cgma
CubitAttribUser Class Reference
#include <CubitAttribUser.hpp>
Inheritance diagram for CubitAttribUser:
RefEntity BasicTopologyEntity Body RefCollection RefEdge RefFace RefVertex RefVolume RefGroup
List of all members.
Public Member Functions
virtual ~CubitAttribUser ()
 CubitAttribUser (CubitAttrib *=NULL)
CubitAttribget_cubit_attrib (int attrib_type, CubitBoolean create_if_missing=CUBIT_TRUE)
CubitStatus add_cubit_attrib (CubitAttrib *cubit_attrib_ptr)
void append_simple_attribute (TopologyBridge *bridge, const CubitSimpleAttrib &attrib_ptr)
void append_attrib_internal (TopologyBridge *bridge, const CubitSimpleAttrib &attrib_ptr)
void remove_all_simple_attribute (TopologyBridge *bridge)
void remove_simple_attribute (TopologyBridge *bridge, const CubitSimpleAttrib &attrib_ptr)
CubitStatus clear_simple_attribs ()
CubitStatus clear_simple_attribs_set_to_actuate ()
CubitStatus auto_read_cubit_attrib ()
CubitStatus read_cubit_attrib (int attrib_type)
CubitStatus write_specific_cubit_attrib (CubitAttrib *cubit_attrib_ptr)
CubitStatus write_cubit_attrib_by_type (int attrib_type)
CubitStatus write_cubit_attrib_list (DLIList< CubitAttrib * > attrib_list)
CubitStatus write_cubit_attribs ()
void split_owner (DLIList< CubitSimpleAttrib > &csa_list)
void merge_owner (RefEntity *deletable_entity)
void transf_owner (const CubitVector &matrow1, const CubitVector &matrow2, const CubitVector &matrow3, const CubitVector &translate_vec, const double scale_factor)
CubitStatus actuate_cubit_attrib (int attrib_type)
CubitStatus auto_actuate_cubit_attrib (CubitBoolean from_constructor=CUBIT_TRUE, CubitBoolean after_geom_changes=CUBIT_FALSE)
CubitStatus update_cubit_attrib (int)
CubitStatus auto_update_cubit_attrib ()
void find_cubit_attrib_type (int, DLIList< CubitAttrib * > &) const
CubitStatus remove_cubit_attrib (int attrib_type)
CubitStatus remove_cubit_attrib (CubitAttrib *)
CubitStatus remove_attrib_geometry_entity (CubitAttrib *)
void get_cubit_attrib_list (DLIList< CubitAttrib * > &)
int num_cubit_attrib ()
void set_updated_flag (CubitBoolean flag)
void set_written_flag (CubitBoolean flag)
Static Public Member Functions
static CubitStatus actuate_cubit_attrib (DLIList< RefEntity * >, int)
static CubitStatus auto_update_cubit_attrib (DLIList< RefEntity * > &entity_list, CubitBoolean write_too=CUBIT_TRUE)
static CubitStatus clear_all_simple_attrib (DLIList< RefEntity * > &entity_list)
static CubitStatus clear_all_simple_attrib_set_to_actuate (DLIList< RefEntity * > &entity_list)
Protected Attributes
CubitAttribheadAttrib
Private Member Functions
 CubitAttribUser (const CubitAttribUser &)
void operator= (const CubitAttribUser &)
CubitStatus put_simple_attrib (const CubitSimpleAttrib &cubit_simple_attrib_ptr, CubitBoolean append_it=CUBIT_TRUE)
void auto_create_for_merge (RefEntity *deletable_entity)
CubitStatus actuate_cubit_attrib (DLIList< CubitAttrib * >)
CubitStatus actuate_cubit_attrib (CubitAttrib *)
CubitStatus remove_cubit_attrib (DLIList< CubitAttrib * >)
Static Private Member Functions
static void auto_reset_cubit_attrib (DLIList< RefEntity * > ref_ents)
Detailed Description
Definition at line 29 of file CubitAttribUser.hpp.
Definition at line 33 of file CubitAttribUser.cpp.
  //delete all ToolData's chained off this user.
  CubitAttrib *ca_ptr = headAttrib;
  while ( ca_ptr) {
    CubitAttrib *next = ca_ptr->next_attrib();
    delete ca_ptr;
    ca_ptr = next;
  headAttrib = NULL;
CubitAttribUser::CubitAttribUser ( CubitAttrib cubit_attrib_ptr = NULL)
Definition at line 28 of file CubitAttribUser.cpp.
  headAttrib = cubit_attrib_ptr;
Member Function Documentation
Definition at line 490 of file CubitAttribUser.cpp.
