add(PartitionLoop *loop) | PartitionSurface | |
add(PartitionCoSurf *cosurf) | PartitionSurface | |
append_simple_attribute_virt(const CubitSimpleAttrib &) | PartitionSurface | [virtual] |
are_positions_on(DLIList< CubitVector * > &test_position_list, DLIList< CubitBoolean * > &is_on_list) | Surface | [virtual] |
bodysm() | TopologyBridge | |
bodysms(DLIList< BodySM * > &bodies, bool unique=true) | TopologyBridge | |
bounding_box() const | PartitionSurface | [virtual] |
bridge_manager() const | TopologyBridge | |
bridge_manager(BridgeManager *manager) | TopologyBridge | |
bridge_sense() | TopologyBridge | [inline] |
ChildType typedef | Surface | |
closest_facet(const CubitVector &input_position, CubitVector &result_position) | PartitionSurface | |
closest_point(CubitVector const &pos, CubitVector *close=0, CubitVector *norm=0, CubitVector *curv1=0, CubitVector *curv2=0) | SubSurface | [virtual] |
closest_point_along_vector(CubitVector &from_point, CubitVector &along_vector, CubitVector &point_on_surface) | SubSurface | [virtual] |
closest_point_trimmed(CubitVector from, CubitVector &result) | SubSurface | [virtual] |
closest_point_uv_guess(CubitVector const &location, double &u, double &v, CubitVector *closest_location=NULL, CubitVector *unit_normal=NULL) | SubSurface | [virtual] |
closest_points(DLIList< CubitVector * > &location_list, DLIList< CubitVector * > *closest_location_list=NULL, DLIList< CubitVector * > *unit_normal_list=NULL, DLIList< CubitVector * > *curvature1_list=NULL, DLIList< CubitVector * > *curvature2_list=NULL) | Surface | [virtual] |
closest_points_trimmed(std::vector< CubitVector > &from_points_list, std::vector< CubitVector > &points_on_surface_list) | Surface | [virtual] |
coedgesms(DLIList< CoEdgeSM * > &coedgesms, bool unique=true) | TopologyBridge | |
combine(PartitionSurface *dead_surface) | SubSurface | [virtual] |
construct(const CubitSimpleAttrib &attrib, PartitionLump *vol) | PartitionSurface | [static] |
copy() | SubSurface | [protected, virtual] |
curves(DLIList< Curve * > &curves, bool unique=true) | TopologyBridge | |
curves_ignore_virtual(DLIList< Curve * > &curves, bool unique=true) | TopologyBridge | |
draw_facets(int color) const | PartitionSurface | |
evaluate(double u, double v, CubitVector *position, CubitVector *unit_normal, CubitVector *curvature1, CubitVector *curvature2) | SubSurface | [virtual] |
Surface::evaluate(double u, double v, CubitVector &pos, CubitVector deriv1[2], CubitVector deriv2[3]) | Surface | [virtual] |
facetList | PartitionSurface | [protected] |
find_first(const PartitionShell *shell) const | PartitionSurface | |
find_first(const PartitionLump *lump) const | PartitionSurface | |
find_first(const PartitionShell *shell, CubitSense sense) const | PartitionSurface | |
find_next(const PartitionCoSurf *cosurf) const | PartitionSurface | |
geometry_sense | PartitionSurface | [protected] |
geometry_type() | SubSurface | [virtual] |
GeometryEntity() | GeometryEntity | [inline] |
get_children(DLIList< TopologyBridge * > &children, bool return_hidden_entities=false, int layer=MAX_TB_LAYER) | TopologyBridge | |
get_children_virt(DLIList< TopologyBridge * > &) | PartitionSurface | [virtual] |
get_cone_params(CubitVector ¢er, CubitVector &normal, CubitVector &major_axis, double &radius_ratio, double &sine_angle, double &cos_angle) const | SubSurface | [virtual] |
get_facet_data(DLIList< CubitFacetData * > &result_list) const | PartitionSurface | |
