cgma
ManagedPtrVector< X > Class Template Reference
A vector of pointers to objects that are automatically deleted when the container itself is deleted. More...
#include <ManagedPtrVector.hpp>
List of all members.
Classes
class  iterator
Public Types
typedef X value_type
typedef Xreference_type
typedef size_t size_type
typedef std::vector< X * > container_type
Public Member Functions
 ManagedPtrVector ()
 ~ManagedPtrVector ()
void push_back (X *obj)
iterator begin ()
iterator end ()
reference_type operator[] (size_type i)
 Refer by index.
std::auto_ptr< Xrelease (iterator to_release)
 Remove an item from the list without deleting it.
std::auto_ptr< Xreplace (iterator to_replace, std::auto_ptr< X > new_val)
 Replace one object with another.
void clear ()
size_type size () const
Private Member Functions
 ManagedPtrVector (const ManagedPtrVector< X > &)
ManagedPtrVectoroperator= (const ManagedPtrVector< X > &)
Private Attributes
container_type mContainer
Detailed Description
template<typename X>
class ManagedPtrVector< X >
Loosely modeled after the boost ptr containers.
Definition at line 13 of file ManagedPtrVector.hpp.
Member Typedef Documentation
typedef std::vector<X*> ManagedPtrVector< X >::container_type
Definition at line 19 of file ManagedPtrVector.hpp.
typedef X& ManagedPtrVector< X >::reference_type
Definition at line 17 of file ManagedPtrVector.hpp.
typedef size_t ManagedPtrVector< X >::size_type
Definition at line 18 of file ManagedPtrVector.hpp.
typedef X ManagedPtrVector< X >::value_type
Definition at line 16 of file ManagedPtrVector.hpp.
ManagedPtrVector< X >::ManagedPtrVector ( ) [inline]
Definition at line 105 of file ManagedPtrVector.hpp.
ManagedPtrVector< X >::~ManagedPtrVector ( ) [inline]
Definition at line 107 of file ManagedPtrVector.hpp.
  { clear(); }
ManagedPtrVector< X >::ManagedPtrVector ( const ManagedPtrVector< X > &  ) [private]
Member Function Documentation
iterator ManagedPtrVector< X >::begin ( ) [inline]
Definition at line 115 of file ManagedPtrVector.hpp.
  { return iterator(mContainer.begin()); }
void ManagedPtrVector< X >::clear ( ) [inline]
Definition at line 169 of file ManagedPtrVector.hpp.
    // delete all the pointers
    for (typename container_type::iterator i = mContainer.begin();
      i != mContainer.end();
      i++)
      delete *i;
    mContainer.clear();
iterator ManagedPtrVector< X >::end ( ) [inline]
Definition at line 117 of file ManagedPtrVector.hpp.
  { return iterator(mContainer.end()); }
ManagedPtrVector& ManagedPtrVector< X >::operator= ( const ManagedPtrVector< X > &  ) [private]
reference_type ManagedPtrVector< X >::operator[] ( size_type  i) [inline]
Refer by index.
Definition at line 121 of file ManagedPtrVector.hpp.
  { return *(mContainer[i]); }
void ManagedPtrVector< X >::push_back ( X obj) [inline]
Definition at line 112 of file ManagedPtrVector.hpp.
  { mContainer.push_back(obj); }
std::auto_ptr<X> ManagedPtrVector< X >::release ( iterator  to_release) [inline]
The returned auto_ptr now owns the pointer.
Definition at line 126 of file ManagedPtrVector.hpp.
    // save a raw pointer.
    X* rv = to_release.operator->();
    // find the iterator in the container.  We don't have access
    // to the internal iterator, so we have to loop through to find it.
    // This could probably be optimized.
    for (;
      i != mContainer.end() && iterator(i) != to_release;
      ++i)
    // we either found the iterator, or the end.  erase it.
    mContainer.erase(i);
    return std::auto_ptr<X>(rv);
std::auto_ptr<X> ManagedPtrVector< X >::replace ( iterator  to_replace,
std::auto_ptr< X new_val
) [inline]
The returned auto_ptr now owns the pointer removed from the container, and the container owns the object pointed to by new_val.
Definition at line 148 of file ManagedPtrVector.hpp.
    X* rv = to_replace.operator->();
    for (;
      ++i)
      if (iterator(i) == to_replace)
        *i = new_val;
    return std::auto_ptr<X>(NULL);
size_type ManagedPtrVector< X >::size ( ) const [inline]
Definition at line 181 of file ManagedPtrVector.hpp.
  { return mContainer.size(); }
Member Data Documentation
container_type ManagedPtrVector< X >::mContainer [private]
Definition at line 189 of file ManagedPtrVector.hpp.
