cgma
00001 //#include <vector> 00002 #include <set> 00003 #include "string.h" 00004 #include "CubitDefines.h" 00005 #include "CGMMemFile.hpp" 00006 #include "CubitMessage.hpp" 00007 #include "GeometryQueryTool.hpp" 00008 #include "TDUniqueId.hpp" 00009 #include "Body.hpp" 00010 #include "ProcData.hpp" 00011 #include "TDParallel.hpp" 00012 00013 //std::vector<int> CGMMemFile::bodyToProc; 00014 DLIList <int> CGMMemFile::bodyToProc; 00015 //int *CGMMemFile::bodyToProc = NULL; 00016 //int CGMMemFile::nBodyToProc = 0 00017 00018 /* 00019 int larger_vol(RefEntity* &x, RefEntity* &y) 00020 { 00021 double x_vol = x->measure(); 00022 double y_vol = y->measure(); 00023 if (x_vol > y_vol) 00024 return -1; 00025 else if (x_vol < y_vol) 00026 return 1; 00027 else 00028 return 0; 00029 } 00030 */ 00031 CGMMemFile::CGMMemFile(void* buffer, 00032 size_t bufSize) 00033 { 00034 PRINT_DEBUG_100("Initializing memfile in proc %d, size %d.\n", 00035 ProcData::instance()->myRank, bufSize); 00036 m_pBuffer = (unsigned char *) buffer; 00037 m_sizeBuffer = bufSize; 00038 m_currentPosition = 0; 00039 //balanceSurf = 0; 00040 //totalLoads = NULL; 00041 //balancedLists = NULL; 00042 } 00043 00044 CGMMemFile::~CGMMemFile() 00045 { 00046 // delete the buffer 00047 delete m_pBuffer; 00048 } 00049 00050 CubitStatus CGMMemFile::bcast_buffer() 00051 { 00052 //- broadcasts the buffer contained in this object 00053 // get a ProcData object, then simply broadcast 00054 ProcData *proc_data = ProcData::instance(); 00055 if (proc_data->is_master()) { 00056 PRINT_DEBUG_100("Broadcasting buffer size from master.\n"); 00057 #ifdef USE_MPI 00058 MPI_Bcast(&m_sizeBuffer, 1, MPI_INT, proc_data->masterRank, 00059 MPI_COMM_WORLD); 00060 #endif 00061 PRINT_DEBUG_100("Broadcasting buffer from master, %d bytes.\n", m_sizeBuffer); 00062 #ifdef USE_MPI 00063 MPI_Bcast(m_pBuffer, m_sizeBuffer, MPI_BYTE, proc_data->masterRank, 00064 MPI_COMM_WORLD); 00065 #endif 00066 } 00067 else { 00068 int this_size; 00069 PRINT_DEBUG_100("Broadcasting buffer size from proc %d.\n", ProcData::instance()->myRank); 00070 #ifdef USE_MPI 00071 MPI_Bcast(&this_size, 1, MPI_INT, proc_data->masterRank, 00072 MPI_COMM_WORLD); 00073 #endif 00074 PRINT_DEBUG_100("Processor %d: received size of %d.\n", proc_data->myRank, this_size); 00075 check_size(this_size); 00076 PRINT_DEBUG_100("Broadcasting buffer from proc %d, %d bytes.\n", 00077 ProcData::instance()->myRank, this_size); 00078 #ifdef USE_MPI 00079 MPI_Bcast(m_pBuffer, this_size, MPI_BYTE, proc_data->masterRank, 00080 MPI_COMM_WORLD); 00081 #endif 00082 } 00083 00084 return CUBIT_SUCCESS; 00085 } 00086 00087 CubitStatus CGMMemFile::bcast_entity_list(DLIList<RefEntity*> &ref_entity_list) 00088 { 00089 //- broadcasts the entity list; root takes list as input, 00090 //- others write as output 00091 CubitStatus status; 00092 double twrite, tbcast; 00093 if (ProcData::instance()->is_master()) { 00094 if (DEBUG_FLAG(137)) { 00095 #ifdef USE_MPI 00096 twrite = MPI_Wtime(); 00097 #endif 00098 tbcast = twrite; 00099 } 00100 write_refentity_list(ref_entity_list); 00101 if (CUBIT_TRUE == DEBUG_FLAG(137)) 00102 #ifdef USE_MPI 00103 twrite = MPI_Wtime() - twrite; 00104 #endif 00105 } 00106 00107 status = bcast_buffer(); 00108 00109 if (!ProcData::instance()->is_master()) { 00110 read_refentity_list(ref_entity_list); 00111 } 00112 00113 /* 00114 if (CUBIT_TRUE == DEBUG_FLAG(137)) { 00115 MPI_Barrier(MPI_COMM_WORLD); 00116 if (ProcData::instance()->is_master()) { 00117 tbcast = MPI_Wtime() - tbcast; 00118 GeometryQueryTool *gti = GeometryQueryTool::instance(); 00119 00120 PRINT_DEBUG_137("buffer size (bytes), time to write buffer, total time to bcast (sec) = %d, %f, %f\n", 00121 m_sizeBuffer, twrite, tbcast); 00122 PRINT_DEBUG_137("Complexity: vertices, edges, faces, bodies = %d, %d, %d, %d\n", 00123 gti->num_ref_vertices(), gti->num_ref_edges(), gti->num_ref_faces(), 00124 gti->num_bodies()); 00125 PRINT_DEBUG_137("Stats: %s, %d, %d, %f, %f, %d, %d, %d, %d\n", 00126 filename, ProcData::instance()->numProcs, m_sizeBuffer, twrite, tbcast, 00127 gti->num_ref_vertices(), gti->num_ref_edges(), gti->num_ref_faces(), 00128 gti->num_bodies()); 00129 } 00130 } 00131 */ 00132 return status; 00133 } 00134 00135 CubitStatus CGMMemFile::bcast_and_delete_entity_list(DLIList<RefEntity*> &ref_entity_list, 00136 DLIList<RefEntity*> &ref_entity_list_master) 00137 { 00138 // reset the attribImporteds flags to facilitate attribute reporting 00139 //CubitAttrib::clear_attrib_importeds(); 00140 00141 //- broadcasts the entity list and delete the rest which this process doesn't need 00142 CubitStatus status; 00143 int nEntity, totalRefSize, endEntity, index, nBarEntity, restEntity; 00144 double tbcastDelete; 00145 ProcData *proc_data = ProcData::instance(); 00146 int nProcs = proc_data->numProcs; 00147 int myid = proc_data->myRank; 00148 00149 if (proc_data->is_master()) { 00150 totalRefSize = get_refentity_list_size(ref_entity_list); 00151 00152 if (DEBUG_FLAG(137)) { 00153 #ifdef USE_MPI 00154 tbcastDelete = MPI_Wtime(); 00155 #endif 00156 } 00157 write_refentity_list(ref_entity_list); 00158 } 00159 00160 status = bcast_buffer(); 00161 00162 if (!proc_data->is_master()) { 00163 read_refentity_list(ref_entity_list); 00164 00165 nEntity = ref_entity_list.size(); 00166 nBarEntity = nEntity/nProcs; 00167 restEntity = nEntity%nProcs; 00168 00169 // distribute with Round-Robin 00170 // tjt - don't need the 'else' part of the next if test, 00171 // since if restEntity == 0 you'll get the same results (i.e. the 'else' clause 00172 // of the next (nested) if will be the one evaluated 00173 // H.J.K - I thought another 'else' part can reduce some flops. 