cgma
00001 //- File: CAEntityColor.cpp 00002 //- Owner: Joel Kopp 00003 //- Description: Cubit Attribute for entity colors. 00004 //- Checked By: 00005 //- Version: 00006 00007 #include "CAEntityColor.hpp" 00008 #include "RefEntity.hpp" 00009 #include "RefVolume.hpp" 00010 #include "CastTo.hpp" 00011 #include "CubitMessage.hpp" 00012 00013 CubitAttrib* CAEntityColor_creator(RefEntity* entity, const CubitSimpleAttrib &p_csa) 00014 { 00015 return new CAEntityColor(entity, p_csa); 00016 } 00017 00018 CAEntityColor::CAEntityColor(RefEntity* new_attrib_owner, 00019 const CubitSimpleAttrib &csa_ptr) 00020 : CubitAttrib(new_attrib_owner) 00021 { 00022 entityColor = 0; 00023 00024 if(!csa_ptr.isEmpty()) 00025 { 00026 const std::vector<int>& i_list = csa_ptr.int_data_list(); 00027 assert(i_list.size() > 0); 00028 entityColor = i_list[0]; 00029 } 00030 } 00031 00032 CAEntityColor::~CAEntityColor() 00033 { 00034 } 00035 00036 00037 CubitStatus CAEntityColor::actuate() 00038 { 00039 if ( hasActuated) 00040 return CUBIT_SUCCESS; 00041 00042 if ( !attribOwnerEntity ) 00043 return CUBIT_FAILURE; 00044 00045 deleteAttrib = CUBIT_FALSE; 00046 00047 //- If actuating after import, change the color. Else (auto actuated) color is already changed... 00048 if( attribOwnerEntity->color() == CUBIT_DEFAULT_COLOR_INDEX || 00049 dynamic_cast<RefVolume*>(attribOwnerEntity) ) 00050 { 00051 attribOwnerEntity->color(entityColor); 00052 } 00053 00054 hasActuated = CUBIT_TRUE; 00055 return CUBIT_SUCCESS; 00056 } 00057 00058 CubitStatus CAEntityColor::update() 00059 { 00060 delete_attrib(CUBIT_TRUE); 00061 return CUBIT_SUCCESS; 00062 00063 /* 00064 if ( hasUpdated ) 00065 return CUBIT_SUCCESS; 00066 00067 if ( !attribOwnerEntity) 00068 return CUBIT_FAILURE; 00069 00070 entityColor = attribOwnerEntity->color(); 00071 00072 // set the updated flag 00073 hasUpdated = CUBIT_TRUE; 00074 00075 if( entityColor == -1 ) 00076 { 00077 delete_attrib(CUBIT_TRUE); 00078 return CUBIT_SUCCESS; 00079 } 00080 00081 return CUBIT_SUCCESS; 00082 */ 00083 } 00084 00085 void CAEntityColor::merge_owner(CubitAttrib *deletable_attrib) 00086 { 00087 // take the id with the lowest value 00088 CAEntityColor *other_caecolor = CAST_TO(deletable_attrib, CAEntityColor); 00089 00090 if (other_caecolor) 00091 entityColor = other_caecolor->color(); 00092 } 00093 00094 CubitSimpleAttrib CAEntityColor::cubit_simple_attrib() 00095 { 00096 std::vector<CubitString> cs_list; 00097 std::vector<int> i_list; 00098 00099 i_list.push_back ( entityColor ); 00100 00101 cs_list.push_back(att_internal_name()); 00102 00103 return CubitSimpleAttrib(&cs_list, NULL, &i_list); 00104 } 00105 00106 void CAEntityColor::print() 00107 { 00108 // print info on this attribute 00109 00110 PRINT_INFO("CAEntityColor: owner = %s %d: color ", 00111 attribOwnerEntity->class_name(), attribOwnerEntity->id()); 00112 if ( entityColor > -1 ) 00113 PRINT_INFO(" %d\n", 00114 entityColor); 00115 else 00116 PRINT_INFO("\n"); 00117 }
