cgma
PartitionEngine Class Reference
#include <PartitionEngine.hpp>
Inheritance diagram for PartitionEngine:
IntermediateGeomEngine
List of all members.
Public Member Functions
bool is_partition (TBOwner *bridge_owner)
bool is_composite (TBOwner *bridge_owner)
bool is_composite (TopologyBridge *bridge)
virtual void remove_imprint_attributes_after_modify (DLIList< BodySM * > &old_sms, DLIList< BodySM * > &new_sms)
virtual void push_imprint_attributes_before_modify (DLIList< BodySM * > &body_sms)
virtual void push_named_attributes_to_curves_and_points (DLIList< TopologyBridge * > &tb_list, const char *name_in)
virtual void attribute_after_imprinting (DLIList< TopologyBridge * > &tb_list, DLIList< Body * > &old_bodies)
virtual void remove_attributes_from_unmodifed_virtual (DLIList< TopologyBridge * > &bridges)
virtual ~PartitionEngine ()
int level () const
void notify_deactivated (PartitionBody *body)
void notify_deactivated (PartitionLump *vol)
void notify_deactivated (PartitionSurface *surface)
void notify_deactivated (PartitionCurve *curve)
void notify_deactivated (PartitionPoint *point)
void add_to_deactivated_list (PartitionBody *body)
void add_to_deactivated_list (PartitionLump *vol)
void add_to_deactivated_list (PartitionSurface *sur)
void add_to_deactivated_list (PartitionCurve *cur)
void add_to_deactivated_list (PartitionPoint *pt)
CubitStatus import_geometry (DLIList< TopologyBridge * > &imported_geometry)
CubitStatus export_geometry (DLIList< TopologyBridge * > &geometry_to_save)
TBPointinsert_point (Curve *curve, double u)
Curveremove_point (PartitionPoint *point, PartitionCurve *dead_curves[2]=0)
Surfaceinsert_curve (Surface *surface, DLIList< CubitVector * > &segment_points, DLIList< Curve * > &new_curves, const double *tolerance_length=NULL)
CubitStatus insert_curve (DLIList< Surface * > &surfaces, DLIList< CubitVector * > &polyline, DLIList< Surface * > &new_surfaces, DLIList< Curve * > &polyline_curves, const double *tolerance_length=NULL, DLIList< Surface * > *surfs_to_reverse=NULL)
TBPointinsert_point_curve (Surface *surf, const CubitVector &position, Surface *&partitioned_surf)
Lumpinsert_surface (Surface *surf_to_copy, Lump *lump)
Surfaceinsert_surface (DLIList< CubitFacet * > &facets, Lump *lump)
Surfaceremove_curve (PartitionCurve *curve, PartitionSurface *dead_surfs[2]=0)
Lumpremove_surface (PartitionSurface *surface)
int layer ()
CubitStatus add_to_id_map (SubEntitySet *set, int unique_id)
CubitStatus remove_from_id_map (SubEntitySet *set, int unique_id)
SubEntitySetget_from_id_map (int unique_id)
PartitionEntityentity_from_id (int set_id, int geom_id, SubEntitySet &default_set)
CubitStatus destroy_surface (PartitionSurface *surface)
CubitStatus destroy_lump (PartitionLump *lump)
CubitStatus delete_solid_model_entities (PartitionBody *body, BodySM *&real_body)
CubitStatus delete_solid_model_entities (PartitionSurface *surface, Surface *&real_surface)
CubitStatus delete_solid_model_entities (PartitionCurve *curve, Curve *&real_curve)
void clean_out_deactivated_geometry ()
CubitStatus translate (PartitionBody *ent, const CubitVector &delta)
CubitStatus rotate (PartitionBody *ent, const CubitVector &axis, double degrees)
CubitStatus scale (PartitionBody *ent, const CubitVector &factors)
CubitStatus reflect (PartitionBody *ent, const CubitVector &axis)
CubitStatus restore_transform (PartitionBody *ent)
CubitStatus translate (PartitionEntity *ent, const CubitVector &delta)
CubitStatus rotate (PartitionEntity *ent, const CubitVector &axis, double degrees)
CubitStatus scale (PartitionEntity *ent, const CubitVector &factors)
CubitStatus reflect (PartitionEntity *ent, const CubitVector &axis)
CubitStatus notify_transform (TopologyBridge *bridge, const CubitTransformMatrix &xform)
void remove_attributes (DLIList< TopologyBridge * > &bridge_list)
virtual void remove_modified (DLIList< Surface * > &all_surfs, DLIList< Curve * > &all_curves, DLIList< TBPoint * > &all_pts)
void get_tbs_with_bridge_manager_as_owner (TopologyBridge *source_bridge, DLIList< TopologyBridge * > &tbs)
SubSurfacereplace_surface (Surface *surface)
Static Public Member Functions
static PartitionEngineinstance ()
static void delete_instance ()
static void delete_facet (CubitFacet *)
static void curves_from_surfaces (const DLIList< PartitionSurface * > &input_surfs, DLIList< PartitionCurve * > &output_curves)
Private Member Functions
CubitStatus notify_transform_internal (TopologyBridge *bridge, const CubitTransformMatrix &xform)
 PartitionEngine ()
CubitStatus find_coedges (PartitionSurface *surface, PartitionCurve *curve, PartitionPoint *point, PartitionCoEdge *&previous, PartitionCoEdge *&next)
PartitionCurvenext_curve_around_point (PartitionSurface *const surface, CubitFacetEdgeData *const edge, CubitPointData *const point, const bool backwards)
CubitStatus remove_point_curve (PartitionPoint *point)
PartitionPointinsert_point_curve (PartitionSurface *surface, CubitPointData *point)
CubitStatus insert_point_curve (PartitionSurface *surface, PartPTCurve *curve, bool update_topology=true)
PartitionCurveinsert_point (PartitionCurve *curve, PartitionPoint *point)
CubitStatus insert_curve (DLIList< PartitionSurface * > &surfaces, DLIList< CubitVector * > &polyline, DLIList< PartitionSurface * > &new_surfaces, DLIList< PartitionCurve * > &polyline_curves, const double *tolerance_length=NULL)
PartitionSurfaceinsert_curve (PartitionSurface *surface, SegmentedCurve *curve)
SegmentedCurveinsert_curve (DLIList< CubitFacetEdgeData * > &facet_edges, DLIList< CubitVector * > *curve_segments=0)
CubitPointDataproject_to_surface (PartitionSurface *surface, const CubitVector &position)
CubitStatus project_to_surface (DLIList< CubitFacetData * > &facets, DLIList< CubitVector * > &polyline_in, DLIList< CubitFacetEdgeData * > &polyline_out, DLIList< CubitPointData * > &polyline_pts, const double *tolerance_length=NULL)
PartitionLumpinsert_surface (PartitionLump *lump, PartitionSurface *surf)
PartitionBodymake_body (PartitionPoint *pt)
PartitionBodymake_body (PartitionCurve *curve)
PartitionBodymake_body (PartitionSurface *surf)
PartitionBodymake_body (PartitionLump *lump)
PartitionBodymake_body_internal (TopologyBridge *child_ptr)
PartitionLumpreplace_lump (Lump *lump)
Lumprestore_lump (PartitionLump *lump)
CubitStatus destroy_shell (PartitionShell *shell)
Surfacerestore_surface (SubSurface *surface)
SubCurvereplace_curve (Curve *curve)
Curverestore_curve (SubCurve *curve)
PartitionPointreplace_point (TBPoint *point)
TBPointrestore_point (PartitionPoint *point)
PartitionSurfacesplit_surface (PartitionSurface *surface, PartitionCoEdge *new_curve)
PartitionLumpsplit_lump (PartitionShell *shell)
PartitionShellsplit_shell (PartitionShell *shell)
void insert_nonmanifold_surfaces (DLIList< PartitionSurface * > &surfaces, PartitionShell *shell1, PartitionShell *shell2)
CubitStatus inside_shell (PartitionShell *const shell, PartitionSurface *const surf, bool &result)
CubitStatus save_curves (SubEntitySet *curve_set)
CubitStatus save_surfaces (SubEntitySet *surface_set)
CubitStatus save_lumps (SubEntitySet *lump_set)
CubitStatus restore_from_attrib (Curve *partitioned_curve)
CubitStatus restore_from_attrib (Surface *partitioned_surface)
CubitStatus restore_from_attrib (Lump *partitioned_lump)
Private Attributes
std::map< int, SubEntitySet * > uniqueIdMap
DLIList< TopologyBridge * > deactivatedList
Static Private Attributes
static PartitionEngineinstance_ = NULL
Friends
class PartitionLumpImprint
Detailed Description
Definition at line 62 of file PartitionEngine.hpp.
Definition at line 75 of file PartitionEngine.cpp.
  GeometryQueryTool::instance()->unregister_intermediate_engine(this);
Definition at line 99 of file PartitionEngine.cpp.
  CubitStatus r = GeometryQueryTool::instance()->register_intermediate_engine(this);
  assert(r == CUBIT_SUCCESS);
  if (CUBIT_SUCCESS != r) {
    PRINT_ERROR("Failed to register intermediate engine.\n");
Member Function Documentation
Definition at line 6327 of file PartitionEngine.cpp.
Definition at line 6324 of file PartitionEngine.cpp.
Definition at line 6333 of file PartitionEngine.cpp.
Definition at line 6339 of file PartitionEngine.cpp.
Definition at line 6345 of file PartitionEngine.cpp.
Add SubEntitySet to ID map (used for save/restore
Definition at line 137 of file PartitionEngine.cpp.
  if( uniqueIdMap.find(unique_id) != uniqueIdMap.end() )
    { assert(0); return CUBIT_FAILURE; }
  uniqueIdMap[unique_id] = set;
  return CUBIT_SUCCESS;
virtual void PartitionEngine::attribute_after_imprinting ( DLIList< TopologyBridge * > &  tb_list,
DLIList< Body * > &  old_bodies
) [inline, virtual]
Implements IntermediateGeomEngine.
Definition at line 76 of file PartitionEngine.hpp.
Definition at line 6348 of file PartitionEngine.cpp.
void PartitionEngine::curves_from_surfaces ( const DLIList< PartitionSurface * > &  input_surfs,
DLIList< PartitionCurve * > &  output_curves
) [static]
Definition at line 2165 of file PartitionEngine.cpp.
  int i;
  for (i = curves.size(); i--; )
    curves.step_and_get()->mark = 1;
  for (i = surfs.size(); i--; )
    PartitionSurface* surf = surfs.next(i);
    PartitionLoop* loop = 0;
    while ( (loop = surf->next_loop(loop)) )
      PartitionCoEdge* coedge = loop->first_coedge();
      do {
        PartitionCurve* curve = coedge->get_curve();
        if (!curve->mark)
          curve->mark = 1;
          curves.append(curve);
        coedge = loop->next_coedge(coedge);
      } while (coedge != loop->first_coedge());
  for ( i = curves.size(); i--; )
    curves.step_and_get()->mark = 0;
  curves.reset();
void PartitionEngine::delete_facet ( CubitFacet p_dead) [static]
Definition at line 2921 of file PartitionEngine.cpp.
assert(!TDVGFacetOwner::get(p_dead));
assert(dynamic_cast<CubitFacetData*>(p_dead) != NULL);
  CubitFacetEdge* edges[3] = {p_dead->edge(0), p_dead->edge(1), p_dead->edge(2)};
  CubitPoint* pts[3] = {p_dead->point(0), p_dead->point(1), p_dead->point(2)};
  int k;
  for( k = 0; k < 3; k++ )
    if( pts[k] )
      pts[k]->remove_facet( p_dead );
      CubitFacetData *facet_data = static_cast<CubitFacetData*>(p_dead);
      facet_data->set_point( NULL, k);
      if( !pts[k]->num_adj_facets() )
        delete pts[k];
    if( edges[k] )
      edges[k]->remove_facet(p_dead);
      p_dead->edge(NULL, k);
      if(!edges[k]->num_adj_facets())
        delete edges[k];
  delete p_dead;
Definition at line 80 of file PartitionEngine.cpp.
  if( NULL != instance_ )
    delete instance_;
    instance_ = NULL;
Definition at line 5997 of file PartitionEngine.cpp.
  real_body = body->real_body();
  body->destroy_all_children();
Definition at line 6005 of file PartitionEngine.cpp.
  DLIList<TopologyBridge*> parents(0);
  surf->get_parents_virt(parents);
  if ( parents.size() )
  real_surf = 0;
  if ( !surf->sub_entity_set().has_multiple_sub_entities() )
    real_surf = dynamic_cast<Surface*>(surf->partitioned_entity());
  destroy_surface(surf);
Definition at line 6021 of file PartitionEngine.cpp.
  if( curve->next_coedge(0) )
  real_curve = 0;
  if ( !curve->sub_entity_set().has_multiple_sub_entities() )
    real_curve = dynamic_cast<Curve*>(curve->partitioned_entity());
  PartitionPoint* start = curve->start_point();
  PartitionPoint* end = curve->end_point();
  delete curve;
  if ( start->num_curves() == 0 )
    delete start;
  if ( end->num_curves() == 0 )
    delete end;
Destroy a lump and child topology.
Destroy the passed lump and any child topology used only by the passed lump.
Definition at line 677 of file PartitionEngine.cpp.
    /* only partition lump? */
  if ( ! lump->sub_entity_set().has_multiple_sub_entities() )
    DLIList<PartitionEntity*> child_entities;
    lump->sub_entity_set().get_lower_order( child_entities );
    DLIList<PartitionSurface*> surf_list;
    CAST_LIST( child_entities, surf_list, PartitionSurface );
    while( surf_list.size() )
      if( ! remove_surface( surf_list.pop() ) )
    return restore_lump(lump) ? CUBIT_SUCCESS : CUBIT_FAILURE;
  PartitionShell* shell;
  while ( (shell = lump->next_shell(0)) )
    lump->remove(shell);
    destroy_shell(shell);
  delete lump;
Helper for destroying PartitionLump topology
Definition at line 771 of file PartitionEngine.cpp.
  if (shell->get_lump())
    assert(0);
  while( PartitionCoSurf* cosurf = shell->next_co_surface() )
    shell->remove( cosurf );
    SubSurface* psurf = dynamic_cast<SubSurface*>(cosurf->get_surface());
    if (psurf)
      psurf->remove(cosurf);
        // If PartitionSurface is the same as the underlying surface
        // and is not part of any other PartitionLumps, remove it.
      if( !psurf->sub_entity_set().has_lower_order() &&
           psurf->next_co_surface() == 0 )
        restore_surface( psurf );
    delete cosurf;
  delete shell;
Destroy a surface and child topology.
Destroy a surface with no parent topology, destroying any child topology that is used only by the passed surface.
Definition at line 4554 of file PartitionEngine.cpp.
  while( PartitionLoop* dead_loop = surface->next_loop(0) )
    surface->remove(dead_loop);
    while( PartitionCoEdge* dead_coe = dead_loop->first_coedge() )
      PartitionCurve* dead_curve = dead_coe->get_curve();
      dead_loop->remove(dead_coe);
      dead_curve->remove(dead_coe);
      delete dead_coe;
      if( dead_curve->partitioned_entity() == surface->partitioned_entity() )
        if( dead_curve->next_coedge(0) == 0 )
          PartitionPoint* start_pt = dead_curve->start_point();
          PartitionPoint* end_pt = dead_curve->end_point();
          delete dead_curve;
          if( start_pt->partitioned_entity() == surface->partitioned_entity() &&
              start_pt->next_curve() == 0 )
            delete start_pt;
          if( end_pt->partitioned_entity() == surface->partitioned_entity() &&
              end_pt->next_curve() == 0 )
            delete end_pt;
      else if( SubCurve* subcurve = dynamic_cast<SubCurve*>(dead_curve) )
        restore_curve(subcurve);
    delete dead_loop;
  delete surface;
PartitionEntity * PartitionEngine::entity_from_id ( int  set_id,
int  geom_id,
SubEntitySet default_set
Retreive a PartitionEntity given ID pair.
PartitionEntities are identified by the ID of their SubEntitySet and the ID of the entity in that set. Retreive the PartitionEntity given these IDs.
Parameters:
set_idThe UniqueID of the SubEntitySet.
geom_idThe ID of the PartitionEntity within the SubEntitySet
default_setThe SubEntitySet to retreive the entity from if the set_id == 0.
Returns:
The requested PartitionEntit, or NULL if it does not exist.
Definition at line 4602 of file PartitionEngine.cpp.
  if( set_id == 0 )
    return default_set.entity_from_id( entity_id );
  SubEntitySet* set = get_from_id_map(set_id);
  if( set )
    return set->entity_from_id( entity_id );
  return 0;
CubitStatus PartitionEngine::export_geometry ( DLIList< TopologyBridge * > &  geometry_to_save) [virtual]
Save partition geometry.
Saves any partition geometry in the passed list (or on children of entities int the passed list) as attributes on the underlying geometry, and update the passed list to contain the underlying geometry.
Definition at line 5496 of file PartitionEngine.cpp.
  int i;
  CubitStatus result = CUBIT_SUCCESS;
  if ( CGMApp::instance()->attrib_manager()->auto_update_flag(CA_PARTITION_VG) &&
       CGMApp::instance()->attrib_manager()->auto_write_flag(CA_PARTITION_VG) )
      // Get all child topology to export
    DLIList<Curve*> curve_list;
    DLIList<Surface*> surface_list;
    DLIList<Lump*> lump_list;
    DLIList<BodySM*> body_list;
    DLIList<TopologyBridge*> bridge_list, temp_list, coe_curves(1), surf_curves;
    CAST_LIST( list, curve_list, Curve );
    CAST_LIST( list, surface_list, Surface );
    CAST_LIST( list, lump_list, Lump );
    CAST_LIST( list, body_list, BodySM );
    for( i = body_list.size(); i--; )
      BodySM* body = body_list.get_and_step();
      body->get_children( bridge_list, true, layer() );
      while( bridge_list.size() )
        lump_list.append( dynamic_cast<Lump*>(bridge_list.pop()) );
    for( i = lump_list.size(); i--; )
      Lump* lump = lump_list.get_and_step();
      lump->get_children( bridge_list, true, layer() );
        bridge_list.pop()->get_children( temp_list, true, layer() );
        while( temp_list.size() )
          surface_list.append( dynamic_cast<Surface*>(temp_list.pop()) );
    for( i = surface_list.size(); i--; )
      Surface* surf = surface_list.get_and_step();
      surf->get_children( bridge_list, true, layer() );
          temp_list.pop()->get_children_virt( coe_curves );
          assert(coe_curves.size() == 1);
          surf_curves.append(coe_curves.pop());
      surf_curves.uniquify_ordered();
      while( surf_curves.size() )
        curve_list.append( dynamic_cast<Curve*>(surf_curves.pop()) );
      // save curve partitions
    DLIList<SubEntitySet*> set_list;
    for( i = curve_list.size(); i--; )
      SubCurve* curve = dynamic_cast<SubCurve*>(curve_list.get_and_step());
      if( curve )
        set_list.append( &(curve->sub_entity_set()) );
    set_list.uniquify_ordered();
    for( i = set_list.size(); i--; )
      if( ! set_list.get_and_step()->save_geometry() )
        result = CUBIT_FAILURE;
      // save surface partitions
    set_list.clean_out();
      SubSurface* surf = dynamic_cast<SubSurface*>(surface_list.get_and_step());
      if( surf )
        set_list.append( &(surf->sub_entity_set()) );
      // save volume partitions
      PartitionLump* lump = dynamic_cast<PartitionLump*>(lump_list.get_and_step());
      if( lump )
        set_list.append( &(lump->sub_entity_set()) );
    // replace partitions in passed list with the real
    // entities they partition
  PartitionEntity* p_ent = 0;
  list.last() ;
  for ( i = list.size(); i--; )
    if( (p_ent = dynamic_cast<PartitionEntity*>(list.step_and_get())) )
      if( list.is_in_list(p_ent->partitioned_entity()) )
        list.change_to(0);
      else
        list.change_to(p_ent->partitioned_entity());
  list.remove_all_with_value(0);
  return result;
CubitStatus PartitionEngine::find_coedges ( PartitionSurface surface,
PartitionCurve curve,
PartitionPoint point,
PartitionCoEdge *&  previous,
PartitionCoEdge *&  next
) [private]
Find location to insert a curve into a loop.
Given a curve and an end point on the curve, find the two coedges in the loop between which the curve should be inserted.
Parameters:
surfaceThe surface the curve is to be inserted into.
curveThe curve to be inserted.
pointThe end point of the curve to find the loop intersection for
previousA CoEdge ending at the passed point (output).
nextA CoEdge beginning at the passed point (output).
Definition at line 1356 of file PartitionEngine.cpp.
  const char* const bad_loop_message = "Internal error: Invalid loop. (%s:%d)\n";
    // Find list of all coedges around passed point
    // and in passed surface.
