cgma
PartitionSurface Class Reference
#include <PartitionSurface.hpp>
Inheritance diagram for PartitionSurface:
Surface PartitionEntity GeometryEntity TopologyBridge SubSurface
List of all members.
Public Member Functions
virtual CubitStatus combine (PartitionSurface *dead_surface)
 PartitionSurface (PartitionLump *owner)
PartitionSurfacesplit (DLIList< CubitFacetData * > &facets_to_move)
virtual ~PartitionSurface ()
int num_loops () const
PartitionLoopnext_loop (const PartitionLoop *prev=0) const
CubitStatus add (PartitionLoop *loop)
CubitStatus remove (PartitionLoop *loop)
CubitStatus add (PartitionCoSurf *cosurf)
CubitStatus remove (PartitionCoSurf *cosurf)
PartitionCoSurfnext_co_surface (const PartitionCoSurf *prev=0) const
PartitionCoSurffind_first (const PartitionShell *shell) const
PartitionCoSurffind_first (const PartitionLump *lump) const
PartitionCoSurffind_next (const PartitionCoSurf *cosurf) const
PartitionCoSurffind_first (const PartitionShell *shell, CubitSense sense) const
void get_points (DLIList< PartitionPoint * > &list) const
virtual CubitStatus save (CubitSimpleAttrib &attrib)
CubitBox bounding_box () const
double measure ()
GeometryType geometry_type ()
virtual CubitStatus move_to_geometry (CubitVector &position)
virtual void closest_point_trimmed (CubitVector from, CubitVector &closest)
virtual CubitStatus get_point_normal (CubitVector &point, CubitVector &normal)
virtual CubitStatus closest_point_uv_guess (CubitVector const &location, double &u, double &v, CubitVector *closest_location=NULL, CubitVector *unit_normal=NULL)
virtual CubitStatus evaluate (double u, double v, CubitVector *position, CubitVector *normal, CubitVector *curvature1, CubitVector *curvature2)
virtual CubitStatus get_projected_distance_on_surface (CubitVector *pos1, CubitVector *pos2, double &distance)
virtual CubitStatus closest_point (CubitVector const &pos, CubitVector *close=0, CubitVector *norm=0, CubitVector *curv1=0, CubitVector *curv2=0)
virtual CubitStatus principal_curvatures (CubitVector const &loc, double &curv1, double &curv2, CubitVector *closest_location=0)
virtual CubitVector position_from_u_v (double u, double v)
virtual CubitStatus u_v_from_position (CubitVector const &location, double &u, double &v, CubitVector *closest_location=NULL)
virtual CubitStatus closest_point_along_vector (CubitVector &from_point, CubitVector &along_vector, CubitVector &point_on_surface)
virtual CubitBoolean is_periodic ()
virtual CubitBoolean is_periodic_in_U (double &period)
virtual CubitBoolean is_periodic_in_V (double &period)
virtual CubitBoolean is_singular_in_U (double u_param)
virtual CubitBoolean is_singular_in_V (double v_param)
virtual CubitBoolean is_closed_in_U ()
virtual CubitBoolean is_closed_in_V ()
virtual CubitStatus get_sphere_params (CubitVector &center, double &radius) const
virtual CubitStatus get_cone_params (CubitVector &center, CubitVector &normal, CubitVector &major_axis, double &radius_ratio, double &sine_angle, double &cos_angle) const
virtual CubitStatus get_torus_params (CubitVector &center, CubitVector &normal, double &major_radius, double &minor_radius) const
virtual CubitStatus get_nurb_params (bool &rational, int &degree_u, int &degree_v, int &num_cntrl_pts_u, int &num_cntrl_pts_v, DLIList< CubitVector > &cntrl_pts, DLIList< double > &weights, DLIList< double > &u_knots, DLIList< double > &v_knots) const
virtual CubitStatus uv_derivitives (double u, double v, CubitVector &du, CubitVector &dv)
virtual CubitBoolean is_parametric ()
virtual CubitBoolean get_param_range_U (double &lo, double &hi)
virtual CubitBoolean get_param_range_V (double &lo, double &hi)
virtual CubitBoolean is_position_on (CubitVector &test_position)
virtual CubitPointContainment point_containment (const CubitVector &point)
virtual CubitPointContainment point_containment (double u, double v)
CubitPointContainment point_containment (const CubitVector &point, PartitionCurve *&boundary_curve)
CubitSense get_geometry_sense ()
void reverse_sense ()
void get_parents_virt (DLIList< TopologyBridge * > &)
void get_children_virt (DLIList< TopologyBridge * > &)
int layer () const
GeometryQueryEngineget_geometry_query_engine () const
virtual CubitSense get_shell_sense (ShellSM *shell_ptr) const
void append_simple_attribute_virt (const CubitSimpleAttrib &)
void remove_simple_attribute_virt (const CubitSimpleAttrib &)
void remove_all_simple_attribute_virt ()
CubitStatus get_simple_attribute (DLIList< CubitSimpleAttrib > &)
CubitStatus get_simple_attribute (const CubitString &name, DLIList< CubitSimpleAttrib > &)
void notify_split (FacetEntity *old_tri, FacetEntity *new_tri)
void notify_destroyed (CubitFacetData *facet)
void get_facet_data (DLIList< CubitFacetData * > &result_list) const
void set_facet_data (const DLIList< CubitFacetData * > &new_list)
void replace_facets (DLIList< CubitFacetData * > &dead_facets, DLIList< CubitFacetData * > &new_facets)
bool has_facets () const
void draw_facets (int color) const
CubitStatus init_facet_data ()
virtual void transform (const CubitTransformMatrix &xform)
virtual void print_debug_info (const char *prefix=0, bool print_sub_entity_set=true) const
CubitFacetclosest_facet (const CubitVector &input_position, CubitVector &result_position)
CubitStatus notify_moving_point (CubitPoint *point, const CubitVector &new_pos)
Static Public Member Functions
static PartitionSurfaceconstruct (const CubitSimpleAttrib &attrib, PartitionLump *vol)
Protected Member Functions
void interior_facet_points (DLIList< CubitPoint * > &result_list) const
void update_facet_tool ()
void reverse_loops ()
 PartitionSurface ()
virtual PartitionSurfacecopy ()
CubitStatus get_save_topology (DLIList< int > &curves)
CubitStatus insert_facets (DLIList< PartitionEntity * > points, DLIList< CubitFacetEdgeData * > &boundary_edges, DLIList< CubitFacetData * > &surf_facets)
Protected Attributes
DLIList< CubitFacetData * > facetList
CubitSense geometry_sense
Private Member Functions
 PartitionSurface (PartitionSurface *split_from)
 PartitionSurface (const PartitionSurface &)
Private Attributes
PartitionLoopfirstLoop
PartitionCoSurffirstCoSurf
Detailed Description
Definition at line 31 of file PartitionSurface.hpp.
Definition at line 123 of file PartitionSurface.cpp.
