cgma
00001 //------------------------------------------------------------------------- 00002 // Filename : CAActuateSet.cpp 00003 // 00004 // Purpose : Maintain the list of entities for which attributes are 00005 // being actuated such that any entities destroyed 00006 // during actuation (e.g. merging) get removed from the 00007 // list. 00008 // 00009 // Special Notes : 00010 // 00011 // Creator : Jason Kraftcheck 00012 // 00013 // Creation Date : 05/28/02 00014 //------------------------------------------------------------------------- 00015 00016 #include "CAActuateSet.hpp" 00017 #include "RefEntity.hpp" 00018 #include "ModelQueryEngine.hpp" 00019 #include "Body.hpp" 00020 #include "BasicTopologyEntity.hpp" 00021 #include "AppUtil.hpp" 00022 #include "GeometryEvent.hpp" 00023 00024 #include "RefFace.hpp" 00025 #include "RefEdge.hpp" 00026 #include "RefVertex.hpp" 00027 #include "RefVolume.hpp" 00028 #include "RefGroup.hpp" 00029 00030 //------------------------------------------------------------------------- 00031 // Purpose : Constructor 00032 // 00033 // Special Notes : 00034 // 00035 // Creator : Jason Kraftcheck 00036 // 00037 // Creation Date : 05/28/02 00038 //------------------------------------------------------------------------- 00039 CAActuateSet::CAActuateSet( DLIList<RefEntity*>& actuate_list ) 00040 : currentDimension(-1) 00041 { 00042 // register this as a static observer so that we can 00043 // remove entities from the lists as they are destroyed 00044 AppUtil::instance()->event_dispatcher().add_observer(this); 00045 00046 // put all entities in the actuate_list into the typeList 00047 // for the appropriate dimension of entity. 00048 for( int i = actuate_list.size(); i--; ) 00049 { 00050 RefEntity* entity_ptr = actuate_list.get_and_step(); 00051 int dimension = entity_ptr->dimension(); 00052 if( dimension < 0 ) // body 00053 dimension = 4; 00054 typeList[dimension].append( entity_ptr ); 00055 } 00056 } 00057 00058 //------------------------------------------------------------------------- 00059 // Purpose : Destructor 00060 // 00061 // Special Notes : 00062 // 00063 // Creator : Jason Kraftcheck 00064 // 00065 // Creation Date : 05/28/02 00066 //------------------------------------------------------------------------- 00067 CAActuateSet::~CAActuateSet() 00068 { 00069 // remove from static observer list 00070 00071 AppUtil::instance()->event_dispatcher().remove_observer(this); 00072 } 00073 00074 //------------------------------------------------------------------------- 00075 // Purpose : Populate currentList with entities of the specified 00076 // dimension. This includes children of any entities 00077 // of a higher dimension that are in the lists managed 00078 // by this object. 00079 // 00080 // Special Notes : 00081 // 00082 // Creator : Jason Kraftcheck 00083 // 00084 // Creation Date : 05/28/02 00085 //------------------------------------------------------------------------- 00086 void CAActuateSet::set_current_dimension( int dimension ) 00087 { 00088 int i; 00089 DLIList<TopologyEntity*> query_source, query_target; 00090 DLIList<RefEntity*> temp_list; 00091 00092 // Clean out current list before adding new entities 00093 currentList.clean_out(); 00094 00095 // Get the target type to query for. 00096 DagType type = get_type_id( dimension ); 00097 00098 // Get children of higher-order entities 00099 for( i = 4; i > dimension; i-- ) 00100 { 00101 query_source.clean_out(); 00102 query_target.clean_out(); 00103 00104 CAST_LIST( typeList[i], query_source, TopologyEntity ); 00105 ModelQueryEngine::instance() 00106 ->query_model( query_source, type, query_target ); 00107 00108 temp_list.clean_out(); 00109 CAST_LIST( query_target, temp_list, RefEntity ); 00110 00111 append_to_current( temp_list ); 00112 } 00113 00114 // Add lcoal entities of current dimension 00115 append_to_current( typeList[dimension] ); 00116 00117 // Save current dimension 00118 currentDimension = dimension; 00119 } 00120 00121 //------------------------------------------------------------------------- 00122 // Purpose : Add entities to currentList 00123 // 00124 // Special Notes : Make sure no duplicates are added 00125 // 00126 // Creator : Jason Kraftcheck 00127 // 00128 // Creation Date : 05/28/02 00129 //------------------------------------------------------------------------- 00130 void CAActuateSet::append_to_current( DLIList<RefEntity*>& list ) 00131 { 00132 int i; 00133 00134 // Set marks on all new entities 00135 for( i = list.size(); i--; ) 00136 list.get_and_step()->marked(1); 00137 00138 // Clear marks on entities in current list, 00139 // including those also in the new list. 00140 for( i = currentList.size(); i--; ) 00141 currentList.get_and_step()->marked(0); 00142 00143 // Any entities in the new list that are still 00144 // marked are not already in the current list. 00145 // Add them. 00146 for( i = list.size(); i--; ) 00147 { 00148 RefEntity* entity_ptr = list.get_and_step(); 00149 if( entity_ptr->marked() ) 00150 { 00151 currentList.append( entity_ptr ); 00152 entity_ptr->marked(0); 00153 } 00154 } 00155 } 00156 00157 //------------------------------------------------------------------------- 00158 // Purpose : Remove deleted entities from lists 00159 // 00160 // Special Notes : 00161 // 00162 // Creator : Jason Kraftcheck 00163 // 00164 // Creation Date : 05/28/02 00165 //------------------------------------------------------------------------- 00166 void CAActuateSet::notify_observer( const CubitEvent* observer_event) 00167 { 00168 RefEntity* entity_ptr; 00169 int dimension; 00170 00171 const GeometryEvent* geom_event = dynamic_cast<const GeometryEvent*>(observer_event); 00172 00173 // only care about entities that are destroyed 00174 if(!geom_event || geom_event->get_type() != GeometryEvent::TOPOLOGY_ENTITY_DESTRUCTED) 00175 return; 00176 00177 00178 // is it a body? 00179 if( (entity_ptr = dynamic_cast<Body*>(geom_event->get_entity()) ) != NULL ) 00180 dimension = 4; 00181 00182 // is it some other topology entity 00183 else if( (entity_ptr = dynamic_cast<BasicTopologyEntity*>(geom_event->get_entity()) ) 00184 != NULL ) 00185 dimension = entity_ptr->dimension(); 00186 00187 // otherwise we don't care about it 00188 else 00189 return; 00190 00191 00192 // if it exists in the type list, remove it 00193 if( typeList[dimension].move_to( entity_ptr ) ) 00194 typeList[dimension].extract(); 00195 00196 // if it exists in the current list, remove it. 00197 if( dimension == currentDimension && 00198 currentList.move_to( entity_ptr ) ) 00199 currentList.extract(); 00200 00201 } 00202 00203 DagType CAActuateSet::get_type_id( int dimension ) 00204 { 00205 switch( dimension ) 00206 { 00207 case 4: return DagType::body_type(); 00208 case 3: return DagType::ref_volume_type(); 00209 case 2: return DagType::ref_face_type(); 00210 case 1: return DagType::ref_edge_type(); 00211 case 0: return DagType::ref_vertex_type(); 00212 default: assert(0); 00213 return DagType::invalid_type(); 00214 } 00215 }