  DLIList<CubitAttrib*> attrib_list;
  find_cubit_attrib_type(attrib_type, attrib_list);
  CubitStatus actuate_status = actuate_cubit_attrib(attrib_list);
  return actuate_status;
Definition at line 498 of file CubitAttribUser.cpp.
  CubitStatus actuate_status = CUBIT_SUCCESS;
  attrib_list.reset();
  for(int i = 0; i < attrib_list.size(); i++)
    CubitAttrib* cubit_attrib_ptr = attrib_list.get_and_step();
    if (actuate_cubit_attrib(cubit_attrib_ptr) == CUBIT_FAILURE)
      actuate_status = CUBIT_FAILURE;
Definition at line 470 of file CubitAttribUser.cpp.
  CubitStatus return_value = CUBIT_FAILURE;
  if (cubit_attrib_ptr != NULL )
    if (cubit_attrib_ptr->has_actuated() == CUBIT_TRUE ||
        cubit_attrib_ptr->delete_attrib() == CUBIT_TRUE) {
      return CUBIT_FAILURE;
    return_value = cubit_attrib_ptr->actuate();
    if (cubit_attrib_ptr->delete_attrib() == CUBIT_TRUE)
      return_value = remove_cubit_attrib(cubit_attrib_ptr);
      delete cubit_attrib_ptr;
  return return_value;
CubitStatus CubitAttribUser::actuate_cubit_attrib ( DLIList< RefEntity * >  refent_list,
int  attrib_type
) [static]
Definition at line 512 of file CubitAttribUser.cpp.
  RefEntity *ref_ent;
  for(int i = refent_list.size(); i > 0; i--)
    ref_ent = refent_list.get_and_step();
    TopologyEntity* me_ptr = dynamic_cast<TopologyEntity*>(ref_ent);
    if( me_ptr && me_ptr->deactivated() )
      continue;
    ref_ent->find_cubit_attrib_type(attrib_type, attrib_list);
    if (attrib_list.size() > 0)
      return ((attrib_list.get())->actuate_list(refent_list));
Definition at line 65 of file CubitAttribUser.cpp.
  if (cubit_attrib_ptr == NULL)
  CubitStatus cubit_attribute_status = CUBIT_FAILURE;
  CubitAttrib *temp_ptr;
  if (headAttrib == NULL)
    cubit_attribute_status = CUBIT_SUCCESS;
  else
    for(temp_ptr = headAttrib;
        temp_ptr->next_attrib() != NULL;
        temp_ptr = temp_ptr->next_attrib());
    temp_ptr->set_next_attrib(cubit_attrib_ptr);
  return cubit_attribute_status;
void CubitAttribUser::append_attrib_internal ( TopologyBridge bridge,
const CubitSimpleAttrib attrib_ptr
Definition at line 1190 of file CubitAttribUser.cpp.
  DLIList<CubitSimpleAttrib> others;
    // Check for duplicates
  if ( attrib_ptr.character_type() != "DEFERRED_ATTRIB" )
    bridge->get_simple_attribute( attrib_ptr.character_type().c_str(), others );
    while ( others.size() )
      bridge->remove_simple_attribute_virt( others.pop() );
  else
    CubitString real_name = attrib_ptr.string_data_list()[1];
    bridge->get_simple_attribute("DEFERRED_ATTRIB", others);
      CubitSimpleAttrib dup_attrib = others.pop();
      if ( dup_attrib.string_data_list()[1] == real_name )
        bridge->remove_simple_attribute_virt(dup_attrib);
    // append attribute
  bridge->append_simple_attribute_virt(attrib_ptr);
void CubitAttribUser::append_simple_attribute ( TopologyBridge bridge,
Definition at line 1127 of file CubitAttribUser.cpp.
    // for merged objects, put attribute on other entities
  if (CubitSimpleAttrib::get_push_attribs() == CUBIT_TRUE ||
    CGMApp::instance()->attrib_manager()->auto_update_flag(CA_MERGE_PARTNER) == CUBIT_TRUE) {
    DLIList<TopologyBridge*> tb_list;
    bridge->bridge_manager()->get_bridge_list(tb_list);
      // if this entity is merged, it will have > 1 entity in the bridge
      // list
    tb_list.reset();
    assert(tb_list.size() == 0 || tb_list.get() == bridge);
      // Special handling of MergePartner attribute.