  : geometry_sense(CUBIT_FORWARD), firstLoop(0), firstCoSurf(0)
  lump->sub_entity_set().add_lower_order( this );
Definition at line 129 of file PartitionSurface.cpp.
  while( firstLoop )
    remove( firstLoop );
  while( firstCoSurf )
    PartitionCoSurf* cos = firstCoSurf;
    if( cos->get_shell() )
      cos->get_shell()->remove( cos );
    remove( cos );
    delete cos;
    assert( firstCoSurf != cos );
    // delete facets
  DLIList<CubitPoint*> facet_points(3);
  DLIList<CubitFacetEdge*> facet_edges(3);
  while( facetList.size() )
    CubitFacet* facet = facetList.pop();
    facet_edges.clean_out();
    facet->edges(facet_edges);
    facet_points.clean_out();
    facet->points(facet_points);
    TDVGFacetOwner::remove(facet);
    delete facet;
    PartitionCurve* curve;
    while( facet_edges.size() )
      CubitFacetEdge* edge = facet_edges.pop();
      if( edge && !edge->num_adj_facets() ) {
        if ( TDVGFacetOwner::get(edge) ) {
          curve = dynamic_cast<PartitionCurve*>(TDVGFacetOwner::get(edge));
          curve->remove_facet_data();
        delete edge;
    PartitionPoint* ppoint;
    while( facet_points.size() )
      CubitPoint* point = facet_points.pop();
      if( point && !point->num_adj_facets() ) {
        if ( TDVGFacetOwner::get(point) ) {
          ppoint = dynamic_cast<PartitionPoint*>(TDVGFacetOwner::get(point));
          if( ppoint )
            ppoint->facet_point(0);
        delete point;
Definition at line 903 of file PartitionSurface.cpp.
Member Function Documentation
Definition at line 186 of file PartitionSurface.cpp.
  if( loop->mySurface )
    return CUBIT_FAILURE;
  loop->mySurface = this;
  loop->nextInSurface = firstLoop;
  firstLoop = loop;
  return CUBIT_SUCCESS;
Definition at line 235 of file PartitionSurface.cpp.
  if( cosurf->mySurface )
  cosurf->mySurface = this;
  cosurf->surfaceNext = firstCoSurf;
  firstCoSurf = cosurf;
Implements TopologyBridge.
Definition at line 444 of file PartitionSurface.cpp.
{ sub_entity_set().add_attribute( this, csa ); }
CubitBox PartitionSurface::bounding_box ( void  ) const [virtual]
Implements PartitionEntity.
Definition at line 469 of file PartitionSurface.cpp.
  int i, j;
  CubitFacet* facet;
  for ( i = 0; i< facetList.size(); i++ ) {
    facet = facetList.next(i);
    facet->point(0)->marked(1);
    facet->point(1)->marked(1);
    facet->point(2)->marked(1);
  facet = facetList.get();
  CubitBox result(facet->point(0)->coordinates());
  facet->point(0)->marked(0);
    for ( j = 0; j < 3; j++ ) {
      if ( facet->point(j)->marked() ) {
        facet->point(j)->marked(0);
        result |= facet->point(j)->coordinates();
  return result;
CubitFacet * PartitionSurface::closest_facet ( const CubitVector input_position,
CubitVector result_position
Definition at line 1176 of file PartitionSurface.cpp.
  return PartSurfFacetTool::closest_facet( input_position, facetList, result_position );
CubitStatus PartitionSurface::closest_point ( CubitVector const &  pos,
CubitVector close = 0,
CubitVector norm = 0,
CubitVector curv1 = 0,
CubitVector curv2 = 0
) [virtual]
Implements Surface.
Reimplemented in SubSurface.
Definition at line 546 of file PartitionSurface.cpp.
  if ( closest || normal )
    CubitVector tmp_closest;
    CubitFacet* facet = closest_facet( position, tmp_closest );
    if ( closest )
      *closest = tmp_closest;
    if ( normal )
      *normal = facet->normal();
  if( curvature1 )
    curvature1->set( 0.0, 0.0, 0.0 );
  if( curvature2 )
    curvature2->set( 0.0, 0.0, 0.0 );
CubitStatus PartitionSurface::closest_point_along_vector ( CubitVector from_point,
CubitVector along_vector,
CubitVector point_on_surface
) [virtual]
Implements Surface.
Definition at line 518 of file PartitionSurface.cpp.
void PartitionSurface::closest_point_trimmed ( CubitVector  from,
CubitVector closest
) [virtual]
Implements Surface.
Definition at line 513 of file PartitionSurface.cpp.
  closest_facet( f, r );
CubitStatus PartitionSurface::closest_point_uv_guess ( CubitVector const &  location,
double &  u,
double &  v,
CubitVector closest_location = NULL,
CubitVector unit_normal = NULL
) [virtual]
Implements Surface.
Definition at line 536 of file PartitionSurface.cpp.
  return closest_point(location, closest_location, unit_normal);
Definition at line 955 of file PartitionSurface.cpp.
  for ( int i = other_surf->facetList.size(); i--;  )
    TDVGFacetOwner::set(other_surf->facetList.step_and_get(),this);
  facetList += other_surf->facetList;
  other_surf->facetList.clean_out();
Definition at line 1419 of file PartitionSurface.cpp.
    // construct surface and read attrib data
  PartitionSurface* new_surf = new PartitionSurface;
  DLIList<CubitVector*> facet_points;
  DLIList<int> facets, curve_conn, point_owners;
  vol->sub_entity_set().
