cgma
TDOctreeRefFace.cpp
00001 //- Class:       TDOctreeRefFace
00002 //- Description: Tool data for storing additional information needed for MAT generation.
00003 //- Owner:       W. R. Quadors
00004 //- Checked by:
00005 //- Version:
00006
00007 #include "TDOctreeRefFace.hpp"
00008 #include "CubitDefines.h"
00009 #include "ToolData.hpp"
00010 #include "MemoryManager.hpp"
00011 #include "DLIList.hpp"
00012 #include "CubitVector.hpp"
00013 #include "CastTo.hpp"
00014
00015 #include "CubitTransformMatrix.hpp"
00016 #include "RefFace.hpp"
00017 #include "CubitFacet.hpp"
00018 #include "CubitFacetData.hpp"
00019 #include "CubitFacetEdge.hpp"
00020 #include "CubitFacetEdgeData.hpp"
00021 #include "CubitPointData.hpp"
00022 #include "CubitOctreeConstants.hpp"
00023 #include "FacetDataUtil.hpp"
00024
00025
00026 // Constructor
00027 TDOctreeRefFace::TDOctreeRefFace(){
00028
00029   ptrCubitPointList = NULL;
00030   ptrCubitFacetEdgeList = NULL;
00031   ptrCubitFacetList = NULL;
00032   visit = CUBIT_FALSE;
00033   create_2dmat = CUBIT_TRUE;
00034 }
00035
00036 // Distructor
00037 TDOctreeRefFace::~TDOctreeRefFace()
00038 {
00039   if (ptrCubitFacetList != NULL)
00040   {
00041     FacetDataUtil::delete_facets(*ptrCubitFacetList);
00042     if( ptrCubitFacetList )
00043       delete ptrCubitFacetList;
00044     ptrCubitFacetList = NULL;
00045
00046     if( ptrCubitFacetEdgeList )
00047       delete ptrCubitFacetEdgeList;
00048     ptrCubitFacetEdgeList = NULL;
00049
00050     if( ptrCubitPointList )
00051       delete ptrCubitPointList;
00052     ptrCubitPointList = NULL;
00053   }
00054
00055 //PRINT_INFO("Inside ~TDOctreeRefFace\n");
00056 }
00057
00058 //-------------------------------------------------------------------------
00059 // Purpose       : To create TDOctreeRefFace to RefFace
00060 //
00061 // Special Notes :
00062 //
00063 // Creator       : W R Quadros
00064 //
00065 // Creation Date : 07/03
00066 //-------------------------------------------------------------------------
00067 CubitStatus TDOctreeRefFace::add_td(  RefFace *ref_face )
00068 {
00069   ToolData *td;
00070   td = ref_face->get_TD(&TDOctreeRefFace::is_td_octree_ref_face);
00071   if ( td == NULL )
00072   {
00073     TDOctreeRefFace *td_gm = new TDOctreeRefFace;
00074     ref_face->add_TD( td_gm);
00075     td_gm->set_ref_face( ref_face );
00076   }
00077   else
00078   {
00079     TDOctreeRefFace *td_gm = CAST_TO(td, TDOctreeRefFace);
00080     td_gm->set_ref_face( ref_face );
00081
00082   }
00083   return CUBIT_SUCCESS;
00084 }
00085
00086 //-------------------------------------------------------------------------
00087 // Purpose       : get the TDOctreeRefFace for a RefFace
00088 //
00089 // Special Notes :
00090 //
00091 // Creator       : W R Quadros
00092 //
00093 // Creation Date : 07/03
00094 //-------------------------------------------------------------------------
00095 TDOctreeRefFace* TDOctreeRefFace::get_td( RefFace *ref_face )
00096 {
00097   ToolData *td;
00098   td = ref_face->get_TD(&TDOctreeRefFace::is_td_octree_ref_face);
00099   if ( td != NULL )
00100   {
00101     TDOctreeRefFace *td_gm = CAST_TO(td, TDOctreeRefFace);
00102     return td_gm;
00103   }
00104   return (TDOctreeRefFace*) NULL;
00105 }
00106 CubitBoolean TDOctreeRefFace::is_adj_curves( int id1, int id2 ){
00107
00108   int loop_index1, loop_index2;
00109   int i;
00110   int first_curve_id, last_curve_id, start_curve_id;
00111
00112   loopIndex.reset();
00113   loop_index1 = CUBIT_INT_MAX;
00114     // i indicates loop index
00115   for( i = 0; i < loopIndex.size(); i++ ){
