cgma
00001 //- Class: AnalyticGeometryTool 00002 //- Description: This class performs calculations on analytic geometry 00003 // (points, lines, arcs, planes, polygons). Capabilities 00004 // include vector and point math, matrix operations, 00005 // measurements, intersections and comparison/containment checks. 00006 // 00007 //- Owner: Steve Storm, Caterpillar Inc. 00008 //- Checked by: 00009 00010 00011 #include <float.h> 00012 #include "AnalyticGeometryTool.hpp" 00013 #include "CubitMessage.hpp" 00014 #include "CubitBox.hpp" 00015 #include "CubitPlane.hpp" 00016 #include "CubitVector.hpp" 00017 #include "DLIList.hpp" 00018 #include <math.h> 00019 #include "CastTo.hpp" 00020 #include "GfxPreview.hpp" 00021 #include "GMem.hpp" 00022 00023 #include <fstream> 00024 using std::cout; 00025 using std::endl; 00026 using std::ofstream; 00027 using std::ios; 00028 using std::ostream; 00029 00030 static double AGT_IDENTITY_MTX_4X4[4][4] = { {1.0, 0.0, 0.0, 0.0}, 00031 {0.0, 1.0, 0.0, 0.0}, 00032 {0.0, 0.0, 1.0, 0.0}, 00033 {0.0, 0.0, 0.0, 1.0} }; 00034 00035 static double AGT_IDENTITY_MTX_3X3[3][3] = { {1.0, 0.0, 0.0}, 00036 {0.0, 1.0, 0.0}, 00037 {0.0, 0.0, 1.0} }; 00038 00039 AnalyticGeometryTool* AnalyticGeometryTool::instance_ = 0; 00040 00041 Point2 operator+ (const Point2& p, const Point2& q) 00042 { 00043 Point2 add; 00044 add.x = p.x + q.x; 00045 add.y = p.y + q.y; 00046 return add; 00047 } 00048 00049 Point2 operator- (const Point2& p, const Point2& q) 00050 { 00051 Point2 sub; 00052 sub.x = p.x - q.x; 00053 sub.y = p.y - q.y; 00054 return sub; 00055 } 00056 00057 Point2 operator* (double t, const Point2& p) 00058 { 00059 Point2 prod; 00060 prod.x = t*p.x; 00061 prod.y = t*p.y; 00062 return prod; 00063 } 00064 00065 Point2 operator* (const Point2& p, double t) 00066 { 00067 Point2 prod; 00068 prod.x = t*p.x; 00069 prod.y = t*p.y; 00070 return prod; 00071 } 00072 00073 Point2 operator- (const Point2& p) 00074 { 00075 Point2 neg; 00076 neg.x = -p.x; 00077 neg.y = -p.y; 00078 return neg; 00079 } 00080 00081 inline double AnalyticGeometryTool::Dot (const Point2& p, const Point2& q) 00082 { 00083 return double(p.x*q.x + p.y*q.y); 00084 } 00085 00086 Point3 operator+ (const Point3& p, const Point3& q) 00087 { 00088 Point3 add; 00089 add.x = p.x + q.x; 00090 add.y = p.y + q.y; 00091 add.z = p.z + q.z; 00092 return add; 00093 } 00094 00095 Point3 operator- (const Point3& p, const Point3& q) 00096 { 00097 Point3 sub; 00098 sub.x = p.x - q.x; 00099 sub.y = p.y - q.y; 00100 sub.z = p.z - q.z; 00101 return sub; 00102 } 00103 00104 Point3 operator* (double t, const Point3& p) 00105 { 00106 Point3 prod; 00107 prod.x = t*p.x; 00108 prod.y = t*p.y; 00109 prod.z = t*p.z; 00110 return prod; 00111 } 00112 00113 Point3 operator* (const Point3& p, double t) 00114 { 00115 Point3 prod; 00116 prod.x = t*p.x; 00117 prod.y = t*p.y; 00118 prod.z = t*p.z; 00119 return prod; 00120 } 00121 00122 Point3 operator- (const Point3& p) 00123 { 00124 Point3 neg; 00125 neg.x = -p.x; 00126 neg.y = -p.y; 00127 neg.z = -p.z; 00128 return neg; 00129 } 00130 00131 // Method: instance 00132 // provides access to the unique model for this execution. 00133 // sets up this instance on first access 00134 AnalyticGeometryTool* AnalyticGeometryTool::instance() 00135 { 00136 if (instance_ == 0) { 00137 instance_ = new AnalyticGeometryTool; 00138 } 00139 return instance_; 00140 } 00141 00142 AnalyticGeometryTool::AnalyticGeometryTool() 00143 { 00144 agtEpsilon = 1e-8; 00145 } 00146 00147 AnalyticGeometryTool::~AnalyticGeometryTool() 00148 { 00149 instance_ = NULL; 00150 } 00151 00152 //*************************************************************************** 00153 // Double numbers 00154 //*************************************************************************** 00155 00156 00157 void AnalyticGeometryTool::round_near_val( double &val ) 00158 { 00159 if( dbl_eq( val, 0.0 ) ) 00160 val = 0.0; 00161 else if( dbl_eq( val, 1.0 ) ) 00162 val = 1.0; 00163 else if( dbl_eq( val, -1.0 ) ) 00164 val = -1.0; 00165 } 00166 00167 //*************************************************************************** 00168 // Matrices & Transforms 00169 //*************************************************************************** 00170 void AnalyticGeometryTool::transform_pnt( double m[4][4], 00171 double pin[3], 00172 double pout[3] ) 00173 { 00174 double p[3]; // working buffer 00175 00176 // Check if transformation can occur 00177 if (!m) { 00178 if (pin && pout) 00179 copy_pnt(pin, pout); 00180 return; 00181 } 00182 00183 // Perform transformation 00184 p[0] = m[0][0] * pin[0] + m[1][0] * pin[1] + m[2][0] * pin[2] + m[3][0]; 00185 p[1] = m[0][1] * pin[0] + m[1][1] * pin[1] + m[2][1] * pin[2] + m[3][1]; 00186 p[2] = m[0][2] * pin[0] + m[1][2] * pin[1] + m[2][2] * pin[2] + m[3][2]; 00187 00188 // Copy work buffer to out point 00189 copy_pnt(p,pout); 00190 } 00191 00192 void AnalyticGeometryTool::transform_vec( double m3[3][3], 00193 double vin[3], 00194 double vout[3] ) 00195 { 00196 double v[3]; // working buffer 00197 00198 // Determine if transformation can occur 00199 if (!m3) { 00200 if (vin && vout) 00201 copy_vec(vin, vout); 00202 return; 00203 } 00204 00205 // Perform transformation 00206 v[0] = m3[0][0] * vin[0] + m3[1][0] * vin[1] + m3[2][0] * vin[2]; 00207 v[1] = m3[0][1] * vin[0] + m3[1][1] * vin[1] + m3[2][1] * vin[2]; 00208 v[2] = m3[0][2] * vin[0] + m3[1][2] * vin[1] + m3[2][2] * vin[2]; 00209 00210 // Copy work buffer to vector out 00211 copy_pnt(v,vout); 00212 } 00213 00214 void AnalyticGeometryTool::transform_vec( double m4[4][4], 00215 double vin[3], 00216 double vout[3] ) 00217 { 00218 double v[3]; // working buffer 00219 00220 // Determine if transformation can occur 00221 if (!m4) { 00222 if (vin && vout) 00223 copy_vec(vin, vout); 00224 return; 00225 } 00226 00227 // Perform transformation 00228 00229 v[0] = m4[0][0] * vin[0] + m4[1][0] * vin[1] + m4[2][0] * vin[2]; 00230 v[1] = m4[0][1] * vin[0] + m4[1][1] * vin[1] + m4[2][1] * vin[2]; 00231 v[2] = m4[0][2] * vin[0] + m4[1][2] * vin[1] + m4[2][2] * vin[2]; 00232 00233 // Copy work buffer to vector out 00234 copy_pnt(v,vout); 00235 } 00236 00237 void AnalyticGeometryTool::transform_line( double rot_mtx[4][4], 00238 double origin[3], double axis[3] ) 00239 { 00240 double end_pnt[3]; // Find arbitrary end point on line 00241 next_pnt( origin, axis, 10.0, end_pnt ); 00242 00243 transform_pnt( rot_mtx, origin, origin ); 00244 transform_pnt( rot_mtx, end_pnt, end_pnt ); 00245 00246 axis[0] = end_pnt[0] - origin[0]; 00247 axis[1] = end_pnt[1] - origin[1]; 00248 axis[2] = end_pnt[2] - origin[2]; 00249 } 00250 00251 void AnalyticGeometryTool::transform_line( double rot_mtx[4][4], 00252 CubitVector &origin, CubitVector &axis ) 00253 { 00254 CubitVector end_point; // Find arbitrary end point on line 00255 origin.next_point( axis, 10.0, end_point ); 00256 00257 double start_pnt[3], end_pnt[3]; 00258 copy_pnt( origin, start_pnt ); 00259 copy_pnt( end_point, end_pnt ); 00260 00261 transform_pnt( rot_mtx, start_pnt, start_pnt ); 00262 transform_pnt( rot_mtx, end_pnt, end_pnt ); 00263 00264 axis.x( end_pnt[0] - start_pnt[0] ); 00265 axis.y( end_pnt[1] - start_pnt[1] ); 00266 axis.z( end_pnt[2] - start_pnt[2] ); 00267 00268 origin.set( start_pnt ); 00269 } 00270 00271 void AnalyticGeometryTool::copy_mtx( double from[3][3],double to[3][3] ) 00272 { 00273 // Determine if identity matrix needed 00274 if (!from) // copy in the identity matrix 00275 memcpy(to, AGT_IDENTITY_MTX_3X3, sizeof(double)*9); 00276 else // Copy from to to 00277 memcpy(to, from, sizeof(double)*9); 00278 } 00279 00280 void AnalyticGeometryTool::copy_mtx( double from[4][4], double to[4][4] ) 00281 { 00282 // determine if identity matrix needed 00283 if (!from) // copy in the identity matrix 00284 memcpy(to, AGT_IDENTITY_MTX_4X4, sizeof(double)*16); 00285 else // copy from to to 00286 memcpy(to, from, sizeof(double)*16); 00287 } 00288 00289 void AnalyticGeometryTool::copy_mtx( double from[4][4], double to[3][3] ) 00290 { 00291 size_t dbl3; 00292 00293 dbl3 = sizeof(double) * 3; 00294 00295 // Determine if identity matrix needed 00296 if (!from) // Copy in the identity matrix 00297 memcpy(to, AGT_IDENTITY_MTX_3X3, sizeof(double)*9); 00298 else { // Copy each upper left element of from to to 00299 memcpy(to[0], from[0], dbl3); 00300 memcpy(to[1], from[1], dbl3); 00301 memcpy(to[2], from[2], dbl3); 00302 } 00303 } 00304 00305 void AnalyticGeometryTool::copy_mtx(double from[3][3], double to[4][4], 00306 double* origin ) 00307 { 00308 size_t dbl3; 00309 00310 dbl3 = sizeof(double) * 3; 00311 00312 // Determine if identity matrix needed 00313 if (!from) { // Copy in the identity matrix 00314 00315 memcpy(to, AGT_IDENTITY_MTX_4X4, sizeof(double)*16); 00316 00317 if (origin) 00318 memcpy(to[3], origin, dbl3); 00319 } 00320 00321 else { // Copy each upper element of from to to 00322 00323 memcpy(to[0], from[0], dbl3); 00324 memcpy(to[1], from[1], dbl3); 00325 memcpy(to[2], from[2], dbl3); 00326 00327 to[0][3] = 0.0; 00328 to[1][3] = 0.0; 00329 to[2][3] = 0.0; 00330 to[3][3] = 1.0; 00331 00332 if (origin) 00333 { 00334 memcpy(to[3], origin, dbl3); 00335 // to[3][0] = origin[0]; 00336 // to[3][1] = origin[1]; 00337 // to[3][2] = origin[2]; 00338 } 00339 else 00340 memcpy(to[3], AGT_IDENTITY_MTX_4X4[3], sizeof(double)*3); 00341 } 00342 } 00343 00344 void AnalyticGeometryTool::create_rotation_mtx( double theta, double v[3], 00345 double mtx3x3[3][3] ) 00346 { 00347 double coeff1; 00348 double coeff2; 00349 double coeff3; 00350 double v_unit[3]; 00351 00352 if (!mtx3x3) 00353 return; 00354 00355 coeff1 = cos(theta); 00356 coeff2 = (1.0l - coeff1); 00357 coeff3 = sin(theta); 00358 00359 unit_vec(v, v_unit); 00360 00361 mtx3x3[0][0] = coeff1 + coeff2 * (v_unit[0] * v_unit[0]); 00362 mtx3x3[0][1] = coeff2 * v_unit[1] * v_unit[0] + coeff3 * v_unit[2]; 00363 mtx3x3[0][2] = coeff2 * v_unit[2] * v_unit[0] - coeff3 * v_unit[1]; 00364 00365 mtx3x3[1][0] = coeff2 * v_unit[1] * v_unit[0] - coeff3 * v_unit[2]; 00366 mtx3x3[1][1] = coeff1 + coeff2 * (v_unit[1] * v_unit[1]); 00367 mtx3x3[1][2] = coeff2 * v_unit[1] * v_unit[2] + coeff3 * v_unit[0]; 00368 00369 mtx3x3[2][0] = coeff2 * v_unit[2] * v_unit[0] + coeff3 * v_unit[1]; 00370 mtx3x3[2][1] = coeff2 * v_unit[2] * v_unit[1] - coeff3 * v_unit[0]; 00371 mtx3x3[2][2] = coeff1 + coeff2 * (v_unit[2] * v_unit[2]); 00372 } 00373 00374 void AnalyticGeometryTool::create_rotation_mtx( double theta, double v[3], 00375 double mtx4x4[4][4] ) 00376 { 00377 double coeff1; 00378 double coeff2; 00379 double coeff3; 00380 double v_unit[3]; 00381 00382 if (!mtx4x4) 00383 return; 00384 00385 coeff1 = cos(theta); 00386 coeff2 = (1.0l - coeff1); 00387 coeff3 = sin(theta); 00388 00389 unit_vec(v, v_unit); 00390 00391 mtx4x4[0][0] = coeff1 + coeff2 * (v_unit[0] * v_unit[0]); 00392 mtx4x4[0][1] = coeff2 * v_unit[1] * v_unit[0] + coeff3 * v_unit[2]; 00393 mtx4x4[0][2] = coeff2 * v_unit[2] * v_unit[0] - coeff3 * v_unit[1]; 00394 00395 mtx4x4[1][0] = coeff2 * v_unit[1] * v_unit[0] - coeff3 * v_unit[2]; 00396 mtx4x4[1][1] = coeff1 + coeff2 * (v_unit[1] * v_unit[1]); 00397 mtx4x4[1][2] = coeff2 * v_unit[1] * v_unit[2] + coeff3 * v_unit[0]; 00398 00399 mtx4x4[2][0] = coeff2 * v_unit[2] * v_unit[0] + coeff3 * v_unit[1]; 00400 mtx4x4[2][1] = coeff2 * v_unit[2] * v_unit[1] - coeff3 * v_unit[0]; 00401 mtx4x4[2][2] = coeff1 + coeff2 * (v_unit[2] * v_unit[2]); 00402 00403 mtx4x4[0][3] = 0.0; 00404 mtx4x4[1][3] = 0.0; 00405 mtx4x4[2][3] = 0.0; 00406 mtx4x4[3][3] = 1.0; 00407 mtx4x4[3][0] = 0.0; 00408 mtx4x4[3][1] = 0.0; 00409 mtx4x4[3][2] = 0.0; 00410 } 00411 00412 void AnalyticGeometryTool::add_origin_to_rotation_mtx( double rot_mtx[4][4], 00413 double origin[3] ) 00414 { 00415 double tmp_mtx[4][4]; 00416 00417 // Translate to origin 00418 double t[4][4]; 00419 memcpy(t, AGT_IDENTITY_MTX_4X4, sizeof(double)*16); 00420 //PRINT_INFO( "Rotation matrix, before origin: \n" ); 00421 //print_mtx( rot_mtx ); 00422 t[3][0]=-origin[0]; t[3][1]=-origin[1]; t[3][2]=-origin[2]; 00423 mult_mtx( t, rot_mtx, tmp_mtx ); 00424 00425 //PRINT_INFO( "Origin times rotation: \n" ); 00426 //print_mtx( tmp_mtx ); 00427 00428 // Translate back 00429 t[3][0]=origin[0]; t[3][1]=origin[1]; t[3][2]=origin[2]; 00430 mult_mtx( tmp_mtx, t, rot_mtx ); 00431 00432 //PRINT_INFO( "Rotation x -origin: \n" ); 00433 //print_mtx( rot_mtx ); 00434 } 00435 00436 void AnalyticGeometryTool::identity_mtx( double mtx3x3[3][3] ) 00437 { 00438 memcpy(mtx3x3, AGT_IDENTITY_MTX_3X3, sizeof(double)*9); 00439 } 00440 00441 void AnalyticGeometryTool::identity_mtx( double mtx4x4[4][4] ) 00442 { 00443 memcpy(mtx4x4, AGT_IDENTITY_MTX_4X4, sizeof(double)*16); 00444 } 00445 00446 void AnalyticGeometryTool::mtx_to_angs( double mtx3x3[3][3], 00447 double &ax, double &ay, 00448 double &az ) 00449 { 00450 // METHOD: 00451 // o Rotate x-vector onto xz plane 00452 // o Check xp dotted into y 00453 // o If xp dot y is zero ==> az = 0 (x-vector already in xz plane) 00454 // o Otherwise, compute rotation of vector into xz plane to acquire *az 00455 // o Use atan2 (on x-vector) to get *az 00456 // o Rotate the system about z 00457 // o Use atan2 function (on x-vector in xz plane) to determine *ay 00458 // o Rotate the system about y 00459 // o Compute ax using y-vector 00460 // o Resultant angles are negated (to reverse above procedure) 00461 00462 double x[3]; // x-axis vector 00463 double y[3]; // y-axis vector 00464 double z[3]; // z-axis vector 00465 double ar[3][3]; // Rotation matrix 00466 double sinr,cosr; // Used for atan2 function 00467 double work_sys[3][3]; // Temporary holder for system 00468 double *xp = work_sys[0]; // x-axis vector of system: x-primed 00469 double *yp = work_sys[1]; // y-axis vector of system: y-primed 00470 00471 x[0] = 1.0; x[1] = 0.0; x[2] = 0.0; 00472 y[0] = 0.0; y[1] = 1.0; y[2] = 0.0; 00473 z[0] = 0.0; z[1] = 0.0; z[2] = 1.0; 00474 00475 if (!mtx3x3) 00476 return; 00477 00478 // Copy matrix over to work csys 00479 copy_mtx(mtx3x3,work_sys); 00480 00481 // Check xp dotted into y 00482 // If xp dot y is zero ==> az = 0 00483 00484 // Otherwise, compute rotation of vector into xz plane to acquire *az 00485 00486 if (dbl_eq(dot_vec(xp,y), 0.0)) 00487 00488 az = 0.0; 00489 00490 else { 00491 00492 /* 00493 Compute *az - rotate xp to xz-plane about z-axis 00494 y xp 00495 | / 00496 | / negative angle about z (negative of atan2) 00497 -----x (use RH rule about z) 00498 \ 00499 \ positive angle about z (negative of atan2) 00500 xp 00501 */ 00502 00503 sinr = dot_vec(xp,y); 00504 cosr = dot_vec(xp,x); 00505 az = - atan2(sinr, cosr); 00506 00507 // Rotate the system about z 00508 create_rotation_mtx(az,z,ar); 00509 rotate_system(ar,work_sys,work_sys); 00510 00511 } 00512 00513 /* 00514 Compute *ay - rotate xp to x-axis about y-axis 00515 z xp 00516 | / 00517 | / positive angle about y (positive of atan2) 00518 -----x (use RH rule about y) 00519 \ 00520 \ negative angle about y (positive of atan2) 00521 xp 00522 */ 00523 00524 sinr = dot_vec(xp,z); 00525 cosr = dot_vec(xp,x); 00526 ay = atan2(sinr, cosr); 00527 00528 // Rotate the system about y 00529 create_rotation_mtx(ay,y,ar); 00530 rotate_system(ar,work_sys,work_sys); 00531 00532 /* 00533 Compute *ax - rotate yp to y-axis about x-axis 00534 z yp 00535 | / 00536 | / negative angle about x (negative of atan2) 00537 -----y (use RH rule about x) 00538 \ 00539 \ positive angle about x (negative of atan2) 00540 yp 00541 */ 00542 00543 sinr = dot_vec(yp,z); 00544 cosr = dot_vec(yp,y); 00545 ax = atan2(sinr,cosr); // Negative of negative - see below 00546 00547 // Negate above angles for rotation of the system back to original 00548 az = -(az); 00549 ay = -(ay); 00550 00551 // Make sure near zero angles are actually zero 00552 if (dbl_eq(ax, 0.0)) 00553 ax = 0.0; 00554 00555 if (dbl_eq(ay, 0.0)) 00556 ay = 0.0; 00557 } 00558 00559 void AnalyticGeometryTool::mtx_to_angs( double mtx4x4[4][4], 00560 double &ax, double &ay, 00561 double &az ) 00562 { 00563 double work_sys[3][3]; 00564 00565 if(!mtx4x4) 00566 return; 00567 00568 copy_mtx(mtx4x4,work_sys); 00569 mtx_to_angs( work_sys, ax, ay, az ); 00570 } 00571 00572 void AnalyticGeometryTool::rotate_system( double mtx[3][3], 00573 double sys_in[3][3], 00574 double sys_out[3][3] ) 00575 { 00576 double sys_tmp[3][3]; 00577 double *p_sys_tmp; 00578 00579 // Check to see if rotating in place 00580 if (sys_in == sys_out) { 00581 copy_mtx( sys_in, sys_tmp ); 00582 p_sys_tmp = (double *)sys_tmp; 00583 } 00584 else 00585 // Have sys_tmp point at outgoing memory location 00586 p_sys_tmp = (double *)sys_out; 00587 00588 00589 // X-vector 00590 p_sys_tmp[0] = mtx[0][0] * sys_in[0][0] 00591 + mtx[1][0] * sys_in[0][1] 00592 + mtx[2][0] * sys_in[0][2]; 00593 p_sys_tmp[1] = mtx[0][1] * sys_in[0][0] 00594 + mtx[1][1] * sys_in[0][1] 00595 + mtx[2][1] * sys_in[0][2]; 00596 p_sys_tmp[2] = mtx[0][2] * sys_in[0][0] 00597 + mtx[1][2] * sys_in[0][1] 00598 + mtx[2][2] * sys_in[0][2]; 00599 00600 // Y-vector 00601 p_sys_tmp[3] = mtx[0][0] * sys_in[1][0] 00602 + mtx[1][0] * sys_in[1][1] 00603 + mtx[2][0] * sys_in[1][2]; 00604 p_sys_tmp[4] = mtx[0][1] * sys_in[1][0] 00605 + mtx[1][1] * sys_in[1][1] 00606 + mtx[2][1] * sys_in[1][2]; 00607 p_sys_tmp[5] = mtx[0][2] * sys_in[1][0] 00608 + mtx[1][2] * sys_in[1][1] 00609 + mtx[2][2] * sys_in[1][2]; 00610 00611 // Z-vector 00612 p_sys_tmp[6] = mtx[0][0] * sys_in[2][0] 00613 + mtx[1][0] * sys_in[2][1] 00614 + mtx[2][0] * sys_in[2][2]; 00615 p_sys_tmp[7] = mtx[0][1] * sys_in[2][0] 00616 + mtx[1][1] * sys_in[2][1] 00617 + mtx[2][1] * sys_in[2][2]; 00618 p_sys_tmp[8] = mtx[0][2] * sys_in[2][0] 00619 + mtx[1][2] * sys_in[2][1] 00620 + mtx[2][2] * sys_in[2][2]; 00621 00622 // Copy sys_tmp to sys_out if rotating in place 00623 if (sys_in == sys_out) { 00624 memcpy(sys_out, sys_tmp, sizeof(double)*9); 00625 } 00626 } 00627 00628 void AnalyticGeometryTool::rotate_system( double mtx[4][4], 00629 double sys_in[4][4], 00630 double sys_out[4][4] ) 00631 { 00632 double sys_tmp[4][4]; 00633 double* p_sys_tmp; 00634 00635 // Check to see if rotating in place 00636 if (sys_in == sys_out) { 00637 copy_mtx( sys_in, sys_tmp ); 00638 p_sys_tmp = (double *)sys_tmp; 00639 } 00640 else 00641 // Have p_sys_tmp point at outgoing memory location 00642 p_sys_tmp = (double *)sys_out; 00643 00644 00645 // X-vector 00646 p_sys_tmp[0] = mtx[0][0] * sys_in[0][0] 00647 + mtx[1][0] * sys_in[0][1] 00648 + mtx[2][0] * sys_in[0][2]; 00649 p_sys_tmp[1] = mtx[0][1] * sys_in[0][0] 00650 + mtx[1][1] * sys_in[0][1] 00651 + mtx[2][1] * sys_in[0][2]; 00652 p_sys_tmp[2] = mtx[0][2] * sys_in[0][0] 00653 + mtx[1][2] * sys_in[0][1] 00654 + mtx[2][2] * sys_in[0][2]; 00655 00656 // Y-vector 00657 p_sys_tmp[4] = mtx[0][0] * sys_in[1][0] 00658 + mtx[1][0] * sys_in[1][1] 00659 + mtx[2][0] * sys_in[1][2]; 00660 p_sys_tmp[5] = mtx[0][1] * sys_in[1][0] 00661 + mtx[1][1] * sys_in[1][1] 00662 + mtx[2][1] * sys_in[1][2]; 00663 p_sys_tmp[6] = mtx[0][2] * sys_in[1][0] 00664 + mtx[1][2] * sys_in[1][1] 00665 + mtx[2][2] * sys_in[1][2]; 00666 00667 // Z-vector 00668 p_sys_tmp[8] = mtx[0][0] * sys_in[2][0] 00669 + mtx[1][0] * sys_in[2][1] 00670 + mtx[2][0] * sys_in[2][2]; 00671 p_sys_tmp[9] = mtx[0][1] * sys_in[2][0] 00672 + mtx[1][1] * sys_in[2][1] 00673 + mtx[2][1] * sys_in[2][2]; 00674 p_sys_tmp[10] = mtx[0][2] * sys_in[2][0] 00675 + mtx[1][2] * sys_in[2][1] 00676 + mtx[2][2] * sys_in[2][2]; 00677 00678 // Maintain the origin 00679 p_sys_tmp[3] = sys_in[0][3]; 00680 p_sys_tmp[7] = sys_in[1][3]; 00681 p_sys_tmp[11] = sys_in[2][3]; 00682 p_sys_tmp[15] = sys_in[3][3]; 00683 p_sys_tmp[12] = sys_in[3][0]; 00684 p_sys_tmp[13] = sys_in[3][1]; 00685 p_sys_tmp[14] = sys_in[3][2]; 00686 00687 // Copy sys_tmp to sys_out if rotating in place 00688 if (sys_in == sys_out) { 00689 memcpy(sys_out, sys_tmp, sizeof(double)*16); 00690 } 00691 } 00692 00693 double AnalyticGeometryTool::det_mtx( double m[3][3] ) 00694 { 00695 double determinant; 00696 00697 if (!m) 00698 return (0.0); 00699 00700 determinant = m[0][0]*(m[1][1]*m[2][2]-m[1][2]*m[2][1]) 00701 + m[0][1]*(m[1][2]*m[2][0]-m[1][0]*m[2][2]) 00702 + m[0][2]*(m[1][0]*m[2][1]-m[1][1]*m[2][0]); 00703 00704 return (determinant); 00705 } 00706 00707 void AnalyticGeometryTool::mult_mtx( double a[3][3],double b[3][3], 00708 double d[3][3] ) 00709 { 00710 double c[3][3]; // working buffer 00711 00712 if( a != 0 && b != 0 ) { // a & b are valid 00713 00714 c[0][0] = ( a[0][0] * b[0][0] + a[0][1] * b[1][0] 00715 + a[0][2] * b[2][0]); 00716 c[1][0] = ( a[1][0] * b[0][0] + a[1][1] * b[1][0] 00717 + a[1][2] * b[2][0]); 00718 c[2][0] = ( a[2][0] * b[0][0] + a[2][1] * b[1][0] 00719 + a[2][2] * b[2][0]); 00720 00721 c[0][1] = ( a[0][0] * b[0][1] + a[0][1] * b[1][1] 00722 + a[0][2] * b[2][1]); 00723 c[1][1] = ( a[1][0] * b[0][1] + a[1][1] * b[1][1] 00724 + a[1][2] * b[2][1]); 00725 c[2][1] = ( a[2][0] * b[0][1] + a[2][1] * b[1][1] 00726 + a[2][2] * b[2][1]); 00727 00728 c[0][2] = ( a[0][0] * b[0][2] + a[0][1] * b[1][2] 00729 + a[0][2] * b[2][2]); 00730 c[1][2] = ( a[1][0] * b[0][2] + a[1][1] * b[1][2] 00731 + a[1][2] * b[2][2]); 00732 c[2][2] = ( a[2][0] * b[0][2] + a[2][1] * b[1][2] 00733 + a[2][2] * b[2][2]); 00734 00735 copy_mtx(c, d); 00736 00737 } 00738 else if (a) { // b equals 0 00739 copy_mtx(a, d); 00740 } 00741 else if (b) { // a equals 0 00742 copy_mtx(b, d); 00743 } 00744 else { // a & b equal 0 00745 00746 copy_mtx(AGT_IDENTITY_MTX_3X3, d); 00747 } 00748 } 00749 00750 