    add_lower_order( new_surf, attrib, 2, facet_points, facets, curve_conn, point_owners );
  if( facets.size() % 3 != 0 )
    assert( !(facets.size() % 3 ) );
    delete new_surf;
    return 0;
    // create loops and coedges
  DLIList<PartitionCurve*> curve_list;
  int i = curve_conn.size();
  curve_conn.reset();
  bool okay = true;
  while( okay && i > 0 )
    int k = curve_conn.get_and_step();
    i--;
    if( k <= 0 || i < 2*k )
      { okay = false; break; }
    PartitionLoop* new_loop = new PartitionLoop();
    PartitionCoEdge* prev_coedge = 0;
    new_surf->add( new_loop );
    for( int j = 0; okay && j < k; j++ )
      int set_id = curve_conn.get_and_step();
      int ent_id = curve_conn.get_and_step();
      i -= 2;
      CubitSense sense = CUBIT_FORWARD;
      if( ent_id < 0 )
        sense = CUBIT_REVERSED;
        ent_id = -ent_id;
      PartitionEntity* ent = PartitionEngine::instance()
        .entity_from_id( set_id, ent_id, vol->sub_entity_set() );
      PartitionCurve* curve = dynamic_cast<PartitionCurve*>(ent);
      if( !curve )
      curve_list.append( curve );
      PartitionCoEdge* coedge = new PartitionCoEdge( new_surf, sense );
      new_loop->insert_after( coedge, prev_coedge );
      prev_coedge = coedge;
      curve->add( coedge );
  if( !okay )
    PartitionEngine::instance().destroy_surface( new_surf );
    return 0;
    // construct facet points
  CubitPointData** points = new CubitPointData*[facet_points.size()];
  facet_points.reset();
  point_owners.reset();
  for( i = 0; i < facet_points.size(); i++ )
    CubitVector* pt = facet_points.get_and_step();
    points[i] = new CubitPointData(*pt);
    delete pt;
    int set_id = point_owners.get_and_step();
    int ent_id = point_owners.get_and_step();
    PartitionEntity* owner = PartitionEngine::instance()
    if ( !owner )
      okay = false;
      break;
    if ( owner != new_surf )
      if ( !dynamic_cast<PartitionPoint*>(owner) &&
           !dynamic_cast<PartitionCurve*>(owner) )
        okay = false;
        break;
      TDVGFacetOwner::set(points[i], owner);
  if ( !okay )
    for ( i = 0; i < facet_points.size(); i++ )
      delete points[i];
    delete [] points;
    return 0;
    // construct facets
  facets.reset();
  DLIList<CubitFacetData*> facet_list;
  int junk = 0;
  for( i = 0; i < facets.size(); i += 3 )
    CubitFacetData* facet = new CubitFacetData(
                                    points[facets.next(0)],
                                    points[facets.next(1)],
                                    points[facets.next(2)], &junk );
    facet_list.append(facet);
    facets.step(3);
      // set edge owners to this surface as a kind of mark
      // (will use this a little later)
    for ( int j = 0; j < 3; j++ )
      TDVGFacetOwner::set( facet->edge(j), new_surf );
    // Seam facet points on vertices
    PartitionEntity* ent = TDVGFacetOwner::get(points[i]);
    PartitionPoint* vertex = dynamic_cast<PartitionPoint*>(ent);
    if (!vertex) continue;
    if ( !vertex->facet_point() )
      vertex->facet_point(points[i]);
    else if ( vertex->facet_point() != points[i] )
      vertex->facet_point()->merge_points(points[i]);
      points[i] = vertex->facet_point();
    // done with point list -- delete it
  delete [] points;
    // seam facet edges with curves
  DLIList<CubitFacetEdge*> pt_edges;
  DLIList<CubitFacetEdgeData*> curve_edges;
  while ( curve_list.size() )
    curve_edges.clean_out();
    PartitionCurve* curve = curve_list.pop();
    CubitPoint* pt = curve->start_point()->facet_point();
    if (!pt) {okay = false; break;}
    //For periodic curves, you can easily set up 'curve_edges'
    //in the opposite order.  When finding the first edge, I added
    //the logic in the if(find_correct_direction_on_periodics) block.  It
    //looks at the first facet edge in the curve and finds the appropriate
    //facet edge sharing the same point that has the smallest angle between.
    //This approach assure that we are appending the facet edges to the list
    //'curve_edges' in the same orientation as the facet edges on the curve.
    bool find_correct_direction_on_periodics = false;
    PartitionPoint* start_vtx = curve->start_point();
    PartitionPoint* end_vtx = curve->end_point();
    CubitPointData* start_point = start_vtx->facet_point();
    CubitPointData* end_point = end_vtx->facet_point();
    if( start_vtx == end_vtx && start_point == end_point )
      find_correct_direction_on_periodics = true;
    double smallest_angle = CUBIT_DBL_MAX;
    bool debug = false;
    do {
      if( smallest_angle != CUBIT_DBL_MAX )
      CubitFacetEdge *edge = 0, *pt_edge = 0;
      pt_edges.clean_out();
      pt->edges(pt_edges);
      while ( pt_edges.size() )
        CubitFacetEdge* tmp_edge = pt_edges.pop();
        if ( TDVGFacetOwner::get(tmp_edge) != new_surf )
          continue;
        PartitionEntity* owner = TDVGFacetOwner::get(tmp_edge->other_point(pt));
        if ( owner == curve )
          if( find_correct_direction_on_periodics )
            CubitPoint* start_point = pt;
            curve->get_facet_data(curve_edges);
            curve_edges.reset();
            CubitFacetEdge *first_facet_edge = curve_edges.get();
            CubitPoint *real_next_point = first_facet_edge->other_point(start_point);
            CubitPoint *possible_next_point = tmp_edge->other_point(start_point);
            CubitVector v1 = real_next_point->coordinates() - start_point->coordinates();
            CubitVector v2 = possible_next_point->coordinates() - start_point->coordinates();
            double angle = v1.interior_angle(v2);
            if( angle < smallest_angle )
              smallest_angle = angle;
              edge = tmp_edge;
          else
            edge = tmp_edge;
        else if ( owner == curve->end_point() )
          pt_edge = tmp_edge;
      if ( !edge )
        edge = pt_edge;
      else
        //so we don't traverse backwards
        TDVGFacetOwner::set(edge->other_point(pt), 0);
      CubitFacetEdgeData* edge_d = dynamic_cast<CubitFacetEdgeData*>(edge);
      if (!edge_d)
        okay = false;
        break;
      if( debug )
        pt->debug_draw(4);
        GfxDebug::mouse_xforms();
        edge_d->debug_draw(5);
        edge_d->other_point(pt)->debug_draw(6);
      curve_edges.append(edge_d);
      pt = edge_d->other_point(pt);
    } while (pt != curve->end_point()->facet_point());
    if( !okay || !PartSurfFacetTool::seam_curve( curve_edges, curve, facet_list ) )
      okay = false;
      break;
    // clean up any owner pointers on edges that were being
    // used as a kind of mark
  for ( i = facet_list.size(); i--; )
    CubitFacet* facet = facet_list.get_and_step();
      if ( TDVGFacetOwner::get(facet->edge(j)) == new_surf )
        TDVGFacetOwner::set(facet->edge(j), 0);
    // set surface facets
  new_surf->set_facet_data( facet_list );
  if (!okay)
    return 0;
  return new_surf;
PartitionSurface * PartitionSurface::copy ( ) [protected, virtual]
Definition at line 909 of file PartitionSurface.cpp.
  return new PartitionSurface(this);
void PartitionSurface::draw_facets ( int  color) const
Definition at line 22 of file PartitionSurface.cpp.