      // Need to store the bridge sense in the attribute, which
      // is potentially different for different TopologyBridges.
    int type = CGMApp::instance()->attrib_manager()->attrib_type_from_internal_name(attrib_ptr.character_type().c_str());
    if ( type == CA_MERGE_PARTNER )
      CubitSimpleAttrib merge_attrib = attrib_ptr;
        // now adjust the attrib on each bridge to hold the
        // relative sense for that bridge.
      for (int i = tb_list.size(); i > 0; i--) {
        TopologyBridge *temp_tb = tb_list.get_and_step();
        CAMergePartner::set_bridge_sense( merge_attrib, temp_tb->bridge_sense() );
        GeometryEntity *geom_ptr = dynamic_cast<GeometryEntity*>(temp_tb);
        if (geom_ptr )
          //if we're copying a merged entity, saved id should be zero
          if( GeometryModifyTool::instance()->get_copy_entity() )
            CAMergePartner::set_saved_id( merge_attrib, 0 );
          else
            CAMergePartner::set_saved_id( merge_attrib, geom_ptr->get_saved_id() );
          //First bridge should be marked as "survivor"
          if( i == tb_list.size() )
            CAMergePartner::set_survivor( merge_attrib, 1 );
          else
            CAMergePartner::set_survivor( merge_attrib, 0 );
        append_attrib_internal(temp_tb, merge_attrib);
      // For anything other than CAMergePartner, just append the
      // unmodified attribute to each bridge.
    else
      for ( int i = tb_list.size(); i--; )
        append_attrib_internal( tb_list.get_and_step(), attrib_ptr);
  else
      // Append this name to the primary bridge
    append_attrib_internal(bridge, attrib_ptr);
Definition at line 556 of file CubitAttribUser.cpp.
  CubitAttrib *attrib;
  get_cubit_attrib_list(attrib_list);
  int i;
  for( i = attrib_list.size(); i != 0; i--)
    attrib = attrib_list.get_and_step();
      // check first for deletable attribute; this attribute shouldn't really be here,
      // but until we figure out why it is...
    if (attrib->delete_attrib() == CUBIT_TRUE) {
      PRINT_DEBUG_90("Trying to auto actuate deletable attribute - this is bad...\n");
    else if (attrib->auto_actuate_flag() == CUBIT_TRUE &&
        !attrib->has_actuated() &&
        (!from_constructor || attrib->actuate_in_constructor()) &&
        (after_geom_changes || !attrib->actuate_after_geom_changes()))
      PRINT_DEBUG_90("Actuating attribute type %s for %s %d\n",
                     attrib->att_internal_name(), attrib->attrib_owner()->class_name(),
                     attrib->attrib_owner()->id());
      if(attrib->actuate() == CUBIT_FAILURE)
        // need to check again for delete flag, since it might have been set
        // in actuate function
      if( attrib->delete_attrib() == CUBIT_TRUE)
        remove_cubit_attrib(attrib);
        delete attrib;
//  if (CADeferredAttrib::cleanup_cadas(from_constructor, after_geom_changes) == CUBIT_FAILURE)
//    actuate_status = CUBIT_FAILURE;
void CubitAttribUser::auto_create_for_merge ( RefEntity deletable_entity) [private]
Definition at line 448 of file CubitAttribUser.cpp.
    // copy any attr's on deletable_entity but not on this
  DLIList<CubitAttrib*> deletable_ca_list;
  deletable_entity->get_cubit_attrib_list(deletable_ca_list);
  if (deletable_ca_list.size() == 0) return;
  DLIList<CubitAttrib*> new_list;
  RefEntity *entity = CAST_TO(this, RefEntity);
  for (int i = deletable_ca_list.size(); i > 0; i--) {
    new_list.clean_out();
    CubitAttrib *deletable_ca_ptr = deletable_ca_list.get_and_step();
    find_cubit_attrib_type(deletable_ca_ptr->int_attrib_type(), new_list);
    if (new_list.size() == 0)
      CGMApp::instance()->attrib_manager()->create_cubit_attrib(
            entity, CubitSimpleAttrib());
Definition at line 889 of file CubitAttribUser.cpp.
