cgma
CubitSparseMatrix Class Reference
#include <CubitSparseMatrix.hpp>
List of all members.
Public Member Functions
 CubitSparseMatrix ()
 CubitSparseMatrix (int numRows, int numCols, std::vector< int > &is, std::vector< int > &js, std::vector< double > &es)
 ~CubitSparseMatrix ()
void reset (int numRows, int numCols, std::vector< int > &is, std::vector< int > &js, std::vector< double > &es)
void clear ()
void print (char *filename=0) const
void add (int row, int col, double data)
int num_non_zeros (void) const
void num_non_zeros_per_row (double &ave, int &max, int &min) const
int num_rows (void) const
int num_cols (void) const
const std::map< int, double > * get_row (int row) const
void sub_matrix (const std::vector< bool > &rows_to_include, const std::vector< bool > &cols_to_include, CubitSparseMatrix &submatrix)
std::vector< double > operator* (const std::vector< double > &vec) const
void plus_identity ()
Private Member Functions
void delete_data (void)
Private Attributes
std::map< int, std::map< int,
double > * >
matrixData
int numRows
int numCols
Detailed Description
Definition at line 18 of file CubitSparseMatrix.hpp.
Definition at line 49 of file CubitSparseMatrix.cpp.
  numRows = numCols = 0;
CubitSparseMatrix::CubitSparseMatrix ( int  numRows,
int  numCols,
std::vector< int > &  is,
std::vector< int > &  js,
std::vector< double > &  es
Member Function Documentation
void CubitSparseMatrix::add ( int  row,
int  col,
double  data
Definition at line 107 of file CubitSparseMatrix.cpp.
  if ( row+1 > numRows ||
       col+1 > numCols )
    throw std::invalid_argument( "The dimensions of the 2 matrices must be the same." );
  map<int,double> *submap = NULL;
  map<int,map<int,double>*>::iterator iter = matrixData.find( row );
  if ( iter == matrixData.end() )
    submap = new map<int,double>;
    matrixData.insert( std::pair<int, map<int,double>*>(row, submap) );
  else
    submap = iter->second;
    map<int,double>::iterator iter2 = submap->find( col );
    if ( iter2 != submap->end() )
      iter2->second += data;
      return;
  submap->insert( std::pair<int, double>( col, data ) );
Definition at line 94 of file CubitSparseMatrix.cpp.
  numRows = 0;
  numCols = 0;
  delete_data();
void CubitSparseMatrix::delete_data ( void  ) [private]
Definition at line 152 of file CubitSparseMatrix.cpp.
  while ( !matrixData.empty() )
    map<int,double> *submap = matrixData.begin()->second;
    matrixData.begin()->second = NULL;
    matrixData.erase( matrixData.begin() );
    delete submap;
const map< int, double > * CubitSparseMatrix::get_row ( int  row) const
Definition at line 300 of file CubitSparseMatrix.cpp.
  if ( row < 0 || row >= numRows )
    throw std::invalid_argument( "The row index must be greater than or equal to 0, and less than the number of rows in the matrix." );
  map<int, map<int,double>*>::const_iterator iter = matrixData.find( row );
    return NULL;
  return iter->second;
int CubitSparseMatrix::num_cols ( void  ) const [inline]
Definition at line 47 of file CubitSparseMatrix.hpp.
{ return numCols; };
int CubitSparseMatrix::num_non_zeros ( void  ) const
Definition at line 418 of file CubitSparseMatrix.cpp.
  int num_nz = 0;
  map<int, map<int,double>*>::const_iterator iter1 = matrixData.begin();
  while ( iter1 != matrixData.end() )
    //iter1->first;
    map<int,double>*submap = iter1->second;
    if ( submap ) num_nz += submap->size();
    iter1++;
  return num_nz;
void CubitSparseMatrix::num_non_zeros_per_row ( double &  ave,
int &  max,
int &  min
) const
Definition at line 370 of file CubitSparseMatrix.cpp.
  max = 0;
  min = numCols;
  ave = 0.0;
    //iter1->first;
    iter1++;
    int nz = submap->size();
    ave += nz;
    if ( nz > max ) max = nz;
    if ( nz < min ) min = nz;
  if ( numCols > 0 )
    ave /= numCols;
int CubitSparseMatrix::num_rows ( void  ) const [inline]
Definition at line 46 of file CubitSparseMatrix.hpp.
