cgma
RefEntityName.hpp
00001 //- Class: RefEntityName
00002 //-
00003 //- Description: This file maintains a map between a name and a
00004 //- refentity. Names must be unique, but a refentity may have
00005 //- multiple names. This is a singleton class.
00006 //-
00007 //- Owner: Greg Sjaardema
00008 //- Checked by:
00009 //- Version: $Id:
00010
00011 #ifndef REFENTITYNAME_HPP
00012 #define REFENTITYNAME_HPP
00013
00014 #include "CGMGeomConfigure.h"
00015 #include "CubitDefines.h"
00016 #include <map>
00017
00018 template <class X> class DLIList;
00019 class CubitString;
00020 class RefEntity;
00021
00022 typedef std::multimap<RefEntity*, CubitString> RefEntityNameMap;
00023 typedef std::map<CubitString, RefEntity*> NameRefEntityMap;
00024
00025 struct RefEntityNameMaps
00026 {
00027   RefEntityNameMap refMap;
00028   NameRefEntityMap nameMap;
00029 };
00030
00031 class CUBIT_GEOM_EXPORT RefEntityName
00032 {
00033
00034 public:
00035
00036   //Initialize all settings in this class
00037   static void initialize_settings();
00038   static RefEntityName *instance();
00039   ~RefEntityName();
00040
00041   static void delete_instance()
00042   {
00043     if(instance_)
00044       delete instance_;
00045     instance_ = NULL;
00046   }
00047
00048   void       remove_refentity_name(RefEntity* entity,
00049                                    const CubitString &name,
00050                                    CubitBoolean update_attribs = CUBIT_TRUE);
00051   //- Remove the this name from the map. All other names for this
00052   //- RefEntity remain in the map
00053
00054   void       remove_refentity_name(RefEntity *entity,
00055                                    CubitBoolean update_attribs = CUBIT_TRUE);
00056   //- Remove this RefEntity and all its names from the map.
00057
00058   CubitStatus add_refentity_name(RefEntity *entity,
00059                                  CubitString &name,
00060                                  bool update_attribs = true,
00061                                  bool check_name_validity = true);
00062   //- Add the map between this RefEntity and the name.
00063   //- If 'name' is invalid or duplicate, it is changed and
00064   //- new name is returned.
00065   //- Returns CUBIT_FAILURE if unsuccessful.
00066
00067   CubitStatus add_refentity_name(RefEntity *entity,
00068                                  DLIList<CubitString> &names,
00069                                  bool update_attribs = true,
00070                                  bool check_name_validity = true);
00071     //- add multiple names to the name map for this entity
00072
00073   int        get_refentity_name(const RefEntity *entity, DLIList<CubitString> &names);
00074   //- Get the list of names corresponding to this RefEntity.
00075   //- Returns the number of names found for this RefEntity.
00076
00077   void       merge_refentity_names(RefEntity *retained,
00078                                    RefEntity *dead);
00079   //- Associates the names of the dead RefEntity with the retained
00080   //- RefEntity.
00081
00082   void       switch_refentity_names(RefEntity *entity1,
00083                                     RefEntity *entity2);
00084   //- Switch names of entity1 and entity2
00085
00086   RefEntity* get_refentity(const CubitString &name);
00087   //- Returns a pointer to the RefEntity with this name.
00088
00089   void       list_refentity_names(const char *type = "all");
00090   //- Prints an alphabetical list of all entity names in the map.
00091   //- The argument is a filter on the list which restricts it to
00092   //- certain entity types (body, volume, surface, curve, vertex).
00093
00094   const char*      get_refentity_type(const CubitString &name);
00095   //- Returns a pointer to the string identifying the type of the
00096   //- RefEntity with this name. (Body, Volume, ...)
00097
00098   int        get_refentity_id(const CubitString &name);
00099   //- Returns the id of the RefEntity with this name.
00100
00101   static int  get_generate_default_names();
00102   static void set_generate_default_names(int on_off);
00103   //- Specifies whether default RefEntity names should be generated (Surface1).
00104
00105   static int  get_fix_duplicate_names();
00106   static void set_fix_duplicate_names(int on_off);
00107   //- Specifies whether duplicate names should be fixed (made unique)
00108
00109   void set_character(char rep, const CubitString &type);
00110   char get_character(const CubitString &type) const;
00111
00112
00113   static void set_suffix_setting(CubitString rep);
00114   static CubitString get_suffix_setting();
00115   static void set_replacement_setting(CubitString rep);
00116   static CubitString get_replacement_setting();
00117
00118   static CubitString base_name(const CubitString &name);
00119
00120   CubitBoolean same_base_name(const CubitString &name1,
00121                               const CubitString &name2);
00122     //- return CUBIT_TRUE if the base name (i.e. the name before the suffixChar)
00123     //- is the same
00124
00125   static CubitBoolean get_merge_base_names() {return mergeBaseNames;};
00126   static void set_merge_base_names(CubitBoolean flag) {mergeBaseNames = flag;};
00127     //- get/set mergeBaseNames
00128
00129   void copy_refentity_names( const RefEntity* source,
00130                              RefEntity* target,
00131                              CubitBoolean update_attribs = CUBIT_TRUE );
00132   void copy_refentity_names( DLIList<RefEntity*>& source_list,
00133                              RefEntity* target,
00134                              CubitBoolean unique_base_names = CUBIT_TRUE,
00135                              CubitBoolean update_attribs = CUBIT_TRUE );
00136     //- Copy names from one entity to another.
00137
00138   bool print_name_change_warnings() {return printNameChangeWarnings;}
00139   void print_name_change_warnings(bool new_val) {printNameChangeWarnings = new_val;}
00140   int num_name_change_warnings() {return numNameChangeWarnings;}
00141   void num_name_change_warnings(int new_val) {numNameChangeWarnings = new_val;}
00142
00143 protected:
00144   RefEntityName();
00145   //- Class Constructor. (Not callable by user code. Class is constructed
00146   //- by the {instance()} member function.
00147
00148 private:
00149   CubitStatus clean(CubitString &raw_name);
00150   //- replace invalid characters in {raw_name} with {replacementCharacter}
00151
00152   CubitStatus generate_unique_name(CubitString &name);
00153
00154   static RefEntityName *instance_;
00155   //- static pointer to unique instance of this class
00156
00157   RefEntityNameMaps nameEntityList;
00158
00159   static int fixDuplicateNames;
00160   static int generateDefaultNames;
00161   static char replacementCharacter;
00162   static char suffixCharacter;
00163   static bool printNameChangeWarnings;
00164   static int numNameChangeWarnings;
00165
00166   static CubitBoolean mergeBaseNames;
00167     //- if CUBIT_TRUE, when entity names are merged, names with duplicate
00168     //- base names are removed
00169 };
00170 #endif
00171
00172