    // auto read all simple attributes on this entity & create CA's for them;
    // checks global and CA-specific auto read flag, and puts CSA's back on
    // entity if auto read for that type is off
  CubitStatus cubit_assign_status = CUBIT_FAILURE;
    // Get the GeometryEntity of this RefEntity (it could be the OSME
    // if it is a Body) and get its name, if it exists
  DLIList<CubitSimpleAttrib> csattrib_list;
    // Deal with a Body entity
  Body* Body_ptr = CAST_TO(this, Body);
  BasicTopologyEntity* BTE_ptr = CAST_TO(this, BasicTopologyEntity);
  if ( Body_ptr != NULL )
    BodySM* OSME_ptr = Body_ptr->get_body_sm_ptr();
    OSME_ptr->get_simple_attribute(csattrib_list);
    remove_all_simple_attribute(OSME_ptr);
  else if ( BTE_ptr != NULL )
    GeometryEntity* GE_ptr = BTE_ptr->get_geometry_entity_ptr();
    GE_ptr->get_simple_attribute(csattrib_list);
    remove_all_simple_attribute(GE_ptr);
  else return CUBIT_SUCCESS;
  csattrib_list.reset();
  for(int i = csattrib_list.size(); i != 0; i--)
    const CubitSimpleAttrib& cubit_simple_attrib_ptr = csattrib_list.get_and_step();
    int csa_type = CGMApp::instance()->attrib_manager()->attrib_type(cubit_simple_attrib_ptr);
    CubitAttrib *new_attrib = NULL;
    if (CGMApp::instance()->attrib_manager()->auto_read_flag(csa_type))
        // auto create this CA
      new_attrib = CGMApp::instance()->attrib_manager()->create_cubit_attrib(csa_type,
                                                    CAST_TO(this, RefEntity), cubit_simple_attrib_ptr);
    if (new_attrib != NULL && new_attrib->delete_attrib() == CUBIT_FALSE)
      cubit_assign_status = CUBIT_SUCCESS;
    else if (new_attrib != NULL && new_attrib->delete_attrib() == CUBIT_TRUE) {
      remove_cubit_attrib(new_attrib);
      delete new_attrib;
    else
      put_simple_attrib(cubit_simple_attrib_ptr);
  return cubit_assign_status;
void CubitAttribUser::auto_reset_cubit_attrib ( DLIList< RefEntity * >  ref_ents) [static, private]
Definition at line 730 of file CubitAttribUser.cpp.
    // set the update flag back off for all attribs on these entities and their children
  DLIList<RefEntity*> children, temp_list;
  int i;
  for (i = ref_ents.size(); i > 0; i--) {
    temp_list.clean_out();
    ref_ents.get_and_step()->get_all_child_ref_entities(temp_list);
    children += temp_list;
  ref_ents.merge_unique(children);
    // ok, have a unique'd list if entities; now reset on each of them
  ref_ents.reset();
    ref_ents.get()->set_written_flag(CUBIT_FALSE);
    ref_ents.get_and_step()->set_updated_flag(CUBIT_FALSE);
Definition at line 653 of file CubitAttribUser.cpp.
    // for this cau, automatically create and update ca's
    // first, create ca's for any attribute type which has its auto
    // update flag set and which isn't present yet on this entity
  /*CubitStatus success = */
  CGMApp::instance()->attrib_manager()->auto_update_attribs(CAST_TO(this, RefEntity));
    // now, update all attributes present on this entity
  CubitStatus update_status = CUBIT_SUCCESS;
  DLIList<CubitAttrib*> attribs_to_delete;
  int i;
    if (!attrib->has_updated()) {
        // if this attribute has written already, reset the information in it
        // so it gets a "clean" update (otherwise information can be added to
        // lists on the attrib more than once)
      if (CUBIT_TRUE == attrib->has_written())
         attrib->reset();
        // reset the delete flag here, so we don't need to do it in every attribute
        // (it'll get set back to delete if the update isn't successful)
      attrib->delete_attrib(CUBIT_FALSE);
      PRINT_DEBUG_90("Updating attribute type %s for %s %d, delete = ",
      update_status = attrib->update();
      if( attrib->delete_attrib() )
        attribs_to_delete.append( attrib );
      PRINT_DEBUG_90("%s\n",
                     (attrib->delete_attrib() == CUBIT_FALSE ? "NO" : "YES"));
        // if update was successful, reset the written flag (assumes that all
        // updates are done before writing starts)
        // (don't reset if it's the entity_name attrib, since this attrib is
        // written automatically every time it's updated)
      if (update_status == CUBIT_SUCCESS && attrib->int_attrib_type() != CA_ENTITY_NAME)
        attrib->has_written(CUBIT_FALSE);
    else
        PRINT_DEBUG_90("Not updating attribute type %s for %s %d, delete = ",
  //remove any attribs that don't need to be there
  remove_cubit_attrib( attribs_to_delete );
  RefEntity* re_ptr;
  re_ptr = CAST_TO(this, RefEntity);
  DLIList<RefEntity*> children;
  re_ptr->get_child_ref_entities( children );
  for ( i = children.size(); i > 0; i-- )
    children.get()->auto_update_cubit_attrib();
    children.step();
  return update_status;
Definition at line 766 of file CubitAttribUser.cpp.
