cgma
CubitAttribUser.hpp
00001 //- Class:       CubitAttribUser
00002 //- Owner:       Greg Nielson
00003 //- Description: Base class inherited by the RefEntity class that
00004 //-              gives attribute functionality to the RefEntitys.
00005 //- Checked By:
00006 //- Version:
00007
00008 #ifndef CUBIT_ATTRIB_USER_HPP
00009 #define CUBIT_ATTRIB_USER_HPP
00010
00011 // #include "CubitString.hpp"
00012
00013 class RefEntity;
00014
00015 #include "CubitDefines.h"
00016 #include "CubitAttrib.hpp"
00017 #include "DLIList.hpp"
00018 #include "CubitSimpleAttrib.hpp"
00019 #include "CGMGeomConfigure.h"
00020
00021 class TopologyBridge;
00022
00023 //template <class X> class DLIList;
00024 //class CubitAttrib;
00025 //class CubitSimpleAttrib;
00026 //class CAEntityName;
00027
00028
00029 class CUBIT_GEOM_EXPORT CubitAttribUser
00030 {
00031 private:
00032 //  CubitStatus remove_attrib_geometry_entity (CubitSimpleAttrib*);
00033     CubitAttribUser( const CubitAttribUser& );
00034     void operator=( const CubitAttribUser&);
00035
00036
00037 protected:
00038   CubitAttrib* headAttrib;
00039
00040 public:
00041 // bad function CubitAttribUser() {headAttrib = NULL;}
00042
00043   virtual ~CubitAttribUser();
00044
00045   CubitAttribUser(CubitAttrib* = NULL);
00046
00047   CubitAttrib* get_cubit_attrib (int attrib_type,
00048                                  CubitBoolean create_if_missing = CUBIT_TRUE);
00049
00050   CubitStatus add_cubit_attrib (CubitAttrib* cubit_attrib_ptr);
00051     //- appends this attrib to the list
00052
00053 private:
00054 //________  Change Code by DZ of Cat,  3/11/99 12:19:10 PM  ________
00055   CubitStatus put_simple_attrib (const CubitSimpleAttrib& cubit_simple_attrib_ptr,
00056      CubitBoolean append_it = CUBIT_TRUE);
00057 //________  Change End by DZ of Cat,  3/11/99 12:19:10 PM  ________
00058
00059 public:
00060   void append_simple_attribute(TopologyBridge* bridge, const CubitSimpleAttrib& attrib_ptr);
00061   void append_attrib_internal( TopologyBridge* bridge, const CubitSimpleAttrib& attrib_ptr );
00062   void remove_all_simple_attribute(TopologyBridge* bridge);
00063   void remove_simple_attribute(TopologyBridge* bridge, const CubitSimpleAttrib& attrib_ptr);
00064
00065   CubitStatus clear_simple_attribs();
00066     // Remove all CubitSimpleAttrib from TopologyBridges.
00067
00068   CubitStatus clear_simple_attribs_set_to_actuate();
00069     // Remove all CubitSimpleAttrib from TopologyBridges if attrib type's actuate was set to true
00070
00071 public:
00072   CubitStatus auto_read_cubit_attrib ();
00073     //moves all attributes from the SME to CUBIT
00074
00075   CubitStatus read_cubit_attrib (int attrib_type);
00076     //moves a specific cubit attribute type from the SME to CUBIT
00077
00078   //CubitStatus read_cubit_attrib(CubitBoolean read_children = CUBIT_FALSE);
00079     // reads all attribs from SME to CUBIT, and optionally for children
00080
00081   CubitStatus write_specific_cubit_attrib (CubitAttrib* cubit_attrib_ptr);
00082     //moves a specific cubit attribute from CUBIT to the SME
00083
00084   CubitStatus write_cubit_attrib_by_type (int attrib_type);
00085     //moves a specific cubit attribute type from CUBIT to the SME
00086
00087   CubitStatus write_cubit_attrib_list (DLIList<CubitAttrib*> attrib_list);
00088     //moves a list of cubit attributes from CUBIT to the SME
00089
00090   CubitStatus write_cubit_attribs ();
00091     //moves all cubit attributes from CUBIT to the SME
00092
00093 public:
00094   void split_owner(DLIList<CubitSimpleAttrib> &csa_list);
00095     //- if owner is to be split, get simple attribs for new entity
00096
00097   void merge_owner(RefEntity *deletable_entity);
