cgma
RefGroup.hpp
00001 //- Class:       RefGroup
00002 //- Description: The RefGroup class contains the reference entity structure
00003 //-              for bodies. It contains the standard information such as
00004 //-              meshed status, etc.
00005 //- Owner:       Ted Blacker
00006 //- Checked by:  Greg Sjaardema, 2/28/94
00007 //- Version: $Id:
00008
00009 #ifndef REFGROUP_HPP
00010 #define REFGROUP_HPP
00011
00012 #include "RefCollection.hpp"
00013 #include "CubitObserver.hpp"
00014
00015 class CubitBox;
00016 template <class X> class DLIList;
00017 class RefGroup;
00018 class RefVolume;
00019 class RefFace;
00020 class RefEdge;
00021 class RefVertex;
00022 class RefEntity;
00023
00024 class CUBIT_GEOM_EXPORT RefGroup : public RefCollection,
00025                  public CubitObserver
00026 {
00027
00028 public:
00029
00030   friend class RefEntityFactory;
00031     //- the factory is allowed to call the (private) constructors
00032
00033   friend class TDCAGE;
00034
00035 protected:  /* Delete using RefGroup::delete_group(..) */
00036   virtual ~RefGroup();
00037     //- Class destructor
00038
00039 public:
00040
00041   static const char* get_class_name()
00042      {
00043        return "Group";
00044      }
00045
00046   virtual const char* class_name() const
00047      {
00048        return get_class_name();
00049      }
00050
00051   int maximum_dimension();
00052     //- This routine returns the maximum dimension of its owned subentities.
00053     //- The 'only' kludge is that if one of its subentities is a RefGroup, it
00054     //- must call 'maximum_dimension' on that entity instead of dimension().
00055
00056   virtual const std::type_info& entity_type_info() const
00057       { return typeid(RefGroup); }
00058     //- return the type for this geometryEntity
00059
00060   DagType dag_type() const
00061     { return DagType::invalid_type(); }
00062
00063   virtual CubitStatus add_ref_entity(RefEntity *ref_entity, bool emit_event = false);
00064   virtual CubitStatus add_ref_entity(DLIList<RefEntity*>& entity_list, bool emit_event = false);
00065   virtual CubitStatus remove_ref_entity(RefEntity *ref_entity,
00066                                         bool emit_event = false);
00067   virtual CubitStatus remove_ref_entity(DLIList<RefEntity*>& entity_list,
00068                                         bool emit_event = false);
00069
00070     //- add or remove one or more ref entities to/from this group
00071
00072   virtual void get_sub_entities(DLIList<RefEntity*> &entity_list);
00073     //- appends all ref entities owned by this entity and recurses
00074     //- down to dimension 0
00075
00076   virtual void is_mergeable(AutoMergeStatus val);
00077   bool is_mergeable() { return RefEntity::is_mergeable(); }
00078
00079   int remove_all_ref_entities();
00080   //- remove all geometry entities in the group.
00081   //- Returns number of items removed.
00082
00083   virtual void get_parent_ref_entities(DLIList<RefEntity*>&);
00084     //- appends all ref entities that own this to entity_list.
00085     //- Goes up just one dimension.
00086
00087   virtual void get_child_ref_entities(DLIList<RefEntity*>& entity_list);
00088     //- appends all immediate ref entities owned by this entity on entity_list
00089     //- Goes down just one dimension.
00090
00091   RefEntity* get_child_ref_entity_by_index(const std::type_info& entity_type, int index);
00092     //- Gets the ref entity of type entity_type at specified index in the list.
00093
00094   int get_num_child_ref_entities_by_type(const std::type_info &entity_type);
00095     //- Gets the number of ref entities of type entity_type in the list.
00096
00097   virtual void get_child_entities(DLIList<CubitEntity*>& cub_entity_list);
00098     //- appends all immediate ref entities owned by this entity on entity_list
00099     //- Goes down just one dimension.
00100
00101   void expand_group( DLIList<RefEntity*>& entity_list );
00102     //- appends all the ref entities owned by this group.  It will go down
00103     //- until there are no ref-groups in the entity_list.
00104
00105   virtual CubitBox bounding_box();
00106   virtual CubitVector center_point();
00107
00108   int subtract(RefGroup *group_to_subtract, RefGroup *target_group);
00109     //- subtract group_to_subtract from this group
00110
00111   int intersect(RefGroup *other_group, RefGroup *target_group);
00112     //- intersect other_group with this one
00113
00114   int unite(RefGroup *other_group, RefGroup *target_group);
00115     //- unite other_group with this one
00116
00117   virtual int validate();
00118     //- Return number of problems detected, 0 if none.
00119
00120   //virtual void draw (int color);
00121     //- draw the group's contained entities
00122
00123   static CubitStatus delete_group (RefGroup *group_ptr,
00124                                    CubitBoolean propagate = CUBIT_FALSE);
00125     //- deletes a specified group from the global group list
00126     //- if the boolean "propagate" is true, the groups sub_groups are
00127     //- deleted also; as well as the sub_group's groups, etc..
00128
00129   static void delete_all_groups ();
00130     //- deletes all the groups from the model (except for 'picked_group' and 'drawn_group')
00131
00132   static void get_contained_groups (RefGroup *group_ptr,
00133                                     DLIList<RefGroup*> &contained_groups);
00134     //- gets the groups owned by group_ptr, as well as any other groups
00135     //- owned by these groups, etc..  Current group (group_ptr) is also
00136     //- added to the list.
00137
00138   static void get_groups_within( CubitEntity* cubit_entity_ptr,
00139                                  DLIList<RefGroup*> &groups_within,
00140                                  const CubitBoolean recursive = CUBIT_TRUE);
00141   static void get_groups_within( RefEntity* ref_entity_ptr,
00142                                  DLIList<RefGroup*> &groups_within,
00143                                  const CubitBoolean recursive = CUBIT_TRUE);
00144   static void get_groups_within( RefGroup* ref_group_ptr,
00145                                  DLIList<RefGroup*> &groups_within,
00146                                  const CubitBoolean recursive = CUBIT_TRUE);
00147     //- Finds those groups which contain the input entity, at any level
00148     //-  (i.e., if group 2 contains group 3 which contains the entity, then
00149     //-  group 2 and group 3 will be returned in the output list).
00150
00151   void notify_observer(const CubitEvent *observer_event);
00152     //- handle notify observer function
00153
00154 protected:
00155
00156   DLIList<RefEntity*>  entityList;
00157
00158   int recursionMark;
00159
00160   RefGroup(int proe_type);
00161     // For Pro/E parts and assemblies (avoids notify). 1=assembly, 2=part
00162     //- Class contructors
00163
00164   RefGroup(const char* name = NULL, int id = 0);
00165   RefGroup (DLIList<RefEntity*>& entity_list);
00166     //- need constructors accessable from derived classes
00167
00168 private:
00169
00170 };
00171
00172 #endif // REFGROUP_HPP
00173