  DLIList<PartitionCoEdge*> point_coedges;
  PartitionCoEdge* coedge;
  PartitionCurve* pt_curve = 0;
  while ( (pt_curve = point->next_curve(pt_curve)) )
    coedge = 0;
    while ( (coedge = pt_curve->next_coedge(coedge)) )
      if (coedge->get_loop() &&
          coedge->get_loop()->get_surface() == surface &&
          !dynamic_cast<PartPTCurve*>(coedge->get_curve()))
        point_coedges.append(coedge);
    // TBPoint is at end of a sipe/hardline
  if ( point_coedges.size() == 0 )
    previous = next = 0;
    // One coedge - closed curve
  if ( point_coedges.size() == 1 &&
       point_coedges.get()->start_point() ==
       point_coedges.get()->end_point() )
    previous = next = point_coedges.get();
    // Broken loop?
  if ( point_coedges.size() % 2 != 0 )
    PRINT_ERROR(bad_loop_message,__FILE__,__LINE__);
    assert(0);
    // If only two coedges, then we're done
    // If closed curve, the answer may be the same coedge for both
    // prev and next.  E.g. A torus cracked along the outside major
    // radius and a sipe that intersects that crack curve.  Need
    // to fall though to the more complex check below in that case.
  if ( point_coedges.size() == 2 &&
       point_coedges.get()->get_curve()->start_point() !=
         point_coedges.get()->get_curve()->end_point() &&
       point_coedges.next()->get_curve()->start_point() !=
         point_coedges.next()->get_curve()->end_point() )
    previous = point_coedges.get();
    next = point_coedges.next();
    if ( previous->start_point() == point )
      std::swap(previous, next);
    // Find previous/next coedges by using order of
    // facet edges about point in surface facetting.
  CubitPointData* facet_point = point->facet_point();
  DLIList<CubitFacetEdgeData*> curve_edges;
  curve->get_facet_data(curve_edges);
  CubitFacetEdgeData* edge;
  //bool edge_reversed;
  if ( point == curve->start_point() )
    curve_edges.reset();
    edge = curve_edges.get();
  else
    assert(curve->end_point() == point);
    curve_edges.last();
  PartitionCurve *prev_curve, *next_curve;
  prev_curve = next_curve_around_point( surface, edge, facet_point, true );
  next_curve = next_curve_around_point( surface, edge, facet_point, false );
  if ( !prev_curve || !next_curve )
    assert(0);
  coedge = 0;
  while ( (coedge = prev_curve->next_coedge(coedge)) )
    if ( coedge->get_loop() &&  // parent not a partition surface?
         coedge->end_point() == point )
      previous = coedge;
      break;
  coedge = 0;
  while ( (coedge = next_curve->next_coedge(coedge)) )
         coedge->start_point() == point )
      next = coedge;
      break;
Retreive SubEntitySet from ID map given ID.
Definition at line 172 of file PartitionEngine.cpp.
  std::map<int,SubEntitySet*>::iterator itor = uniqueIdMap.find(id);
  return itor == uniqueIdMap.end() ? 0 : itor->second;
Definition at line 6356 of file PartitionEngine.cpp.
  BridgeManager* bm = dynamic_cast<BridgeManager*>(source_bridge->owner());
  if( bm )
    tbs.append( source_bridge );
    return;
  SubEntitySet* set = dynamic_cast<SubEntitySet*>(source_bridge->owner());
  if( !set )
    return;
  DLIList<PartitionEntity*> entity_list;
  set->get_sub_entities( entity_list );
  DLIList<TopologyBridge*> tb_list;
  CAST_LIST( entity_list, tb_list, TopologyBridge );
  while( tb_list.size() )
    TopologyBridge *tb = tb_list.pop();
    if( tb->bridge_manager() )
      tbs.append( tb );
    else
      TBOwner *owner = tb->owner();
      TopologyBridge *tmp_tb = CAST_TO( owner, TopologyBridge );
      if( tmp_tb )
        tb_list.append( tmp_tb );
      else
        CompositePoint *comp_pt = CAST_TO( tb, CompositePoint );
        if( comp_pt )
          CompositeEngine::instance().get_tbs_with_bridge_manager_as_owner( tb, tb_list );
        else
          CompositeCurve *comp_curve = CAST_TO( tb, CompositeCurve );
          if( comp_curve )
  tbs.uniquify_ordered();
  return;
CubitStatus PartitionEngine::import_geometry ( DLIList< TopologyBridge * > &  imported_geometry) [virtual]
Restore partitions on passed geometry
Reads partition geometry saved as attributes on the passed geometry, restores the partitions and udpates the passed list
Definition at line 5633 of file PartitionEngine.cpp.
  int i;
  DLIList<Curve*> curve_list, temp_curves;
  DLIList<Surface*> surface_list, temp_surfaces;
  DLIList<Lump*> lump_list, temp_lumps;
    temp_lumps.clean_out();
    body_list.get_and_step()->lumps( temp_lumps );
    lump_list += temp_lumps;
    temp_surfaces.clean_out();
    lump_list.get_and_step()->surfaces( temp_surfaces );
    surface_list += temp_surfaces;
    temp_curves.clean_out();
    surface_list.get_and_step()->curves( temp_curves );
    curve_list += temp_curves;
  if ( CGMApp::instance()->attrib_manager()->auto_actuate_flag(CA_PARTITION_VG) &&
       CGMApp::instance()->attrib_manager()->auto_read_flag(CA_PARTITION_VG) )
    curve_list.uniquify_ordered();
      if( ! restore_from_attrib( curve_list.get_and_step() ) )
    surface_list.uniquify_ordered();
      if( ! restore_from_attrib( surface_list.get_and_step() ) )
    lump_list.uniquify_ordered();
      if( ! restore_from_attrib( lump_list.get_and_step() ) )
      // update imported list
    list.last();
    DLIList<TopologyBridge*> temp_list;
    for( i = list.size(); i--; )
      TopologyBridge* bridge = list.step_and_get();
      SubEntitySet* set = dynamic_cast<SubEntitySet*>(bridge->owner());
      if( !set ) continue;
      entity_list.clean_out();
      temp_list.clean_out();
      CAST_LIST( entity_list, temp_list, TopologyBridge );
      temp_list.reset();
      list.change_to( temp_list.get_and_step() );
      for( int j = temp_list.size(); j > 1; j-- )
        list.append( temp_list.get_and_step() );
  else
    DLIList<TopologyBridge*> point_list(curve_list.size()*2), tmp_points(2);
    for ( i = curve_list.size(); i--; )
      tmp_points.clean_out();
      curve_list.get()->get_children(tmp_points);
      point_list += tmp_points;
      SubEntitySet::strip_attributes( curve_list.get_and_step() );
    point_list.uniquify_ordered();
    for ( i = point_list.size(); i--; )
      SubEntitySet::strip_attributes( point_list.get_and_step() );
    for ( i = surface_list.size(); i--; )
      SubEntitySet::strip_attributes( surface_list.get_and_step() );
    for ( i = lump_list.size(); i--; )
      SubEntitySet::strip_attributes( lump_list.get_and_step() );
  return result;
Surface * PartitionEngine::insert_curve ( Surface surface,
DLIList< CubitVector * > &  segment_points,
DLIList< Curve * > &  new_curves,
const double *  tolerance_length = NULL
Single-surface interface to insert_curve(DLIList<Surface*>&,...)
See also:
insert_curve( DLIList<Surface*>&, DLIList<CubitVector*>&, DLIList<Surface*>,& DLIList<Curve*>& )
Definition at line 2051 of file PartitionEngine.cpp.
  DLIList<Surface*> input_surfs(1), output_surfs(2);
  input_surfs.append(surface);
  if ( ! insert_curve(input_surfs, segment_points, output_surfs, new_curves,
                tolerance_length) )
    return 0;
  return output_surfs.size() ? output_surfs.get() : surface;
CubitStatus PartitionEngine::insert_curve ( DLIList< Surface * > &  surfaces,
DLIList< CubitVector * > &  polyline,
DLIList< Surface * > &  new_surfaces,
DLIList< Curve * > &  polyline_curves,
const double *  tolerance_length = NULL,
DLIList< Surface * > *  surfs_to_reverse = NULL
Partition surfaces
Split surfaces by projecting the passed polyline onto the patch of surfaces.
Parameters:
surfacesThe list of surfaces to split.
polylineThe curve to imprint the surfaces with.
new_surfacesPopulated with new surfaces created during partitioning.
polyline_curvesPopolated with new curves.
Definition at line 2074 of file PartitionEngine.cpp.
  int i;
  for ( i = input_surfaces.size(); i--; )
    if ( dynamic_cast<CompositeSurface*>(input_surfaces.get_and_step()) )
      return CompositeEngine::instance().insert_curve(
        input_surfaces, segment_points, new_surfaces, new_curves );
  DLIList<SubSurface*> replaced_surfaces;
  DLIList<PartitionSurface*> surface_list, new_part_surfs;
  DLIList<PartitionCurve*> curve_list;
    // get partition surfaces
    int reverse_surf = 0;
    Surface* surf = input_surfaces.get_and_step();
    // We will need to reverse the surface and its facets if it
    // is in the passed-in list of surfaces to reverse.
    if(surfs_to_reverse && surfs_to_reverse->is_in_list(surf))
      reverse_surf = 1;
    PartitionSurface* partsurf = dynamic_cast<PartitionSurface*>(surf);
    if( partsurf )
      surface_list.append(partsurf);
      if(reverse_surf)
        partsurf->reverse_sense();
    else
      SubSurface* subsurf = replace_surface(surf);
      if (!subsurf)
        break;
      replaced_surfaces.append( subsurf );
      surface_list.append(subsurf);
      if(reverse_surf)
        subsurf->reverse_sense();
  if (result)
    result = insert_curve( surface_list, segment_points, new_part_surfs, curve_list,
      tolerance_length);
  if (!result)
    // we replaced the original surface we need to clean up also
    for ( i = replaced_surfaces.size(); i--;  )
      SubSurface* surf = replaced_surfaces.step_and_get();
      restore_surface( surf ); // this also deletes the virtual surface
    return result;
  CAST_LIST_TO_PARENT(curve_list,new_curves);
  CAST_LIST_TO_PARENT(new_part_surfs,new_surfaces);
    // clean up any partition surfaces we created but didn't modify
    if ( !surf->sub_entity_set().has_lower_order() &&
         !surf->next_co_surface(0) )
    else
      new_surfaces.append( surf );
  return result;
CubitStatus PartitionEngine::insert_curve ( DLIList< PartitionSurface * > &  surfaces,
DLIList< PartitionSurface * > &  new_surfaces,
DLIList< PartitionCurve * > &  polyline_curves,
) [private]
Partition surfaces
Parameters:
Definition at line 2199 of file PartitionEngine.cpp.
  int i;
  const double TOL_SQR = GEOMETRY_RESABS*GEOMETRY_RESABS;
    // Get curves
  DLIList<PartitionCurve*> curves;
  curves_from_surfaces( surface_list, curves );
    // Check for intersections with boundary curves
  segment_points.reset();
  curves.reset();
  for ( i = segment_points.size(); i--;  )
    CubitVector& pos = *segment_points.get_and_step();
    bool debug = false;
    if (debug)
      GfxDebug::draw_point(pos, CUBIT_BLUE_INDEX);
      GfxDebug::mouse_xforms();
    for ( int j = curves.size(); j--; )
      PartitionCurve* curve = curves.get_and_step();
      if ((curve->start_point()->coordinates() - pos).length_squared() < TOL_SQR)
        pos = curve->start_point()->coordinates();
        break;
      if ((curve->end_point()->coordinates() - pos).length_squared() < TOL_SQR)
        pos = curve->end_point()->coordinates();
        break;
      CubitVector closest;
      curve->closest_point_trimmed( pos, closest );
      if ( (pos - closest).length_squared() > TOL_SQR )
        continue;
      if ((curve->start_point()->coordinates() - closest).length_squared() < TOL_SQR)
        break;
      if ((curve->end_point()->coordinates() - closest).length_squared() < TOL_SQR)
        break;
      double u = curve->u_from_position(closest);
      TBPoint* point = insert_point( curve, u );
      if (!point)
        PRINT_ERROR("Error splitting curve.  Aborting.\n");
      pos = point->coordinates();
      pos = closest;
      break;
    // get surface facets
  DLIList<CubitFacetData*> surf_facets, facet_list;
  surface_list.reset();
    surf_facets.clean_out();
    surface_list.get_and_step()->get_facet_data( surf_facets );
    facet_list += surf_facets;
    // Do facet projection
  DLIList<CubitFacetEdgeData*> polyline;
  DLIList<CubitPointData*> polyline_pts;
  project_to_surface( facet_list, segment_points, polyline, polyline_pts, tolerance_length);
  if(segment_points.size() == polyline_pts.size())
    // Move facet points to real geometry
    DLIList<CubitFacetEdge*> edge_list;
    DLIList<CubitFacet*> pt_facets;
    polyline_pts.reset();
    int count = 0;
      CubitPointData* facet_pt = polyline_pts.get_and_step();
      CubitVector position( *segment_points.get_and_step() );
      if ( !facet_pt )
        continue;
      PartitionPoint* point = dynamic_cast<PartitionPoint*>(TDVGFacetOwner::get(facet_pt));
      if ( point )
        count++;
        continue;
      PartitionCurve* curve = 0;
      edge_list.clean_out();
      facet_pt->edges( edge_list );
      while ( edge_list.size() )
        PartitionEntity* owner = TDVGFacetOwner::get(edge_list.pop());
        if ( owner )
          assert(!curve || curve == owner);
          curve = dynamic_cast<PartitionCurve*>(owner);
      if ( curve )
        Surface* surface = dynamic_cast<Surface*>(curve->partitioned_entity());
        if ( surface )
          CubitVector surf_pos;
          surface->closest_point( position, &surf_pos );
          if (facet_pt->check_inverted_facets(surf_pos))
            facet_pt->set( surf_pos );
        else
          curve->relax_to_geometry( facet_pt, &position );
        continue;
      PartitionSurface* surf = 0;
      pt_facets.clean_out();
      facet_pt->facets( pt_facets );
      while ( pt_facets.size() )
        PartitionEntity* owner = TDVGFacetOwner::get(pt_facets.pop());
        if ( owner )
          assert(!surf || surf == owner);
          surf = dynamic_cast<PartitionSurface*>(owner);
      if ( surf && dynamic_cast<SubSurface*>(surf) )
        surf->relax_to_geometry( facet_pt, &position );
  if ( !polyline.size() )
  //In the following lines we see if we need to split curves on
  //the boundary of the surface.  This is necessary when the endpoints of
  //the polylines used for partitioning are not coincident with
  //boundary curves.
  //get all the facet points of the polyline
  DLIList<CubitPoint*> points_on_polyline;
  for( int k=polyline.size(); k--; )
    CubitFacetEdgeData *tmp_edge = polyline.get_and_step();
    if( !tmp_edge )
      continue;
    points_on_polyline.append_unique( tmp_edge->start_node() );
    points_on_polyline.append_unique( tmp_edge->end_node() );
  //get all the resulting facets
  DLIList<CubitFacet*> facets_after;
    for( int s=surf_facets.size(); s--; )
      facets_after.append( surf_facets.get_and_step() );
  //from the facets, collect all the boundary points
  DLIList<CubitPoint*> boundary_pts;
  FacetDataUtil::get_boundary_points( facets_after, boundary_pts );
  //for each polyline points...
  for( int k=points_on_polyline.size(); k--; )
    CubitPoint *tmp_pt = points_on_polyline.get_and_step();
    //if the point is on the boundary...
    if( boundary_pts.is_in_list( tmp_pt ) )
      PartitionPoint* point = dynamic_cast<PartitionPoint*>(TDVGFacetOwner::get(tmp_pt));
      if( !point ) //if the point is not already a vertex on the boundary...
        //find the adjacent boundary curve that we'll insert these points into
        DLIList<CubitFacetEdge*> adj_edges;
        tmp_pt->edges( adj_edges );
        for( int s=adj_edges.size(); s--; )
          CubitFacetEdge *tmp_edge = adj_edges.get_and_step();
          PartitionCurve* curve = dynamic_cast<PartitionCurve*>(TDVGFacetOwner::get(tmp_edge));
          if( curve )
            DLIList<TopologyBridge*> bridges;
            get_tbs_with_bridge_manager_as_owner(curve, bridges );
            if( bridges.size() == 0 )
              CompositeEngine::instance().get_tbs_with_bridge_manager_as_owner( curve, bridges );
            RefEdge *ref_edge = dynamic_cast<RefEdge*>(bridges.get()->topology_entity());
            RefEdge *edge1, *edge2;
            //now do the split
            PartitionTool::instance()->partition( ref_edge, tmp_pt->coordinates(), edge1, edge2  );
            break;
    // construct the curves
  DLIList<CubitFacetEdgeData*> cubit_edges;
  DLIList<CubitFacetEdge*> pt_edges;
  polyline.reset();
  for ( i = polyline.size(); i > 0; )
      // get list of FacetPoints for Curve
    cubit_edges.clean_out();
    CubitFacetEdgeData* edge = polyline.get_and_step();
    if (!edge) { i--; continue; }
    assert(!TDVGFacetOwner::get(edge) &&
           edge->num_adj_facets() < 3 &&
           edge->num_adj_facets() > 0);
    PartitionEntity* owner = TDVGFacetOwner::get(edge->adj_facet(0));
    assert( edge->num_adj_facets() == 1 ||
            TDVGFacetOwner::get(edge->adj_facet(1)) == owner );
    cubit_edges.append( edge );
    while( polyline.get() )
      CubitPoint* pt = edge->shared_point(polyline.get());
      edge = polyline.get();
             edge->num_adj_facets() > 0 && pt);
      PartitionEntity* tmp = TDVGFacetOwner::get(edge->adj_facet(0));
            TDVGFacetOwner::get(edge->adj_facet(1)) == tmp );
      bool edge_owner = false;
      pt->edges(pt_edges);
      while (pt_edges.size())
        if (TDVGFacetOwner::get(pt_edges.pop()))
          edge_owner = true;
      if ( tmp != owner || TDVGFacetOwner::get(pt) || edge_owner )
        break;
      cubit_edges.append( polyline.get_and_step() );
    if (NULL == polyline.get())
      polyline.step();
      i -= 1;
    i -= cubit_edges.size();
      // create curve and partition surface
    PartitionCurve* new_curve = insert_curve( cubit_edges, &segment_points );
    if ( new_curve )
      curve_list.append(new_curve);
    // find new surfaces to return
    PartitionCurve* curve = curve_list.step_and_get();
    PartitionCoEdge* coedge = 0;
    while( (coedge = curve->next_coedge(coedge)) )
      new_part_surfs.append( coedge->get_loop()->get_surface() );
  if ( curve_list.size() )
      // do facet cleanup
      curve_list.get_and_step()->do_facet_cleanup();
    //for ( i = new_part_surfs.size(); i--; )
    //  new_part_surfs.get_and_step()->do_facet_cleanup();
    new_part_surfs.step_and_get()->mark = 1;
    surface_list.step_and_get()->mark = 0;
    if ( new_part_surfs.step_and_get()->mark )
      new_part_surfs.get()->mark = 0;
    else
      new_part_surfs.change_to(0);
  new_part_surfs.remove_all_with_value(0);
  return curve_list.size() ? CUBIT_SUCCESS : CUBIT_FAILURE;
Insert a new curve into surface topology.
Insert a new curve into the topology of the passed surface, splitting the surface if the curve splits a loop in the surface.
The surface facet connectivity is used to determine which curves belong with which surface after the split. This function assumes that the surface facetting has already been updated with the projection of the new curve, and that the resulting facet edges are associated with the passed curve.
Used by insert_curve(DLIList<CubitFacetEdgeData*>&), and restore_from_attrib(Surface*).
Parameters:
surfaceThe surface to split
curveThe split curve
Returns:
NULL if an error occured, the new surface if the surface was split, otherwise the passed surface.
Definition at line 1099 of file PartitionEngine.cpp.
