cgma
TtyProgressTool Class Reference
#include <TtyProgressTool.hpp>
Inheritance diagram for TtyProgressTool:
ProgressTool
List of all members.
Public Member Functions
 TtyProgressTool ()
virtual ~TtyProgressTool ()
virtual void start (int lower, int upper, const char *title=0, const char *info=0, CubitBoolean smooth=CUBIT_TRUE, CubitBoolean cancelButton=CUBIT_FALSE)
virtual void end ()
virtual void step ()
virtual void percent (double p)
virtual void check_interrupt ()
void clear_all ()
Private Member Functions
bool update ()
void display (int step, int pct)
Private Attributes
int myRange
int currentVal
int currPercent
int prevWidth
char * lineBuffer
char * barStart
char * bufferEnd
char * firstMessage
char * secondMessage
Detailed Description
Definition at line 18 of file TtyProgressTool.hpp.
Definition at line 60 of file TtyProgressTool.hpp.
Definition at line 49 of file TtyProgressTool.cpp.
  clear_all();
Member Function Documentation
Implements ProgressTool.
Definition at line 253 of file TtyProgressTool.cpp.
Definition at line 54 of file TtyProgressTool.cpp.
    // free allocated buffers
    // (messages were created with strdup (CubitUtil::util_strdup),
    // which uses malloc so use free() (CubitUtil::util_strdup_free())).
  delete [] lineBuffer;
  if (firstMessage)
    CubitUtil::util_strdup_free(firstMessage);
  if (secondMessage)
    CubitUtil::util_strdup_free(secondMessage);
    // zero data so calls to step or percent fail.
  myRange = 0;
  prevWidth = 0;
  lineBuffer = barStart = bufferEnd = 0;
  firstMessage = secondMessage = 0;
void TtyProgressTool::display ( int  step,
int  pct
) [private]
Definition at line 257 of file TtyProgressTool.cpp.
  int prev_width = prevWidth;
  bool do_output = false;
    // check for change in terminal width and update if necessary.
  if (!update())
    return;
    // if tty size changed or percent changed, need to update
  if (prev_width != prevWidth || new_percent != currPercent)
    currPercent = new_percent;
    do_output = true;
    // calculate start of numeric percent in lineBuffer
  char* pctStart = bufferEnd;
  if (DISPLAY_NUM_PERCENT)
    pctStart -= 4; // start of numeric percent
    // check if the progress bar output is changing, and if
    // so set do_output to true
  size_t bar_width = 0, bar_drawn = 0, old_drawn;
  if (barStart && myRange > 0)
    bar_width = pctStart - barStart - 1;
    bar_drawn = new_count >= myRange ? bar_width :
                new_count <= 0       ? 0         :
                bar_width * new_count / myRange;
    old_drawn = currentVal >= myRange ? bar_width :
                currentVal <= 0       ? 0         :
                bar_width * currentVal / myRange;
    if (bar_drawn != old_drawn)
      do_output = true;
  currentVal = new_count;
  if (DISPLAY_NUM_PERCENT && do_output)
      // normalize numeric percent to values that can be displayed
    int pct = currPercent;
    if (pct < 0)
      pct = 0;
    else if(pct > 999)
      pct = 999;
      // display numeric percent in last three chars of line
    pctStart[2] = (char)('0' + pct % 10);
    pctStart[1] = pctStart[0] = ' ';
    for ( int i = 1; i >= 0 && pct > 9; i-- )
      pct /= 10;
      pctStart[i] = (char)('0' + pct % 10);
    // if progress bar is to be displayed, update it.
  if (barStart && do_output)
      // write '=' for filled section of bar
    if (bar_drawn > 1)
      memset(barStart, PROGRESS_BAR_FILLED, bar_drawn - 1);
      // write '>' between filled and unfilled sections of bar
    if (bar_drawn > 0)
      barStart[bar_drawn - 1] = PROGRESS_BAR_CURRENT;
      // write spaces in unfilled part of bar
    if (bar_drawn < bar_width)
      memset(barStart + bar_drawn, PROGRESS_BAR_EMPTY, bar_width - bar_drawn);
    // write the buffer to the terminal
  if (do_output)
    fwrite( lineBuffer, bufferEnd - lineBuffer, 1, stdout );
    fflush( stdout );
void TtyProgressTool::end ( ) [virtual]
Definition at line 238 of file TtyProgressTool.cpp.
    // clear terminal line
  if (lineBuffer)
    memset( lineBuffer + 1, ' ', bufferEnd - lineBuffer - 1 );
    putchar('\r');
    fflush( stdout );
    // clear internal data
  clear_all();
void TtyProgressTool::percent ( double  p) [virtual]
Definition at line 233 of file TtyProgressTool.cpp.
  display( (int)(p * myRange), (int)(100 * p) );
void TtyProgressTool::start ( int  lower,
int  upper,
const char *  title = 0,
const char *  info = 0,
CubitBoolean  smooth = CUBIT_TRUE,
CubitBoolean  cancelButton = CUBIT_FALSE
) [virtual]
Definition at line 201 of file TtyProgressTool.cpp.