00098     //- if owner is to be merged, combine attribs from deletable_entity with this
00099
00100   void transf_owner(const CubitVector &matrow1,
00101                     const CubitVector &matrow2,
00102                     const CubitVector &matrow3,
00103                     const CubitVector &translate_vec,
00104                     const double scale_factor);
00105     //- called if owner is to be transformed
00106
00107 private:
00108   void auto_create_for_merge(RefEntity *deletable_entity);
00109     //- create any attribs on deletable_entity and not on this
00110
00111 public:
00112   //static CubitBoolean cubit_simple_attrib_equivalent(CubitSimpleAttrib*,
00113   //                                                   CubitSimpleAttrib*);
00114
00115   //int cubit_attrib_equivalent(CubitAttrib*,CubitAttrib*);
00116
00117   //CubitStatus make_simple_attrib (CubitSimpleAttrib**,
00118   //                                CubitAttrib*);
00119
00120   CubitStatus actuate_cubit_attrib (int attrib_type);
00121
00122 private:
00123   CubitStatus actuate_cubit_attrib (DLIList<CubitAttrib*>);
00124   CubitStatus actuate_cubit_attrib (CubitAttrib*);
00125
00126 public:
00127   static CubitStatus actuate_cubit_attrib (DLIList<RefEntity*>,int);
00128     //- actuate attributes of the specified type on entities in the list
00129
00130   //CubitStatus actuate_cubit_attrib ();
00131
00132   CubitStatus auto_actuate_cubit_attrib (CubitBoolean from_constructor = CUBIT_TRUE,
00133                                          CubitBoolean after_geom_changes = CUBIT_FALSE);
00134
00135   //CubitStatus update_cubit_attrib ();
00136
00137   //CubitStatus update_cubit_attrib (CubitAttrib*);
00138
00139   CubitStatus update_cubit_attrib (int);
00140
00141   //CubitStatus update_cubit_attrib (DLIList<CubitAttrib*>);
00142
00143   CubitStatus auto_update_cubit_attrib ();
00144     //- for this cau, automatically create and update ca's
00145
00146 public:
00147   static CubitStatus auto_update_cubit_attrib (DLIList<RefEntity*> &entity_list,
00148                                                CubitBoolean write_too = CUBIT_TRUE);
00149     //- for entity_list, auto create, update and write ca's
00150
00151   static CubitStatus clear_all_simple_attrib( DLIList<RefEntity*>& entity_list );
00152     //- remove all CubitSimpleAttrib from TopologyBridges.
00153
00154   static CubitStatus clear_all_simple_attrib_set_to_actuate( DLIList<RefEntity*>& entity_list );
00155     //- remove all CubitSimpleAttrib from TopologyBridges that have actuate flag set to true.
00156
00157 private:
00158   static void auto_reset_cubit_attrib(DLIList<RefEntity*> ref_ents);
00159     //- set the update flag on all attribs on these entities and their children to false
00160
00161 public:
00162   //void auto_reset_cubit_attrib();
00163     //- set the update flag on all my attribs to false
00164
00165   void find_cubit_attrib_type (int, DLIList<CubitAttrib*>&) const;
00166
00167 private:
00168   CubitStatus remove_cubit_attrib (DLIList<CubitAttrib*>);
00169
00170 public:
00171   CubitStatus remove_cubit_attrib (int attrib_type);
00172
00173   CubitStatus remove_cubit_attrib (CubitAttrib*);
00174
00175   //CubitStatus remove_cubit_attrib ();
00176
00177   CubitStatus remove_attrib_geometry_entity (CubitAttrib*);
00178
00179   //CubitStatus remove_attrib_geometry_entity ();
00180
00181   void get_cubit_attrib_list (DLIList<CubitAttrib*>&);
00182
00183   int num_cubit_attrib();
00184     // returns number of cubit attributes
00185
00186   void set_updated_flag(CubitBoolean flag);
00187   void set_written_flag(CubitBoolean flag);
00188
00189   //void print_attribs();
00190     //- finds and prints all CA's on this entity
00191 };
00192
00193 #endif
00194
00195
00196
00197
00198