  PartitionSurface* new_surface = 0;
  assert( &(curve->sub_entity_set()) == &(surface->sub_entity_set()) );
  PartitionPoint *start_point = curve->start_point();
  PartitionPoint *end_point   = curve->end_point();
  PartitionLoop  *start_loop = 0, *end_loop = 0;
  PartitionCoEdge *start_prev_coedge = 0, *start_next_coedge = 0;
  PartitionCoEdge *end_prev_coedge = 0, *end_next_coedge = 0;
    // find where to insert new curve in loop
  if ( !find_coedges( surface, curve, start_point, start_prev_coedge, start_next_coedge ) )
    return 0;
  if ( !find_coedges( surface, curve, end_point, end_prev_coedge, end_next_coedge ))
    return 0;
  assert((!start_prev_coedge && !start_next_coedge) ||
         (start_prev_coedge && start_next_coedge &&
          start_prev_coedge->get_loop() == start_next_coedge->get_loop()));
  assert((!end_prev_coedge && !end_next_coedge) ||
         (end_prev_coedge && end_next_coedge &&
          end_prev_coedge->get_loop() == end_next_coedge->get_loop()));
  if ( start_prev_coedge )
    start_loop = start_prev_coedge->get_loop();
  if ( end_prev_coedge )
    end_loop = end_prev_coedge->get_loop();
    // remove any point-curves
  PartitionCurve* pt_curve;
  PartPTCurve* point_curve;
  for ( int i = 0; i < 2; i++ ) // do once for each end point
    PartitionPoint* pt = i ? end_point : start_point;
    pt_curve = pt->next_curve(0);
    while ( pt_curve  )
      point_curve = dynamic_cast<PartPTCurve*>(pt_curve);
      pt_curve = pt->next_curve(pt_curve);
      if (point_curve && point_curve->next_coedge(0)->get_loop()->get_surface() == surface)
        point_curve->start_point(0);
        point_curve->end_point(0);
        PartitionCoEdge* coedge = point_curve->next_coedge(0);
        point_curve->remove(coedge);
        assert( !point_curve->next_coedge(0) );
        PartitionLoop* loop = coedge->get_loop();
        loop->remove(coedge);
        assert( !loop->first_coedge() );
        surface->remove(loop);
        delete loop;
        delete coedge;
        delete point_curve;
  PartitionCoEdge* forward = new PartitionCoEdge( surface, CUBIT_FORWARD );
  PartitionCoEdge* reverse = new PartitionCoEdge( surface, CUBIT_REVERSED );
  curve->add(forward);
  curve->add(reverse);
    // new one-curve loop?
  if( !start_loop && !end_loop )
    PartitionLoop* new_loop = new PartitionLoop();
    surface->add( new_loop );
    new_loop->insert_after( forward, 0 );
    if( curve->start_point() == curve->end_point() )
      PartitionLoop* loop2 = new PartitionLoop();
      loop2->insert_after( reverse, 0 );
      if( VGLoopTool
          <PartitionSurface,PartitionLoop,PartitionCoEdge,PartitionCurve,PartitionPoint>
          ::loop_angle_metric( forward ) > 0 )
        new_loop = loop2;
      else
        surface->remove(new_loop);
        surface->add( loop2 );
      new_surface = split_surface( surface, new_loop->first_coedge() );
      new_surface->add( new_loop );
    else
      new_loop->insert_after( reverse, forward );
    // sipe
  else if( !start_loop || !end_loop )
    PartitionCoEdge* prev;
    PartitionLoop* loop;
    if( start_loop )
      loop = start_loop;
      prev = start_prev_coedge;
    else
      loop = end_loop;
      prev = end_prev_coedge;
    if( forward->start_point() == prev->end_point() )
      loop->insert_after( forward, prev );
    else
      assert( reverse->start_point() == prev->end_point() );
      loop->insert_after( reverse, prev );
      loop->insert_after( forward, reverse );
    // join loops
  else if( start_loop != end_loop )
    PartitionCoEdge* prev = start_prev_coedge;
    PartitionCoEdge* coedge = end_next_coedge;
    PartitionCoEdge* next = 0, *other_coedge;
      start_loop->insert_after( forward, prev );
      prev = forward;
      other_coedge = reverse;
    else
      start_loop->insert_after( reverse, prev );
      prev = reverse;
      other_coedge = forward;
    while ( end_loop->first_coedge() )
      next = end_loop->next_coedge( coedge );
      end_loop->remove( coedge );
      start_loop->insert_after( coedge, prev );
      prev = coedge;
      coedge = next;
      // The other coedge for the curve we are restoring...
    start_loop->insert_after( other_coedge, prev );
    assert( end_loop->num_coedges() == 0 );
    surface->remove( end_loop );
    delete end_loop;
    // split a loop (and create a new surface)
  else
    assert( start_loop == end_loop );
      // If the curve we are adding results in a hole that
      // intersects the loop we are splitting at a single
      // vertex, we need to figure out which of the coedges
      // goes in the hole and which is added to the loop
      // we are splitting.
    if( forward->start_point() == forward->end_point() )
      assert( start_next_coedge == end_next_coedge );
      assert( start_prev_coedge == end_prev_coedge );
      CubitVector prev_tan, forward_tan, reverse_tan, normal, junk;
      CubitVector point = forward->start_point()->coordinates();
      start_prev_coedge->get_curve()->closest_point( point, junk, &prev_tan );
      if( start_prev_coedge->sense() == CUBIT_FORWARD ) // yes, forward!!!
        prev_tan *= -1.0;
      forward->get_curve()->closest_point( point, junk, &forward_tan );
      reverse_tan = forward_tan * -1.0;
      surface->closest_point( point, 0, &normal );
      double angle1 = normal.vector_angle( prev_tan, forward_tan );
      double angle2 = normal.vector_angle( prev_tan, reverse_tan );
      if( angle2 < angle1 )
        PartitionCoEdge* temp = reverse;
        reverse = forward;
        forward = temp;
    else
      if( forward->end_point() == end_next_coedge->start_point() )
        reverse = forward;
        forward = temp;
    end_loop = new PartitionLoop();
    start_loop->insert_after( forward, end_prev_coedge );
    end_loop->insert_after( reverse, 0 );
    PartitionCoEdge* prev = reverse;
    while( coedge != start_next_coedge )
      PartitionCoEdge* next = start_loop->next_coedge( coedge );
      start_loop->remove( coedge );
      end_loop->insert_after( coedge, prev );
      prev = coedge;
      coedge = next;
    new_surface = split_surface( surface, reverse );
    new_surface->add( end_loop );
  if( new_surface )
    PartitionCoSurf* cos = 0;
    while( (cos = surface->next_co_surface( cos )) )
      cos->get_shell()->add( new_surface, cos->sense() );
    if( surface->owner() )
      surface->owner()->notify_split( new_surface, surface );
    return new_surface;
  else
      surface->owner()->notify_topology_modified( surface );
    return surface;
SegmentedCurve * PartitionEngine::insert_curve ( DLIList< CubitFacetEdgeData * > &  facet_edges,
DLIList< CubitVector * > *  curve_segments = 0
) [private]
Insert a curve into surface topology.
Given the imprint if a curve on the surface facetting, create a new curve and insert it in the surface topology, splitting the surface if necessary. The surface is determined from the owners of the facets adjacent to the passed edges. The new curve is returned.
If the list of curve segments is not specified, the facet edges will be used to define the curve geometry. The list of curve segments may optionally be specified to provide a more precise definition of the curve geometry.
Used by insert_Curve( DLIList<Surface*>&, DLIList<CubitVector*&, ... );
Definition at line 2532 of file PartitionEngine.cpp.
  int i;
    // find surface
  PartitionSurface* surface = 0;
  DLIList<CubitFacet*> facets;
  for ( i = segments.size(); i--; )
    CubitFacetEdgeData* edge = segments.get_and_step();
    facets.clean_out();
    edge->facets(facets);
    assert(facets.size() == 2);
    for (int j = 0; j < facets.size(); j++ )
      CubitFacet* facet = facets.get_and_step();
      PartitionEntity* fowner = TDVGFacetOwner::get(facet);
      PartitionSurface* surf = dynamic_cast<PartitionSurface*>(fowner);
      if ( !surf || (surface && surf != surface) )
        PRINT_ERROR("Internal Error in PartitionEngine.  Corrupt facet data.\n");
        assert(0);
        return 0;
      surface = surf;
    // if there is a real surface, relax facet points to surface
  Surface* real_surf = dynamic_cast<Surface*>(surface->partitioned_entity());
    // find start and end facet points
  CubitPointData* pts[2];
  CubitPoint* pt;
  if( segments.size() == 1 )
    pts[0] = dynamic_cast<CubitPointData*>(segments.get()->point(0));
    pts[1] = dynamic_cast<CubitPointData*>(segments.get()->point(1));
  else
    segments.last();
    pt = segments.get()->shared_point( segments.prev() );
    pt = segments.get()->other_point( pt );
    pts[1] = dynamic_cast<CubitPointData*>(pt);
    segments.reset();
    pt = segments.get()->shared_point( segments.next() );
    pts[0] = dynamic_cast<CubitPointData*>(pt);
    // create end points (partition curves if necessary)
  bool okay = true;
  DLIList<CubitFacetEdge*> edges;
  bool created_pts[2] = {false,false};
  PartitionPoint* end_pts[2] = {0,0};
  for ( i = 0; okay && i < 2; i++ )
    end_pts[i] = dynamic_cast<PartitionPoint*>(TDVGFacetOwner::get(pts[i]));
    if( end_pts[i] ) continue;
    edges.clean_out();
    pts[i]->edges(edges);
    for ( int j = edges.size(); !curve && j--; )
      curve = dynamic_cast<PartitionCurve*>(TDVGFacetOwner::get(edges.get_and_step()));
    if( curve )
      curve->relax_to_geometry( pts[i] );
      PartitionPoint* new_pt = new PartitionPoint( pts[i]->coordinates(), curve );
      if ( insert_point( curve, new_pt ) )
        end_pts[i] = new_pt;
        created_pts[i] = true;
        assert( TDVGFacetOwner::get(pts[i]) == new_pt );
      else
        delete new_pt;
        okay = false;
      continue;
    facets.clean_out();
    pts[i]->facets(facets);
    for ( int k = facets.size(); k--; )
      if( TDVGFacetOwner::get(facets.get_and_step()) != surface )
        okay = false;
        break;
    if( okay )
      if( real_surf )
        surface->relax_to_geometry( pts[i] );
      end_pts[i] = new PartitionPoint( pts[i]->coordinates(), surface );
      end_pts[i]->facet_point( pts[i] );
    // create curve
  SegmentedCurve* curve = 0;
  if( okay )
    DLIList<CubitVector*> vectors(segments.size()+1), *curve_geom_ptr;
//    if( curve_geom )
//      curve_geom_ptr = curve_geom;
//    else
      segments.reset();
      pt = pts[0];
      vectors.append( new CubitVector( pt->coordinates() ) );
      for( i = segments.size(); i--; )
        pt = segments.get_and_step()->other_point(pt);
        if ( real_surf && i > 0 )
          surface->relax_to_geometry( pt );
        assert(!!pt);
      curve_geom_ptr = &vectors;
    curve = new SegmentedCurve( surface, *curve_geom_ptr );
    while( vectors.size() ) delete vectors.pop();
    curve->start_point( end_pts[0] );
    curve->end_point( end_pts[1] );
    curve->set_facet_data(segments);
    if( insert_curve( surface, curve ) )
      return curve;
  // If we got this far, then something went wrong.
  // Try to clean up.
  if( curve )
    segments.clean_out();
    delete curve;
  for( i = 0; i < 2; i++ )
    if( ! created_pts[i] ) continue;
    end_pts[i]->facet_point(0);
    if( dynamic_cast<Curve*>(end_pts[i]->partitioned_entity()) )
      remove_point( end_pts[i] );
    else
      delete end_pts[i];
  return 0;
void PartitionEngine::insert_nonmanifold_surfaces ( DLIList< PartitionSurface * > &  surfaces,
PartitionShell shell1,
PartitionShell shell2
) [private]
Put non-manifold surfaces in appropriate shell.
After a shell is split, figure out which of the new shells each surface in the passed list of non-manifold surfaces belongs in, and add it to that shell.
Called by split_shell(PartitionShell*)
Parameters:
surfacesA list of non-manifold surfaces with co-surfaces already created, but not beloning to any shell.
shell1One of the two shells.
shell2The other of the two shells.
Definition at line 4158 of file PartitionEngine.cpp.
  DLIList<PartitionSurface*> known_list(surf_stack.size()),
                           unknown_list(surf_stack.size());
  PartitionCoSurf* cosurf;
  PartitionSurface* surf;
  PartitionCoEdge *coedge, *curve_coe;
  PartitionCurve* curve;
    // Loop until we've placed all the surfaces in one
    // shell or the other.
  while ( surf_stack.size() )
    bool did_some = false;
      // Put any surfaces for which we immediately
      // know the shell into the appropriate shell.
      // Put others in known_list or unknown_list
      // depending on if we can determine which shell
      // they go in using a geometric comparison.
    known_list.clean_out();
    unknown_list.clean_out();
      // Take all surfaces out of stack in this loop.
      // We might put some back in after the loop (thus
      // the outer loop.)
      surf = surf_stack.pop();
      PartitionShell* known_shell = 0;
      bool found_shell = false;
      loop = 0;
        do
          curve_coe = 0;
          while ( (curve_coe = curve->next_coedge(curve_coe)) )
            PartitionSurface* surf = curve_coe->get_loop()->get_surface();
            cosurf = 0;
            while ( (cosurf = surf->next_co_surface( cosurf )) )
              if( cosurf->get_shell() == shell1 ||
                  cosurf->get_shell() == shell2 )
                found_shell = true;
                if ( known_shell && known_shell != cosurf->get_shell() )
                  known_shell = 0;
                else
                  known_shell = cosurf->get_shell();
        } while( coedge != loop->first_coedge() );
      } // end while(loop)
        // This surface does not intersect the shell at
        // any curve.  We can't do this one yet.
      if ( !found_shell )
        unknown_list.append( surf );
        continue;
        // This surface intersected both shells at some
        // curves, but did not have a curve that intersected
        // only one shell.  We can do this one geometricly
        // if we have to.
      if ( !known_shell )
        continue;
        // If we got this far, then the surface had at least
        // one curve that intersected only one of the shells.
        // We know it goes in that shell.
      did_some = true;
      PartitionCoSurf* cosurf1 = surf->find_first((PartitionShell*)0);
      PartitionCoSurf* cosurf2 = surf->find_next(cosurf1);
      known_shell->add(cosurf1);
      known_shell->add(cosurf2);
    } // while(surf_stack)  -- the inside one
      // Unknown_list always goes back in surf_stack to
      // try again.
    surf_stack += unknown_list;
      // If we did some surfaces, then put the rest back
      // in surf_stack and try again.  If they intersect
      // one of the surfaces we did place in this iteration,
      // we can avoid needing to do geometric checks.
    if ( did_some )
      surf_stack += known_list;
      continue;
      // If known_list is empty, somethings wrong (we're
      // going to loop forever.)  Abort the loop and try
      // to recover as best we can.
    if( !known_list.size() )
      break;
      // choose a single surface in do a geometric comparison
      // for, and put the rest back in surf_stack
    surf = known_list.pop();
    bool in_shell = false;
    if ( ! inside_shell( shell2, surf, in_shell ) )
        // if inside_shell failed, abort.
      surf_stack.append(surf);
      break;
    PartitionShell* shell = in_shell ? shell2 : shell1;
    shell->add(surf->find_first((PartitionShell*)0));
    // something went wrong
  if( surf_stack.size() )
    PRINT_ERROR("Internal error splitting volume at %s:%d\n"
                "Topology may be invalid.  Please report this.\n",
                __FILE__, __LINE__);
    while( surf_stack.size() )
      PartitionSurface* surf = surf_stack.pop();
      cosurf = 0;
      while( (cosurf = surf->next_co_surface(cosurf)) )
        if( !cosurf->get_shell() )
          shell1->add(cosurf);
TBPoint * PartitionEngine::insert_point ( Curve curve,
double  u
Partition a curve
Parameters:
curveThe curve to partition
uThe location at which to split the curve.
Returns:
The new point created at the split location.
Definition at line 813 of file PartitionEngine.cpp.
  PartitionCurve* pcurve = dynamic_cast<PartitionCurve*>(curve);
  bool replaced_curve = false;
  if( !pcurve )
    if( CompositeCurve* comp = dynamic_cast<CompositeCurve*>(curve) )
      return CompositeEngine::instance().insert_point( comp, u );
    pcurve = replace_curve( curve );
    if( !pcurve )
      return 0;
    replaced_curve = true;
  CubitVector coords;
  if( ! pcurve->position_from_u( u, coords ) )
    if( replaced_curve )
      restore_curve( dynamic_cast<SubCurve*>(pcurve) );
    return 0;
  PartitionPoint* npoint = new PartitionPoint( coords, pcurve );
  PartitionCurve* ncurve = insert_point(pcurve, npoint);
  if( !ncurve )
    delete npoint;
    return 0;
  return npoint;
Partition a curve using the passed point.
Split a curve.
Used by restore_from_attrib(), insert_point(PartitionCurve*,double), and insert_point(CubitPointData*)
Parameters:
curveThe curve to split.
pointThe new point splitting the curve.
Returns:
The new curve.
Definition at line 863 of file PartitionEngine.cpp.
  const double TOLSQR = GEOMETRY_RESABS * GEOMETRY_RESABS;
  CubitVector coords = npoint->coordinates();
  double u = pcurve->u_from_position(coords);
  double u_min, u_max;
  pcurve->get_param_range( u_min, u_max );
  if(u_min > u_max)
    double dtemp = u_min;
    u_min = u_max;
    u_max = dtemp;
  if( u - u_min < CUBIT_RESABS || u_max - u < CUBIT_RESABS )
    return 0;
  if( (pcurve->start_point()->coordinates() - coords).length_squared() < TOLSQR
   || (pcurve->end_point()->coordinates() - coords).length_squared() < TOLSQR )
    return 0;
  PartitionCurve* ncurve = pcurve->split( u );
  if( !ncurve )
    return 0;
  ncurve->end_point( pcurve->end_point() );
  pcurve->end_point( npoint );
  ncurve->start_point( npoint );
  pcurve->fix_facet_data( ncurve );
  PartitionCoEdge *pcoedge = 0, *ncoedge = 0;
  while( (pcoedge = pcurve->next_coedge( pcoedge )) )
    ncoedge = new PartitionCoEdge( pcoedge );
    ncurve->add( ncoedge );
    if( pcoedge->get_loop() )
      if( pcoedge->sense() == CUBIT_FORWARD )
        pcoedge->get_loop()->insert_after( ncoedge, pcoedge );
      else
        pcoedge->get_loop()->insert_before( ncoedge, pcoedge );
  if( pcurve->owner() )
    pcurve->owner()->notify_split( ncurve, pcurve );
  return ncurve;
TBPoint * PartitionEngine::insert_point_curve ( Surface surf,
const CubitVector position,
Surface *&  partitioned_surf
Imprint a point on a surface, creating a zero-length (point) curve.
Parameters:
surfaceThe surface on which to create the point-curve
positionThe location on the surface at which to create the point.
Returns:
The point created (and owned by the point-curve). The point curve will be the only parent curve of this point.
Definition at line 3351 of file PartitionEngine.cpp.
  if ( CompositeSurface* csurf = dynamic_cast<CompositeSurface*>(surf) )
    TBPoint* result =
      CompositeEngine::instance().insert_point_curve(csurf, position);
    partitioned_surf = csurf;
    return result;
  bool replaced_surface = false;
  PartitionSurface* psurf = dynamic_cast<PartitionSurface*>(surf);
  if ( ! psurf ) {
    psurf = replace_surface(surf);
    replaced_surface = true;
    if ( ! psurf ) return 0;
  CubitPointData* facet_point = project_to_surface( psurf, position );
  if ( !facet_point ) {
    if( replaced_surface )
      restore_surface( dynamic_cast<SubSurface*>(psurf) );
    partitioned_surf = NULL;
    return 0;
  PartitionPoint* result = insert_point_curve( psurf, facet_point );
  if ( !result ) {
    return 0;
  PartitionCurve* curve = result->next_curve(0);
  if (replaced_surface && !dynamic_cast<PartPTCurve*>(curve))
    TBPoint* real = result->real_point();
    partitioned_surf = restore_surface( dynamic_cast<SubSurface*>(psurf) );
    if (real)
      result = dynamic_cast<PartitionPoint*>(real->owner());
      return result ? result : real;
  else
    partitioned_surf = psurf;
  return result;
Create a point curve
Create point-curve topology. After the surface facetting has been updated with the location of a point-curve, create the point curve given the facet point.
Called by insert_point_curve(ParttionSurface*, const CubitVector& )
Definition at line 3414 of file PartitionEngine.cpp.
    // If imprint at existing vertex, just return that vertex
  if ( TDVGFacetOwner::get(point) )
    return dynamic_cast<PartitionPoint*>(TDVGFacetOwner::get(point));
    // Check if imprint point is on a curve of the surface
  point->edges(edges);
  PartitionEntity* owner = 0;
  int owner_count = 0;
  int owner_edges = 0;
  while (edges.size())
    if (PartitionEntity* ent = TDVGFacetOwner::get(edges.pop()))
      if (owner != ent)
        owner_count++;
      owner = ent;
      owner_edges++;
    // If imprint is on curve, split the curve
  if (owner)
    PartitionCurve* curve = dynamic_cast<PartitionCurve*>(owner);
      // check valid facet configuration.  should be only one
      // owner, and owner should own exactly two of the adjacent
      // edges.  And owner should be a partition curve.
    if (!curve || owner_count != 1 || owner_edges != 2)
      PRINT_ERROR("Internal error at %s:%d\n  Invalid state.\n", __FILE__, __LINE__ );
      assert(0);
      return NULL;
    PartitionPoint* new_point = new PartitionPoint(point->coordinates(), curve);
    new_point->facet_point(point);
    curve = insert_point( curve, new_point );
    if (!curve)
      delete new_point;
      return 0;
    return new_point;
    // If here, point is in surface interior.  Create point-curve.
