add_facet(CubitFacet *facet) | FaceterPointData | [virtual] |
add_TD(ToolData *new_td) | ToolDataUser | [virtual] |
adjacent_points(CubitPoint **adj_points, int &num_adj_points) | CubitPoint | |
adjacent_points(DLIList< CubitPoint * > &result_list) | CubitPoint | |
attachedFacets | FaceterPointData | [private] |
bounding_box() | CubitPoint | |
check_inverted_facets(const CubitVector &new_position) | CubitPoint | |
coef_vector() | CubitPoint | [inline, virtual] |
coef_vector(const CubitMatrix &coef) | CubitPoint | [inline, virtual] |
coefVector | CubitPoint | [protected] |
compute_avg_normal() | FaceterPointData | |
coordinates() const | FaceterPointData | [inline, virtual] |
coordinates(double point_array[3]) | FaceterPointData | [virtual] |
coords | FaceterPointData | [private] |
CubitPoint() | CubitPoint | |
d_coef(const double d_coefficient) | CubitPoint | [inline, virtual] |
d_coef() | CubitPoint | [inline, virtual] |
dCoef | CubitPoint | [protected] |
debug_draw(int color=-1, int flush=1, int draw_uv=0) | CubitPoint | [virtual] |
define_tangent_vectors() | CubitPoint | |
delete_TD(IdentityFn specified_type) | ToolDataUser | [virtual] |
delete_TD(ToolData *td) | ToolDataUser | [virtual] |
du(CubitVector &duvec) | CubitPoint | [inline, virtual] |
du() | CubitPoint | [inline, virtual] |
dv(CubitVector &dvvec) | CubitPoint | [inline, virtual] |
dv() | CubitPoint | [inline, virtual] |
edges(DLIList< CubitFacetEdge * > &edge_list) | FaceterPointData | [virtual] |
entityId | FaceterPointData | [private] |
FacetEntity() | FacetEntity | |
FaceterPointData(double x_val, double y_val, double z_val) | FaceterPointData | |
FaceterPointData(const CubitVector &new_point) | FaceterPointData | |
facets(DLIList< CubitFacet * > &facet_list) | FaceterPointData | [inline, virtual] |
facets_on_surf(int surf_id, DLIList< CubitFacet * > &facet_list, CubitBoolean &on_internal_boundary) | CubitPoint | |
get_all_TDs(IdentityFn specified_type, DLIList< ToolData * > *all_tds) const | ToolDataUser | [virtual] |
get_all_TDs(DLIList< ToolData * > *all_tds) const | ToolDataUser | [virtual] |
get_edge(CubitPoint *other_point) | CubitPoint | |
get_interior_angle() | FaceterPointData | [inline] |
get_next() | FaceterPointData | [inline] |
get_parents(DLIList< FacetEntity * > &facet_list) | CubitPoint | [virtual] |
get_prev() | FaceterPointData | [inline] |
get_TD(IdentityFn specified_type) | ToolDataUser | [virtual] |
get_TD(IdentityFn specified_type) const | ToolDataUser | [virtual] |
get_uv(CubitFacet *facet, double &u, double &v) | CubitPoint | [virtual] |
get_uvs(CubitFacet *facet, double &u, double &v, double &s) | CubitPoint | [virtual] |
id()=0 | CubitPoint | [pure virtual] |
is_feature() | CubitPoint | [inline] |
isFeature | CubitPoint | [protected] |
marked(int marked) | FaceterPointData | [inline, virtual] |
marked() | FaceterPointData | [inline, virtual] |
markedFlag | CubitPoint | [protected] |
memoryManager | FaceterPointData | [private, static] |
merge_points(CubitPoint *cp, CubitBoolean keep_point=CUBIT_FALSE) | CubitPoint | [virtual] |
mNext | FaceterPointData | [private] |