00174 //if (restEntity) { 00175 if (myid < restEntity) { 00176 index = myid*(nBarEntity+1) + 1; 00177 endEntity = (myid+1)*(nBarEntity+1) + 1; 00178 } 00179 else { 00180 index = restEntity*(nBarEntity+1) + (myid-restEntity)*nBarEntity + 1; 00181 endEntity = restEntity*(nBarEntity+1) + (myid-restEntity+1)*nBarEntity + 1; 00182 } 00183 //} 00184 /* else { 00185 index = myid*nBarEntity + 1; 00186 endEntity = (myid+1)*nBarEntity + 1; 00187 }*/ 00188 00189 // tjt - huh? Where do you delete the entities? 00190 // H.J.K - I changed code and deleted ref_entity_list directly without temp_list 00191 ref_entity_list.reset(); 00192 for (int i = 1; i < index; i++) { 00193 ref_entity_list.remove(); 00194 } 00195 00196 ref_entity_list.step(endEntity-index); 00197 00198 for (int i = endEntity; i < nEntity+1; i++) { 00199 ref_entity_list.remove(); 00200 } 00201 00202 // report attribs imported 00203 //CubitAttrib::report_attrib_importeds(); 00204 } 00205 else { 00206 nEntity = ref_entity_list.size(); 00207 nBarEntity = nEntity/nProcs; 00208 restEntity = nEntity%nProcs; 00209 00210 ref_entity_list_master.clean_out(); 00211 ref_entity_list.reset(); 00212 00213 for (int j = 0; j < nBarEntity; j++) 00214 ref_entity_list_master.append(ref_entity_list.get_and_step()); 00215 00216 if (restEntity > 0) 00217 ref_entity_list_master.append(ref_entity_list.get_and_step()); 00218 00219 //cout << "ref_entity_list_master.size()="<< ref_entity_list_master.size() << endl; 00220 } 00221 00222 /* 00223 if (CUBIT_TRUE == DEBUG_FLAG(137)) { 00224 MPI_Barrier(MPI_COMM_WORLD); 00225 if (ProcData::instance()->is_master()) { 00226 tbcastDelete = MPI_Wtime() - tbcastDelete; 00227 GeometryQueryTool *gti = GeometryQueryTool::instance(); 00228 00229 PRINT_DEBUG_137("total time to bcast and delete(sec) = %f\n", tbcastDelete); 00230 PRINT_DEBUG_137("total reference entity list size (bytes) = %d\n", totalRefSize); 00231 PRINT_DEBUG_137("Complexity: vertices, edges, faces, bodies = %d, %d, %d, %d\n", 00232 gti->num_ref_vertices(), gti->num_ref_edges(), gti->num_ref_faces(), 00233 gti->num_bodies()); 00234 double twrite = 0.0; 00235 PRINT_DEBUG_137("Stats: %s, %d, %d, %f, %f, %d, %d, %d, %d\n", 00236 filename, ProcData::instance()->numProcs, m_sizeBuffer, twrite, tbcastDelete, 00237 gti->num_ref_vertices(), gti->num_ref_edges(), gti->num_ref_faces(), gti->num_bodies()); 00238 } 00239 } 00240 */ 00241 return status; 00242 } 00243 /* 00244 CubitStatus CGMMemFile::send_body_to_procs(DLIList<RefEntity*> &ref_entity_list) 00245 { 00246 int nEntity; 00247 DLIList<RefEntity*> temp_list, temp_ref_list; 00248 00249 ProcData *proc_data = ProcData::instance(); 00250 00251 int nProcs = proc_data->numProcs; 00252 00253 if (proc_data->is_master()) { 00254 nEntity = ref_entity_list.size(); 00255 int nBarEntity = nEntity/nProcs; 00256 int restEntity = nEntity%nProcs; 00257 int nEndEntity = nBarEntity + restEntity; 00258 00259 ref_entity_list.reset(); 00260 bodyToProc.clean_out(); 00261 00262 // make temporary lists to contain geometry information for each processors 00263 for (int i = 0; i < nProcs; i++) { 00264 for ( int j = 0; j < nBarEntity; j++) { 00265 RefEntity* body_ptr = ref_entity_list.get_and_step(); 00266 temp_list.append(body_ptr); 00267 bodyToProc.append(TDUniqueId::get_unique_id(body_ptr)); 00268 bodyToProc.append(i); 00269 } 00270 00271 if (i < restEntity) { 00272 RefEntity* body_ptr = ref_entity_list.get_and_step(); 00273 temp_list.append(body_ptr); 00274 bodyToProc.append(TDUniqueId::get_unique_id(body_ptr)); 00275 bodyToProc.append(i); 00276 } 00277 00278 temp_list.clean_out(); 00279 } 00280 } 00281 00282 // broadcast number of bodies 00283 MPI_Bcast(&nEntity, 1, MPI_INT, proc_data->masterRank, MPI_COMM_WORLD); 00284 00285 int body_to_proc[2*nEntity]; 00286 00287 if (proc_data->is_master()) // make temporary array 00288 bodyToProc.copy_to(body_to_proc); 00289 00290 MPI_Bcast(body_to_proc, 2*nEntity, MPI_INT, proc_data->masterRank, MPI_COMM_WORLD); 00291 00292 if (!proc_data->is_master()) // copy from temporary array 00293 bodyToProc.copy_from(body_to_proc, 2*nEntity); 00294 00295 return CUBIT_SUCCESS; 00296 } 00297 */ 00298 00299 CubitStatus CGMMemFile::scatter_entity_list(DLIList<RefEntity*> &ref_entity_list) 00300 { 00301 // scatter exact amount of geometry information to each processors 00302 CubitStatus status; 00303 double tScatter; 00304 int mySendCount; 00305 int nEntity; 00306 DLIList<RefEntity*> temp_list, temp_ref_list; 00307 00308 ProcData *proc_data = ProcData::instance(); 00309 if (DEBUG_FLAG(137) && proc_data->is_master()) 00310 #ifdef USE_MPI 00311 tScatter = MPI_Wtime(); 00312 #endif 00313 00314 int nProcs = proc_data->numProcs; 00315 int *sendCounts = new int[nProcs]; 00316 int *displacements = new int[nProcs]; 00317 int nBarEntity; 00318 int restEntity; 00319 int nEndEntity; 00320 displacements[0] = 0; 00321 00322 if (proc_data->is_master()) { 00323 nEntity = ref_entity_list.size(); 00324 nBarEntity = nEntity/nProcs; 00325 restEntity = nEntity%nProcs; 00326 nEndEntity = nBarEntity + restEntity; 00327 00328 ref_entity_list.reset(); 00329 int sum = 0; 00330 00331 // make temporary lists to contain geometry information for each processors 00332 for (int i = 0; i < nProcs; i++) { 00333 for ( int j = 0; j < nBarEntity; j++) { 00334 RefEntity* body_ptr = ref_entity_list.get_and_step(); 00335 temp_list.append(body_ptr); 00336 } 00337 00338 if (i < restEntity) { 00339 RefEntity* body_ptr = ref_entity_list.get_and_step(); 00340 temp_list.append(body_ptr); 00341 } 00342 00343 sendCounts[i] = get_refentity_list_size(temp_list); 00344 sum += sendCounts[i]; 00345 temp_list.clean_out(); 00346 } 00347 00348 // check the size of the buffer and resize if necessary 00349 check_size(sum); 00350 00351 // now actually append the information 00352 ref_entity_list.reset(); 00353 for (int i = 0; i < nProcs; i++) { 00354 for ( int j = 0; j < nBarEntity; j++) { 00355 temp_list.append(ref_entity_list.get_and_step()); 00356 } 00357 00358 if (i < restEntity) { 00359 temp_list.append(ref_entity_list.get_and_step()); 00360 } 00361 00362 append_refentity_list(temp_list, sendCounts[i]); 00363 temp_list.clean_out(); 00364 } 00365 } 00366 00367 // broadcast buffer size array 00368 PRINT_DEBUG_100("Broadcasting buffer size array from master.