cgma
OctreeIntersectionData Class Reference
#include <OctreeIntersectionData.hpp>
List of all members.
Public Member Functions
 OctreeIntersectionData (const CubitVector &normal, const CubitBoolean half_space, const double &len, RefFace *ptr_face, const CubitVector &closest_point_on_facet, CubitFacet *lp_facet)
 OctreeIntersectionData (CubitOctreeNode *ptr_white_node, CubitVector normal, CubitVector int_point, double len, RefFace *ptr_face)
 ~OctreeIntersectionData ()
CubitVector get_normal (void)
CubitVector get_int_point (void)
double get_length (void)
RefFaceget_face (void)
CubitOctreeNodeget_white_node (void)
CubitFacetget_facet_ptr ()
CubitBoolean get_halfspace ()
CubitVector get_facet_normal ()
CubitBoolean is_merged ()
void set_merged (const CubitBoolean val)
Static Public Member Functions
static int compare_function (OctreeIntersectionData *&a, OctreeIntersectionData *&b)
Private Attributes
CubitOctreeNodewhiteNode
CubitVector facetNormal
CubitVector intPoint
double length
RefFacerefFace
CubitFacetptrFacet
CubitBoolean halfSpace
CubitBoolean merged
Detailed Description
Definition at line 24 of file OctreeIntersectionData.hpp.
OctreeIntersectionData::OctreeIntersectionData ( const CubitVector normal,
const double &  len,
RefFace ptr_face,
const CubitVector closest_point_on_facet,
CubitFacet lp_facet
Definition at line 8 of file OctreeIntersectionData.cpp.
  facetNormal = normal;
  halfSpace = half_space;
  length = len;
  refFace = ptr_face;
  intPoint = closest_point_on_facet;
  ptrFacet = lp_facet;
  merged = 0;
OctreeIntersectionData::OctreeIntersectionData ( CubitOctreeNode ptr_white_node,
CubitVector  normal,
double  len,
RefFace ptr_face
Definition at line 19 of file OctreeIntersectionData.cpp.
  intPoint = int_point;
  refFace = ptr_face;
  length = len;
  whiteNode = ptr_white_node;
Member Function Documentation
Definition at line 39 of file OctreeIntersectionData.hpp.
    if (a->get_length() < b->get_length()) {return -1;}
    else if (a->get_length() > b->get_length()) {return 1;}
    else {return 0;}
Definition at line 33 of file OctreeIntersectionData.hpp.
{ return refFace; }
Definition at line 35 of file OctreeIntersectionData.hpp.
{return ptrFacet;} // for SAT code
Definition at line 36 of file OctreeIntersectionData.hpp.
{return halfSpace;} // for SAT code
Definition at line 31 of file OctreeIntersectionData.hpp.
{return intPoint; }
double OctreeIntersectionData::get_length ( void  ) [inline]
Definition at line 32 of file OctreeIntersectionData.hpp.
{ return length; }
Definition at line 30 of file OctreeIntersectionData.hpp.
{ return facetNormal; }
Definition at line 34 of file OctreeIntersectionData.hpp.
{ return whiteNode; }
Definition at line 46 of file OctreeIntersectionData.hpp.
{return merged;}
void OctreeIntersectionData::set_merged ( const CubitBoolean  val) [inline]
Definition at line 47 of file OctreeIntersectionData.hpp.
{merged = val;}
Member Data Documentation
Definition at line 53 of file OctreeIntersectionData.hpp.
Definition at line 54 of file OctreeIntersectionData.hpp.