{ return numRows; };
vector< double > CubitSparseMatrix::operator* ( const std::vector< double > &  vec) const
Definition at line 259 of file CubitSparseMatrix.cpp.
  if ( (int) vec.size() != numCols )
    throw std::invalid_argument( "The length of the input vector must be the same as the number of colums in the matrix." );
  vector<double> ans( numRows );
  int i;
  for ( i = 0; i < numRows; i++ )
    ans[i] = 0.0;
    int row = iter1->first;
    iter1++;
    map<int,double>::iterator iter2 = submap->begin();
    while ( iter2 != submap->end() )
      int col = iter2->first;
      double data = iter2->second;
      iter2++;
      ans[row] += data * vec[col];
  return ans;
Definition at line 403 of file CubitSparseMatrix.cpp.
  for ( int i = 0; i < numRows; i++ )
    if ( i > numCols ) break;
    add( i, i, 1.0 );
void CubitSparseMatrix::print ( char *  filename = 0) const
Definition at line 319 of file CubitSparseMatrix.cpp.
  printf( "CubitSparseMatrix::numRows: %d\n", numRows );
  printf( "CubitSparseMatrix::numCols: %d\n", numCols );
  int min, max;
  double ave;
  num_non_zeros_per_row( ave, max, min );
  printf( "CubitSparseMatrix::Average # Non Zeros per row: %f\n", ave );
  printf( "CubitSparseMatrix::Minimum # Non Zeros per row: %d\n", min );
  printf( "CubitSparseMatrix::Maximum # Non Zeros per row: %d\n", max );
  CubitFile fp;
  if ( filename )
    fp.open( filename, "w" );
    iter1++;
      iter2++;
      if ( fp.file() )
        fprintf( fp.file(), "%d %d %f\n",
                row, col, data );
      else
      printf( "CubitSparseMatrix::(%d,%d) : %f\n",
              row, col, data );
void CubitSparseMatrix::reset ( int  numRows,
int  numCols,
Definition at line 61 of file CubitSparseMatrix.cpp.
  if( is.size() != js.size() ||
      is.size() != es.size() )
    throw std::invalid_argument("The sizes of is, js, and es must be the same" );
  delete_data();
  int num_data = is.size();
  numRows = num_rows;
  numCols = num_cols;
  for ( int i = 0; i < num_data; i++ )
    add( is[i], js[i], es[i] );
void CubitSparseMatrix::sub_matrix ( const std::vector< bool > &  rows_to_include,
const std::vector< bool > &  cols_to_include,
CubitSparseMatrix submatrix
Definition at line 172 of file CubitSparseMatrix.cpp.
  if ( (int) rows_to_include.size() != numRows )
    throw std::invalid_argument( "The length of rows_to_include must the the same as the number of rows in the matrix." );
  if ( (int) cols_to_include.size() != numCols )
    throw std::invalid_argument( "The length of cols_to_include must the the same as the number of colums in the matrix." );
  vector<int> is;
  vector<int> js;
  vector<double> es;
  int i;
  int *row_indices = new int[numRows];
  int *col_indices = new int[numCols];
  int num_rows = 0;
  int num_cols = 0;
    if ( rows_to_include[i] )
      row_indices[i] = num_rows;
      num_rows++;
    else
      row_indices[i] = 0;
  for ( i = 0; i < numCols; i++ )
    if ( cols_to_include[i] )
      col_indices[i] = num_cols;
      num_cols++;
    else
      col_indices[i] = 0;
  map<int, map<int,double>*>::iterator iter1 = matrixData.begin();
    iter1++;
    if ( !rows_to_include[row] )
      continue;
      iter2++;
      if ( !cols_to_include[col] )
        continue;
      is.push_back( row_indices[row] );
      js.push_back( col_indices[col] );
      es.push_back( data );
  delete [] col_indices;
  delete [] row_indices;
  submatrix.reset( num_rows, num_cols, is, js, es );
Member Data Documentation
std::map< int, std::map< int, double> * > CubitSparseMatrix::matrixData [private]
Definition at line 67 of file CubitSparseMatrix.hpp.
Definition at line 70 of file CubitSparseMatrix.hpp.
Definition at line 69 of file CubitSparseMatrix.hpp.
