cgma
00001 //- Class: ChollaPoint 00002 //- Owner: Steven J. Owen 00003 //- Description: Maintains a list of mesh. This is used to store 00004 //- the exterior skin while creating a geometry from a mesh. 00005 //- Created: 4/27/01 00006 //- Checked By: 00007 //- Version: 00008 00009 #ifndef ChollaPoint_HPP 00010 #define ChollaPoint_HPP 00011 00012 #include "DLIList.hpp" 00013 #include "ChollaEntity.hpp" 00014 00015 class Curve; 00016 class FacetEntity; 00017 class ChollaCurve; 00018 class ChollaSurface; 00019 class ChollaVolume; 00020 00021 class ChollaPoint : public ChollaEntity 00022 { 00023 private: 00024 00025 DLIList<ChollaCurve*> curveList; 00026 FacetEntity *myCubitPoint; 00027 void *myPoint; 00028 int id; 00029 ChollaPoint *myMergePartner; 00030 00031 public: 00032 00033 ChollaPoint( ); 00034 //- default constructor 00035 00036 ~ChollaPoint(); 00037 // destructor 00038 00039 void add_facet(FacetEntity *exterior_node) 00040 { myCubitPoint = exterior_node; } 00041 //- define the node associated with this point 00042 00043 void remove_facet( void ) 00044 {myCubitPoint = NULL;} 00045 //- sets myCubitPoint to NULL 00046 00047 void remove_facet( FacetEntity *facet_pnt ) 00048 {if( myCubitPoint == facet_pnt ) myCubitPoint = NULL;} 00049 //- sets myCubitPoint to NULL only if specified facet_pnt matches with myCubitPoint 00050 00051 00052 FacetEntity *get_facets() 00053 {return myCubitPoint;} 00054 //- get the point 00055 00056 void add_curve( ChollaCurve *fcm_ptr ) 00057 {curveList.append_unique( fcm_ptr );} 00058 //- associate a curve with this point 00059 00060 inline void remove_curve( ChollaCurve *fcm_ptr ) 00061 { curveList.remove( fcm_ptr ); } 00062 //- removes a curve attached with it 00063 00064 DLIList<ChollaCurve*> &get_curves() 00065 {return curveList;} 00066 //- get the list of curves attached to this point 00067 00068 DLIList<ChollaCurve*> *get_curve_list_ptr() 00069 {return &curveList;} 00070 //- get the pointer to the list of curves 00071 00072 void assign_geometric_point(void *point) 00073 {myPoint = point;} 00074 //- set the geometric point associated with the ChollaPoint 00075 00076 void* get_geometric_point() 00077 {return myPoint;} 00078 //- return the geometric point associated with the ChollaPoint 00079 00080 int get_id(){return id;} 00081 00082 void get_surfaces(DLIList<ChollaSurface *> &surf_list); 00083 //- get list of associated cholla surfaces 00084 00085 CubitBoolean is_in_curve( ChollaCurve *chcurve ); 00086 // return whether this point is in the given curve 00087 00088 CubitBoolean is_in_surface( ChollaSurface *cholla_surf ); 00089 // return whether this point is in the given surface 00090 00091 CubitBoolean is_in_volume( ChollaVolume *cholla_vol ); 00092 // return whether this point is in the given volume 00093 00094 CubitStatus verify_curves(); 00095 //- verify that all curves at this point have this point as an adjacency 00096 00097 ChollaPoint *merge_partner(){ return myMergePartner; } 00098 00099 void set_merge_partner( ChollaPoint *merge_partner ) 00100 { myMergePartner = merge_partner;} 00101 00102 00103 }; 00104 00105 template <> struct DLIListSorter<ChollaPoint*> 00106 { 00107 bool operator()(ChollaPoint* a, ChollaPoint* b) { return a->get_id() < b->get_id(); } 00108 }; 00109 00110 #endif 00111 00112
