cgma
PartitionEngine.hpp
00001 //-------------------------------------------------------------------------
00002 // Filename      : PartitionEngine.hpp
00003 //
00004 // Purpose       :
00005 //
00006 // Special Notes :
00007 //
00008 // Creator       : Jason Kraftcheck
00009 //
00010 // Creation Date : 04/23/02
00011 //-------------------------------------------------------------------------
00012
00013 #ifndef PARTITION_ENGINE_HPP
00014 #define PARTITION_ENGINE_HPP
00015
00016 #include "CubitDefines.h"
00017 #include "VGDefines.h"
00018 #include <map>
00019 #include "IntermediateGeomEngine.hpp"
00020 #include "DLIList.hpp"
00021
00022 class TopologyBridge;
00023 class TBPoint;
00024 class Curve;
00025 class Surface;
00026 class Lump;
00027 class LoopSM;
00028 class BodySM;
00029
00030 class SubSurface;
00031 class SubCurve;
00032 class SegmentedCurve;
00033
00034 class PartitionEntity;
00035 class PartitionBody;
00036 class PartitionLump;
00037 class PartitionShell;
00038 class PartitionCoSurf;
00039 class PartitionSurface;
00040 class PartitionCurve;
00041 class PartitionPoint;
00042 class PartitionLoop;
00043 class PartitionCoEdge;
00044 class PartPTCurve;
00045
00046 class PST_Point;
00047 class SubEntitySet;
00048 class FacetProjectTool;
00049 class CubitSimpleAttrib;
00050
00051 class CubitPoint;
00052 class CubitFacet;
00053 class CubitPointData;
00054 class CubitFacetData;
00055 class CubitFacetEdgeData;
00056 class Body;
00057
00058 class CubitVector;
00059 class CubitTransformMatrix;
00060 template <class X> class DLIList;
00061
00062 class PartitionEngine : public IntermediateGeomEngine
00063 {
00064
00065 public:
00066   bool is_partition(TBOwner *bridge_owner);
00067   bool is_composite(TBOwner *bridge_owner);
00068   bool is_composite(TopologyBridge *bridge);
00069   virtual void remove_imprint_attributes_after_modify
00070                                 ( DLIList<BodySM*> &old_sms,
00071                                 DLIList<BodySM*> &new_sms ){};
00072   virtual void push_imprint_attributes_before_modify
00073                      ( DLIList<BodySM*> &body_sms ){};
00074   virtual void push_named_attributes_to_curves_and_points
00075                      ( DLIList<TopologyBridge*> &tb_list, const char *name_in ){};
00076   virtual void attribute_after_imprinting(DLIList<TopologyBridge*> &tb_list,
00077                                           DLIList<Body*> &old_bodies){};
00078   virtual void remove_attributes_from_unmodifed_virtual(DLIList<TopologyBridge*> &bridges){};
00079
00080
00081
00082   virtual ~PartitionEngine();
00083
00085   static PartitionEngine& instance();
00086   static void delete_instance();
00087
00088   int level() const { return SUBCOMP_PARTITION_LAYER; }
00089
00090   void notify_deactivated (PartitionBody* body);
00091   void notify_deactivated( PartitionLump* vol);
00092   void notify_deactivated (PartitionSurface* surface);
00093   void notify_deactivated (PartitionCurve* curve);
00094   void notify_deactivated (PartitionPoint* point);
00095   void add_to_deactivated_list(PartitionBody* body);
00096   void add_to_deactivated_list(PartitionLump* vol);
00097   void add_to_deactivated_list(PartitionSurface* sur);
00098   void add_to_deactivated_list(PartitionCurve* cur);
00099   void add_to_deactivated_list(PartitionPoint* pt);
00106   CubitStatus import_geometry( DLIList<TopologyBridge*>& imported_geometry );
00107
00115   CubitStatus export_geometry( DLIList<TopologyBridge*>& geometry_to_save );
00116
00123   TBPoint* insert_point( Curve* curve, double u );
00124
00133   Curve* remove_point( PartitionPoint* point,
00134                        PartitionCurve* dead_curves[2] = 0 );
00135
00140   Surface* insert_curve( Surface* surface,
00141                          DLIList<CubitVector*>& segment_points,
00142                          DLIList<Curve*>& new_curves,
00143                          const double *tolerance_length = NULL);
00144
00154   CubitStatus insert_curve( DLIList<Surface*>& surfaces,
00155                             DLIList<CubitVector*>& polyline,
00156                             DLIList<Surface*>& new_surfaces,