get_geometry_query_engine() const | PartitionSurface | [virtual] |
get_geometry_sense() | SubSurface | [virtual] |
get_nurb_params(bool &rational, int °ree_u, int °ree_v, int &num_cntrl_pts_u, int &num_cntrl_pts_v, DLIList< CubitVector > &cntrl_pts, DLIList< double > &weights, DLIList< double > &u_knots, DLIList< double > &v_knots) const | SubSurface | [virtual] |
get_param_range_U(double &lo, double &hi) | SubSurface | [virtual] |
get_param_range_V(double &lo, double &hi) | SubSurface | [virtual] |
get_parents(DLIList< TopologyBridge * > &parents) | TopologyBridge | |
get_parents_virt(DLIList< TopologyBridge * > &) | PartitionSurface | [virtual] |
get_point_normal(CubitVector &point, CubitVector &normal) | SubSurface | [virtual] |
get_points(DLIList< PartitionPoint * > &list) const | PartitionSurface | |
get_projected_distance_on_surface(CubitVector *pos1, CubitVector *pos2, double &distance) | PartitionSurface | [virtual] |
get_save_topology(DLIList< int > &curves) | PartitionSurface | [protected] |
get_saved_id() const | GeometryEntity | [inline] |
get_saved_names(std::vector< CubitString > &names) | GeometryEntity | |
get_shell_sense(ShellSM *shell_ptr) const | PartitionSurface | [virtual] |
get_simple_attribute(DLIList< CubitSimpleAttrib > &) | PartitionSurface | [virtual] |
get_simple_attribute(const CubitString &name, DLIList< CubitSimpleAttrib > &) | PartitionSurface | [virtual] |
get_sphere_params(CubitVector ¢er, double &radius) const | SubSurface | [virtual] |
get_torus_params(CubitVector ¢er, CubitVector &normal, double &major_radius, double &minor_radius) const | SubSurface | [virtual] |
get_uv_sense() | Surface | [inline, virtual] |
has_facets() const | PartitionSurface | [inline] |
init_facet_data() | PartitionSurface | |
insert_facets(DLIList< PartitionEntity * > points, DLIList< CubitFacetEdgeData * > &boundary_edges, DLIList< CubitFacetData * > &surf_facets) | PartitionSurface | [protected] |
interior_facet_points(DLIList< CubitPoint * > &result_list) const | PartitionSurface | [protected] |
is_closed_in_U() | SubSurface | [virtual] |
is_closed_in_V() | SubSurface | [virtual] |
is_cylindrical() | Surface | [inline, virtual] |
is_parametric() | SubSurface | [virtual] |
is_periodic() | SubSurface | [virtual] |
is_periodic_in_U(double &period) | SubSurface | [virtual] |
is_periodic_in_V(double &period) | SubSurface | [virtual] |
is_position_on(CubitVector &test_position) | SubSurface | [virtual] |
is_singular_in_U(double u_param) | SubSurface | [virtual] |
is_singular_in_V(double v_param) | SubSurface | [virtual] |
layer() const | PartitionSurface | [inline, virtual] |
loopsm() | TopologyBridge | |
loopsms(DLIList< LoopSM * > &loopsms, bool unique=true) | TopologyBridge | |
lump() | TopologyBridge | |
lumps(DLIList< Lump * > &lumps, bool unique=true) | TopologyBridge | |
mark | PartitionEntity | |
MAX_TB_LAYER enum value | TopologyBridge | |
measure() | SubSurface | [virtual] |
move_to_geometry(CubitVector &position) | PartitionSurface | [virtual] |
next_co_surface(const PartitionCoSurf *prev=0) const | PartitionSurface | [inline] |
next_loop(const PartitionLoop *prev=0) const | PartitionSurface | [inline] |
notify_destroyed(CubitFacetData *facet) | PartitionSurface | |
notify_moving_point(CubitPoint *point, const CubitVector &new_pos) | PartitionSurface | |
notify_split(FacetEntity *old_tri, FacetEntity *new_tri) | PartitionSurface | [virtual] |
