cgma
CubitAttribUser Member List
This is the complete list of members for CubitAttribUser, including all inherited members.
actuate_cubit_attrib(int attrib_type)CubitAttribUser
actuate_cubit_attrib(DLIList< CubitAttrib * >)CubitAttribUser [private]
actuate_cubit_attrib(CubitAttrib *)CubitAttribUser [private]
actuate_cubit_attrib(DLIList< RefEntity * >, int)CubitAttribUser [static]
add_cubit_attrib(CubitAttrib *cubit_attrib_ptr)CubitAttribUser
append_attrib_internal(TopologyBridge *bridge, const CubitSimpleAttrib &attrib_ptr)CubitAttribUser
append_simple_attribute(TopologyBridge *bridge, const CubitSimpleAttrib &attrib_ptr)CubitAttribUser
auto_actuate_cubit_attrib(CubitBoolean from_constructor=CUBIT_TRUE, CubitBoolean after_geom_changes=CUBIT_FALSE)CubitAttribUser
auto_create_for_merge(RefEntity *deletable_entity)CubitAttribUser [private]
auto_read_cubit_attrib()CubitAttribUser
auto_reset_cubit_attrib(DLIList< RefEntity * > ref_ents)CubitAttribUser [private, static]
auto_update_cubit_attrib()CubitAttribUser
auto_update_cubit_attrib(DLIList< RefEntity * > &entity_list, CubitBoolean write_too=CUBIT_TRUE)CubitAttribUser [static]
clear_all_simple_attrib(DLIList< RefEntity * > &entity_list)CubitAttribUser [static]
clear_all_simple_attrib_set_to_actuate(DLIList< RefEntity * > &entity_list)CubitAttribUser [static]
clear_simple_attribs()CubitAttribUser
clear_simple_attribs_set_to_actuate()CubitAttribUser
CubitAttribUser(const CubitAttribUser &)CubitAttribUser [private]
CubitAttribUser(CubitAttrib *=NULL)CubitAttribUser
find_cubit_attrib_type(int, DLIList< CubitAttrib * > &) const CubitAttribUser
get_cubit_attrib(int attrib_type, CubitBoolean create_if_missing=CUBIT_TRUE)CubitAttribUser
get_cubit_attrib_list(DLIList< CubitAttrib * > &)CubitAttribUser
headAttribCubitAttribUser [protected]
merge_owner(RefEntity *deletable_entity)CubitAttribUser
num_cubit_attrib()CubitAttribUser
operator=(const CubitAttribUser &)CubitAttribUser [private]
put_simple_attrib(const CubitSimpleAttrib &cubit_simple_attrib_ptr, CubitBoolean append_it=CUBIT_TRUE)CubitAttribUser [private]
read_cubit_attrib(int attrib_type)CubitAttribUser
remove_all_simple_attribute(TopologyBridge *bridge)CubitAttribUser
remove_attrib_geometry_entity(CubitAttrib *)CubitAttribUser
remove_cubit_attrib(DLIList< CubitAttrib * >)CubitAttribUser [private]
remove_cubit_attrib(int attrib_type)CubitAttribUser
remove_cubit_attrib(CubitAttrib *)CubitAttribUser
remove_simple_attribute(TopologyBridge *bridge, const CubitSimpleAttrib &attrib_ptr)CubitAttribUser
set_updated_flag(CubitBoolean flag)CubitAttribUser
set_written_flag(CubitBoolean flag)CubitAttribUser
split_owner(DLIList< CubitSimpleAttrib > &csa_list)CubitAttribUser
transf_owner(const CubitVector &matrow1, const CubitVector &matrow2, const CubitVector &matrow3, const CubitVector &translate_vec, const double scale_factor)CubitAttribUser
update_cubit_attrib(int)CubitAttribUser
write_cubit_attrib_by_type(int attrib_type)CubitAttribUser
write_cubit_attrib_list(DLIList< CubitAttrib * > attrib_list)CubitAttribUser
write_cubit_attribs()CubitAttribUser
write_specific_cubit_attrib(CubitAttrib *cubit_attrib_ptr)CubitAttribUser
~CubitAttribUser()CubitAttribUser [virtual]