    //- for entity_list, auto create, update and write ca's
    // now, reset the update and write flags for these entities
    // and their children
  auto_reset_cubit_attrib(entity_list);
    // need to update all then write all in separate loops,
    // to prevent duplication of attributes
  int i;
  for ( i = entity_list.size(); i > 0; i--)
     entity_list.get_and_step()->auto_update_cubit_attrib();
  if (write_too) {
    for (i = entity_list.size(); i > 0; i--)
      entity_list.get_and_step()->write_cubit_attribs();
Definition at line 790 of file CubitAttribUser.cpp.
  CubitStatus result = CUBIT_SUCCESS;
  for( int i = entity_list.size(); i--; )
    if( entity_list.get_and_step()->clear_simple_attribs() != CUBIT_SUCCESS )
      result = CUBIT_FAILURE;
  return result;
Definition at line 799 of file CubitAttribUser.cpp.
    if( entity_list.get_and_step()->clear_simple_attribs_set_to_actuate() != CUBIT_SUCCESS )
  return result;
Definition at line 213 of file CubitAttribUser.cpp.
  CubitAttrib *cubit_attrib_ptr = NULL;
  CubitAttrib *next_attrib_ptr = NULL;
  for(cubit_attrib_ptr = headAttrib;
      cubit_attrib_ptr != NULL;)
    //ignore Assembly and Name attributes
    next_attrib_ptr = cubit_attrib_ptr->next_attrib();
    if( cubit_attrib_ptr->int_attrib_type() != CA_ENTITY_NAME &&
        cubit_attrib_ptr->int_attrib_type() != CA_ASSEMBLY_DATA)
      remove_cubit_attrib( cubit_attrib_ptr );
    cubit_attrib_ptr = next_attrib_ptr;
  if (DEBUG_FLAG(94))
    PRINT_DEBUG_94("CubitAttribUser::clear_simple_attribs()\n");
  TopologyEntity* te_ptr = dynamic_cast<TopologyEntity*>(this);
  if( !te_ptr )
  remove_all_simple_attribute(te_ptr->bridge_manager()->topology_bridge());
  update_cubit_attrib(CA_ASSEMBLY_DATA);
  write_cubit_attrib_by_type(CA_ASSEMBLY_DATA);
  update_cubit_attrib(CA_ENTITY_NAME);
  write_cubit_attrib_by_type( CA_ENTITY_NAME );
Definition at line 178 of file CubitAttribUser.cpp.
        cubit_attrib_ptr->int_attrib_type() != CA_ASSEMBLY_DATA &&
        CGMApp::instance()->attrib_manager()->auto_actuate_flag(
          cubit_attrib_ptr->int_attrib_type()))
  if (DEBUG_FLAG(94))
  if( !te_ptr )
void CubitAttribUser::find_cubit_attrib_type ( int  type,
DLIList< CubitAttrib * > &  attrib_list
) const
Definition at line 808 of file CubitAttribUser.cpp.
  for(CubitAttrib* cubit_attrib_ptr = headAttrib;
      cubit_attrib_ptr = cubit_attrib_ptr->next_attrib())
    if (type == cubit_attrib_ptr->int_attrib_type())
      attrib_list.append_unique(cubit_attrib_ptr);
CubitAttrib * CubitAttribUser::get_cubit_attrib ( int  attrib_type,
CubitBoolean  create_if_missing = CUBIT_TRUE
Definition at line 47 of file CubitAttribUser.cpp.