  DLIList<CubitFacetData*> facets;
  get_facet_data(facets);
  int i;
  for ( i = facets.size(); i--; ) {
    CubitFacet* facet = facets.step_and_get();
      if ( facet->edge(j) )
        facet->edge(j)->marked(0);
        facet->edge(j)->marked(facet->edge(j)->marked()+1);
    CubitFacetData* facet = facets.step_and_get();
    CubitVector pts[3] = {facet->point(0)->coordinates(),
                          facet->point(1)->coordinates(),
                          facet->point(2)->coordinates()};
      CubitVector p1 = pts[j];
      CubitVector p2 = pts[(j+1)%3];
      int c = color == CUBIT_RED_INDEX ? color - 1 : CUBIT_RED_INDEX;
      CubitFacetEdge* edge = facet->edge((j+2)%3);
      if (!edge) continue;
      switch( edge->marked() ) {
          case 1: c = color + 1; break;
          case 2: c = color; break;
          default : c = color == CUBIT_RED_INDEX ? color - 1 : CUBIT_RED_INDEX;
        if (edge->marked()==1 && !TDVGFacetOwner::get(edge))
          PRINT_WARNING("Boundary edge in surface facetting not owned by a curve.\n");
      GfxDebug::draw_line( (float)p1.x(), (float)p1.y(), (float)p1.z(),
                      (float)p2.x(), (float)p2.y(), (float)p2.z(), c );
    CubitVector center = ( pts[0] + pts[1] + pts[2] ) / 3.0;
    CubitVector normal = (pts[1] - pts[0]) * (pts[2] - pts[0]);
    double len = normal.length();
    if ( len > GEOMETRY_RESABS ) {
        normal /= sqrt(len);
//      if ( len > 1e-2 )
//        normal /= len;
//      else
//        normal.length(1.0);
        GfxDebug::draw_vector( center, center + normal, color );
    } else {
      GfxDebug::draw_point( center, color + 1 );
  GfxDebug::flush();
CubitStatus PartitionSurface::evaluate ( double  u,
double  v,
CubitVector position,
CubitVector normal,
CubitVector curvature1,
CubitVector curvature2
) [virtual]
Implements Surface.
Definition at line 1725 of file PartitionSurface.cpp.
Definition at line 271 of file PartitionSurface.cpp.
  while( cos && cos->get_shell() != shell )
    cos = cos->surfaceNext;
  return cos;
Definition at line 280 of file PartitionSurface.cpp.
  while( cos && (!cos->get_shell() || cos->get_shell()->get_lump() != lump ) )
  return cos;
Definition at line 298 of file PartitionSurface.cpp.
  while( cos && (cos->get_shell() != shell || cos->sense() != sense) )
  return cos;
Definition at line 288 of file PartitionSurface.cpp.
  if( prev->mySurface != this )
    return 0;
  PartitionCoSurf* cos = prev->surfaceNext;
  while( cos && cos->get_shell() != prev->get_shell() )
  return cos;
Reimplemented from Surface.
Definition at line 508 of file PartitionSurface.cpp.
  return FACET_SURFACE_TYPE;
Definition at line 357 of file PartitionSurface.cpp.
  for( PartitionLoop* loop = firstLoop; loop; loop = loop->nextInSurface )
    list.append( loop );
CubitStatus PartitionSurface::get_cone_params ( CubitVector center,
CubitVector normal,
CubitVector major_axis,
double &  radius_ratio,
double &  sine_angle,
double &  cos_angle
) const [virtual]
Implements Surface.
Definition at line 1752 of file PartitionSurface.cpp.
  PRINT_ERROR("Currently, Cubit is unable to determine cone parameters for PartitionSurfaces.\n");
void PartitionSurface::get_facet_data ( DLIList< CubitFacetData * > &  result_list) const
Definition at line 964 of file PartitionSurface.cpp.
  result_list = facetList;
Implements Surface.
Definition at line 880 of file PartitionSurface.cpp.
  return geometry_sense;
CubitStatus PartitionSurface::get_nurb_params ( bool &  rational,
int &  degree_u,
int &  degree_v,
int &  num_cntrl_pts_u,
int &  num_cntrl_pts_v,
DLIList< CubitVector > &  cntrl_pts,
DLIList< double > &  weights,
DLIList< double > &  u_knots,
DLIList< double > &  v_knots
) const [virtual]
Implements Surface.
Definition at line 1778 of file PartitionSurface.cpp.
  PRINT_ERROR("Currently, Cubit is unable to determine nurbs parameters for PartitionSurface.\n");
CubitBoolean PartitionSurface::get_param_range_U ( double &  lo,
double &  hi
) [virtual]
Implements Surface.
Definition at line 637 of file PartitionSurface.cpp.
  return CUBIT_FALSE;
CubitBoolean PartitionSurface::get_param_range_V ( double &  lo,
double &  hi
) [virtual]
Implements Surface.
Definition at line 642 of file PartitionSurface.cpp.
  return CUBIT_FALSE;
void PartitionSurface::get_parents_virt ( DLIList< TopologyBridge * > &  result_list) [virtual]
Definition at line 363 of file PartitionSurface.cpp.
  Surface* real_surf = dynamic_cast<Surface*>(partitioned_entity());
  if( ! real_surf )
    for( PartitionCoSurf* cos = firstCoSurf; cos; cos = cos->surfaceNext )
        result_list.append_unique( cos->get_shell() );
  else
    int i;
    DLIList<TopologyBridge*> real_surf_shells, tmp_list;
    real_surf->get_parents_virt( real_surf_shells );
      // get real volumes from real shells
    DLIList<TopologyBridge*> real_surf_vols(real_surf_shells.size());
    real_surf_shells.reset();
    for( i = real_surf_shells.size(); i--; )
      tmp_list.clean_out();
      real_surf_shells.get_and_step()->get_parents_virt( tmp_list );
      assert(tmp_list.size() == 1);
      real_surf_vols.append(tmp_list.get());
      // replace real volumes with owning partition volumes (if any)
    DLIList<TopologyBridge*> vol_list(real_surf_vols.size());
    real_surf_vols.reset();
    for( i = real_surf_vols.size(); i--; )
      TopologyBridge* vol_bridge = real_surf_vols.get_and_step();
      SubEntitySet* set = dynamic_cast<SubEntitySet*>(vol_bridge->owner());
      if( set )
        set->get_owners(tmp_list);
        vol_list += tmp_list;
      else
        vol_list.append(vol_bridge);
      // for each volume, get all child shells that are parents of this
    vol_list.reset();
    DLIList<TopologyBridge*> vol_shells;
    for( i = vol_list.size(); i--; )
      vol_shells.clean_out();
      vol_list.get_and_step()->get_children( vol_shells, false, layer() );
      vol_shells.reset();
      for( int j = vol_shells.size(); j--; )
        TopologyBridge* shell = vol_shells.get_and_step();
        shell->get_children( tmp_list, false, layer() );
        if( tmp_list.is_in_list(this) )
          result_list.append(shell);
Implements Surface.
Definition at line 525 of file PartitionSurface.cpp.
Definition at line 316 of file PartitionSurface.cpp.
  PartitionLoop* loop = 0;
  while ( (loop = next_loop(loop)) )
    PartitionCoEdge* coedge = loop->first_coedge();
    do
      PartitionCurve* curve = coedge->get_curve();
      list.append( curve->start_point() );
      list.append( curve->end_point() );
      coedge = loop->next_coedge(coedge);
    } while( coedge != loop->first_coedge() );
  list.reset();
  int i;
  for ( i = list.size(); i--; )
    list.get_and_step()->mark = 1;
    list.back();
    if( list.get()->mark )
      list.get()->mark = 0;
    else
      list.change_to(0);
  list.remove_all_with_value(0);
CubitStatus PartitionSurface::get_projected_distance_on_surface ( CubitVector pos1,
CubitVector pos2,
double &  distance
) [virtual]
Implements Surface.