  PartitionPoint* new_point = new PartitionPoint( point->coordinates(), surf );
  PartPTCurve* new_curve = new PartPTCurve( surf );
  new_curve->start_point( new_point );
  new_curve->end_point( new_point );
  insert_point_curve( surf, new_curve );
  return new_point;
CubitStatus PartitionEngine::insert_point_curve ( PartitionSurface surface,
PartPTCurve curve,
bool  update_topology = true
) [private]
Definition at line 3477 of file PartitionEngine.cpp.
  PartitionCoEdge* new_coedge = new PartitionCoEdge( surf, CUBIT_FORWARD );
  new_curve->add( new_coedge );
  new_loop->insert_after( new_coedge, 0 );
  surf->add( new_loop );
  if ( surf->owner() && update_topology )
    surf->owner()->notify_topology_modified(surf);
Lump * PartitionEngine::insert_surface ( Surface surf_to_copy,
Lump lump
Partition a lump.
Create a new surface in the lump as a copy of the passed surface. This function may partition the lump if the surface copy divides a shell of the lump into two distinct regions.
Parameters:
surface_to_copyThe geometry from which to create the new surface
lumpThe lump into which the surface is to be inserted.
Returns:
If an error occured, the return value will be NULL. If the lump was split, the return value will be the new lump. Otherwise it will be the passed lump.
Definition at line 3503 of file PartitionEngine.cpp.
  GMem gmem;
  int i;
  CubitStatus status = surface->get_geometry_query_engine()->
    get_graphics( surface, &gmem );
  if( !status )
    PRINT_ERROR("PartitionEngine::insert_surface: GeometryEngine::"
                "get_graphics failed for surface.\n");
    return 0;
  int num_pts = gmem.pointListCount;
  CubitPointData** ptarray = new CubitPointData*[num_pts];
  GPoint *p_itor = gmem.point_list();
  GPoint *p_end = p_itor + num_pts;
  CubitPointData** array_itor = ptarray;
  for( ; p_itor < p_end; p_itor++, array_itor++ )
    *array_itor = new CubitPointData(CubitVector(p_itor->x,p_itor->y,p_itor->z));
  DLIList<CubitFacetData*> facets;
  int* f_itor = gmem.facet_list();
  int* f_end = f_itor + gmem.fListCount;
  i = 0;
  for( ; f_itor < f_end ; f_itor += (1 + *f_itor) )
    if( *f_itor != 3 )
      PRINT_ERROR("Non-triangular facet in PartitionEngine::insert_surface\n");
    else
      facets.append( new CubitFacetData(ptarray[f_itor[1]],
                                        ptarray[f_itor[2]],
                                        ptarray[f_itor[3]], &i) );
    // clean up any unused points
  for( i = 0; i < num_pts; i++ )
    if( ptarray[i]->num_adj_facets() == 0 )
      delete ptarray[i];
  delete [] ptarray;
    // create partition lump
  bool created_lump = false;
  PartitionLump* partlump = dynamic_cast<PartitionLump*>(lump);
  if( !partlump )
    created_lump = true;
    partlump = replace_lump(lump);
    assert(partlump != NULL);
    // Get vertex locations
  DLIList<CubitVector> coords;
  DLIList<TopologyBridge*> loops, coedges, curves, points, all_points;
  surface->get_children_virt(loops);
  while( loops.size() )
    loops.pop()->get_children( coedges, true, layer() - 1 );
    while ( coedges.size() )
      coedges.pop()->get_children_virt(curves);
      assert(curves.size() == 1);
      TopologyBridge* curve = curves.pop();
      curve->get_children( points, true, layer() - 1 );
      assert ( points.size() < 3 );
      all_points.merge_unique( points );
      points.clean_out();
  while( all_points.size() )
    coords.append(CubitVector( dynamic_cast<TBPoint*>(all_points.pop())->coordinates() ) );
  PartitionLumpImprint tool( partlump );
  DLIList<PartitionEntity*> new_entities;
  PartitionSurface* new_surf = tool.imprint( facets, coords, new_entities );
  if ( !new_surf )
    if( created_lump ) restore_lump(partlump);
    return 0;
  PartitionLump* result = insert_surface( partlump, new_surf );
  if( !result )
    destroy_surface( new_surf );
    if( created_lump ) restore_lump( partlump );
    return 0;
  return result;
Surface * PartitionEngine::insert_surface ( DLIList< CubitFacet * > &  facets,
Lump lump
Partition a lump.
Create a new surface in the lump from the passed facet patch. This function may partition the lump if the surface divides a shell of the lump into two distinct regions.
Parameters:
facetsThe geometry from which to create the new surface
Returns:
Definition at line 3598 of file PartitionEngine.cpp.
    // create partition lump and surface
  if( !partlump )
    if (!partlump)
      return 0;
  DLIList<PartitionEntity*> new_list;
  PartitionSurface* new_surf = tool.imprint( facets, new_list );
  if ( !new_surf )
    return 0;
  if( !result )
    return 0;
  return new_surf;
Insert a surface into a lump
Update lump topology for the creation of a new surface. Splits the lump if necessary.
Used by insert_surface(Surface*,Lump*) and restore_from_attrib(Lump*)
Parameters:
lumpThe lump to insert the surface in
surfThe surface to insert
Returns:
NULL if an error occured, the new lump if the passed lump was split, or the passed lump otherwise.
Definition at line 3643 of file PartitionEngine.cpp.
  assert( &(lump->sub_entity_set()) == &(surface->sub_entity_set()) );
    // Find all affected shells.  If any curve is not part of an
    // existing shell in the volume, set all_curves_connected to
    // false.  If any curve does not intersect the volume, then
    // the volume does not need to be split into two (or the surface
    // forms a new void in the volume.)
  bool all_curves_connected = true;
  DLIList<PartitionShell*> modified_list;
  PartitionCoEdge *coedge, *curve_coedge;
  while( (loop = surface->next_loop(loop)) )
    do {
      curve_coedge = 0;
      shell = 0;
      while( (curve_coedge = curve->next_coedge(curve_coedge)) )
        PartitionSurface* surf = curve_coedge->get_loop()->get_surface();
        cosurf = 0;
        while( (cosurf = surf->next_co_surface( cosurf )) )
          if( cosurf->get_shell()->get_lump() == lump )
            assert( !shell || cosurf->get_shell() == shell );
      if( shell )
        modified_list.append_unique(shell);
      else
        all_curves_connected = false;
    // Construct CoSurfaces
  PartitionCoSurf* cosurf1 = new PartitionCoSurf(CUBIT_FORWARD);
  PartitionCoSurf* cosurf2 = new PartitionCoSurf(CUBIT_REVERSED);
  surface->add(cosurf1);
  surface->add(cosurf2);
    // If there were no affected shells, we need to make a new
    // shell for a possible void in the volume.
  PartitionShell* shell_to_split = 0;
  if( modified_list.size() == 0 )
    shell_to_split = new PartitionShell();
    lump->add(shell_to_split);
      // If surface is closed, set all_curves_connected
      // to true to indicate that volume needs to be split.
      // (Creating a one-surface void in the volume.)
    loop = 0;
      do
        curve_coedge = 0;
        int coedge_count = 0;
          if( curve_coedge->get_loop() == loop )
            coedge_count++;
          else
            assert(curve_coedge->get_loop()->get_surface() != surface);
        if( coedge_count == 1 )
        else
          assert(coedge_count == 2);
    // Otherwise combine all the affected shells
  else
    modified_list.reverse();
    shell_to_split = modified_list.pop();
    while( modified_list.size() )
      shell = modified_list.pop();
        shell->remove(cosurf);
        shell_to_split->add(cosurf);
      delete shell;
  shell_to_split->add(cosurf1);
  shell_to_split->add(cosurf2);
    // If we don't need to split the volume, we are done
  if( !all_curves_connected )
    return lump;
    // We probably need to split the the lump...
  else
    return split_lump( shell_to_split );
CubitStatus PartitionEngine::inside_shell ( PartitionShell *const  shell,
bool &  result
) [private]
Test if a surface is on the inside of a shell.
Given a surface which shares at least one curve with the boundary of the shell (i.e. two non-manifold surfaces in the shell), determine if the surface is inside or outside of the shell.
This is a helper function for insert_nonmanifold_surfaces(..)
Definition at line 4310 of file PartitionEngine.cpp.
    // Find the curve and coedge at which the nonmanifold surface
    // intersects the shells
  PartitionCoEdge *nonman_coedge = 0;
  while ( !nonman_coedge && (loop = surf->next_loop(loop)) )
    PartitionCoEdge* loop_coedge = loop->first_coedge();
    do
        // Check if this curve is the curve of intersection
        // Iterate through curve coedges.
      PartitionCurve* curve = loop_coedge->get_curve();
      PartitionCoEdge* curve_coedge = 0;
      while ( (curve_coedge = curve->next_coedge(curve_coedge)) )
        PartitionSurface* coedge_surf = curve_coedge->get_loop()->get_surface();
        if( coedge_surf->find_first(shell) )
          nonman_coedge = curve_coedge;
          break;
      loop_coedge = loop->next_coedge(loop_coedge);
    } while( !nonman_coedge && loop_coedge != loop->first_coedge() );
  if ( !nonman_coedge ) // bad input!
    // There must exist two surfaces in the shell that are manifold
    // in the shell and that are adjacent to the curve
  PartitionCurve* common_curve = nonman_coedge->get_curve();
  PartitionCoSurf *cosurf1 = 0, *cosurf2 = 0, *cosurf;
  PartitionCoEdge *coedge1 = 0, *coedge2 = 0, *coedge = 0;
  while ( (coedge = common_curve->next_coedge(coedge)) )
    PartitionSurface* surf = coedge->get_loop()->get_surface();
    if ( (cosurf = surf->find_first(shell)) && !surf->find_next(cosurf) )
      if( coedge1 ) {
        coedge2 = coedge;
        cosurf2 = cosurf;
      } else {
        coedge1 = coedge;
        cosurf1 = cosurf;
  if ( !coedge1 || !coedge2 )
    // Evaluate normals at midpoint of curve
  CubitVector base, tangent, point;
  double u = (common_curve->start_param()+common_curve->end_param())/2.0;
  common_curve->position_from_u( u, base );
  common_curve->closest_point( base, point, &tangent );
  tangent.normalize();
  CubitVector normal1, normal2, normal;
  surf->closest_point( base, 0, &normal );
  cosurf1->get_surface()->closest_point( base, 0, &normal1 );
  cosurf2->get_surface()->closest_point( base, 0, &normal2 );
    // Try to handle tangencies
  bool fix1 = (normal1 * normal).length_squared() < CUBIT_RESABS;
  bool fix2 = (normal2 * normal).length_squared() < CUBIT_RESABS;
  if ( fix1 || fix2 )
    CubitVector dir = tangent * normal;
    double len = dir.length();
    assert(len > GEOMETRY_RESABS);
    dir /= len;
    if ( nonman_coedge->sense() == CUBIT_FORWARD )
      dir = -dir;
    CubitVector diag = surf->bounding_box().diagonal();
    if ( fix1 )
      CubitVector d = cosurf1->get_surface()->bounding_box().diagonal();
      if ( diag.x() < d.x() ) diag.x(d.x());
      if ( diag.y() < d.y() ) diag.y(d.y());
      if ( diag.z() < d.z() ) diag.z(d.z());
    if( fix2 )
      CubitVector d = cosurf2->get_surface()->bounding_box().diagonal();
    double step = 1e-3 * fabs( diag % dir );
    if ( step < 2*GEOMETRY_RESABS )
      step = 2*GEOMETRY_RESABS;
    for ( int i = 0; i < 1000; i++ )
      point = base + i * step * dir;
      if( fix1 )
      if( fix2 )
      bool done1 = !fix1 || (normal1 * normal).length_squared() > CUBIT_RESABS;
      bool done2 = !fix2 || (normal2 * normal).length_squared() > CUBIT_RESABS;
      if ( done1 && done2 )
        fix1 = fix2 = false;
        break;
  if ( fix1 || fix2 )
    PRINT_ERROR("Failed to adjust for surface tangencies.\n"
                "This is a BUG.  %s:%d\n", __FILE__, __LINE__ );
    normal = -normal;
  if ( cosurf1->sense() == coedge1->sense() )
    normal1 = -normal1;
  if ( cosurf2->sense() == coedge2->sense() )
    normal2 = -normal2;
  result = tangent.vector_angle(normal1, normal ) <=
           tangent.vector_angle(normal1, normal2);
Get singleton instance
Definition at line 117 of file PartitionEngine.cpp.
  if( instance_ == NULL )
    instance_ = new PartitionEngine();
    assert( instance_ != NULL );
  return *instance_;
bool PartitionEngine::is_composite ( TBOwner bridge_owner) [virtual]
Definition at line 752 of file PartitionEngine.cpp.
  return false;
bool PartitionEngine::is_composite ( TopologyBridge bridge) [virtual]
Definition at line 757 of file PartitionEngine.cpp.
  return false;
bool PartitionEngine::is_partition ( TBOwner bridge_owner) [virtual]
Definition at line 739 of file PartitionEngine.cpp.
  bool ret = false;
  if(bridge_owner)
    if(dynamic_cast<SubEntitySet*>(bridge_owner))
      ret = true;
  return ret;
int PartitionEngine::layer ( ) [inline]
Return layer in the TopologyBridge graph that this engine handles
Definition at line 220 of file PartitionEngine.hpp.
int PartitionEngine::level ( ) const [inline, virtual]
Definition at line 88 of file PartitionEngine.hpp.
Find or create the owning body for a new PartitionPoint
Definition at line 5865 of file PartitionEngine.cpp.
  if( pt->sub_entity_set().body() )
    return pt->sub_entity_set().body();
  if( pt->next_curve(0) )
    return make_body(pt->next_curve(0));
  return make_body_internal(pt);
Find or create the owning body for a new PartitionCurve
Definition at line 5843 of file PartitionEngine.cpp.
  if( curve->sub_entity_set().body() )
    return curve->sub_entity_set().body();
    if( coedge->get_loop() )
      return make_body(coedge->get_loop()->get_surface());
  return make_body_internal(curve);
Find or create the owning body for a new PartitionSurface
Definition at line 5823 of file PartitionEngine.cpp.
  if( surf->sub_entity_set().body() )
    return surf->sub_entity_set().body();
  if( surf->next_co_surface(0) )
    return make_body(surf->next_co_surface(0)->get_shell()->get_lump());
  return make_body_internal(surf);
Find or create the owning body for a new PartitionLump
Definition at line 5806 of file PartitionEngine.cpp.
  if( lump->get_body() )
    return lump->get_body();
  return make_body_internal( lump );
Common code used by make_body(..) methods.
Definition at line 5772 of file PartitionEngine.cpp.
    // query topology for BodySM
  DLIList<TopologyBridge*> list;
  BodySM* body;
  while( !(body = dynamic_cast<BodySM*>(bridge)) )
    list.clean_out();
    bridge->get_parents_virt(list);
    if( !list.size() )
      return 0;
    bridge = list.get();
  SubEntitySet* set = dynamic_cast<SubEntitySet*>(body->owner());
  if( set )
    return set->body();
  PartitionBody* result = new PartitionBody(body);
  if( body->owner() )
    body->owner()->swap_bridge( body, result, false );
  body->owner( &(result->sub_entity_set()) );
  return result;
PartitionCurve * PartitionEngine::next_curve_around_point ( PartitionSurface *const  surface,
CubitFacetEdgeData *const  edge,
CubitPointData *const  point,
const bool  backwards
) [private]
Helper function for find_coedges(..).
Use facet connectivity to find next/prev curve in loop.
Parameters:
surfaceThe owning surface
edgeA facet edge owned by the surface
pointThe facet point to search around
backwardsThe search direction (false for clockwise)
Returns:
The next curve in the specified order around the passed facet point.
Definition at line 1482 of file PartitionEngine.cpp.
  //PartitionCoEdge* result = 0;
  CubitFacetEdge* edge = start_edge;
  while ( edge->num_adj_facets() == 2 )
    CubitFacet* facet1 = edge->adj_facet(0);
    CubitFacet* facet2 = edge->adj_facet(1);
    assert (TDVGFacetOwner::get(facet1) == surface);
    assert (TDVGFacetOwner::get(facet2) == surface);
    bool edge_reversed = edge->point(1) == point;
    int facet_sense = edge_reversed == backwards ? -1 : 1;
    int facet1_index = facet1->edge_index(edge);
#ifndef NDEBUG
    int facet2_index = facet2->edge_index(edge);
    assert(facet1->edge_use(facet1_index) == -facet2->edge_use(facet2_index));
#endif
    if ( facet_sense == facet1->edge_use(facet1_index) )
      edge = facet1->next_edge_at_point( edge, point );
    else
      edge = facet2->next_edge_at_point( edge, point );
    assert(edge != start_edge);
    PartitionEntity* edge_owner = TDVGFacetOwner::get(edge);
    PartitionCurve* curve = dynamic_cast<PartitionCurve*>(edge_owner);
    if ( curve )
      return curve;
  return 0;
Definition at line 6318 of file PartitionEngine.cpp.
Definition at line 6321 of file PartitionEngine.cpp.
Definition at line 6330 of file PartitionEngine.cpp.
Definition at line 6336 of file PartitionEngine.cpp.
Definition at line 6342 of file PartitionEngine.cpp.
Implements IntermediateGeomEngine.
Definition at line 6167 of file PartitionEngine.cpp.
  return CUBIT_SUCCESS;
Definition at line 6173 of file PartitionEngine.cpp.
  int i;
  DLIList<Surface*> surfaces;
  DLIList<Curve*> curves;
  DLIList<TBPoint*> points;
  if (PartitionBody* body = dynamic_cast<PartitionBody*>(ent))
    DLIList<PartitionEntity*> ent_list;
    body->get_all_children( ent_list );
    CAST_LIST( ent_list, surfaces, PartitionSurface );
    CAST_LIST( ent_list, curves, PartitionCurve );
    CAST_LIST( ent_list, points, PartitionPoint );
  else
    if(BodySM* bodysm = dynamic_cast<BodySM*>(ent))
      DLIList<TopologyBridge*> lumps, shells, tmp_surfs;
      bodysm->get_children( lumps, true, layer() );
      while (lumps.size())
        lumps.pop()->get_children( shells, true, layer() );
        while (shells.size())
          tmp_surfs.clean_out();
          shells.pop()->get_children( tmp_surfs, true, layer() );
          while (tmp_surfs.size())
            surfaces.append( dynamic_cast<Surface*>(tmp_surfs.pop()) );
      surfaces.uniquify_ordered();
    else if(Surface* surf = dynamic_cast<Surface*>(ent))
    else if(Curve* curv = dynamic_cast<Curve*>(ent))
      curves.append( curv );
    else if(TBPoint* point = dynamic_cast<TBPoint*>(ent))
      points.append( point );
    if (surfaces.size())
      DLIList<TopologyBridge*> loops, coedges, tmp_curves;
      for (i = surfaces.size(); i--; )
        surfaces.get_and_step()->get_children( loops, true, layer() );
          loops.pop()->get_children( coedges, true, layer() );
          while (coedges.size())
            coedges.pop()->get_children( tmp_curves, true, layer() );
            while (tmp_curves.size())
              curves.append( dynamic_cast<Curve*>(tmp_curves.pop()) );
    if (curves.size())
      DLIList<TopologyBridge*> tmp_points;
      for (i = curves.size(); i--; )
        curves.get_and_step()->get_children( tmp_points, true, layer() );
        while (tmp_points.size())
          points.append( dynamic_cast<TBPoint*>(tmp_points.pop()) );
      points.uniquify_ordered();
  // see if the transformation is a reflection
  double det = xform.sub_matrix( 3, 3 ).determinant();
  bool reflection = det < 0.0;
  while (surfaces.size())
    PartitionSurface* surf = dynamic_cast<PartitionSurface*>(surfaces.pop());
    if (surf)
      surf->transform( xform );
  while (curves.size())
    PartitionCurve* curv = dynamic_cast<PartitionCurve*>(curves.pop());
    if (curv)
      curv->transform( xform );
      if (reflection)
        // PartitionSurface transform above reverses loops and coedges on Partition
        // surfaces.  Need to reverse sense of PartitionCoEdges in loops on non
        // partition surfaces
        // reverse the coedges of this curve
        PartitionCoEdge* p_coedge = 0;
        while ((p_coedge = curv->next_coedge(p_coedge)) != NULL)
          TopologyBridge* loop_bridge = p_coedge->find_parent_loop();
          if (loop_bridge)
            if (0 == dynamic_cast<PartitionLoop*>(loop_bridge))
              p_coedge->reverse_sense();
  while (points.size())
    PartitionPoint* pnt = dynamic_cast<PartitionPoint*>(points.pop());
    if (pnt)
      pnt->transform( xform );
CubitPointData * PartitionEngine::project_to_surface ( PartitionSurface surface,
) [private]
Project a point into the surface facetting
Project a position onto the facetting of a surface, updating the surface facetting to contain the resulting point.