void AnalyticGeometryTool::mult_mtx( double a[4][4], 00751 double b[4][4], 00752 double d[4][4] ) 00753 { 00754 double c[4][4]; // working buffer 00755 00756 if( a != 0 && b != 0 ) { // a & b are valid 00757 00758 c[0][0] = ( a[0][0] * b[0][0] + a[0][1] * b[1][0] 00759 + a[0][2] * b[2][0] + a[0][3] * b[3][0]); 00760 c[1][0] = ( a[1][0] * b[0][0] + a[1][1] * b[1][0] 00761 + a[1][2] * b[2][0] + a[1][3] * b[3][0]); 00762 c[2][0] = ( a[2][0] * b[0][0] + a[2][1] * b[1][0] 00763 + a[2][2] * b[2][0] + a[2][3] * b[3][0]); 00764 c[3][0] = ( a[3][0] * b[0][0] + a[3][1] * b[1][0] 00765 + a[3][2] * b[2][0] + a[3][3] * b[3][0]); 00766 00767 c[0][1] = ( a[0][0] * b[0][1] + a[0][1] * b[1][1] 00768 + a[0][2] * b[2][1] + a[0][3] * b[3][1]); 00769 c[1][1] = ( a[1][0] * b[0][1] + a[1][1] * b[1][1] 00770 + a[1][2] * b[2][1] + a[1][3] * b[3][1]); 00771 c[2][1] = ( a[2][0] * b[0][1] + a[2][1] * b[1][1] 00772 + a[2][2] * b[2][1] + a[2][3] * b[3][1]); 00773 c[3][1] = ( a[3][0] * b[0][1] + a[3][1] * b[1][1] 00774 + a[3][2] * b[2][1] + a[3][3] * b[3][1]); 00775 00776 c[0][2] = ( a[0][0] * b[0][2] + a[0][1] * b[1][2] 00777 + a[0][2] * b[2][2] + a[0][3] * b[3][2]); 00778 c[1][2] = ( a[1][0] * b[0][2] + a[1][1] * b[1][2] 00779 + a[1][2] * b[2][2] + a[1][3] * b[3][2]); 00780 c[2][2] = ( a[2][0] * b[0][2] + a[2][1] * b[1][2] 00781 + a[2][2] * b[2][2] + a[2][3] * b[3][2]); 00782 c[3][2] = ( a[3][0] * b[0][2] + a[3][1] * b[1][2] 00783 + a[3][2] * b[2][2] + a[3][3] * b[3][2]); 00784 00785 c[0][3] = ( a[0][0] * b[0][3] + a[0][1] * b[1][3] 00786 + a[0][2] * b[2][3] + a[0][3] * b[3][3]); 00787 c[1][3] = ( a[1][0] * b[0][3] + a[1][1] * b[1][3] 00788 + a[1][2] * b[2][3] + a[1][3] * b[3][3]); 00789 c[2][3] = ( a[2][0] * b[0][3] + a[2][1] * b[1][3] 00790 + a[2][2] * b[2][3] + a[2][3] * b[3][3]); 00791 c[3][3] = ( a[3][0] * b[0][3] + a[3][1] * b[1][3] 00792 + a[3][2] * b[2][3] + a[3][3] * b[3][3]); 00793 00794 copy_mtx(c, d); 00795 } 00796 else if (a) { // b equals 0 00797 copy_mtx(a, d); 00798 } 00799 else if (b) { // a equals 0 00800 copy_mtx(b, d); 00801 } 00802 else { // a & b equal 0 00803 00804 copy_mtx(AGT_IDENTITY_MTX_4X4, d); 00805 } 00806 } 00807 00808 CubitStatus AnalyticGeometryTool::inv_mtx_adj( double mtx[3][3], 00809 double inv_mtx[3][3] ) 00810 { 00811 int i,i1,i2,j,j1,j2; 00812 double work_mtx[3][3]; 00813 double determinant; 00814 00815 // Check for null input 00816 if (!mtx) { 00817 copy_mtx(AGT_IDENTITY_MTX_3X3, inv_mtx); 00818 return CUBIT_SUCCESS; 00819 } 00820 00821 // Calculate determinant 00822 determinant = det_mtx(mtx); 00823 00824 // Check for singularity 00825 if (dbl_eq(determinant,0.0)) 00826 return CUBIT_FAILURE; 00827 00828 // Get work matrix (allow inverting in place) 00829 copy_mtx(mtx, work_mtx); 00830 00831 // Inverse is adjoint matrix divided by determinant 00832 for (i=1; i<4; i++) { 00833 00834 i1 = (i % 3) + 1; i2 = (i1 % 3) + 1; 00835 00836 for (j=1; j<4; j++) { 00837 00838 j1 = (j % 3) + 1; j2 = (j1 % 3) + 1; 00839 00840 inv_mtx[j-1][i-1] = (work_mtx[i1-1][j1-1]*work_mtx[i2-1][j2-1] - 00841 work_mtx[i1-1][j2-1]*work_mtx[i2-1][j1-1]) 00842 / determinant; 00843 00844 } 00845 } 00846 return CUBIT_SUCCESS; 00847 } 00848 00849 CubitStatus AnalyticGeometryTool::inv_trans_mtx( double transf[4][4], 00850 double inv_transf[4][4] ) 00851 { 00852 double scale_sq; 00853 double inv_sq_scale; 00854 double tmp_transf[4][4]; // For temporary storage of incoming matrix 00855 double *p_tmp_transf = NULL; 00856 00857 // If input transform is 0 set output to identity matrix 00858 if (!transf) { 00859 copy_mtx( AGT_IDENTITY_MTX_4X4, inv_transf ); 00860 return CUBIT_SUCCESS; 00861 } 00862 00863 // Obtain the matrix scale 00864 scale_sq = transf[0][0]*transf[0][0] + transf[0][1]*transf[0][1] + 00865 transf[0][2]*transf[0][2]; 00866 00867 // Check for singular matrix 00868 if (scale_sq < (.000000001 * .000000001)) 00869 return CUBIT_FAILURE; 00870 00871 // Need the inverse scale squared 00872 inv_sq_scale = 1.0 / scale_sq; 00873 00874 // Check to see if inverting in place 00875 if (transf == inv_transf) { 00876 copy_mtx( transf, tmp_transf ); 00877 p_tmp_transf = (double *)tmp_transf; 00878 } 00879 else 00880 p_tmp_transf = (double *)transf; 00881 00882 // The X vector 00883 inv_transf[0][0] = p_tmp_transf[0] * inv_sq_scale; 00884 inv_transf[1][0] = p_tmp_transf[1] * inv_sq_scale; 00885 inv_transf[2][0] = p_tmp_transf[2] * inv_sq_scale; 00886 00887 // The Y vector 00888 inv_transf[0][1] = p_tmp_transf[4] * inv_sq_scale; 00889 inv_transf[1][1] = p_tmp_transf[5] * inv_sq_scale; 00890 inv_transf[2][1] = p_tmp_transf[6] * inv_sq_scale; 00891 00892 // The Z vector 00893 inv_transf[0][2] = p_tmp_transf[8] * inv_sq_scale; 00894 inv_transf[1][2] = p_tmp_transf[9] * inv_sq_scale; 00895 inv_transf[2][2] = p_tmp_transf[10] * inv_sq_scale; 00896 00897 // Column 4 00898 inv_transf[0][3] = 0.0; 00899 inv_transf[1][3] = 0.0; 00900 inv_transf[2][3] = 0.0; 00901 00902 // The X origin 00903 inv_transf[3][0] = -inv_sq_scale * ( p_tmp_transf[0] * p_tmp_transf[12] 00904 + p_tmp_transf[1] * p_tmp_transf[13] 00905 + p_tmp_transf[2] * p_tmp_transf[14]); 00906 00907 // The Y origin 00908 inv_transf[3][1] = -inv_sq_scale * ( p_tmp_transf[4] * p_tmp_transf[12] 00909 + p_tmp_transf[5] * p_tmp_transf[13] 00910 + p_tmp_transf[6] * p_tmp_transf[14]); 00911 00912 // The Z origin 00913 inv_transf[3][2] = -inv_sq_scale * ( p_tmp_transf[8] * p_tmp_transf[12] 00914 + p_tmp_transf[9] * p_tmp_transf[13] 00915 + p_tmp_transf[10] * p_tmp_transf[14]); 00916 00917 // This is always one 00918 inv_transf[3][3] = 1.0; 00919 00920 return CUBIT_SUCCESS; 00921 } 00922 00923 void AnalyticGeometryTool::vecs_to_mtx( double xvec[3], 00924 double yvec[3], 00925 double zvec[3], 00926 double matrix[3][3] ) 00927 { 00928 if (xvec) 00929 copy_pnt(xvec, matrix[0]); 00930 else 00931 copy_pnt(AGT_IDENTITY_MTX_3X3[0], matrix[0]); 00932 00933 if (yvec) 00934 copy_pnt(yvec, matrix[1]); 00935 else 00936 copy_pnt(AGT_IDENTITY_MTX_3X3[1], matrix[1]); 00937 00938 if (zvec) 00939 copy_pnt(zvec, matrix[2]); 00940 else 00941 copy_pnt(AGT_IDENTITY_MTX_3X3[2], matrix[2]); 00942 } 00943 00944 void AnalyticGeometryTool::vecs_to_mtx( double xvec[3], 00945 double yvec[3], 00946 double zvec[3], 00947 double origin[3], 00948 double matrix[4][4] ) 00949 { 00950 if (xvec) 00951 copy_pnt(xvec, matrix[0]); 00952 else 00953 copy_pnt(AGT_IDENTITY_MTX_3X3[0], matrix[0]); 00954 00955 if (yvec) 00956 copy_pnt(yvec, matrix[1]); 00957 else 00958 copy_pnt(AGT_IDENTITY_MTX_3X3[1], matrix[1]); 00959 00960 if (zvec) 00961 copy_pnt(zvec, matrix[2]); 00962 else 00963 copy_pnt(AGT_IDENTITY_MTX_3X3[2], matrix[2]); 00964 00965 if( origin ) 00966 copy_pnt(origin, matrix[3]); 00967 else 00968 { 00969 matrix[3][0] = 0.0; 00970 matrix[3][1] = 0.0; 00971 matrix[3][2] = 0.0; 00972 } 00973 00974 matrix[0][3] = 0.0; 00975 matrix[1][3] = 0.0; 00976 matrix[2][3] = 0.0; 00977 matrix[3][3] = 1.0; 00978 } 00979 00980 void AnalyticGeometryTool::print_mtx( double mtx[3][3] ) 00981 { 00982 PRINT_INFO( "%f %f %f\n", mtx[0][0], mtx[0][1], mtx[0][2] ); 00983 PRINT_INFO( "%f %f %f\n", mtx[1][0], mtx[1][1], mtx[1][2] ); 00984 PRINT_INFO( "%f %f %f\n", mtx[2][0], mtx[2][1], mtx[2][2] ); 00985 } 00986 00987 void AnalyticGeometryTool::print_mtx( double mtx[4][4] ) 00988 { 00989 PRINT_INFO( "%f %f %f %f\n", mtx[0][0], mtx[0][1], mtx[0][2], mtx[0][3] ); 00990 PRINT_INFO( "%f %f %f %f\n", mtx[1][0], mtx[1][1], mtx[1][2], mtx[1][3] ); 00991 PRINT_INFO( "%f %f %f %f\n", mtx[2][0], mtx[2][1], mtx[2][2], mtx[2][3] ); 00992 PRINT_INFO( "%f %f %f %f\n", mtx[3][0], mtx[3][1], mtx[3][2], mtx[3][3] ); 00993 } 00994 00995 //*************************************************************************** 00996 // 3D Points 00997 //*************************************************************************** 00998 void AnalyticGeometryTool::copy_pnt( double pnt_in[3], double pnt_out[3] ) 00999 { 01000 if (pnt_in == pnt_out) 01001 return; 01002 01003 if (pnt_out == NULL) 01004 return; 01005 01006 if (pnt_in == NULL) { 01007 pnt_out[0] = 0.0; 01008 pnt_out[1] = 0.0; 01009 pnt_out[2] = 0.0; 01010 return; 01011 } 01012 01013 // Simply copy first point into second point 01014 memcpy(pnt_out, pnt_in, sizeof(double)*3); 01015 } 01016 01017 void AnalyticGeometryTool::copy_pnt( double pnt_in[3], CubitVector &cubit_vec ) 01018 { 01019 cubit_vec.set( pnt_in ); 01020 } 01021 01022 void AnalyticGeometryTool::copy_pnt( CubitVector &cubit_vec, double pnt_out[3] ) 01023 { 01024 pnt_out[0] = cubit_vec.x(); 01025 pnt_out[1] = cubit_vec.y(); 01026 pnt_out[2] = cubit_vec.z(); 01027 } 01028 01029 01030 CubitBoolean AnalyticGeometryTool::pnt_eq( double pnt1[3],double pnt2[3] ) 01031 { 01032 double x = pnt2[0] - pnt1[0]; // difference in the x direction 01033 double y = pnt2[1] - pnt1[1]; // difference in the y direction 01034 double z = pnt2[2] - pnt1[2]; // difference in the z direction 01035 01036 return (dbl_eq(sqrt(x*x + y*y + z*z), 0.0)); 01037 } 01038 01039 01040 CubitStatus AnalyticGeometryTool::mirror_pnt( double pnt[3], 01041 double pln_orig[3], 01042 double pln_norm[3], 01043 double m_pnt[3]) 01044 { 01045 double int_pnt[3], 01046 vec[3]; 01047 01048 // Find intersection of point and plane 01049 if (int_pnt_pln(pnt, pln_orig, pln_norm, int_pnt)) { 01050 // If intersection is on the plane, return 01051 copy_pnt(pnt, m_pnt); 01052 return CUBIT_FAILURE; 01053 } 01054 01055 // Find vector from pnt to int_pnt 01056 get_vec(pnt, int_pnt, vec); 01057 01058 // Traverse twice the length of vec in vec direction 01059 m_pnt[0] = pnt[0] + 2.0 * vec[0]; 01060 m_pnt[1] = pnt[1] + 2.0 * vec[1]; 01061 m_pnt[2] = pnt[2] + 2.0 * vec[2]; 01062 01063 return CUBIT_SUCCESS; 01064 } 01065 01066 01067 CubitStatus AnalyticGeometryTool::next_pnt( double str_pnt[3], 01068 double vec_dir[3], 01069 double len, 01070 double new_pnt[3]) 01071 { 01072 double uv[3]; // unit vector representation of vector direction 01073 01074 // unitize specified direction 01075 if (!unit_vec(vec_dir,uv)) { 01076 copy_pnt(str_pnt, new_pnt); 01077 return CUBIT_FAILURE; 01078 } 01079 01080 // determine next point in space 01081 01082 new_pnt[0] = str_pnt[0] + (len * uv[0]); 01083 new_pnt[1] = str_pnt[1] + (len * uv[1]); 01084 new_pnt[2] = str_pnt[2] + (len * uv[2]); 01085 01086 return CUBIT_SUCCESS; 01087 } 01088 01089 01090 //*************************************************************************** 01091 // 3D Vectors 01092 //*************************************************************************** 01093 CubitStatus AnalyticGeometryTool::unit_vec( double vin[3], double vout[3] ) 01094 { 01095 double rmag; // holds magnitude of vector 01096 01097 // Calculate vector magnitude 01098 rmag = sqrt(vin[0]*vin[0] + vin[1]*vin[1] + vin[2]*vin[2]); 01099 01100 // check if vector has a magnitude - catch division by zero 01101 01102 if (dbl_eq(rmag, 0.0)) { 01103 if (vin != vout) 01104 copy_pnt(vin, vout); 01105 return CUBIT_FAILURE; 01106 } 01107 01108 // divide each element of the vector by the magnitude 01109 01110 vout[0] = vin[0] / rmag; 01111 vout[1] = vin[1] / rmag; 01112 vout[2] = vin[2] / rmag; 01113 01114 return CUBIT_SUCCESS; 01115 } 01116 01117 double AnalyticGeometryTool::dot_vec( double uval[3], double vval[3] ) 01118 { 01119 double dot_val; 01120 01121 // perform dot calculation = v[0]*u[0] + v[1]*u[1] + v[1]*u[1] 01122 01123 dot_val = uval[0]*vval[0] + uval[1]*vval[1] + uval[2]*vval[2]; 01124 01125 return(dot_val); 01126 } 01127 01128 void AnalyticGeometryTool::cross_vec( double uval[3], double vval[3], 01129 double cross[3] ) 01130 { 01131 // determine cross product of the two vectors 01132 01133 cross[0] = uval[1] * vval[2] - uval[2] * vval[1]; 01134 cross[1] = uval[2] * vval[0] - uval[0] * vval[2]; 01135 cross[2] = uval[0] * vval[1] - uval[1] * vval[0]; 01136 } 01137 01138 void AnalyticGeometryTool::cross_vec_unit( double uval[3], double vval[3], 01139 double cross[3] ) 01140 { 01141 // determine cross product of the two vectors 01142 cross_vec(uval,vval,cross); 01143 01144 // convert to unit vector 01145 unit_vec(cross,cross); 01146 } 01147 01148 void AnalyticGeometryTool::orth_vecs( double uvect[3], double vvect[3], 01149 double wvect[3] ) 01150 { 01151 double x[3]; 01152 unsigned short i = 0; 01153 unsigned short imin = 3; 01154 double rmin = 1.0E20; 01155 unsigned short iperm1[3]; 01156 unsigned short iperm2[3]; 01157 unsigned short cont_flag = 1; 01158 double vec[3]; 01159 01160 // Initialize perm flags 01161 iperm1[0] = 1; iperm1[1] = 2; iperm1[2] = 0; 01162 iperm2[0] = 2; iperm2[1] = 0; iperm2[2] = 1; 01163 01164 // unitize vector 01165 01166 unit_vec(uvect,vec); 01167 01168 while (i<3 && cont_flag ) { 01169 if (dbl_eq(vec[i], 0.0)) { 01170 vvect[i] = 1.0; 01171 vvect[iperm1[i]] = 0.0; 01172 vvect[iperm2[i]] = 0.0; 01173 cont_flag = 0; 01174 } 01175 01176 if (fabs(vec[i]) < rmin) { 01177 imin = i; 01178 rmin = fabs(vec[i]); 01179 } 01180 ++i; 01181 } 01182 01183 if (cont_flag) { 01184 x[imin] = 1.0; 01185 x[iperm1[imin]] = 0.0; 01186 x[iperm2[imin]] = 0.0; 01187 01188 // determine cross product 01189 cross_vec_unit(vec,x,vvect); 01190 } 01191 01192 // cross vector to determine last orthogonal vector 01193 cross_vec(vvect,vec,wvect); 01194 } 01195 01196 double AnalyticGeometryTool::mag_vec( double vec[3] ) 01197 { 01198 return (sqrt(vec[0]*vec[0] + vec[1]*vec[1] + vec[2]*vec[2])); 01199 } 01200 01201 CubitStatus AnalyticGeometryTool::get_vec ( double str_pnt[3], 01202 double stp_pnt[3], 01203 double vector_out[3] ) 01204 { 01205 // Make sure we can create a vector 01206 if (pnt_eq(str_pnt, stp_pnt)) { 01207 vector_out[0] = 0.0; 01208 vector_out[1] = 0.0; 01209 vector_out[2] = 0.0; 01210 return CUBIT_FAILURE; 01211 } 01212 01213 // determine vector by subtracting starting point from stopping point 01214 01215 vector_out[0] = stp_pnt[0] - str_pnt[0]; 01216 vector_out[1] = stp_pnt[1] - str_pnt[1]; 01217 vector_out[2] = stp_pnt[2] - str_pnt[2]; 01218 01219 return CUBIT_SUCCESS; 01220 } 01221 01222 CubitStatus AnalyticGeometryTool::get_vec_unit( double str_pnt[3], 01223 double stp_pnt[3], 01224 double uv_out[3] ) 01225 { 01226 // determine vector between points 01227 if (!get_vec(str_pnt,stp_pnt,uv_out)) 01228 return CUBIT_FAILURE; 01229 01230 // unitize vector 01231 if (!unit_vec(uv_out,uv_out)) 01232 return CUBIT_FAILURE; 01233 01234 return CUBIT_SUCCESS; 01235 } 01236 01237 void AnalyticGeometryTool::mult_vecxconst( double constant, 01238 double vec[3], 01239 double vec_out[3] ) 01240 { 01241 // multiply each element of the vector by the constant 01242 vec_out[0] = constant * vec[0]; 01243 vec_out[1] = constant * vec[1]; 01244 vec_out[2] = constant * vec[2]; 01245 } 01246 01247 01248 void AnalyticGeometryTool::reverse_vec( double vin[3],double vout[3] ) 01249 { 01250 // Multiply the vector components by a -1.0 01251 mult_vecxconst(-1.0, vin, vout); 01252 } 01253 01254 double AnalyticGeometryTool::angle_vec_vec( double v1[3],double v2[3] ) 01255 { 01256 double denom, dot, cosang, sinang, acrsb, angle; 01257 double crossed_vec[3]; 01258 01259 // For accuracy, use cosine for large angles, sine for small angles 01260 denom = sqrt((v1[0]*v1[0] + v1[1]*v1[1] + v1[2]*v1[2]) 01261 *(v2[0]*v2[0] + v2[1]*v2[1] + v2[2]*v2[2])); 01262 01263 // Check for a zero length vector 01264 if (dbl_eq(denom, 0.0)) 01265 return (0.0); 01266 01267 dot = dot_vec(v1, v2); 01268 01269 cosang = dot/denom; 01270 01271 if (1.0 - fabs(cosang) < 0.01) { 01272 cross_vec(v1, v2, crossed_vec); 01273 acrsb = mag_vec(crossed_vec); 01274 sinang = acrsb/denom; 01275 if (cosang > 0.0) 01276 angle = asin(sinang); 01277 else 01278 angle = AGT_PI - asin(sinang); 01279 } 01280 else 01281 angle = acos(cosang); 01282 01283 return (angle); 01284 } 01285 01286 //*************************************************************************** 01287 // Distances 01288 //*************************************************************************** 01289 double AnalyticGeometryTool::dist_pnt_pnt( double pnt1[3], double pnt2[3] ) 01290 { 01291 double x = pnt2[0] - pnt1[0]; // difference in the x direction 01292 double y = pnt2[1] - pnt1[1]; // difference in the y direction 01293 double z = pnt2[2] - pnt1[2]; // difference in the z direction 01294 01295 // return the distance 01296 return(sqrt(x*x + y*y + z*z)); 01297 } 01298 01299 01300 01301 double AnalyticGeometryTool::dist_pln_pln( double pln_1_orig[3], 01302 double pln_1_norm[3], 01303 double pln_2_orig[3], 01304 double pln_2_norm[3], 01305 AgtSide *side, 01306 AgtOrientation *orien, 01307 unsigned short *status ) 01308 { 01309 double distance; 01310 double int_pnt[3]; 01311 double vec[3]; 01312 01313 // Check to see if planes are parallel 01314 if (is_vec_par(pln_1_norm, pln_2_norm)) { 01315 01316 // Set successful status 01317 if (status) 01318 *status = 1; 01319 01320 // Calculate perpendicular line plane intersection on plane_2 from 01321 // pln_1_origin 01322 int_ln_pln(pln_1_orig, pln_1_norm, pln_2_orig, pln_2_norm, 01323 int_pnt); 01324 01325 // Find distance between pln_1_origin and this intersection pnt 01326 distance = dist_pnt_pnt(pln_1_orig, int_pnt); 01327 01328 // Get side if required 01329 if (side) { 01330 01331 if (dbl_eq(distance, 0.0)) 01332 01333 *side = AGT_ON_PLANE; 01334 01335 else { 01336 01337 // Get vector to intersection point 01338 get_vec(pln_1_orig, int_pnt, vec); 01339 01340 // Compare angles 01341 if (dbl_eq(angle_vec_vec(vec, pln_1_norm), 0.0)) 01342 *side = AGT_POS_SIDE; 01343 else 01344 *side = AGT_NEG_SIDE; 01345 01346 } 01347 } 01348 01349 // Get orientation if required 01350 if (orien) { 01351 01352 // Compare surface normals 01353 if (dbl_eq(angle_vec_vec(pln_1_norm, pln_2_norm), 0.0)) 01354 *orien = AGT_SAME_DIR; 01355 else 01356 *orien = AGT_OPP_DIR; 01357 } 01358 01359 } 01360 01361 else { 01362 01363 if (status) 01364 *status = 0; 01365 01366 if (side) 01367 *side = AGT_CROSS; 01368 01369 distance = 0.0; 01370 01371 } 01372 01373 return (distance); 01374 } 01375 01376 01377 01378 //*************************************************************************** 01379 // Intersections 01380 //*************************************************************************** 01381 CubitStatus AnalyticGeometryTool::int_ln_pln( double ln_orig[3], 01382 double ln_vec[3], 01383 double pln_orig[3], 01384 double pln_norm[3], 01385 double int_pnt[3] ) 01386 { 01387 double denom; 01388 double t; 01389 01390 // Set parametric eqns of line equal to parametric eqn of plane & solve 01391 // for t 01392 denom = pln_norm[0]*ln_vec[0] + pln_norm[1]*ln_vec[1] + 01393 pln_norm[2]*ln_vec[2]; 01394 01395 if (dbl_eq(denom, 0.0)) 01396 return CUBIT_FAILURE; 01397 01398 t = (pln_norm[0]*(pln_orig[0]-ln_orig[0]) + 01399 pln_norm[1]*(pln_orig[1]-ln_orig[1]) + 01400 pln_norm[2]*(pln_orig[2]-ln_orig[2]))/denom; 01401 01402 // Substitute t back into equations of line to get xyz 01403 int_pnt[0] = ln_orig[0] + ln_vec[0]*t; 01404 int_pnt[1] = ln_orig[1] + ln_vec[1]*t; 01405 int_pnt[2] = ln_orig[2] + ln_vec[2]*t; 01406 01407 return CUBIT_SUCCESS; 01408 } 01409 01410 int AnalyticGeometryTool::int_ln_ln( double p1[3], double v1[3], 01411 double p2[3], double v2[3], 01412 double int_pnt1[3], double int_pnt2[3] ) 01413 { 01414 double norm[3]; 01415 double pln1_norm[3]; 01416 double pln2_norm[3]; 01417 01418 // Cross the two vectors to get a normal vector 01419 cross_vec(v1, v2, norm); 01420 01421 if (dbl_eq(mag_vec(norm), 0.0)) 01422 return 0; 01423 01424 // Cross v2 & normal to get normal to plane 2 01425 cross_vec(v2, norm, pln2_norm); 01426 01427 // Find intersection of pln2_norm and vector 1 - this is int_pnt1 01428 int_ln_pln(p1, v1, p2, pln2_norm, int_pnt1); 01429 01430 // Cross v1 & normal to get normal to plane 1 01431 cross_vec(v1, norm, pln1_norm); 01432 01433 // Find intersection of pln2_norm and vector 1 - this is int_pnt2 01434 int_ln_pln(p2, v2, p1, pln1_norm, int_pnt2); 01435 01436 // Check to see if the intersection points are the same & return 01437 if (pnt_eq(int_pnt1, int_pnt2)) 01438 return 1; 01439 else 01440 return 2; 01441 } 01442 01443 01444 int AnalyticGeometryTool::int_pnt_pln( double pnt[3], 01445 double pln_orig[3], 01446 double pln_norm[3], 01447 double pln_int[3] ) 01448 { 01449 // Calculate line plane intersection w/plane normal as line vector 01450 int_ln_pln(pnt, pln_norm, pln_orig, pln_norm, pln_int); 01451 01452 // Check to see if point is on the plane 01453 if (pnt_eq(pln_int, pnt)) 01454 return 1; 01455 else 01456 return 0; 01457 } 01458 01459 01460 01461 //*************************************************************************** 01462 // Comparison/Containment Tests 01463 //*************************************************************************** 01464 CubitBoolean AnalyticGeometryTool::is_vec_par( double vec_1[3], 01465 double vec_2[3] ) 01466 { 01467 double cross[3]; 01468 01469 // Get cross product & see if its magnitude is zero 01470 cross_vec(vec_1, vec_2, cross); 01471 01472 if (dbl_eq(mag_vec(cross), 0.0)) 01473 return CUBIT_TRUE; 01474 else 01475 return CUBIT_FALSE; 01476 } 01477 01478 CubitBoolean AnalyticGeometryTool::is_vec_perp( double vec_1[3],double vec_2[3]) 01479 { 01480 // Check angle between vectors 01481 if (dbl_eq(angle_vec_vec(vec_1, vec_2), AGT_PI_DIV_2)) 01482 return CUBIT_TRUE; 01483 else 01484 return CUBIT_FALSE; 01485 } 01486 01487 CubitBoolean AnalyticGeometryTool::is_vecs_same_dir( double vec_1[3], 01488 double vec_2[3] ) 01489 { 01490 // Check to see if angle between vectors can be considered zero 01491 if (dbl_eq(angle_vec_vec(vec_1, vec_2), 0.0)) 01492 return CUBIT_TRUE; 01493 else 01494 return CUBIT_FALSE; 01495 } 01496 01497 01498 CubitBoolean AnalyticGeometryTool::is_pnt_on_ln( double pnt[3], 01499 double ln_orig[3], 01500 double ln_vec[3] ) 01501 { 01502 double vec[3]; 01503 01504 // Compare pnt and line origin 01505 if (pnt_eq(pnt, ln_orig)) 01506 return CUBIT_TRUE; 01507 01508 // Get a vector from line origin to the point 01509 get_vec(ln_orig, pnt, vec); 01510 01511 // If this vector is parallel with line vector, point is on the line 01512 if (is_vec_par(vec, ln_vec)) 01513 return CUBIT_TRUE; 01514 else 01515 return CUBIT_FALSE; 01516 } 01517 01518 CubitBoolean AnalyticGeometryTool::is_pnt_on_ln_seg( double pnt[3], 01519 double end1[3], 01520 double end2[3] ) 01521 { 01522 // METHOD: 01523 // o Use parametric equations of line 01524 // 01525 // x = x1 + t(x2 - x1) 01526 // y = y1 + t(y2 - y1) 01527 // z = z1 + t(z2 - z1) 01528 // 01529 // o Note: two other method's were considered: 01530 // 1) Comparing sum of distance of point to both end points to the 01531 // line length. 