actuate_cubit_attrib(int attrib_type) | CubitAttribUser | |
actuate_cubit_attrib(DLIList< RefEntity * >, int) | CubitAttribUser | [static] |
add_compare_data(RefEntity *partner) | RefEntity | |
add_cubit_attrib(CubitAttrib *cubit_attrib_ptr) | CubitAttribUser | |
add_observer(CubitObserver *observer) | CubitObservable | [protected, virtual] |
add_TD(ToolData *new_td) | ToolDataUser | [virtual] |
append_attrib_internal(TopologyBridge *bridge, const CubitSimpleAttrib &attrib_ptr) | CubitAttribUser | |
append_simple_attribute(TopologyBridge *bridge, const CubitSimpleAttrib &attrib_ptr) | CubitAttribUser | |
assign_default_name(CubitBoolean user_setting=CUBIT_FALSE) | RefEntity | |
auto_actuate_cubit_attrib(CubitBoolean from_constructor=CUBIT_TRUE, CubitBoolean after_geom_changes=CUBIT_FALSE) | CubitAttribUser | |
auto_read_cubit_attrib() | CubitAttribUser | |
auto_update_cubit_attrib() | CubitAttribUser | |
auto_update_cubit_attrib(DLIList< RefEntity * > &entity_list, CubitBoolean write_too=CUBIT_TRUE) | CubitAttribUser | [static] |
autoMergeStatus | RefEntity | [protected] |
bounding_box()=0 | CubitEntity | [pure virtual] |
can_modify() | RefEntity | [virtual] |
center_point() | RefEntity | [virtual] |
change_to_parent_ref_entities(DLIList< RefEntity * > &ancestors) | RefEntity | [static] |
children_mergeable() | RefEntity | [virtual] |
class_name() const =0 | CubitEntity | [pure virtual] |
clear_all_simple_attrib(DLIList< RefEntity * > &entity_list) | CubitAttribUser | [static] |
clear_all_simple_attrib_set_to_actuate(DLIList< RefEntity * > &entity_list) | CubitAttribUser | [static] |
clear_simple_attribs() | CubitAttribUser | |
clear_simple_attribs_set_to_actuate() | CubitAttribUser | |
collectionEntityPtr | RefCollection | [protected] |
color(int value) | RefEntity | [virtual] |
color() const | RefEntity | [virtual] |
comparison_found(RefEntity *partner) | RefEntity | |
CubitAttribUser(CubitAttrib *=NULL) | CubitAttribUser | |
CubitEntity() | CubitEntity | [inline] |
CubitEventDispatcher class | CubitObservable | [friend] |
CubitObservable() | CubitObservable | |
CubitObservable(const CubitObservable &) | CubitObservable | [protected] |
CubitObserver class | CubitObservable | [friend] |
dag_type() const =0 | RefEntity | [pure virtual] |
dag_type(const std::type_info &) | RefEntity | [static] |
dag_type(const char *cli_type_name) | RefEntity | [static] |
delete_TD(IdentityFn specified_type) | ToolDataUser | [virtual] |
delete_TD(ToolData *td) | ToolDataUser | [virtual] |
dimension() const | RefEntity | [virtual] |
entity_name() const | RefEntity | [virtual] |
entity_name(CubitString name) | RefEntity | |
entity_names(DLIList< CubitString > &names) const | RefEntity | |
entity_type_info() const =0 | RefEntity | [pure virtual] |
entityId | CubitEntity | [protected] |
find_cubit_attrib_type(int, DLIList< CubitAttrib * > &) const | CubitAttribUser | |
gather_bdy_entities(DLIList< RefEntity * > &entity_list, DLIList< RefEntity * > &bdy_list) | RefEntity | [static] |
generate_default_name(CubitString &name) | RefEntity | |
get_all_child_ref_entities(DLIList< RefEntity * > &entity_list) | RefEntity | |
get_all_child_ref_entities(DLIList< RefEntity * > &input_list, DLIList< RefEntity * > &output_list) | RefEntity | [static] |
get_all_parent_ref_entities(DLIList< RefEntity * > &entity_list, const int get_bodies=CUBIT_FALSE) | RefEntity | |
get_all_TDs(IdentityFn specified_type, DLIList< ToolData * > *all_tds) const | ToolDataUser | [virtual] |
get_all_TDs(DLIList< ToolData * > *all_tds) const | ToolDataUser | [virtual] |
get_by_name(const CubitString &name) | RefEntity | [static] |
get_child_ref_entities(DLIList< RefEntity * > &entity_list) | RefEntity | [virtual] |
get_child_ref_entity_type() const | RefEntity | |
get_child_ref_entity_type(DagType parent_type) | RefEntity | [static] |
get_collection_entity_ptr() | RefCollection | [inline] |
get_collection_entity_ptr() const | RefCollection | [inline] |
get_compare_partner() | RefEntity | |
get_cubit_attrib(int attrib_type, CubitBoolean create_if_missing=CUBIT_TRUE) | CubitAttribUser | |
get_cubit_attrib_list(DLIList< CubitAttrib * > &) | CubitAttribUser | |
get_entity_type_info(const char *entity_type) | RefEntity | [static] |
get_observer_list(DLIList< CubitObserver * > &observers) | CubitObservable | |
get_parent_ref_entities(DLIList< RefEntity * > &entity_list)=0 | RefEntity | [pure virtual] |
get_parent_ref_entity_type() const | RefEntity | |