Used by insert_point_curve(Surface*, const CubitVector&), and restore_from_attrib(Surface*)
Parameters:
surfaceThe surface to project onto.
positionThe position to project.
Returns:
The new facet point added to the surface facetting.
Definition at line 2771 of file PartitionEngine.cpp.
  CubitVector pos;
  CubitFacet* facet = surface->closest_facet( position, pos );
  surface->closest_point( position, &pos );
  CubitFacetData* facet_d = dynamic_cast<CubitFacetData*>(facet);
  assert(!!facet_d);
  CubitVector p[3], v[3], d[3];
  int i;
    // Initialize data
  double dist_tol_sqr = CUBIT_DBL_MAX;
  for ( i = 0; i < 3; i++ ) {
    p[i] = facet_d->point(i)->coordinates();
    v[i] = facet_d->point((i+1)%3)->coordinates() - p[i];
    double dist_sqr = v[i].length_squared();
    if ( dist_sqr < dist_tol_sqr )
      dist_tol_sqr = dist_sqr;
    d[i] = pos - p[i];
  dist_tol_sqr *= 0.2;
  if( dist_tol_sqr < GEOMETRY_RESABS*GEOMETRY_RESABS )
    dist_tol_sqr = GEOMETRY_RESABS*GEOMETRY_RESABS;
    // Check if we are within GEOMETRY_RESABS of a vertex of the
    // triangle or if one of the triangle vertices can be moved
    // to the input location.
  int closest_pt = -1;
  double closest_dist = dist_tol_sqr;
    double dist_sqr = d[i].length_squared();
    bool has_owner = (0 != TDVGFacetOwner::get(facet->point(i)));
    if( !has_owner && dist_sqr < closest_dist ) {
      pt_edges.clean_out();
      facet->point(i)->edges( pt_edges);
      while( pt_edges.size() )
        if ( TDVGFacetOwner::get(pt_edges.pop()) )
          has_owner = true;
    if ( (!has_owner && dist_sqr < closest_dist) ||
         dist_sqr < GEOMETRY_RESABS*GEOMETRY_RESABS ) {
      closest_pt = i;
      closest_dist = dist_sqr;
  if( closest_pt >= 0 )
    facet->point(closest_pt)->set(pos);
    return dynamic_cast<CubitPointData*>(facet->point(closest_pt));
    // Check if the input position is within GEOMETRY_RESABS of one
    // of the triangle edges or if the edge can be 'bent' such that
    // the split point is the input position.
  int closest_edge = -1;
    double t = (v[i] % d[i]) / v[i].length_squared();
    double dist_sqr = (d[i] - t * v[i]).length_squared();
    CubitFacetEdge* edge = facet->point(i)->shared_edge(facet->point((i+1)%3));
    bool has_owner = edge && TDVGFacetOwner::get(edge);
    if( (!has_owner && dist_sqr < closest_dist) ||
      CubitFacet* other_facet = 0;
      for ( int j = 0; j < edge->num_adj_facets(); j++ )
        if (edge->adj_facet(j) != facet &&
            TDVGFacetOwner::get(edge->adj_facet(j)) == surface)
          other_facet = edge->adj_facet(j);
          break;
      if (other_facet)
          // check if splitting the edge will invert some other facet
        int edge_index = other_facet->edge_index( edge );
        CubitVector other_pt = other_facet->point(edge_index)->coordinates();
        CubitVector prev_pt = other_facet->point((edge_index+1)%3)->coordinates();
        CubitVector next_pt = other_facet->point((edge_index+2)%3)->coordinates();
        prev_pt -= other_pt;
        next_pt -= other_pt;
        CubitVector norm = prev_pt * next_pt;
        CubitVector new_e = pos - other_pt;
        if ( norm.vector_angle_quick(prev_pt, new_e) > CUBIT_PI ||
             norm.vector_angle_quick(new_e, next_pt) > CUBIT_PI )
          continue;
          // don't create adjacent sliver facets
        double prev_t = prev_pt % new_e / prev_pt.length_squared();
        prev_pt *= prev_t;
        prev_pt += other_pt;
        if ( (prev_pt - pos).length_squared() < dist_sqr )
          continue;
        double next_t = next_pt % new_e / next_pt.length_squared();
        next_pt *= next_t;
        next_pt += other_pt;
        if ( (next_pt - pos).length_squared() < dist_sqr )
          continue;
      closest_edge = i;
  if( closest_edge >= 0 )
    CubitPoint* pt1 = facet->point(closest_edge);
    CubitPoint* pt2 = facet->point((closest_edge+1)%3);
    CubitFacetEdge* edge = pt1->shared_edge(pt2);
    CubitFacetEdge* new_edge;
    CubitFacet* new_facet;
    CubitPoint* new_point;
    PartSurfFacetTool::split_edge(edge, pos, 0, new_point, new_edge, new_facet );
    if (dynamic_cast<SubSurface*>(surface))
      surface->relax_to_geometry( new_point, &position );
    return dynamic_cast<CubitPointData*>(new_point);
  CubitFacet *new_tri1 = 0, *new_tri2 = 0;
  CubitPoint* pt1 = facet->point(0);
  CubitPoint* pt2 = facet->point(1);
  CubitPoint* pt3 = facet->point(2);
  CubitPoint* new_pt = facet->insert_point( pos, new_tri1, new_tri2 );
  new CubitFacetEdgeData( new_pt, pt1 );
  new CubitFacetEdgeData( new_pt, pt2 );
  new CubitFacetEdgeData( new_pt, pt3 );
  surface->notify_split( facet, new_tri1 );
  surface->notify_split( facet, new_tri2 );
    surface->relax_to_geometry( new_pt, &position );
  return dynamic_cast<CubitPointData*>(new_pt);
CubitStatus PartitionEngine::project_to_surface ( DLIList< CubitFacetData * > &  facets,
DLIList< CubitVector * > &  polyline_in,
DLIList< CubitFacetEdgeData * > &  polyline_out,
DLIList< CubitPointData * > &  polyline_pts,
) [private]
Project a polyline onto a facet patch.
Project a polyline onto a patch of facets. Modifies facets and updates owners of facets. The passed facet patch will no longer be valid after this operation. If necessary, the facets should be re-aquired from the owning geometry, which will have been updated appropriately.
Used by insert_curve(DLIList<Surface*>&, DLIList<CubitVector*>&, ...), and restore_from_attrib(Surface*)
Parameters:
facetsThe facet patch to project onto.
polyline_inThe polyline to project.
polyline_outThe resulting polyline created in the facetting.
polyline_ptsThe points in the facetting corresponding to each input position in polyline_in. List may contain NULL values.
Definition at line 2966 of file PartitionEngine.cpp.
  int i, j;
  unsigned u;
  PartitionSurface* p_adj_surf;
  PartitionCurve* p_curve = 0;
  PartitionEntity* p_owner;
  DLIList<PartitionSurface*> surfaces;
  for (i = cubit_facets.size(); i--; )
    surfaces.append_unique( dynamic_cast<PartitionSurface*>(TDVGFacetOwner::get(cubit_facets.step_and_get())));
    // get points
  DLIList<CubitPoint*> cubit_points(cubit_facets.size() * 3);
  DLIList<CubitFacet*> orig_facets;
  CAST_LIST_TO_PARENT(cubit_facets, orig_facets);
  FacetDataUtil::get_facet_points(orig_facets, cubit_points);
  // get bounding curves from the facets
  std::set<PartitionCurve*> boundary_curves;
  DLIList<CubitFacetEdge*> free_edges;
  FacetDataUtil::edges_by_count(orig_facets, 1, free_edges);
  free_edges.reset();
  for (i=free_edges.size(); i>0; i--)
    p_owner = TDVGFacetOwner::get(free_edges.get_and_step());
    p_curve = CAST_TO(p_owner, PartitionCurve);
    assert(!!p_curve); // every bounding edge should be owned by a curve
    boundary_curves.insert(p_curve);
  std::vector<double> facet_points(cubit_points.size() * 3);
  std::vector<int> simple_facets(cubit_facets.size() * 3);
  cubit_points.reset();
  for ( i = 0; i < cubit_points.size(); i++ )
    CubitPoint* pt = cubit_points.get_and_step();
    pt->marked( i );
    int j = i * 3;
    facet_points[j  ] = pt->coordinates().x();
    facet_points[j+1] = pt->coordinates().y();
    facet_points[j+2] = pt->coordinates().z();
    if (DEBUG_FLAG(145))
      GfxDebug::draw_point(pt->coordinates(), CUBIT_WHITE_INDEX);
      GfxDebug::draw_label(i, (float)(pt->coordinates().x()),
                              (float)(pt->coordinates().y()),
                              (float)(pt->coordinates().z()),
                              CUBIT_WHITE_INDEX);
  cubit_facets.reset();
  for ( i = 0; i < cubit_facets.size(); i++ )
    CubitFacetData* facet = cubit_facets.get_and_step();
    int j = i * 3;
    simple_facets[j  ] = facet->point(0)->marked();
    simple_facets[j+1] = facet->point(1)->marked();
    simple_facets[j+2] = facet->point(2)->marked();
      GfxDebug::draw_facet( facet, CUBIT_CYAN_INDEX );
      CubitVector c = facet->center();
      GfxDebug::draw_label( i, (float)(c.x()),
                               (float)(c.y()),
                               (float)(c.z()),
                               CUBIT_CYAN_INDEX);
      PRINT_DEBUG_145("%2d : %2d %2d %2d\n", i,
                                             facet->point(0)->marked(),
                                             facet->point(1)->marked(),
                                             facet->point(2)->marked());
    // clear point marks
    cubit_points.step_and_get()->marked(0);
    // reduce polyline resolution
  const double dist_tol = GEOMETRY_RESABS*GEOMETRY_RESABS;
  const double COS15 = 0.96592582628906831;
  const double angle_tol = COS15*COS15;
  DLIList<CubitVector*> polyline2;
  polyline.reset();
  CubitVector *prev = polyline.get_and_step();
  polyline2.append(prev);
  for( i = polyline.size() - 2; i--; )
    CubitVector *pt = polyline.get_and_step();
    CubitVector *next = polyline.get();
    CubitVector v1(*pt - *prev);
    CubitVector v2(*next - *pt);
    double len1 = v1.length_squared();
    double len2 = v2.length_squared();
    double dot = v1 % v2;
    if( len1 > dist_tol && len2 > dist_tol &&
        ((dot*dot)/(len1*len2)) < angle_tol )
      polyline2.append(pt);
      prev = pt;
  polyline2.append(polyline.get());
    // Call tool to do projection
  std::vector<double> new_facet_points;
  std::vector<int> dead_simple_facets, new_simple_facets,
                   facet_replacement, new_polyline, seg_pts;
  FacetProjectTool tool;
  if ( !tool.project( polyline, facet_points, simple_facets,
                      facet_replacement, new_facet_points,
                      new_polyline, seg_pts, tolerance_length ) )
    // output the map between input polyline positions and
    // facet points
    std::vector<int>::iterator iitor;
    for ( iitor = seg_pts.begin(); iitor != seg_pts.end(); ++iitor )
      int pt_index = *iitor;
      if ( pt_index == -1 )
        polyline_points.append(NULL);
      else
        CubitPointData* ptd = NULL;
        if(pt_index >= 0 && pt_index < cubit_points.size())
          CubitPoint* pt = cubit_points.next( pt_index );
          ptd = dynamic_cast<CubitPointData*>(pt);
        polyline_points.append(ptd);
    return CUBIT_FAILURE;
    // Convert back to CubitFacet rep
    // make new points
  assert( new_facet_points.size() % 3 == 0 );
  std::vector<CubitPointData*> new_cubit_points(new_facet_points.size()/3);
  std::vector<CubitPointData*>::iterator cpitor = new_cubit_points.begin();
  std::vector<double>::iterator ditor = new_facet_points.begin();
  for ( ; cpitor != new_cubit_points.end(); ++cpitor )
    double x = *ditor++;
    double y = *ditor++;
    double z = *ditor++;
    *cpitor = new CubitPointData(x,y,z);
    cubit_points.append(*cpitor);
    // make new facets
  int prev_index = 0;
  assert( new_simple_facets.size() % 3 == 0 );
  std::vector<CubitFacetData*> facet_list;
  std::vector<CubitFacetData*>::iterator fitor;
  std::vector<int>::iterator iitor = new_simple_facets.begin();
  int id=0; // dummy for CubitFacetData constructor
  for( u = 0; u < dead_simple_facets.size(); u++ )
      // get number of replacement facets
    int index = facet_replacement[u];
    int count = (index - prev_index) / 3;
    assert(((index - prev_index) % 3) == 0);
      // make a new list to hold data
    facet_list.clear();
    facet_list.resize(count+1);
    fitor = facet_list.begin();
      // put dead facet at beginning of list
    CubitFacetData* p_dead = cubit_facets.next(dead_simple_facets[u]);
    *fitor++ = p_dead;
    // get the surface that owns the dead facet
    p_owner = TDVGFacetOwner::get(p_dead);
    PartitionSurface* p_dead_surf = CAST_TO(p_owner, PartitionSurface);
    assert(!!p_dead_surf);
      // construct and append replacement facets
    for ( j=0; j < count; j++ )
      CubitPoint* pt1 = cubit_points.next( *iitor++ );
      CubitPoint* pt2 = cubit_points.next( *iitor++ );
      CubitPoint* pt3 = cubit_points.next( *iitor++ );
      *fitor++ = new CubitFacetData(pt1, pt2, pt3, &id);
      // set up for next iteration
    assert(fitor == facet_list.end());
    prev_index = index;
      // do something with "facet_list"
    DLIList<CubitFacetData*> old_facet_list;
    // fill edge replacement lists
    std::vector<CubitFacetEdgeData*> edge_lists[3];
    get_edge_replacements(facet_list, edge_lists);
    // update edges/facets on curves and adjacent surfaces
    CubitFacetEdgeData* old_edge;
    for (j=0; j<3; j++)
      DLIList<CubitFacetEdgeData*> new_edges;
      if (edge_lists[j].size()) // check for replacements
        std::vector<CubitFacetEdgeData*>::iterator eitor = edge_lists[j].begin();
        old_edge = *eitor++;
        p_owner = TDVGFacetOwner::get(old_edge);
        for (; eitor != edge_lists[j].end(); eitor++)
          new_edges.append(*eitor);
        assert(new_edges.size() > 1); // shouldn't ever get 1 to 1 replacement here
        // split facets on adjacent surfaces if the split crosses a curve
        // on the outside boundary of the facets
        if (boundary_curves.find(p_curve) != boundary_curves.end())
          // get facets to be replaced on adjacent surf
          DLIList<CubitFacetData*> adj_facets;
          DLIList<CubitFacet*> tmp_list;
          old_edge->facets(tmp_list);
          CAST_LIST(tmp_list, adj_facets, CubitFacetData);
          if (adj_facets.size() > 1)
            DLIList<CubitFacetData*> adj_replacements;
            int i_adj;
            for (i_adj=adj_facets.size(); i_adj>0; i_adj--)
              CubitFacetData* p_adjacent = adj_facets.get_and_step();
              if (p_adjacent == p_dead)
                continue;
              // create replacement facets
              adj_replacements.clean_out();
              // get the point opposite the edge being replaced
              int e_index = p_adjacent->edge_index(old_edge);
              bool old_reversed = -1 == p_adjacent->edge_use(e_index);
              CubitPoint* prev_pt = NULL;
              //if old_reversed is false, the new_edge' reversed flag is true
              int old_prev_pt_index;
              if (old_reversed)
                 prev_pt = old_edge->point(0);
                 old_prev_pt_index = 0;
              else
                 prev_pt = old_edge->point(1);
                 old_prev_pt_index = 1;
              CubitPoint* opposite_pt = p_adjacent->point(e_index);
              //CubitPoint* opposite_pt = p_adjacent->point(p_adjacent->edge_index(old_edge)); // opposite edge and point have same index
              new_edges.reset();
              int i_new;
              for (i_new=new_edges.size(); i_new>0; i_new--)
                CubitFacetEdge* p_edge = new_edges.get_and_step();
                prev_pt = p_edge->other_point(prev_pt);
                assert(!!prev_pt);
                bool new_reversed = p_edge->point(old_prev_pt_index) == prev_pt;
                int reversed = (int)(new_reversed != old_reversed);
                CubitFacetData* p_facet = new CubitFacetData(p_edge->point(reversed),
                                                             p_edge->point(1-reversed),
                                                             opposite_pt, &id);
                adj_replacements.append(p_facet);
              p_owner = TDVGFacetOwner::get(p_adjacent);
              p_adj_surf = CAST_TO(p_owner, PartitionSurface);
              assert(!!p_adj_surf);
              old_facet_list.clean_out();
              old_facet_list.append(p_adjacent);
              p_adj_surf->replace_facets(old_facet_list, adj_replacements);
              delete_facet( p_adjacent );
        // replace the curve edges
        p_curve->replace_facet(old_edge, new_edges);
        // Don't delete edge yet.  It's still connected to
        // at least one facet.  Wait 'till the facet is deleted.
        //delete old_edge;
    // replace dead facet
    fitor++; // skip dead facet
    DLIList<CubitFacetData*> new_facets;
    for (; fitor != facet_list.end(); fitor++)
      new_facets.append(*fitor);
    old_facet_list.append(p_dead);
    p_dead_surf->replace_facets(old_facet_list, new_facets);
    delete_facet(p_dead);
  assert(iitor == new_simple_facets.end());
  // output the edges that make up the projected curve
  iitor = new_polyline.begin();
  while( *iitor )
    int count = *iitor++;
    CubitPoint* prev_point = cubit_points.next( *iitor++ );
    for ( i = 1; i < count; i++ ) {
      CubitPoint* pt = cubit_points.next( *iitor++ );
      CubitFacetEdge* edge = prev_point->shared_edge(pt);
      CubitFacetEdgeData* edge_d = dynamic_cast<CubitFacetEdgeData*>(edge);
      assert(!!edge_d);
      if (TDVGFacetOwner::get(edge_d))
        polyline_out.append(0);
      else
        if (edge_d->point(0) == pt)
          edge_d->flip();
        polyline_out.append(edge_d);
      prev_point = pt;
  // facet points
    else
      assert(pt_index >= 0 && pt_index < cubit_points.size());
      CubitPointData* ptd = dynamic_cast<CubitPointData*>(pt);
      assert(!!ptd);
virtual void PartitionEngine::push_imprint_attributes_before_modify ( DLIList< BodySM * > &  body_sms) [inline, virtual]
Definition at line 73 of file PartitionEngine.hpp.
virtual void PartitionEngine::push_named_attributes_to_curves_and_points ( DLIList< TopologyBridge * > &  tb_list,
const char *  name_in
) [inline, virtual]
Definition at line 75 of file PartitionEngine.hpp.
Definition at line 6142 of file PartitionEngine.cpp.
  BodySM* body = ent->real_body();
  if (!body->get_geometry_query_engine()->reflect( body, axis ))
  CubitTransformMatrix xform;
  xform.reflect( axis );
  notify_transform_internal( ent, xform );
Definition at line 6081 of file PartitionEngine.cpp.
  GeometryEntity* geom = dynamic_cast<GeometryEntity*>(ent->partitioned_entity());
  if (!geom->get_geometry_query_engine()->reflect( geom, axis ))
  notify_transform_internal( geom, xform );
void PartitionEngine::remove_attributes ( DLIList< TopologyBridge * > &  bridge_list) [virtual]
Definition at line 6300 of file PartitionEngine.cpp.
  //for each SubEntitySet in map, change it's unique id to zero
  std::map<int,SubEntitySet*>::iterator itor = uniqueIdMap.begin();
  while( itor != uniqueIdMap.end() )
    if(itor->second->get_entity())
      SubEntitySet::strip_attributes( itor->second->get_entity() );
      itor->second->reset_unique_id();
    itor++;
  //clean out the map
  uniqueIdMap.clear();
virtual void PartitionEngine::remove_attributes_from_unmodifed_virtual ( DLIList< TopologyBridge * > &  bridges) [inline, virtual]
Definition at line 78 of file PartitionEngine.hpp.