01532 // 2) Checking to see if area of a triangle with the vertices is zero 01533 // 01534 // Using parametric equations is more efficient in many cases. 01535 double t1 = 0.0, 01536 t2 = 0.0, 01537 t3 = 0.0, 01538 neg_range, 01539 pos_range; 01540 01541 unsigned short flg1 = 0, 01542 flg2 = 0, 01543 flg3 = 0; 01544 01545 neg_range = 0.0 - agtEpsilon; 01546 pos_range = 1.0 + agtEpsilon; 01547 01548 if (fabs(end2[0] - end1[0]) < agtEpsilon) 01549 { 01550 if (fabs(pnt[0] - end1[0]) < agtEpsilon) 01551 flg1 = 1; 01552 else 01553 return CUBIT_FALSE; 01554 } 01555 else 01556 { 01557 t1 = (pnt[0] - end1[0])/(end2[0] - end1[0]); 01558 01559 if (t1<neg_range || t1>pos_range) 01560 return CUBIT_FALSE; 01561 } 01562 01563 if (fabs(end2[1] - end1[1]) < agtEpsilon) 01564 { 01565 if (fabs(pnt[1] - end1[1]) < agtEpsilon) 01566 flg2 = 1; 01567 else 01568 return CUBIT_FALSE; 01569 } 01570 else 01571 { 01572 t2 = (pnt[1] - end1[1])/(end2[1] - end1[1]); 01573 01574 if (t2<neg_range || t2>pos_range) 01575 return CUBIT_FALSE; 01576 } 01577 01578 if (fabs(end2[2] - end1[2]) < agtEpsilon) 01579 { 01580 if (fabs(pnt[2] - end1[2]) < agtEpsilon) 01581 flg3 = 1; 01582 else 01583 return CUBIT_FALSE; 01584 } 01585 else 01586 { 01587 t3 = (pnt[2] - end1[2])/(end2[2] - end1[2]); 01588 01589 if (t3<neg_range || t3>pos_range) 01590 return CUBIT_FALSE; 01591 } 01592 01593 // If any 2 flags are 1, point is on the line, 01594 // otherwise, check remaining T's for equality 01595 01596 if (flg1) 01597 { 01598 // Here, flg1 = 1 01599 01600 if (flg2) 01601 { 01602 // Here, flg1 = 1 01603 // Here, flg2 = 1 01604 return CUBIT_TRUE; 01605 } 01606 else 01607 { 01608 // Here, flg1 = 1 01609 // Here, flg2 = 0 01610 01611 if (flg3) 01612 // Here, flg1 = 1 01613 // Here, flg2 = 0 01614 // Here, flg3 = 1 01615 return CUBIT_TRUE; 01616 else 01617 { 01618 // Here, flg1 = 1 01619 // Here, flg2 = 0 01620 // Here, flg3 = 0 01621 if (dbl_eq(t2, t3)) 01622 return CUBIT_TRUE; 01623 else 01624 return CUBIT_FALSE; 01625 } 01626 } 01627 } 01628 else 01629 { 01630 // Here, flg1 = 0 01631 if (flg2) 01632 { 01633 // Here, flg1 = 0 01634 // Here, flg2 = 1 01635 if (flg3) 01636 return CUBIT_TRUE; 01637 // Here, flg1 = 0 01638 // Here, flg2 = 1 01639 // Here, flg3 = 1 01640 else 01641 { 01642 // Here, flg1 = 0 01643 // Here, flg2 = 1 01644 // Here, flg3 = 0 01645 if (dbl_eq(t1, t3)) 01646 return CUBIT_TRUE; 01647 else 01648 return CUBIT_FALSE; 01649 } 01650 } 01651 else 01652 { 01653 // Here, flg1 = 0 01654 // Here, flg2 = 0 01655 if (flg3) 01656 { 01657 // Here, flg1 = 0 01658 // Here, flg2 = 0 01659 // Here, flg3 = 1 01660 if (dbl_eq(t1, t2)) 01661 return CUBIT_TRUE; 01662 else 01663 return CUBIT_FALSE; 01664 } 01665 else 01666 { 01667 // Here, flg1 = 0 01668 // Here, flg2 = 0 01669 // Here, flg3 = 0 01670 if (dbl_eq(t1, t2) && dbl_eq(t1, t3)) 01671 return CUBIT_TRUE; 01672 else 01673 return CUBIT_FALSE; 01674 } 01675 } 01676 } 01677 01678 // This would be a programmer's error if we got to this point 01679 // return CUBIT_FALSE; 01680 } 01681 01682 CubitBoolean AnalyticGeometryTool::is_pnt_on_pln( double pnt[3], 01683 double pln_orig[3], 01684 double pln_norm[3] ) 01685 { 01686 double result; 01687 01688 // See if point satisfies parametric equation of plane 01689 01690 result = pln_norm[0] * (pnt[0] - pln_orig[0]) + 01691 pln_norm[1] * (pnt[1] - pln_orig[1]) + 01692 pln_norm[2] * (pnt[2] - pln_orig[2]); 01693 01694 if (dbl_eq(result, 0.0)) 01695 return CUBIT_TRUE; 01696 else 01697 return CUBIT_FALSE; 01698 } 01699 01700 CubitBoolean AnalyticGeometryTool::is_ln_on_pln( double ln_orig[3], 01701 double ln_vec[3], 01702 double pln_orig[3], 01703 double pln_norm[3] ) 01704 { 01705 01706 // Check to see if line origin is on the plane. If so, check to see if 01707 // line vector is perpendicular to plane normal. 01708 01709 if (is_pnt_on_pln(ln_orig, pln_orig, pln_norm) && 01710 is_vec_perp(ln_vec, pln_norm)) 01711 return CUBIT_TRUE; 01712 else 01713 return CUBIT_FALSE; 01714 } 01715 01716 01717 01718 CubitBoolean AnalyticGeometryTool::is_pln_on_pln( double pln_orig1[3], 01719 double pln_norm1[3], 01720 double pln_orig2[3], 01721 double pln_norm2[3] ) 01722 { 01723 // If 1st plane origin is on the 2nd plane and the normals are 01724 // parallel they are coincident 01725 if( is_vec_par( pln_norm1, pln_norm2 ) && 01726 is_pnt_on_pln( pln_orig1, pln_orig2, pln_norm2 ) ) 01727 return CUBIT_TRUE; 01728 else 01729 return CUBIT_FALSE; 01730 } 01731 01732 //*************************************************************************** 01733 // Arcs/Circles 01734 //*************************************************************************** 01735 void AnalyticGeometryTool::setup_arc( double vec_1[3], double vec_2[3], 01736 double origin[3], double start_angle, 01737 double end_angle, double radius, 01738 AGT_3D_Arc &arc ) 01739 { 01740 copy_pnt( vec_1, arc.Vec1 ); 01741 copy_pnt( vec_2, arc.Vec2 ); 01742 copy_pnt( origin, arc.Origin ); 01743 arc.StartAngle = start_angle; 01744 arc.EndAngle = end_angle; 01745 arc.Radius = radius; 01746 } 01747 01748 void AnalyticGeometryTool::setup_arc( CubitVector& vec_1, CubitVector& vec_2, 01749 CubitVector origin, double start_angle, 01750 double end_angle, double radius, 01751 AGT_3D_Arc &arc ) 01752 { 01753 vec_1.get_xyz( arc.Vec1 ); 01754 vec_2.get_xyz( arc.Vec2 ); 01755 origin.get_xyz( arc.Origin ); 01756 arc.StartAngle = start_angle; 01757 arc.EndAngle = end_angle; 01758 arc.Radius = radius; 01759 } 01760 01761 void AnalyticGeometryTool::get_arc_xyz( AGT_3D_Arc &arc, double param, double pnt[3] ) 01762 { 01763 double Tp; 01764 01765 // Un-normalized parameter 01766 Tp = arc.StartAngle * ( 1.0 - param ) + arc.EndAngle * param; 01767 01768 // Solve for XYZ 01769 pnt[0] = arc.Radius * ( cos( Tp ) * arc.Vec1[0] + 01770 sin( Tp ) * arc.Vec2[0] ) + 01771 arc.Origin[0]; 01772 01773 pnt[1] = arc.Radius * ( cos( Tp ) * arc.Vec1[1] + 01774 sin( Tp ) * arc.Vec2[1] ) + 01775 arc.Origin[1]; 01776 01777 pnt[2] = arc.Radius * ( cos( Tp ) * arc.Vec1[2] + 01778 sin( Tp ) * arc.Vec2[2] ) + 01779 arc.Origin[2]; 01780 } 01781 01782 void AnalyticGeometryTool::get_arc_xyz( AGT_3D_Arc &arc, double param, CubitVector& pnt ) 01783 { 01784 double Tp; 01785 01786 // Un-normalized parameter 01787 Tp = arc.StartAngle * ( 1.0 - param ) + arc.EndAngle * param; 01788 01789 // Solve for XYZ 01790 pnt.x( arc.Radius * ( cos( Tp ) * arc.Vec1[0] + 01791 sin( Tp ) * arc.Vec2[0] ) + 01792 arc.Origin[0] ); 01793 01794 pnt.y( arc.Radius * ( cos( Tp ) * arc.Vec1[1] + 01795 sin( Tp ) * arc.Vec2[1] ) + 01796 arc.Origin[1] ); 01797 01798 pnt.z( arc.Radius * ( cos( Tp ) * arc.Vec1[2] + 01799 sin( Tp ) * arc.Vec2[2] ) + 01800 arc.Origin[2] ); 01801 } 01802 01803 int 01804 AnalyticGeometryTool::get_num_circle_tess_pnts( double radius, 01805 double len_tol ) 01806 { 01807 double cmin, cmax; 01808 01809 double c = 2*CUBIT_PI*radius; // Circumference 01810 01811 // Find the number of points required for the given accuracy. Use 01812 // a bisection method. 01813 int nmin = 8, nmax = 100; 01814 cmin = 2.0*nmin*radius*sin(CUBIT_PI/nmin); // Circumference of circle using segments 01815 cmax = 2.0*nmax*radius*sin(CUBIT_PI/nmax); 01816 01817 if( dbl_eq( cmin, c ) ) 01818 return nmin; 01819 01820 double old_epsilon = set_epsilon( len_tol ); 01821 01822 // Find an n that is more than accurate enough 01823 while( !dbl_eq( cmax, c ) ) 01824 { 01825 nmin = nmax; 01826 nmax = nmin * 10; 01827 cmin = 2.0*nmin*radius*sin(CUBIT_PI/nmin); 01828 cmax = 2.0*nmax*radius*sin(CUBIT_PI/nmax); 01829 } 01830 01831 // Biscect until the minimum number of segments satisfying 01832 // the tolerance is found. 01833 int n; 01834 while( 1 ) 01835 { 01836 n = (nmin + nmax)/2; 01837 double cn = 2.0*n*radius*sin(CUBIT_PI/n); 01838 if( dbl_eq( cn, c ) ) 01839 { 01840 // Go lower 01841 nmax = n; 01842 } 01843 else 01844 { 01845 // Go higher 01846 nmin = n; 01847 } 01848 if( nmax-nmin < 2 ) 01849 break; 01850 } 01851 set_epsilon( old_epsilon ); 01852 01853 return nmax; 01854 } 01855 01856 //*************************************************************************** 01857 // Miscellaneous 01858 //*************************************************************************** 01859 void AnalyticGeometryTool::get_pln_orig_norm( double A, double B, double C, 01860 double D, double pln_orig[3], 01861 double pln_norm[3] ) 01862 { 01863 double x = 0.0, y = 0.0, z = 0.0; 01864 01865 // Try to have origin aligned with one of the principal axes 01866 if( !dbl_eq( C, 0.0 ) ) 01867 z = -D/C; 01868 else if (!dbl_eq( A, 0.0 ) ) 01869 x = -D/A; 01870 else if (!dbl_eq( B, 0.0 ) ) 01871 y = -D/B; 01872 01873 pln_orig[0] = x; 01874 pln_orig[1] = y; 01875 pln_orig[2] = z; 01876 01877 if( pln_norm ) 01878 { 01879 pln_norm[0] = A; 01880 pln_norm[1] = B; 01881 pln_norm[2] = C; 01882 } 01883 } 01884 01885 void AnalyticGeometryTool::get_box_corners( double box_min[3], 01886 double box_max[3], 01887 double c[8][3] ) 01888 { 01889 // Left-Bottom-Front // Left-Top-Front 01890 c[0][0] = box_min[0]; c[1][0] = box_min[0]; 01891 c[0][1] = box_min[1]; c[1][1] = box_max[1]; 01892 c[0][2] = box_max[2]; c[1][2] = box_max[2]; 01893 01894 // Right-Top-Front // Right-Bottom-Front 01895 c[2][0] = box_max[0]; c[3][0] = box_max[0]; 01896 c[2][1] = box_max[1]; c[3][1] = box_min[1]; 01897 c[2][2] = box_max[2]; c[3][2] = box_max[2]; 01898 01899 // Left-Bottom-Back // Left-Top-Back 01900 c[4][0] = box_min[0]; c[5][0] = box_min[0]; 01901 c[4][1] = box_min[1]; c[5][1] = box_max[1]; 01902 c[4][2] = box_min[2]; c[5][2] = box_min[2]; 01903 01904 // Right-Top-Back // Right-Bottom-Back 01905 c[6][0] = box_max[0]; c[7][0] = box_max[0]; 01906 c[6][1] = box_max[1]; c[7][1] = box_min[1]; 01907 c[6][2] = box_min[2]; c[7][2] = box_min[2]; 01908 01909 } 01910 01911 CubitStatus 01912 AnalyticGeometryTool::min_pln_box_int_corners( const CubitPlane& plane, 01913 const CubitBox& box, 01914 int extension_type, 01915 double extension, 01916 CubitVector& p1, CubitVector& p2, 01917 CubitVector& p3, CubitVector& p4, 01918 CubitBoolean silent ) 01919 { 01920 CubitVector box_min = box.minimum(); 01921 CubitVector box_max = box.maximum(); 01922 01923 CubitVector plane_norm = plane.normal(); 01924 01925 double box_min_pnt[3], box_max_pnt[3], pln_norm[3]; 01926 box_min.get_xyz( box_min_pnt ); box_max.get_xyz( box_max_pnt ); 01927 plane_norm.get_xyz( pln_norm ); 01928 01929 double pnt1[3], pnt2[3], pnt3[3], pnt4[3]; 01930 01931 if( min_pln_box_int_corners( pln_norm, plane.coefficient(), 01932 box_min_pnt, box_max_pnt, 01933 extension_type, extension, 01934 pnt1, pnt2, pnt3, pnt4, silent ) == CUBIT_FAILURE ) 01935 return CUBIT_FAILURE; 01936 01937 p1.set( pnt1 ); p2.set( pnt2 ); p3.set( pnt3 ); p4.set( pnt4 ); 01938 01939 return CUBIT_SUCCESS; 01940 } 01941 01942 CubitStatus 01943 AnalyticGeometryTool::min_pln_box_int_corners( CubitVector& vec1, 01944 CubitVector& vec2, 01945 CubitVector& vec3, 01946 CubitVector& box_min, 01947 CubitVector& box_max, 01948 int extension_type, 01949 double extension, 01950 CubitVector& p1, CubitVector& p2, 01951 CubitVector& p3, CubitVector& p4, 01952 CubitBoolean silent ) 01953 { 01954 CubitPlane plane; 01955 if( plane.mk_plane_with_points( vec1, vec2, vec3 ) == CUBIT_FAILURE ) 01956 return CUBIT_FAILURE; 01957 01958 CubitVector plane_norm = plane.normal(); 01959 double coefficient = plane.coefficient(); 01960 01961 double plane_norm3[3]; 01962 double box_min3[3]; 01963 double box_max3[3]; 01964 01965 box_min.get_xyz( box_min3 ); 01966 box_max.get_xyz( box_max3 ); 01967 plane_norm.get_xyz( plane_norm3 ); 01968 01969 double p1_3[3], p2_3[3], p3_3[3], p4_3[3]; 01970 p1.get_xyz( p1_3 ); 01971 p2.get_xyz( p2_3 ); 01972 p3.get_xyz( p3_3 ); 01973 p4.get_xyz( p4_3 ); 01974 01975 if( min_pln_box_int_corners( plane_norm3, coefficient, box_min3, box_max3, 01976 extension_type, extension, p1_3, p2_3, p3_3, p4_3, silent ) == CUBIT_FAILURE ) 01977 return CUBIT_FAILURE; 01978 01979 p1.set( p1_3 ); 01980 p2.set( p2_3 ); 01981 p3.set( p3_3 ); 01982 p4.set( p4_3 ); 01983 01984 return CUBIT_SUCCESS; 01985 } 01986 01987 CubitStatus 01988 AnalyticGeometryTool::min_pln_box_int_corners( double pln_norm[3], 01989 double pln_coeff, 01990 double box_min[3], 01991 double box_max[3], 01992 int extension_type, 01993 double extension, 01994 double p1[3], double p2[3], 01995 double p3[3], double p4[3], 01996 CubitBoolean silent ) 01997 { 01998 int i; 01999 double cubit2pln_mtx[4][4], 02000 pln2cubit_mtx[4][4]; 02001 double pln_orig[3]; 02002 double box_tol = 1e-6; 02003 02004 // Adjust bounding box if it is zero in any direction 02005 double abox_min[3], abox_max[3]; 02006 copy_pnt( box_min, abox_min ); 02007 copy_pnt( box_max, abox_max ); 02008 02009 double x_range = fabs(box_max[0]-box_min[0]); 02010 double y_range = fabs(box_max[1]-box_min[1]); 02011 double z_range = fabs(box_max[2]-box_min[2]); 02012 02013 if( x_range < box_tol || y_range < box_tol || z_range < box_tol ) 02014 { 02015 // Adjust zero length side(s) to maximum range 02016 double adj = CUBIT_MAX((CUBIT_MAX((x_range),(y_range))),(z_range))/2.0; 02017 02018 // Arbitrarily expand box if it is zero in size 02019 if( adj < box_tol ) 02020 adj = 5.0; 02021 02022 if( x_range < box_tol ) 02023 { 02024 abox_min[0] -= adj; 02025 abox_max[0] += adj; 02026 } 02027 if( y_range < box_tol ) 02028 { 02029 abox_min[1] -= adj; 02030 abox_max[1] += adj; 02031 } 02032 if( z_range < box_tol ) 02033 { 02034 abox_min[2] -= adj; 02035 abox_max[2] += adj; 02036 } 02037 } 02038 02039 // Get plane origin 02040 double A = pln_norm[0]; 02041 double B = pln_norm[1]; 02042 double C = pln_norm[2]; 02043 double D = pln_coeff; 02044 get_pln_orig_norm( A, B, C, D, pln_orig ); 02045 02046 // Find intersections of edges with plane. Add to unique array. At most 02047 // there are 6 intersections... 02048 double int_array[6][3]; 02049 int num_int = 0; 02050 num_int = get_plane_bbox_intersections( abox_min, abox_max, pln_orig, pln_norm, 02051 int_array ); 02052 02053 // Adjust so plane intercepts bounding box 02054 if( num_int < 3 ) 02055 { 02056 // Move the plane to the center of the bounding box 02057 double box_cent[3]; 02058 box_cent[0] = (abox_min[0]+abox_max[0])/2.0; 02059 box_cent[1] = (abox_min[1]+abox_max[1])/2.0; 02060 box_cent[2] = (abox_min[2]+abox_max[2])/2.0; 02061 02062 // Get the intersections 02063 num_int = get_plane_bbox_intersections( abox_min, abox_max, box_cent, pln_norm, int_array ); 02064 02065 // Project the points back to the original plane 02066 switch (num_int) 02067 { 02068 case 6: 02069 int_pnt_pln( int_array[5], pln_orig, pln_norm, int_array[5] ); 02070 case 5: 02071 int_pnt_pln( int_array[4], pln_orig, pln_norm, int_array[4] ); 02072 case 4: 02073 int_pnt_pln( int_array[3], pln_orig, pln_norm, int_array[3] ); 02074 case 3: 02075 int_pnt_pln( int_array[2], pln_orig, pln_norm, int_array[2] ); 02076 case 2: 02077 int_pnt_pln( int_array[1], pln_orig, pln_norm, int_array[1] ); 02078 case 1: 02079 int_pnt_pln( int_array[0], pln_orig, pln_norm, int_array[0] ); 02080 } 02081 } 02082 02083 if( num_int == 0 ) 02084 { 02085 if( silent == CUBIT_FALSE ) 02086 PRINT_ERROR( "Plane does not intersect the bounding box\n" 02087 " Can't find 4 corners of plane\n" ); 02088 return CUBIT_FAILURE; 02089 } 02090 if( num_int < 3 ) 02091 { 02092 if( silent == CUBIT_FALSE ) 02093 PRINT_ERROR( "Plane intersects the bounding box at only %d locations\n" 02094 " Can't calculate 4 corners of plane\n", num_int ); 02095 return CUBIT_FAILURE; 02096 } 02097 02098 // Transform pnts to plane coordinate system 02099 double pln_x[3], pln_y[3]; 02100 orth_vecs( pln_norm, pln_x, pln_y ); 02101 vecs_to_mtx( pln_x, pln_y, pln_norm, pln_orig, pln2cubit_mtx ); 02102 inv_trans_mtx( pln2cubit_mtx, cubit2pln_mtx ); 02103 02104 double int_arr_pln[6][3]; 02105 for( i=0; i<num_int; i++ ) 02106 transform_pnt( cubit2pln_mtx, int_array[i], int_arr_pln[i] ); 02107 02108 for(i=0; i<num_int; i++) 02109 { 02110 if( !dbl_eq( int_arr_pln[i][2], 0.0 ) ) 02111 { 02112 if( silent == CUBIT_FALSE ) 02113 PRINT_ERROR( "in AnalyticGeometryTool::min_box_pln_int_corners\n" 02114 " Transform to plane wrong\n" ); 02115 return CUBIT_FAILURE; 02116 } 02117 } 02118 02119 // Place into format for mimimal box calculation 02120 Point2 pt[6]; 02121 for ( i=0; i<num_int; i++ ) 02122 { 02123 pt[i].x = int_arr_pln[i][0]; 02124 pt[i].y = int_arr_pln[i][1]; 02125 } 02126 02127 // Find rectangle with minimal area to surround the points 02128 // (this is definitely overkill esp. for the simple cases.....) 02129 OBBox2 minimal = MinimalBox2( num_int, pt ); 02130 02131 // Strip out results 02132 double old_epsilon = set_epsilon( 1e-10 ); 02133 double centroid[3]; 02134 centroid[0] = minimal.center.x; 02135 centroid[1] = minimal.center.y; 02136 centroid[2] = 0.0; 02137 round_near_val( centroid[0] ); // Makes near -1, 0, 1 values -1, 0, 1 02138 round_near_val( centroid[1] ); 02139 transform_pnt( pln2cubit_mtx, centroid, centroid ); 02140 02141 double x_axis[3]; 02142 x_axis[0] = minimal.axis[0].x; 02143 x_axis[1] = minimal.axis[0].y; 02144 x_axis[2] = 0.0; 02145 round_near_val( x_axis[0] ); 02146 round_near_val( x_axis[1] ); 02147 transform_vec( pln2cubit_mtx, x_axis, x_axis ); 02148 02149 double y_axis[3]; 02150 y_axis[0] = minimal.axis[1].x; 02151 y_axis[1] = minimal.axis[1].y; 02152 y_axis[2] = 0.0; 02153 round_near_val( y_axis[0] ); 02154 round_near_val( y_axis[1] ); 02155 transform_vec( pln2cubit_mtx, y_axis, y_axis ); 02156 02157 set_epsilon( old_epsilon ); 02158 02159 double dist_x; 02160 double dist_y; 02161 double extension_distance = 0.0; 02162 if( extension_type == 1 ) // Percentage (of 1/2 diagonal) 02163 { 02164 double diag_len = sqrt( minimal.extent[0]*minimal.extent[0] 02165 + minimal.extent[1]*minimal.extent[1] ); 02166 extension_distance = diag_len*extension/100.0; 02167 } 02168 else if( extension_type == 2 ) // Absolute distance in x and y 02169 extension_distance = extension; 02170 02171 dist_x = minimal.extent[0] + extension_distance; 02172 dist_y = minimal.extent[1] + extension_distance; 02173 02174 next_pnt( centroid, x_axis, -dist_x, p1 ); 02175 next_pnt( p1, y_axis, -dist_y, p1 ); 02176 02177 next_pnt( centroid, x_axis, -dist_x, p2 ); 02178 next_pnt( p2, y_axis, dist_y, p2 ); 02179 02180 next_pnt( centroid, x_axis, dist_x, p3 ); 02181 next_pnt( p3, y_axis, dist_y, p3 ); 02182 02183 next_pnt( centroid, x_axis, dist_x, p4 ); 02184 next_pnt( p4, y_axis, -dist_y, p4 ); 02185 02186 return CUBIT_SUCCESS; 02187 } 02188 02189 int AnalyticGeometryTool::get_plane_bbox_intersections( double box_min[3], 02190 double box_max[3], 02191 double pln_orig[3], 02192 double pln_norm[3], 02193 double int_array[6][3]) 02194 { 02195 // Fill in an array with all 8 box corners 02196 double corner[8][3]; 02197 get_box_corners( box_min, box_max, corner ); 02198 02199 // Get 12 edges of the box 02200 double ln_start[12][3], ln_end[12][3]; 02201 copy_pnt( corner[0], ln_start[0] ); copy_pnt( corner[1], ln_end[0] ); 02202 copy_pnt( corner[1], ln_start[1] ); copy_pnt( corner[2], ln_end[1] ); 02203 copy_pnt( corner[2], ln_start[2] ); copy_pnt( corner[3], ln_end[2] ); 02204 copy_pnt( corner[3], ln_start[3] ); copy_pnt( corner[0], ln_end[3] ); 02205 copy_pnt( corner[4], ln_start[4] ); copy_pnt( corner[5], ln_end[4] ); 02206 copy_pnt( corner[5], ln_start[5] ); copy_pnt( corner[6], ln_end[5] ); 02207 copy_pnt( corner[6], ln_start[6] ); copy_pnt( corner[7], ln_end[6] ); 02208 copy_pnt( corner[7], ln_start[7] ); copy_pnt( corner[4], ln_end[7] ); 02209 copy_pnt( corner[0], ln_start[8] ); copy_pnt( corner[4], ln_end[8] ); 02210 copy_pnt( corner[1], ln_start[9] ); copy_pnt( corner[5], ln_end[9] ); 02211 copy_pnt( corner[2], ln_start[10] ); copy_pnt( corner[6], ln_end[10] ); 02212 copy_pnt( corner[3], ln_start[11] ); copy_pnt( corner[7], ln_end[11] ); 02213 02214 double ln_vec[3]; 02215 double int_pnt[3]; 02216 int num_int = 0; 02217 int i, j, found; 02218 for( i=0; i<12; i++ ) 02219 { 02220 get_vec_unit( ln_start[i], ln_end[i], ln_vec ); 02221 if( int_ln_pln( ln_start[i], ln_vec, pln_orig, pln_norm, int_pnt ) ) 02222 { 02223 // Only add if on the bounded line segment 02224 if( is_pnt_on_ln_seg( int_pnt, ln_start[i], ln_end[i] ) ) 02225 { 02226 // Only add if unique 02227 found = 0; 02228 for( j=0; j<num_int; j++ ) 02229 { 02230 if( pnt_eq( int_pnt, int_array[j] ) ) 02231 { 02232 found = 1; 02233 break; 02234 } 02235 } 02236 if( !found ) 02237 { 02238 copy_pnt( int_pnt, int_array[num_int] ); 02239 num_int++; 02240 } 02241 } 02242 } 02243 } 02244 return num_int; 02245 } 02246 02247 CubitStatus 02248 AnalyticGeometryTool::get_tight_bounding_box( DLIList<CubitVector*> &point_list, 02249 CubitVector ¢er, 02250 CubitVector axes[3], 02251 CubitVector &extension ) 02252 { 02253 int num_pnts = point_list.size(); 02254 if( num_pnts == 0 ) 02255 return CUBIT_FAILURE; 02256 Point3 *pnt_arr = new Point3[num_pnts]; 02257 02258 int i; 02259 point_list.reset(); 02260 CubitVector *vec; 02261 for( i=0; i<num_pnts; i++ ) 02262 { 02263 vec = point_list.get_and_step(); 02264 //GfxPreview::draw_point( vec, 3 ); 02265 02266 pnt_arr[i].x = vec->x(); 02267 pnt_arr[i].y = vec->y(); 02268 pnt_arr[i].z = vec->z(); 02269 } 02270 02271 OBBox3 minimal = MinimalBox3 (point_list.size(), pnt_arr); 02272 02273 //PRINT_INFO( "MinBox center = %lf, %lf, %lf\n", minimal.center.x, minimal.center.y, minimal.center.z ); 02274 //PRINT_INFO( "MinBox axis 1 = %lf, %lf, %lf\n", minimal.axis[0].x, minimal.axis[0].y, minimal.axis[0].z ); 02275 //PRINT_INFO( "MinBox axis 2 = %lf, %lf, %lf\n", minimal.axis[1].x, minimal.axis[1].y, minimal.axis[1].z ); 02276 //PRINT_INFO( "MinBox axis 3 = %lf, %lf, %lf\n", minimal.axis[2].x, minimal.axis[2].y, minimal.axis[2].z ); 02277 //PRINT_INFO( "MinBox extent = %lf, %lf, %lf\n", minimal.extent[0], minimal.extent[1], minimal.extent[2] ); 02278 02279 center.set(minimal.center.x, minimal.center.y, minimal.center.z); 02280 axes[0].set(minimal.axis[0].x, minimal.axis[0].y, minimal.axis[0].z); 02281 axes[1].set(minimal.axis[1].x, minimal.axis[1].y, minimal.axis[1].z); 02282 axes[2].set(minimal.axis[2].x, minimal.axis[2].y, minimal.axis[2].z); 02283 extension.set(minimal.extent[0], minimal.extent[1], minimal.extent[2]); 02284 02285 delete [] pnt_arr; 02286 02287 return CUBIT_SUCCESS; 02288 } 02289 02290 CubitStatus 02291 AnalyticGeometryTool::get_tight_bounding_box( DLIList<CubitVector*> &point_list, 02292 CubitVector& p1, CubitVector& p2, 02293 CubitVector& p3, CubitVector& p4, 02294 CubitVector& p5, CubitVector& p6, 02295 CubitVector& p7, CubitVector& p8) 02296 { 02297 int num_pnts = point_list.size(); 02298 if( num_pnts == 0 ) 02299 return CUBIT_FAILURE; 02300 Point3 *pnt_arr = new Point3[num_pnts]; 02301 02302 int i; 02303 point_list.reset(); 02304 CubitVector *vec; 02305 for( i=0; i<num_pnts; i++ ) 02306 { 02307 vec = point_list.get_and_step(); 02308 02309 pnt_arr[i].x = vec->x(); 02310 pnt_arr[i].y = vec->y(); 02311 pnt_arr[i].z = vec->z(); 02312 } 02313 02314 OBBox3 minimal = MinimalBox3 (point_list.size(), pnt_arr); 02315 02316 //PRINT_INFO( "MinBox center = %lf, %lf, %lf\n", minimal.center.x, minimal.center.y, minimal.center.z ); 02317 //PRINT_INFO( "MinBox axis 1 = %lf, %lf, %lf\n", minimal.axis[0].x, minimal.axis[0].y, minimal.axis[0].z ); 02318 //PRINT_INFO( "MinBox axis 2 = %lf, %lf, %lf\n", minimal.axis[1].x, minimal.axis[1].y, minimal.axis[1].z ); 02319 //PRINT_INFO( "MinBox axis 3 = %lf, %lf, %lf\n", minimal.axis[2].x, minimal.axis[2].y, minimal.axis[2].z ); 02320 //PRINT_INFO( "MinBox extent = %lf, %lf, %lf\n", minimal.extent[0], minimal.extent[1], minimal.extent[2] ); 02321 02322 CubitVector center(minimal.center.x, minimal.center.y, minimal.center.z); 02323 CubitVector x(minimal.axis[0].x, minimal.axis[0].y, minimal.axis[0].z); 02324 CubitVector y(minimal.axis[1].x, minimal.axis[1].y, minimal.axis[1].z); 02325 CubitVector z(minimal.axis[2].x, minimal.axis[2].y, minimal.axis[2].z); 02326 CubitVector extent(minimal.extent[0], minimal.extent[1], minimal.extent[2]); 02327 02328 center.next_point( -x, extent.x(), p1 ); p1.next_point( -y, extent.y(), p1 ); 02329 p1.next_point( z, extent.z(), p1 ); 02330 02331 center.next_point( -x, extent.x(), p2 ); p2.next_point( y, extent.y(), p2 ); 02332 p2.next_point( z, extent.z(), p2 ); 02333 02334 center.next_point( x, extent.x(), p3 ); p3.next_point( y, extent.y(), p3 ); 02335 p3.next_point( z, extent.z(), p3 ); 02336 02337 center.next_point( x, extent.x(), p4 ); p4.next_point( -y, extent.y(), p4 ); 02338 p4.next_point( z, extent.z(), p4 ); 02339 02340 center.next_point( -x, extent.x(), p5 ); p5.next_point( -y, extent.y(), p5 ); 02341 p5.next_point( -z, extent.z(), p5 ); 02342 02343 center.next_point( -x, extent.x(), p6 ); p6.next_point( y, extent.y(), p6 ); 02344 p6.next_point( -z, extent.z(), p6 ); 02345 02346 center.next_point( x, extent.x(), p7 ); p7.next_point( y, extent.y(), p7 ); 02347 p7.next_point( -z, extent.z(), p7 ); 02348 02349 center.next_point( x, extent.x(), p8 ); p8.next_point( -y, extent.y(), p8 ); 02350 p8.next_point( -z, extent.z(), p8 ); 02351 02352 delete [] pnt_arr; 02353 02354 return CUBIT_SUCCESS; 02355 } 02356 02357 CubitStatus 02358 AnalyticGeometryTool::min_cyl_box_int( double radius, 02359 CubitVector& axis, 02360 CubitVector& center, 02361 CubitBox& box, 02362 int extension_type, 02363 double extension, 02364 CubitVector &start, 02365 CubitVector &end, 02366 int num_tess_pnts ) 02367 02368 { 02369 CubitVector box_min = box.minimum(); 02370 CubitVector box_max = box.maximum(); 02371 02372 double box_min_pnt[3], box_max_pnt[3], axis_vec[3], center_pnt[3]; 02373 box_min.get_xyz( box_min_pnt ); box_max.get_xyz( box_max_pnt ); 02374 axis.get_xyz( axis_vec ); center.get_xyz( center_pnt ); 02375 02376 double start_pnt[3], end_pnt[3]; 02377 02378 if( min_cyl_box_int( radius, axis_vec, center_pnt, 02379 box_min_pnt, box_max_pnt, 02380 extension_type, extension, 02381 start_pnt, end_pnt, num_tess_pnts ) 02382 == CUBIT_FAILURE ) 02383 return CUBIT_FAILURE; 02384 02385 start.set( start_pnt ); end.set( end_pnt ); 02386 02387 return CUBIT_SUCCESS; 02388 } 02389 02390 CubitStatus 02391 AnalyticGeometryTool::min_cyl_box_int( double radius, double axis[3], 02392 double center[3], 02393 double box_min[3], double box_max[3], 02394 int extension_type, double extension, 02395 double start[3], double end[3], 02396 int num_tess_pnts ) 02397 { 02398 double cyl_z[3]; 02399 unit_vec( axis, cyl_z ); 02400 02401 //PRINT_INFO( "Axis = %f, %f, %f\n", cyl_z[0], cyl_z[1], cyl_z[2] ); 02402 //PRINT_INFO( "Center = %f, %f, %f\n", center[0], center[1], center[2] ); 02403 02404 // Find transformation matrix to take a point into cylinder's 02405 // coordinate system 02406 double cubit2cyl_mtx[4][4], cyl2cubit_mtx[4][4]; 02407 double cyl_x[3], cyl_y[3]; 02408 orth_vecs( cyl_z, cyl_x, cyl_y ); 02409 vecs_to_mtx( cyl_x, cyl_y, cyl_z, center, cyl2cubit_mtx ); 02410 inv_trans_mtx( cyl2cubit_mtx, cubit2cyl_mtx ); 02411 02412 // Setup the circle 02413 double vec_1[3], vec_2[3]; 02414 orth_vecs( cyl_z, vec_1, vec_2 ); 02415 AGT_3D_Arc arc; 02416 setup_arc( vec_1, vec_2, center, 0.0, 2.0 * CUBIT_PI, radius, arc ); 02417 02418 // Setup the planes of the box 02419 double pln_norm[6][3], pln_orig[6][3]; 02420 // Front 02421 pln_orig[0][0] = 0.0; pln_orig[0][1] = 0.0; pln_orig[0][2] = box_max[2]; 02422 pln_norm[0][0] = 0.0; pln_norm[0][1] = 0.0; pln_norm[0][2] = 1.0; 02423 // Left 02424 pln_orig[1][0] = box_min[0]; pln_orig[1][1] = 0.0; pln_orig[1][2] = 0.0; 02425 pln_norm[1][0] = -1.0; pln_norm[1][1] = 0.0; pln_norm[1][2] = 0.0; 02426 // Top 02427 pln_orig[2][0] = 0.0; pln_orig[2][1] = box_max[1]; pln_orig[2][2] = 0.0; 02428 pln_norm[2][0] = 0.0; pln_norm[2][1] = 1.0; pln_norm[2][2] = 0.0; 02429 // Right 02430 pln_orig[3][0] = box_max[0]; pln_orig[3][1] = 0.0; pln_orig[3][2] = 0.0; 02431 pln_norm[3][0] = 1.0; pln_norm[3][1] = 0.0; pln_norm[3][2] = 0.0; 02432 // Bottom 02433 pln_orig[4][0] = 0.0; pln_orig[4][1] = box_min[1]; pln_orig[4][2] = 0.0; 02434 pln_norm[4][0] = 0.0; pln_norm[4][1] = -1.0; pln_norm[4][2] = 0.0; 02435 // Back 02436 pln_orig[5][0] = 0.0; pln_orig[5][1] = 0.0; pln_orig[5][2] = box_min[2]; 02437 pln_norm[5][0] = 0.0; pln_norm[5][1] = 0.0; pln_norm[5][2] = -1.0; 02438 02439 double z; // Intersection along cylinder's axis 02440 double min_z = CUBIT_DBL_MAX, max_z = -CUBIT_DBL_MAX; 02441 02442 double t = 0.0, dt; 02443 dt = 1.0/(double)num_tess_pnts; 02444 double pnt[3]; 02445 double int_pnt[3]; 02446 double box_tol = 1e-14; 02447 double box_min_0 = box_min[0]-box_tol; 02448 double box_min_1 = box_min[1]-box_tol; 02449 double box_min_2 = box_min[2]-box_tol; 02450 double box_max_0 = box_max[0]+box_tol; 02451 double box_max_1 = box_max[1]+box_tol; 02452 double box_max_2 = box_max[2]+box_tol; 02453 02454 int i,j; 02455 for( i=0; i<num_tess_pnts; i++ ) 02456 { 02457 get_arc_xyz( arc, t, pnt ); 02458 02459 for( j=0; j<6; j++ ) 02460 { 02461 // Evaluate the intersection at this point 02462 if( int_ln_pln( pnt, cyl_z, pln_orig[j], pln_norm[j], int_pnt ) 02463 == CUBIT_FAILURE ) 02464 continue; 02465 02466 // Throw-out if intersection not on physical box 02467 if( int_pnt[0] < box_min_0 || int_pnt[1] < box_min_1 || 02468 int_pnt[2] < box_min_2 || int_pnt[0] > box_max_0 || 02469 int_pnt[1] > box_max_1 || int_pnt[2] > box_max_2 ) 02470 continue; 02471 02472 // Find min/max cylinder z on box so far 02473 // z-distance (in cylinder coordinate system) 02474 z = cubit2cyl_mtx[0][2]*int_pnt[0] + cubit2cyl_mtx[1][2]*int_pnt[1] + 02475 cubit2cyl_mtx[2][2]*int_pnt[2] + cubit2cyl_mtx[3][2]; 02476 02477 if( z < min_z ) min_z = z; 02478 if( z > max_z ) max_z = z; 02479 02480 } 02481 02482 t += dt; 02483 02484 } 02485 02486 // Check the 8 corners of the box - they are likely min/max's. 02487 double box_corners[8][3]; 02488 get_box_corners( box_min, box_max, box_corners ); 02489 for( i=0; i<8; i++ ) 02490 { 02491 // Get the corner in the cylinder csys 02492 transform_pnt( cubit2cyl_mtx, box_corners[i], pnt ); 02493 // If the pnt is within the circle's radius, check it's z-coord 02494 // (distance from center) 02495 if( sqrt( pnt[0]*pnt[0] + pnt[1]*pnt[1] ) <= radius+box_tol ) 02496 { 02497 if( pnt[2] < min_z ) min_z = pnt[2]; 02498 if( pnt[2] > max_z ) max_z = pnt[2]; 02499 } 02500 } 02501 02502 if( min_z == CUBIT_DBL_MAX || max_z == -CUBIT_DBL_MAX ) 02503 { 02504 PRINT_ERROR( "Unable to find cylinder/box intersection\n" ); 02505 return CUBIT_FAILURE; 02506 } 02507 02508 if( min_z == max_z ) 02509 { 02510 PRINT_ERROR( "Unable to find cylinder/box intersection\n" ); 02511 return CUBIT_FAILURE; 02512 } 02513 02514 //PRINT_INFO( "Min dist = %f\n", min_z ); 02515 //PRINT_INFO( "Max dist = %f\n", max_z ); 02516 02517 // Find the start and end of the cylinder 02518 next_pnt( center, cyl_z, min_z, start ); 02519 next_pnt( center, cyl_z, max_z, end ); 02520 02521 //PRINT_INFO( "Start = %f, %f, %f\n", start[0], start[1], start[2] ); 02522 //PRINT_INFO( "End = %f, %f, %f\n", end[0], end[1], end[2] ); 02523 02524 // Extend start and end, if necessary 02525 if( extension_type > 0 ) 02526 { 02527 double ext_distance = 0.0; 02528 if( extension_type == 1 ) // percentage 02529 { 02530 double cyl_length = dist_pnt_pnt( start, end ); 02531 ext_distance = extension/100.0 * cyl_length; 02532 } 02533 else 02534 ext_distance = extension; 02535 02536 next_pnt( end, cyl_z, ext_distance, end ); 02537 reverse_vec( cyl_z, cyl_z ); 02538 next_pnt( start, cyl_z, ext_distance, start ); 02539 } 02540 02541 return CUBIT_SUCCESS; 02542 } 02543 02544 // MAGIC SOFTWARE - see .hpp file 02545 // FILE: minbox2.cpp 02546 //--------------------------------------------------------------------------- 02547 double AnalyticGeometryTool::Area (int N, Point2* pt, double angle) 02548 { 02549 double cs = cos(angle), sn = sin(angle); 02550 02551 double umin = +cs*pt[0].x+sn*pt[0].y, umax = umin; 02552 double vmin = -sn*pt[0].x+cs*pt[0].y, vmax = vmin; 02553 for (int i = 1; i < N; i++) 02554 { 02555 double u = +cs*pt[i].x+sn*pt[i].y; 02556 if ( u < umin ) 02557 umin = u; 02558 else if ( u > umax ) 02559 umax = u; 02560 02561 double v = -sn*pt[i].x+cs*pt[i].y; 02562 if ( v < vmin ) 02563 vmin = v; 02564 else if ( v > vmax ) 02565 vmax = v; 02566 } 02567 02568 double area = (umax-umin)*(vmax-vmin); 02569 return area; 02570 } 02571 //--------------------------------------------------------------------------- 02572 void AnalyticGeometryTool::MinimalBoxForAngle (int N, Point2* pt, double angle, 02573 OBBox2& box) 02574 { 02575 double cs = cos(angle), sn = sin(angle); 02576 02577 02578 double umin = +cs*pt[0].x+sn*pt[0].y, umax = umin; 02579 double vmin = -sn*pt[0].x+cs*pt[0].y, vmax = vmin; 02580 for (int i = 1; i < N; i++) 02581 { 02582 double u = +cs*pt[i].x+sn*pt[i].y; 02583 if ( u < umin ) 02584 umin = u; 02585 else if ( u > umax ) 02586 umax = u; 02587 02588 double v = -sn*pt[i].x+cs*pt[i].y; 02589 if ( v < vmin ) 02590 vmin = v; 02591 else if ( v > vmax ) 02592 vmax = v; 02593 } 02594 02595 double umid = 0.5*(umax+umin); 02596 double vmid = 0.5*(vmax+vmin); 02597 box.center.x = umid*cs-vmid*sn; 02598 box.center.y = umid*sn+vmid*cs; 02599 box.axis[0].x = cs; 02600 box.axis[0].y = sn; 02601 box.axis[1].x = -sn; 02602 box.axis[1].y = cs; 02603 box.extent[0] = 0.5*(umax-umin); 02604 box.extent[1] = 0.5*(vmax-vmin); 02605 } 02606 //--------------------------------------------------------------------------- 02607 OBBox2 AnalyticGeometryTool::MinimalBox2 (int N, Point2* pt) 02608 { 02609 OBBox2 box; 02610 02611 // bracket a minimum for angles in [-pi,pi] 02612 double angle, area; 02613 int imin = 0; 02614 double areaMin = Area(N,pt,angleMin); 02615 02616 int i; 02617 for (i = 1; i <= maxPartition; i++) 02618 { 02619 angle = angleMin+i*angleRange/maxPartition; 02620 area = Area(N,pt,angle); 02621 if ( area < areaMin ) 02622 { 02623 imin = i; 02624 areaMin = area; 02625 } 02626 } 02627 02628 double angle0 = angleMin+(imin-1)*angleRange/maxPartition; 02629 double area0 = Area(N,pt,angle0); 02630 double angle1 = angleMin+(imin+1)*angleRange/maxPartition; 02631 double area1 = Area(N,pt,angle1); 02632 02633 // use inverse parabolic interpolation to find the minimum 02634 for (i = 0; i <= invInterp; i++) 02635 { 02636 double angleMid, areaMid; 02637 02638 // test for convergence (do not change these parameters) 02639 const double epsilon = 1e-08, tol = 1e-04; 02640 // const double omtol = 1.0-tol; 02641 if ( fabs(angle1-angle0) <= 2*tol*fabs(angle)+epsilon ) 02642 break; 02643 02644 // compute vertex of interpolating parabola 02645 double dangle0 = angle0-angle, dangle1 = angle1-angle; 02646 double darea0 = area0-area, darea1 = area1-area; 02647 double temp0 = dangle0*darea1, temp1 = dangle1*darea0; 02648 double delta = temp1-temp0; 02649 if ( fabs(delta) < epsilon ) 02650 break; 02651 02652 angleMid = angle+0.5*(dangle1*temp1-dangle0*temp0)/(temp1-temp0); 02653 02654 // update bracket 02655 if ( angleMid < angle ) 02656 { 02657 areaMid = Area(N,pt,angleMid); 02658 if ( areaMid <= area ) 02659 { 02660 angle1 = angle; 02661 area1 = area; 02662 angle = angleMid; 02663 area = areaMid; 02664 } 02665 else 02666 { 02667 angle0 = angleMid; 02668 area0 = areaMid; 02669 } 02670 } 02671 else if ( angleMid > angle ) 02672 { 02673 areaMid = Area(N,pt,angleMid); 02674 if ( areaMid <= area ) 02675 { 02676 angle0 = angle; 02677 area0 = area; 02678 angle = angleMid; 02679 area = areaMid; 02680 } 02681 else 02682 { 02683 angle1 = angleMid; 02684 area1 = areaMid; 02685 } 02686 } 02687 else 02688 { 02689 // bracket middle already vertex of parabola 02690 break; 02691 } 02692 } 02693 02694 MinimalBoxForAngle(N,pt,angle,box); 02695 return box; 02696 } 02697 //--------------------------------------------------------------------------- 02698 02699 #ifdef MINBOX2_TEST 02700 02701 #include <stdlib.h> 02702 02703 void main () 02704 { 02705 const int N = 128; 02706 Point2 pt[N]; 02707 02708 for (int i = 0; i < N; i++) 02709 { 02710 pt[i].x = rand()/double(RAND_MAX); 02711 pt[i].y = rand()/double(RAND_MAX); 02712 } 02713 02714 OBBox2 minimal = MinimalBox2(N,pt); 02715 } 02716 02717 #endif 02718 02719 #if 1 02720 // FILE: minbox3.cpp 02721 //--------------------------------------------------------------------------- 02722 void AnalyticGeometryTool::MatrixToAngleAxis (double** R, double& angle, double axis[3]) 02723 { 02724 // Let (x,y,z) be the unit-length axis and let A be an angle of rotation. 02725 // The rotation matrix is R = I + sin(A)*P + (1-cos(A))*P^2 where 02726 // I is the identity and 02727 // 02728 // +- -+ 02729 // P = | 0 +z -y | 02730 // | -z 0 +x | 02731 // | +y -x 0 | 02732 // +- -+ 02733 // 02734 // Some algebra will show that 02735 // 02736 // cos(A) = (trace(R)-1)/2 and R - R^t = 2*sin(A)*P 02737 // 02738 // In the event that A = pi, R-R^t = 0 which prevents us from extracting 02739 // the axis through P. Instead note that R = I+2*P^2 when A = pi, so 02740 // P^2 = (R-I)/2. The diagonal entries of P^2 are x^2-1, y^2-1, and z^2-1. 02741 // We can solve these for axis (x,y,z). Because the angle is pi, it does 02742 // not matter which sign you choose on the square roots. 02743 02744 double trace = R[0][0]+R[1][1]+R[2][2]; 02745 double cs = 0.5*(trace-1.0); 02746 if ( -1 < cs ) 02747 { 02748 if ( cs < 1 ) 02749 angle = acos(cs); 02750 else 02751 angle = 0; 02752 } 02753 else 02754 { 02755 angle = AGT_PI; 02756 } 02757 02758 axis[0] = R[1][2]-R[2][1]; 02759 axis[1] = R[2][0]-R[0][2]; 02760 axis[2] = R[0][1]-R[1][0]; 02761 double length = sqrt(axis[0]*axis[0]+axis[1]*axis[1]+axis[2]*axis[2]); 02762 const double epsilon = 1e-06; 02763 if ( length > epsilon ) 02764 { 02765 axis[0] /= length; 02766 axis[1] /= length; 02767 axis[2] /= length; 02768 } 02769 else // angle is 0 or pi 02770 { 02771 if ( angle > 1.0 ) // any number strictly between 0 and pi works 02772 { 02773 // angle must be pi 02774 axis[0] = sqrt(0.5*(1.0+R[0][0])); 02775 axis[1] = sqrt(0.5*(1.0+R[1][1])); 02776 axis[2] = sqrt(0.5*(1.0+R[2][2])); 02777 02778 // determine signs of axis components 02779 double test[3]; 02780 test[0] = R[0][0]*axis[0]+R[0][1]*axis[1]+R[0][2]*axis[2]-axis[0]; 02781 test[1] = R[1][0]*axis[0]+R[1][1]*axis[1]+R[1][2]*axis[2]-axis[1]; 02782 test[2] = R[2][0]*axis[0]+R[2][1]*axis[1]+R[2][2]*axis[2]-axis[2]; 02783 length = test[0]*test[0]+test[1]*test[1]+test[2]*test[2]; 02784 if ( length < epsilon ) 02785 return; 02786 02787 axis[1] = -axis[1]; 02788 test[0] = R[0][0]*axis[0]+R[0][1]*axis[1]+R[0][2]*axis[2]-axis[0]; 02789 test[1] = R[1][0]*axis[0]+R[1][1]*axis[1]+R[1][2]*axis[2]-axis[1]; 02790 test[2] = R[2][0]*axis[0]+R[2][1]*axis[1]+R[2][2]*axis[2]-axis[2]; 02791 length = test[0]*test[0]+test[1]*test[1]+test[2]*test[2]; 02792 if ( length < epsilon ) 02793 return; 02794 02795 axis[2] = -axis[2]; 02796 test[0] = R[0][0]*axis[0]+R[0][1]*axis[1]+R[0][2]*axis[2]-axis[0]; 02797 test[1] = R[1][0]*axis[0]+R[1][1]*axis[1]+R[1][2]*axis[2]-axis[1]; 02798 test[2] = R[2][0]*axis[0]+R[2][1]*axis[1]+R[2][2]*axis[2]-axis[2]; 02799 length = test[0]*test[0]+test[1]*test[1]+test[2]*test[2]; 02800 if ( length < epsilon ) 02801 return; 02802 02803 axis[1] = -axis[1]; 02804 test[0] = R[0][0]*axis[0]+R[0][1]*axis[1]+R[0][2]*axis[2]-axis[0]; 02805 test[1] = R[1][0]*axis[0]+R[1][1]*axis[1]+R[1][2]*axis[2]-axis[1]; 02806 test[2] = R[2][0]*axis[0]+R[2][1]*axis[1]+R[2][2]*axis[2]-axis[2]; 02807 length = test[0]*test[0]+test[1]*test[1]+test[2]*test[2]; 02808 if ( length < epsilon ) 02809 return; 02810 } 02811 else 02812 { 02813 // Angle is zero, matrix is the identity, no unique axis, so 02814 // return (1,0,0) for as good a guess as any. 02815 axis[0] = 1.0; 02816 axis[1] = 0.0; 02817 axis[2] = 0.0; 02818 } 02819 } 02820 } 02821 //--------------------------------------------------------------------------- 02822 void AnalyticGeometryTool::AngleAxisToMatrix (double angle, double axis[3], double R[3][3]) 02823 { 02824 double cs = cos(angle), sn = sin(angle); 02825 double length = sqrt(axis[0]*axis[0]+axis[1]*axis[1]+axis[2]*axis[2]); 02826 double x = axis[0]/length; 02827 double y = axis[1]/length; 02828 double z = axis[2]/length; 02829 double omc = 1.0-cs; 02830 double x2 = x*x, y2 = y*y, z2 = z*z; 02831 double xy = x*y, xz = x*z, yz = y*z; 02832 double snx = sn*x, sny = sn*y, snz = sn*z; 02833 02834 R[0][0] = 1.0-omc*(y2+z2); 02835 R[0][1] = +snz+omc*xy; 02836 R[0][2] = -sny+omc*xz; 02837 R[1][0] = -snz+omc*xy; 02838 R[1][1] = 1.0-omc*(x2+z2); 02839 R[1][2] = +snx+omc*yz; 02840 R[2][0] = +sny+omc*xz; 02841 R[2][1] = -snx+omc*yz; 02842 R[2][2] = 1.0-omc*(x2+y2); 02843 } 02844 //--------------------------------------------------------------------------- 02845 double AnalyticGeometryTool::Volume (int N, Point3* pt, double angle[3]) 02846 { 02847 double cs0 = cos(angle[0]), sn0 = sin(angle[0]); 02848 double cs1 = cos(angle[1]), sn1 = sin(angle[1]); 02849 double axis[3] = { cs0*sn1, sn0*sn1, cs1 }; 02850 double rot[3][3]; 02851 AngleAxisToMatrix(angle[2],axis,rot); 02852 02853 double min[3] = 02854 { 02855 rot[0][0]*pt[0].x+rot[1][0]*pt[0].y+rot[2][0]*pt[0].z, 02856 rot[0][1]*pt[0].x+rot[1][1]*pt[0].y+rot[2][1]*pt[0].z, 02857 rot[0][2]*pt[0].x+rot[1][2]*pt[0].y+rot[2][2]*pt[0].z 02858 }; 02859 02860 double max[3] = { min[0], min[1], min[2] }; 02861 02862 for (int i = 1; i < N; i++) 02863 { 02864 double test[3] = 02865 { 02866 rot[0][0]*pt[i].x+rot[1][0]*pt[i].y+rot[2][0]*pt[i].z, 02867 rot[0][1]*pt[i].x+rot[1][1]*pt[i].y+rot[2][1]*pt[i].z, 02868 rot[0][2]*pt[i].x+rot[1][2]*pt[i].y+rot[2][2]*pt[i].z 02869 }; 02870 02871 if ( test[0] < min[0] ) 02872 min[0] = test[0]; 02873 else if ( test[0] > max[0] ) 02874 max[0] = test[0]; 02875 02876 if ( test[1] < min[1] ) 02877 min[1] = test[1]; 02878 else if ( test[1] > max[1] ) 02879 max[1] = test[1]; 02880 02881 if ( test[2] < min[2] ) 02882 min[2] = test[2]; 02883 else if ( test[2] > max[2] ) 02884 max[2] = test[2]; 02885 } 02886 02887 double volume = (max[0]-min[0])*(max[1]-min[1])*(max[2]-min[2]); 02888 return volume; 02889 } 02890 //--------------------------------------------------------------------------- 02891 void AnalyticGeometryTool::MinimalBoxForAngles (int N, Point3* pt, double angle[3], 02892 OBBox3& box) 02893 { 02894 double cs0 = cos(angle[0]), sn0 = sin(angle[0]); 02895 double cs1 = cos(angle[1]), sn1 = sin(angle[1]); 02896 double axis[3] = { cs0*sn1, sn0*sn1, cs1 }; 02897 double rot[3][3]; 02898 AngleAxisToMatrix(angle[2],axis,rot); 02899 02900 double min[3] = 02901 { 02902 rot[0][0]*pt[0].x+rot[1][0]*pt[0].y+rot[2][0]*pt[0].z, 02903 rot[0][1]*pt[0].x+rot[1][1]*pt[0].y+rot[2][1]*pt[0].z, 02904 rot[0][2]*pt[0].x+rot[1][2]*pt[0].y+rot[2][2]*pt[0].z 02905 }; 02906 02907 double max[3] = { min[0], min[1], min[2] }; 02908 02909 for (int i = 1; i < N; i++) 02910 { 02911 double test[3] = 02912 { 02913 rot[0][0]*pt[i].x+rot[1][0]*pt[i].y+rot[2][0]*pt[i].z, 02914 rot[0][1]*pt[i].x+rot[1][1]*pt[i].y+rot[2][1]*pt[i].z, 02915 rot[0][2]*pt[i].x+rot[1][2]*pt[i].y+rot[2][2]*pt[i].z 02916 }; 02917 02918 if ( test[0] < min[0] ) 02919 min[0] = test[0]; 02920 else if ( test[0] > max[0] ) 02921 max[0] = test[0]; 02922 02923 if ( test[1] < min[1] ) 02924 min[1] = test[1]; 02925 else if ( test[1] > max[1] ) 02926 max[1] = test[1]; 02927 02928 if ( test[2] < min[2] ) 02929 min[2] = test[2]; 02930 else if ( test[2] > max[2] ) 02931 max[2] = test[2]; 02932 } 02933 02934 double mid[3] = 02935 { 02936 0.5*(max[0]+min[0]), 0.5*(max[1]+min[1]), 0.5*(max[2]+min[2]) 02937 }; 02938 02939 box.center.x = mid[0]*rot[0][0]+mid[1]*rot[0][1]+mid[2]*rot[0][2]; 02940 box.center.y = mid[0]*rot[1][0]+mid[1]*rot[1][1]+mid[2]*rot[1][2]; 02941 box.center.z = mid[0]*rot[2][0]+mid[1]*rot[2][1]+mid[2]*rot[2][2]; 02942 box.axis[0].x = rot[0][0]; 02943 box.axis[0].y = rot[1][0]; 02944 box.axis[0].z = rot[2][0]; 02945 box.axis[1].x = rot[0][1]; 02946 box.axis[1].y = rot[1][1]; 02947 box.axis[1].z = rot[2][1]; 02948 box.axis[2].x = rot[0][2]; 02949 box.axis[2].y = rot[1][2]; 02950 box.axis[2].z = rot[2][2]; 02951 box.extent[0] = 0.5*(max[0]-min[0]); 02952 box.extent[1] = 0.5*(max[1]-min[1]); 02953 box.extent[2] = 0.5*(max[2]-min[2]); 02954 } 02955 //--------------------------------------------------------------------------- 02956 void AnalyticGeometryTool::GetInterval (double A[3], double D[3], double& tmin, double& tmax) 02957 { 02958 //static const double angle_min[3] = { -AGT_PI, 0.0, 0.0 }; 02959 //static const double angle_max[3] = { AGT_PI, AGT_PI, AGT_PI }; 02960 //The pgCC compiler running on solars and cross-compiling for 02961 //janus has a bug such that it dies if the initialization 02962 //of angle_min is mixed symbolic and literal constants, so 02963 //define a symbolid constant for 0.0. 