00116     start_curve_id = loopIndex.get_and_step();
00117     if( id1 < start_curve_id ){
00118       loop_index1 = i - 1;
00119       break;
00120     }
00121   }
00122   if( loop_index1 == CUBIT_INT_MAX ){
00123     loop_index1 = i - 1;
00124   }
00125
00126   loopIndex.reset();
00127   loop_index2 = CUBIT_INT_MAX;
00128     // i indicates loop index
00129   for( i = 0; i < loopIndex.size(); i++ ){
00130     start_curve_id = loopIndex.get_and_step();
00131     if( id2 < start_curve_id ){
00132       loop_index2 = i - 1;
00133       break;
00134     }
00135   }
00136
00137   if( loop_index2 == CUBIT_INT_MAX ){
00138     loop_index2 = i - 1;
00139   }
00140
00141   if( loop_index1 != loop_index2 ){
00142       // curves are not in same loop
00143     return CUBIT_FALSE;
00144   }
00145   else{
00146     if( abs(id1 - id2) == 1 ){
00147         // adj curves of same loop
00148       return CUBIT_TRUE;
00149     }
00150     loopIndex.reset();
00151     loopIndex.step( loop_index1 );
00152     first_curve_id = loopIndex.get_and_step();
00153     last_curve_id = loopIndex.get() - 1;
00154
00155     if( last_curve_id < first_curve_id ){
00156 //      PRINT_DEBUG_157(" id1 = %d and id2 = %d", id1, id2 );
00157 //      PRINT_DEBUG_157(" Note: Last curve id ( %d ) is less than first curve id ( %d ) \n", last_curve_id, first_curve_id );
00158       last_curve_id = lastCurveID;
00159 //      PRINT_DEBUG_157(" last_curve_id is reset to %d \n", lastCurveID );
00160     }
00161
00162     if( abs(id1 - id2) == (last_curve_id - first_curve_id ) ){
00163         // firs and last curve of same loop
00164       return CUBIT_TRUE;
00165     }
00166
00167       // part of same curve
00168     if( abs(id1 - id2) == 0 ){
00169       return CUBIT_TRUE;
00170     }
00171
00172       // same loop but non-adj curves
00173     return CUBIT_FALSE;
00174   }
00175 }
00176
00177 CubitBoolean TDOctreeRefFace::split_facet_type_03( CubitFacet *target_facet, DLIList<CubitFacet*> &facet_list, DLIList<CubitFacetEdge*> &facet_edge_list, DLIList<CubitPoint*> &point_list ){
00178
00179     // Do Nothing
00180     // During CAT centroid will give the approximate branch point
00181   return CUBIT_TRUE;
00182 }
00183
00184 CubitBoolean TDOctreeRefFace::split_facet_type_13( CubitFacet *target_facet, DLIList<CubitFacet*> &facet_list, DLIList<CubitFacetEdge*> &facet_edge_list, DLIList<CubitPoint*> &point_list ){
00185   int i;
00186   CubitFacetEdge *boundary_edge = NULL, *ptr_edge;
00187   CubitPoint *boundary_edge_pnt0, *boundary_edge_pnt1, *other_boundary_point;
00188   double internal_angle;
00189   int num_of_segments;
00190
00191   for( i = 0; i < 3; i++ ){
00192     ptr_edge = target_facet->edge(i);
00193     if( abs( ptr_edge->marked() ) == 1 ){
00194       boundary_edge = ptr_edge;
00195       break;
00196     }
00197   }
00198
00199   boundary_edge_pnt0 = boundary_edge->point(0);
00200   boundary_edge_pnt1 = boundary_edge->point(1);
00201
00202   for( i = 0; i < 3; i++ ){
00203     other_boundary_point = target_facet->point(i);
00204     if( other_boundary_point->id() != boundary_edge_pnt0->id() &&  other_boundary_point->id() != boundary_edge_pnt1->id() ){
00205       break;
00206     }
00207   }
00208
00209   internal_angle = target_facet->angle( other_boundary_point );
00210
00211   num_of_segments = (int)(floor( (internal_angle / (FACET_SPLITTING_INTERNAL_ANGLE )) + 0.5));
00212
00213   if( num_of_segments > 1 )
00214     split_facet_locally_along_edge( target_facet, boundary_edge_pnt0, boundary_edge_pnt1, boundary_edge, num_of_segments, facet_list, facet_edge_list, point_list );