mPrev | FaceterPointData | [private] |
myInteriorAngle | FaceterPointData | [private] |
myOwner | FaceterPointData | [private] |
next_feature_edges(CubitFacetEdge *this_edge_ptr, DLIList< CubitFacetEdge * > feature_edge_list) | CubitPoint | |
normal(CubitVector &surf_norm) | CubitPoint | [inline, virtual] |
normal() | CubitPoint | [inline, virtual] |
normal(CubitFacet *facet_ptr) | CubitPoint | |
normal(CubitQuadFacet *qfacet_ptr) | CubitPoint | |
normal(CubitFacetEdge *edge_ptr) | CubitPoint | |
normal_ptr() | CubitPoint | [inline, virtual] |
num_adj_facets() | FaceterPointData | [virtual] |
owner(RefEntity *my_owner) | FaceterPointData | [inline] |
owner() | FaceterPointData | [inline] |
points(DLIList< CubitPoint * > &point_list) | FaceterPointData | [inline, virtual] |
project_to_tangent_plane(CubitVector &pt) | CubitPoint | |
remove_facet(CubitFacet *facet) | FaceterPointData | [virtual] |
remove_TD(IdentityFn specified_type) | ToolDataUser | [virtual] |
remove_TD(ToolData *td) | ToolDataUser | [virtual] |
reset_normal() | CubitPoint | [inline, virtual] |
rotate_normal(CubitTransformMatrix &rotmat) | CubitPoint | |
set(const CubitVector &pos) | FaceterPointData | [inline, virtual] |
set_as_feature() | CubitPoint | [inline] |
set_box_tol(double tol) | CubitPoint | [inline, static] |
set_id(int) | CubitPoint | [inline, virtual] |
set_interior_angle(double angle) | FaceterPointData | [inline] |
set_next(FaceterPointData *next) | FaceterPointData | [inline] |
set_normal(CubitVector &surf_norm) | CubitPoint | [inline, virtual] |
set_prev(FaceterPointData *prev) | FaceterPointData | [inline] |
set_uv(double u, double v) | CubitPoint | [inline, virtual] |
set_uvs(double u, double v, double s) | CubitPoint | [inline, virtual] |
SetDynamicMemoryAllocation(memoryManager) int id() | FaceterPointData | [inline] |
shared_edge(CubitPoint *other_point) | CubitPoint | |
shared_facets(CubitPoint *other_point, CubitFacet *&facet1, CubitFacet *&facet2) | CubitPoint | |
shared_facets(CubitPoint *other_point, DLIList< CubitFacet * > &result_list) | CubitPoint | |
size() | CubitPoint | [inline, virtual] |
sizeVal | CubitPoint | [protected] |
sort_by_angle(FaceterPointData *&pt_1, FaceterPointData *&pt_2) | FaceterPointData | [static] |
surfNormal | CubitPoint | [protected] |
surfU | CubitPoint | [protected] |
surfV | CubitPoint | [protected] |
tangent(CubitFacetEdge *edge_ptr, double mindot) | CubitPoint | |
ToolDataUser() | ToolDataUser | [inline] |
transform(CubitTransformMatrix &tfmat) | CubitPoint | |
transform_to_global(CubitVector &loc_vec, CubitVector &glob_vec) | CubitPoint | |
transform_to_local(CubitVector &glob_vec, CubitVector &loc_vec) | CubitPoint | |
tris(DLIList< CubitFacet * > &facet_list) | CubitPoint | [inline, virtual] |
uVal | CubitPoint | [protected] |
vVal | CubitPoint | [protected] |
x() | FaceterPointData | [inline, virtual] |
y() | FaceterPointData | [inline, virtual] |
z() | FaceterPointData | [inline, virtual] |
~CubitPoint() | CubitPoint | [virtual] |
~FacetEntity() | FacetEntity | [virtual] |
~FaceterPointData() | FaceterPointData | |
~ToolDataUser() | ToolDataUser | [virtual] |