02964 // -- J.Kraftcheck, 06/05/2001 02965 static const double ZERO = 0.0; 02966 static const double angle_min[3] = { -AGT_PI, ZERO, ZERO }; 02967 static const double angle_max[3] = { AGT_PI, AGT_PI, AGT_PI }; 02968 02969 tmin = -DBL_MAX; 02970 tmax = +DBL_MAX; 02971 02972 for (int i = 0; i < 3; i++) 02973 { 02974 const double epsilon = 1e-08; 02975 double b0 = angle_min[i]-A[i]; 02976 double b1 = angle_max[i]-A[i]; 02977 02978 double inv, tmp; 02979 if ( D[i] > epsilon ) 02980 { 02981 inv = 1.0/D[i]; 02982 tmp = inv*b0; 02983 if ( tmp > tmin ) 02984 tmin = tmp; 02985 tmp = inv*b1; 02986 if ( tmp < tmax ) 02987 tmax = tmp; 02988 } 02989 else if ( D[i] < -epsilon ) 02990 { 02991 inv = 1.0/D[i]; 02992 tmp = inv*b0; 02993 if ( tmp < tmax ) 02994 tmax = tmp; 02995 tmp = inv*b1; 02996 if ( tmp > tmin ) 02997 tmin = tmp; 02998 } 02999 } 03000 03001 if( tmin == -DBL_MAX || tmax == DBL_MAX ) // Added by SRS 10-6-2000 03002 { 03003 //PRINT_WARNING( "tmin/tmax not set\n" ); 03004 tmin = -1.0; 03005 tmax = 1.0; 03006 } 03007 } 03008 //--------------------------------------------------------------------------- 03009 void AnalyticGeometryTool::Combine (double result[3], double A[3], double t, double D[3]) 03010 { 03011 for (int i = 0; i < 3; i++) 03012 result[i] = A[i]+t*D[i]; 03013 } 03014 //--------------------------------------------------------------------------- 03015 double AnalyticGeometryTool::MinimizeOnInterval (int N, Point3* pt, double A[3], double D[3]) 03016 { 03017 // compute intersection of line A+t*D with domain of function 03018 double tmin, tmax; 03019 GetInterval(A,D,tmin,tmax); 03020 double tran = tmax-tmin; 03021 double angle[3]; 03022 03023 if( tran == 0.0 ) // Added by SRS 10-6-2000 03024 tran = 1.0; 03025 03026 // bracket a minimum for angles in [A+tmin*D,A+tmax*D] 03027 double t = 0.0; 03028 double volumeMin = Volume(N,pt,A); 03029 double volume; 03030 03031 const int max_partition = 64; 03032 int i, imin; 03033 for (i = 0, imin = -1; i <= max_partition; i++) 03034 { 03035 t = tmin+i*tran/max_partition; 03036 Combine(angle,A,t,D); 03037 03038 volume = Volume(N,pt,angle); 03039 if ( volume < volumeMin ) 03040 { 03041 imin = i; 03042 volumeMin = volume; 03043 } 03044 } 03045 03046 if ( imin != -1 ) 03047 { 03048 t = tmin+imin*tran/max_partition; 03049 } 03050 else 03051 { 03052 t = 0.0; 03053 03054 // interval in which t=0 lies 03055 imin = int(-tmin*max_partition/tran+0.5); 03056 } 03057 volume = volumeMin; 03058 03059 double t0 = tmin+(imin-1)*tran/max_partition; 03060 Combine(angle,A,t0,D); 03061 double volume0 = Volume(N,pt,angle); 03062 03063 double t1 = tmin+(imin+1)*tran/max_partition; 03064 Combine(angle,A,t1,D); 03065 double volume1 = Volume(N,pt,angle); 03066 03067 // use inverse parabolic interpolation to find the minimum 03068 const int inv_interp = 64; 03069 for (i = 0; i <= inv_interp; i++) 03070 { 03071 double tMid, volumeMid; 03072 03073 // test for convergence (do not change these parameters) 03074 const double epsilon = 1e-08, tol = 1e-04; 03075 // const double omtol = 1.0-tol; 03076 if ( fabs(t1-t0) <= 2*tol*fabs(t)+epsilon ) 03077 break; 03078 03079 // compute vertex of interpolating parabola 03080 double dt0 = t0-t, dt1 = t1-t; 03081 double dvolume0 = volume0-volume, dvolume1 = volume1-volume; 03082 double temp0 = dt0*dvolume1, temp1 = dt1*dvolume0; 03083 double delta = temp1-temp0; 03084 if ( fabs(delta) < epsilon ) 03085 break; 03086 03087 tMid = t+0.5*(dt1*temp1-dt0*temp0)/(temp1-temp0); 03088 03089 // update bracket 03090 if ( tMid < t ) 03091 { 03092 Combine(angle,A,tMid,D); 03093 volumeMid = Volume(N,pt,angle); 03094 if ( volumeMid <= volume ) 03095 { 03096 t1 = t; 03097 volume1 = volume; 03098 t = tMid; 03099 volume = volumeMid; 03100 } 03101 else 03102 { 03103 t0 = tMid; 03104 volume0 = volumeMid; 03105 } 03106 } 03107 else if ( tMid > t ) 03108 { 03109 Combine(angle,A,tMid,D); 03110 volumeMid = Volume(N,pt,angle); 03111 if ( volumeMid <= volume ) 03112 { 03113 t0 = t; 03114 volume0 = volume; 03115 t = tMid; 03116 volume = volumeMid; 03117 } 03118 else 03119 { 03120 t1 = tMid; 03121 volume1 = volumeMid; 03122 } 03123 } 03124 else 03125 { 03126 // bracket middle already vertex of parabola 03127 break; 03128 } 03129 } 03130 03131 Combine(A,A,t,D); 03132 return volume; 03133 } 03134 //--------------------------------------------------------------------------- 03135 double AnalyticGeometryTool::MinimizeOnLattice (int N, Point3* pt, double A[3], int layers, 03136 double thickness) 03137 { 03138 int xmin = 0, ymin = 0, zmin = 0; 03139 double volume = Volume(N,pt,A); 03140 03141 double angle[3]; 03142 for (int z = -layers; z <= layers; z++) 03143 { 03144 angle[2] = A[2]+thickness*z/layers; 03145 for (int y = -layers; y <= layers; y++) 03146 { 03147 angle[1] = A[1]+thickness*y/layers; 03148 for (int x = -layers; x <= layers; x++) 03149 { 03150 angle[0] = A[0]+thickness*x/layers; 03151 03152 double v = Volume(N,pt,angle); 03153 if ( v < volume ) 03154 { 03155 xmin = x; 03156 ymin = y; 03157 zmin = z; 03158 volume = v; 03159 } 03160 } 03161 } 03162 } 03163 03164 A[0] += thickness*xmin/layers; 03165 A[1] += thickness*ymin/layers; 03166 A[2] += thickness*zmin/layers; 03167 03168 return volume; 03169 } 03170 //--------------------------------------------------------------------------- 03171 void AnalyticGeometryTool::InitialGuess (int N, Point3* pt, double angle[3]) 03172 { 03173 int i; 03174 03175 // compute mean of points 03176 double xsum = 0.0f, ysum = 0.0f, zsum = 0.0f;; 03177 for (i = 0; i < N; i++) 03178 { 03179 xsum += pt[i].x; 03180 ysum += pt[i].y; 03181 zsum += pt[i].z; 03182 } 03183 double xmean = xsum/N; 03184 double ymean = ysum/N; 03185 double zmean = zsum/N; 03186 03187 // compute covariances of points 03188 double xxsum = 0.0f, xysum = 0.0f, xzsum = 0.0f; 03189 double yysum = 0.0f, yzsum = 0.0f, zzsum = 0.0f; 03190 for (i = 0; i < N; i++) 03191 { 03192 double dx = pt[i].x - xmean; 03193 double dy = pt[i].y - ymean; 03194 double dz = pt[i].z - zmean; 03195 xxsum += dx*dx; 03196 xysum += dx*dy; 03197 xzsum += dx*dz; 03198 yysum += dy*dy; 03199 yzsum += dy*dz; 03200 zzsum += dz*dz; 03201 } 03202 double xxcov = xxsum/N; 03203 double xycov = xysum/N; 03204 double xzcov = xzsum/N; 03205 double yycov = yysum/N; 03206 double yzcov = yzsum/N; 03207 double zzcov = zzsum/N; 03208 03209 // compute eigenvectors for covariance matrix 03210 mgcEigenD eig(3); 03211 eig.Matrix(0,0) = xxcov; 03212 eig.Matrix(0,1) = xycov; 03213 eig.Matrix(0,2) = xzcov; 03214 eig.Matrix(1,0) = xycov; 03215 eig.Matrix(1,1) = yycov; 03216 eig.Matrix(1,2) = yzcov; 03217 eig.Matrix(2,0) = xzcov; 03218 eig.Matrix(2,1) = yzcov; 03219 eig.Matrix(2,2) = zzcov; 03220 eig.EigenStuff3(); 03221 03222 // Use eigenvectors as the box axes. Eigenmatrix must not have a 03223 // reflection component, thus the check for negative determinant. 03224 const double epsilon = 1e-06; 03225 double** R = (double**)eig.Eigenvector(); 03226 double det = 03227 +R[0][0]*R[1][1]*R[2][2] 03228 +R[0][1]*R[1][2]*R[2][0] 03229 +R[0][2]*R[1][0]*R[2][1] 03230 -R[0][2]*R[1][1]*R[2][0] 03231 -R[0][1]*R[1][0]*R[2][2] 03232 -R[0][0]*R[1][2]*R[2][1]; 03233 if ( det < 0.0 ) 03234 { 03235 R[0][0] = -R[0][0]; 03236 R[1][0] = -R[1][0]; 03237 R[2][0] = -R[2][0]; 03238 } 03239 03240 // extract angles from rotation axis = (cos(u)sin(v),sin(u)sin(v),cos(v)) 03241 double axis[3]; 03242 MatrixToAngleAxis(R,angle[2],axis); 03243 if ( -1+epsilon < axis[2] ) 03244 { 03245 if ( axis[2] < 1-epsilon ) 03246 { 03247 angle[0] = atan2(axis[1],axis[0]); 03248 angle[1] = acos(axis[2]); 03249 } 03250 else 03251 { 03252 angle[0] = 0; 03253 angle[1] = 0; 03254 } 03255 } 03256 else 03257 { 03258 angle[0] = 0; 03259 angle[1] = AGT_PI; 03260 } 03261 } 03262 //--------------------------------------------------------------------------- 03263 OBBox3 AnalyticGeometryTool::MinimalBox3 (int N, Point3* pt) 03264 { 03265 // compute a good initial guess for an oriented bounding box 03266 double angle[3]; 03267 InitialGuess(N,pt,angle); 03268 double oldVolume = Volume(N,pt,angle); 03269 03270 //if initial guess gives angles that are zero, the rest of this code 03271 //can give bounding box that isn't tight. This probably 03272 //isn't the best fix but it works. CDE 4-20-2009 03273 if( angle[0] == 0 ) 03274 angle[0] = 0.5; 03275 if( angle[1] == 0 ) 03276 angle[1] = 0.5; 03277 if( angle[2] == 0 ) 03278 angle[2] = 0.5; 03279 03280 double saveAngle[3] = { angle[0], angle[1], angle[2] }; 03281 03282 // Powell's direction set method 03283 double U[3][3], volume; 03284 const int maxiters = 3*32; 03285 for (int iter = 0; iter < maxiters; iter++) 03286 { 03287 // reset directions to avoid linear dependence degeneration 03288 if ( iter % 3 == 0 ) 03289 { 03290 U[0][0] = 1.0; U[0][1] = 0.0; U[0][2] = 0.0; 03291 U[1][0] = 0.0; U[1][1] = 1.0; U[1][2] = 0.0; 03292 U[2][0] = 0.0; U[2][1] = 0.0; U[2][2] = 1.0; 03293 } 03294 03295 // find minima in specified directions 03296 for (int d = 0; d < 3; d++) 03297 volume = MinimizeOnInterval(N,pt,angle,U[d]); 03298 03299 // estimate a conjugate direction 03300 double conj[3] = 03301 { 03302 angle[0]-saveAngle[0], 03303 angle[1]-saveAngle[1], 03304 angle[2]-saveAngle[2] 03305 }; 03306 double length = sqrt(conj[0]*conj[0]+conj[1]*conj[1]+conj[2]*conj[2]); 03307 if ( length >= 1e-06 ) 03308 { 03309 double invLen = 1.0/length; 03310 conj[0] *= invLen; 03311 conj[1] *= invLen; 03312 conj[2] *= invLen; 03313 03314 // minimize in conjugate direction 03315 volume = MinimizeOnInterval(N,pt,angle,conj); 03316 } 03317 else 03318 { 03319 // Possible local, but not global, minimum. Search nearby for 03320 // a smaller volume. 03321 volume = MinimizeOnLattice(N,pt,angle,2,0.0001); 03322 volume = MinimizeOnLattice(N,pt,angle,2,0.0010); 03323 volume = MinimizeOnLattice(N,pt,angle,2,0.0100); 03324 volume = MinimizeOnLattice(N,pt,angle,2,0.1000); 03325 } 03326 03327 // test for convergence 03328 const double epsilon = 1e-04; 03329 double diff = fabs(volume-oldVolume); 03330 if ( diff <= epsilon ) 03331 { 03332 // Possible local, but not global, minimum. Search nearby for 03333 // a smaller volume. 03334 volume = MinimizeOnLattice(N,pt,angle,2,0.0001); 03335 volume = MinimizeOnLattice(N,pt,angle,2,0.0010); 03336 volume = MinimizeOnLattice(N,pt,angle,2,0.0100); 03337 volume = MinimizeOnLattice(N,pt,angle,2,0.1000); 03338 diff = fabs(volume-oldVolume); 03339 if ( diff <= epsilon ) 03340 break; 03341 } 03342 03343 // cycle the directions and add conjugate direction to list 03344 U[0][0] = U[1][0]; U[0][1] = U[1][1]; U[0][2] = U[1][2]; 03345 U[1][0] = U[2][0]; U[1][1] = U[2][1]; U[1][2] = U[2][2]; 03346 U[2][0] = conj[0]; U[2][1] = conj[1]; U[2][2] = conj[2]; 03347 03348 // set parameters for next pass 03349 oldVolume = volume; 03350 saveAngle[0] = angle[0]; 03351 saveAngle[1] = angle[1]; 03352 saveAngle[2] = angle[2]; 03353 } 03354 03355 OBBox3 box; 03356 MinimalBoxForAngles(N,pt,angle,box); 03357 return box; 03358 } 03359 //--------------------------------------------------------------------------- 03360 03361 #ifdef MINBOX3_TEST 03362 03363 #define RAND (rand()/double(RAND_MAX)) 03364 03365 void main () 03366 { 03367 // build box with axes parallel to coordinate axes 03368 const int N = 16; 03369 const double ex = 1.0; 03370 const double ey = 2.0; 03371 const double ez = 3.0; 03372 Point3 pt[N]; 03373 pt[0].x = -ex; pt[0].y = -ey; pt[0].z = -ez; 03374 pt[1].x = -ex; pt[1].y = +ey; pt[1].z = -ez; 03375 pt[2].x = +ex; pt[2].y = +ey; pt[2].z = -ez; 03376 pt[3].x = +ex; pt[3].y = -ey; pt[3].z = -ez; 03377 pt[4].x = -ex; pt[4].y = -ey; pt[4].z = +ez; 03378 pt[5].x = -ex; pt[5].y = +ey; pt[5].z = +ez; 03379 pt[6].x = +ex; pt[6].y = +ey; pt[6].z = +ez; 03380 pt[7].x = +ex; pt[7].y = -ey; pt[7].z = +ez; 03381 03382 for (int k = 8; k < N; k++) 03383 { 03384 // generate random points inside box to confound initial Gaussian fit 03385 pt[k].x = -ex+2.0*ex*RAND; 03386 pt[k].y = -ey+2.0*ey*RAND; 03387 pt[k].z = -ez+2.0*ez*RAND; 03388 } 03389 03390 double maxNorm = 0.0; 03391 int iMaxNorm = -1; 03392 for (int iter = 0; iter < 1024; iter++) 03393 { 03394 // build arbitrary rotation matrix 03395 double angle = RAND; 03396 double line[3] = { RAND, RAND, RAND }; 03397 double rot[3][3]; 03398 double length = sqrt(line[0]*line[0]+line[1]*line[1]+line[2]*line[2]); 03399 line[0] /= length; 03400 line[1] /= length; 03401 line[2] /= length; 03402 AngleAxisToMatrix(angle,line,rot); 03403 03404 // rotate box 03405 Point3 rpt[N]; 03406 for (int i = 0; i < N; i++) 03407 { 03408 rpt[i].x = rot[0][0]*pt[i].x+rot[0][1]*pt[i].y+rot[0][2]*pt[i].z; 03409 rpt[i].y = rot[1][0]*pt[i].x+rot[1][1]*pt[i].y+rot[1][2]*pt[i].z; 03410 rpt[i].z = rot[2][0]*pt[i].x+rot[2][1]*pt[i].y+rot[2][2]*pt[i].z; 03411 } 03412 03413 OBBox3 minimal = MinimalBox3(N,rpt); 03414 03415 int index[3]; 03416 if ( minimal.extent[0] <= minimal.extent[1] ) 03417 { 03418 if ( minimal.extent[1] <= minimal.extent[2] ) 03419 { 03420 index[0] = 0; 03421 index[1] = 1; 03422 index[2] = 2; 03423 } 03424 else 03425 { 03426 if ( minimal.extent[0] <= minimal.extent[2] ) 03427 { 03428 index[0] = 0; 03429 index[1] = 2; 03430 index[2] = 1; 03431 } 03432 else 03433 { 03434 index[0] = 2; 03435 index[1] = 0; 03436 index[2] = 1; 03437 } 03438 } 03439 } 03440 else 03441 { 03442 if ( minimal.extent[0] <= minimal.extent[2] ) 03443 { 03444 index[0] = 1; 03445 index[1] = 0; 03446 index[2] = 2; 03447 } 03448 else 03449 { 03450 if ( minimal.extent[1] <= minimal.extent[2] ) 03451 { 03452 index[0] = 1; 03453 index[1] = 2; 03454 index[2] = 0; 03455 } 03456 else 03457 { 03458 index[0] = 2; 03459 index[1] = 1; 03460 index[2] = 0; 03461 } 03462 } 03463 } 03464 03465 double dx = ex-minimal.extent[index[0]]; 03466 double dy = ey-minimal.extent[index[1]]; 03467 double dz = ez-minimal.extent[index[2]]; 03468 double norm = sqrt(dx*dx+dy*dy+dz*dz); 03469 if ( norm > maxNorm ) 03470 { 03471 maxNorm = norm; 03472 iMaxNorm = iter; 03473 } 03474 } 03475 } 03476 03477 #endif // MINBOX3_TEST 03478 03479 // FILE: eigen.cpp 03480 //=========================================================================== 03481 // error handling 03482 int mgcEigen::verbose1 = 0; 03483 unsigned mgcEigen::error = 0; 03484 const unsigned mgcEigen::invalid_size = 0x00000001; 03485 const unsigned mgcEigen::allocation_failed = 0x00000002; 03486 const unsigned mgcEigen::ql_exceeded = 0x00000004; 03487 const char* mgcEigen::message[3] = { 03488 "invalid matrix size", 03489 "allocation failed", 03490 "QL algorithm - exceeded maximum iterations" 03491 }; 03492 //--------------------------------------------------------------------------- 03493 void mgcEigen:: 03494 Tridiagonal2 (float** pmat, float* pdiag, float* psubd) 03495 { 03496 // matrix is already tridiagonal 03497 03498 pdiag[0] = pmat[0][0]; 03499 pdiag[1] = pmat[1][1]; 03500 psubd[0] = pmat[0][1]; 03501 psubd[1] = 0; 03502 pmat[0][0] = 1; pmat[0][1] = 0; 03503 pmat[1][0] = 0; pmat[1][1] = 1; 03504 } 03505 //--------------------------------------------------------------------------- 03506 void mgcEigen:: 03507 Tridiagonal3 (float** pmat, float* pdiag, float* psubd) 03508 { 03509 float a = pmat[0][0], b = pmat[0][1], c = pmat[0][2], 03510 d = pmat[1][1], e = pmat[1][2], 03511 f = pmat[2][2]; 03512 03513 pdiag[0] = a; 03514 psubd[2] = 0; 03515 if ( c != 0 ) { 03516 float ell = float(sqrt(b*b+c*c)); 03517 b /= ell; 03518 c /= ell; 03519 float q = 2*b*e+c*(f-d); 03520 pdiag[1] = d+c*q; 03521 pdiag[2] = f-c*q; 03522 psubd[0] = ell; 03523 psubd[1] = e-b*q; 03524 pmat[0][0] = 1; pmat[0][1] = 0; pmat[0][2] = 0; 03525 pmat[1][0] = 0; pmat[1][1] = b; pmat[1][2] = c; 03526 pmat[2][0] = 0; pmat[2][1] = c; pmat[2][2] = -b; 03527 } 03528 else { 03529 pdiag[1] = d; 03530 pdiag[2] = f; 03531 psubd[0] = b; 03532 psubd[1] = e; 03533 pmat[0][0] = 1; pmat[0][1] = 0; pmat[0][2] = 0; 03534 pmat[1][0] = 0; pmat[1][1] = 1; pmat[1][2] = 0; 03535 pmat[2][0] = 0; pmat[2][1] = 0; pmat[2][2] = 1; 03536 } 03537 } 03538 //--------------------------------------------------------------------------- 03539 void mgcEigen:: 03540 Tridiagonal4 (float** pmat, float* pdiag, float* psubd) 03541 { 03542 // save pmatrix M 03543 float 03544 a = pmat[0][0], b = pmat[0][1], c = pmat[0][2], d = pmat[0][3], 03545 e = pmat[1][1], f = pmat[1][2], g = pmat[1][3], 03546 h = pmat[2][2], i = pmat[2][3], 03547 j = pmat[3][3]; 03548 03549 pdiag[0] = a; 03550 psubd[3] = 0; 03551 03552 pmat[0][0] = 1; pmat[0][1] = 0; pmat[0][2] = 0; pmat[0][3] = 0; 03553 pmat[1][0] = 0; 03554 pmat[2][0] = 0; 03555 pmat[3][0] = 0; 03556 03557 if ( c != 0 || d != 0 ) { 03558 float q11, q12, q13; 03559 float q21, q22, q23; 03560 float q31, q32, q33; 03561 03562 // build column Q1 03563 float len = float(sqrt(b*b+c*c+d*d)); 03564 q11 = b/len; 03565 q21 = c/len; 03566 q31 = d/len; 03567 03568 psubd[0] = len; 03569 03570 // compute S*Q1 03571 float v0 = e*q11+f*q21+g*q31; 03572 float v1 = f*q11+h*q21+i*q31; 03573 float v2 = g*q11+i*q21+j*q31; 03574 03575 pdiag[1] = q11*v0+q21*v1+q31*v2; 03576 03577 // build column Q3 = Q1x(S*Q1) 03578 q13 = q21*v2-q31*v1; 03579 q23 = q31*v0-q11*v2; 03580 q33 = q11*v1-q21*v0; 03581 len = float(sqrt(q13*q13+q23*q23+q33*q33)); 03582 if ( len > 0 ) { 03583 q13 /= len; 03584 q23 /= len; 03585 q33 /= len; 03586 03587 // build column Q2 = Q3xQ1 03588 q12 = q23*q31-q33*q21; 03589 q22 = q33*q11-q13*q31; 03590 q32 = q13*q21-q23*q11; 03591 03592 v0 = q12*e+q22*f+q32*g; 03593 v1 = q12*f+q22*h+q32*i; 03594 v2 = q12*g+q22*i+q32*j; 03595 psubd[1] = q11*v0+q21*v1+q31*v2; 03596 pdiag[2] = q12*v0+q22*v1+q32*v2; 03597 psubd[2] = q13*v0+q23*v1+q33*v2; 03598 03599 v0 = q13*e+q23*f+q33*g; 03600 v1 = q13*f+q23*h+q33*i; 03601 v2 = q13*g+q23*i+q33*j; 03602 pdiag[3] = q13*v0+q23*v1+q33*v2; 03603 } 03604 else { // S*Q1 parallel to Q1, choose any valid Q2 and Q3 03605 psubd[1] = 0; 03606 03607 len = q21*q21+q31*q31; 03608 if ( len > 0 ) { 03609 float tmp = q11-1; 03610 q12 = -q21; 03611 q22 = 1+tmp*q21*q21/len; 03612 q32 = tmp*q21*q31/len; 03613 03614 q13 = -q31; 03615 q23 = q32; 03616 q33 = 1+tmp*q31*q31/len; 03617 03618 v0 = q12*e+q22*f+q32*g; 03619 v1 = q12*f+q22*h+q32*i; 03620 v2 = q12*g+q22*i+q32*j; 03621 pdiag[2] = q12*v0+q22*v1+q32*v2; 03622 psubd[2] = q13*v0+q23*v1+q33*v2; 03623 03624 v0 = q13*e+q23*f+q33*g; 03625 v1 = q13*f+q23*h+q33*i; 03626 v2 = q13*g+q23*i+q33*j; 03627 pdiag[3] = q13*v0+q23*v1+q33*v2; 03628 } 03629 else { // Q1 = (+-1,0,0) 03630 q12 = 0; q22 = 1; q32 = 0; 03631 q13 = 0; q23 = 0; q33 = 1; 03632 03633 pdiag[2] = h; 03634 pdiag[3] = j; 03635 psubd[2] = i; 03636 } 03637 } 03638 03639 pmat[1][1] = q11; pmat[1][2] = q12; pmat[1][3] = q13; 03640 pmat[2][1] = q21; pmat[2][2] = q22; pmat[2][3] = q23; 03641 