Surface * PartitionEngine::remove_curve ( PartitionCurve curve,
PartitionSurface dead_surfs[2] = 0
Undo surface partitioning
Remove a previously inserted split curve.
Parameters:
curveThe curve to remove.
dead_surfsIf non-null, will be populated with pointers to any surfaces destroyed by this operation.
Returns:
The surviving surface.
Definition at line 1533 of file PartitionEngine.cpp.
  if( dead_surfs )
    dead_surfs[0] = dead_surfs[1] = 0;
  PartPTCurve* point_curve = dynamic_cast<PartPTCurve*>(passed_curve);
  if( point_curve )
      point_curve->next_coedge(0)->get_loop()->get_surface();
    if( !remove_point_curve( point_curve->start_point() ) )
      return 0;
    SubSurface* subsurf = dynamic_cast<SubSurface*>(surf);
    if( subsurf && !subsurf->next_co_surface() &&
        !subsurf->sub_entity_set().has_lower_order() )
      Surface* result = restore_surface( subsurf );
      if( result && dead_surfs )
        dead_surfs[0] = subsurf;
      return result;
    else
      return surf;
  SegmentedCurve* curve = dynamic_cast<SegmentedCurve*>(passed_curve);
  if( !curve )
    assert(0);
    assert( dynamic_cast<SubCurve*>(passed_curve) );
    PartitionCoEdge* coedge1 = passed_curve->next_coedge(0);
    PartitionCoEdge* coedge2 = passed_curve->next_coedge(coedge1);
    if( !coedge2 || passed_curve->next_coedge(coedge2) )
      return 0;
    DLIList<TopologyBridge*> surfaces;
    coedge1->find_parent_loop()->get_parents_virt( surfaces );
    fix_up_query_results( surfaces );
    assert( surfaces.size() == 1 );
    Surface* surface1 = dynamic_cast<Surface*>(surfaces.get());
    surfaces.clean_out();
    coedge2->find_parent_loop()->get_parents_virt( surfaces );
    Surface* surface2 = dynamic_cast<Surface*>(surfaces.get());
    SubSurface* surf1 = dynamic_cast<SubSurface*>(surface1);
    SubSurface* surf2 = dynamic_cast<SubSurface*>(surface2);
    if( surface1 == surface2 )
      if( !surf1 )
        surf1 = surf2 = replace_surface( surface1 );
    else
      if( !surf1 )
        surf1 = replace_surface( surface1 );
      if( !surf2 )
        surf2 = replace_surface( surface2 );
      // create SegmentedCurves from SubCurves
    CompositeEngine::instance()->
      remove_curve( dynamic_cast<Curve*>(passed_curve->partitioned_entity()) );
  DLIList<TopologyBridge*> tb_list;
    // get two coedges to remove
  curve->get_parents_virt( tb_list );
  if( tb_list.size() != 2 )
    return 0;
  PartitionCoEdge* coedge1 = dynamic_cast<PartitionCoEdge*>(tb_list.get_and_step());
  PartitionCoEdge* coedge2 = dynamic_cast<PartitionCoEdge*>(tb_list.get_and_step());
  assert( coedge1 && coedge2 );
    // get two loops and surfaces
  PartitionLoop* loop1 = coedge1->get_loop();
  PartitionLoop* loop2 = coedge2->get_loop();
  PartitionSurface* surf1 = loop1->get_surface();
  PartitionSurface* surf2 = loop2->get_surface();
  assert( surf1 && surf2 );
    // surfaces must be partitions of the same real surface
  if( surf1->partitioned_entity() != surf2->partitioned_entity() )
    return 0;
    // surfaces must have same parent shells
  while( (cos = surf1->next_co_surface( cos )) )
    if( ! surf2->find_first( cos->get_shell(), cos->sense() ) )
      return 0;
    // same loop : remove a sipe or split a loop
  if( loop1 == loop2 )
    if( loop1->next_coedge( coedge1 ) != coedge2 &&
        loop1->prev_coedge( coedge1 ) != coedge2 )
      PartitionCoEdge* coedge = loop1->next_coedge( coedge1 );
      PartitionCoEdge* prev = 0;
      while( coedge != coedge2 )
        loop1->remove( coedge );
        loop2->insert_after( coedge, prev );
        prev = coedge;
      surf1->add( loop2 );
    loop1->remove( coedge1 );
    loop1->remove( coedge2 );
    if( loop1->first_coedge() == 0 )
      surf1->remove( loop1 );
      delete loop1;
    // stitch loops
  else
      // insert coedges
    while( loop2->next_coedge(coedge2) != coedge2 ) // all but the dead one
      PartitionCoEdge* coedge = loop2->next_coedge( coedge2 );
      loop2->remove( coedge );
      loop1->insert_before( coedge, coedge1 );
    loop2->remove( coedge2 );
    assert( loop2->first_coedge() == 0 );
    surf2->remove( loop2 );
    if( loop1->num_coedges() == 0 )
      delete loop1;
    delete loop2;
  curve->remove( coedge1 );
  curve->remove( coedge2 );
  delete coedge1;
  delete coedge2;
  PartitionPoint* start_pt = curve->start_point();
  PartitionPoint* end_pt = curve->end_point();
  delete curve;
  if ( !start_pt->next_curve() )
    if ( start_pt->real_point() )
      restore_point(start_pt);
    else
      delete start_pt;
  if ( end_pt != start_pt && !end_pt->next_curve() )
    if ( end_pt->real_point() )
      restore_point(end_pt);
    else
      delete end_pt;
    // need to combine surfaces?
  if( surf1 != surf2 )
    surf1->combine( surf2 );
    while( PartitionLoop* loop = surf2->next_loop() )
      surf2->remove( loop );
      surf1->add( loop );
    while( PartitionCoSurf* cos = surf2->next_co_surface() )
      if( cos->get_shell() )
        cos->get_shell()->remove( cos );
      surf2->remove( cos );
      delete cos;
    if( dead_surfs )
      dead_surfs[0] = surf2;
    delete surf2;
    // can remove partition surface?
  SubSurface* subsurf = dynamic_cast<SubSurface*>(surf1);
    if( dead_surfs )
      if( dead_surfs[0] )
        dead_surfs[1] = surf1;
      else
        dead_surfs[0] = surf1;
    return restore_surface( subsurf );
  else
    return surf1;
Remove SubEntitySet from ID map (used for save/restore
Definition at line 154 of file PartitionEngine.cpp.
  std::map<int,SubEntitySet*>::iterator itor = uniqueIdMap.find(id);
  if( itor == uniqueIdMap.end() || itor->second != set )
    { assert(0); return CUBIT_FAILURE; }
  uniqueIdMap.erase(itor);
virtual void PartitionEngine::remove_imprint_attributes_after_modify ( DLIList< BodySM * > &  old_sms,
DLIList< BodySM * > &  new_sms
) [inline, virtual]
Definition at line 70 of file PartitionEngine.hpp.
void PartitionEngine::remove_modified ( DLIList< Surface * > &  all_surfs,
DLIList< Curve * > &  all_curves,
DLIList< TBPoint * > &  all_pts
) [virtual]
Definition at line 6351 of file PartitionEngine.cpp.
Curve * PartitionEngine::remove_point ( PartitionPoint point,
PartitionCurve dead_curves[2] = 0
Undo curve partitioning or point-curve creation.
Parameters:
pointThe point to remove.
dead_curvesIf non-null, polulated with pointers to the destroyed PartitionCurves (pointers are by definition stale pointers.)
Returns:
The surviving curve, or null if a point-curve was removed..
Definition at line 924 of file PartitionEngine.cpp.
  if( dead_curves )
    dead_curves[0] = dead_curves[1] = 0;
  if( point->num_curves() > 2 )
    return 0;
  DLIList<TopologyBridge*> curve_bridges;
  point->get_parents_virt( curve_bridges );
  if( curve_bridges.size() > 2 )
    return 0;
  if( curve_bridges.size() == 1 )
    PartPTCurve* point_curve = dynamic_cast<PartPTCurve*>(curve_bridges.get());
    if( ! point_curve )
      return 0;
    if( dead_curves )
      dead_curves[0] = point_curve;
    remove_point_curve( point );
    return 0;
  TopologyBridge* real = point->partitioned_entity();
  if( dynamic_cast<TBPoint*>(real) )
    Curve* curve1 = dynamic_cast<Curve*>(curve_bridges.get());
    Curve* curve2 = dynamic_cast<Curve*>(curve_bridges.next());
    PartitionCurve* pc1 = dynamic_cast<PartitionCurve*>(curve1);
    PartitionCurve* pc2 = dynamic_cast<PartitionCurve*>(curve2);
    assert( pc1 || pc2 );
    if( !pc1 )
      pc1 = replace_curve( curve1 );
    if( !pc2 )
      pc2 = replace_curve( curve2 );
    CompositeEngine::instance()->remove_point( dynamic_cast<TBPoint*>(real) );
    bool reverse = ( pc1->start_point() == pc2->start_point() ||
                     pc2->end_point() == pc2->end_point() );
    if( pc1->partitioned_entity() == 0 )
      bool prepend = false;
      if( pc1->other_point( pc2->start_point() ) )
        prepend = true;
      pc2->sub_entity_set().merge( pc1->sub_entity_set(), reverse, prepend );
    else if( pc2->partitioned_entity() == 0 )
      if( pc2->other_point( pc1->start_point() ) )
        prepend = true;
      pc1->sub_entity_set().merge( pc2->sub_entity_set(), reverse, prepend );
    else
      return 0;
  if( point->num_curves() != 2 )
    return 0;
  PartitionCurve* survivor = point->next_curve(0);
  PartitionCurve* casualty = point->next_curve(survivor);
  if( survivor->start_point() == point &&
      casualty->end_point() == point )
      // swap
    survivor = casualty;
    casualty = point->next_curve(0);
  if( ! survivor->combine( casualty ) )
    return 0;
  PartitionPoint* other_pt =
    casualty->start_point() == point ?
    casualty->end_point() : casualty->start_point();
  casualty->start_point(0);
  casualty->end_point(0);
  if( survivor->start_point() == point )
    survivor->start_point( other_pt );
  else
    survivor->end_point( other_pt );
  delete point;
  while( PartitionCoEdge* coedge = casualty->next_coedge(0) )
      coedge->get_loop()->remove( coedge );
    casualty->remove( coedge );
    delete coedge;
  delete casualty;
  if( dead_curves )
    dead_curves[0] = casualty;
  Curve* result = survivor;
  SubCurve* subcurve = dynamic_cast<SubCurve*>(survivor);
  if( subcurve && !survivor->sub_entity_set().has_multiple_sub_entities() )
    Curve* real_curve = restore_curve( subcurve );
    if (real_curve)
      result = real_curve;
      if (dead_curves)
        dead_curves[1] = survivor;
  return result;
Remove a point-curve
Definition at line 1050 of file PartitionEngine.cpp.
  if( point->num_curves() != 1 )
  PartPTCurve* curve = dynamic_cast<PartPTCurve*>(point->next_curve(0));
  if( !curve )
  PartitionSurface* surf = 0;
  if( curve->num_coedges() )
    assert( curve->num_coedges() == 1 );
    PartitionCoEdge* coedge = curve->next_coedge(0);
    PartitionLoop* loop = coedge->get_loop();
    if( loop )
      surf = loop->get_surface();
      surf->remove( loop );
      assert( loop->num_coedges() == 0 );
      delete loop;
    curve->remove( coedge );
    delete coedge;
  curve->start_point(0);
  curve->end_point(0);
  delete curve;
  delete point;
  if( surf && surf->owner() )
    surf->owner()->notify_topology_modified( surf );
Undo lump partitioning
Remove a previously inserted split surface.
Parameters:
surfaceThe surface to remove.
Returns:
The surviving lump.
Definition at line 4464 of file PartitionEngine.cpp.
    // If surface belongs to non-partition volumes, we cannot proceed.
  DLIList<TopologyBridge*> shell_bridges;
  surface->get_parents_virt( shell_bridges );
  while( shell_bridges.size() )
    if( ! dynamic_cast<PartitionShell*>(shell_bridges.pop()) )
      return 0;
  PartitionCoSurf* cosurf1 = surface->next_co_surface(0);
  if( ! cosurf1 )
    return 0; // doesn't belong to any PartitionLumps;
  PartitionCoSurf* cosurf2 = surface->next_co_surface(cosurf1);
  if( !cosurf2 || surface->next_co_surface(cosurf2) )
    return 0; // must have exactly two parent cosurfaces.
  PartitionShell* shell1 = cosurf1->get_shell();
  PartitionShell* shell2 = cosurf2->get_shell();
  PartitionLump* lump1 = shell1->get_lump();
  PartitionLump* lump2 = shell2->get_lump();
  if( surface->partitioned_entity() != lump1->partitioned_entity() )
    return 0; // shouldn't have gotten this far, but just in case ...
    // remove and destroy surface
  shell1->remove( cosurf1 );
  shell2->remove( cosurf2 );
  surface->remove(cosurf1);
  surface->remove(cosurf2);
  delete cosurf1;
  delete cosurf2;
  destroy_surface(surface);
    // combine volumes?
  if( shell1 != shell2 )
    assert(lump1 != lump2);
    while( PartitionCoSurf* cosurf = shell2->next_co_surface(0) )
      shell2->remove(cosurf);
    lump2->remove(shell2);
    delete shell2;
    if( !shell1->next_co_surface(0) )
      lump1->remove(shell1);
      delete shell1;
    while( PartitionShell* shell = lump2->next_shell(0) )
      lump2->remove(shell);
      lump1->add(shell);
    delete lump2;
    // one-surface shell
  else if( !shell1->next_co_surface(0) )
    lump1->remove( shell1 );
    delete shell1;
    // possibly split shells
  else
    PartitionShell* shell = split_shell( shell1 );
    if( shell )
      lump1->add(shell);
  if( !lump1->sub_entity_set().has_lower_order() )
    return restore_lump( lump1 );
  else
    return lump1;
SubCurve * PartitionEngine::replace_curve ( Curve curve) [private]
Replicate topology in partition layer
Definition at line 187 of file PartitionEngine.cpp.
  SubCurve* result = dynamic_cast<SubCurve*>(curve);
  if( result )
    return result;
  if( dynamic_cast<SegmentedCurve*>(curve) )
    return 0;
  //curve->get_children_virt( list );
  //fix_up_query_results( list );
  curve->get_children(list, false, layer());
  PartitionPoint *start_pt = 0, *end_pt = 0;
  bool new_start = false, new_end = false;
  list.reset();
  TopologyBridge* bridge = list.get_and_step();
  start_pt = dynamic_cast<PartitionPoint*>(bridge);
  if( ! start_pt )
    start_pt = replace_point( dynamic_cast<TBPoint*>(bridge) );
    if( ! start_pt )
      return 0;
    new_start = true;
  if( list.size() == 1 )
    end_pt = start_pt;
  else if( list.size() == 2 )
    end_pt = dynamic_cast<PartitionPoint*>(bridge);
    if( !end_pt )
      end_pt = replace_point( dynamic_cast<TBPoint*>(bridge) );
      new_end = true;
      if( !end_pt )
        if( new_start )
          restore_point( start_pt );
        return 0;
  assert( start_pt && end_pt );
  result = new SubCurve( curve );
  if( ! result->start_point( start_pt ) ||
      ! result->end_point( end_pt ) )
    result->start_point(0);
    result->end_point(0);
    delete result;
    if( new_start )
    if( new_end )
      restore_point( end_pt );
    return 0;
  if( curve->owner() )
    curve->owner()->swap_bridge(curve, result, false);
  curve->owner(&(result->sub_entity_set()));
  list.clean_out();
  curve->get_parents_virt( list );
  for( int i = list.size(); i--; )
    CoEdgeSM* coedge = dynamic_cast<CoEdgeSM*>(bridge);
    assert( coedge != NULL );
    PartitionCoEdge* pcoedge = new PartitionCoEdge( coedge );
    CubitStatus s = result->add( pcoedge );
    assert( s );
    if (CUBIT_SUCCESS != s) {
      PRINT_ERROR("Failed to add coedge to SubCurve.\n");
      return NULL;
    if( coedge->owner() )
      coedge->owner()->swap_bridge(coedge, pcoedge, false);
    coedge->owner(&(pcoedge->sub_entity_set()));
  PartitionBody* body = 0;
  if( result->start_point()->sub_entity_set().body() )
    body = result->start_point()->sub_entity_set().body();
  else if( result->end_point()->sub_entity_set().body() )
    body = result->end_point()->sub_entity_set().body();
  else
    body = make_body(result);
  if( body )
    if( !result->start_point()->sub_entity_set().body() )
      body->add(result->start_point()->sub_entity_set());
    if( !result->end_point()->sub_entity_set().body() )
      body->add(result->end_point()->sub_entity_set());
    body->add(result->sub_entity_set());
    PartitionCoEdge* coedge = 0;
    while ( (coedge = result->next_coedge(coedge)) )
      if ( !coedge->sub_entity_set().body() )
        body->add(coedge->sub_entity_set());
  // we must notify the graphics of the modify from "real" to virtual -- KGM
  // I realize that this is not where the other notifies are completed but there
  // is no knowledge of the change later on.
  CubitObservable* observable = dynamic_cast<CubitObservable*>(result->topology_entity());
  if (observable)
     AppUtil::instance()->send_event(GeometryEvent(GeometryEvent::GEOMETRY_MODIFIED, dynamic_cast<RefEntity*>(result->topology_entity())));
  return result;
Definition at line 416 of file PartitionEngine.cpp.
  int i, j;
  PartitionLump* result = dynamic_cast<PartitionLump*>(lump);
  if( result )
    return result;
  DLIList<TopologyBridge*> shell_list, surface_list;
  lump->get_children( shell_list, false, layer() );
  DLIList<PartitionShell*> new_shells;
  shell_list.reset();
  for( i = shell_list.size(); i--; )
    ShellSM* shell = dynamic_cast<ShellSM*>(shell_list.get_and_step());
    PartitionShell* pshell = new PartitionShell();
    new_shells.append(pshell);
    if( shell->owner() )
      shell->owner()->swap_bridge( shell, pshell, false );
    shell->owner(0);
    surface_list.clean_out();
    shell->get_children( surface_list, false, layer() );
    surface_list.reset();
    for( j = surface_list.size(); j--; )
      Surface* surface = dynamic_cast<Surface*>(surface_list.get_and_step());
      PartitionSurface* psurf = dynamic_cast<PartitionSurface*>(surface);
      if( !psurf )
        psurf = replace_surface( surface );
        if (!psurf)
          while (new_shells.size())
            destroy_shell(new_shells.pop());
          return 0;
      Surface* real_surf = dynamic_cast<Surface*>(psurf->partitioned_entity());
      assert(!!real_surf);
      CubitSense sense = real_surf->get_shell_sense(shell);
      assert(sense == CUBIT_FORWARD || sense == CUBIT_REVERSED);
      pshell->add( psurf, sense );
  result = new PartitionLump( lump );
  if( lump->owner() )
    lump->owner()->swap_bridge(lump, result, false);
  lump->owner(&(result->sub_entity_set()));
  new_shells.reverse();
  while( new_shells.size() )
    result->add(new_shells.pop());
  PartitionBody* body = make_body(result);
  if( body )
    body->add( result->sub_entity_set() );
  return result;
Definition at line 488 of file PartitionEngine.cpp.
  PartitionPoint* result = dynamic_cast<PartitionPoint*>(point);
  if( !result )
    result = new PartitionPoint( point );
  if( result )
    if( point->owner() )
      point->owner()->swap_bridge( point, result, false );
    point->owner( &(result->sub_entity_set()) );
  return result;
Definition at line 318 of file PartitionEngine.cpp.
  int i, j;
  // check if the input surface is already a SubSurface
  SubSurface* result = dynamic_cast<SubSurface*>(surface);
  if( result )
    return result;
  // check if the input surface is already a PartitionSurface
  if( dynamic_cast<PartitionSurface*>(surface) )
    return 0;
  // create a new SubSurface, swap out the TBOwner if it
  // exists and reset the input surface TBOwner.
