DLIList< CubitPoint * > &  point_list) [virtual]
Definition at line 149 of file CubitFacetEdgeData.cpp.
  point_list.append( pointArray[0] );
  point_list.append( pointArray[1] );
Definition at line 161 of file CubitFacetEdgeData.cpp.
  CubitStatus stat = CUBIT_SUCCESS;
  bool removed = adjFacetList.remove( facet_ptr );
  if (removed)
  else
    stat = CUBIT_FAILURE;
  return stat;
void CubitFacetEdgeData::set_id ( int  ent_id) [inline, virtual]
Definition at line 48 of file CubitFacetEdgeData.hpp.
{entityId=ent_id;};
void CubitFacetEdgeData::set_point ( CubitPoint pt,
int  index
) [inline]
Definition at line 54 of file CubitFacetEdgeData.hpp.
{ pointArray[index] = pt; }
Definition at line 51 of file CubitFacetEdgeData.hpp.
{ return point(0); }
Member Data Documentation
Definition at line 37 of file CubitFacetEdgeData.hpp.
Definition at line 35 of file CubitFacetEdgeData.hpp.