00215
00216   return CUBIT_TRUE;
00217 }
00218
00219 CubitBoolean TDOctreeRefFace::split_facet_type_23( CubitFacet *target_facet, DLIList<CubitFacet*> &facet_list, DLIList<CubitFacetEdge*> &facet_edge_list, DLIList<CubitPoint*> &point_list ){
00220
00221   int i;
00222   CubitFacetEdge *ptr_edge, *boundary_edge1, *boundary_edge2 = NULL,
00223       *boundary_split_edge;
00224   CubitPoint *other_boundary_point;
00225   double internal_angle;
00226   int num_of_segments;
00227
00228   boundary_edge1 = NULL;
00229   for( i = 0; i < 3; i++ ){
00230     ptr_edge = target_facet->edge(i);
00231     if( abs( ptr_edge->marked() ) == 1 ){
00232       if( boundary_edge1 == NULL ){
00233         boundary_edge1 = ptr_edge;
00234       }
00235       else{
00236         boundary_edge2 = ptr_edge;
00237         break;
00238       }
00239     }
00240   }
00241
00242
00243   CubitFacetEdgeData *boundary_edge1_data = dynamic_cast<CubitFacetEdgeData*>( boundary_edge1 );
00244   CubitFacetEdgeData *boundary_edge2_data = dynamic_cast<CubitFacetEdgeData*>( boundary_edge2 );
00245
00246   if( boundary_edge1_data->length() > boundary_edge2_data->length() ){
00247     boundary_split_edge = boundary_edge1;
00248   }
00249   else{
00250     boundary_split_edge = boundary_edge2;
00251   }
00252
00253   for( i = 0; i < 3; i++ ){
00254     other_boundary_point = target_facet->point(i);
00255     if( other_boundary_point->id() != boundary_split_edge->point(0)->id() &&  other_boundary_point->id() != boundary_split_edge->point(1)->id() ){
00256       break;
00257     }
00258   }
00259
00260   internal_angle = target_facet->angle( other_boundary_point );
00261
00262   num_of_segments = (int)(floor( (internal_angle / (FACET_SPLITTING_INTERNAL_ANGLE )) + 0.5));
00263
00264   if( num_of_segments > 1 )
00265     split_facet_locally_along_edge( target_facet, boundary_split_edge->point(0), boundary_split_edge->point(1), boundary_split_edge, num_of_segments, facet_list, facet_edge_list, point_list );
00266
00267   return CUBIT_TRUE;
00268 }
00269
00270 CubitBoolean TDOctreeRefFace::split_facet_type_33( CubitFacet *target_facet, DLIList<CubitFacet*> &facet_list, DLIList<CubitFacetEdge*> &facet_edge_list, DLIList<CubitPoint*> &point_list ){
00271
00272     // Do Nothing
00273     //
00274     // WARNING: Degenerate Case
00275     // A triangualar surface patch is a facet.
00276     // Skeleton should be calculated by taking circum/in center and radius.
00277   return CUBIT_TRUE;
00278 }
00279
00280 CubitBoolean TDOctreeRefFace::split_facet_locally_along_edge( CubitFacet *target_facet, CubitPoint *edge1_pt, CubitPoint *edge2_pt, CubitFacetEdge *ptr_edge, int num_of_segments, DLIList<CubitFacet*> &facet_list, DLIList<CubitFacetEdge*> &facet_edge_list, DLIList<CubitPoint*> &point_list){
00281   int i;
00282   CubitFacet *new_facet;
00283   CubitVector position, delta_length;
00284
00285   delta_length = (edge2_pt->coordinates() - edge1_pt->coordinates()) / num_of_segments;
00286
00287   for( i = num_of_segments - 1; i >= 1; i-- ){
00288     position = edge1_pt->coordinates() + ( delta_length * i );
00289
00290     CubitPointData* new_pt_data = new CubitPointData( position );
00291
00292       // update TD and append the list
00293     CubitPoint *new_pt = CAST_TO(new_pt_data, CubitPoint);
00294     new_facet = split_facet_into_two_facets( target_facet, edge1_pt, edge2_pt, ptr_edge, new_pt, facet_list, facet_edge_list, point_list );
00295
00296       // mark the newly created facets so that they are not checked for
00297       // further splitting.  "this" facet is marked in Octree.cpp.