pmat[3][1] = q31; pmat[3][2] = q32; pmat[3][3] = q33; 03642 } 03643 else { 03644 pdiag[1] = e; 03645 psubd[0] = b; 03646 pmat[1][1] = 1; 03647 pmat[2][1] = 0; 03648 pmat[3][1] = 0; 03649 03650 if ( g != 0 ) { 03651 float ell = float(sqrt(f*f+g*g)); 03652 f /= ell; 03653 g /= ell; 03654 float Q = 2*f*i+g*(j-h); 03655 03656 pdiag[2] = h+g*Q; 03657 pdiag[3] = j-g*Q; 03658 psubd[1] = ell; 03659 psubd[2] = i-f*Q; 03660 pmat[1][2] = 0; pmat[1][3] = 0; 03661 pmat[2][2] = f; pmat[2][3] = g; 03662 pmat[3][2] = g; pmat[3][3] = -f; 03663 } 03664 else { 03665 pdiag[2] = h; 03666 pdiag[3] = j; 03667 psubd[1] = f; 03668 psubd[2] = i; 03669 pmat[1][2] = 0; pmat[1][3] = 0; 03670 pmat[2][2] = 1; pmat[2][3] = 0; 03671 pmat[3][2] = 0; pmat[3][3] = 1; 03672 } 03673 } 03674 } 03675 //--------------------------------------------------------------------------- 03676 void mgcEigen:: 03677 TridiagonalN (int n, float** pmat, float* pdiag, float* psubd) 03678 { 03679 int i, j, k, ell; 03680 03681 for (i = n-1, ell = n-2; i >= 1; i--, ell--) { 03682 float h = 0, scale = 0; 03683 03684 if ( ell > 0 ) { 03685 for (k = 0; k <= ell; k++) 03686 scale += float(fabs(pmat[i][k])); 03687 if ( scale == 0 ) 03688 psubd[i] = pmat[i][ell]; 03689 else { 03690 for (k = 0; k <= ell; k++) { 03691 pmat[i][k] /= scale; 03692 h += pmat[i][k]*pmat[i][k]; 03693 } 03694 float f = pmat[i][ell]; 03695 float g = ( f > 0 ? -float(sqrt(h)) : float(sqrt(h)) ); 03696 psubd[i] = scale*g; 03697 h -= f*g; 03698 pmat[i][ell] = f-g; 03699 f = 0; 03700 for (j = 0; j <= ell; j++) { 03701 pmat[j][i] = pmat[i][j]/h; 03702 g = 0; 03703 for (k = 0; k <= j; k++) 03704 g += pmat[j][k]*pmat[i][k]; 03705 for (k = j+1; k <= ell; k++) 03706 g += pmat[k][j]*pmat[i][k]; 03707 psubd[j] = g/h; 03708 f += psubd[j]*pmat[i][j]; 03709 } 03710 float hh = f/(h+h); 03711 for (j = 0; j <= ell; j++) { 03712 f = pmat[i][j]; 03713 psubd[j] = g = psubd[j] - hh*f; 03714 for (k = 0; k <= j; k++) 03715 pmat[j][k] -= f*psubd[k]+g*pmat[i][k]; 03716 } 03717 } 03718 } 03719 else 03720 psubd[i] = pmat[i][ell]; 03721 03722 pdiag[i] = h; 03723 } 03724 03725 pdiag[0] = psubd[0] = 0; 03726 for (i = 0, ell = -1; i <= n-1; i++, ell++) { 03727 if ( pdiag[i] ) { 03728 for (j = 0; j <= ell; j++) { 03729 float sum = 0; 03730 for (k = 0; k <= ell; k++) 03731 sum += pmat[i][k]*pmat[k][j]; 03732 for (k = 0; k <= ell; k++) 03733 pmat[k][j] -= sum*pmat[k][i]; 03734 } 03735 } 03736 pdiag[i] = pmat[i][i]; 03737 pmat[i][i] = 1; 03738 for (j = 0; j <= ell; j++) 03739 pmat[j][i] = pmat[i][j] = 0; 03740 } 03741 03742 // re-ordering if mgcEigen::QLAlgorithm is used subsequently 03743 for (i = 1, ell = 0; i < n; i++, ell++) 03744 psubd[ell] = psubd[i]; 03745 psubd[n-1] = 0; 03746 } 03747 //--------------------------------------------------------------------------- 03748 void mgcEigen:: 03749 QLAlgorithm (int n, float* pdiag, float* psubd, float** pmat) 03750 { 03751 const int eigen_maxiter = 30; 03752 03753 for (int ell = 0; ell < n; ell++) { 03754 int iter; 03755 for (iter = 0; iter < eigen_maxiter; iter++) { 03756 int m; 03757 for (m = ell; m <= n-2; m++) { 03758 float dd = float(fabs(pdiag[m])+fabs(pdiag[m+1])); 03759 if ( (float)(fabs(psubd[m])+dd) == dd ) 03760 break; 03761 } 03762 if ( m == ell ) 03763 break; 03764 03765 float g = (pdiag[ell+1]-pdiag[ell])/(2*psubd[ell]); 03766 float r = float(sqrt(g*g+1)); 03767 if ( g < 0 ) 03768 g = pdiag[m]-pdiag[ell]+psubd[ell]/(g-r); 03769 else 03770 g = pdiag[m]-pdiag[ell]+psubd[ell]/(g+r); 03771 float s = 1, c = 1, p = 0; 03772 for (int i = m-1; i >= ell; i--) { 03773 float f = s*psubd[i], b = c*psubd[i]; 03774 if ( fabs(f) >= fabs(g) ) { 03775 c = g/f; 03776 r = float(sqrt(c*c+1)); 03777 psubd[i+1] = f*r; 03778 c *= (s = 1/r); 03779 } 03780 else { 03781 s = f/g; 03782 r = float(sqrt(s*s+1)); 03783 psubd[i+1] = g*r; 03784 s *= (c = 1/r); 03785 } 03786 g = pdiag[i+1]-p; 03787 r = (pdiag[i]-g)*s+2*b*c; 03788 p = s*r; 03789 pdiag[i+1] = g+p; 03790 g = c*r-b; 03791 03792 for (int k = 0; k < n; k++) { 03793 f = pmat[k][i+1]; 03794 pmat[k][i+1] = s*pmat[k][i]+c*f; 03795 pmat[k][i] = c*pmat[k][i]-s*f; 03796 } 03797 } 03798 pdiag[ell] -= p; 03799 psubd[ell] = g; 03800 psubd[m] = 0; 03801 } 03802 if ( iter == eigen_maxiter ) { 03803 Report(ql_exceeded); 03804 return; 03805 } 03806 } 03807 } 03808 //--------------------------------------------------------------------------- 03809 void mgcEigen:: 03810 DecreasingSort (int n, float* eigval, float** eigvec) 03811 { 03812 // sort eigenvalues in decreasing order, e[0] >= ... >= e[n-1] 03813 for (int i = 0, k; i <= n-2; i++) { 03814 // locate maximum eigenvalue 03815 float max = eigval[k=i]; 03816 int j; 03817 for (j = i+1; j < n; j++) 03818 if ( eigval[j] > max ) 03819 max = eigval[k=j]; 03820 03821 if ( k != i ) { 03822 // swap eigenvalues 03823 eigval[k] = eigval[i]; 03824 eigval[i] = max; 03825 03826 // swap eigenvectors 03827 for (j = 0; j < n; j++) { 03828 float tmp = eigvec[j][i]; 03829 eigvec[j][i] = eigvec[j][k]; 03830 eigvec[j][k] = tmp; 03831 } 03832 } 03833 } 03834 } 03835 //--------------------------------------------------------------------------- 03836 void mgcEigen:: 03837 IncreasingSort (int n, float* eigval, float** eigvec) 03838 { 03839 // sort eigenvalues in increasing order, e[0] <= ... <= e[n-1] 03840 for (int i = 0, k; i <= n-2; i++) { 03841 // locate minimum eigenvalue 03842 float min = eigval[k=i]; 03843 int j; 03844 for (j = i+1; j < n; j++) 03845 if ( eigval[j] < min ) 03846 min = eigval[k=j]; 03847 03848 if ( k != i ) { 03849 // swap eigenvalues 03850 eigval[k] = eigval[i]; 03851 eigval[i] = min; 03852 03853 // swap eigenvectors 03854 for (j = 0; j < n; j++) { 03855 float tmp = eigvec[j][i]; 03856 eigvec[j][i] = eigvec[j][k]; 03857 eigvec[j][k] = tmp; 03858 } 03859 } 03860 } 03861 } 03862 //--------------------------------------------------------------------------- 03863 int mgcEigen:: 03864 Number (unsigned single_error) 03865 { 03866 int result; 03867 for (result = -1; single_error; single_error >>= 1) 03868 result++; 03869 return result; 03870 } 03871 //--------------------------------------------------------------------------- 03872 void mgcEigen:: 03873 Report (unsigned single_error) 03874 { 03875 if ( mgcEigen::verbose1 ) 03876 cout << "mgcEigen: " << message[Number(single_error)] << endl; 03877 else { 03878 ofstream ostr("eigen.err",ios::out|ios::app); 03879 ostr << "mgcEigen: " << message[Number(single_error)] << endl; 03880 } 03881 error |= single_error; 03882 } 03883 //--------------------------------------------------------------------------- 03884 void mgcEigen:: 03885 Report (ostream& ostr) 03886 { 03887 for (unsigned single_error = 1; single_error; single_error <<= 1) 03888 if ( error & single_error ) 03889 ostr << "mgcEigen: " << message[Number(single_error)] << endl; 03890 03891 error = 0; 03892 } 03893 //=========================================================================== 03894 // error handling 03895 int mgcEigenD::verbose1 = 0; 03896 unsigned mgcEigenD::error = 0; 03897 const unsigned mgcEigenD::invalid_size = 0x00000001; 03898 const unsigned mgcEigenD::allocation_failed = 0x00000002; 03899 const unsigned mgcEigenD::ql_exceeded = 0x00000004; 03900 const char* mgcEigenD::message[3] = { 03901 "invalid matrix size", 03902 "allocation failed", 03903 "QL algorithm - exceeded maximum iterations" 03904 }; 03905 //--------------------------------------------------------------------------- 03906 mgcEigenD:: 03907 mgcEigenD (int _size) 03908 { 03909 if ( (size = _size) <= 1 ) { 03910 Report(invalid_size); 03911 return; 03912 } 03913 if ( (mat = new double*[size]) == 0 ) { 03914 Report(allocation_failed); 03915 return; 03916 } 03917 for (int d = 0; d < size; d++) 03918 if ( (mat[d] = new double[size]) == 0 ) { 03919 Report(allocation_failed); 03920 return; 03921 } 03922 if ( (diag = new double[size]) == 0 ) { 03923 Report(allocation_failed); 03924 return; 03925 } 03926 if ( (subd = new double[size]) == 0 ) { 03927 Report(allocation_failed); 03928 return; 03929 } 03930 } 03931 //--------------------------------------------------------------------------- 03932 mgcEigenD:: 03933 ~mgcEigenD () 03934 { 03935 delete[] subd; 03936 delete[] diag; 03937 for (int d = 0; d < size; d++) 03938 delete[] mat[d]; 03939 delete[] mat; 03940 } 03941 //--------------------------------------------------------------------------- 03942 void mgcEigenD:: 03943 Tridiagonal2 (double** pmat, double* pdiag, double* psubd) 03944 { 03945 // matrix is already tridiagonal 03946 03947 pdiag[0] = pmat[0][0]; 03948 pdiag[1] = pmat[1][1]; 03949 psubd[0] = pmat[0][1]; 03950 psubd[1] = 0; 03951 pmat[0][0] = 1; pmat[0][1] = 0; 03952 pmat[1][0] = 0; pmat[1][1] = 1; 03953 } 03954 //--------------------------------------------------------------------------- 03955 void mgcEigenD:: 03956 Tridiagonal3 (double** pmat, double* pdiag, double* psubd) 03957 { 03958 double a = pmat[0][0], b = pmat[0][1], c = pmat[0][2], 03959 d = pmat[1][1], e = pmat[1][2], f = pmat[2][2]; 03960 03961 pdiag[0] = a; 03962 psubd[2] = 0; 03963 if ( c != 0 ) { 03964 double ell = sqrt(b*b+c*c); 03965 b /= ell; 03966 c /= ell; 03967 double q = 2*b*e+c*(f-d); 03968 pdiag[1] = d+c*q; 03969 pdiag[2] = f-c*q; 03970 psubd[0] = ell; 03971 psubd[1] = e-b*q; 03972 pmat[0][0] = 1; pmat[0][1] = 0; pmat[0][2] = 0; 03973 pmat[1][0] = 0; pmat[1][1] = b; pmat[1][2] = c; 03974 pmat[2][0] = 0; pmat[2][1] = c; pmat[2][2] = -b; 03975 } 03976 else { 03977 pdiag[1] = d; 03978 pdiag[2] = f; 03979 psubd[0] = b; 03980 psubd[1] = e; 03981 pmat[0][0] = 1; pmat[0][1] = 0; pmat[0][2] = 0; 03982 pmat[1][0] = 0; pmat[1][1] = 1; pmat[1][2] = 0; 03983 pmat[2][0] = 0; pmat[2][1] = 0; pmat[2][2] = 1; 03984 } 03985 } 03986 //--------------------------------------------------------------------------- 03987 void mgcEigenD:: 03988 Tridiagonal4 (double** pmat, double* pdiag, double* psubd) 03989 { 03990 // save pmatrix M 03991 double 03992 a = pmat[0][0], b = pmat[0][1], c = pmat[0][2], d = pmat[0][3], 03993 e = pmat[1][1], f = pmat[1][2], g = pmat[1][3], 03994 h = pmat[2][2], i = pmat[2][3], j = pmat[3][3]; 03995 03996 pdiag[0] = a; 03997 psubd[3] = 0; 03998 03999 pmat[0][0] = 1; pmat[0][1] = 0; pmat[0][2] = 0; pmat[0][3] = 0; 04000 pmat[1][0] = 0; 04001 pmat[2][0] = 0; 04002 pmat[3][0] = 0; 04003 04004 if ( c != 0 || d != 0 ) { 04005 double q11, q12, q13; 04006 double q21, q22, q23; 04007 double q31, q32, q33; 04008 04009 // build column Q1 04010 double len = sqrt(b*b+c*c+d*d); 04011 q11 = b/len; 04012 q21 = c/len; 04013 q31 = d/len; 04014 04015 psubd[0] = len; 04016 04017 // compute S*Q1 04018 double v0 = e*q11+f*q21+g*q31; 04019 double v1 = f*q11+h*q21+i*q31; 04020 double v2 = g*q11+i*q21+j*q31; 04021 04022 pdiag[1] = q11*v0+q21*v1+q31*v2; 04023 04024 // build column Q3 = Q1x(S*Q1) 04025 q13 = q21*v2-q31*v1; 04026 q23 = q31*v0-q11*v2; 04027 q33 = q11*v1-q21*v0; 04028 len = sqrt(q13*q13+q23*q23+q33*q33); 04029 if ( len > 0 ) { 04030 q13 /= len; 04031 q23 /= len; 04032 q33 /= len; 04033 04034 // build column Q2 = Q3xQ1 04035 q12 = q23*q31-q33*q21; 04036 q22 = q33*q11-q13*q31; 04037 q32 = q13*q21-q23*q11; 04038 04039 v0 = q12*e+q22*f+q32*g; 04040 v1 = q12*f+q22*h+q32*i; 04041 v2 = q12*g+q22*i+q32*j; 04042 psubd[1] = q11*v0+q21*v1+q31*v2; 04043 pdiag[2] = q12*v0+q22*v1+q32*v2; 04044 psubd[2] = q13*v0+q23*v1+q33*v2; 04045 04046 v0 = q13*e+q23*f+q33*g; 04047 v1 = q13*f+q23*h+q33*i; 04048 v2 = q13*g+q23*i+q33*j; 04049 pdiag[3] = q13*v0+q23*v1+q33*v2; 04050 } 04051 else { // S*Q1 parallel to Q1, choose any valid Q2 and Q3 04052 psubd[1] = 0; 04053 04054 len = q21*q21+q31*q31; 04055 if ( len > 0 ) { 04056 double tmp = q11-1; 04057 q12 = -q21; 04058 q22 = 1+tmp*q21*q21/len; 04059 q32 = tmp*q21*q31/len; 04060 04061 q13 = -q31; 04062 q23 = q32; 04063 q33 = 1+tmp*q31*q31/len; 04064 04065 v0 = q12*e+q22*f+q32*g; 04066 v1 = q12*f+q22*h+q32*i; 04067 v2 = q12*g+q22*i+q32*j; 04068 pdiag[2] = q12*v0+q22*v1+q32*v2; 04069 psubd[2] = q13*v0+q23*v1+q33*v2; 04070 04071 v0 = q13*e+q23*f+q33*g; 04072 v1 = q13*f+q23*h+q33*i; 04073 v2 = q13*g+q23*i+q33*j; 04074 pdiag[3] = q13*v0+q23*v1+q33*v2; 04075 } 04076 else { // Q1 = (+-1,0,0) 04077 q12 = 0; q22 = 1; q32 = 0; 04078 q13 = 0; q23 = 0; q33 = 1; 04079 04080 pdiag[2] = h; 04081 pdiag[3] = j; 04082 psubd[2] = i; 04083 } 04084 } 04085 04086 pmat[1][1] = q11; pmat[1][2] = q12; pmat[1][3] = q13; 04087 pmat[2][1] = q21; pmat[2][2] = q22; pmat[2][3] = q23; 04088 pmat[3][1] = q31; pmat[3][2] = q32; pmat[3][3] = q33; 04089 } 04090 else { 04091 pdiag[1] = e; 04092 psubd[0] = b; 04093 pmat[1][1] = 1; 04094 pmat[2][1] = 0; 04095 pmat[3][1] = 0; 04096 04097 if ( g != 0 ) { 04098 double ell = sqrt(f*f+g*g); 04099 f /= ell; 04100 g /= ell; 04101 double Q = 2*f*i+g*(j-h); 04102 04103 pdiag[2] = h+g*Q; 04104 pdiag[3] = j-g*Q; 04105 psubd[1] = ell; 04106 psubd[2] = i-f*Q; 04107 pmat[1][2] = 0; pmat[1][3] = 0; 04108 pmat[2][2] = f; pmat[2][3] = g; 04109 pmat[3][2] = g; pmat[3][3] = -f; 04110 } 04111 else { 04112 pdiag[2] = h; 04113 pdiag[3] = j; 04114 psubd[1] = f; 04115 psubd[2] = i; 04116 pmat[1][2] = 0; pmat[1][3] = 0; 04117 pmat[2][2] = 1; pmat[2][3] = 0; 04118 pmat[3][2] = 0; pmat[3][3] = 1; 04119 } 04120 } 04121 } 04122 //--------------------------------------------------------------------------- 04123 void mgcEigenD:: 04124 TridiagonalN (int n, double** pmat, double* pdiag, double* psubd) 04125 { 04126 int i, j, k, ell; 04127 04128 for (i = n-1, ell = n-2; i >= 1; i--, ell--) { 04129 double h = 0, scale = 0; 04130 04131 if ( ell > 0 ) { 04132 for (k = 0; k <= ell; k++) 04133 scale += fabs(pmat[i][k]); 04134 if ( scale == 0 ) 04135 psubd[i] = pmat[i][ell]; 04136 else { 04137 for (k = 0; k <= ell; k++) { 04138 pmat[i][k] /= scale; 04139 h += pmat[i][k]*pmat[i][k]; 04140 } 04141 double f = pmat[i][ell]; 04142 double g = ( f > 0 ? -sqrt(h) : sqrt(h) ); 04143 psubd[i] = scale*g; 04144 h -= f*g; 04145 pmat[i][ell] = f-g; 04146 f = 0; 04147 for (j = 0; j <= ell; j++) { 04148 pmat[j][i] = pmat[i][j]/h; 04149 g = 0; 04150 for (k = 0; k <= j; k++) 04151 g += pmat[j][k]*pmat[i][k]; 04152 for (k = j+1; k <= ell; k++) 04153 g += pmat[k][j]*pmat[i][k]; 04154 psubd[j] = g/h; 04155 f += psubd[j]*pmat[i][j]; 04156 } 04157 double hh = f/(h+h); 04158 for (j = 0; j <= ell; j++) { 04159 f = pmat[i][j]; 04160 psubd[j] = g = psubd[j] - hh*f; 04161 for (k = 0; k <= j; k++) 04162 pmat[j][k] -= f*psubd[k]+g*pmat[i][k]; 04163 } 04164 } 04165 } 04166 else 04167 psubd[i] = pmat[i][ell]; 04168 04169 pdiag[i] = h; 04170 } 04171 04172 pdiag[0] = psubd[0] = 0; 04173 for (i = 0, ell = -1; i <= n-1; i++, ell++) { 04174 if ( pdiag[i] ) { 04175 for (j = 0; j <= ell; j++) { 04176 double sum = 0; 04177 for (k = 0; k <= ell; k++) 04178 sum += pmat[i][k]*pmat[k][j]; 04179 for (k = 0; k <= ell; k++) 04180 pmat[k][j] -= sum*pmat[k][i]; 04181 } 04182 } 04183 pdiag[i] = pmat[i][i]; 04184 pmat[i][i] = 1; 04185 for (j = 0; j <= ell; j++) 04186 pmat[j][i] = pmat[i][j] = 0; 04187 } 04188 04189 // re-ordering if mgcEigenD::QLAlgorithm is used subsequently 04190 for (i = 1, ell = 0; i < n; i++, ell++) 04191 psubd[ell] = psubd[i]; 04192 psubd[n-1] = 0; 04193 } 04194 //--------------------------------------------------------------------------- 04195 void mgcEigenD:: 04196 QLAlgorithm (int n, double* pdiag, double* psubd, double** pmat) 04197 { 04198 const int eigen_maxiter = 30; 04199 04200 for (int ell = 0; ell < n; ell++) { 04201 int iter; 04202 for (iter = 0; iter < eigen_maxiter; iter++) { 04203 int m; 04204 for (m = ell; m <= n-2; m++) { 04205 double dd = fabs(pdiag[m])+fabs(pdiag[m+1]); 04206 if ( (double)(fabs(psubd[m])+dd) == dd ) 04207 break; 04208 } 04209 if ( m == ell ) 04210 break; 04211 04212 double g = (pdiag[ell+1]-pdiag[ell])/(2*psubd[ell]); 04213 double r = sqrt(g*g+1); 04214 if ( g < 0 ) 04215 g = pdiag[m]-pdiag[ell]+psubd[ell]/(g-r); 04216 else 04217 g = pdiag[m]-pdiag[ell]+psubd[ell]/(g+r); 04218 double s = 1, c = 1, p = 0; 04219 for (int i = m-1; i >= ell; i--) { 04220 double f = s*psubd[i], b = c*psubd[i]; 04221 if ( fabs(f) >= fabs(g) ) { 04222 c = g/f; 04223 r = sqrt(c*c+1); 04224 psubd[i+1] = f*r; 04225 c *= (s = 1/r); 04226 } 04227 else { 04228 s = f/g; 04229 r = sqrt(s*s+1); 04230 psubd[i+1] = g*r; 04231 s *= (c = 1/r); 04232 } 04233 g = pdiag[i+1]-p; 04234 r = (pdiag[i]-g)*s+2*b*c; 04235 p = s*r; 04236 pdiag[i+1] = g+p; 04237 g = c*r-b; 04238 04239 for (int k = 0; k < n; k++) { 04240 f = pmat[k][i+1]; 04241 pmat[k][i+1] = s*pmat[k][i]+c*f; 04242 pmat[k][i] = c*pmat[k][i]-s*f; 04243 } 04244 } 04245 pdiag[ell] -= p; 04246 psubd[ell] = g; 04247 psubd[m] = 0; 04248 } 04249 if ( iter == eigen_maxiter ) { 04250 Report(ql_exceeded); 04251 return; 04252 } 04253 } 04254 } 04255 //--------------------------------------------------------------------------- 04256 void mgcEigenD:: 04257 DecreasingSort (int n, double* eigval, double** eigvec) 04258 { 04259 // sort eigenvalues in decreasing order, e[0] >= ... >= e[n-1] 04260 for (int i = 0, k; i <= n-2; i++) { 04261 // locate maximum eigenvalue 04262 double max = eigval[k=i]; 04263 int j; 04264 for (j = i+1; j < n; j++) 04265 if ( eigval[j] > max ) 04266 max = eigval[k=j]; 04267 04268 if ( k != i ) { 04269 // swap eigenvalues 04270 eigval[k] = eigval[i]; 04271 eigval[i] = max; 04272 04273 // swap eigenvectors 04274 for (j = 0; j < n; j++) { 04275 double tmp = eigvec[j][i]; 04276 eigvec[j][i] = eigvec[j][k]; 04277 eigvec[j][k] = tmp; 04278 } 04279 } 04280 } 04281 } 04282 //--------------------------------------------------------------------------- 04283 void mgcEigenD:: 04284 IncreasingSort (int n, double* eigval, double** eigvec) 04285 { 04286 // sort eigenvalues in increasing order, e[0] <= ... <= e[n-1] 04287 for (int i = 0, k; i <= n-2; i++) { 04288 // locate minimum eigenvalue 04289 double min = eigval[k=i]; 04290 int j; 04291 for (j = i+1; j < n; j++) 04292 if ( eigval[j] < min ) 04293 min = eigval[k=j]; 04294 04295 if ( k != i ) { 04296 // swap eigenvalues 04297 eigval[k] = eigval[i]; 04298 eigval[i] = min; 04299 04300 // swap eigenvectors 04301 for (j = 0; j < n; j++) { 04302 double tmp = eigvec[j][i]; 04303 eigvec[j][i] = eigvec[j][k]; 04304 eigvec[j][k] = tmp; 04305 } 04306 } 04307 } 04308 } 04309 //--------------------------------------------------------------------------- 04310 mgcEigenD& mgcEigenD:: 04311 Matrix (double** inmat) 04312 { 04313 for (int row = 0; row < size; row++) 04314 for (int col = 0; col < size; col++) 04315 mat[row][col] = inmat[row][col]; 04316 return *this; 04317 } 04318 //--------------------------------------------------------------------------- 04319 void mgcEigenD:: 04320 EigenStuff3 () 04321 { 04322 Tridiagonal3(mat,diag,subd); 04323 QLAlgorithm(size,diag,subd,mat); 04324 } 04325 //--------------------------------------------------------------------------- 04326 int mgcEigenD:: 04327 Number (unsigned single_error) 04328 { 04329 int result; 04330 for (result = -1; single_error; single_error >>= 1) 04331 result++; 04332 return result; 04333 } 04334 //--------------------------------------------------------------------------- 04335 void mgcEigenD:: 04336 Report (unsigned single_error) 04337 { 04338 if ( mgcEigenD::verbose1 ) 04339 cout << "mgcEigenD: " << message[Number(single_error)] << endl; 04340 else { 04341 ofstream ostr("eigen.err",ios::out|ios::app); 04342 ostr << "mgcEigenD: " << message[Number(single_error)] << endl; 04343 } 04344 error |= single_error; 04345 } 04346 //--------------------------------------------------------------------------- 04347 void mgcEigenD:: 04348 Report (ostream& ostr) 04349 { 04350 for (unsigned single_error = 1; single_error; single_error <<= 1) 04351 if ( error & single_error ) 04352 ostr << "mgcEigenD: " << message[Number(single_error)] << endl; 04353 04354 error = 0; 04355 } 04356 //=========================================================================== 04357 04358 #ifdef EIGEN_TEST 04359 04360 int main () 04361 { 04362 mgcEigenD eig(3); 04363 04364 eig.Matrix(0,0) = 2; eig.Matrix(0,1) = 1; eig.Matrix(0,2) = 1; 04365 eig.Matrix(1,0) = 1; eig.Matrix(1,1) = 2; eig.Matrix(1,2) = 1; 04366 eig.Matrix(2,0) = 1; eig.Matrix(2,1) = 1; eig.Matrix(2,2) = 2; 04367 04368 eig.IncrSortEigenStuff3(); 04369 04370 cout.setf(ios::fixed); 04371 04372 cout << "eigenvalues = " << endl; 04373 for (int row = 0; row < 3; row++) 04374 cout << eig.Eigenvalue(row) << ' '; 04375 cout << endl; 04376 04377 cout << "eigenvectors = " << endl; 04378 for (row = 0; row < 3; row++) { 04379 for (int col = 0; col < 3; col++) 04380 cout << eig.Eigenvector(row,col) << ' '; 04381 cout << endl; 04382 } 04383 04384 // eigenvalues = 04385 // 1.000000 1.000000 4.000000 04386 // eigenvectors = 04387 // 0.411953 0.704955 0.577350 04388 // 0.404533 -0.709239 0.577350 04389 // -0.816485 0.004284 0.577350 04390 04391 return 0; 04392 } 04393 #endif 04394 #endif 04395 04396 // FILE: tri3tri3.cpp 04397 //--------------------------------------------------------------------------- 04398 // MinTriangleTriangle 04399 // 04400 // The quadratic form representing the squared distance between two planes 04401 // never has an isolated global minimum. The generic case is for it to 04402 // have an entire line of zeros (the line of intersection of the two 04403 // planes). Therefore, it is sufficient to compare edges of each triangle 04404 // with the entire other triangle, looking for the minimum distance. 04405 //--------------------------------------------------------------------------- 04406 04407 // NOTE: This code is not fully optimized as is the code in pt3lin3, 04408 // pt3tri3, and lin3lin3. 