cgma
00001 //- Class: ChollaSkinTool 00002 //- Description: Creates a skin defined by facets and points, depending on the 00003 //- dimensionality of the desired skin. 00004 //- Owner: Steve Owen 00005 //- Checked by: 00006 //- Version: 00007 #include "ChollaSkinTool.hpp" 00008 #include "FacetEntity.hpp" 00009 #include "TDGeomFacet.hpp" 00010 #include "CastTo.hpp" 00011 #include "ChollaSurface.hpp" 00012 #include "ChollaCurve.hpp" 00013 #include "CubitFacetEdge.hpp" 00014 #include "TDFacetBoundaryEdge.hpp" 00015 #include "ChollaDebug.hpp" 00016 #include "GfxDebug.hpp" 00017 00018 static int mydebug = 0; 00019 //================================================================================== 00020 //Function: ChollaSkinTool (PUBLIC) (constructor) 00021 //================================================================================== 00022 ChollaSkinTool::ChollaSkinTool() 00023 { 00024 } 00025 //================================================================================== 00026 //Function: ~ChollaSkinTool (PUBLIC) (destructor) 00027 //================================================================================== 00028 ChollaSkinTool::~ChollaSkinTool() 00029 { 00030 } 00031 00032 //================================================================================== 00033 //Function: skin_1d (PUBLIC) 00034 //Description: creates a skin of the given facet entities. 00035 //================================================================================== 00036 CubitStatus ChollaSkinTool::skin_1d(DLIList<FacetEntity*> &facet_list, 00037 ChollaCurve *&facet_curve_mesh_ptr) 00038 { 00039 CubitStatus rv = CUBIT_SUCCESS; 00040 00041 // create a ChollaCurve if we have to (only if this is a 1D facet) 00042 00043 if (!facet_curve_mesh_ptr) 00044 { 00045 FacetEntity *edge_ptr = facet_list.get(); 00046 TDGeomFacet *td_gm = TDGeomFacet::get_geom_facet( edge_ptr ); 00047 facet_curve_mesh_ptr = new ChollaCurve( td_gm->get_block_id() ); 00048 00049 // associate all of the tooldata on the faces of this surf with the 00050 // new ChollaCurve 00051 00052 int ii; 00053 for (ii=0; ii<facet_list.size(); ii++) 00054 { 00055 edge_ptr = facet_list.get_and_step(); 00056 facet_curve_mesh_ptr->add_facet( edge_ptr ); 00057 td_gm = TDGeomFacet::get_geom_facet( edge_ptr ); 00058 td_gm->add_cholla_curve( facet_curve_mesh_ptr ); 00059 } 00060 } 00061 00062 // Note: the start and end points of this curve will be defined in 00063 // ChollaCurve::split_curve. The BlockPointMesh objects at these points 00064 // will be defined in MeshGeometryCreator::classify_node 00065 00066 return rv; 00067 } 00068 00069 //================================================================================== 00070 //Function: skin_2d (PUBLIC) 00071 //Description: creates a skin of the given mesh entities. 00072 //================================================================================== 00073 CubitStatus ChollaSkinTool::skin_2d(DLIList<FacetEntity*> &facet_list, 00074 ChollaSurface *&facet_surface_mesh_ptr) 00075 { 00076 if(facet_list.size() == 0){ 00077 return CUBIT_SUCCESS; 00078 } 00079 00080 int debugflag=0; 00081 if (debugflag) 00082 { 00083 dcolor(CUBIT_YELLOW_INDEX); 00084 dldraw( facet_list ); 00085 dview(); 00086 dcolor(CUBIT_RED_INDEX); 00087 } 00088 CubitStatus rv = CUBIT_SUCCESS; 00089 int block_id; 00090 00091 // create a ChollaSurface if we have to (only if this is a 2D model) 00092 00093 FacetEntity *face_ptr = facet_list.get(); 00094 TDGeomFacet *td_gm = TDGeomFacet::get_geom_facet( face_ptr ); 00095 block_id = td_gm->get_block_id(); 00096 if (!facet_surface_mesh_ptr) 00097 { 00098 facet_surface_mesh_ptr = new ChollaSurface(block_id); 00099 00100 // associate all of the tooldata on the faces of this surf with the new ChollaSurface 00101 00102 int ii; 00103 for (ii=0; ii<facet_list.size(); ii++) 00104 { 00105 face_ptr = facet_list.get_and_step(); 00106 facet_surface_mesh_ptr->add_facet( face_ptr ); 00107 td_gm = TDGeomFacet::get_geom_facet( face_ptr ); 00108 td_gm->add_cholla_surf( facet_surface_mesh_ptr ); 00109 td_gm->set_hit_flag( facet_surface_mesh_ptr->get_id() ); 00110 } 00111 } 00112 00113 // create a single ChollaCurve for this surface (assumes one loop of edges) 00114 00115 ChollaCurve *fcm_ptr = new ChollaCurve( block_id ); 00116 facet_surface_mesh_ptr->add_curve( fcm_ptr ); 00117 fcm_ptr->add_surface( facet_surface_mesh_ptr ); 00118 00119 // loop through all faces on this surface searching for the boundary edges 00120 00121 int jj, kk, ll; 00122 for ( kk = 0; kk < facet_list.size(); kk++) 00123 { 00124 face_ptr = facet_list.get_and_step(); 00125 DLIList<CubitFacetEdge*> edge_list; 00126 face_ptr->edges( edge_list ); 00127 00128 // loop through each edge on this face searching for boundary edges 00129 00130 for (jj=edge_list.size(); jj > 0; jj--) 00131 { 00132 CubitFacetEdge *edge_ptr = edge_list.get_and_step(); 00133 00134 // check if this edge has already been processed from an adjacent surface. 00135 // If it has, then tool data would have already been defined at this edge 00136 // and by definition would be at the boundary (only tooldatas on edges 00137 // at the boundary ofa surface are created) 00138 00139 TDGeomFacet *td_gm_edge = TDGeomFacet::get_geom_facet(edge_ptr); 00140 int on_boundary = 0; 00141 if (td_gm_edge != NULL) 00142 { 00143 on_boundary = 1; 00144 00145 // check for internal C-zero edge 00146 00147 if (edge_ptr->num_adj_facets() == 2) 00148 { 00149 TDFacetBoundaryEdge *td_fbe = 00150 TDFacetBoundaryEdge::get_facet_boundary_edge( edge_ptr ); 00151 if (td_fbe != NULL) 00152 { 00153 if (td_fbe->is_internal_edge()) 00154 { 00155 on_boundary = 0; 00156 } 00157 } 00158 } 00159 } 00160 00161 // check for general case where no tool data yet defined 00162 00163 else 00164 { 00165 DLIList<FacetEntity*> adj_face_list; 00166 00167 // check the adjacent faces to this edge. If only one adjacent face, then 00168 // it is on the boundary. If more than one face, then the other face(s) 00169 // must be associated with a surface other than facet_surface_mesh_ptr 00170 // in order to be on the boundary 00171 00172 edge_ptr->get_parents( adj_face_list ); 00173 if (adj_face_list.size() <= 1) 00174 { 00175 on_boundary = 1; 00176 } 00177 else 00178 { 00179 for (ll=adj_face_list.size(); ll> 0 && !on_boundary; ll--) 00180 { 00181 FacetEntity *adj_face_ptr = adj_face_list.get_and_step(); 00182 if (adj_face_ptr != face_ptr) 00183 { 00184 TDGeomFacet *td_gm_adjface = TDGeomFacet::get_geom_facet(adj_face_ptr); 00185 DLIList<ChollaSurface*> surf_list; 00186 td_gm_adjface->get_cholla_surfs( surf_list ); 00187 00188 // if it doesn't have an associated surface yet, then it is 00189 // a neighboring surface that has not been defined yet (this 00190 // should only occur for the 2D case) 00191 00192 if (surf_list.size() == 0) 00193 { 00194 on_boundary = 1; 00195 } 00196 else 00197 { 00198 00199 // there should only be one surface associated with 00200 // each face - otherwise we've screwed up somewhere 00201 00202 assert ( surf_list.size() == 1 ); 00203 00204 // if the surface is not the same as the current surface 00205 // then we are at the boundary 00206 00207 ChollaSurface *check_bsm_ptr = surf_list.get(); 00208 if (facet_surface_mesh_ptr != check_bsm_ptr) 00209 { 00210 on_boundary = 1; 00211 } 00212 } 00213 } 00214 } 00215 } 00216 } 00217 if (on_boundary) 00218 { 00219 // create a tool data if needed 00220 00221 if (td_gm_edge == NULL) 00222 { 00223 TDGeomFacet::add_geom_facet(edge_ptr, -1); 00224 td_gm_edge = TDGeomFacet::get_geom_facet( edge_ptr ); 00225 edge_ptr->set_as_feature(); 00226 } 00227 00228 // add the pointer to this surface onto the edge tool data 00229 00230 td_gm_edge->add_cholla_surf( facet_surface_mesh_ptr ); 00231 00232 // add this edge to the curve 00233 00234 fcm_ptr->add_facet( edge_ptr ); 00235 if (mydebug) 00236 dedraw(edge_ptr); 00237 } 00238 } 00239 } 00240 00241 return rv; 00242 } 00243 00244 00245 00246 00247 00248