    // get rid of any old state if someone forgot to call end().
  clear_all();
    // store passed range
  myRange = upper - lower;
  currentVal = currPercent = 0;
  prevWidth = 0;
    // copy passed messages
  const char* empty = "";
  if (s1)
    firstMessage = CubitUtil::util_strdup((char*)s1);
  else
    firstMessage = CubitUtil::util_strdup((char*)empty);
  if (s2)
    secondMessage = CubitUtil::util_strdup((char*)s2);
    // generate line buffer
  display(0,0);
void TtyProgressTool::step ( ) [virtual]
Definition at line 226 of file TtyProgressTool.cpp.
  int new_count = currentVal + 1;
  if( myRange > 0 )
    display( new_count, 100 * new_count / myRange );
bool TtyProgressTool::update ( ) [private]
Definition at line 73 of file TtyProgressTool.cpp.
    // Minimum/maximum space for progress bar.  (Add 2 to constants
    // for the leading and trailing '|' character.)
  const int MIN_PROGRESS_WIDTH = MIN_PROGRESS_BAR_WIDTH + 2;
  const int MAX_PROGRESS_WIDTH = MAX_PROGRESS_BAR_WIDTH + 2;
    // Get terminal width.  Assume 80 if query fails.
  int width, height;
  if ( !AppUtil::instance()->get_terminal_size(height, width) )
    width = 80;
#ifdef _WIN32
    // Windows cmd.exe wraps the line when the last character
    // of the line is output, rather than the first character
    // after the end of the line.  Stop one short so to avoid
    // newlines.
  width--;
#endif
    // If terminal width hasn't changed then no update is
    // required.  return.
  if ( width && width == prevWidth )
    return true;
  prevWidth = width;
    // If width isn't at least 6 don't try to display anything.
    // Clear data and return.
  if ( width < 4 )
    return false;
    // Re-create lineBuffer for the new terminal width if necessary.
  if ( !lineBuffer || (bufferEnd - lineBuffer - 1 < width) )
#ifdef _WIN32
    lineBuffer = new char [width+2];
    lineBuffer[width+1] = '\r';
#else
    lineBuffer = new char [width+1];
#endif
    if ( !lineBuffer )
      return false;
  bufferEnd = lineBuffer + width + 1;    // one past end of buffer
  barStart = 0;              // start of progress bar (null if no progress bar)
  char* bar_end = 0;         // end of progress bar
    // Current start and end (fill lineBuffer until start == end)
  char* start = lineBuffer;
  char* end = bufferEnd;
    // Use \r to move cursor to beginning of line without advancing a line.
  *(start++) = '\r'; // leading \r
    // If displaying numeric percent on end of line, allocate 4 spaces
    // at end of line and place '%' char in the fourth one.
  if (DISPLAY_NUM_PERCENT && (end - start > 3))
    end[-1] = '%';
    end -= 4;
    // Copy first message into line
  if (firstMessage && (end - start > 2))
    int len = strlen(firstMessage);
      // need to truncate message?
    if (len + 2 > end - start)
      len = end - start - 2;
    memcpy(start, firstMessage, len);
    start += len;
      // add trailing ": "
    *(start++) = ':';
    *(start++) = ' ';
    // Allocate space for minimum progress bar if sufficient space
  if (DISPLAY_PROGRESS_BAR && (end - start > MIN_PROGRESS_WIDTH))
    bar_end = end;
    end -= MIN_PROGRESS_WIDTH;
    // Copy second message into line buffer
  if (secondMessage && (end - start > 2))
    int len = strlen(secondMessage);
    memcpy(start, secondMessage, len);
    start += len;
    *(start++) = ':';
    *(start++) = ' ';
    // Finish progress bar setup (if progress bar is displayed at all)
  if (bar_end)
      // Grow progress bar up to MAX_PROGRESS_WIDTH (or all the
      // remaining space if MAX_PROGRESS_BAR_WIDTH is unset)
    int diff = bar_end - start - MAX_PROGRESS_WIDTH;
    end = start;
    if (MAX_PROGRESS_BAR_WIDTH && diff >  0)
      end += diff;
      // Put in bounding '|' chars for progress bar and
      // initialize barStart to point *after* the leading '|'
    barStart = end;
    barStart[0] = PROGRESS_BAR_START;
    bar_end[-1] = PROGRESS_BAR_END;
    barStart++;
    // fill any remaining space with spaces
  if (start < end)
    memset( start, ' ', end - start );
  return true;
Member Data Documentation
char* TtyProgressTool::barStart [private]
Definition at line 53 of file TtyProgressTool.hpp.
char* TtyProgressTool::bufferEnd [private]
Definition at line 54 of file TtyProgressTool.hpp.
Definition at line 48 of file TtyProgressTool.hpp.
Definition at line 49 of file TtyProgressTool.hpp.
Definition at line 56 of file TtyProgressTool.hpp.
char* TtyProgressTool::lineBuffer [private]
Definition at line 52 of file TtyProgressTool.hpp.
int TtyProgressTool::myRange [private]
Definition at line 47 of file TtyProgressTool.hpp.
Definition at line 50 of file TtyProgressTool.hpp.
Definition at line 57 of file TtyProgressTool.hpp.