04409 04410 //--------------------------------------------------------------------------- 04411 double 04412 AnalyticGeometryTool::MinTriangleTriangle (Triangle3& tri0, 04413 Triangle3& tri1, 04414 double& s, double& t, double& u, 04415 double& v) 04416 { 04417 double s0, t0, u0, v0, min, min0; 04418 Line3 line; 04419 04420 // compare edges of tri0 against all of tri1 04421 line.b = tri0.b; 04422 line.m = tri0.e0; 04423 min = MinLineSegmentTriangle(line,tri1,s,u,v); 04424 t = 0; 04425 04426 line.m = tri0.e1; 04427 min0 = MinLineSegmentTriangle(line,tri1,t0,u0,v0); 04428 s0 = 0; 04429 if ( min0 < min ) 04430 { 04431 min = min0; 04432 s = s0; 04433 t = t0; 04434 u = u0; 04435 v = v0; 04436 } 04437 04438 line.b = line.b + tri0.e0; 04439 line.m = line.m - tri0.e0; 04440 min0 = MinLineSegmentTriangle(line,tri1,t0,u0,v0); 04441 s0 = 1-t0; 04442 if ( min0 < min ) 04443 { 04444 min = min0; 04445 s = s0; 04446 t = t0; 04447 u = u0; 04448 v = v0; 04449 } 04450 04451 // compare edges of tri1 against all of tri0 04452 line.b = tri1.b; 04453 line.m = tri1.e0; 04454 min0 = MinLineSegmentTriangle(line,tri0,u0,s0,t0); 04455 v0 = 0; 04456 if ( min0 < min ) 04457 { 04458 min = min0; 04459 s = s0; 04460 t = t0; 04461 u = u0; 04462 v = v0; 04463 } 04464 04465 line.m = tri1.e1; 04466 min0 = MinLineSegmentTriangle(line,tri0,v0,s0,t0); 04467 u0 = 0; 04468 if ( min0 < min ) 04469 { 04470 min = min0; 04471 s = s0; 04472 t = t0; 04473 u = u0; 04474 v = v0; 04475 } 04476 04477 line.b = line.b + tri1.e0; 04478 line.m = line.m - tri1.e0; 04479 min0 = MinLineSegmentTriangle(line,tri0,v0,s0,t0); 04480 u0 = 1-v0; 04481 if ( min0 < min ) 04482 { 04483 min = min0; 04484 s = s0; 04485 t = t0; 04486 u = u0; 04487 v = v0; 04488 } 04489 04490 return min; 04491 } 04492 04493 //--------------------------------------------------------------------------- 04494 04495 #ifdef TRI3TRI3_TEST 04496 04497 //#define RAND (2.0f*rand()/double(RAND_MAX)-1) 04498 04499 //ofstream ostr("data.txt"); 04500 04501 void main () 04502 { 04503 Triangle3 tri0, tri1; 04504 Point3 p, q, diff; 04505 double u, v, s, t, u0, v0, s0, t0, min0, min1, dist; 04506 04507 double maxdiff = 0; 04508 04509 for (int i = 0; i < 128; i++) 04510 { 04511 tri0.b.x = RAND; 04512 tri0.b.y = RAND; 04513 tri0.b.z = RAND; 04514 tri0.e0.x = RAND; 04515 tri0.e0.y = RAND; 04516 tri0.e0.z = RAND; 04517 tri0.e1.x = RAND; 04518 tri0.e1.y = RAND; 04519 tri0.e1.z = RAND; 04520 04521 tri1.b.x = RAND; 04522 tri1.b.y = RAND; 04523 tri1.b.z = RAND; 04524 tri1.e0.x = RAND; 04525 tri1.e0.y = RAND; 04526 tri1.e0.z = RAND; 04527 tri1.e1.x = RAND; 04528 tri1.e1.y = RAND; 04529 tri1.e1.z = RAND; 04530 04531 min0 = FLT_MAX; 04532 int max = 32; 04533 for (int w = 0; w <= max; w++) 04534 { 04535 t0 = w/double(max); 04536 for (int z = 0; w+z <= max; z++) 04537 { 04538 s0 = z/double(max); 04539 p = tri0.b+s0*tri0.e0+t0*tri0.e1; 04540 for (int y = 0; y <= max; y++) 04541 { 04542 v0 = y/double(max); 04543 for (int x = 0; x+y <= max; x++) 04544 { 04545 u0 = x/double(max); 04546 q = tri1.b+u0*tri1.e0+v0*tri1.e1; 04547 04548 diff = p-q; 04549 dist = Length(diff); 04550 if ( dist < min0 ) 04551 { 04552 min0 = dist; 04553 s = s0; 04554 t = t0; 04555 u = u0; 04556 v = v0; 04557 } 04558 } 04559 } 04560 } 04561 } 04562 ostr << "i = " << i << endl; 04563 ostr << "sampled = " << s << ' ' << t << ' ' << u << ' ' 04564 << v << ' ' << min0 << endl; 04565 04566 min1 = MinTriangleTriangle(tri0,tri1,s,t,u,v); 04567 ostr << "analytic = " << s << ' ' << t << ' ' << u << ' ' 04568 << v << ' ' << min1 << endl; 04569 04570 ostr << "diff = " << min1-min0 << endl; 04571 04572 if ( min1-min0 > maxdiff ) 04573 maxdiff = min1-min0; 04574 04575 ostr << endl; 04576 } 04577 04578 ostr << "max diff = " << maxdiff << endl; 04579 } 04580 #endif 04581 04582 //--------------------------------------------------------------------------- 04583 double 04584 AnalyticGeometryTool::MinLineSegmentLineSegment (const Line3& seg0, const Line3& seg1, 04585 double& s, double& t) 04586 { 04587 Point3 diff = seg0.b - seg1.b; 04588 double A = Dot(seg0.m,seg0.m); 04589 double B = -Dot(seg0.m,seg1.m); 04590 double C = Dot(seg1.m,seg1.m); 04591 double D = Dot(seg0.m,diff); 04592 double E; // -Dot(seg1.m,diff), defer until needed 04593 double F = Dot(diff,diff); 04594 double det = Abs(A*C-B*B); // A*C-B*B = |Cross(M0,M1)|^2 >= 0 04595 04596 double tmp; 04597 04598 if ( det >= par_tolerance ) 04599 { 04600 // line segments are not parallel 04601 E = -Dot(seg1.m,diff); 04602 s = B*E-C*D; 04603 t = B*D-A*E; 04604 04605 if ( s >= 0 ) 04606 { 04607 if ( s <= det ) 04608 { 04609 if ( t >= 0 ) 04610 { 04611 if ( t <= det ) // region 0 (interior) 04612 { 04613 // minimum at two interior points of 3D lines 04614 double invDet = 1.0f/det; 04615 s *= invDet; 04616 t *= invDet; 04617 return DIST(s*(A*s+B*t+2*D)+t*(B*s+C*t+2*E)+F); 04618 } 04619 else // region 3 (side) 04620 { 04621 t = 1; 04622 tmp = B+D; 04623 if ( tmp >= 0 ) 04624 { 04625 s = 0; 04626 return DIST(C+2*E+F); 04627 } 04628 else if ( -tmp >= A ) 04629 { 04630 s = 1; 04631 return DIST(A+C+F+2*(E+tmp)); 04632 } 04633 else 04634 { 04635 s = -tmp/A; 04636 return DIST(tmp*s+C+2*E+F); 04637 } 04638 } 04639 } 04640 else // region 7 (side) 04641 { 04642 t = 0; 04643 if ( D >= 0 ) 04644 { 04645 s = 0; 04646 return DIST(F); 04647 } 04648 else if ( -D >= A ) 04649 { 04650 s = 1; 04651 return DIST(A+2*D+F); 04652 } 04653 else 04654 { 04655 s = -D/A; 04656 return DIST(D*s+F); 04657 } 04658 } 04659 } 04660 else 04661 { 04662 if ( t >= 0 ) 04663 { 04664 if ( t <= det ) // region 1 (side) 04665 { 04666 s = 1; 04667 tmp = B+E; 04668 if ( tmp >= 0 ) 04669 { 04670 t = 0; 04671 return DIST(A+2*D+F); 04672 } 04673 else if ( -tmp >= C ) 04674 { 04675 t = 1; 04676 return DIST(A+C+F+2*(D+tmp)); 04677 } 04678 else 04679 { 04680 t = -tmp/C; 04681 return DIST(tmp*t+A+2*D+F); 04682 } 04683 } 04684 else // region 2 (corner) 04685 { 04686 tmp = B+D; 04687 if ( -tmp <= A ) 04688 { 04689 t = 1; 04690 if ( tmp >= 0 ) 04691 { 04692 s = 0; 04693 return DIST(C+2*E+F); 04694 } 04695 else 04696 { 04697 s = -tmp/A; 04698 return DIST(tmp*s+C+2*E+F); 04699 } 04700 } 04701 else 04702 { 04703 s = 1; 04704 tmp = B+E; 04705 if ( tmp >= 0 ) 04706 { 04707 t = 0; 04708 return DIST(A+2*D+F); 04709 } 04710 else if ( -tmp >= C ) 04711 { 04712 t = 1; 04713 return DIST(A+C+F+2*(D+tmp)); 04714 } 04715 else 04716 { 04717 t = -tmp/C; 04718 return DIST(tmp*t+A+2*D+F); 04719 } 04720 } 04721 } 04722 } 04723 else // region 8 (corner) 04724 { 04725 if ( -D < A ) 04726 { 04727 t = 0; 04728 if ( D >= 0 ) 04729 { 04730 s = 0; 04731 return DIST(F); 04732 } 04733 else 04734 { 04735 s = -D/A; 04736 return DIST(D*s+F); 04737 } 04738 } 04739 else 04740 { 04741 s = 1; 04742 tmp = B+E; 04743 if ( tmp >= 0 ) 04744 { 04745 t = 0; 04746 return DIST(A+2*D+F); 04747 } 04748 else if ( -tmp >= C ) 04749 { 04750 t = 1; 04751 return DIST(A+C+F+2*(D+tmp)); 04752 } 04753 else 04754 { 04755 t = -tmp/C; 04756 return DIST(tmp*t+A+2*D+F); 04757 } 04758 } 04759 } 04760 } 04761 } 04762 else 04763 { 04764 if ( t >= 0 ) 04765 { 04766 if ( t <= det ) // region 5 (side) 04767 { 04768 s = 0; 04769 if ( E >= 0 ) 04770 { 04771 t = 0; 04772 return DIST(F); 04773 } 04774 else if ( -E >= C ) 04775 { 04776 t = 1; 04777 return DIST(C+2*E+F); 04778 } 04779 else 04780 { 04781 t = -E/C; 04782 return DIST(E*t+F); 04783 } 04784 } 04785 else // region 4 (corner) 04786 { 04787 tmp = B+D; 04788 if ( tmp < 0 ) 04789 { 04790 t = 1; 04791 if ( -tmp >= A ) 04792 { 04793 s = 1; 04794 return DIST(A+C+F+2*(E+tmp)); 04795 } 04796 else 04797 { 04798 s = -tmp/A; 04799 return DIST(tmp*s+C+2*E+F); 04800 } 04801 } 04802 else 04803 { 04804 s = 0; 04805 if ( E >= 0 ) 04806 { 04807 t = 0; 04808 return DIST(F); 04809 } 04810 else if ( -E >= C ) 04811 { 04812 t = 1; 04813 return DIST(C+2*E+F); 04814 } 04815 else 04816 { 04817 t = -E/C; 04818 return DIST(E*t+F); 04819 } 04820 } 04821 } 04822 } 04823 else // region 6 (corner) 04824 { 04825 if ( D < 0 ) 04826 { 04827 t = 0; 04828 if ( -D >= A ) 04829 { 04830 s = 1; 04831 return DIST(A+2*D+F); 04832 } 04833 else 04834 { 04835 s = -D/A; 04836 return DIST(D*s+F); 04837 } 04838 } 04839 else 04840 { 04841 s = 0; 04842 if ( E >= 0 ) 04843 { 04844 t = 0; 04845 return DIST(F); 04846 } 04847 else if ( -E >= C ) 04848 { 04849 t = 1; 04850 return DIST(C+2*E+F); 04851 } 04852 else 04853 { 04854 t = -E/C; 04855 return DIST(E*t+F); 04856 } 04857 } 04858 } 04859 } 04860 } 04861 else 04862 { 04863 // line segments are parallel 04864 if ( B > 0 ) 04865 { 04866 // direction vectors form an obtuse angle 04867 if ( D >= 0 ) 04868 { 04869 s = 0; 04870 t = 0; 04871 return DIST(F); 04872 } 04873 else if ( -D <= A ) 04874 { 04875 s = -D/A; 04876 t = 0; 04877 return DIST(D*s+F); 04878 } 04879 else 04880 { 04881 E = -Dot(seg1.m,diff); 04882 s = 1; 04883 tmp = A+D; 04884 if ( -tmp >= B ) 04885 { 04886 t = 1; 04887 return DIST(A+C+F+2*(B+D+E)); 04888 } 04889 else 04890 { 04891 t = -tmp/B; 04892 return DIST(A+2*D+F+t*(C*t+2*(B+E))); 04893 } 04894 } 04895 } 04896 else 04897 { 04898 // direction vectors form an acute angle 04899 if ( -D >= A ) 04900 { 04901 s = 1; 04902 t = 0; 04903 return DIST(A+2*D+F); 04904 } 04905 else if ( D <= 0 ) 04906 { 04907 s = -D/A; 04908 t = 0; 04909 return DIST(D*s+F); 04910 } 04911 else 04912 { 04913 E = -Dot(seg1.m,diff); 04914 s = 0; 04915 if ( D >= -B ) 04916 { 04917 t = 1; 04918 return DIST(C+2*E+F); 04919 } 04920 else 04921 { 04922 t = -D/B; 04923 return DIST(F+t*(2*E+C*t)); 04924 } 04925 } 04926 } 04927 } 04928 } 04929 //--------------------------------------------------------------------------- 04930 04931 #ifdef LIN3LIN3_TEST 04932 04933 //#include <stdlib.h> 04934 //#include <fstream.h> 04935 04936 //#define RAND (2.0f*rand()/double(RAND_MAX)-1) 04937 04938 //ofstream ostr("data.txt"); 04939 04940 void TestSegSeg () 04941 { 04942 Line3 seg0, seg1; 04943 Point3 p0, p1, diff; 04944 double s, t, s0, t0, min0, min1, dist; 04945 double maxDiff = 0.0f; 04946 04947 for (int i = 0; i < 128; i++) 04948 { 04949 seg0.b.x = RAND; 04950 seg0.b.y = RAND; 04951 seg0.b.z = RAND; 04952 04953 seg0.m.x = RAND; 04954 seg0.m.y = RAND; 04955 seg0.m.z = RAND; 04956 04957 seg1.b.x = RAND; 04958 seg1.b.y = RAND; 04959 seg1.b.z = RAND; 04960 04961 if ( i % 2 ) 04962 { 04963 // non-parallel line segments 04964 seg1.m.x = RAND; 04965 seg1.m.y = RAND; 04966 seg1.m.z = RAND; 04967 } 04968 else 04969 { 04970 // parallel line segments 04971 double scale = RAND; 04972 seg1.m = scale*seg0.m; 04973 } 04974 04975 min0 = FLT_MAX; 04976 int ymax = 128, xmax = 128; 04977 for (int y = 0; y < ymax; y++) 04978 { 04979 s0 = y/double(ymax-1); 04980 p0 = seg0.b+s0*seg0.m; 04981 for (int x = 0; x < xmax; x++) 04982 { 04983 t0 = x/double(xmax-1); 04984 p1 = seg1.b+t0*seg1.m; 04985 04986 diff = p1-p0; 04987 dist = Length(diff); 04988 if ( dist < min0 ) 04989 { 04990 min0 = dist; 04991 s = s0; 04992 t = t0; 04993 } 04994 } 04995 } 04996 ostr << "sampled = " << s << ' ' << t << ' ' << min0 << endl; 04997 04998 min1 = MinLineSegmentLineSegment(seg0,seg1,s,t); 04999 ostr << "analytic = " << s << ' ' << t << ' ' << min1 << endl; 05000 05001 double compDiff = min1-min0; 05002 ostr << "diff = " << compDiff << endl; 05003 if ( compDiff > maxDiff ) 05004 maxDiff = compDiff; 05005 05006 ostr << endl; 05007 } 05008 ostr << "max diff = " << maxDiff << endl; 05009 } 05010 #endif 05011 05012 // FILE: pt3tri3.cpp 05013 //--------------------------------------------------------------------------- 05014 double 05015 AnalyticGeometryTool::MinPointTriangle (const Point3& p, const Triangle3& tri, 05016 double& s, double& t) 05017 { 05018 Point3 diff = tri.b - p; 05019 double A = Dot(tri.e0,tri.e0); 05020 double B = Dot(tri.e0,tri.e1); 05021 double C = Dot(tri.e1,tri.e1); 05022 double D = Dot(tri.e0,diff); 05023 double E = Dot(tri.e1,diff); 05024 double F = Dot(diff,diff); 05025 double det = Abs(A*C-B*B); // A*C-B*B = |Cross(e0,e1)|^2 >= 0 05026 // A-2*B+C = Dot(e0,e0)-2*Dot(e0,e1)+Dot(e1,e1) = |e0-e1|^2 > 0 05027 05028 s = B*E-C*D; 05029 t = B*D-A*E; 05030 05031 if ( s+t <= det ) 05032 { 05033 if ( s < 0 ) 05034 { 05035 if ( t < 0 ) // region 4 05036 { 05037 if ( D < 0 ) 05038 { 05039 t = 0; 05040 if ( -D >= A ) 05041 { 05042 s = 1; 05043 return DIST(A+2*D+F); 05044 } 05045 else 05046 { 05047 s = -D/A; 05048 return DIST(D*s+F); 05049 } 05050 } 05051 else 05052 { 05053 s = 0; 05054 if ( E >= 0 ) 05055 { 05056 t = 0; 05057 return DIST(F); 05058 } 05059 else if ( -E >= C ) 05060 { 05061 t = 1; 05062 return DIST(C+2*E+F); 05063 } 05064 else 05065 { 05066 t = -E/C; 05067 return DIST(E*t+F); 05068 } 05069 } 05070 } 05071 else // region 3 05072 { 05073 s = 0; 05074 if ( E >= 0 ) 05075 { 05076 t = 0; 05077 return DIST(F); 05078 } 05079 else if ( -E >= C ) 05080 { 05081 t = 1; 05082 return DIST(C+2*E+F); 05083 } 05084 else 05085 { 05086 t = -E/C; 05087 return DIST(E*t+F); 05088 } 05089 } 05090 } 05091 else if ( t < 0 ) // region 5 05092 { 05093 t = 0; 05094 if ( D >= 0 ) 05095 { 05096 s = 0; 05097 return DIST(F); 05098 } 05099 else if ( -D >= A ) 05100 { 05101 s = 1; 05102 return DIST(A+2*D+F); 05103 } 05104 else 05105 { 05106 s = -D/A; 05107 return DIST(D*s+F); 05108 } 05109 } 05110 else // region 0 05111 { 05112 // minimum at interior point 05113 if( det == 0.0 ) 05114 { 05115 //PRINT_WARNING( "Found zero determinant\n" ); 05116 return CUBIT_DBL_MAX; 05117 } 05118 05119 double invDet = 1.0f/det; 05120 s *= invDet; 05121 t *= invDet; 05122 return DIST(s*(A*s+B*t+2*D)+t*(B*s+C*t+2*E)+F); 05123 } 05124 } 05125 else 05126 { 05127 double tmp0, tmp1, numer, denom; 05128 05129 if ( s < 0 ) // region 2 05130 { 05131 tmp0 = B+D; 05132 tmp1 = C+E; 05133 if ( tmp1 > tmp0 ) 05134 { 05135 numer = tmp1 - tmp0; 05136 denom = A-2*B+C; 05137 if ( numer >= denom ) 05138 { 05139 s = 1; 05140 t = 0; 05141 return DIST(A+2*D+F); 05142 } 05143 else 05144 { 05145 s = numer/denom; 05146 t = 1-s; 05147 return DIST(s*(A*s+B*t+2*D)+t*(B*s+C*t+2*E)+F); 05148 } 05149 } 05150 else 05151 { 05152 s = 0; 05153 if ( tmp1 <= 0 ) 05154 { 05155 t = 1; 05156 return DIST(C+2*E+F); 05157 } 05158 else if ( E >= 0 ) 05159 { 05160 t = 0; 05161 return DIST(F); 05162 } 05163 else 05164 { 05165 t = -E/C; 05166 return DIST(E*t+F); 05167 } 05168 } 05169 } 05170 else if ( t < 0 ) // region 6 05171 { 05172 tmp0 = B+E; 05173 tmp1 = A+D; 05174 if ( tmp1 > tmp0 ) 05175 { 05176 numer = tmp1 - tmp0; 05177 denom = A-2*B+C; 05178 if ( numer >= denom ) 05179 { 05180 t = 1; 05181 s = 0; 05182 return DIST(C+2*E+F); 05183 } 05184 else 05185 { 05186 t = numer/denom; 05187 s = 1-t; 05188 return DIST(s*(A*s+B*t+2*D)+t*(B*s+C*t+2*E)+F); 05189 } 05190 } 05191 else 05192 { 05193 t = 0; 05194 if ( tmp1 <= 0 ) 05195 { 05196 s = 1; 05197 return DIST(A+2*D+F); 05198 } 05199 else if ( D >= 0 ) 05200 { 05201 s = 0; 05202 return DIST(F); 05203 } 05204 else 05205 { 05206 s = -D/A; 05207 return DIST(D*s+F); 05208 } 05209 } 05210 } 05211 else // region 1 05212 { 05213 numer = C+E-B-D; 05214 if ( numer <= 0 ) 05215 { 05216 s = 0; 05217 t = 1; 05218 return DIST(C+2*E+F); 05219 } 05220 else 05221 { 05222 denom = A-2*B+C; 05223 if ( numer >= denom ) 05224 { 05225 s = 1; 05226 t = 0; 05227 return DIST(A+2*D+F); 05228 } 05229 else 05230 { 05231 s = numer/denom; 05232 t = 1-s; 05233 return DIST(s*(A*s+B*t+2*D)+t*(B*s+C*t+2*E)+F); 05234 } 05235 } 05236 } 05237 } 05238 } 05239 //--------------------------------------------------------------------------- 05240 05241 #ifdef PT3TRI3_TEST 05242 05243 //#include <float.h> 05244 //#include <fstream.h> 05245 //#include <stdlib.h> 05246 05247 //ofstream ostr("data.txt"); 05248 05249 //#define RAND (2.0f*rand()/double(RAND_MAX)-1) 05250 05251 void main () 05252 { 05253 Triangle3 tri; 05254 Point3 p, q, diff; 05255 double s, t, s0, t0, min0, min1, dist; 05256 05257 double maxdiff = 0; 05258 05259 for (int i = 0; i < 128; i++) 05260 { 05261 tri.b.x = RAND; 05262 tri.b.y = RAND; 05263 tri.b.z = RAND; 05264 tri.e0.x = RAND; 05265 tri.e0.y = RAND; 05266 tri.e0.z = RAND; 05267 tri.e1.x = RAND; 05268 tri.e1.y = RAND; 05269 tri.e1.z = RAND; 05270 05271 p.x = RAND; 05272 p.y = RAND; 05273 p.z = RAND; 05274 05275 min0 = FLT_MAX; 05276 int max = 128; 05277 for (int y = 0; y <= max; y++) 05278 { 05279 s0 = y/double(max); 05280 for (int x = 0; x+y <= max; x++) 05281 { 05282 t0 = x/double(max); 05283 q = tri.b+s0*tri.e0+t0*tri.e1; 05284 05285 diff = p-q; 05286 dist = Length(diff); 05287 if ( dist < min0 ) 05288 { 05289 min0 = dist; 05290 s = s0; 05291 t = t0; 05292 } 05293 } 05294 } 05295 ostr << "sampled = " << s << ' ' << t << ' ' << min0 << endl; 05296 05297 min1 = MinPointTriangle(p,tri,s,t); 05298 ostr << "analytic = " << s << ' ' << t << ' ' << min1 << endl; 05299 05300 ostr << "diff = " << min1-min0 << endl; 05301 05302 if ( min1-min0 > maxdiff ) 05303 maxdiff = min1-min0; 05304 05305 ostr << endl; 05306 } 05307 ostr << "max diff = " << maxdiff << endl; 05308 } 05309 #endif 05310 05311 // FILE: lin3tri3.cpp 05312 //--------------------------------------------------------------------------- 05313 // This code computes the closest points of a line L(r) = a0+r*a1 and a 05314 // triangle Tri(s,t) = b0+s*b1+t*b2, where 0 <= r <= 1 and 0 <= s <= 1, 05315 // 0 <= t <= 1, and 0 <= s+t <= 1. 05316 // 05317 // In calculus terms, the goal is to minimize the squared-distance function 05318 // Q(r,s,t) = Dot(L(r)-Tri(s,t),L(r)-Tri(s,t)) over the prism domain 05319 // 0 <= r <= 1, 0 <= s <= 1, 0 <= t <= 1, 0 <= s+t <= 1. This function is 05320 // 05321 // Q(r,s,t) = [r s t] A [r s t] + 2 B [r s t] + C 05322 // 05323 // where A is a 3x3 symmetric matrix, B is a 3x1 column vector, and C is 05324 // a constant. The entries of A and B are various dot products derived 05325 // from the vectors a0, a1, b0, b1, and b2. 05326 // 05327 // The analysis is similar to that of MinPointTriangle. The (s,t) domain 05328 // is partitioned similarly, but the prism is obtained by extruding the 05329 // domain in the r-direction. The three cases for r are: r < 0, 0 <= r <= 1, 05330 // and r > 1. For each case the partitioning in (s,t) is identical to that 05331 // of MinPointTriangle. The region numbers for r < 0 are appended with an 05332 // 'm' and the region numbers for r > 1 are appended with a 'p'. 05333 //--------------------------------------------------------------------------- 05334 05335 // NOTE: This code is not fully optimized as is the code in pt3lin3, 05336 // pt3tri3, and lin3lin3. 