get_parent_ref_entity_type(DagType child_type) | RefEntity | [static] |
get_ref_class_name(const std::type_info &ref_type) | RefEntity | [static] |
get_related_entity_list(const std::type_info &related_entity_type, DLIList< RefEntity * > &entity_list) | RefEntity | |
get_TD(IdentityFn specified_type) | ToolDataUser | [virtual] |
get_TD(IdentityFn specified_type) const | ToolDataUser | [virtual] |
headAttrib | CubitAttribUser | [protected] |
id() const | CubitEntity | [virtual] |
is_child(RefEntity *entity) | RefEntity | [virtual] |
is_mergeable(AutoMergeStatus val) | RefEntity | [virtual] |
is_mergeable() | RefEntity | |
is_merged() | RefEntity | |
is_parent(RefEntity *entity) | RefEntity | [virtual] |
is_transparent(int flag) | CubitEntity | [virtual] |
is_transparent() const | CubitEntity | [virtual] |
is_visible(int flag) | CubitEntity | [virtual] |
is_visible() const | CubitEntity | [virtual] |
join(RefEntity *ref_entity_2, DLIList< RefEntity * > &join_set) | RefEntity | |
join(DLIList< RefEntity * > &ref_entities, DLIList< RefEntity * > &join_set) | RefEntity | [static] |
listFlag | RefEntity | [protected] |
local_tolerance(double value) | RefEntity | [inline] |
local_tolerance(void) | RefEntity | [inline] |
marked(int value) | RefEntity | [inline, virtual] |
marked() | RefEntity | [inline, virtual] |
markedFlag | RefEntity | [protected] |
mColor | RefEntity | [protected] |
measure() | RefEntity | [virtual] |
measure_label() | RefEntity | [virtual] |
meet(RefEntity *ref_entity_2, DLIList< RefEntity * > &join_set) | RefEntity | |
meet(DLIList< RefEntity * > &ref_entities, DLIList< RefEntity * > &join_set) | RefEntity | [static] |
merge_entity_names(RefEntity *dead_entity) | RefEntity | |
merge_owner(RefEntity *deletable_entity) | CubitAttribUser | |
merge_status() const | RefEntity | |
notify_observers(const CubitEvent *event) | CubitObservable | |
notify_sub_all_observers(const GeometryEvent::Type &event) | RefEntity | |
num_cubit_attrib() | CubitAttribUser | |
num_names() const | RefEntity | |
num_parent_ref_entities() | RefEntity | |
observerList | CubitObservable | [protected] |
CubitObservable::operator=(const CubitObservable &) | CubitObservable | [protected] |
read_cubit_attrib(int attrib_type) | CubitAttribUser | |
RefCollection() | RefCollection | |
RefEntity() | RefEntity | |
remove_all_simple_attribute(TopologyBridge *bridge) | CubitAttribUser | |
remove_attrib_geometry_entity(CubitAttrib *) | CubitAttribUser | |
remove_compare_data() | RefEntity | |
remove_cubit_attrib(int attrib_type) | CubitAttribUser | |
remove_cubit_attrib(CubitAttrib *) | CubitAttribUser | |
remove_entity_name(CubitString const &name) | RefEntity | |
remove_entity_names() | RefEntity | |
remove_from_observers() | CubitObservable | [protected] |
remove_observer(CubitObserver *observer) | CubitObservable | [protected, virtual] |
remove_simple_attribute(TopologyBridge *bridge, const CubitSimpleAttrib &attrib_ptr) | CubitAttribUser | |
remove_TD(IdentityFn specified_type) | ToolDataUser | [virtual] |
remove_TD(ToolData *td) | ToolDataUser | [virtual] |
set_collection_entity_ptr(CollectionEntity *collection_entity_ptr) | RefCollection | |
set_id(int i) | RefEntity | [virtual] |
set_id(int i, CubitBoolean emit_event) | RefEntity | |
set_updated_flag(CubitBoolean flag) | CubitAttribUser | |
set_written_flag(CubitBoolean flag) | CubitAttribUser | |
split_owner(DLIList< CubitSimpleAttrib > &csa_list) | CubitAttribUser | |
switch_entity_names(RefEntity *other_entity) | RefEntity | |
ToolDataUser() | ToolDataUser | [inline] |
transf_owner(const CubitVector &matrow1, const CubitVector &matrow2, const CubitVector &matrow3, const CubitVector &translate_vec, const double scale_factor) | CubitAttribUser | |
update_auto_merge_state() | RefEntity | |
update_cubit_attrib(int) | CubitAttribUser | |
valence(RefEntity *parent=NULL) | RefEntity | |
validate() | RefEntity | [virtual] |
write_cubit_attrib_by_type(int attrib_type) | CubitAttribUser | |
write_cubit_attrib_list(DLIList< CubitAttrib * > attrib_list) | CubitAttribUser | |
write_cubit_attribs() | CubitAttribUser | |
write_specific_cubit_attrib(CubitAttrib *cubit_attrib_ptr) | CubitAttribUser | |
~CubitAttribUser() | CubitAttribUser | [virtual] |
~CubitEntity() | CubitEntity | [virtual] |
~CubitObservable() | CubitObservable | [virtual] |
~RefCollection() | RefCollection | [virtual] |
~RefEntity() | RefEntity | [virtual] |
~ToolDataUser() | ToolDataUser | [virtual] |
