cgma
HiddenEntitySet.cpp
00001 //-------------------------------------------------------------------------
00002 // Filename      : HiddenEntitySet.cpp
00003 //
00004 // Purpose       : A class to hold a list of hidden entites and act as
00005 //                 their owner.
00006 //
00007 // Special Notes :
00008 //
00009 // Creator       : Jason Kraftcheck
00010 //
00011 // Creation Date : 01/14/02
00012 //-------------------------------------------------------------------------
00013
00014 #include "VGDefines.h"
00015 #include "HiddenEntitySet.hpp"
00016
00017 #include "BodySM.hpp"
00018 #include "Lump.hpp"
00019 #include "ShellSM.hpp"
00020 #include "Surface.hpp"
00021 #include "LoopSM.hpp"
00022 #include "CoEdgeSM.hpp"
00023 #include "Curve.hpp"
00024 #include "Point.hpp"
00025
00026 // for debug output
00027 #include "CompositePoint.hpp"
00028 #include "CompositeCurve.hpp"
00029 #include "CompositeCoEdge.hpp"
00030 #include "CompositeSurface.hpp"
00031 #include "CubitMessage.hpp"
00032
00033
00034 HiddenEntitySet::~HiddenEntitySet()
00035 {
00036   std::vector<TopologyBridge*>::iterator iter;
00037   for (iter=hiddenList.begin(); iter!=hiddenList.end(); iter++)
00038     (*iter)->owner(0);
00039
00040   hiddenList.clear();
00041 }
00042
00043 CubitStatus HiddenEntitySet::hide( TopologyBridge* bridge )
00044 {
00045   if( bridge->owner() && !bridge->owner()->remove_bridge(bridge) )
00046     return CUBIT_FAILURE;
00047
00048   bridge->owner( this );
00049
00050   // It would be simpler to just add new hidden entities at the back of the list
00051   // but this code mimics the previous behavior of inserting new entities
00052   // after the first entity in the list.  Changing this changes the ids of
00053   // geometry entities when a composite is removed.  BWH - 11/09/05
00054   //
00055   // TODO - BWH - do we want to change the order now to make things simpler or come up
00056   // with a way to keep ids after removing composites
00057   //
00058   // TODO - BWH - the list functions in HiddenEntitySet are almost identical to the list functions in BridgeManager
00059   // the main difference is the order that entities are inserted.  If we want to make the behavior consistent, maybe a TBList class
00060   // could be implemented to use in both places.
00061
00062   std::vector<TopologyBridge*>::iterator iter;
00063   iter = hiddenList.begin();
00064   if (hiddenList.size() > 0)
00065     iter++;
00066   hiddenList.insert(iter, bridge);
00067
00068   return CUBIT_SUCCESS;
00069 }
00070
00071 CubitStatus HiddenEntitySet::restore( TopologyBridge* bridge )
00072 {
00073   if( bridge->owner() != this )
00074     return CUBIT_FAILURE;
00075
00076   std::vector<TopologyBridge*>::iterator iter;
00077   iter = std::find(hiddenList.begin(), hiddenList.end(), bridge);
00078   if (iter != hiddenList.end())
00079     hiddenList.erase(iter);
00080   else
00081     return CUBIT_FAILURE;
00082
00083   bridge->owner( 0 );
00084
00085   return CUBIT_SUCCESS;
00086 }
00087
00088 CubitStatus HiddenEntitySet::remove_bridge( TopologyBridge* bridge )
00089 {
00090   return restore(bridge);
00091 }
00092
00093 CubitStatus HiddenEntitySet::swap_bridge( TopologyBridge* old_tb,
00094                                           TopologyBridge* new_tb,
00095                                           bool )
00096 {
00097   if ( new_tb->owner() || !restore(old_tb) )
00098   {
00099     assert(0);
00100     return CUBIT_FAILURE;
