add_td(RefFace *ref_face) | TDOctreeRefFace | [static] |
append_list_item(int loop_id) | TDOctreeRefFace | [inline] |
check_valid_facets(CubitBoolean disable_if_bad) | TDOctreeRefFace | |
create_2dmat | TDOctreeRefFace | [private] |
get_create_2dmat() | TDOctreeRefFace | [inline] |
get_ptr_cubit_facet_edge_list() | TDOctreeRefFace | [inline] |
get_ptr_cubit_facet_list() | TDOctreeRefFace | [inline] |
get_ptr_cubit_point_list() | TDOctreeRefFace | [inline] |
get_td(RefFace *ref_face) | TDOctreeRefFace | [static] |
get_visit(void) const | TDOctreeRefFace | [inline] |
is_adj_curves(int id1, int id2) | TDOctreeRefFace | |
is_td_octree_ref_face(const ToolData *td) | TDOctreeRefFace | [inline, static] |
lastCurveID | TDOctreeRefFace | [private] |
loopIndex | TDOctreeRefFace | [private] |
merge(ToolDataUser *other_td_user) | ToolData | [virtual] |
next_tool_data() | ToolData | [inline] |
next_tool_data(ToolData *data) | ToolData | [inline] |
propogate(ToolDataUser *new_td_user) | ToolData | [virtual] |
ptrCubitFacetEdgeList | TDOctreeRefFace | [private] |
ptrCubitFacetList | TDOctreeRefFace | [private] |
ptrCubitPointList | TDOctreeRefFace | [private] |
refFace | TDOctreeRefFace | [private] |
set_create_2dmat(const CubitBoolean new_val) | TDOctreeRefFace | [inline] |
set_last_curve_id(int id) | TDOctreeRefFace | [inline] |
set_ptr_cubit_facet_edge_list(DLIList< CubitFacetEdge * > *ptr_cubit_facet_edge_list) | TDOctreeRefFace | [inline] |
set_ptr_cubit_facet_list(DLIList< CubitFacet * > *ptr_cubit_facet_list) | TDOctreeRefFace | [inline] |
set_ptr_cubit_point_list(DLIList< CubitPoint * > *ptr_cubit_point_list) | TDOctreeRefFace | [inline] |
set_ref_face(RefFace *ptr_ref_face) | TDOctreeRefFace | [inline] |
set_visit(CubitBoolean type) | TDOctreeRefFace | [inline] |
split_facet_into_two_facets(CubitFacet *target_facet, CubitPoint *edge1_pt, CubitPoint *edge2_pt, CubitFacetEdge *boundary_edge, CubitPoint *new_pt, DLIList< CubitFacet * > &facet_list, DLIList< CubitFacetEdge * > &facet_edge_list, DLIList< CubitPoint * > &point_list) | TDOctreeRefFace | |
split_facet_locally_along_edge(CubitFacet *target_facet, CubitPoint *edge1_pt, CubitPoint *edge2_pt, CubitFacetEdge *boundary_edge, int num_of_segments, DLIList< CubitFacet * > &facet_list, DLIList< CubitFacetEdge * > &facet_edge_list, DLIList< CubitPoint * > &point_list) | TDOctreeRefFace | |
split_facet_type_00(CubitFacet *target_facet, DLIList< CubitFacet * > &facet_list, DLIList< CubitFacetEdge * > &facet_edge_list, DLIList< CubitPoint * > &point_list) | TDOctreeRefFace | |
split_facet_type_01(CubitFacet *target_facet, DLIList< CubitFacet * > &facet_list, DLIList< CubitFacetEdge * > &facet_edge_list, DLIList< CubitPoint * > &point_list) | TDOctreeRefFace | |
split_facet_type_02(CubitFacet *target_facet, DLIList< CubitFacet * > &facet_list, DLIList< CubitFacetEdge * > &facet_edge_list, DLIList< CubitPoint * > &point_list) | TDOctreeRefFace | |
split_facet_type_03(CubitFacet *target_facet, DLIList< CubitFacet * > &facet_list, DLIList< CubitFacetEdge * > &facet_edge_list, DLIList< CubitPoint * > &point_list) | TDOctreeRefFace | |
split_facet_type_12(CubitFacet *target_facet, DLIList< CubitFacet * > &facet_list, DLIList< CubitFacetEdge * > &facet_edge_list, DLIList< CubitPoint * > &point_list) | TDOctreeRefFace | |
split_facet_type_13(CubitFacet *target_facet, DLIList< CubitFacet * > &facet_list, DLIList< CubitFacetEdge * > &facet_edge_list, DLIList< CubitPoint * > &point_list) | TDOctreeRefFace | |
split_facet_type_23(CubitFacet *target_facet, DLIList< CubitFacet * > &facet_list, DLIList< CubitFacetEdge * > &facet_edge_list, DLIList< CubitPoint * > &point_list) | TDOctreeRefFace | |
split_facet_type_33(CubitFacet *target_facet, DLIList< CubitFacet * > &facet_list, DLIList< CubitFacetEdge * > &facet_edge_list, DLIList< CubitPoint * > &point_list) | TDOctreeRefFace | |
TDOctreeRefFace() | TDOctreeRefFace | |
ToolData() | ToolData | [inline, protected] |
visit | TDOctreeRefFace | [private] |
~TDOctreeRefFace() | TDOctreeRefFace | |
~ToolData() | ToolData | [virtual] |
