cgma
FaceterPointData.hpp
00001 //-----------------------------------------------------------------------------
00002 //
00003 //  File: FaceterPointData.hpp
00004 //
00005 //  Purpose:  Child class of CubitPoint.  It is the Cubit-specific version of
00006 //            of the CubitPoint.
00007 //
00008 //  Notes:    Note that this class contains data which is accessed
00009 //            virtually from CubitPoint.  In most cases, you can create
00010 //            a FaceterPointData and treat it as if it is a CubitPoint.
00011 //            For example:
00012 //               CubitPoint *cp = (CubitPoint *) new FaceterPointData(...);
00013 //            There should be no reason to reference the CubitFacetPoint
00014 //            directly.  This is done to allow different data representations
00015 //            of a point in addition to that used by Cubit.
00016 //
00017 //-----------------------------------------------------------------------------
00018
00019
00020 #ifndef FACETERPOINTDATA_HPP
00021 #define FACETERPOINTDATA_HPP
00022
00023 // Include for CubitBoolean
00024 #include "CubitDefines.h"
00025 #include "CubitVector.hpp"
00026 #include "DLIList.hpp"
00027 #include "MemoryManager.hpp"
00028 #include "ToolDataUser.hpp"
00029 #include "CubitMatrix.hpp"
00030 #include "CubitPoint.hpp"
00031 class CubitFacet;
00032 class RefEntity;
00033
00034 class FaceterPointData : public CubitPoint
00035 {
00036 private:
00037
00038   CubitVector coords;
00039   DLIList<CubitFacet*> *attachedFacets;
00040   RefEntity *myOwner;
00041   FaceterPointData *mNext, *mPrev;
00042   double myInteriorAngle;
00043
00044   static MemoryManager memoryManager;
00045     //- memory management object
00046
00047   int entityId;
00048
00049 public:
00050
00051   FaceterPointData(double x_val, double y_val, double z_val );
00052   FaceterPointData( const CubitVector &new_point );
00053   ~FaceterPointData();
00054
00055   SetDynamicMemoryAllocation(memoryManager)
00056       //- class specific new and delete operators
00057
00058   int id(){ return entityId;}
00059
00060     //The following functions are used for sorting FaceterPointData
00061     //based on their interior angle.
00062   static int sort_by_angle ( FaceterPointData *&pt_1,
00063                              FaceterPointData *&pt_2);
00064   void set_interior_angle(double angle)
00065     {myInteriorAngle = angle;}
00066   double get_interior_angle()
00067     {return myInteriorAngle;}
00068   void set_prev(FaceterPointData *prev)
00069     {mPrev = prev;}
00070   FaceterPointData* get_prev()
00071     {return mPrev;}
00072   void set_next(FaceterPointData *next)
00073     {mNext = next;}
00074   FaceterPointData* get_next()
00075     {return mNext;}
00076
00077
00078
00079   double x(){return coords.x();}
00080   double y(){return coords.y();}
00081   double z(){return coords.z();}
00082   void set( const CubitVector &pos ) { coords = pos; }
00083
00084   void marked(int marked){ markedFlag = marked;}
00085   int marked(){return markedFlag;}
00086     //- generic marker for efficient sorting.
00087
00088   CubitVector coordinates() const { return coords; }
00089   void coordinates(double point_array[3]);
00090   void owner(RefEntity* my_owner)
00091     {myOwner = my_owner;}
00092   RefEntity* owner()
00093     {return myOwner;}
00094   void add_facet( CubitFacet *facet);
00095   void remove_facet( CubitFacet *facet );
00096   int num_adj_facets();
00097
00098   void facets( DLIList<CubitFacet*> &facet_list)
00099     { if (attachedFacets) facet_list += *attachedFacets; }
00100   void edges( DLIList<CubitFacetEdge*> &edge_list);
00101   void points( DLIList<CubitPoint*> &point_list )
00102     { point_list.append( this ); }
00103
00104   void compute_avg_normal();
00105 };
00106
00107 #endif