00101   }
00102
00103   return hide(new_tb);
00104 }
00105
00106 CubitStatus HiddenEntitySet::merge( HiddenEntitySet* other )
00107 {
00108   std::vector<TopologyBridge*>::iterator iter;
00109   std::vector<TopologyBridge*> other_list;
00110
00111   // copy the list being merged so we can operate on the real list
00112   // without invalidating the iterator
00113   other_list = other->hiddenList;
00114   for (iter=other_list.begin(); iter!=other_list.end(); iter++ )
00115   {
00116     other->restore( *iter );
00117     hide( *iter );
00118   }
00119
00120   return CUBIT_SUCCESS;
00121 }
00122
00123
00124 void HiddenEntitySet::hidden_surfaces( DLIList<Surface*>& result )
00125 {
00126   std::vector<TopologyBridge*>::iterator iter;
00127   for (iter=hiddenList.begin(); iter!=hiddenList.end(); iter++)
00128   {
00129     if (Surface* ptr = dynamic_cast<Surface*>( *iter ))
00130       result.append(ptr);
00131   }
00132 }
00133
00134 void HiddenEntitySet::hidden_coedges( DLIList<CoEdgeSM*>& result )
00135 {
00136   std::vector<TopologyBridge*>::iterator iter;
00137   for (iter=hiddenList.begin(); iter!=hiddenList.end(); iter++)
00138   {
00139     if (CoEdgeSM* ptr = dynamic_cast<CoEdgeSM*>( *iter ))
00140       result.append(ptr);
00141   }
00142 }
00143
00144 void HiddenEntitySet::hidden_curves( DLIList<Curve*>& result )
00145 {
00146   std::vector<TopologyBridge*>::iterator iter;
00147   for (iter=hiddenList.begin(); iter!=hiddenList.end(); iter++)
00148   {
00149     if (Curve* ptr = dynamic_cast<Curve*>( *iter ))
00150       result.append(ptr);
00151   }
00152 }
00153
00154 void HiddenEntitySet::hidden_points( DLIList<TBPoint*>& result )
00155 {
00156   std::vector<TopologyBridge*>::iterator iter;
00157   for (iter=hiddenList.begin(); iter!=hiddenList.end(); iter++)
00158   {
00159     if (TBPoint* ptr = dynamic_cast<TBPoint*>( *iter ))
00160       result.append(ptr);
00161   }
00162 }
00163
00164 void HiddenEntitySet::print_debug_info( const char* prefix ) const
00165 {
00166   if (!prefix)
00167     prefix = "";
00168
00169   PRINT_INFO("%sHiddenEntitySet %p owned by %s %p\n",
00170     prefix, (void*)this,
00171     myOwner ? fix_type_name(typeid(*myOwner).name()) : "(null)",
00172     (void*)myOwner );
00173
00174   char* new_prefix = new char[strlen(prefix)+3];
00175   strcpy( new_prefix, prefix );
00176   strcat( new_prefix, "  ");
00177
00178   std::vector<TopologyBridge*>::const_iterator iter;
00179   for (iter=hiddenList.begin(); iter!=hiddenList.end(); iter++)
00180   {
00181     if( CompositePoint* cp = dynamic_cast<CompositePoint*>(*iter) )
00182       cp->print_debug_info(new_prefix, true);
00183     else if( CompositeCurve* cc = dynamic_cast<CompositeCurve*>(*iter) )
00184       cc->print_debug_info(new_prefix, true);
00185     else if( CompositeCoEdge* ce = dynamic_cast<CompositeCoEdge*>(*iter) )
00186       ce->print_debug_info(new_prefix, true);
00187     else if( CompositeSurface* cs = dynamic_cast<CompositeSurface*>(*iter) )
00188       cs->print_debug_info(new_prefix, true);
00189     else
00190 #ifdef TOPOLOGY_BRIDGE_IDS
00191       PRINT_INFO("%s%s %d\n", new_prefix, fix_type_name(typeid(*(*iter)).name()), (*iter)->get_id() );
00192 #else
00193       PRINT_INFO("%s%s %p\n", new_prefix, fix_type_name(typeid(*(*iter)).name()), (void*)(*iter) );
00194 #endif
00195   }
00196   delete [] new_prefix;
00197 }
00198
00199 void HiddenEntitySet::notify_reversed( TopologyBridge* )
00200   {}