00157                             DLIList<Curve*>& polyline_curves,
00158                             const double *tolerance_length = NULL,
00159                             DLIList<Surface*>* surfs_to_reverse = NULL);
00160
00169   TBPoint* insert_point_curve( Surface* surf,
00170                              const CubitVector& position,
00171                              Surface *&partitioned_surf );
00172
00184   Lump* insert_surface( Surface* surf_to_copy, Lump* lump );
00185
00197   Surface* insert_surface( DLIList<CubitFacet*>& facets, Lump* lump );
00198
00199
00208   Surface* remove_curve( PartitionCurve* curve,
00209                          PartitionSurface* dead_surfs[2] = 0 );
00210
00217   Lump* remove_surface( PartitionSurface* surface );
00218
00220   int layer() { return SUBCOMP_PARTITION_LAYER; }
00221
00222   //static void destroy_facet( CubitFacetData* facet );
00223
00225   CubitStatus add_to_id_map( SubEntitySet* set, int unique_id );
00226
00228   CubitStatus remove_from_id_map( SubEntitySet* set, int unique_id );
00229
00231   SubEntitySet* get_from_id_map( int unique_id );
00232
00247   PartitionEntity* entity_from_id( int set_id, int geom_id,
00248                                    SubEntitySet& default_set );
00249
00250
00256   CubitStatus destroy_surface( PartitionSurface* surface );
00257
00263   CubitStatus destroy_lump( PartitionLump* lump );
00264
00265   static void delete_facet( CubitFacet* );
00266
00267   CubitStatus delete_solid_model_entities( PartitionBody* body,
00268                                            BodySM*& real_body );
00269   CubitStatus delete_solid_model_entities( PartitionSurface* surface,
00270                                            Surface*& real_surface );
00271   CubitStatus delete_solid_model_entities( PartitionCurve* curve,
00272                                            Curve*& real_curve );
00273
00274   static void curves_from_surfaces( const DLIList<PartitionSurface*>& input_surfs,
00275                                     DLIList<PartitionCurve*>& output_curves );
00276
00277   void clean_out_deactivated_geometry();
00278
00279   CubitStatus translate( PartitionBody* ent, const CubitVector& delta );
00280   CubitStatus rotate( PartitionBody* ent, const CubitVector& axis, double degrees );
00281   CubitStatus scale( PartitionBody* ent, const CubitVector& factors );
00282   CubitStatus reflect( PartitionBody* ent, const CubitVector& axis );
00283   CubitStatus restore_transform( PartitionBody* ent );
00284
00285   CubitStatus translate( PartitionEntity* ent, const CubitVector& delta );
00286   CubitStatus rotate( PartitionEntity* ent, const CubitVector& axis, double degrees );
00287   CubitStatus scale( PartitionEntity* ent, const CubitVector& factors );
00288   CubitStatus reflect( PartitionEntity* ent, const CubitVector& axis );
00289
00290   CubitStatus notify_transform( TopologyBridge* bridge,
00291                                 const CubitTransformMatrix& xform );
00292
00293   void remove_attributes( DLIList<TopologyBridge*> &bridge_list );
00294     //remove Composite attributes off of topology bridges
00295   virtual void remove_modified(DLIList<Surface*> &all_surfs,
00296     DLIList<Curve*> &all_curves, DLIList<TBPoint*> &all_pts);
00297
00298   void get_tbs_with_bridge_manager_as_owner( TopologyBridge *source_bridge,
00299                                                DLIList<TopologyBridge*> &tbs );
00300 private:
00301
00302   CubitStatus notify_transform_internal( TopologyBridge* bridge,
00303                                 const CubitTransformMatrix& xform );
00304
00305   PartitionEngine();
00306
00307   friend class PartitionLumpImprint;
00308
00321   CubitStatus find_coedges( PartitionSurface* surface,
00322                             PartitionCurve* curve,
00323                             PartitionPoint* point,
00324                             PartitionCoEdge*& previous,
00325                             PartitionCoEdge*& next );
00326
00337   PartitionCurve* next_curve_around_point( PartitionSurface *const surface,
00338                                            CubitFacetEdgeData *const edge,