  DLIList<TopologyBridge*> loop_list, coe_list, curve_list;
  surface->get_children( loop_list, false, layer() );
  result = new SubSurface( surface );
  if( surface->owner() )
    surface->owner()->swap_bridge(surface, result, false);
  surface->owner(&(result->sub_entity_set()));
  // Add the loop onto the new surface
  loop_list.reset();
  for( i = loop_list.size(); i--; )
    LoopSM* loop = dynamic_cast<LoopSM*>(loop_list.get_and_step());
    PartitionLoop* partloop = new PartitionLoop();
    result->add( partloop );
    if( loop->owner() )
      loop->owner()->swap_bridge( loop, partloop, false );
    loop->owner(0);
    // Take care of the curves in the loop
    coe_list.clean_out();
    loop->get_children( coe_list, false, layer() );
    coe_list.reset();
    for( j = coe_list.size(); j--; )
      CoEdgeSM* coedge = dynamic_cast<CoEdgeSM*>(coe_list.get_and_step());
      if(!dynamic_cast<PartitionCoEdge*>(coedge) &&
         !dynamic_cast<SubEntitySet*>(coedge->owner()) )
        curve_list.clean_out();
        coedge->get_children_virt( curve_list );
        assert( curve_list.size() == 1 );
        Curve* curve = dynamic_cast<Curve*>(curve_list.get());
        assert(! dynamic_cast<PartitionCurve*>(curve) );
        SubCurve* pcurve = replace_curve( curve );
        assert(pcurve != NULL);
        if (NULL == pcurve) {
          PRINT_ERROR("Failed to replace curve.\n");
          return NULL;
    coe_list.reset();
    PartitionCoEdge *curr, *prev = 0;
    coe_list.reset();
      curr = dynamic_cast<PartitionCoEdge*>(coe_list.get_and_step());
      assert( curr != NULL );
      partloop->insert_after( curr, prev );
      prev = curr;
  // If the facet data is incorrect put everything back
  if (!result->init_facet_data()) {
    restore_surface( result );
    return 0;
  // finalize by making the body
  if( body )
  return result;
Curve * PartitionEngine::restore_curve ( SubCurve curve) [private]
Remove partition layer topolgy and restore real topology
Definition at line 544 of file PartitionEngine.cpp.
  if( curve->num_partitions() > 1 )
    return 0;
  while( (coedge = curve->next_coedge( coedge )) )
      return 0;
  while( (coedge = curve->next_coedge(0)) )
    CoEdgeSM* real_coedge = coedge->real_coedge();
    if( real_coedge )
      coedge->sub_entity_set().remove_bridge( real_coedge );
        coedge->owner()->swap_bridge( coedge, real_coedge, false );
    delete coedge;
  PartitionPoint* start = curve->start_point();
  curve->start_point( 0 );
  if( start->num_curves() == 0 )
    if( start->real_point() )
      restore_point( start );
    else
      delete start;
  PartitionPoint* end = curve->end_point();
  if( end->num_curves() == 0 )
    if( end->real_point() )
      restore_point( end );
    else
      delete end;
  Curve* result = curve->real_curve();
  curve->sub_entity_set().unwrap_attributes();
  curve->sub_entity_set().remove_bridge( result );
    curve->owner()->swap_bridge( curve, result, false );
  delete curve;
  if (observable)
  return result;
CubitStatus PartitionEngine::restore_from_attrib ( Curve partitioned_curve) [private]
Restore curve partitions from attributes
Definition at line 4625 of file PartitionEngine.cpp.
  int i, id, dim, max_id = 0;
  DLIList<CubitSimpleAttrib> attribs, point_attribs, curve_attribs;
  DLIList<CubitVector*> empty;
  DLIList<int> junk, point_conn;
  DLIList<PartitionPoint*> new_points;
  CubitStatus result = CUBIT_FAILURE;
      // Get list of partition attributes.
    curve->get_simple_attribute(PARTITION_GEOM_ATTRIB_NAME,attribs);
    if( attribs.size() == 0 )
      // Group attributes into those defining partition points and
      // those defining the subcurves.  Also find max ID of all
      // partition geometry on this curve
    attribs.reset();
    for( i = attribs.size(); i--; )
      const CubitSimpleAttrib& attrib = attribs.get_and_step();
      dim = SubEntitySet::get_geom_dimension(attrib);
      if( dim == 0 )
        point_attribs.append(attrib);
      else if( dim == 1 )
        curve_attribs.append(attrib);
      else
        goto CLEANUP_CURVE_FROM_ATTRIB;
      id = SubEntitySet::get_geom_id( attrib );
      if( id > max_id )
        max_id = id;
      // Create first curve (duplicate of input curve)
    PartitionCurve* first_curve = replace_curve( curve );
    if( ! first_curve )
      // Set up SubEntitySet such that new entities get IDs
      // larger than max_id as they are created.
    first_curve->sub_entity_set().renumerate( max_id + 1, false );
      // Create all the partition points
    point_attribs.reset();
    for( i = point_attribs.size(); i--; )
      const CubitSimpleAttrib& attrib = point_attribs.get_and_step();
      PartitionPoint* point = new PartitionPoint( attrib, first_curve );
      if( !point )
      curve->remove_simple_attribute_virt(attrib);
      // Now partition the curve and assign the ID from each
      // curve attribute the the appropriate curve partition.
      // We're going to do this in order along the curve, such
      // that the first subcurve will begin at the start_point() of
      // the original curve.
    PartitionPoint* prev_point = first_curve->start_point();
    PartitionCurve* next_curve = first_curve;
    while( curve_attribs.size() )
        // Search for attribute corresponding to curve
        // beginning at prev_point
      PartitionPoint *start = 0, *end = 0;
      CubitSimpleAttrib curve_attrib;
      curve_attribs.last();
      for( i = curve_attribs.size(); i--; )
          // Get data from attribute
        const CubitSimpleAttrib& attrib = curve_attribs.step_and_get();
        point_conn.clean_out();
        if( !SubEntitySet::read_geometry(id,dim,empty,junk,point_conn,junk,attrib)
            || empty.size() || junk.size() || dim != 1 || point_conn.size() != 4)
          // Get start point from IDs
        point_conn.reset();
        int sid = point_conn.get_and_step();
        int eid = point_conn.get_and_step();
        PartitionEntity* ent = entity_from_id(sid, eid, first_curve->sub_entity_set());
        start = dynamic_cast<PartitionPoint*>(ent);
        if( start == prev_point )
            // Found the attrib we want.
            // Get the end point and break the loop.
          end = dynamic_cast<PartitionPoint*>(ent);
          curve_attrib = curve_attribs.extract();
          break;
        // Make sure we found an attrib to do
      if( curve_attrib.isEmpty() || !start || !end )
        // Unless this is the last partition (no more splitting
        // required), split the curve at the end point.  Make
        // next_curve point to the (unpartitioned) remainder of
        // the curve.
      PartitionCurve* new_curve = next_curve;
      if( next_curve->end_point() != end )
        next_curve = insert_point( new_curve, end );
        if( !next_curve )
        // Set the new curve's ID to whatever it is stored
        // as in the attribute.
      new_curve->sub_entity_set().set_id( new_curve,
        SubEntitySet::get_geom_id( curve_attrib ) );
        // Remove processed attributes.
      curve->remove_simple_attribute_virt( curve_attrib );
        // Next iteration
      prev_point = end;
      // Compress SubEntitySet ID space
    next_curve->sub_entity_set().renumerate( max_id + 1, true );
    result = CUBIT_SUCCESS;
CLEANUP_CURVE_FROM_ATTRIB:
  for( i = new_points.size(); i--; )
    PartitionPoint* pt = new_points.get_and_step();
    if( !pt->next_curve(0) )
      delete pt;
  if (!result)
    PRINT_ERROR("Error restoring curve partitions from attributes.\n");
  return result;
CubitStatus PartitionEngine::restore_from_attrib ( Surface partitioned_surface) [private]
Restore surface partitions from attributes
Definition at line 4784 of file PartitionEngine.cpp.
  int i, j, k, id, dim, max_id = 0;
  DLIList<CubitSimpleAttrib> attribs;
  DLIList<CubitFacetEdgeData*> polyline_edges;
  DLIList<CubitPointData*> polyline_pts;
  DLIList<CubitFacetData*> surf_facets;
  DLIList<CubitVector*> positions;
  DLIList<PartitionEntity*> new_geom;
  DLIList<PartitionLoop*> loops;
  DLIList<int> facets(0), connectivity, pt_owners;
  SubSurface* first_surf = 0;
      // Get partition attributes from entity.  Return if there aren't any.
    surf->get_simple_attribute(PARTITION_GEOM_ATTRIB_NAME,attribs);
    PRINT_DEBUG_86("Reading partition geometry on %s %p\n",
      fix_type_name( typeid(*surf).name() ), (void*)surf );
      // Find max ID
    attribs.reset();
      id = SubEntitySet::get_geom_id( attribs.get_and_step() );
      if( id > max_id )
        max_id = id;
      // Create first partition surface (initially a duplicate of
      // the input surface)
    first_surf = replace_surface( surf );
    if( ! first_surf )
      PRINT_ERROR("Internal Error: PartitionEngine::replace_surface() failed.\n");
      goto CLEANUP_SURF_FROM_ATTRIB;
      // Update SubEntitySet such that new entities get assigned
      // IDs greater than max_id when they are created.  This
      // leaves the range 0->max_id free so that we can reassign
      // the saved IDs after the entities are created.
    first_surf->sub_entity_set().renumerate( max_id + 1, false );
      // create all interior vertices
    attribs.reset();
        // Only want point attributes (dimension of zero)
      CubitSimpleAttrib attrib = attribs.get();
      if( SubEntitySet::get_geom_dimension(attrib) != 0 )
        attribs.step();
        continue;
        // Create the point at the location specified in the attrib.
      attribs.extract();
      surf->remove_simple_attribute_virt(attrib);
      PartitionPoint* new_pt = new PartitionPoint( attrib, first_surf );
      CubitPointData* data = project_to_surface( first_surf, new_pt->coordinates() );
      new_pt->facet_point(data);
      new_geom.append(new_pt);
      PRINT_DEBUG_86("  Created Point %p (%d in subset) at (%f,%f,%f)\n",
        (void*)new_pt, new_pt->sub_entity_set().get_id(new_pt),
        new_pt->coordinates().x(), new_pt->coordinates().y(),
        new_pt->coordinates().z() );
      if (DEBUG_FLAG(86))
        GfxDebug::draw_point(new_pt->coordinates(), new_pt->sub_entity_set().get_id(new_pt));
        GfxDebug::flush();
      // create all interior curves
    attribs.reset();
        // Only want curve attributes (dimension of one)
      if( SubEntitySet::get_geom_dimension(attrib) != 1 )
        attribs.step();
        continue;
        // Remove this attrib from the real geom, as we are
        // handling it
      attribs.extract();
      if ( SubEntitySet::get_segment_count(attrib) == 0 )
        PartPTCurve* pt_curve = PartPTCurve::construct(attrib, first_surf);
        if (!pt_curve)
          PRINT_ERROR("point-curve construction failed -- corrupt data?\n");
        new_geom.append( pt_curve );
        PRINT_DEBUG_86("  Created point-curve %p (%d in subset) with\n"
                       "    point %p (%d in subset) at (%f,%f,%f)\n",
          (void*)pt_curve,
          pt_curve->sub_entity_set().get_id(pt_curve),
          (void*)pt_curve->start_point(),
          pt_curve->start_point()->sub_entity_set().get_id(pt_curve->start_point()),
          pt_curve->start_point()->coordinates().x(),
          pt_curve->start_point()->coordinates().y(),
          pt_curve->start_point()->coordinates().z() );
        CubitPointData* pt = project_to_surface( first_surf, pt_curve->start_point()->coordinates() );
        if ( !pt )
          PRINT_ERROR("projection of position onto surface facets failed.\n");
        pt_curve->start_point()->facet_point( pt );
        continue;
        // Create the curve
      SegmentedCurve* new_curve = SegmentedCurve::construct( attrib, first_surf );
      if( !new_curve )
        PRINT_ERROR("segmented curve construction failed -- corrupt data?\n");
      new_geom.append(new_curve);
      PRINT_DEBUG_86("  Created polyline curve %p (%d in subset) with %d segments.\n"
                     "    start point %p (%d in subset) at (%f,%f,%f)\n"
                     "      end point %p (%d in subset) at (%f,%f,%f)\n",
          (void*)new_curve,
          new_curve->sub_entity_set().get_id(new_curve),
          new_curve->point_count() - 1,
          (void*)new_curve->start_point(),
          new_curve->start_point()->sub_entity_set().get_id(new_curve->start_point()),
          new_curve->start_point()->coordinates().x(),
          new_curve->start_point()->coordinates().y(),
          new_curve->start_point()->coordinates().z(),
          (void*)new_curve->end_point(),
          new_curve->end_point()->sub_entity_set().get_id(new_curve->end_point()),
          new_curve->end_point()->coordinates().x(),
          new_curve->end_point()->coordinates().y(),
          new_curve->end_point()->coordinates().z() );
        // Get curve segments
      positions.clean_out();
      polyline_edges.clean_out();
      new_curve->get_segments( positions );
      if (DEBUG_FLAG(86))
        GPoint* array = new GPoint[positions.size()];
        positions.reset();
        for (int dd = 0; dd < positions.size(); dd++ )
          array[dd].x = (float)positions.next(dd)->x();
          array[dd].y = (float)positions.next(dd)->y();
          array[dd].z = (float)positions.next(dd)->z();
        GfxDebug::draw_polyline(array, positions.size(),
                                new_curve->sub_entity_set().get_id(new_curve));
        GfxDebug::flush();
        // Make sure segment end points are on curve end points
      positions.last();
      *positions.get() = new_curve->end_point()->coordinates();
      positions.reset();
      *positions.get() = new_curve->start_point()->coordinates();
        // Project curve into surface facets
      surf_facets.clean_out();
      first_surf->get_facet_data( surf_facets );
      CubitStatus s = project_to_surface( surf_facets, positions,
                              polyline_edges, polyline_pts );
      while( positions.size() )
        CubitVector* position = positions.pop();
        if(s)
   //       assert(polyline_pts.size());
          CubitPointData* point = polyline_pts.pop();
          if (point && point->check_inverted_facets(*position))
            point->set(*position);
        delete position;
      if( !s || !polyline_edges.size() )
        PRINT_ERROR("Imprint of polyline onto surface facets failed.\n");
        // move facet points onto surface
      for ( j = 0; j < 2; j++ )
        for ( k = polyline_edges.size(); k--; )
          if ( CubitFacetEdgeData* edge = polyline_edges.get_and_step() )
            edge->point(j)->marked(1);
      for ( j = polyline_edges.size(); j--; )
        CubitFacetEdgeData* edge = polyline_edges.get_and_step();
        if ( !edge ) continue;
        for ( k = 0; k < 2; k++ )
          CubitPoint* pt = edge->point(k);
          if ( pt->marked() )
            pt->marked(0);
            first_surf->relax_to_geometry(pt);
        // Associate facet data with geometry
      CubitPoint *last_pt, *first_pt;
      polyline_edges.last();
      assert(!polyline_edges.get());
      polyline_edges.pop();
      if( polyline_edges.size() == 1 )
        last_pt = polyline_edges.get()->point(1);
        first_pt = polyline_edges.get()->point(0);
      else
        CubitFacetEdgeData *edge, *neighbor;
        edge = polyline_edges.get();
        neighbor = polyline_edges.prev();
        if( !edge || !neighbor )
          PRINT_ERROR("Bad surface facets.\n");
        last_pt = edge->shared_point(neighbor);
        last_pt = edge->other_point(last_pt);
        polyline_edges.reset();
        neighbor = polyline_edges.next();
        first_pt = edge->shared_point(neighbor);
        first_pt = edge->other_point(first_pt);
      PartitionEntity* owner1 = TDVGFacetOwner::get( first_pt );
      PartitionEntity* owner2 = TDVGFacetOwner::get( last_pt );
      if ( new_curve->start_point() == new_curve->end_point() )
        if ( owner1 == owner2 && owner1 == new_curve->start_point() )
          first_pt = polyline_edges.get()->other_point( first_pt );
          last_pt = polyline_edges.get()->other_point( last_pt );
          double u1 = new_curve->u_from_position( first_pt->coordinates() );
          double u2 = new_curve->u_from_position( last_pt->coordinates() );
          if ( u2 < u1 )
            polyline_edges.reverse();
        else
          s = CUBIT_FAILURE;
      else if ( owner1 == new_curve->end_point() &&
                owner2 == new_curve->start_point() )
      else if( owner1 != new_curve->start_point() ||
               owner2 != new_curve->end_point() )
        s = CUBIT_FAILURE;
      if (!s)
        PRINT_ERROR("Tolerance problems when restoring surface partitions.\n");
      new_curve->set_facet_data( polyline_edges );
      // while there are more surface partitions to create
    PartitionEntity* ent = 0;
    while( attribs.size() )
        // read attribute
      CubitSimpleAttrib surf_attr = attribs.pop();
      connectivity.clean_out();
      CubitStatus s = SubEntitySet::
        read_geometry( id, dim, positions, facets, connectivity, pt_owners, surf_attr );
      if( !s || dim != 2 || positions.size() || facets.size() )
        PRINT_ERROR("Corrupt/inconsistent subsurface data.\n");
      PRINT_DEBUG_86("  Constructing SubSurface (%d in subset)\n", id);
        // construct surface loops
      int j = connectivity.size();
      PartitionCoEdge* curve_coedge = 0; // save one non-point-curve coedge
      while ( j > 0 )
        int loop = connectivity.get_and_step();
        j--;
        PartitionLoop* new_loop = new PartitionLoop();
        loops.append( new_loop );
        PartitionCoEdge* prev_coedge = 0;
        PRINT_DEBUG_86("   Loop: ");
        while( loop-- )
          int set_id = connectivity.get_and_step();
          int ent_id = connectivity.get_and_step();
          int sense = ent_id < 0 ? -1 : 1;
          ent_id *= sense;
          j -= 2;
          ent = entity_from_id( set_id, ent_id, first_surf->sub_entity_set() );
          PartitionCurve* curve = dynamic_cast<PartitionCurve*>(ent);
          PRINT_DEBUG_86(" %p,%d,%d%c", (void*)curve, set_id, ent_id*sense, loop?',':'\n');
          if(!curve)
            PRINT_ERROR("Nonexistant curve specified in saved connectivity.\n");
          CubitSense cubit_sense = sense == -1 ? CUBIT_REVERSED : CUBIT_FORWARD;
          while ( (coedge = curve->next_coedge(coedge)) )
            if ( coedge->sense() == cubit_sense &&
                 coedge->get_loop() &&
                 coedge->get_loop()->get_surface() == first_surf )
              break;
          if ( !coedge )
            coedge = new PartitionCoEdge( first_surf, cubit_sense );
            curve->add(coedge);
          if (!curve_coedge && curve->geometry_type() != POINT_CURVE_TYPE)
            curve_coedge = coedge;
          new_loop->insert_after( coedge, prev_coedge );
          prev_coedge = coedge;
      if (!curve_coedge)
        PRINT_ERROR("Nonexistant co-edge specified in saved connectivity.\n");
      PartitionSurface* new_surf = split_surface( first_surf, curve_coedge );
      if (new_surf == first_surf && attribs.size() > 0)
        PRINT_ERROR("Surface splitting failed -- bad topology?.\n");
      new_surf->sub_entity_set().set_id( new_surf, id );
      while ( loops.size() )
        new_surf->add( loops.pop() );
CLEANUP_SURF_FROM_ATTRIB:
    // clean up any unused loops from failed surface creation
    PartitionLoop* loop = loops.pop();
    while ( loop->first_coedge() )
      PartitionCoEdge* coedge = loop->first_coedge();
      loop->remove(coedge);
      if (coedge->get_curve())
        coedge->get_curve()->remove(coedge);
      delete coedge;
    delete loop;
    // first_surf will contain dead loops - clean them up
  PartitionLoop* surf_loop = 0;
  while ( (surf_loop = first_surf->next_loop( surf_loop ) ) != NULL )
    if ( !surf_loop->first_coedge() )
      loops.append( surf_loop );
    surf_loop = loops.pop();
    first_surf->remove( surf_loop );
    delete surf_loop;
  new_geom.reset();
  while( new_geom.size() )
    PartitionEntity* ent = new_geom.pop();
    if( PartitionPoint* pt = dynamic_cast<PartitionPoint*>(ent) )
        delete pt;
    else if( PartitionCurve* curve = dynamic_cast<PartitionCurve*>(ent) )
      if( !curve->next_coedge(0) )
        delete curve;
  first_surf->sub_entity_set().renumerate( max_id + 1, true );
  if (!result)
    PRINT_ERROR("Error restoring surface partitions from attributes.\n");
  return result;
CubitStatus PartitionEngine::restore_from_attrib ( Lump partitioned_lump) [private]
Restore lump partitions from attributes
Definition at line 5245 of file PartitionEngine.cpp.