05337 05338 //--------------------------------------------------------------------------- 05339 double 05340 AnalyticGeometryTool::MinLineSegmentTriangle (const Line3& seg, const Triangle3& tri, 05341 double& r, double& s, double& t) 05342 { 05343 Point3 diff = tri.b - seg.b; 05344 double A00 = Dot(seg.m,seg.m); 05345 double A01 = -Dot(seg.m,tri.e0); 05346 double A02 = -Dot(seg.m,tri.e1); 05347 double A11 = Dot(tri.e0,tri.e0); 05348 double A12 = Dot(tri.e0,tri.e1); 05349 double A22 = Dot(tri.e1,tri.e1); 05350 double B0 = -Dot(diff,seg.m); 05351 double B1 = Dot(diff,tri.e0); 05352 double B2 = Dot(diff,tri.e1); 05353 double cof00 = A11*A22-A12*A12; 05354 double cof01 = A02*A12-A01*A22; 05355 double cof02 = A01*A12-A02*A11; 05356 double det = A00*cof00+A01*cof01+A02*cof02; 05357 05358 Line3 triseg; 05359 Point3 pt; 05360 double min, min0, r0, s0, t0; 05361 05362 if ( Abs(det) >= par_tolerance ) 05363 { 05364 double cof11 = A00*A22-A02*A02; 05365 double cof12 = A02*A01-A00*A12; 05366 double cof22 = A00*A11-A01*A01; 05367 double invDet = 1.0f/det; 05368 double rhs0 = -B0*invDet; 05369 double rhs1 = -B1*invDet; 05370 double rhs2 = -B2*invDet; 05371 05372 r = cof00*rhs0+cof01*rhs1+cof02*rhs2; 05373 s = cof01*rhs0+cof11*rhs1+cof12*rhs2; 05374 t = cof02*rhs0+cof12*rhs1+cof22*rhs2; 05375 05376 if ( r < 0 ) 05377 { 05378 if ( s+t <= 1 ) 05379 { 05380 if ( s < 0 ) 05381 { 05382 if ( t < 0 ) // region 4m 05383 { 05384 // min on face s=0 or t=0 or r=0 05385 triseg.b = tri.b; 05386 triseg.m = tri.e1; 05387 min = MinLineSegmentLineSegment(seg,triseg,r,t); 05388 s = 0; 05389 triseg.b = tri.b; 05390 triseg.m = tri.e0; 05391 min0 = MinLineSegmentLineSegment(seg,triseg,r0,s0); 05392 t0 = 0; 05393 if ( min0 < min ) 05394 { 05395 min = min0; 05396 r = r0; 05397 s = s0; 05398 t = t0; 05399 } 05400 min0 = MinPointTriangle(seg.b,tri,s0,t0); 05401 r0 = 0; 05402 if ( min0 < min ) 05403 { 05404 min = min0; 05405 r = r0; 05406 s = s0; 05407 t = t0; 05408 } 05409 } 05410 else // region 3m 05411 { 05412 // min on face s=0 or r=0 05413 triseg.b = tri.b; 05414 triseg.m = tri.e1; 05415 min = MinLineSegmentLineSegment(seg,triseg,r,t); 05416 s = 0; 05417 min0 = MinPointTriangle(seg.b,tri,s0,t0); 05418 r0 = 0; 05419 if ( min0 < min ) 05420 { 05421 min = min0; 05422 r = r0; 05423 s = s0; 05424 t = t0; 05425 } 05426 } 05427 } 05428 else if ( t < 0 ) // region 5m 05429 { 05430 // min on face t=0 or r=0 05431 triseg.b = tri.b; 05432 triseg.m = tri.e0; 05433 min = MinLineSegmentLineSegment(seg,triseg,r,s); 05434 t = 0; 05435 min0 = MinPointTriangle(seg.b,tri,s0,t0); 05436 r0 = 0; 05437 if ( min0 < min ) 05438 { 05439 min = min0; 05440 r = r0; 05441 s = s0; 05442 t = t0; 05443 } 05444 } 05445 else // region 0m 05446 { 05447 // min face on r=0 05448 min = MinPointTriangle(seg.b,tri,s,t); 05449 r = 0; 05450 } 05451 } 05452 else 05453 { 05454 if ( s < 0 ) // region 2m 05455 { 05456 // min on face s=0 or s+t=1 or r=0 05457 triseg.b = tri.b; 05458 triseg.m = tri.e1; 05459 min = MinLineSegmentLineSegment(seg,triseg,r,t); 05460 s = 0; 05461 triseg.b = tri.b+tri.e0; 05462 triseg.m = tri.e1-tri.e0; 05463 min0 = MinLineSegmentLineSegment(seg,triseg,r0,t0); 05464 s0 = 1-t0; 05465 if ( min0 < min ) 05466 { 05467 min = min0; 05468 r = r0; 05469 s = s0; 05470 t = t0; 05471 } 05472 min0 = MinPointTriangle(seg.b,tri,s0,t0); 05473 r0 = 0; 05474 if ( min0 < min ) 05475 { 05476 min = min0; 05477 r = r0; 05478 s = s0; 05479 t = t0; 05480 } 05481 } 05482 else if ( t < 0 ) // region 6m 05483 { 05484 // min on face t=0 or s+t=1 or r=0 05485 triseg.b = tri.b; 05486 triseg.m = tri.e0; 05487 min = MinLineSegmentLineSegment(seg,triseg,r,s); 05488 t = 0; 05489 triseg.b = tri.b+tri.e0; 05490 triseg.m = tri.e1-tri.e0; 05491 min0 = MinLineSegmentLineSegment(seg,triseg,r0,t0); 05492 s0 = 1-t0; 05493 if ( min0 < min ) 05494 { 05495 min = min0; 05496 r = r0; 05497 s = s0; 05498 t = t0; 05499 } 05500 min0 = MinPointTriangle(seg.b,tri,s0,t0); 05501 r0 = 0; 05502 if ( min0 < min ) 05503 { 05504 min = min0; 05505 r = r0; 05506 s = s0; 05507 t = t0; 05508 } 05509 } 05510 else // region 1m 05511 { 05512 // min on face s+t=1 or r=0 05513 triseg.b = tri.b+tri.e0; 05514 triseg.m = tri.e1-tri.e0; 05515 min = MinLineSegmentLineSegment(seg,triseg,r,t); 05516 s = 1-t; 05517 min0 = MinPointTriangle(seg.b,tri,s0,t0); 05518 r0 = 0; 05519 if ( min0 < min ) 05520 { 05521 min = min0; 05522 r = r0; 05523 s = s0; 05524 t = t0; 05525 } 05526 } 05527 } 05528 } 05529 else if ( r <= 1 ) 05530 { 05531 if ( s+t <= 1 ) 05532 { 05533 if ( s < 0 ) 05534 { 05535 if ( t < 0 ) // region 4 05536 { 05537 // min on face s=0 or t=0 05538 triseg.b = tri.b; 05539 triseg.m = tri.e1; 05540 min = MinLineSegmentLineSegment(seg,triseg,r,t); 05541 s = 0; 05542 triseg.b = tri.b; 05543 triseg.m = tri.e0; 05544 min0 = MinLineSegmentLineSegment(seg,triseg,r0,s0); 05545 t0 = 0; 05546 if ( min0 < min ) 05547 { 05548 min = min0; 05549 r = r0; 05550 s = s0; 05551 t = t0; 05552 } 05553 } 05554 else // region 3 05555 { 05556 // min on face s=0 05557 triseg.b = tri.b; 05558 triseg.m = tri.e1; 05559 min = MinLineSegmentLineSegment(seg,triseg,r,t); 05560 s = 0; 05561 } 05562 } 05563 else if ( t < 0 ) // region 5 05564 { 05565 // min on face t=0 05566 triseg.b = tri.b; 05567 triseg.m = tri.e0; 05568 min = MinLineSegmentLineSegment(seg,triseg,r,s); 05569 t = 0; 05570 } 05571 else // region 0 05572 { 05573 // global minimum is interior, done 05574 min = Sqrt(Abs(r*(A00*r+A01*s+A02*t+2.0f*B0) 05575 +s*(A01*r+A11*s+A12*t+2.0f*B1) 05576 +t*(A02*r+A12*s+A22*t+2.0f*B2) 05577 +Dot(diff,diff))); 05578 } 05579 } 05580 else 05581 { 05582 if ( s < 0 ) // region 2 05583 { 05584 // min on face s=0 or s+t=1 05585 triseg.b = tri.b; 05586 triseg.m = tri.e1; 05587 min = MinLineSegmentLineSegment(seg,triseg,r,t); 05588 s = 0; 05589 triseg.b = tri.b+tri.e0; 05590 triseg.m = tri.e1-tri.e0; 05591 min0 = MinLineSegmentLineSegment(seg,triseg,r0,t0); 05592 s0 = 1-t0; 05593 if ( min0 < min ) 05594 { 05595 min = min0; 05596 r = r0; 05597 s = s0; 05598 t = t0; 05599 } 05600 } 05601 else if ( t < 0 ) // region 6 05602 { 05603 // min on face t=0 or s+t=1 05604 triseg.b = tri.b; 05605 triseg.m = tri.e0; 05606 min = MinLineSegmentLineSegment(seg,triseg,r,s); 05607 t = 0; 05608 triseg.b = tri.b+tri.e0; 05609 triseg.m = tri.e1-tri.e0; 05610 min0 = MinLineSegmentLineSegment(seg,triseg,r0,t0); 05611 s0 = 1-t0; 05612 if ( min0 < min ) 05613 { 05614 min = min0; 05615 r = r0; 05616 s = s0; 05617 t = t0; 05618 } 05619 } 05620 else // region 1 05621 { 05622 // min on face s+t=1 05623 triseg.b = tri.b+tri.e0; 05624 triseg.m = tri.e1-tri.e0; 05625 min = MinLineSegmentLineSegment(seg,triseg,r,t); 05626 s = 1-t; 05627 } 05628 } 05629 } 05630 else // r > 1 05631 { 05632 if ( s+t <= 1 ) 05633 { 05634 if ( s < 0 ) 05635 { 05636 if ( t < 0 ) // region 4p 05637 { 05638 // min on face s=0 or t=0 or r=1 05639 triseg.b = tri.b; 05640 triseg.m = tri.e1; 05641 min = MinLineSegmentLineSegment(seg,triseg,r,t); 05642 s = 0; 05643 triseg.b = tri.b; 05644 triseg.m = tri.e0; 05645 min0 = MinLineSegmentLineSegment(seg,triseg,r0,s0); 05646 t0 = 0; 05647 if ( min0 < min ) 05648 { 05649 min = min0; 05650 r = r0; 05651 s = s0; 05652 t = t0; 05653 } 05654 pt = seg.b+seg.m; 05655 min0 = MinPointTriangle(pt,tri,s0,t0); 05656 r0 = 1; 05657 if ( min0 < min ) 05658 { 05659 min = min0; 05660 r = r0; 05661 s = s0; 05662 t = t0; 05663 } 05664 } 05665 else // region 3p 05666 { 05667 // min on face s=0 or r=1 05668 triseg.b = tri.b; 05669 triseg.m = tri.e1; 05670 min = MinLineSegmentLineSegment(seg,triseg,r,t); 05671 s = 0; 05672 pt = seg.b+seg.m; 05673 min0 = MinPointTriangle(pt,tri,s0,t0); 05674 r0 = 1; 05675 if ( min0 < min ) 05676 { 05677 min = min0; 05678 r = r0; 05679 s = s0; 05680 t = t0; 05681 } 05682 } 05683 } 05684 else if ( t < 0 ) // region 5p 05685 { 05686 // min on face t=0 or r=1 05687 triseg.b = tri.b; 05688 triseg.m = tri.e0; 05689 min = MinLineSegmentLineSegment(seg,triseg,r,s); 05690 t = 0; 05691 pt = seg.b+seg.m; 05692 min0 = MinPointTriangle(pt,tri,s0,t0); 05693 r0 = 1; 05694 if ( min0 < min ) 05695 { 05696 min = min0; 05697 r = r0; 05698 s = s0; 05699 t = t0; 05700 } 05701 } 05702 else // region 0p 05703 { 05704 // min face on r=1 05705 pt = seg.b+seg.m; 05706 min = MinPointTriangle(pt,tri,s,t); 05707 r = 1; 05708 } 05709 } 05710 else 05711 { 05712 if ( s < 0 ) // region 2p 05713 { 05714 // min on face s=0 or s+t=1 or r=1 05715 triseg.b = tri.b; 05716 triseg.m = tri.e1; 05717 min = MinLineSegmentLineSegment(seg,triseg,r,t); 05718 s = 0; 05719 triseg.b = tri.b+tri.e0; 05720 triseg.m = tri.e1-tri.e0; 05721 min0 = MinLineSegmentLineSegment(seg,triseg,r0,t0); 05722 s0 = 1-t0; 05723 if ( min0 < min ) 05724 { 05725 min = min0; 05726 r = r0; 05727 s = s0; 05728 t = t0; 05729 } 05730 pt = seg.b+seg.m; 05731 min0 = MinPointTriangle(pt,tri,s0,t0); 05732 r0 = 1; 05733 if ( min0 < min ) 05734 { 05735 min = min0; 05736 r = r0; 05737 s = s0; 05738 t = t0; 05739 } 05740 } 05741 else if ( t < 0 ) // region 6p 05742 { 05743 // min on face t=0 or s+t=1 or r=1 05744 triseg.b = tri.b; 05745 triseg.m = tri.e0; 05746 min = MinLineSegmentLineSegment(seg,triseg,r,s); 05747 t = 0; 05748 triseg.b = tri.b+tri.e0; 05749 triseg.m = tri.e1-tri.e0; 05750 min0 = MinLineSegmentLineSegment(seg,triseg,r0,t0); 05751 s0 = 1-t0; 05752 if ( min0 < min ) 05753 { 05754 min = min0; 05755 r = r0; 05756 s = s0; 05757 t = t0; 05758 } 05759 pt = seg.b+seg.m; 05760 min0 = MinPointTriangle(pt,tri,s0,t0); 05761 r0 = 1; 05762 if ( min0 < min ) 05763 { 05764 min = min0; 05765 r = r0; 05766 s = s0; 05767 t = t0; 05768 } 05769 } 05770 else // region 1p 05771 { 05772 // min on face s+t=1 or r=1 05773 triseg.b = tri.b+tri.e0; 05774 triseg.m = tri.e1-tri.e0; 05775 min = MinLineSegmentLineSegment(seg,triseg,r,t); 05776 s = 1-t; 05777 pt = seg.b+seg.m; 05778 min0 = MinPointTriangle(pt,tri,s0,t0); 05779 r0 = 1; 05780 if ( min0 < min ) 05781 { 05782 min = min0; 05783 r = r0; 05784 s = s0; 05785 t = t0; 05786 } 05787 } 05788 } 05789 } 05790 } 05791 else 05792 { 05793 // line and triangle are parallel 05794 triseg.b = tri.b; 05795 triseg.m = tri.e0; 05796 min = MinLineSegmentLineSegment(seg,triseg,r,s); 05797 t = 0; 05798 05799 triseg.m = tri.e1; 05800 min0 = MinLineSegmentLineSegment(seg,triseg,r0,t0); 05801 s0 = 0; 05802 if ( min0 < min ) 05803 { 05804 min = min0; 05805 r = r0; 05806 s = s0; 05807 t = t0; 05808 } 05809 05810 triseg.b = triseg.b + tri.e0; 05811 triseg.m = triseg.m - tri.e0; 05812 min0 = MinLineSegmentLineSegment(seg,triseg,r0,t0); 05813 s0 = 1-t0; 05814 if ( min0 < min ) 05815 { 05816 min = min0; 05817 r = r0; 05818 s = s0; 05819 t = t0; 05820 } 05821 05822 min0 = MinPointTriangle(seg.b,tri,s0,t0); 05823 r0 = 0; 05824 if ( min0 < min ) 05825 { 05826 min = min0; 05827 r = r0; 05828 s = s0; 05829 t = t0; 05830 } 05831 05832 pt = seg.b+seg.m; 05833 min0 = MinPointTriangle(pt,tri,s0,t0); 05834 r0 = 1; 05835 if ( min0 < min ) 05836 { 05837 min = min0; 05838 r = r0; 05839 s = s0; 05840 t = t0; 05841 } 05842 } 05843 05844 return min; 05845 } 05846 //--------------------------------------------------------------------------- 05847 05848 #ifdef LIN3TRI3_TEST 05849 05850 //#define RAND (2.0f*rand()/float(RAND_MAX)-1) 05851 05852 //ofstream ostr("data.txt"); 05853 05854 void main () 05855 { 05856 Triangle3 tri; 05857 Line3 line; 05858 Point3 p, q, diff; 05859 double r, s, t, r0, s0, t0, min0, min1, dist; 05860 05861 double maxdiff = 0; 05862 05863 for (int i = 0; i < 128; i++) 05864 { 05865 tri.b.x = RAND; 05866 tri.b.y = RAND; 05867 tri.b.z = RAND; 05868 tri.e0.x = RAND; 05869 tri.e0.y = RAND; 05870 tri.e0.z = RAND; 05871 tri.e1.x = RAND; 05872 tri.e1.y = RAND; 05873 tri.e1.z = RAND; 05874 05875 line.b.x = RAND; 05876 line.b.y = RAND; 05877 line.b.z = RAND; 05878 if ( i % 2 ) 05879 { 05880 // non-parallel line and triangle 05881 line.m.x = RAND; 05882 line.m.y = RAND; 05883 line.m.z = RAND; 05884 } 05885 else 05886 { 05887 // line is parallel to triangle 05888 double c0 = RAND; 05889 double c1 = RAND; 05890 line.m = c0*tri.e0+c1*tri.e1; 05891 } 05892 05893 min0 = FLT_MAX; 05894 int max = 32; 05895 for (int z = 0; z <= max; z++) 05896 { 05897 r0 = z/double(max); 05898 p = line.b+r0*line.m; 05899 for (int y = 0; y <= max; y++) 05900 { 05901 s0 = y/double(max); 05902 for (int x = 0; x+y <= max; x++) 05903 { 05904 t0 = x/double(max); 05905 q = tri.b+s0*tri.e0+t0*tri.e1; 05906 05907 diff = p-q; 05908 dist = Length(diff); 05909 if ( dist < min0 ) 05910 { 05911 min0 = dist; 05912 r = r0; 05913 s = s0; 05914 t = t0; 05915 } 05916 } 05917 } 05918 } 05919 ostr << "i = " << i << endl; 05920 ostr << "sampled = " << r << ' ' << s << ' ' << t << ' ' 05921 << min0 << endl; 05922 05923 min1 = MinLineSegmentTriangle(line,tri,r,s,t); 05924 ostr << "analytic = " << r << ' ' << s << ' ' << t << ' ' 05925 << min1 << endl; 05926 05927 ostr << "diff = " << min1-min0 << endl; 05928 05929 if ( min1-min0 > maxdiff ) 05930 maxdiff = min1-min0; 05931 05932 ostr << endl; 05933 } 05934 05935 ostr << "max diff = " << maxdiff << endl; 05936 } 05937 #endif 05938 05939 //FILE: triasect.cpp 05940 //--------------------------------------------------------------------------- 05941 AgtLine 05942 AnalyticGeometryTool::EdgeToLine (Point2* v0, Point2* v1) 05943 { 05944 // assert: v0 and v1 are distinct 05945 05946 Point2 edge = { v1->x - v0->x, v1->y - v0->y }; 05947 05948 AgtLine line; 05949 line.N.x = edge.y; 05950 line.N.y = -edge.x; 05951 line.c = line.N.x*v0->x + line.N.y*v0->y; 05952 05953 return line; 05954 } 05955 //--------------------------------------------------------------------------- 05956 void 05957 AnalyticGeometryTool::TriangleLines (Triangle* T, AgtLine line[3]) 05958 { 05959 line[0] = EdgeToLine(&T->v[0],&T->v[1]); 05960 line[1] = EdgeToLine(&T->v[0],&T->v[2]); 05961 line[2] = EdgeToLine(&T->v[1],&T->v[2]); 05962 05963 // make sure normals point outwards 05964 Point2 avr = { 0.0, 0.0 }; 05965 int i; 05966 for (i = 0; i < 3; i++) 05967 { 05968 avr.x += T->v[i].x; 05969 avr.y += T->v[i].y; 05970 } 05971 static double oneThird = 1.0/3.0; 05972 avr.x *= oneThird; 05973 avr.y *= oneThird; 05974 05975 for (i = 0; i < 3; i++) 05976 { 05977 double dot = line[i].N.x*avr.x+line[i].N.y*avr.y-line[i].c; 05978 if ( dot > 0.0 ) 05979 { 05980 line[i].N.x = -line[i].N.x; 05981 line[i].N.y = -line[i].N.y; 05982 line[i].c = -line[i].c; 05983 } 05984 } 05985 } 05986 //--------------------------------------------------------------------------- 05987 AgtTriList* 05988 AnalyticGeometryTool::SplitAndDecompose (Triangle* T, AgtLine* line) 05989 { 05990 double c[3]; 05991 int positive = 0, ip[3]; 05992 int negative = 0, in[3]; 05993 int i; 05994 for (i = 0; i < 3; i++) 05995 { 05996 c[i] = line->N.x*T->v[i].x + line->N.y*T->v[i].y - line->c; 05997 if ( c[i] > 0.0 ) 05998 { 05999 ip[positive++] = i; 06000 } 06001 else if ( c[i] < 0.0 ) 06002 { 06003 in[negative++] = i; 06004 } 06005 } 06006 06007 // For a split to occur, one of the c_i must be positive and one must 06008 // be negative. 06009 AgtTriList* list = NULL; 06010 06011 if ( negative == 0 ) // T is completely on the positive side of line 06012 return 0; 06013 06014 if ( positive == 0 ) 06015 { 06016 // T is completely on the negative side of line 06017 list = new AgtTriList; 06018 list->tri = T; 06019 list->next = 0; 06020 return list; 06021 } 06022 06023 // T is split by line. Determine how it is split and how to decompose 06024 // the negative-side portion into triangles (3 cases). 06025 double w0, w1, cdiff; 06026 Point2 intrp[2]; 06027 06028 if ( positive == 2 ) 06029 { 06030 // ++- 06031 for (i = 0; i < 2 /* = positive */; i++) 06032 { 06033 cdiff = c[ip[i]]-c[in[0]]; 06034 w0 = -c[in[0]]/cdiff; 06035 w1 = c[ip[i]]/cdiff; 06036 T->v[ip[i]].x = w0*T->v[ip[i]].x+w1*T->v[in[0]].x; 06037 T->v[ip[i]].y = w0*T->v[ip[i]].y+w1*T->v[in[0]].y; 06038 } 06039 list = new AgtTriList; 06040 list->tri = T; 06041 list->next = 0; 06042 } 06043 else if ( positive == 1 ) 06044 { 06045 if ( negative == 2 ) 06046 { 06047 // +-- 06048 for (i = 0; i < 2 /* = negative */; i++) 06049 { 06050 cdiff = c[ip[0]]-c[in[i]]; 06051 w0 = -c[in[i]]/cdiff; 06052 w1 = c[ip[0]]/cdiff; 06053 intrp[i].x = w0*T->v[ip[0]].x+w1*T->v[in[i]].x; 06054 intrp[i].y = w0*T->v[ip[0]].y+w1*T->v[in[i]].y; 06055 } 06056 06057 T->v[ip[0]] = intrp[0]; 06058 list = new AgtTriList; 06059 list->tri = T; 06060 06061 Triangle* T1 = new Triangle; 06062 T1->v[0] = intrp[0]; 06063 T1->v[1] = T->v[in[1]]; 06064 T1->v[2] = intrp[1]; 06065 list->next = new AgtTriList; 06066 list->next->tri = T1; 06067 list->next->next = 0; 06068 } 06069 else 06070 { 06071 // +-0 06072 cdiff = c[ip[0]]-c[in[0]]; 06073 w0 = -c[in[0]]/cdiff; 06074 w1 = c[ip[0]]/cdiff; 06075 T->v[ip[0]].x = w0*T->v[ip[0]].x+w1*T->v[in[0]].x; 06076 T->v[ip[0]].y = w0*T->v[ip[0]].y+w1*T->v[in[0]].y; 06077 list = new AgtTriList; 06078 list->tri = T; 06079 list->next = 0; 06080 } 06081 } 06082 06083 return list; 06084 } 06085 //--------------------------------------------------------------------------- 06086 AgtTriList* 06087 AnalyticGeometryTool::Intersection (Triangle* T0, Triangle* T1) 06088 { 06089 // build edges of T0 06090 AgtLine line[3]; 06091 TriangleLines(T0,line); 06092 06093 // initial list is copy of T1 (since triangle may be deleted) 06094 AgtTriList* list = new AgtTriList; 06095 list->tri = new Triangle; 06096 memcpy(list->tri,T1,sizeof(Triangle)); 06097 list->next = 0; 06098 06099 // process subtriangles of T1 against lines of T0 06100 for (int i = 0; i < 3; i++) 06101 { 06102 AgtTriList* save = 0; 06103 while ( list ) 06104 { 06105 // get head of list 06106 Triangle* T = list->tri; 06107 06108 AgtTriList* sad = SplitAndDecompose(T,&line[i]); 06109 if ( sad ) 06110 { 06111 // search for end of list 06112 AgtTriList* end = sad; 06113 while ( end->next ) 06114 end = end->next; 06115 06116 // attach decomposition to front of save-list 06117 end->next = save; 06118 save = sad; 06119 } 06120 06121 // remove head of list 06122 AgtTriList* tmp = list; 06123 list = list->next; 06124 06125 if( sad == NULL ) 06126 delete tmp->tri; 06127 delete tmp; 06128 } 06129 list = save; 06130 } 06131 06132 return list; 06133 } 06134 //--------------------------------------------------------------------------- 06135 double 06136 AnalyticGeometryTool::AreaTriangle (Triangle* T) 06137 { 06138 Point2 e1 = { T->v[1].x - T->v[0].x, T->v[1].y - T->v[0].y }; 06139 Point2 e2 = { T->v[2].x - T->v[0].x, T->v[2].y - T->v[0].y }; 06140 06141 return fabs(0.5*(e1.x*e2.y-e1.y*e2.x)); 06142 } 06143 //--------------------------------------------------------------------------- 06144 double 06145 AnalyticGeometryTool::Area (AgtTriList* list) 06146 { 06147 double area = 0.0; 06148 06149 while ( list ) 06150 { 06151 area += AreaTriangle(list->tri); 06152 list = list->next; 06153 } 06154 06155 return area; 06156 } 06157 //--------------------------------------------------------------------------- 06158 06159 double 06160 AnalyticGeometryTool::AreaIntersection( Triangle &tri1, Triangle &tri2 ) 06161 { 06162 AgtTriList* list = Intersection(&tri1,&tri2); 06163 double area = Area(list); 06164 while ( list ) 06165 { 06166 AgtTriList* save = list; 06167 list = list->next; 06168 delete save->tri; 06169 delete save; 06170 } 06171 delete list; 06172 return area; 06173 } 06174 06175 #ifdef TRIASECT_TEST 06176 06177 void main () 06178 { 06179 Triangle T0; 06180 T0.v[0].x = 0.0; T0.v[0].y = 0.0; 06181 T0.v[1].x = 1.0; T0.v[1].y = 0.0; 06182 T0.v[2].x = 0.0; T0.v[2].y = 1.0; 06183 06184 Triangle T1; 06185 const double eps = 0.001; 06186 T1.v[0].x = 0.5+eps; T1.v[0].y = 0.5+eps; 06187 T1.v[1].x = -eps; T1.v[1].y = 0.5; 06188 T1.v[2].x = 0.5; T1.v[2].y = -eps; 06189 06190 AgtTriList* list = Intersection(&T0,&T1); 06191 double area = Area(list); 06192 06193 while ( list ) 06194 { 06195 AgtTriList* save = list; 06196 list = list->next; 06197 delete save->tri; 06198 delete save; 06199 } 06200 } 06201 #endif 06202 06203 double 06204 AnalyticGeometryTool::Angle( Triangle3& tri1, Triangle3& tri2 ) 06205 { 06206 double norm1[3]; 06207 Normal( tri1, norm1 ); 06208 06209 double norm2[3]; 06210 Normal( tri2, norm2 ); 06211 06212 return angle_vec_vec( norm1, norm2 ); 06213 } 06214 06215 06216 void 06217 AnalyticGeometryTool::Normal( Triangle3& tri, double normal[3] ) 06218 { 06219 double vec1[3]; 06220 vec1[0]=tri.e0.x; vec1[1]=tri.e0.y; vec1[2]=tri.e0.z; 06221 06222 double vec2[3]; 06223 vec2[0]=tri.e1.x; vec2[1]=tri.e1.y; vec2[2]=tri.e1.z; 06224 06225 cross_vec_unit( vec1, vec2, normal ); 06226 } 06227 06228 double 06229 AnalyticGeometryTool::ProjectedOverlap( Triangle3& tri1, Triangle3& tri2, bool draw_overlap ) 06230 { 06231 // Transform both triangles into local coordinate system of tri1 06232 // to eliminate z-coordinate. 06233 06234 // Use normal as z-axis 06235 double z[3]; 06236 Normal( tri1, z ); 06237 06238 // x-axis goes from b to e0 06239 double x[3]; 06240 x[0] = tri1.e0.x; 06241 x[1] = tri1.e0.y; 06242 x[2] = tri1.e0.z; 06243 06244 // Cross z with x to get y-axis 06245 double y[3]; 06246 cross_vec( z, x, y ); 06247 06248 // Unitize them all 06249 unit_vec( x, x ); 06250 unit_vec( y, y ); 06251 unit_vec( z, z ); 06252 06253 double origin[3]; 06254 origin[0] = tri1.b.x; 06255 origin[1] = tri1.b.y; 06256 origin[2] = tri1.b.z; 06257 06258 double mtxTriOne2Global[4][4]; 06259 vecs_to_mtx( x, y, z, origin, mtxTriOne2Global ); // Really mtxTriOne2Global 06260 double mtxGlobal2TriOne[4][4]; 06261 inv_trans_mtx( mtxTriOne2Global, mtxGlobal2TriOne ); 06262 06263 double v0[3], v1[3], v2[3]; // Vertices of triangle 06264 v0[0]=tri1.b.x; v0[1]=tri1.b.y; v0[2]=tri1.b.z; 06265 v1[0]=tri1.e0.x+tri1.b.x; v1[1]=tri1.e0.y+tri1.b.y; v1[2]=tri1.e0.z+tri1.b.z; 06266 v2[0]=tri1.e1.x+tri1.b.x; v2[1]=tri1.e1.y+tri1.b.y; v2[2]=tri1.e1.z+tri1.b.z; 06267 transform_pnt( mtxGlobal2TriOne, v0, v0 ); 06268 transform_pnt( mtxGlobal2TriOne, v1, v1 ); 06269 transform_pnt( mtxGlobal2TriOne, v2, v2 ); 06270 06271 // Load this into a 2D triangle T1 ( z-axis is now zero ) 06272 Triangle T1; 06273 T1.v[0].x = v0[0]; T1.v[0].y = v0[1]; 06274 T1.v[1].x = v1[0]; T1.v[1].y = v1[1]; 06275 T1.v[2].x = v2[0]; T1.v[2].y = v2[1]; 06276 06277 // Setup the next triangle, in this coordinate system 06278 v0[0]=tri2.b.x; v0[1]=tri2.b.y; v0[2]=tri2.b.z; 06279 v1[0]=tri2.e0.x+tri2.b.x; v1[1]=tri2.e0.y+tri2.b.y; v1[2]=tri2.e0.z+tri2.b.z; 06280 v2[0]=tri2.e1.x+tri2.b.x; v2[1]=tri2.e1.y+tri2.b.y; v2[2]=tri2.e1.z+tri2.b.z; 06281 06282 // The following creates coordinates of tri2 in tri1's csys 06283 transform_pnt( mtxGlobal2TriOne, v0, v0 ); 06284 transform_pnt( mtxGlobal2TriOne, v1, v1 ); 06285 transform_pnt( mtxGlobal2TriOne, v2, v2 ); 06286 06287 // Now we can project tri2 to tri1 simply by dropping the z-coordinate 06288 Triangle T2; 06289 T2.v[0].x = v0[0]; T2.v[0].y = v0[1]; 06290 T2.v[1].x = v1[0]; T2.v[1].y = v1[1]; 06291 T2.v[2].x = v2[0]; T2.v[2].y = v2[1]; 06292 06293 // Now find area of overlap 06294 if( draw_overlap ) 06295 { 06296 AgtTriList* list = Intersection(&T1, &T2); 06297 double overlap_area = Area(list); 06298 while ( list ) 06299 { 06300 Triangle *tmp_tri = list->tri; 06301 06302 v0[0]=tmp_tri->v[0].x; 06303 v0[1]=tmp_tri->v[0].y; 06304 v0[2]=0; 06305 06306 v1[0]=tmp_tri->v[1].x; 06307 v1[1]=tmp_tri->v[1].y; 06308 v1[2]=0; 06309 06310 v2[0]=tmp_tri->v[2].x; 06311 v2[1]=tmp_tri->v[2].y; 06312 v2[2]=0; 06313 06314 transform_pnt( mtxTriOne2Global, v0, v0 ); 06315 transform_pnt( mtxTriOne2Global, v1, v1 ); 06316 transform_pnt( mtxTriOne2Global, v2, v2 ); 06317 06318 //Now Draw the thing 06319 GMem g_mem; 06320 g_mem.allocate_tri(1); 06321 g_mem.pointListCount = 3; 06322 06323 g_mem.point_list()[0].x = v0[0]; 06324 g_mem.point_list()[0].y = v0[1]; 06325 g_mem.point_list()[0].z = v0[2]; 06326 06327 g_mem.point_list()[1].x = v1[0]; 06328 g_mem.point_list()[1].y = v1[1]; 06329 g_mem.point_list()[1].z = v1[2]; 06330 06331 g_mem.point_list()[2].x = v2[0]; 06332 g_mem.point_list()[2].y = v2[1]; 06333 g_mem.point_list()[2].z = v2[2]; 06334 06335 g_mem.facet_list()[0] = 3; 06336 g_mem.facet_list()[1] = 0; 06337 g_mem.facet_list()[2] = 1; 06338 g_mem.facet_list()[3] = 2; 06339 06340 g_mem.fListCount = 1; 06341 GfxPreview::draw_polygon(g_mem.point_list(),3,4,4,true); 06342 06343 AgtTriList* save = list; 06344 list = list->next; 06345 delete save->tri; 06346 delete save; 06347 } 06348 delete list; 06349 return overlap_area; 06350 } 06351 else 06352 return AreaIntersection( T1, T2 ); 06353 }