Definition at line 1734 of file PartitionSurface.cpp.
CubitStatus PartitionSurface::get_save_topology ( DLIList< int > &  curves) [protected]
Definition at line 1314 of file PartitionSurface.cpp.
  while( (loop = next_loop(loop)) )
    topo_list.append(loop->num_coedges());
    do
      int set_id, crv_id;
      if( &(curve->sub_entity_set()) == &(sub_entity_set()) )
        set_id = 0;
        crv_id = sub_entity_set().get_id( curve );
      else
        set_id = curve->sub_entity_set().get_unique_id();
        crv_id = curve->sub_entity_set().get_id(curve);
      if( coedge->sense() == CUBIT_REVERSED )
        crv_id *= -1;
      topo_list.append(set_id);
      topo_list.append(crv_id);
    } while( (coedge = loop->next_coedge(coedge)) != loop->first_coedge() );
CubitSense PartitionSurface::get_shell_sense ( ShellSM shell_ptr) const [virtual]
Implements Surface.
Definition at line 426 of file PartitionSurface.cpp.
  if( PartitionShell* pshell = dynamic_cast<PartitionShell*>(shell_ptr) )
    return pshell->find_sense( this );
  if( real_surf )
    DLIList<TopologyBridge*> list(2);
    real_surf->get_parents_virt( list );
    if( list.is_in_list( shell_ptr ) )
      return real_surf->get_shell_sense( shell_ptr );
  return CUBIT_UNKNOWN;
Definition at line 450 of file PartitionSurface.cpp.
  sub_entity_set().get_attributes( this, list );
Definition at line 455 of file PartitionSurface.cpp.
  sub_entity_set().get_attributes( this, name.c_str(), list );
CubitStatus PartitionSurface::get_sphere_params ( CubitVector center,
double &  radius
) const [virtual]
Implements Surface.
Definition at line 1742 of file PartitionSurface.cpp.
  PRINT_ERROR("Currently, Cubit is unable to determine sphere parameters for PartitionSurfaces.\n");
CubitStatus PartitionSurface::get_torus_params ( CubitVector center,
CubitVector normal,
double &  major_radius,
double &  minor_radius
) const [virtual]
Implements Surface.
Definition at line 1766 of file PartitionSurface.cpp.
  PRINT_ERROR("Currently, Cubit is unable to determine torus parameters for PartitionSurface.\n");
bool PartitionSurface::has_facets ( ) const [inline]
Definition at line 239 of file PartitionSurface.hpp.
{ return facetList.size() > 0; }
Definition at line 994 of file PartitionSurface.cpp.
  //assert(are_marks_cleared());
  CubitStatus res = CUBIT_SUCCESS;
  GMem gMem;
  // TODO - tolerance arguments are defaulted.  Do we need to specify?
  res = real_surf->get_geometry_query_engine()->
    get_graphics(real_surf, &gMem, PartitionTool::instance()->get_faceting_tolerance() );
  if( !res )
  // Work around  bug w/ coincident facet points
  // for blend surfaces.  Consolidate coincident points.
  int old_count = gMem.pointListCount;
  gMem.consolidate_points(GEOMETRY_RESABS);
  if( old_count != gMem.pointListCount ) {
    PRINT_WARNING("Possible invalid facetting for surface.  "
                  "Coincident points found.\n");
  DLIList<CubitFacetData*> surf_facets;
  CubitPointData** point_array = new CubitPointData*[gMem.pointListCount];
  // create CubitFacetData from GMem
  int i;
  CubitVector ipos, opos;
  for ( i = 0; i < gMem.pointListCount; i++ ) {
    ipos.set( gMem.point_list()[i].x, gMem.point_list()[i].y, gMem.point_list()[i].z );
    if( real_surf->closest_point( ipos, &opos ) )
      ipos = opos;
    point_array[i] = new CubitPointData( ipos );
  int junk = 0;
  bool fail_out = false;
  CubitPoint *p1, *p2, *p3;
  for ( i = 0; i < gMem.fListCount; i += 4 )
    if(gMem.facet_list()[i] != 3)
      fail_out = true;
    else
      p1 = point_array[ gMem.facet_list()[i+1] ];
      p2 = point_array[ gMem.facet_list()[i+2] ];
      p3 = point_array[ gMem.facet_list()[i+3] ];
      if(p1 == p2 || p1 == p3 || p2 == p3)
        fail_out = true;
    if(fail_out == true)
      PRINT_ERROR("Non-triangular facet encountered.  Aborting.\n");
      while (surf_facets.size())
        delete surf_facets.pop();
      for (i = 0; i < gMem.pointListCount; i++)
        delete point_array[i];
      delete [] point_array;
    else
      CubitFacetData* facet = new CubitFacetData(p1, p2, p3, &junk );
      surf_facets.append(facet);
  if(geometry_sense == CUBIT_REVERSED)
    for(i=surf_facets.size(); i--;)
      surf_facets.get_and_step()->flip();
    // Make sure facet orientation is consistant
  DLIList<CubitFacet*> facets(surf_facets.size());
  for ( i = surf_facets.size(); i--; )
    CubitFacet* facet = surf_facets.step_and_get();
    facet->marked(1);
  bool reversed_some = false;
  while ( facets.size() )
    CubitFacet* facet = facets.pop();
    facet->marked(0);
    bool reversed[3] = {false,false,false};
    CubitFacet* neighbors[3] = {0,0,0};
    for ( i = 0; i < 3; i++ )
      CubitFacetEdge* edge = facet->edge(i);
      CubitFacet* other = edge->other_facet(facet);
      if( other && other != facet )
        neighbors[i] = other;
        int index = other->edge_index(edge);
        if ( facet->edge_use(i) == other->edge_use(index) )
          reversed[i] = true;
    if ( !(reversed[0] || reversed[1] || reversed[2]) )
      continue;
    facet->flip();
    reversed_some = true;
    reversed[0] = !reversed[0];
    reversed[1] = !reversed[1];
    reversed[2] = !reversed[2];
      if( neighbors[i] && reversed[i] && !neighbors[i]->marked() )
        neighbors[i]->marked(1);
        facets.append( neighbors[i] );
  if( reversed_some )
                  "Inconsistent facet orientation.\n");
    // pick a facet and compare to surface normal to see
    // if we have them all backwards
  surf_facets.reset();
  CubitFacet* facet = surf_facets.get();
  CubitVector pts[3] = { facet->point(0)->coordinates(),
  CubitVector facet_norm = (pts[1] - pts[0]) * (pts[2] - pts[0]);
  CubitVector facet_cent = (pts[0] + pts[1] + pts[2]) / 3.0;
  CubitVector surf_norm;
  real_surf->closest_point( facet_cent, 0, &surf_norm );
  if ( facet_norm % surf_norm < 0 )
                  "Backwards facets.\n");
      surf_facets.step_and_get()->flip();
  PartSurfFacetTool tool(this);
  return tool.init_facet_data(surf_facets);
CubitStatus PartitionSurface::insert_facets ( DLIList< PartitionEntity * >  points,
DLIList< CubitFacetEdgeData * > &  boundary_edges,
DLIList< CubitFacetData * > &  surf_facets
) [protected]
void PartitionSurface::interior_facet_points ( DLIList< CubitPoint * > &  result_list) const [protected]
Definition at line 1347 of file PartitionSurface.cpp.