num_loops() const | PartitionSurface | |
owner() const | TopologyBridge | [inline] |
owner(TBOwner *new_owner) | TopologyBridge | [inline] |
param_dir(CubitVector &, CubitVector &, double &, double &) | Surface | [inline, virtual] |
partitioned_entity() const | PartitionEntity | [inline] |
partitioned_surface() const | SubSurface | [inline] |
PartitionEntity() | PartitionEntity | [protected] |
PartitionSurface(PartitionLump *owner) | PartitionSurface | |
PartitionSurface() | PartitionSurface | [protected] |
point_containment(const CubitVector &point) | PartitionSurface | [virtual] |
point_containment(double u, double v) | PartitionSurface | [virtual] |
point_containment(const CubitVector &point, PartitionCurve *&boundary_curve) | PartitionSurface | |
points(DLIList< TBPoint * > &points, bool unique=true) | TopologyBridge | |
position_from_u_v(double u, double v) | SubSurface | [virtual] |
principal_curvatures(CubitVector const &loc, double &curv1, double &curv2, CubitVector *closest_location=0) | SubSurface | [virtual] |
print_debug_info(const char *prefix=0, bool print_sub_entity_set=true) const | PartitionSurface | [virtual] |
print_partitioned_entity(const char *prefix=0) const | PartitionEntity | |
relax_to_geometry(CubitPoint *facet_point, const CubitVector *input_position=0) | PartitionEntity | |
remove(PartitionLoop *loop) | PartitionSurface | |
remove(PartitionCoSurf *cosurf) | PartitionSurface | |
remove_all_simple_attribute_virt() | PartitionSurface | [virtual] |
remove_simple_attribute_virt(const CubitSimpleAttrib &) | PartitionSurface | [virtual] |
replace_facets(DLIList< CubitFacetData * > &dead_facets, DLIList< CubitFacetData * > &new_facets) | PartitionSurface | |
reverse_bridge_sense() | TopologyBridge | [inline] |
reverse_loops() | PartitionSurface | [protected] |
reverse_sense() | SubSurface | [virtual] |
save(CubitSimpleAttrib &) | SubSurface | [virtual] |
set_facet_data(const DLIList< CubitFacetData * > &new_list) | PartitionSurface | |
set_saved_id(int value) | GeometryEntity | [inline] |
set_saved_names(const std::vector< CubitString > &names) | GeometryEntity | |
shellsms(DLIList< ShellSM * > &shellsms, bool unique=true) | TopologyBridge | |
split(DLIList< CubitFacetData * > &facets_to_move) | PartitionSurface | |
sub_entity_set() const | PartitionEntity | [inline] |
SubSurface(Surface *real_surf) | SubSurface | |
SubSurface(SubSurface *split_from) | SubSurface | [private] |
Surface() | Surface | |
surfaces(DLIList< Surface * > &surfaces, bool unique=true) | TopologyBridge | |
surfaces_ignore_virtual(DLIList< Surface * > &surfaces, bool unique=true) | TopologyBridge | |
topology_entity() const | TopologyBridge | |
TopologyBridge() | TopologyBridge | [inline] |
transform(const CubitTransformMatrix &xform) | PartitionSurface | [virtual] |
u_v_from_position(CubitVector const &location, double &u, double &v, CubitVector *closest_location=NULL) | SubSurface | [virtual] |
update_facet_tool() | PartitionSurface | [protected] |
uv_derivitives(double u, double v, CubitVector &du, CubitVector &dv) | SubSurface | [virtual] |
validate(const CubitString &, DLIList< TopologyEntity * > &) | TopologyBridge | [inline, virtual] |
~GeometryEntity() | GeometryEntity | [virtual] |
~PartitionEntity() | PartitionEntity | [virtual] |
~PartitionSurface() | PartitionSurface | [virtual] |
~SubSurface() | SubSurface | [virtual] |
~Surface() | Surface | [virtual] |
~TopologyBridge() | TopologyBridge | [virtual] |