\n"); 00369 #ifdef USE_MPI 00370 MPI_Bcast(sendCounts, nProcs, MPI_INT, proc_data->masterRank, MPI_COMM_WORLD); 00371 #endif 00372 00373 for (int i = 1; i < nProcs; i++) { 00374 displacements[i] = displacements[i-1] + sendCounts[i-1]; 00375 } 00376 00377 mySendCount = sendCounts[proc_data->myRank]; 00378 00379 if (!proc_data->is_master()) check_size(mySendCount); 00380 00381 PRINT_DEBUG_100("Scattering buffer from master.\n"); 00382 00383 // scatter geometry 00384 #ifdef USE_MPI 00385 MPI_Scatterv(m_pBuffer, sendCounts, displacements, MPI_BYTE, m_pBuffer, 00386 mySendCount, MPI_BYTE, proc_data->masterRank, MPI_COMM_WORLD); 00387 #endif 00388 00389 if (!proc_data->is_master()) { 00390 status = read_refentity_list(ref_entity_list); 00391 } 00392 /* 00393 ref_entity_list.reset(); 00394 for (int i = 0; i < ref_entity_list.size(); i++) { 00395 DLIList<RefEntity*> entities; 00396 RefEntity *entity = ref_entity_list.get_and_step(); 00397 entity->get_all_child_ref_entities(entities); 00398 //cout << "my_id=" << ProcData::instance()->myRank 00399 // << " num of children=" << entities.size() << endl; 00400 //entities.reset(); 00401 //for (int j = 0; j < entities.size(); j++) { 00402 //cout << "my_id=" << ProcData::instance()->myRank 00403 // << " measure=" << entities.get_and_step()->measure() << endl; 00404 //} 00405 } 00406 */ 00407 /* 00408 // delete unneeded part in master node 00409 if (proc_data->is_master()) { 00410 int index, endEntity; 00411 if (0 < restEntity) { 00412 index = 1; 00413 endEntity = nBarEntity + 2; 00414 } 00415 else { 00416 index = restEntity*(nBarEntity+1) + 1; 00417 endEntity = nBarEntity + 1; 00418 } 00419 ref_entity_list.reset(); 00420 for (int i = 1; i < index; i++) { 00421 ref_entity_list.remove(); 00422 } 00423 00424 ref_entity_list.step(endEntity-index); 00425 00426 for (int j = endEntity; j < nEntity+1; j++) { 00427 ref_entity_list.remove(); 00428 } 00429 } 00430 */ 00431 /* 00432 int body_to_proc[2*nEntity]; 00433 00434 if (proc_data->is_master()) // make temporary array 00435 bodyToProc.copy_to(body_to_proc); 00436 00437 MPI_Bcast(body_to_proc, 2*nEntity, MPI_INT, proc_data->masterRank, MPI_COMM_WORLD); 00438 00439 if (!proc_data->is_master()) // copy from temporary array 00440 bodyToProc.copy_from(body_to_proc, 2*nEntity); 00441 00442 cout << "myid=" << proc_data->myRank << " bodyToProc.size() = " << bodyToProc.size() << endl; 00443 00444 DLIList <int> *body_to_proc_ptr = get_body_to_proc(); 00445 00446 cout << "myid=" << proc_data->myRank << " body_to_proc_ptr->size() = " << body_to_proc_ptr->size() << endl; 00447 00448 if (!proc_data->is_master()) 00449 bodyToProc.resize(2*nEntity); 00450 00451 MPI_Bcast(bodyToProc, nBodyToProc, MPI_INT, proc_data->masterRank, MPI_COMM_WORLD); 00452 00453 cout << "myid=" << proc_data->myRank << " bodyToProc.size() = " << bodyToProc.size() << endl; 00454 00455 std::vector<int> *body_to_proc_ptr = get_body_to_proc(); 00456 00457 cout << "myid=" << proc_data->myRank << " body_to_proc_ptr->size() = " << body_to_proc_ptr->size() << endl; 00458 cout << "myid=" << proc_data->myRank << " nEntity pointer = " << &nEntity << endl; 00459 cout << "myid=" << proc_data->myRank << " body_to_proc_ptr = " << body_to_proc_ptr << endl; 00460 cout << "myid=" << proc_data->myRank << " bodyToProcPtr = " << &bodyToProc << endl; 00461 */ 00462 /* 00463 // broadcast body to processors map 00464 MPI_Bcast(bodyToProc, nBodyToProc, MPI_INT, proc_data->masterRank, MPI_COMM_WORLD); 00465 00466 if (!proc_data->is_master()) { 00467 for (int k = 0; k < nBodyToProc; k++) { 00468 cout << "bodyToProc[" << k << "]=" << bodyToProc[k] << endl; 00469 } 00470 } 00471 */ 00472 /* 00473 if (CUBIT_TRUE == DEBUG_FLAG(137)) { 00474 MPI_Barrier(MPI_COMM_WORLD); 00475 if (proc_data->is_master()) { 00476 tScatter = MPI_Wtime() - tScatter; 00477 GeometryQueryTool *gti = GeometryQueryTool::instance(); 00478 00479 PRINT_DEBUG_137("total time to scatter (sec) = %f\n", tScatter); 00480 PRINT_DEBUG_137("Complexity: vertices, edges, faces, bodies = %d, %d, %d, %d\n", 00481 gti->num_ref_vertices(), gti->num_ref_edges(), gti->num_ref_faces(), 00482 gti->num_bodies()); 00483 PRINT_DEBUG_137("Stats: %s, %d, %d, %f, %f, %d, %d, %d, %d\n", 00484 filename, ProcData::instance()->numProcs, m_sizeBuffer, 0.0, tScatter, 00485 gti->num_ref_vertices(), gti->num_ref_edges(), gti->num_ref_faces(), 00486 gti->num_bodies()); 00487 } 00488 } 00489 */ 00490 return status; 00491 } 00492 /* 00493 CubitStatus CGMMemFile::scatter_entity_list(DLIList<RefEntity*> &ref_entity_list, 00494 const char *filename) 00495 { 00496 // scatter exact amount of geometry information to each processors 00497 CubitStatus status; 00498 double tScatter; 00499 int mySendCount; 00500 int nEntity; 00501 DLIList<RefEntity*> temp_list, temp_ref_list; 00502 00503 ProcData *proc_data = ProcData::instance(); 00504 if (DEBUG_FLAG(137) && proc_data->is_master()) 00505 tScatter = MPI_Wtime(); 00506 00507 int nProcs = proc_data->numProcs; 00508 int *sendCounts = new int[nProcs]; 00509 int *displacements = new int[nProcs]; 00510 int nBarEntity; 00511 int restEntity; 00512 int nEndEntity; 00513 displacements[0] = 0; 00514 00515 if (proc_data->is_master()) { 00516 int curPosition = 0; 00517 nEntity = ref_entity_list.size(); 00518 nBarEntity = nEntity/nProcs; 00519 restEntity = nEntity%nProcs; 00520 nEndEntity = nBarEntity + restEntity; 00521 00522 ref_entity_list.reset(); 00523 int sum = 0; 00524 00525 // make temporary lists to contain geometry information for each processors 00526 for (int i = 0; i < nProcs; i++) { 00527 for ( int j = 0; j < nBarEntity; j++) { 00528 RefEntity* body_ptr = ref_entity_list.get_and_step(); 00529 