cgma
HiddenEntitySet Class Reference
#include <HiddenEntitySet.hpp>
Inheritance diagram for HiddenEntitySet:
TBOwner
List of all members.
Public Member Functions
 HiddenEntitySet (TBOwner *owner)
virtual ~HiddenEntitySet ()
CubitStatus hide (TopologyBridge *bridge)
CubitStatus restore (TopologyBridge *bridge)
void hidden_surfaces (DLIList< Surface * > &)
void hidden_coedges (DLIList< CoEdgeSM * > &)
void hidden_curves (DLIList< Curve * > &)
void hidden_points (DLIList< TBPoint * > &)
CubitStatus remove_bridge (TopologyBridge *bridge)
CubitStatus swap_bridge (TopologyBridge *old_tb, TopologyBridge *new_tb, bool reversed)
void notify_reversed (TopologyBridge *)
CubitStatus merge (HiddenEntitySet *other)
TBOwnerowner () const
void print_debug_info (const char *prefix) const
bool is_empty () const
Private Attributes
TBOwnermyOwner
std::vector< TopologyBridge * > hiddenList
Detailed Description
Definition at line 26 of file HiddenEntitySet.hpp.
Definition at line 31 of file HiddenEntitySet.hpp.
: myOwner(owner) {}
Definition at line 34 of file HiddenEntitySet.cpp.
  std::vector<TopologyBridge*>::iterator iter;
  for (iter=hiddenList.begin(); iter!=hiddenList.end(); iter++)
    (*iter)->owner(0);
  hiddenList.clear();
Member Function Documentation
Definition at line 134 of file HiddenEntitySet.cpp.
    if (CoEdgeSM* ptr = dynamic_cast<CoEdgeSM*>( *iter ))
      result.append(ptr);
void HiddenEntitySet::hidden_curves ( DLIList< Curve * > &  result)
Definition at line 144 of file HiddenEntitySet.cpp.
    if (Curve* ptr = dynamic_cast<Curve*>( *iter ))
      result.append(ptr);
Definition at line 154 of file HiddenEntitySet.cpp.
    if (TBPoint* ptr = dynamic_cast<TBPoint*>( *iter ))
      result.append(ptr);
Definition at line 124 of file HiddenEntitySet.cpp.
    if (Surface* ptr = dynamic_cast<Surface*>( *iter ))
      result.append(ptr);
Definition at line 43 of file HiddenEntitySet.cpp.
  if( bridge->owner() && !bridge->owner()->remove_bridge(bridge) )
    return CUBIT_FAILURE;
  bridge->owner( this );
  // It would be simpler to just add new hidden entities at the back of the list
  // but this code mimics the previous behavior of inserting new entities
  // after the first entity in the list.  Changing this changes the ids of
  // geometry entities when a composite is removed.  BWH - 11/09/05
  // TODO - BWH - do we want to change the order now to make things simpler or come up
  // with a way to keep ids after removing composites
  // TODO - BWH - the list functions in HiddenEntitySet are almost identical to the list functions in BridgeManager
  // the main difference is the order that entities are inserted.  If we want to make the behavior consistent, maybe a TBList class
  // could be implemented to use in both places.
  iter = hiddenList.begin();
  if (hiddenList.size() > 0)
    iter++;
  hiddenList.insert(iter, bridge);
  return CUBIT_SUCCESS;
bool HiddenEntitySet::is_empty ( ) const [inline]
Definition at line 56 of file HiddenEntitySet.hpp.
      { return hiddenList.empty(); }
Definition at line 106 of file HiddenEntitySet.cpp.
  std::vector<TopologyBridge*> other_list;
  // copy the list being merged so we can operate on the real list
  // without invalidating the iterator
  other_list = other->hiddenList;
  for (iter=other_list.begin(); iter!=other_list.end(); iter++ )
    other->restore( *iter );
    hide( *iter );
Implements TBOwner.
Definition at line 199 of file HiddenEntitySet.cpp.
TBOwner* HiddenEntitySet::owner ( ) const [inline]
Definition at line 51 of file HiddenEntitySet.hpp.
      { return myOwner; }
void HiddenEntitySet::print_debug_info ( const char *  prefix) const
Definition at line 164 of file HiddenEntitySet.cpp.
  if (!prefix)
    prefix = "";
  PRINT_INFO("%sHiddenEntitySet %p owned by %s %p\n",
    prefix, (void*)this,
    myOwner ? fix_type_name(typeid(*myOwner).name()) : "(null)",
    (void*)myOwner );
  char* new_prefix = new char[strlen(prefix)+3];
  strcpy( new_prefix, prefix );
  strcat( new_prefix, "  ");
  std::vector<TopologyBridge*>::const_iterator iter;
    if( CompositePoint* cp = dynamic_cast<CompositePoint*>(*iter) )
      cp->print_debug_info(new_prefix, true);
    else if( CompositeCurve* cc = dynamic_cast<CompositeCurve*>(*iter) )
      cc->print_debug_info(new_prefix, true);
    else if( CompositeCoEdge* ce = dynamic_cast<CompositeCoEdge*>(*iter) )
      ce->print_debug_info(new_prefix, true);
    else if( CompositeSurface* cs = dynamic_cast<CompositeSurface*>(*iter) )
      cs->print_debug_info(new_prefix, true);
    else
#ifdef TOPOLOGY_BRIDGE_IDS
      PRINT_INFO("%s%s %d\n", new_prefix, fix_type_name(typeid(*(*iter)).name()), (*iter)->get_id() );
#else
      PRINT_INFO("%s%s %p\n", new_prefix, fix_type_name(typeid(*(*iter)).name()), (void*)(*iter) );
#endif
  delete [] new_prefix;
Implements TBOwner.
Definition at line 88 of file HiddenEntitySet.cpp.
  return restore(bridge);
Definition at line 71 of file HiddenEntitySet.cpp.
  if( bridge->owner() != this )
  iter = std::find(hiddenList.begin(), hiddenList.end(), bridge);
  if (iter != hiddenList.end())
    hiddenList.erase(iter);
  else
  bridge->owner( 0 );
CubitStatus HiddenEntitySet::swap_bridge ( TopologyBridge old_tb,
TopologyBridge new_tb,
bool  reversed
) [virtual]
Implements TBOwner.
Definition at line 93 of file HiddenEntitySet.cpp.
  if ( new_tb->owner() || !restore(old_tb) )
    assert(0);
  return hide(new_tb);
Member Data Documentation
Definition at line 62 of file HiddenEntitySet.hpp.
Definition at line 61 of file HiddenEntitySet.hpp.