00339                                            CubitPointData *const point,
00340                                            const bool backwards );
00341
00342
00344   CubitStatus remove_point_curve( PartitionPoint* point );
00345
00355   PartitionPoint* insert_point_curve( PartitionSurface* surface,
00356                                       CubitPointData* point );
00357   CubitStatus insert_point_curve( PartitionSurface* surface,
00358                                   PartPTCurve* curve,
00359                                   bool update_topology = true );
00360
00361
00373   PartitionCurve* insert_point( PartitionCurve* curve, PartitionPoint* point );
00374
00384   CubitStatus insert_curve( DLIList<PartitionSurface*>& surfaces,
00385                             DLIList<CubitVector*>& polyline,
00386                             DLIList<PartitionSurface*>& new_surfaces,
00387                             DLIList<PartitionCurve*>& polyline_curves,
00388                             const double *tolerance_length = NULL);
00389
00409   PartitionSurface* insert_curve( PartitionSurface* surface,
00410                                   SegmentedCurve* curve );
00411
00427   SegmentedCurve* insert_curve( DLIList<CubitFacetEdgeData*>& facet_edges,
00428                                 DLIList<CubitVector*>* curve_segments = 0 );
00429
00442   CubitPointData* project_to_surface( PartitionSurface* surface,
00443                                       const CubitVector& position );
00444
00464   CubitStatus project_to_surface( DLIList<CubitFacetData*>& facets,
00465                                   DLIList<CubitVector*>& polyline_in,
00466                                   DLIList<CubitFacetEdgeData*>& polyline_out,
00467                                   DLIList<CubitPointData*>& polyline_pts,
00468                                   const double *tolerance_length = NULL);
00469
00482   PartitionLump* insert_surface( PartitionLump* lump, PartitionSurface* surf );
00483
00484
00486   PartitionBody* make_body( PartitionPoint* pt );
00488   PartitionBody* make_body( PartitionCurve* curve );
00490   PartitionBody* make_body( PartitionSurface* surf );
00492   PartitionBody* make_body( PartitionLump* lump );
00494   PartitionBody* make_body_internal( TopologyBridge* child_ptr );
00495
00497   PartitionLump* replace_lump( Lump* lump );
00499   Lump* restore_lump( PartitionLump* lump );
00501   CubitStatus destroy_shell( PartitionShell* shell );
00502
00503
00504 public: /* temporarily public for debugging */
00506   SubSurface* replace_surface( Surface* surface );
00507 private:
00509   Surface* restore_surface( SubSurface* surface );
00510
00512   SubCurve* replace_curve( Curve* curve );
00514   Curve* restore_curve( SubCurve* curve );
00515
00517   PartitionPoint* replace_point( TBPoint* point );
00519   TBPoint* restore_point( PartitionPoint* point );
00520
00538   PartitionSurface* split_surface( PartitionSurface* surface,
00539                                    PartitionCoEdge* new_curve );
00540
00555   PartitionLump* split_lump( PartitionShell* shell );
00556
00563   PartitionShell* split_shell( PartitionShell* shell );
00564
00578   void insert_nonmanifold_surfaces( DLIList<PartitionSurface*>& surfaces,
00579                              PartitionShell* shell1, PartitionShell* shell2);
00580
00590   CubitStatus inside_shell( PartitionShell* const shell,
00591                             PartitionSurface* const surf,
00592                             bool& result );
00593
00595   CubitStatus save_curves( SubEntitySet* curve_set );
00597   CubitStatus save_surfaces( SubEntitySet* surface_set );
00599   CubitStatus save_lumps( SubEntitySet* lump_set );
00600
00602   CubitStatus restore_from_attrib( Curve* partitioned_curve );
00604   CubitStatus restore_from_attrib( Surface* partitioned_surface );
00606   CubitStatus restore_from_attrib( Lump* partitioned_lump );
00607
00608   static PartitionEngine* instance_;
00609
00611   std::map<int,SubEntitySet*> uniqueIdMap;
00612
00613   DLIList<TopologyBridge*> deactivatedList;
00614 };
00615
00616 #endif