temp_list.clean_out(); 00530 temp_list.append(body_ptr); 00531 sendCounts[i] += get_refentity_list_size(temp_list); 00532 } 00533 00534 if (i < restEntity) { 00535 RefEntity* body_ptr = ref_entity_list.get_and_step(); 00536 temp_list.clean_out(); 00537 temp_list.append(body_ptr); 00538 sendCounts[i] += get_refentity_list_size(temp_list); 00539 } 00540 00541 sum += sendCounts[i]; 00542 } 00543 00544 // check the size of the buffer and resize if necessary 00545 check_size(sum); 00546 00547 // now actually append the information 00548 ref_entity_list.reset(); 00549 for (int i = 0; i < nProcs; i++) { 00550 for ( int j = 0; j < nBarEntity; j++) { 00551 temp_list.clean_out(); 00552 temp_list.append(ref_entity_list.get_and_step()); 00553 int count = get_refentity_list_size(temp_list); 00554 append_refentity_list(temp_list, count); 00555 } 00556 00557 if (i < restEntity) { 00558 temp_list.clean_out(); 00559 temp_list.append(ref_entity_list.get_and_step()); 00560 int count = get_refentity_list_size(temp_list); 00561 append_refentity_list(temp_list, count); 00562 } 00563 00564 //append_refentity_list(temp_list, sendCounts[i]); 00565 //temp_list.clean_out(); 00566 } 00567 } 00568 00569 // broadcast buffer size array 00570 PRINT_DEBUG_100("Broadcasting buffer size array from master.\n"); 00571 MPI_Bcast(sendCounts, nProcs, MPI_INT, proc_data->masterRank, MPI_COMM_WORLD); 00572 00573 for (int i = 1; i < nProcs; i++) { 00574 displacements[i] = displacements[i-1] + sendCounts[i-1]; 00575 } 00576 00577 mySendCount = sendCounts[proc_data->myRank]; 00578 00579 if (!proc_data->is_master()) check_size(mySendCount); 00580 00581 PRINT_DEBUG_100("Scattering buffer from master.\n"); 00582 00583 // scatter geometry 00584 MPI_Scatterv(m_pBuffer, sendCounts, displacements, MPI_BYTE, m_pBuffer, 00585 mySendCount, MPI_BYTE, proc_data->masterRank, MPI_COMM_WORLD); 00586 00587 if (!proc_data->is_master()) { 00588 status = read_refentity_list(ref_entity_list); 00589 } 00590 00591 ref_entity_list.reset(); 00592 for (int i = 0; i < ref_entity_list.size(); i++) { 00593 DLIList<RefEntity*> entities; 00594 RefEntity *entity = ref_entity_list.get_and_step(); 00595 entity->get_all_child_ref_entities(entities); 00596 cout << "my_id=" << ProcData::instance()->myRank 00597 << " num of children=" << entities.size() << endl; 00598 entities.reset(); 00599 for (int j = 0; j < entities.size(); j++) { 00600 cout << "my_id=" << ProcData::instance()->myRank 00601 << " measure=" << entities.get_and_step()->measure() << endl; 00602 } 00603 } 00604 00605 if (CUBIT_TRUE == DEBUG_FLAG(137)) { 00606 MPI_Barrier(MPI_COMM_WORLD); 00607 if (proc_data->is_master()) { 00608 tScatter = MPI_Wtime() - tScatter; 00609 GeometryQueryTool *gti = GeometryQueryTool::instance(); 00610 00611 PRINT_DEBUG_137("total time to scatter (sec) = %f\n", tScatter); 00612 PRINT_DEBUG_137("Complexity: vertices, edges, faces, bodies = %d, %d, %d, %d\n", 00613 gti->num_ref_vertices(), gti->num_ref_edges(), gti->num_ref_faces(), 00614 gti->num_bodies()); 00615 PRINT_DEBUG_137("Stats: %s, %d, %d, %f, %f, %d, %d, %d, %d\n", 00616 filename, ProcData::instance()->numProcs, m_sizeBuffer, 0.0, tScatter, 00617 gti->num_ref_vertices(), gti->num_ref_edges(), gti->num_ref_faces(), 00618 gti->num_bodies()); 00619 } 00620 } 00621 00622 return status; 00623 } 00624 */ 00625 /* 00626 CubitStatus CGMMemFile::vol_balace_send_body_processors(DLIList<RefEntity*> &ref_entity_list) 00627 { 00628 ProcData *proc_data = ProcData::instance(); 00629 bodyToProc.clean_out(); 00630 int nEntity = 0; 00631 00632 if (proc_data->is_master()) { 00633 int nProcs = proc_data->numProcs; 00634 nEntity = ref_entity_list.size(); 00635 balancedLists = new DLIList<RefEntity*>*[nProcs]; 00636 00637 for (int k = 0; k < nProcs; k++) 00638 balancedLists[k] = new DLIList<RefEntity*>; 00639 00640 totalLoads = new double[nProcs]; 00641 ref_entity_list.sort(larger_vol); 00642 ref_entity_list.reset(); 00643 00644 // fill first bodies to processors 00645 for (int l = 0; l < nProcs; l++) { 00646 RefEntity *body_ptr = ref_entity_list.get_and_step(); 00647 // just calculate volumes for load 00648 totalLoads[l] = body_ptr->measure(); 00649 bodyToProc.append(TDUniqueId::get_unique_id(body_ptr)); 00650 bodyToProc.append(l); 00651 balancedLists[l]->append(body_ptr); 00652 } 00653 00654 // fill the rest 00655 for (int i = nProcs; i < nEntity; i++) { 00656 RefEntity *body_ptr = ref_entity_list.get_and_step(); 00657 double min_vol = totalLoads[0]; 00658 int min_i = 0; 00659 00660 for (int j = 1; j < nProcs; j++) { 00661 if (min_vol > totalLoads[j]) { 00662 min_vol = totalLoads[j]; 00663 min_i = j; 00664 } 00665 } 00666 00667 totalLoads[min_i] += body_ptr->measure(); 00668 bodyToProc.append(TDUniqueId::get_unique_id(body_ptr)); 00669 bodyToProc.append(min_i); 00670 balancedLists[min_i]->append(body_ptr); 00671 } 00672 } 00673 00674 // broadcast number of bodies 00675 MPI_Bcast(&nEntity, 1, MPI_INT, proc_data->masterRank, MPI_COMM_WORLD); 00676 int body_to_proc[2*nEntity]; 00677 00678 if (proc_data->is_master()) // make temporary array 00679 bodyToProc.copy_to(body_to_proc); 00680 00681 MPI_Bcast(body_to_proc, 2*nEntity, MPI_INT, proc_data->masterRank, MPI_COMM_WORLD); 00682 00683 if (!proc_data->is_master()) // copy from temporary array 00684 bodyToProc.copy_from(body_to_proc, 2*nEntity); 00685 00686 return CUBIT_SUCCESS; 00687 } 00688 00689 CubitStatus CGMMemFile::send_body_to_procs_balanced(DLIList<RefEntity*> &ref_entity_list) 00690 { 00691 ProcData *proc_data = ProcData::instance(); 00692 int nProcs = proc_data->numProcs; 00693 int nEntity; 00694 00695 // load balance bodies by volume 00696 if (proc_data->is_master()) { 00697 double *total_volumes = new double[nProcs]; 00698 nEntity = ref_entity_list.size(); 00699 ref_entity_list.sort(larger_vol); 00700 bodyToProc.clean_out(); 00701 ref_entity_list.reset(); 00702 00703 // fill