  DLIList<CubitPoint*> point_list(facetList.size() * 3);
  DLIList<CubitFacetEdge*> edge_list;
  int i;
  for( i = 0; i < facetList.size(); i++ )
    CubitFacetData* facet = facetList.next(i);
    for( int j = 0; j < 3; j++ )
      CubitPoint* pt = facet->point(j);
      if( TDVGFacetOwner::get(pt) )
        continue;  // not interior - on a vertex
      edge_list.clean_out();
      pt->edges( edge_list );
      bool skip = false;
      for( int k = edge_list.size(); k--; )
        if( TDVGFacetOwner::get(edge_list.step_and_get()) )
          skip = true; // not interior - on a curve
      if( !skip )
        point_list.append(pt);
    // uniquify list
  for( i = point_list.size(); i--; )
    point_list.step_and_get()->marked(1);
    if( point_list.step_and_get()->marked() )
      point_list.get()->marked(0);
    else
      point_list.change_to(0);
  point_list.remove_all_with_value(0);
  list = point_list;
Definition at line 615 of file PartitionSurface.cpp.
  return CUBIT_FALSE;
Definition at line 620 of file PartitionSurface.cpp.
  return  CUBIT_FALSE;
Implements Surface.
Definition at line 632 of file PartitionSurface.cpp.
  return CUBIT_FALSE;
Implements Surface.
Definition at line 590 of file PartitionSurface.cpp.
  return CUBIT_FALSE;
CubitBoolean PartitionSurface::is_periodic_in_U ( double &  period) [virtual]
Implements Surface.
Definition at line 595 of file PartitionSurface.cpp.
  return  CUBIT_FALSE;
CubitBoolean PartitionSurface::is_periodic_in_V ( double &  period) [virtual]
Implements Surface.
Definition at line 600 of file PartitionSurface.cpp.
  return CUBIT_FALSE;
Implements Surface.
Definition at line 647 of file PartitionSurface.cpp.
  const double tolsqr = GEOMETRY_RESABS * GEOMETRY_RESABS;
  CubitVector closest;
  closest_facet( position, closest );
  double distsqr = (position - closest).length_squared();
  return (CubitBoolean)(distsqr < tolsqr);
CubitBoolean PartitionSurface::is_singular_in_U ( double  u_param) [virtual]
Implements Surface.
Definition at line 605 of file PartitionSurface.cpp.
  return CUBIT_FALSE;
CubitBoolean PartitionSurface::is_singular_in_V ( double  v_param) [virtual]
Implements Surface.
Definition at line 610 of file PartitionSurface.cpp.
  return  CUBIT_FALSE;
int PartitionSurface::layer ( ) const [inline, virtual]
Reimplemented from TopologyBridge.
Definition at line 221 of file PartitionSurface.hpp.
double PartitionSurface::measure ( ) [virtual]
Implements GeometryEntity.
Definition at line 500 of file PartitionSurface.cpp.
  double result = 0.;
  for ( int i = facetList.size(); i--; )
    result += facetList.step_and_get()->area();
  return result;
Reimplemented from PartitionEntity.
Definition at line 530 of file PartitionSurface.cpp.
  const CubitVector copy(pos);
  return closest_point( copy, &pos );
PartitionCoSurf * PartitionSurface::next_co_surface ( const PartitionCoSurf prev = 0) const [inline]
Definition at line 302 of file PartitionSurface.hpp.
  return !prev                   ? firstCoSurf       :
         prev->mySurface == this ? prev->surfaceNext :
                                   0;
PartitionLoop * PartitionSurface::next_loop ( const PartitionLoop prev = 0) const [inline]
Definition at line 294 of file PartitionSurface.hpp.
  return !prev                   ? firstLoop           :
         prev->mySurface == this ? prev->nextInSurface :
                                   0;
Definition at line 1717 of file PartitionSurface.cpp.
  facetList.move_to(facet);
  assert(facetList.size() && facetList.get() == facet);
  facetList.extract();
Definition at line 1704 of file PartitionSurface.cpp.
  DLIList<CubitFacetData*> old_facets, new_facets;
  if (!PartSurfFacetTool::fix_move_point(point, new_pos, facetList, old_facets, new_facets, this))
  assert( !old_facets.size() == !new_facets.size() );
  if (old_facets.size())
    replace_facets( old_facets, new_facets );
void PartitionSurface::notify_split ( FacetEntity old_tri,
FacetEntity new_tri
) [virtual]
Definition at line 980 of file PartitionSurface.cpp.
  if ( dynamic_cast<CubitFacetEdge*>(old_tri) )
    return;
  CubitFacetData* new_ptr = dynamic_cast<CubitFacetData*>(new_tri);
#ifndef NDEBUG
  CubitFacetData* old_ptr = dynamic_cast<CubitFacetData*>(old_tri);
  assert(old_ptr && new_ptr && facetList.is_in_list(old_ptr));
#endif
  TDVGFacetOwner::set(new_ptr,this);
  facetList.append(new_ptr);
Definition at line 227 of file PartitionSurface.cpp.
  int count = 0;
    count++;
  return count;
Implements Surface.
Definition at line 656 of file PartitionSurface.cpp.
  PartitionCurve* curve = 0;
  CubitPointContainment result = point_containment( point, curve );
  if ( curve ) {
    CubitVector curve_closest;
    curve->closest_point( point, curve_closest );
    if ( (point - curve_closest).length_squared() < GEOMETRY_RESABS*GEOMETRY_RESABS )
      result = CUBIT_PNT_BOUNDARY;
  return result;
CubitPointContainment PartitionSurface::point_containment ( double  u,
double  v
) [virtual]
Implements Surface.
Definition at line 869 of file PartitionSurface.cpp.
  return CUBIT_PNT_UNKNOWN;
Definition at line 669 of file PartitionSurface.cpp.