  CubitAttrib* cubit_attrib_ptr = NULL;
  RefEntity* entity = NULL;
  find_cubit_attrib_type (attrib_type, attrib_list);
    cubit_attrib_ptr =  attrib_list.get();
  else if ( create_if_missing == CUBIT_TRUE )
    cubit_attrib_ptr = CGMApp::instance()->attrib_manager()->create_cubit_attrib(attrib_type, entity, CubitSimpleAttrib());
  return cubit_attrib_ptr;
Definition at line 1013 of file CubitAttribUser.cpp.
      cubit_attrib_ptr = cubit_attrib_ptr->next_attrib()) {
    assert(NULL != cubit_attrib_ptr);
void CubitAttribUser::merge_owner ( RefEntity deletable_entity)
Definition at line 359 of file CubitAttribUser.cpp.
    //- if owner is to be merged, combine attribs from deletable_entity with this
    // if no deletable entity, keep the entity name and delete the other
    // attribs on this entity
  int i;
  if (deletable_entity == NULL) {
    DLIList<CubitAttrib*> ca_list;
    get_cubit_attrib_list(ca_list);
    for (i = ca_list.size(); i > 0; i--) {
      CubitAttrib *ca_ptr = ca_list.get_and_step();
      if (ca_ptr->int_attrib_type() != CA_ENTITY_NAME &&
          ca_ptr->int_attrib_type() != CA_ASSEMBLY_DATA &&
          ca_ptr->int_attrib_type() != CA_MESH_OUTPUT_GROUP)
        remove_cubit_attrib(ca_ptr);
        delete ca_ptr;
    return;
    // first auto create attributes
  auto_create_for_merge(deletable_entity);
    // call merge for each attribute, passing other as argument
  DLIList<CubitAttrib*> ca_list, deletable_ca_list;
  assert(ca_list.size() >= deletable_ca_list.size());
    deletable_ca_list.reset();
    CubitAttrib *deletable_ca_ptr = NULL;
    if (deletable_ca_list.size() > 0) {
      deletable_ca_ptr = deletable_ca_list.get();
        // get the corresponding deletable attribute, then extract it from
        //   the list
      while (ca_ptr->int_attrib_type() != deletable_ca_ptr->int_attrib_type() &&
             !deletable_ca_list.is_at_end()) {
        deletable_ca_list.step();
      if (ca_ptr->int_attrib_type() == deletable_ca_ptr->int_attrib_type())
        deletable_ca_list.extract();
      else deletable_ca_ptr = NULL;
    ca_ptr->merge_owner(deletable_ca_ptr);
    // now, check delete flag for each ca_ptr, and delete if necessary
    if (ca_ptr->delete_attrib()) {
      delete ca_ptr;
  // ok, we're done
Definition at line 1023 of file CubitAttribUser.cpp.
  int number = 0;
    number++;
  return number;
void CubitAttribUser::operator= ( const CubitAttribUser ) [private]
CubitStatus CubitAttribUser::put_simple_attrib ( const CubitSimpleAttrib cubit_simple_attrib_ptr,
CubitBoolean  append_it = CUBIT_TRUE
) [private]
Definition at line 90 of file CubitAttribUser.cpp.
  Body* Body_ptr;
  BasicTopologyEntity* BTE_ptr;
      // Get the OSME pointer
      // check for duplicates
    if (DEBUG_FLAG(94))
      DLIList<CubitSimpleAttrib> cs_list;
      OSME_ptr->get_simple_attribute(cs_list);
      for (int i = cs_list.size(); i > 0; i--)
        const CubitSimpleAttrib cs_attrib = cs_list.get_and_step();
        if (cs_attrib == new_csattrib_ptr)
          PRINT_INFO("Trying to add equivalent attribute of type %s on Body %d.\n",
                     new_csattrib_ptr.character_type().c_str(), Body_ptr->id());
        else if (cs_attrib.character_type() == new_csattrib_ptr.character_type())
          PRINT_INFO("Trying to add attribute of same type %s on Body %d.\n",
//________  Change Code by DZ of Cat,  3/11/99 12:25:30 PM  ________
      // Attach this name to it
    if ( append_it )
       append_simple_attribute(OSME_ptr, new_csattrib_ptr);
//________  Change End by DZ of Cat,  3/11/99 12:25:30 PM  ________
    // Deal with BasicTopologyEntities
      // Get the GeometryEntity pointer
    if( NULL == GE_ptr )
    if (DEBUG_FLAG(94))
      GE_ptr->get_simple_attribute(cs_list);
        const CubitSimpleAttrib &cs_attrib = cs_list.get_and_step();
          PRINT_INFO("Trying to add equivalent attribute of type %s on %s %d.\n",
                     BTE_ptr->class_name(), BTE_ptr->id());
          PRINT_INFO("Trying to add attribute of same type %s on %s %d.\n",
//_________  Add Code by DZ of Cat,  3/11/99 11:10:29 AM  _________
    if ( append_it )
       append_simple_attribute(GE_ptr, new_csattrib_ptr);
//_________  Code End by DZ of Cat,  3/11/99 11:10:29 AM  _________
    // Deal with all other RefEntities.  As these do not have any
    // underlying entities (such as solid model entities) associated
    // with them, this block is a do-nothing block.