00298     new_facet->marked( -1 );
00299     edge2_pt = new_pt;
00300   }
00301   return CUBIT_TRUE;
00302 }
00303
00304 CubitFacet *TDOctreeRefFace::split_facet_into_two_facets( CubitFacet *target_facet, CubitPoint* edge1_pt, CubitPoint* edge2_pt, CubitFacetEdge *edge, CubitPoint* new_pt, DLIList<CubitFacet*> &facet_list, DLIList<CubitFacetEdge*> &facet_edge_list, DLIList<CubitPoint*> &point_list){
00305
00306     //add new_pt to point_list
00307   point_list.append( new_pt );
00308   new_pt->marked( abs( edge->marked() ));
00309
00310     // split triangle
00311   CubitFacetData* facet_d = dynamic_cast<CubitFacetData*>(target_facet);
00312   assert(!!facet_d);
00313
00314     // fix up existing facet
00315   int pt2_index = target_facet->point_index( edge2_pt );
00316   bool edge_reversed = ( edge1_pt == target_facet->point( (pt2_index+1) % 3 ) );
00317   int edge_index = (pt2_index + 1 + edge_reversed) % 3;
00318
00319   edge2_pt->remove_facet( target_facet );
00320   facet_d->set_point( new_pt, pt2_index );
00321   new_pt->add_facet( target_facet );
00322   target_facet->update_plane();
00323
00324     // make new facet and update facet list
00325   CubitPoint* other_pt = target_facet->point( edge_index );
00326   CubitFacetData* new_facet;
00327   if( edge_reversed )
00328     new_facet = new CubitFacetData( other_pt, edge2_pt, new_pt );
00329   else
00330     new_facet = new CubitFacetData( other_pt, new_pt, edge2_pt );
00331
00332     // facet constructor takes care of this
00333     // update the facets in points
00334     // this takes care of adj facets of new edges and
00335     // conversely edges of two facets
00336     //edge2_pt->add_facet( new_facet );
00337     //new_pt->add_facet( new_facet );
00338     //other_pt->add_facet( new_facet );
00339
00340
00341     // Facets list in the points should be updated before creating new edge
00342     // the edge constructor generates adjacet facets.
00343     // split edge, if there is one
00344     //CubitFacetEdge* edge = edge1_pt->shared_edge( edge2_pt );
00345   CubitFacetEdgeData* new_edge = 0;
00346   if( edge ){
00347     CubitFacetEdgeData* edge_d = dynamic_cast<CubitFacetEdgeData*>(edge);
00348     assert(!!edge_d);
00349
00350
00351       // make sure new edge has same orientation as old edge
00352     new_edge = dynamic_cast<CubitFacetEdgeData*>(new_pt->shared_edge(edge2_pt));
00353     if( edge->point(0) == edge1_pt ){
00354       edge_d->set_point(new_pt, 1);
00355       if ( !new_edge )
00356         new_edge = new CubitFacetEdgeData( new_pt, edge2_pt );
00357       else if( new_edge->point(0) != new_pt )
00358         new_edge->flip();
00359     }
00360     else {
00361       edge_d->set_point(new_pt, 0);
00362       if ( !new_edge )
00363         new_edge = new CubitFacetEdgeData( edge2_pt, new_pt );
00364       else if( new_edge->point(1) != new_pt )
00365         new_edge->flip();
00366     }
00367
00368     new_edge->marked( abs( edge->marked() ) );
00369     facet_edge_list.append( new_edge );
00370   }
00371   else{
00372     PRINT_INFO("ERROR:Edge is doesn't exist. Splitting is not possible");
00373   }
00374
00375   int sense;
00376
00377     /*
00378       // constructor takes care of this
00379       if ( new_edge ) {
00380       assert(!new_facet->edge(0));
00381       new_facet->edge( new_edge, 0 );
00382       new_edge->add_facet( new_facet );
00383       sense = new_facet->point( 1 ) == new_edge->point(0) ? 1 : -1;
00384       new_facet->edge_use( sense, 0 );
00385       }
00386     */
00387     // facet_list appended
00388   facet_list.append( new_facet );
00389
00390     // move other edge, if there is one
00391   int pt1_index = ( pt2_index + 2 - edge_reversed ) % 3;
