cgma
00001 //- Class: CAEntityName 00002 //- Owner: Greg Nielson 00003 //- Description: Cubit Attribute for entity names. 00004 //- Checked By: 00005 //- Version: 00006 00007 #include "CAEntityName.hpp" 00008 #include "BasicTopologyEntity.hpp" 00009 #include "Body.hpp" 00010 #include "RefEntityName.hpp" 00011 #include "CastTo.hpp" 00012 #include "CubitMessage.hpp" 00013 00014 CubitAttrib* CAEntityName_creator(RefEntity* entity, const CubitSimpleAttrib &p_csa) 00015 { 00016 return new CAEntityName(entity, p_csa); 00017 } 00018 00019 CAEntityName::CAEntityName(RefEntity* new_attrib_owner, 00020 const CubitSimpleAttrib &csa_ptr) 00021 : CubitAttrib(new_attrib_owner) 00022 { 00023 if(!csa_ptr.isEmpty()) 00024 { 00025 PRINT_DEBUG_94( "Creating ENTITY_NAME attribute from CSA for %s %d\n", 00026 (attribOwnerEntity ? attribOwnerEntity->class_name() : "(none)"), 00027 (attribOwnerEntity ? attribOwnerEntity->id() : 0)); 00028 00029 const std::vector<CubitString>& cs_list = csa_ptr.string_data_list(); 00030 00031 // step over the attribute type 00032 00033 // now read name / option pairs 00034 for (size_t i = 1; i<cs_list.size(); i++) 00035 { 00036 CubitString cs = cs_list[i]; 00037 if (cs.length() == 0) 00038 PRINT_WARNING("Empty name attribute for %s %d.\n", 00039 attribOwnerEntity->class_name(), 00040 attribOwnerEntity->id()); 00041 else 00042 entityNames.append(cs); 00043 } 00044 00045 if (entityNames.size() == 0) 00046 deleteAttrib = CUBIT_TRUE; 00047 } 00048 } 00049 00050 CAEntityName::~CAEntityName() 00051 { 00052 PRINT_DEBUG_94("Deleting ENTITY_NAME attribute\n"); 00053 } 00054 00055 CubitStatus CAEntityName::actuate() 00056 { 00057 if (hasActuated == CUBIT_TRUE) return CUBIT_SUCCESS; 00058 00059 PRINT_DEBUG_94( "Actuating ENTITY_NAME attribute for %s %d\n", 00060 attribOwnerEntity->class_name(), attribOwnerEntity->id()); 00061 00062 entityNames.reset(); 00063 00064 CubitBoolean update_attribs = (CubitBoolean) 00065 (RefEntityName::instance()->get_generate_default_names()!=1); 00066 00067 RefEntityName::instance()->add_refentity_name(attribOwnerEntity,entityNames, 00068 update_attribs); 00069 00070 hasActuated = CUBIT_TRUE; 00071 return CUBIT_SUCCESS; 00072 } 00073 00074 CubitStatus CAEntityName::update() 00075 { 00076 if (hasUpdated) return CUBIT_SUCCESS; 00077 00078 PRINT_DEBUG_94( "Updating ENTITY_NAME attribute for %s %d\n", 00079 attribOwnerEntity->class_name(), attribOwnerEntity->id()); 00080 00081 // set the updated flag 00082 hasUpdated = CUBIT_TRUE; 00083 00084 // first, remove this attrib in its old form from the geometry entity 00085 if (hasWritten == CUBIT_TRUE) { 00086 attribOwnerEntity->remove_attrib_geometry_entity(this); 00087 hasWritten = CUBIT_FALSE; 00088 } 00089 00090 DLIList<CubitString> names; 00091 int num_names = RefEntityName::instance()-> 00092 get_refentity_name(attribOwnerEntity,names); 00093 if( num_names == 0) 00094 { 00095 delete_attrib(CUBIT_TRUE); 00096 return CUBIT_SUCCESS; 00097 } 00098 else 00099 { 00100 // get the names; since RefEntityName passes back pointers to 00101 // its own strings, create new ones here 00102 int i; 00103 00104 // first, delete all the old names on the list 00105 entityNames.clean_out(); 00106 00107 for (i = names.size(); i > 0; i--) { 00108 entityNames.append(names.get_and_step()); 00109 } 00110 00111 // reset the delete flag if it was set before 00112 delete_attrib(CUBIT_FALSE); 00113 00114 // now, write to geometry entity 00115 attribOwnerEntity->write_specific_cubit_attrib(this); 00116 } 00117 return CUBIT_SUCCESS; 00118 } 00119 00120 CubitStatus CAEntityName::reset() 00121 { 00122 PRINT_DEBUG_94("CAEntityName::reset()\n"); 00123 00124 //- reset function, cleans out name list 00125 entityNames.clean_out(); 00126 00127 // need to reset hasUpdated flag too, so next update will do something 00128 hasUpdated = CUBIT_FALSE; 00129 return CUBIT_SUCCESS; 00130 } 00131 00132 CubitSimpleAttrib CAEntityName::split_owner() 00133 { 00134 // if this entity is to be split, pass back a simple attribute with 00135 // duplicate name data to be put on new entity 00136 PRINT_DEBUG_94("CAEntityName::split_owner()\n"); 00137 update(); 00138 if( deleteAttrib ) 00139 return CubitSimpleAttrib(); 00140 else 00141 return cubit_simple_attrib(); 00142 } 00143 00144 void CAEntityName::merge_owner(CubitAttrib *deletable_attrib) 00145 { 00146 // if this entity is to be merged, copy names over from deletable entity 00147 CAEntityName *caen_ptr = CAST_TO(deletable_attrib, CAEntityName); 00148 if (caen_ptr) 00149 { 00150 DLIList<CubitString> &other_names = caen_ptr->entityNames; 00151 other_names.reset(); 00152 for (int i = other_names.size(); i--; ) 00153 { 00154 entityNames.append(other_names.get_and_step()); 00155 } 00156 } 00157 } 00158 00159 CubitSimpleAttrib CAEntityName::cubit_simple_attrib() 00160 { 00161 PRINT_DEBUG_94("CAEntityName::cubit_simple_attrib()\n"); 00162 00163 std::vector<CubitString> cs_list; 00164 00165 // pack the string list: 00166 // character type of this CA 00167 cs_list.push_back(att_internal_name()); 00168 00169 // name, option pairs 00170 int i; 00171 for ( i = entityNames.size(); i > 0; i--) { 00172 cs_list.push_back(entityNames.get_and_step()); 00173 } 00174 00175 return CubitSimpleAttrib(&cs_list, NULL, NULL); 00176 } 00177 00178 00179 void CAEntityName::print() 00180 { 00181 // print info on this attribute 00182 entityNames.reset(); 00183 00184 PRINT_INFO("CAEntityName: owner = %s %d; names: ", 00185 attribOwnerEntity->class_name(), attribOwnerEntity->id()); 00186 for (int i = entityNames.size(); i > 0; i--) 00187 PRINT_INFO("%s ", entityNames.get_and_step().c_str()); 00188 00189 PRINT_INFO("\n"); 00190 }