  else
  if (DEBUG_FLAG(90))
    RefEntity *ref_entity = CAST_TO(this, RefEntity);
    PRINT_DEBUG_90( "Putting simple attribute of type %s on"
                " %s %d.\n", new_csattrib_ptr.character_type().c_str(),
                ref_entity->class_name(), ref_entity->id());
Definition at line 943 of file CubitAttribUser.cpp.
  CubitStatus read_status;
    // get all simple attrib's
    read_status = OSME_ptr->get_simple_attribute(csattrib_list);
    read_status = GE_ptr->get_simple_attribute(csattrib_list);
    if (attrib_type == CA_ALL_ATTRIBUTES || csa_type == attrib_type) {
        // create this CA
//       CubitAttrib *new_attrib =
    else {
        // otherwise we don't want to read this one; since the get_simple_attribute
        // took the attribute off, we'll have to put this one back on
  return read_status;
Definition at line 1219 of file CubitAttribUser.cpp.
    // remove this name from the primary object
  bridge->remove_all_simple_attribute_virt();
    // for merged objects, remove all attributes from other entities
    tb_list.reset();
      if (temp_tb != bridge) temp_tb->remove_all_simple_attribute_virt();
Definition at line 1034 of file CubitAttribUser.cpp.
  CubitStatus removed = CUBIT_FAILURE;
  if(cubit_attrib_ptr == NULL)
    return removed;
  CubitSimpleAttrib csattrib_ptr = cubit_attrib_ptr->cubit_simple_attrib();
  if(!csattrib_ptr.isEmpty())
    if (DEBUG_FLAG(90)) {
      PRINT_DEBUG_90( "Removing simple attribute of type %s on"
                  " %s %d.\n", csattrib_ptr.character_type().c_str(),
    TopologyEntity* topo_ptr = CAST_TO(this, TopologyEntity);
    if (topo_ptr && topo_ptr->bridge_manager()->topology_bridge())
        remove_simple_attribute(topo_ptr->bridge_manager()->topology_bridge(), csattrib_ptr);
      removed = CUBIT_SUCCESS;
  return removed;
Definition at line 820 of file CubitAttribUser.cpp.
  CubitStatus remove_status = CUBIT_SUCCESS;
  for(int i = attrib_list.size(); i != 0; i--)
    if (remove_cubit_attrib(cubit_attrib_ptr) == CUBIT_FAILURE)
      remove_status = CUBIT_FAILURE;
  return remove_status;
Definition at line 835 of file CubitAttribUser.cpp.
  CubitStatus remove_status = remove_cubit_attrib(attrib_list);
Definition at line 843 of file CubitAttribUser.cpp.
  CubitStatus remove_geom = remove_attrib_geometry_entity(cubit_attrib_ptr);
  //CubitStatus remove_cubit = CUBIT_FAILURE;
  CubitBoolean once = CUBIT_FALSE;
  if (headAttrib == cubit_attrib_ptr) {
    headAttrib = cubit_attrib_ptr->next_attrib();
    once = CUBIT_TRUE;
  CubitAttrib* temp_cubit_attrib_ptr = headAttrib;
  while (temp_cubit_attrib_ptr != NULL) {
    if (cubit_attrib_ptr == temp_cubit_attrib_ptr->next_attrib()) {
      if (once) {
        PRINT_DEBUG_90("Removing attribute more than once.\n");
      temp_cubit_attrib_ptr->set_next_attrib(cubit_attrib_ptr->
                                             next_attrib());
      once = CUBIT_TRUE;
    temp_cubit_attrib_ptr = temp_cubit_attrib_ptr->next_attrib();
  return remove_geom;
void CubitAttribUser::remove_simple_attribute ( TopologyBridge bridge,
Definition at line 1238 of file CubitAttribUser.cpp.