first bodies to processors 00704 for (int l = 0; l < nProcs; l++) { 00705 RefEntity *body_ptr = ref_entity_list.get_and_step(); 00706 total_volumes[l] = body_ptr->measure(); 00707 bodyToProc.append(TDUniqueId::get_unique_id(body_ptr)); 00708 bodyToProc.append(l); 00709 } 00710 00711 // fill the rest 00712 for (int i = nProcs; i < nEntity; i++) { 00713 RefEntity *body_ptr = ref_entity_list.get_and_step(); 00714 double min_vol = total_volumes[0]; 00715 int min_i = 0; 00716 00717 for (int j = 1; j < nProcs; j++) { 00718 if (min_vol > total_volumes[j]) { 00719 min_vol = total_volumes[j]; 00720 min_i = j; 00721 } 00722 } 00723 00724 total_volumes[min_i] += body_ptr->measure(); 00725 bodyToProc.append(TDUniqueId::get_unique_id(body_ptr)); 00726 bodyToProc.append(min_i); 00727 } 00728 00729 delete total_volumes; 00730 } 00731 00732 // broadcast number of bodies 00733 MPI_Bcast(&nEntity, 1, MPI_INT, proc_data->masterRank, MPI_COMM_WORLD); 00734 int body_to_proc[2*nEntity]; 00735 00736 if (proc_data->is_master()) // make temporary array 00737 bodyToProc.copy_to(body_to_proc); 00738 00739 MPI_Bcast(body_to_proc, 2*nEntity, MPI_INT, proc_data->masterRank, MPI_COMM_WORLD); 00740 00741 if (!proc_data->is_master()) // copy from temporary array 00742 bodyToProc.copy_from(body_to_proc, 2*nEntity); 00743 00744 return CUBIT_SUCCESS; 00745 } 00746 */ 00747 00748 /* 00749 CubitStatus CGMMemFile::scatter_vol_balanced_entity_list(DLIList<RefEntity*> &ref_entity_list, 00750 DLIList<RefEntity*> &ref_entity_list_master, 00751 const char *filename) 00752 { 00753 // scatter exact amount of geometry information to each processors 00754 CubitStatus status; 00755 double tScatter; 00756 int mySendCount; 00757 int nEntity; 00758 00759 ProcData *proc_data = ProcData::instance(); 00760 if (DEBUG_FLAG(137) && proc_data->is_master()) 00761 tScatter = MPI_Wtime(); 00762 00763 int nProcs = proc_data->numProcs; 00764 int *sendCounts = new int[nProcs]; 00765 int *displacements = new int[nProcs]; 00766 int nBarEntity; 00767 int restEntity; 00768 int nEndEntity; 00769 displacements[0] = 0; 00770 ref_entity_list_master; 00771 00772 if (proc_data->is_master()) { 00773 int curPosition = 0; 00774 nEntity = ref_entity_list.size(); 00775 nBarEntity = nEntity/nProcs; 00776 restEntity = nEntity%nProcs; 00777 nEndEntity = nBarEntity + restEntity; 00778 00779 double *body_volumes = new double[nEntity]; 00780 double *total_volumes = new double[nProcs]; 00781 DLIList<RefEntity*> **load_balace_array = new DLIList<RefEntity*>*[nProcs]; 00782 00783 for (int k = 0; k < nProcs; k++) 00784 load_balace_array[k] = new DLIList<RefEntity*>; 00785 00786 ref_entity_list.reset(); 00787 for (int l = 0; l < nProcs; l++) { 00788 RefEntity *body_ptr = ref_entity_list.get_and_step(); 00789 load_balace_array[l]->append(body_ptr); 00790 total_volumes[l] = body_ptr->measure(); 00791 } 00792 00793 for (int i = nProcs; i < nEntity; i++) { 00794 RefEntity *body_ptr = ref_entity_list.get_and_step(); 00795 double min_vol = total_volumes[0]; 00796 int min_i = 0; 00797 00798 for (int j = 1; j < nProcs; j++) { 00799 if (min_vol > total_volumes[j]) { 00800 min_vol = total_volumes[j]; 00801 min_i = j; 00802 } 00803 } 00804 00805 load_balace_array[min_i]->append(body_ptr); 00806 total_volumes[min_i] += body_ptr->measure(); 00807 } 00808 00809 int sum = 0; 00810 // make temporary lists to contain geometry information for each processors 00811 for (int i = 0; i < nProcs; i++) { 00812 PRINT_DEBUG_100("load_balace_array[i]=%d\n", load_balace_array[i]); 00813 PRINT_DEBUG_100("*load_balace_array[i]=%d\n", *load_balace_array[i]); 00814 PRINT_DEBUG_100("sendCounts[i]=%d\n", sendCounts[i]); 00815 sendCounts[i] = get_refentity_list_size(*(load_balace_array[i])); 00816 sum += sendCounts[i]; 00817 } 00818 00819 // check the size of the buffer and resize if necessary 00820 check_size(sum); 00821 00822 // now actually append the information 00823 ref_entity_list.clean_out(); 00824 for (int i = 0; i < nProcs; i++) { 00825 append_refentity_list(*load_balace_array[i], sendCounts[i]); 00826 ref_entity_list += *load_balace_array[i]; // serialize ref_entity_list 00827 } 00828 00829 // check and save ref_entity_list information for master 00830 ref_entity_list_master.clean_out(); 00831 ref_entity_list_master += *load_balace_array[0]; 00832 //ref_entity_list_master = *load_balace_array[0]; 00833 } 00834 00835 // broadcast buffer size array 00836 PRINT_DEBUG_100("Broadcasting buffer size array from master.\n"); 00837 MPI_Bcast(sendCounts, nProcs, MPI_INT, proc_data->masterRank, MPI_COMM_WORLD); 00838 00839 for (int i = 1; i < nProcs; i++) { 00840 displacements[i] = displacements[i-1] + sendCounts[i-1]; 00841 } 00842 00843 mySendCount = sendCounts[proc_data->myRank]; 00844 00845 if (!proc_data->is_master()) check_size(mySendCount); 00846 00847 PRINT_DEBUG_100("Scattering buffer from master.\n"); 00848 00849 // scatter geometry 00850 MPI_Scatterv(m_pBuffer, sendCounts, displacements, MPI_BYTE, m_pBuffer, 00851 mySendCount, MPI_BYTE, proc_data->masterRank, MPI_COMM_WORLD); 00852 00853 if (!proc_data->is_master()) 00854 status = read_refentity_list(ref_entity_list); 00855 00856 if (CUBIT_TRUE == DEBUG_FLAG(137)) { 00857 MPI_Barrier(MPI_COMM_WORLD); 00858 if (proc_data->is_master()) { 00859 tScatter = MPI_Wtime() - tScatter; 00860 GeometryQueryTool *gti = GeometryQueryTool::instance(); 00861 00862 PRINT_DEBUG_137("total time to scatter (sec) = %f\n", tScatter); 00863 PRINT_DEBUG_137("Complexity: vertices, edges, faces, bodies = %d, %d, %d, %d\n", 00864 gti->num_ref_vertices(), gti->num_ref_edges(), gti->num_ref_faces(), 00865 gti->num_bodies()); 00866 PRINT_DEBUG_137("Stats: %s, %d, %d, %f, %f, %d, %d, %d, %d\n", 00867 filename, ProcData::instance()->numProcs, m_sizeBuffer, 0.0, tScatter, 00868 gti->num_ref_vertices(), gti->num_ref_edges(), gti->num_ref_faces(), 00869 gti->num_bodies()); 00870 } 00871 } 00872 00873 return status; 00874 } 00875 */ 00876 /* 00877 // before partition input 00878 CubitStatus CGMMemFile::scatter_balanced_entity_list(DLIList<RefEntity*> &ref_entity_list, 00879 DLIList<RefEntity*> &ref_entity_list_master, 00880 const char *filename, 00881 DLIList<RefEntity*> **balanced_lists) 00882 { 00883 //cout << "my_id=" << ProcData::instance()->myRank << "CGMMemFile::scatter_balanced_entity_list1" << endl; 00884 // scatter exact amount of geometry information to each processors 00885 CubitStatus status; 00886 double tScatter; 00887 int mySendCount; 00888 ProcData *proc_data = ProcData::instance(); 00889 00890 if (DEBUG_FLAG(137) && proc_data->is_master()) 00891 tScatter = MPI_Wtime(); 00892 00893 int nProcs = proc_data->numProcs; 00894 int *sendCounts = new int[nProcs]; 00895 int *displacements = new int[nProcs]; 00896 int nBarEntity; 00897 int restEntity; 00898 int nEndEntity; 00899 displacements[0] = 0; 00900 //ref_entity_list_master; 00901 00902 //cout << "my_id=" << ProcData::instance()->myRank << "CGMMemFile::scatter_balanced_entity_list2" << endl; 00903 if (proc_data->is_master()) { 00904 //cout << "my_id=" << ProcData::instance()->myRank << "CGMMemFile::scatter_balanced_entity_list3" << endl; 00905 int sum = 0; 00906 00907 // make temporary lists to contain geometry information for each processors 00908 for (int i = 0; i < nProcs; i++) { 00909 //cout << "CGMMemFile::scatter_balanced_entity_list3.11" << endl; 00910 sendCounts[i] = get_refentity_list_size(*(balanced_lists[i])); 00911 //cout << "sendCounts[" << i << "]=" << sendCounts[i] << ",balanced_lists[i]->size()=" 00912 //<< balanced_lists[i]->size() << endl; 00913 sum += sendCounts[i]; 00914 } 00915 00916 //cout << "CGMMemFile::scatter_balanced_entity_list3.1" << endl; 00917 // check the size of the buffer and resize if necessary 00918 check_size(sum); 00919 //cout << "CGMMemFile::scatter_balanced_entity_list3.2" << endl; 00920 00921 // now actually append the information 00922 ref_entity_list.clean_out(); 00923 for (int i = 0; i < nProcs; i++) { 00924 append_refentity_list(*balanced_lists[i], sendCounts[i]); 00925 ref_entity_list += *balanced_lists[i]; // serialize ref_entity_list 00926 } 00927 00928 //cout << "CGMMemFile::scatter_balanced_entity_list3.3" << endl; 00929 // check and save ref_entity_list information for master 00930 ref_entity_list_master.clean_out(); 00931 ref_entity_list_master += *balanced_lists[0]; 00932 //cout << "CGMMemFile::scatter_balanced_entity_list3.4" << endl; 00933 } 00934 00935 //cout << "my_id=" << ProcData::instance()->myRank << "CGMMemFile::scatter_balanced_entity_list4" << endl; 00936 // broadcast buffer size array 00937 PRINT_DEBUG_100("Broadcast 00938 ing buffer size array from master.\n"); 00939 00940 //for (int n = 0; n < nProcs; n++) 00941 //cout << "sendCounts[" << n << "]=" << sendCounts[n] << endl; 00942 00943 MPI_Bcast(sendCounts, nProcs, MPI_INT, proc_data->masterRank, MPI_COMM_WORLD); 00944 //cout << "my_id=" << ProcData::instance()->myRank << "CGMMemFile::scatter_balanced_entity_list4.1" << endl; 00945 00946 for (int i = 1; i < nProcs; i++) { 00947 displacements[i] = displacements[i-1] + sendCounts[i-1]; 00948 } 00949 //cout << "my_id=" << ProcData::instance()->myRank << "CGMMemFile::scatter_balanced_entity_list4.2" << endl; 00950 00951 mySendCount = sendCounts[proc_data->myRank]; 00952 //cout << "my_id=" << ProcData::instance()->myRank << "CGMMemFile::scatter_balanced_entity_list4.3" << endl; 00953 00954 if (!proc_data->is_master()) check_size(mySendCount); 00955 //cout << "my_id=" << ProcData::instance()->myRank << "CGMMemFile::scatter_balanced_entity_list4.4" << endl; 00956 00957 PRINT_DEBUG_100("Scattering buffer from master.\n"); 00958 00959 //cout << "CGMMemFile::scatter_balanced_entity_list5" << endl; 00960 // scatter geometry 00961 MPI_Scatterv(m_pBuffer, sendCounts, displacements, MPI_BYTE, m_pBuffer, 00962 mySendCount, MPI_BYTE, proc_data->masterRank, MPI_COMM_WORLD); 00963 00964 if (!proc_data->is_master()) 00965 status = read_refentity_list(ref_entity_list); 00966 00967 //cout << "CGMMemFile::scatter_balanced_entity_list6" << endl; 00968 if (CUBIT_TRUE == DEBUG_FLAG(137)) { 00969 //MPI_Barrier(MPI_COMM_WORLD); 00970 if (proc_data->is_master()) { 00971 tScatter = MPI_Wtime() - tScatter; 00972 GeometryQueryTool *gti = GeometryQueryTool::instance(); 00973 00974 PRINT_DEBUG_137("total time to scatter (sec) = %f\n", tScatter); 00975 PRINT_DEBUG_137("Complexity: vertices, edges, faces, bodies = %d, %d, %d, %d\n", 00976 gti->num_ref_vertices(), gti->num_ref_edges(), gti->num_ref_faces(), 00977 gti->num_bodies()); 00978 PRINT_DEBUG_137("Stats: %s, %d, %d, %f, %f, %d, %d, %d, %d\n", 00979 filename, ProcData::instance()->numProcs, m_sizeBuffer, 0.0, tScatter, 00980 gti->num_ref_vertices(), gti->num_ref_edges(), gti->num_ref_faces(), 00981 gti->num_bodies()); 00982 } 00983 } 00984 //cout << "CGMMemFile::scatter_balanced_entity_list7" << endl; 00985 00986 return status; 00987 } 00988 */ 00989 /* 00990 // partition input without balancedLists 00991 CubitStatus CGMMemFile::scatter_balanced_entity_list(DLIList<RefEntity*> &ref_entity_list, 00992 DLIList<RefEntity*> &ref_entity_list_master, 00993 const char *filename) 00994 { 00995 //cout << "CGMMemFile::scatter_balanced_entity_list1" 00996 // << ",balanced_lists=" << balanced_lists << endl; 00997 // scatter exact amount of geometry information to each processors 00998 CubitStatus status; 00999 double tScatter; 01000 int mySendCount; 01001 ProcData *proc_data = ProcData::instance(); 01002 01003 if (DEBUG_FLAG(137) && proc_data->is_master()) 01004 tScatter = MPI_Wtime(); 01005 01006 int nProcs = proc_data->numProcs; 01007 int *sendCounts = new int[nProcs]; 01008 int *displacements = new int[nProcs]; 01009 //int nBarEntity; 01010 //int restEntity; 01011 //int nEndEntity; 01012 displacements[0] = 0; 01013 