build_curve_geometry(DLIList< FacetCurveMesh * > &facet_curve_list) | FacetGeometryCreator | [private] |
build_geometry(DLIList< FacetSurfaceMesh * > &facet_surface_list, DLIList< FacetCurveMesh * > &facet_curve_list, DLIList< FacetPointMesh * > &facet_point_list, int interp_order, CubitBoolean use_feature_angle, double min_dot, CubitBoolean smooth_non_manifold, CubitBoolean split_surfaces) | FacetGeometryCreator | [private] |
build_loop_geometry(DLIList< FacetCurveMesh * > &facet_curve_list, FacetSurfaceMesh *fsm_ptr, DLIList< LoopSM * > &loop_list, int &ncurves) | FacetGeometryCreator | [private] |
build_point_geometry(DLIList< FacetPointMesh * > &facet_point_list) | FacetGeometryCreator | [private] |
build_surface_geometry(DLIList< FacetSurfaceMesh * > &facet_surface_list, int interp_order, double min_dot) | FacetGeometryCreator | [private] |
classify_edge(FacetEntity *edge_ptr, DLIList< FacetCurveMesh * > &facet_curve_list, FacetSurfaceMesh *fsm_ptr) | FacetGeometryCreator | [private] |
classify_point(CubitPoint *point_ptr, DLIList< FacetPointMesh * > &facet_point_list, FacetCurveMesh *fcm_ptr) | FacetGeometryCreator | [private] |
clean_geometry(CubitBoolean smooth_non_manifold, CubitBoolean split_surfaces, CubitBoolean use_feature_angle, double min_dot, DLIList< FacetCurveMesh * > &facet_curve_list) | FacetGeometryCreator | [private] |
create_curve_boundaries(DLIList< FacetCurveMesh * > &facet_curve_list, DLIList< FacetPointMesh * > &facet_point_list) | FacetGeometryCreator | [private] |
create_surface_boundaries(DLIList< FacetSurfaceMesh * > &facet_surface_list, DLIList< FacetCurveMesh * > &facet_curve_list, CubitBoolean use_feature_angle, double min_dot) | FacetGeometryCreator | [private] |
create_volume_boundaries(DLIList< FacetSurfaceMesh * > &facet_surface_sheets, CubitBoolean use_feature_angle, double min_dot, CubitBoolean split_surfaces) | FacetGeometryCreator | [private] |
delete_hash_curves() | FacetGeometryCreator | [private] |
delete_hash_points() | FacetGeometryCreator | [private] |
delete_tool_datas() | FacetGeometryCreator | [private] |
edgeList | FacetGeometryCreator | [private] |
faceList | FacetGeometryCreator | [private] |
facetCurveList | FacetGeometryCreator | [private] |
FacetGeometryCreator() | FacetGeometryCreator | |
FacetGeometryCreator(DLIList< FacetEntity * > &face_list, DLIList< FacetEntity * > &edge_list, DLIList< FacetEntity * > &point_list) | FacetGeometryCreator | |
facetPointList | FacetGeometryCreator | [private] |
facetSurfaceList | FacetGeometryCreator | [private] |
get_curve_hash_key(DLIList< FacetSurfaceMesh * > *bsm_list_ptr) | FacetGeometryCreator | [private] |
get_point_hash_key(DLIList< FacetCurveMesh * > *bsm_list_ptr) | FacetGeometryCreator | [private] |
hashCurveArray | FacetGeometryCreator | [private] |
hashCurveSize | FacetGeometryCreator | [private] |
hashPointArray | FacetGeometryCreator | [private] |
hashPointSize | FacetGeometryCreator | [private] |
init_hash_curves() | FacetGeometryCreator | [private] |
init_hash_points() | FacetGeometryCreator | [private] |
pointList | FacetGeometryCreator | [private] |
print_me() | FacetGeometryCreator | |
set_up_tool_datas() | FacetGeometryCreator | [private] |
~FacetGeometryCreator() | FacetGeometryCreator | |
