cgma
#include <FaceterPointData.hpp>
Definition at line 34 of file FaceterPointData.hpp.
FaceterPointData::FaceterPointData | ( | double | x_val, |
double | y_val, | ||
double | z_val | ||
Definition at line 19 of file FaceterPointData.cpp.
: coords( x_val, y_val, z_val ) { attachedFacets = NULL; point_counter++; entityId = point_counter; myOwner = NULL; myInteriorAngle = CUBIT_DBL_MAX; mPrev = NULL; mNext = NULL; }
FaceterPointData::FaceterPointData | ( | const CubitVector & | new_point | ) |
Definition at line 39 of file FaceterPointData.cpp.
: coords( new_point ) { attachedFacets = NULL; point_counter++; entityId = point_counter; myOwner = NULL; myInteriorAngle = CUBIT_DBL_MAX; mPrev = NULL; mNext = NULL; }
Definition at line 59 of file FaceterPointData.cpp.
{ delete attachedFacets; }
void FaceterPointData::add_facet | ( | CubitFacet * | facet | ) | [virtual] |
Implements CubitPoint.
Definition at line 87 of file FaceterPointData.cpp.
{ if ( attachedFacets == NULL ) attachedFacets = new DLIList<CubitFacet*>(8); attachedFacets->append(facet); return; }
void FaceterPointData::compute_avg_normal | ( | ) |
Reimplemented from CubitPoint.
CubitVector FaceterPointData::coordinates | ( | void | ) | const [inline, virtual] |
void FaceterPointData::coordinates | ( | double | point_array[3] | ) | [virtual] |
Definition at line 72 of file FaceterPointData.cpp.
void FaceterPointData::edges | ( | DLIList< CubitFacetEdge * > & | edge_list | ) | [virtual] |
Definition at line 119 of file FaceterPointData.cpp.
{ int ii, jj, kk; CubitFacet *facet_ptr; CubitFacetEdge *edge_ptr, *check_edge_ptr; for (ii=0; ii<attachedFacets->size(); ii++) { facet_ptr = attachedFacets->get_and_step(); for (jj=0; jj<3; jj++) { edge_ptr = facet_ptr->edge( jj ); if (edge_ptr) { if (edge_ptr->point(0) == this || edge_ptr->point(1) == this) { int found = 0; for (kk=0; kk<edge_list.size() && !found; kk++) { check_edge_ptr = edge_list.get_and_step(); if (check_edge_ptr == edge_ptr) found = 1; } if (!found) { edge_list.append( edge_ptr ); } } } } } return; }
void FaceterPointData::facets | ( | DLIList< CubitFacet * > & | facet_list | ) | [inline, virtual] |
Definition at line 98 of file FaceterPointData.hpp.
{ if (attachedFacets) facet_list += *attachedFacets; }
double FaceterPointData::get_interior_angle | ( | ) | [inline] |
Definition at line 66 of file FaceterPointData.hpp.
{return myInteriorAngle;}
FaceterPointData* FaceterPointData::get_next | ( | ) | [inline] |
Definition at line 74 of file FaceterPointData.hpp.
{return mNext;}
FaceterPointData* FaceterPointData::get_prev | ( | ) | [inline] |
Definition at line 70 of file FaceterPointData.hpp.
{return mPrev;}
void FaceterPointData::marked | ( | int | marked | ) | [inline, virtual] |
Definition at line 84 of file FaceterPointData.hpp.
{ markedFlag = marked;}
int FaceterPointData::marked | ( | ) | [inline, virtual] |
Definition at line 85 of file FaceterPointData.hpp.
{return markedFlag;}
int FaceterPointData::num_adj_facets | ( | ) | [virtual] |
Definition at line 162 of file FaceterPointData.cpp.
{ if (attachedFacets == NULL) return 0; else return attachedFacets->size(); }
void FaceterPointData::owner | ( | RefEntity * | my_owner | ) | [inline] |
Definition at line 90 of file FaceterPointData.hpp.
{myOwner = my_owner;}
RefEntity* FaceterPointData::owner | ( | ) | [inline] |
Definition at line 92 of file FaceterPointData.hpp.
{return myOwner;}
void FaceterPointData::points | ( | DLIList< CubitPoint * > & | point_list | ) | [inline, virtual] |
Definition at line 101 of file FaceterPointData.hpp.
{ point_list.append( this ); }
void FaceterPointData::remove_facet | ( | CubitFacet * | facet | ) | [virtual] |
Definition at line 103 of file FaceterPointData.cpp.
{ if ( attachedFacets == NULL ) return; attachedFacets->remove(facet); return; }
void FaceterPointData::set | ( | const CubitVector & | pos | ) | [inline, virtual] |
void FaceterPointData::set_interior_angle | ( | double | angle | ) | [inline] |
Definition at line 64 of file FaceterPointData.hpp.
{myInteriorAngle = angle;}
void FaceterPointData::set_next | ( | FaceterPointData * | next | ) | [inline] |
Definition at line 72 of file FaceterPointData.hpp.
{mNext = next;}
void FaceterPointData::set_prev | ( | FaceterPointData * | prev | ) | [inline] |
Definition at line 68 of file FaceterPointData.hpp.
{mPrev = prev;}
Definition at line 55 of file FaceterPointData.hpp.
{ return entityId;}
int FaceterPointData::sort_by_angle | ( | FaceterPointData *& | pt_1, |
FaceterPointData *& | pt_2 | ||
) | [static] |
Definition at line 170 of file FaceterPointData.cpp.
{ if ( (pt_1->get_interior_angle() > pt_2->get_interior_angle() ) ) return -1; if ( (pt_2->get_interior_angle() < pt_2->get_interior_angle() ) ) return 1; else return 0; }
double FaceterPointData::x | ( | void | ) | [inline, virtual] |
double FaceterPointData::y | ( | void | ) | [inline, virtual] |
double FaceterPointData::z | ( | void | ) | [inline, virtual] |
DLIList<CubitFacet*>* FaceterPointData::attachedFacets [private] |
Definition at line 39 of file FaceterPointData.hpp.
CubitVector FaceterPointData::coords [private] |
Definition at line 38 of file FaceterPointData.hpp.
int FaceterPointData::entityId [private] |
Definition at line 47 of file FaceterPointData.hpp.
MemoryManager FaceterPointData::memoryManager [static, private] |
Definition at line 44 of file FaceterPointData.hpp.
FaceterPointData* FaceterPointData::mNext [private] |
Definition at line 41 of file FaceterPointData.hpp.
FaceterPointData * FaceterPointData::mPrev [private] |
double FaceterPointData::myInteriorAngle [private] |
Definition at line 42 of file FaceterPointData.hpp.
RefEntity* FaceterPointData::myOwner [private] |
Definition at line 40 of file FaceterPointData.hpp.