  CubitVector facet_pos;
  CubitFacet* facet = closest_facet(point, facet_pos);
  int i;
  double tol = 10*GEOMETRY_RESABS;
  int closest_edge = -1;
  CubitPoint* closest_point = 0;
  double closest_dist_sqr = CUBIT_DBL_MAX;
  CubitVector closest_pos;
  CubitFacetEdge* edge;
    // Find closest edge/point on facet
    CubitVector start = edge->point(0)->coordinates();
    CubitVector end   = edge->point(1)->coordinates();
    CubitVector dir = end - start;
    double len_sqr = dir.length_squared();
    double t = (dir % (point - start)) / len_sqr;
    double len = sqrt(len_sqr);
    double dist_from_start = t * len;
    double dist_from_end   = (1.0 - t) * len;
    CubitPoint* facet_point = 0;
    CubitVector pos;
    if ( dist_from_start < tol )
      pos = start;
      facet_point = edge->point(0);
    else if( dist_from_end < tol )
      pos = end;
      facet_point = edge->point(1);
    else
      pos = t * dir + start;
    double dist_sqr = (pos - point).length_squared();
    if ( dist_sqr < closest_dist_sqr )
      closest_edge = i;
      closest_point = facet_point;
      closest_dist_sqr = dist_sqr;
      closest_pos = pos;
  edge = facet->edge(closest_edge);
    // If closest to an edge (not a point) ...
  if ( !closest_point )
      // If the edge is not on the boundary of the surface facets...
    if ( !curve || curve->is_nonmanifold(this) )
      return CUBIT_PNT_INSIDE;  // not a boundary edge
      // If within tolerance of boundary
    if ( (point - closest_pos).length_squared() < tol*tol )
      return CUBIT_PNT_BOUNDARY;
      // Check which side of the edge the point is on
    CubitVector dir = edge->point(1)->coordinates() - edge->point(0)->coordinates();
    if ( facet->edge_use(closest_edge) == -1 )
      dir = -dir;
    double dot = facet->normal() % ((closest_pos - point) * dir);
    if ( dot < 0.0 )
      return CUBIT_PNT_OUTSIDE;
    else
    // Get two boundary edges adjacent to point
  closest_point->edges( edge_list );
  for ( i = edge_list.size(); i--; )
    edge = edge_list.step_and_get();
    if ( !curve || !curve->is_in_surface(this,true) )
      edge_list.change_to(0);
  edge_list.remove_all_with_value(0);
  if (!edge_list.size())
  if (edge_list.size() > 2)
    // This is a special case.  The point was closest to an
    // intersection of more than two curves on the surface boundary
    // (for example the point where a circular hole is tangent to
    //  the boundary of the surface.).  If the input position is closest
    //  to such a point it must be outside the surface (or on the boundary).
    // However, a little work is required to decide which curve to pass back.
    while (edge_list.size())
      PartitionEntity* owner = TDVGFacetOwner::get(edge_list.pop());
      curve_list.append_unique( dynamic_cast<PartitionCurve*>(owner) );
    assert( !! TDVGFacetOwner::get(closest_point) );
    curve = 0;
    while (curve_list.size())
      PartitionCurve* temp_curve = curve_list.pop();
      temp_curve->closest_point( point, closest_pos );
      if ( (point - closest_pos).length_squared() < closest_dist_sqr )
        curve = temp_curve;
        closest_dist_sqr = (point - closest_pos).length_squared();
    if ( (point - closest_point->coordinates()).length_squared() < tol*tol )
    else
  assert(edge_list.size() == 2);
  CubitFacetEdge *bdy_edges[2] = {edge_list.get(), edge_list.next()};
    // need to pass back a curve
  curve = dynamic_cast<PartitionCurve*>(TDVGFacetOwner::get(bdy_edges[0]));
    // Fill arrays for each of two boundary edges
  CubitFacet* bdy_facets[2] = {0,0};      // adjacent facet
  bool inside_facets[2] = {false,false};  // inside/outside of facet
  CubitPoint* start_pts[2], *end_pts[2];  // edge points
  for ( int j = 0; j < 2; j++ )
    for ( i = 0; i < bdy_edges[j]->num_adj_facets(); i++ )
      CubitFacet* facet = bdy_edges[j]->adj_facet(i);
      if ( TDVGFacetOwner::get(facet) == this )
        bdy_facets[j] = facet;
        break;
    assert(!!bdy_facets[j]);
    int index = bdy_facets[j]->edge_index(bdy_edges[j]);
    if ( bdy_facets[j]->edge_use(index) < 0 ) {
      start_pts[j] = bdy_edges[j]->point(1);
      end_pts[j] = bdy_edges[j]->point(0);
    } else {
      start_pts[j] = bdy_edges[j]->point(0);
      end_pts[j] = bdy_edges[j]->point(1);
    CubitVector dir = end_pts[j]->coordinates() - start_pts[j]->coordinates();
    inside_facets[j] = dot > 0.0;
    // mean normal for facets
  CubitVector normal = bdy_facets[0]->normal();
  normal += bdy_facets[1]->normal();
    // cross product of edge vectors
    // if we had edges in wrong order, need to reverse
    // crossproduct
  CubitVector cross;
  CubitVector dir1 = end_pts[0]->coordinates() - start_pts[0]->coordinates();
  CubitVector dir2 = end_pts[1]->coordinates() - start_pts[1]->coordinates();
  if ( end_pts[0] == closest_point && start_pts[1] == closest_point )
    cross = dir1 * dir2;
  else
    assert( start_pts[0] == closest_point && end_pts[1] == closest_point );
    cross = dir2 * dir1;
  bool convex = (cross % normal) > 0.0;
  if ( convex )
    return inside_facets[0] && inside_facets[1] ? CUBIT_PNT_INSIDE : CUBIT_PNT_OUTSIDE;
  else
    return inside_facets[0] || inside_facets[1] ? CUBIT_PNT_INSIDE : CUBIT_PNT_OUTSIDE;
CubitVector PartitionSurface::position_from_u_v ( double  u,
double  v
) [virtual]
Implements Surface.
Definition at line 578 of file PartitionSurface.cpp.
  return CubitVector(0.0,0.0,0.0);
CubitStatus PartitionSurface::principal_curvatures ( CubitVector const &  loc,
double &  curv1,
double &  curv2,
CubitVector closest_location = 0
) [virtual]
Implements Surface.
Definition at line 570 of file PartitionSurface.cpp.
void PartitionSurface::print_debug_info ( const char *  prefix = 0,
bool  print_sub_entity_set = true
) const [virtual]
Definition at line 93 of file PartitionSurface.cpp.
  if( !prefix ) prefix = "";
  PRINT_INFO("%sPartitionSurface %p\n", prefix, (void*)this );
    PRINT_INFO("%s  Loop %p:\n", prefix, (void*)loop );
    do
      PRINT_INFO("%s    CoEdge %p %s -> Curve %p\n",
        prefix, (void*)coedge, coedge->sense() == CUBIT_FORWARD ? "FORWARD" :
                        coedge->sense() == CUBIT_REVERSED ? "REVERSE" :
                        "UNKNOWN", (void*)coedge->get_curve() );
  char buffer[128];
  sprintf(buffer,"%s  ",prefix);
  if( print_sub_entity_set )
    sub_entity_set().print_debug_info(buffer);
Definition at line 198 of file PartitionSurface.cpp.
  if( loop->mySurface != this )
  if( firstLoop == loop )
    firstLoop = loop->nextInSurface;
  else
    PartitionLoop* prev = firstLoop;
    while( prev && prev->nextInSurface != loop )
      prev = prev->nextInSurface;
    if( !prev )
      assert(0);
    prev->nextInSurface = loop->nextInSurface;
  loop->mySurface = 0;
  loop->nextInSurface = 0;
Definition at line 246 of file PartitionSurface.cpp.
  if( cosurf->mySurface != this )
  if( cosurf == firstCoSurf )
    firstCoSurf = cosurf->surfaceNext;
  else
    PartitionCoSurf* prev = firstCoSurf;
    while( prev && prev->surfaceNext != cosurf )
      prev = prev->surfaceNext;
    if( !prev ) { assert(prev != NULL); return CUBIT_FAILURE; }
    prev->surfaceNext = cosurf->surfaceNext;
  cosurf->mySurface = 0;
  cosurf->surfaceNext = 0;
Definition at line 448 of file PartitionSurface.cpp.