01014 cout << "CGMMemFile::scatter_balanced_entity_list2" << endl; 01015 01016 if (proc_data->is_master()) { 01017 cout << "CGMMemFile::scatter_balanced_entity_list3.1" << endl; 01018 01019 DLIList<RefEntity*> **balance_lists = new DLIList<RefEntity*>*[nProcs]; 01020 01021 for (int i = 0; i < nProcs; i++) 01022 balance_lists[i] = new DLIList<RefEntity*>; 01023 01024 cout << "CGMMemFile::scatter_balanced_entity_list3.2" << endl; 01025 01026 int n_refs = ref_entity_list.size(); 01027 ref_entity_list.reset(); 01028 01029 for (; n_refs > 0; n_refs--) { 01030 cout << "CGMMemFile::scatter_balanced_entity_list3.3" << endl; 01031 RefEntity *entity = ref_entity_list.get_and_step(); 01032 TDParallel *td_par = (TDParallel *) entity->get_TD(&TDParallel::is_parallel); 01033 01034 if (td_par == NULL) { 01035 td_par = new TDParallel(entity); 01036 } 01037 01038 //cout << "td_par->get_proc_id()=" << td_par->get_proc_id() << endl; 01039 //cout << "balance_lists=" << balance_lists << endl; 01040 //cout << "balance_lists[td_par->get_proc_id()]=" 01041 // << balance_lists[td_par->get_proc_id()] << endl; 01042 01043 int temp_id = td_par->get_proc_id(); 01044 01045 if (temp_id > -1) 01046 balance_lists[temp_id]->append(entity); 01047 } 01048 01049 cout << "CGMMemFile::scatter_balanced_entity_list3.4" << endl; 01050 int sum = 0; 01051 for (int j = 0; j < nProcs; j++) { 01052 cout << "CGMMemFile::scatter_balanced_entity_list3.41" << endl; 01053 01054 sendCounts[j] = get_refentity_list_size(*(balance_lists[j])); 01055 cout << "CGMMemFile::scatter_balanced_entity_list3.42" << endl; 01056 sum += sendCounts[j]; 01057 cout << "CGMMemFile::scatter_balanced_entity_list3.43" << endl; 01058 } 01059 01060 cout << "CGMMemFile::scatter_balanced_entity_list3.5" << endl; 01061 // check the size of the buffer and resize if necessary 01062 check_size(sum); 01063 01064 cout << "CGMMemFile::scatter_balanced_entity_list3.6" << endl; 01065 // now actually append the information 01066 ref_entity_list.clean_out(); 01067 for (int k = 0; k < nProcs; k++) { 01068 append_refentity_list(*balance_lists[k], sendCounts[k]); 01069 ref_entity_list += *balance_lists[k]; // serialize ref_entity_list 01070 } 01071 cout << "CGMMemFile::scatter_balanced_entity_list3.7" << endl; 01072 // check and save ref_entity_list information for master 01073 ref_entity_list_master.clean_out(); 01074 ref_entity_list_master += *balance_lists[0]; 01075 01076 for (int l = 0; l < nProcs; l++) 01077 delete balance_lists[l]; 01078 cout << "CGMMemFile::scatter_balanced_entity_list3.8" << endl; 01079 delete [] balance_lists; 01080 01081 } 01082 01083 cout << "my_id=" << ProcData::instance()->myRank << "CGMMemFile::scatter_balanced_entity_list4" << endl; 01084 // broadcast buffer size array 01085 PRINT_DEBUG_100("Broadcast 01086 ing buffer size array from master.\n"); 01087 01088 //for (int n = 0; n < nProcs; n++) 01089 //cout << "sendCounts[" << n << "]=" << sendCounts[n] << endl; 01090 01091 MPI_Bcast(sendCounts, nProcs, MPI_INT, proc_data->masterRank, MPI_COMM_WORLD); 01092 cout << "my_id=" << ProcData::instance()->myRank << "CGMMemFile::scatter_balanced_entity_list4.1" << endl; 01093 01094 for (int i = 1; i < nProcs; i++) { 01095 displacements[i] = displacements[i-1] + sendCounts[i-1]; 01096 } 01097 cout << "my_id=" << ProcData::instance()->myRank << "CGMMemFile::scatter_balanced_entity_list4.2" << endl; 01098 01099 mySendCount = sendCounts[proc_data->myRank]; 01100 cout << "my_id=" << ProcData::instance()->myRank << "CGMMemFile::scatter_balanced_entity_list4.3" << endl; 01101 01102 if (!proc_data->is_master()) check_size(mySendCount); 01103 cout << "my_id=" << ProcData::instance()->myRank << "CGMMemFile::scatter_balanced_entity_list4.4" << endl; 01104 01105 PRINT_DEBUG_100("Scattering buffer from master.\n"); 01106 01107 cout << "CGMMemFile::scatter_balanced_entity_list5" << endl; 01108 // scatter geometry 01109 MPI_Scatterv(m_pBuffer, sendCounts, displacements, MPI_BYTE, m_pBuffer, 01110 mySendCount, MPI_BYTE, proc_data->masterRank, MPI_COMM_WORLD); 01111 01112 cout << "CGMMemFile::scatter_balanced_entity_list5.1" << endl; 01113 if (!proc_data->is_master()) 01114 status = read_refentity_list(ref_entity_list); 01115 01116 cout << "CGMMemFile::scatter_balanced_entity_list6" << endl; 01117 if (CUBIT_TRUE == DEBUG_FLAG(137)) { 01118 //MPI_Barrier(MPI_COMM_WORLD); 01119 if (proc_data->is_master()) { 01120 tScatter = MPI_Wtime() - tScatter; 01121 GeometryQueryTool *gti = GeometryQueryTool::instance(); 01122 01123 PRINT_DEBUG_137("total time to scatter (sec) = %f\n", tScatter); 01124 PRINT_DEBUG_137("Complexity: vertices, edges, faces, bodies = %d, %d, %d, %d\n", 01125 gti->num_ref_vertices(), gti->num_ref_edges(), gti->num_ref_faces(), 01126 gti->num_bodies()); 01127 PRINT_DEBUG_137("Stats: %s, %d, %d, %f, %f, %d, %d, %d, %d\n", 01128 filename, ProcData::instance()->numProcs, m_sizeBuffer, 0.0, tScatter, 01129 gti->num_ref_vertices(), gti->num_ref_edges(), gti->num_ref_faces(), 01130 gti->num_bodies()); 01131 } 01132 } 01133 cout << "CGMMemFile::scatter_balanced_entity_list7" << endl; 01134 01135 //for (int l = 0; l < nProcs; l++) 01136 //delete balance_lists[l]; 01137 01138 01139 01140 return status; 01141 } 01142 */ 01143 // partition input 01144 CubitStatus CGMMemFile::scatter_balanced_entity_list(DLIList<RefEntity*> &ref_entity_list, 01145 DLIList<RefEntity*> &ref_entity_list_master, 01146 DLIList<RefEntity*> **balanced_lists) 01147 { 01148 //cout << "CGMMemFile::scatter_balanced_entity_list1" 01149 // << ",balanced_lists=" << balanced_lists << endl; 01150 // scatter exact amount of geometry information to each processors 01151 CubitStatus status; 01152 double tScatter; 01153 int mySendCount; 01154 ProcData *proc_data = ProcData::instance(); 01155 01156 if (DEBUG_FLAG(137) && proc_data->is_master()) 01157 #ifdef USE_MPI 01158 tScatter = MPI_Wtime(); 01159 #endif 01160 01161 int nProcs = proc_data->numProcs; 01162 int *sendCounts = new int[nProcs]; 01163 int *displacements = new int[nProcs]; 01164 //int nBarEntity; 01165 //int restEntity; 01166 //int nEndEntity; 01167 displacements[0] = 0; 01168 01169 //cout << "CGMMemFile::scatter_balanced_entity_list2" << endl; 01170 01171 if (proc_data->is_master()) { 01172 //cout << "CGMMemFile::scatter_balanced_entity_list3.1" << endl; 01173 01174 //DLIList<RefEntity*> **balance_lists = new DLIList<RefEntity*>*[nProcs]; 01175 01176 //for (int i = 0; i < nProcs; i++) 01177 //balance_lists[i] = new DLIList<RefEntity*>; 01178 01179 //cout << "CGMMemFile::scatter_balanced_entity_list3.4" << endl; 01180 int sum = 0; 01181 for (int j = 0; j < nProcs; j++) { 01182 //cout << "CGMMemFile::scatter_balanced_entity_list3.41" << endl; 01183 //cout << "balanced_lists[j]->size()=" << balanced_lists[j]->size() 01184 // << endl; 01185 01186 sendCounts[j] = get_refentity_list_size(*(balanced_lists[j])); 01187 //cout << "CGMMemFile::scatter_balanced_entity_list3.42" << endl; 01188 sum += sendCounts[j]; 01189 //cout << "CGMMemFile::scatter_balanced_entity_list3.43" << endl; 01190 } 01191 01192 //cout << "CGMMemFile::scatter_balanced_entity_list3.5" << endl; 01193 // check the size of the buffer and resize if necessary 01194 check_size(sum); 01195 01196 //cout << "CGMMemFile::scatter_balanced_entity_list3.6" << endl; 01197 // now actually append the information 01198 ref_entity_list.clean_out(); 01199 for (int k = 0; k < nProcs; k++) { 01200 append_refentity_list(*balanced_lists[k], sendCounts[k]); 01201 ref_entity_list += *balanced_lists[k]; // serialize ref_entity_list 01202 } 01203 //cout << "CGMMemFile::scatter_balanced_entity_list3.7" << endl; 01204 // check and save ref_entity_list information for master 01205 ref_entity_list_master.clean_out(); 01206 //cout << "CGMMemFile::scatter_balanced_entity_list3.71" << endl; 01207 //cout << "balanced_lists[0]=" << balanced_lists[0] << endl; 01208 ref_entity_list_master += *balanced_lists[0]; 01209 //cout << "CGMMemFile::scatter_balanced_entity_list3.72" << endl; 01210 } 01211 01212 //cout << "my_id=" << ProcData::instance()->myRank << "CGMMemFile::scatter_balanced_entity_list4" << endl; 01213 // broadcast buffer size array 01214 PRINT_DEBUG_100("Broadcasting buffer size array from master.\n"); 01215 01216 //for (int n = 0; n < nProcs; n++) 01217 //cout << "sendCounts[" << n << "]=" << sendCounts[n] << endl; 01218 01219 #ifdef USE_MPI 01220 MPI_Bcast(sendCounts, nProcs, MPI_INT, proc_data->masterRank, MPI_COMM_WORLD); 01221 #endif 01222 //cout << "my_id=" << ProcData::instance()->myRank << "CGMMemFile::scatter_balanced_entity_list4.1" << endl; 01223 01224 for (int i = 1; i < nProcs; i++) { 01225 displacements[i] = displacements[i-1] + sendCounts[i-1]; 01226 } 01227 //cout << "my_id=" << ProcData::instance()->myRank << "CGMMemFile::scatter_balanced_entity_list4.2" << endl; 01228 01229 mySendCount = sendCounts[proc_data->myRank]; 01230 //cout << "my_id=" << ProcData::instance()->myRank << "CGMMemFile::scatter_balanced_entity_list4.3" << endl; 01231 01232 if (!proc_data->is_master()) check_size(mySendCount); 01233 //cout << "my_id=" << ProcData::instance()->myRank << "CGMMemFile::scatter_balanced_entity_list4.4" << endl; 01234 01235 PRINT_DEBUG_100("Scattering buffer from master.\n"); 01236 01237 //cout << "CGMMemFile::scatter_balanced_entity_list5" << endl; 01238 // scatter geometry 01239 #ifdef USE_MPI 01240 MPI_Scatterv(m_pBuffer, sendCounts, displacements, MPI_BYTE, m_pBuffer, 01241 mySendCount, MPI_BYTE, proc_data->masterRank, MPI_COMM_WORLD); 01242 #endif 01243 01244 //cout << "CGMMemFile::scatter_balanced_entity_list5.1" << endl; 01245 if (!proc_data->is_master()) 01246 status = read_refentity_list(ref_entity_list); 01247 01248 //cout << "CGMMemFile::scatter_balanced_entity_list6" << endl; 01249 // if (CUBIT_TRUE == DEBUG_FLAG(138)) { 01250 //MPI_Barrier(MPI_COMM_WORLD); 01251 // if (proc_data->is_master()) { 01252 // tScatter = MPI_Wtime() - tScatter; 01253 // GeometryQueryTool *gti = GeometryQueryTool::instance(); 01254 01255 // PRINT_DEBUG_138("total time to scatter (sec) = %f\n", tScatter); 01256 // PRINT_DEBUG_138("Complexity: vertices, edges, faces, bodies = %d, %d, %d, %d\n", 01257 // gti->num_ref_vertices(), gti->num_ref_edges(), gti->num_ref_faces(), 01258 // gti->num_bodies()); 01259 // PRINT_DEBUG_138("Stats: %s, %d, %d, %f, %f, %d, %d, %d, %d\n", 01260 // filename, ProcData::instance()->numProcs, m_sizeBuffer, 0.0, tScatter, 01261 // gti->num_ref_vertices(), gti->num_ref_edges(), gti->num_ref_faces(), 01262 // gti->num_bodies()); 01263 // } 01264 // } 01265 //cout << "CGMMemFile::scatter_balanced_entity_list7" << endl; 01266 01267 //for (int l = 0; l < nProcs; l++) 01268 //delete balance_lists[l]; 01269 01270 01271 01272 return status; 01273 } 01274 01275 CubitStatus CGMMemFile::check_size(int &target_size, CubitBoolean keep) 01276 { 01277 PRINT_DEBUG_100("Checking buffer size on proc %d, target size %d.\n", 01278 ProcData::instance()->myRank, target_size); 01279 if ((int)m_sizeBuffer < target_size) { 01280 PRINT_DEBUG_100("Increasing buffer size on proc %d.\n", ProcData::instance()->myRank); 01281 void *temp_buffer = malloc(target_size); 01282 if (keep && 0 != m_currentPosition) memcpy(temp_buffer, m_pBuffer, m_currentPosition); 01283 delete m_pBuffer; 01284 m_pBuffer = (unsigned char *) temp_buffer; 01285 m_sizeBuffer = target_size; 01286 } 01287 01288 return CUBIT_SUCCESS; 01289 } 01290 DLIList <int> *CGMMemFile::get_body_to_proc() { 01291 return &bodyToProc; 01292 } 01293 /* 01294 std::vector<int> *CGMMemFile::get_body_to_proc() { 01295 return &bodyToProc; 01296 } 01297 */ 01298 /* 01299 int *CGMMemFile::get_body_to_proc() { 01300 return bodyToProc; 01301 } 01302 01303 int CGMMemFile::get_num_body_to_proc() { 01304 return nBodyToProc; 01305 } 01306 */