  bridge->remove_simple_attribute_virt(attrib_ptr);
    // for merged objects, remove attribute from other entities
    BridgeManager *bm_ptr = bridge->bridge_manager();
    if (bm_ptr != NULL) bm_ptr->get_bridge_list(tb_list);
    tb_list.reset();
      if (temp_tb != bridge) temp_tb->remove_simple_attribute_virt(attrib_ptr);
Definition at line 1105 of file CubitAttribUser.cpp.
  for (int i = ca_list.size(); i > 0; i--)
    ca_list.get_and_step()->has_updated(flag);
Definition at line 1094 of file CubitAttribUser.cpp.
  for (int i = ca_list.size(); i > 0; i--) {
    if (flag == CUBIT_FALSE && ca_list.get()->has_written() == CUBIT_TRUE)
      ca_list.get()->reset();
    ca_list.get_and_step()->has_written(flag);
Definition at line 327 of file CubitAttribUser.cpp.
    //- if owner is to be split, get simple attribs for new entity
    // call split for each attribute, getting back new csa's
  int i;
  for ( i = ca_list.size(); i > 0; i--) {
    CubitSimpleAttrib csa_ptr = ca_ptr->split_owner();
    if (!csa_ptr.isEmpty())
      csa_list.append(csa_ptr);
      delete ca_ptr;
    // ok, we're done
void CubitAttribUser::transf_owner ( const CubitVector matrow1,
const CubitVector matrow2,
const CubitVector matrow3,
const CubitVector translate_vec,
Definition at line 427 of file CubitAttribUser.cpp.
    //- called if owner is to be transformed; simply passes information
    //- to attribs on this entity; does *not* autocreate
    ca_ptr->transf_owner(matrow1, matrow2, matrow3,
                         translate_vec, scale_factor);
    // ok, we're done
Definition at line 611 of file CubitAttribUser.cpp.
  CubitAttrib* new_attrib = NULL;
  if( attrib_list.size() > 1 )
    PRINT_WARNING("File contains multiples of the same attrib.\n");
    PRINT_INFO("    Something was not written correctly.\n");
  if(attrib_list.size() == 0)
    new_attrib = get_cubit_attrib(attrib_type);
  else
    new_attrib = attrib_list.get();
  assert(new_attrib != 0);
  CubitStatus update_status = new_attrib->update();
Definition at line 286 of file CubitAttribUser.cpp.
  CubitStatus write_status = write_cubit_attrib_list(attrib_list);
  return write_status;
Definition at line 294 of file CubitAttribUser.cpp.
  CubitStatus write_status = CUBIT_SUCCESS;
  for(int i = attrib_list.size(); i > 0; i--)
    if (write_specific_cubit_attrib(cubit_attrib_ptr) == CUBIT_FAILURE)
      write_status = CUBIT_FAILURE;
Definition at line 308 of file CubitAttribUser.cpp.
    // write the attributes
  int i;
  for(i = attrib_list.size(); i != 0; i--)
    if (write_specific_cubit_attrib(attrib) == CUBIT_FAILURE)
Definition at line 250 of file CubitAttribUser.cpp.
    // don't write if this attrib is marked as deleted or it has already been written
    // Also, only write if the write flag is on for this attribute type
  if ((cubit_attrib_ptr->delete_attrib() != CUBIT_TRUE) &&
//      (cubit_attrib_ptr->has_written() != CUBIT_TRUE) &&
      (CGMApp::instance()->attrib_manager()->auto_write_flag(cubit_attrib_ptr->int_attrib_type()) == CUBIT_TRUE))
      RefEntity *this_entity = CAST_TO(this, RefEntity);
      PRINT_DEBUG_90( "Writing attribute for %s %d, type %s\n",
                  this_entity->class_name(), this_entity->id(),
                  cubit_attrib_ptr->att_internal_name());
      // set has_written flag here, before actually writing - a trick to
      // allow some attributes to detect they're being written, and do any
      // final setup they need to do before the actual write takes place (used
      // in CAMeshContainer, for example)
    cubit_attrib_ptr->has_written(CUBIT_TRUE);
    const CubitSimpleAttrib &csa_ptr = cubit_attrib_ptr->cubit_simple_attrib();
    result = put_simple_attrib(csa_ptr);
      // if the write wasn't successful, reset the write flag
    if (result != CUBIT_SUCCESS) cubit_attrib_ptr->has_written(CUBIT_FALSE);
  return result;
Member Data Documentation
Definition at line 38 of file CubitAttribUser.hpp.