Definition at line 446 of file PartitionSurface.cpp.
{ sub_entity_set().rem_attribute( this, csa ); }
void PartitionSurface::replace_facets ( DLIList< CubitFacetData * > &  dead_facets,
DLIList< CubitFacetData * > &  new_facets
Definition at line 1151 of file PartitionSurface.cpp.
  int i;
  facetList -= dead_facets;
  facetList += new_facets;
  for( i = dead_facets.size(); i--; )
    TDVGFacetOwner::remove( dead_facets.step_and_get() );
  for( i = new_facets.size(); i--; )
    TDVGFacetOwner::set( new_facets.step_and_get(), this );
  // TODO - memory management - where should the facets get deleted
void PartitionSurface::reverse_loops ( ) [protected]
Definition at line 462 of file PartitionSurface.cpp.
    loop->reverse();
void PartitionSurface::reverse_sense ( ) [virtual]
Definition at line 885 of file PartitionSurface.cpp.
  reverse_loops();
  if( owner() )
    owner()->notify_reversed(this);
  if(geometry_sense == CUBIT_FORWARD)
    geometry_sense = CUBIT_REVERSED;
  else
    geometry_sense = CUBIT_FORWARD;
  int j;
  this->get_facet_data( surf_facets );
  for(j=surf_facets.size(); j--;)
Definition at line 1192 of file PartitionSurface.cpp.
  assert(dynamic_cast<Lump*>(partitioned_entity()) != 0);
  int i;
  int id = sub_entity_set().get_id(this);
  if( id <= 0 ) return CUBIT_FAILURE;
    // get facets
  get_facet_data( facets );
    // get list of points from facets
  DLIList<CubitPoint*> points(facets.size()*3), facet_points(3);
  facets.reset();
  for( i = facets.size(); i--; )
    facets.get_and_step()->points(facet_points);
    points += facet_points;
  for( i = points.size(); i--; )
    points.step_and_get()->marked(0);
    CubitPoint* pt = points.step_and_get();
    pt->marked(pt->marked()+1);
  points.last();
    if( points.get()->marked() > 1 )
      points.get()->marked( points.get()->marked() - 1 );
      points.change_to(0);
    points.back();
  points.remove_all_with_value(0);
    // construct position list
  DLIList<CubitVector*> pt_list(points.size());
  points.reset();
  for( i = 0; i < points.size(); i++ )
    CubitPoint* pt = points.get_and_step();
    pt_list.append( new CubitVector(pt->coordinates()) );
    pt->marked(i);
    // connect facet connectivity list
  DLIList<int> facetlist( facets.size() * 3 );
  facets.reset();
    for( int j = facet_points.size(); j--; )
      facetlist.append( facet_points.get_and_step()->marked() );
  DLIList<int> facet_point_owners;
  points.reset();
  for ( i = points.size(); i--; )
    PartitionEntity* owner = TDVGFacetOwner::get(pt);
    if (!owner)
        CubitFacetEdge* edge = pt_edges.pop();
        PartitionEntity* tmp = TDVGFacetOwner::get(edge);
        if ( tmp )
          assert(!owner || owner == tmp);
          owner = tmp;
    if ( !owner )
      owner = this;
    int set_id, ent_id;
    if( &(owner->sub_entity_set()) == &(sub_entity_set()) )
      set_id = 0;
      ent_id = sub_entity_set().get_id( owner );
    else
      set_id = owner->sub_entity_set().get_unique_id();
      ent_id = owner->sub_entity_set().get_id(owner);
    facet_point_owners.append( set_id );
    facet_point_owners.append( ent_id );
    // clean up point marks
  DLIList<int> topo_list;
  get_save_topology( topo_list );
  return sub_entity_set().save_geometry( id, 2, &pt_list, &facetlist, &topo_list,
                                         &facet_point_owners, attrib );
void PartitionSurface::set_facet_data ( const DLIList< CubitFacetData * > &  new_list)
Definition at line 969 of file PartitionSurface.cpp.
  int i;
  for ( i = facetList.size(); i--; )
    TDVGFacetOwner::remove(facetList.step_and_get());
  facetList = new_list;
    TDVGFacetOwner::set(facetList.step_and_get(),this);
Definition at line 914 of file PartitionSurface.cpp.
  int i;
  bool okay = true;
    // mark facets
    facets.get_and_step()->marked(0);
  for( i = facetList.size(); i--; )
    facetList.get_and_step()->marked(1);
    // make sure all facets in passed list are in my list,
    // and clear the marks
  for( i = facets.size(); i--; ) {
    CubitFacetData* facet = facets.get_and_step();
    if( facet->marked() )
      facet->marked(0);
    else
      okay = false;
  if (!okay) {
      facetList.get_and_step()->marked(0);
    assert(okay);
    return 0;
  for( i = facetList.size(); i--; ) {
    if( facetList.step_and_get()->marked() )
      facetList.get()->marked(0);
    else
      facetList.change_to(0);
  facetList.remove_all_with_value(0);
  PartitionSurface* result = copy();
  result->set_facet_data(facets);
  return result;
void PartitionSurface::transform ( const CubitTransformMatrix xform) [virtual]
Definition at line 1387 of file PartitionSurface.cpp.
  int i;
  DLIList<CubitPoint*> points;
  interior_facet_points(points);
  for(i = points.size(); i--; )
    pt->set( xform * pt->coordinates() );
  double det = xform.sub_matrix( 3, 3 ).determinant();
  if (det < 0.0)
    for (i = 0; i < facetList.size(); i++)
      facetList.next(i)->flip();
    while ((loop = next_loop(loop)))
      loop->reverse();
  for (i = 0; i < facetList.size(); i++ )
    facetList.next(i)->update_plane();
CubitStatus PartitionSurface::u_v_from_position ( CubitVector const &  location,
double &  u,
double &  v,
) [virtual]
Implements Surface.
Definition at line 583 of file PartitionSurface.cpp.
CubitStatus PartitionSurface::uv_derivitives ( double  u,
double  v,
CubitVector du,
CubitVector dv
) [virtual]
Implements Surface.
Definition at line 625 of file PartitionSurface.cpp.
Member Data Documentation
Definition at line 278 of file PartitionSurface.hpp.
Definition at line 287 of file PartitionSurface.hpp.
Definition at line 279 of file PartitionSurface.hpp.