00392   CubitFacetEdge* other_edge = target_facet->edge( pt1_index );
00393   int e_index;
00394   if( other_edge ){
00395     other_edge->remove_facet(target_facet);
00396       //target_facet->edge( 0, pt1_index );
00397     e_index = 1 + edge_reversed;
00398     assert(!new_facet->edge(e_index));
00399     new_facet->edge( other_edge, e_index );
00400     other_edge->add_facet( new_facet );
00401     sense = new_facet->point( ( e_index + 1 ) % 3 ) == other_edge->point(0) ? 1 : -1;
00402     new_facet->edge_use( sense, e_index );
00403   }
00404
00405     // Add new mid edge in two facets
00406
00407   CubitFacetEdgeData *new_mid_edge_data;
00408   CubitFacetEdge *new_mid_edge;
00409   if( edge_reversed )
00410     new_mid_edge_data = new CubitFacetEdgeData( other_pt, new_pt );
00411   else
00412     new_mid_edge_data = new CubitFacetEdgeData( new_pt, other_pt );
00413
00414   new_mid_edge = CAST_TO( new_mid_edge_data, CubitFacetEdge );
00415
00416   new_mid_edge->marked(2);
00417
00418     // new_mid_edge is appended
00419   facet_edge_list.append( new_mid_edge );
00420
00421     /* ////edge constructor takes care of this
00422        target_facet->edge( new_mid_edge, pt1_index );
00423
00424        if( !edge_reversed ){  // new_mid_edge index 2
00425        new_facet->edge( new_mid_edge, ( e_index + 1 ) % 3 );
00426        sense = new_facet->point( ( e_index + 2 ) % 3 ) == new_mid_edge->point(0) ? 1 : -1;
00427        new_facet->edge_use( sense, (e_index + 1 ) % 3);
00428        }
00429        else{ // edge index 1
00430        new_facet->edge( new_mid_edge, ( e_index - 1 ) % 3 );
00431        sense = new_facet->point( ( e_index  ) % 3 ) == new_mid_edge->point(0) ? 1 : -1;
00432        new_facet->edge_use( sense, (e_index - 1 ) % 3);
00433        }
00434     */
00435
00436
00437 #ifndef NDEBUG
00438     /* ---------------------- TESTING ----------------------- */
00439     // Testing the oerientation of faces w.r.t. the common edge
00440
00441   int index0, index1;
00442
00443   if( new_mid_edge->num_adj_facets() != 2 ){
00444     PRINT_INFO("ERROR:number of adjacent faces of new mid edge is not equal to 2 \n");
00445     assert(0);
00446   }
00447
00448   CubitFacet *ptr_facet0 = new_mid_edge->adj_facet(0);
00449   CubitFacet *ptr_facet1 = new_mid_edge->adj_facet(1);
00450
00451   for( index0 = 0; index0 < 3; index0++ ){
00452     if( ptr_facet0->edge(index0) == new_mid_edge )
00453       break;
00454   }
00455
00456   for( index1 = 0; index1 < 3; index1++ ){
00457     if( ptr_facet1->edge(index1) == new_mid_edge )
00458       break;
00459   }
00460
00461   if( index0 == 3 || index1 == 3 ){
00462     PRINT_INFO("ERROR: new edge doesn't exist at the adjacent facets \n");
00463     assert(0);
00464   }
00465
00466   if( ptr_facet0->edge_use(index0) == ptr_facet1->edge_use(index1) ){
00467     PRINT_INFO("ERROR: The orientation of edges is adjacent facet is not proper \n");
00468     assert(0);
00469   }
00470
00471 #endif
00472
00473     //PRINT_DEBUG_157("Passes\n");
00474
00475   return CAST_TO( new_facet, CubitFacet );
00476 }
00477
00478 // This only checks gfx facet edge valence right now (should be == 2)
00479 CubitBoolean TDOctreeRefFace::check_valid_facets(CubitBoolean disable_if_bad)
00480 {
00481   int i;
00482   CubitBoolean good_facets = CUBIT_TRUE;
00483   CubitFacetEdge *facet_edge;
00484
00485   for (i=0; i < ptrCubitFacetEdgeList->size(); ++i)
00486   {
00487     facet_edge = ptrCubitFacetEdgeList->get_and_step();
00488     if (facet_edge->num_adj_facets() > 2)
00489     {
00490       good_facets = CUBIT_FALSE;
00491       break;
00492     }
00493   }
00494
00495   if (disable_if_bad && !good_facets) {set_create_2dmat(CUBIT_FALSE);}
00496   return good_facets;
00497 }
00498
00499 //EOF
00500