  DLIList<int> facets, connectivity, pt_owners;
  PartitionLump* first_lump = 0;
  PartitionLump* new_lump = 0;
  { // pseudo-'try'-block
      // get partition attributes from entity.  Return if none.
    lump->get_simple_attribute(PARTITION_GEOM_ATTRIB_NAME,attribs);
      // find max ID
    attribs.reset();
      if( id > max_id )
        max_id = id;
      // Create first parition lump (initially a duplicate of
      // the input lump)
    first_lump = replace_lump( lump );
    if( ! first_lump )
      goto CLEANUP_LUMP_FROM_ATTRIB;
    first_lump->sub_entity_set().renumerate( max_id + 1, false );
    attribs.reset();
        // skip any non-point geometry
        attribs.step();
        continue;
        // create the point as specified in the attrib
      attribs.extract();
      lump->remove_simple_attribute_virt(attrib);
      PartitionPoint* new_pt = new PartitionPoint( attrib, first_lump );
    attribs.reset();
        // skip attribs for anything but curves
        attribs.step();
        continue;
        // create curve from attrib
      attribs.extract();
      SegmentedCurve* new_curve = SegmentedCurve::construct( attrib, first_lump );
      if( !new_curve )
      // create all interior surfaces
    attribs.reset();
        // skip non-surface attributes
      if( SubEntitySet::get_geom_dimension(attrib) != 2 )
        attribs.step();
        continue;
        // create surface from attribute
      attribs.extract();
      PartitionSurface* new_surf = PartitionSurface::construct( attrib, first_lump );
      if( !new_surf )
      new_geom.append(new_surf);
      // while there are more volume partitions to create
        // Read data from attribute
      const CubitSimpleAttrib& attr = attribs.pop();
        read_geometry( id, dim, positions, facets, connectivity, pt_owners, attr );
      if( !s || dim != 3 || positions.size() || facets.size() )
        new_lump = 0;
      new_lump = new PartitionLump( first_lump );
        // Get list of bounding co-surfaces from attrib data
      while( j > 0 )
        int shell = connectivity.get_and_step();
        j--;
        PartitionShell* new_shell = new PartitionShell();
        new_lump->add(new_shell);
        while( shell-- )
          j -= 2;
          CubitSense sense = CUBIT_FORWARD;
          if ( ent_id < 0 )
            ent_id = -ent_id;
            sense = CUBIT_REVERSED;
          ent = entity_from_id( set_id, ent_id, first_lump->sub_entity_set() );
          PartitionSurface* surf = dynamic_cast<PartitionSurface*>(ent);
          if(!surf)
          PartitionCoSurf* new_cosurf = new PartitionCoSurf(sense);
          surf->add(new_cosurf);
          new_shell->add(new_cosurf);
      new_lump->sub_entity_set().set_id( new_lump, id );
      new_lump = 0;  // we succeeded with this one, so don't try to
                     // destroy it if we fail before creating the next.
CLEANUP_LUMP_FROM_ATTRIB:
  if( new_lump ) // created a lump but didn't successfully complete it
    PartitionShell* shell = 0;
    while ( shell )
      new_lump->remove(shell);
      shell->remove_all_surfaces();
      PartitionShell* old_shell = shell;
      shell = new_lump->next_shell(shell);
      delete old_shell;
  DLIList<PartitionEntity*> lump_list;
  if( first_lump )
      // Get list of other lumps created
    first_lump->sub_entity_set().get_sub_entities( lump_list );
    lump_list.move_to(first_lump);
    assert( lump_list.get() == first_lump );
    lump_list.extract();
      // Destroy first_lump (it is the union of all the partitions)
    while ( shell )
      first_lump->remove(shell);
      shell->remove_all_surfaces( &surfaces );
      shell = first_lump->next_shell(shell);
      delete old_shell;
      while( surfaces.size() )
        SubSurface* surf = dynamic_cast<SubSurface*>(surfaces.pop());
        if ( surf && !surf->next_co_surface(0) &&
             !surf->sub_entity_set().has_lower_order() )
          restore_surface( surf );
    delete first_lump;
    // destroy any unused split geometry
  new_geom.reset();
        delete pt;
        delete curve;
    else if( PartitionSurface* surf = dynamic_cast<PartitionSurface*>(ent) )
      if( !surf->next_co_surface(0) )
        destroy_surface( surf );
    // if there are any remaining partitions of the volume,
    // compress the ID space
  if ( lump_list.size() )
    lump_list.get()->sub_entity_set().renumerate( max_id + 1, true );
  if (!result)
    PRINT_ERROR("Error restoring volume partitions from attributes.\n");
  return result;
Definition at line 717 of file PartitionEngine.cpp.
  if( lump->sub_entity_set().has_lower_order() )
    return 0;
  while( PartitionShell* shell = lump->next_shell() )
    // while surface has loops...
    lump->remove( shell );
    destroy_shell( shell );
  Lump* result = lump->real_lump();
  lump->sub_entity_set().unwrap_attributes();
  lump->sub_entity_set().remove_bridge( result );
  if( lump->owner() )
    lump->owner()->swap_bridge( lump, result, false );
  delete lump;
  return result;
Definition at line 516 of file PartitionEngine.cpp.
  if( point->num_curves() )
    return 0;
  TBPoint* result = point->real_point();
  if( result )
    point->sub_entity_set().unwrap_attributes();
    point->sub_entity_set().remove_bridge(result);
    delete point;
  return result;
Definition at line 617 of file PartitionEngine.cpp.
  if( surface->sub_entity_set().has_lower_order() || surface->next_co_surface() )
    return 0;
  while( PartitionLoop* loop = surface->next_loop() )
    surface->remove( loop );
    while( loop->first_coedge() )
      loop->remove( coedge );
      SubCurve* curve = dynamic_cast<SubCurve*>(coedge->get_curve());
      if( !curve || curve->sub_entity_set().has_lower_order() )
        continue;
      bool remove = true;
      coedge = 0;
        if( coedge->get_loop() )
          remove = false;
          break;
      if( remove )
        restore_curve( curve );
    delete loop;
  Surface* result = surface->partitioned_surface();
  surface->sub_entity_set().unwrap_attributes();
  surface->sub_entity_set().remove_bridge( result );
    surface->owner()->swap_bridge( surface, result, false );
  delete surface;
  return result;
Definition at line 6155 of file PartitionEngine.cpp.
  body->get_transforms( xform );
  if (!body->get_geometry_query_engine()->restore_transform( body ))
CubitStatus PartitionEngine::rotate ( PartitionBody ent,
const CubitVector axis,
double  degrees
Definition at line 6107 of file PartitionEngine.cpp.
  if (!body->get_geometry_query_engine()->rotate( body, axis, degrees ))
  xform.rotate( degrees, axis );
CubitStatus PartitionEngine::rotate ( PartitionEntity ent,
double  degrees
Definition at line 6054 of file PartitionEngine.cpp.
  if (!geom->get_geometry_query_engine()->rotate( geom, axis, degrees ))
Save partition curve geometry as attributes.
Save lump partitions as attributes.
Save surface partitions as attributes.
CubitStatus PartitionEngine::scale ( PartitionBody ent,
const CubitVector factors
Definition at line 6121 of file PartitionEngine.cpp.
  if( factors.x() != factors.y() ||
      factors.y() != factors.z() ||
      factors.x() != factors.z() )
    GeometryModifyEngine *tmp_engine = GeometryModifyTool::instance()->get_engine( body );
    tmp_engine->scale( body, factors );
  else if(!body->get_geometry_query_engine()->scale( body, factors ))
  xform.scale_about_origin( factors );
Definition at line 6068 of file PartitionEngine.cpp.
  if (!geom->get_geometry_query_engine()->scale( geom, factors ))
Split a lump
Split a lump and move shells to new lump. If inserting a surface could potentially result in the lump being partitioned, this method is called to attempt to split the shell and move the appropriate shells to the new lump.
Called by insert_surface( PartitionLump*, PartitionSurface*)
Parameters:
shellThe shell that is potentially to be split.
Returns:
NULL if an error occured, a pointer to the new lump if the shell was split. The orignal shells owner otherwise.
Definition at line 3774 of file PartitionEngine.cpp.
    // Split shell
  PartitionShell* new_shell = split_shell(shell_to_split);
  if( !new_shell )
      // shell did not need to be split
    return shell_to_split->get_lump();
    // Create the new lump and shell
  PartitionLump* new_lump = new PartitionLump( shell_to_split->get_lump() );
  new_lump->add( new_shell );
    // Check for any remaining shells that need to be moved
    // from the old lump to the new lump.
  PartitionLump* lump = shell_to_split->get_lump();
  while( (shell = lump->next_shell(shell)) )
    if( shell == shell_to_split )
      continue;
    bool some_contained = false;
    bool all_contained = true;
    bool all_tested = true;
    PartitionCoSurf* cosurf = 0;
    while( (cosurf = shell->next_co_surface(cosurf)) )
      PartitionSurface* surf = cosurf->get_surface();
      CubitVector pt, tmp = surf->bounding_box().center();
      surf->closest_point_trimmed( tmp, pt );
      switch( new_shell->point_containment(pt) )
        case CUBIT_PNT_INSIDE:
          some_contained = true;
          break;
        case CUBIT_PNT_OUTSIDE:
          all_contained = false;
         break;
        default:
          all_tested = false;
          break;
    if( !all_tested || (some_contained && !all_contained) )
      PRINT_ERROR("Error splitting volume.  Could not determine\n"
                  "which volume shell belongs in.  Geometry may be\n"
                  "invalid.\n");
    if(some_contained && all_contained)
      new_lump->add(shell);
  return new_lump;
Split a shell
Check if a shell can be split, and if so split it.
Called by split_lump(PartitionShell*) and remove_surface(PartitionSurface*)
Definition at line 3894 of file PartitionEngine.cpp.
    // Make sure all cosurface surface marks are cleared
  while( (cosurf = shell_to_split->next_co_surface( cosurf )) )
    cosurf->mark = 0;
    cosurf->get_surface()->mark = 0;
    // Identify non-manifold surfaces, marking them either
    // with a 2 if they can be used to split the volume
    // (if they are part of a connected patch for which the
    // bounadary of that patch intersects the volume boundary
    // at all curves) or a 3 if they are other non-manifold
    // surfaces.  This will get a bit tricky if there are
    // non-manifold surfaces hanging off of the patch of
    // split surfaces.
    // First for all non-manifold surfaces, if the surface has
    // a curve that is not shared with any other surface, mark
    // it with a 3.  Otherwise mark it with a 2.
  cosurf = 0;
  DLIList<PartitionSurface*> surf_stack;
  while ( (cosurf = shell_to_split->next_co_surface(cosurf)) )
      // If we haven't done this surface yet and it is non-manifold
    if ( !surf->mark && surf->find_next(cosurf) )
      surf->mark = 2;
      bool no_free_curve = true;
      PartitionLoop* loop = 0;
      while( no_free_curve && (loop = surf->next_loop(loop)) )
        do
          PartitionCurve* curve = coedge->get_curve();
            // If the curve has more than one coedge, it
            // is not a free curve (this also accounts for
            // the case where the curve is a non-manifold
            // curve on the surface interioir -- e.g. a sipe)
          if ( !curve->next_coedge(coedge) &&
               curve->next_coedge(0) == coedge )
            no_free_curve = false;
            break;
          coedge = loop->next_coedge(coedge);
        } while( coedge != loop->first_coedge() );
      if( !no_free_curve )
        surf->mark = 3;
        surf_stack.append( surf );
    // Now for each surface we marked with a three, traverse
    // and mark adjacent surfaces until we come to a curve
    // connected to more that two surfaces.
  while( surf_stack.size() )
    PartitionSurface* surf = surf_stack.pop();
    while ( (loop = surf->next_loop(loop)) )
      do
        int split_count = 0;
        int boundary_count = 0;
        PartitionCoEdge* curve_coe = 0;
        while ( (curve_coe = curve->next_coedge(curve_coe) ) != NULL )
          PartitionSurface* curve_surf = curve_coe->get_loop()->get_surface();
          switch ( curve_surf->mark )
            case 0: boundary_count++; break;
            case 2: split_count++;    break;
        if ( split_count == 1 && !boundary_count )
          curve_coe = 0;
            if ( curve_surf->mark == 2 )
              curve_surf->mark = 3;
              surf_stack.append(curve_surf);
        coedge = loop->next_coedge( coedge );
    // Now build a new shell by traversing cofaces, marking
    // each with that will go in a new shell with a 1.
    // Start with any cosurf that does not have a free
    // non-manifold surface (marked with a 3).  We'll handle
    // free non-manifold surfaces later.
  DLIList<PartitionCoSurf*> cosurf_stack;
  cosurf = 0;
    if ( cosurf->get_surface()->mark != 3 )
      break;
  if ( cosurf )
    cosurf->mark = 1;
    cosurf_stack.append( cosurf );
    // Traverse over adjacent cosurfaces, marking them with a 1
  while (cosurf_stack.size())
    cosurf = cosurf_stack.pop();
      do
        PartitionCoSurf *boundary_cosurf = 0, *split_cosurf = 0;
        int split_cosurf_count = 0;
        while ( (curve_coe = curve->next_coedge(curve_coe)) )
          if ( curve_coe == coedge )
            continue;
          bool same_coe_sense = curve_coe->sense() == coedge->sense();
          PartitionCoSurf* curve_cosurf = 0;
          while ( (curve_cosurf = curve_surf->next_co_surface(curve_cosurf)) )
            if ( curve_cosurf->get_shell() != shell_to_split )
              continue;
            bool same_cos_sense = curve_cosurf->sense() == cosurf->sense();
            if ( same_cos_sense == same_coe_sense )
              continue;
              // Always choose split surface first if we
              // found one
            if ( curve_cosurf->get_surface()->mark == 2 ) {
              split_cosurf_count++;
              split_cosurf = curve_cosurf;
              // Skip other non-manifold surfaces.  We'll
              // handle those later.
            else if( curve_cosurf->get_surface()->mark != 3 )
              boundary_cosurf = curve_cosurf;
        PartitionCoSurf* next_cosurf = split_cosurf ? split_cosurf : boundary_cosurf;
        if ( !next_cosurf->mark && split_cosurf_count < 2 )
          next_cosurf->mark = 1;
          cosurf_stack.append(next_cosurf);
    } // end while (loop)
  } // end while (cosurf_stack.size())
    // build lists of cosurfaces, one for each shell and
    // one of other non-manifold surfaces
  DLIList<PartitionCoSurf*> marked_list, unmarked_list, other_list;
  while( (cosurf = shell_to_split->next_co_surface(0)) )
    shell_to_split->remove(cosurf);
    if ( cosurf->get_surface()->mark == 3 )
      other_list.append( cosurf );
    else if( cosurf->mark )
      marked_list.append( cosurf );
    else
      unmarked_list.append( cosurf );
    // If one of marked_list or unmarked_list is empty,
    // we can't split the shell yet.  Put cofaces back in
    // shell and exit.
  if ( !marked_list.size() || !unmarked_list.size() )
    marked_list += unmarked_list;
    marked_list += other_list;
    marked_list.reverse();
    while ( marked_list.size() )
      cosurf = marked_list.pop();
      cosurf->mark = 0;
      shell_to_split->add( cosurf );
    return 0;
    // Put unmarked list back in old shell
  unmarked_list.reverse();
  while ( unmarked_list.size() )
    cosurf = unmarked_list.pop();
    shell_to_split->add(cosurf);
    // Put marked list in new shell
  PartitionShell* new_shell = new PartitionShell;
    cosurf->mark = 0;
    new_shell->add(cosurf);
    // Now sort out other non-manifold surfaces
    // Clear marks and get list of surface from cosurfaces
  surf_stack.clean_out();
  while( other_list.size() )
    cosurf = other_list.pop();
    if ( surf->mark )
      surf->mark = 0;
      surf_stack.append(surf);
  insert_nonmanifold_surfaces( surf_stack, shell_to_split, new_shell );
  return new_shell;
Split a surface
Split surface and move loops to new surface. When inserting a curve results in a loop being split (or a new hole-loop being created) this method is called. This method uses facet connectivity and facet-owenr associativity to move the appropriate surface facets and PartitionLoops to the new surface.
Used by insert_curve(PartitionSurface*, SegmentedCurve*).
Parameters:
surfaceThe surface to split.
new_curveA coedge owning the curve that caused the split.
Returns:
NULL if an error occured, the new surface if one was created, or the passed surface if the surface isn't to be split yet.
Definition at line 1883 of file PartitionEngine.cpp.
  int i;
    // get surface facets and make sure marks are cleared
  DLIList<CubitFacetData*> faces;
  surface->get_facet_data(faces);
  for( i = faces.size(); i--; )
    faces.get_and_step()->marked(0);
    // get curve and curve's facet edges
  PartitionCurve* new_curve = dynamic_cast<PartitionCurve*>(new_coedge->get_curve());
  DLIList<CubitFacetEdgeData*> edges;
  new_curve->get_facet_data( edges );
  assert(edges.size());
    // get the first point in the curve's facet edges
  edges.reset();
  CubitFacetEdgeData* edge = edges.get();
  CubitPoint* pt = edge->point(0);
  if ( TDVGFacetOwner::get(pt) != new_curve->start_point() )
    pt = edge->point(1);
    assert(TDVGFacetOwner::get(pt) == new_curve->start_point());
    // get the facets on the surface on the inside size of
    // the coedge
  bool coedge_forward = new_coedge->sense() == CUBIT_FORWARD;
  DLIList<CubitFacetData*> front( faces.size() );
  for ( i = edges.size(); i--; )
    edge = edges.get_and_step();
    bool edge_forward = edge->point(0) == pt;
    bool sense = edge_forward == coedge_forward;
    CubitFacetData* face = find_facet( edge, sense, surface );
    if( face->marked() == 0 )
//draw_facet_edges(face,CUBIT_RED_INDEX);
      face->marked(1);
      front.append( face );
    pt = edge->other_point(pt);
    // mark all adjacent facets traversing only over
    // edges that are in the interior of the surface
  while( front.size() )
    CubitFacetData* face = front.pop();
    for( i = 0; i < 3; i++ )
      if( face->edge(i) && TDVGFacetOwner::get(face->edge(i)) )
        continue;
      CubitFacetData* other = other_facet( face, i, surface );
      if ( other->marked() == 0 )
//draw_facet_edges(face,CUBIT_BLUE_INDEX);
        other->marked(1);
        front.append(other);
    // reuse front to hold all the facets we marked
    CubitFacetData* face = faces.get_and_step();
    if( face->marked() )
    // if we got back all the facets, then the surface
    // was not split!
  if( front.size() == faces.size() )
    return surface;
    // split off a new PartitionSurface
  PartitionSurface* new_surf = surface->split( front );
    // get list of all loops in surface
  DLIList<PartitionLoop*> loops( surface->num_loops() );
  while( (loop = surface->next_loop( loop )) )
    loops.append( loop );
    // check which loops we need to move to the new surface
  while( loops.size() )
    loop = loops.pop();
    PartitionCoEdge* coe = loop->first_coedge();
    if( !coe )
      continue;
    PartitionCurve* curve = coe->get_curve();
    CubitFacetData* face =0;
    if( PartPTCurve* ptc = dynamic_cast<PartPTCurve*>(curve) )
      face = find_facet( ptc->start_point()->facet_point(), new_surf );
    else
      edges.clean_out();
      if (edges.size() > 0) // normal facet
        edges.reset();
        edge = edges.get();
        CubitPoint* start_pt = curve->start_point()->facet_point();
        bool forward = edge->point(0) == start_pt;
        assert( forward || edge->point(1) == start_pt );
        if ( coe->sense() == CUBIT_REVERSED )
          forward = !forward;
        face = find_facet( edge, forward, new_surf );
      else // this is a hardpoint there is a curve with no facets (length)
           // and the start and end points are the same
        TBPoint* hardpoint = curve->start_point()->real_point();
        if (hardpoint && curve->start_point() == curve->end_point() )
          CubitVector hardpoint_coord = hardpoint->coordinates();
          CubitVector new_closest, old_closest;
          new_surf->closest_point_trimmed( hardpoint_coord, new_closest );
          surface->closest_point_trimmed( hardpoint_coord,  old_closest );
          // It appears that the new_surf is really the original surface
          if ( new_closest.length_squared() > old_closest.length_squared() )
            face = reinterpret_cast<CubitFacetData*>(1); // just set the point to non-zero (true)
    if( face )
      new_surf->add( loop );
  PartitionCoSurf* cos = 0;
  while( (cos = surface->next_co_surface( cos )) )
    cos->get_shell()->add( new_surf, cos->sense() );
  return new_surf;
Definition at line 6094 of file PartitionEngine.cpp.
  if (!body->get_geometry_query_engine()->translate( body, delta ))
  xform.translate( delta );
  return CUBIT_SUCCESS;
Definition at line 6041 of file PartitionEngine.cpp.
  if (!geom->get_geometry_query_engine()->translate( geom, delta ))
Friends And Related Function Documentation
friend class PartitionLumpImprint [friend]
Definition at line 307 of file PartitionEngine.hpp.
Member Data Documentation
PartitionEngine * PartitionEngine::instance_ = NULL [static, private]
Definition at line 608 of file PartitionEngine.hpp.
std::map<int,SubEntitySet*> PartitionEngine::uniqueIdMap [private]
Map for getting a SubEntitySet given its unique ID
Definition at line 611 of file PartitionEngine.hpp.
