cgma
00001 //- Class: Cubit2DPoint 00002 //- 00003 //- Description: This file defines the Cubit2DPoint class which is a 00004 //- standard two-dimensional point in space. 00005 //- 00006 //- Owner: Steve Storm 00007 00008 #ifndef CUBIT2DPOINT_HPP 00009 #define CUBIT2DPOINT_HPP 00010 00011 #include "CubitDefines.h" 00012 #include "CGMUtilConfigure.h" 00013 00014 template <class X> class DLIList; 00015 00016 class CUBIT_UTIL_EXPORT Cubit2DPoint 00017 { 00018 public: 00019 00020 //- Heading: Constructors and Destructor 00021 Cubit2DPoint(); //- Default constructor. 00022 00023 Cubit2DPoint( const double x, const double y ); 00024 //- Constructor: create point from two components 00025 00026 Cubit2DPoint( const double xy[2] ); 00027 //- Constructor: create point from array 00028 00029 Cubit2DPoint( const Cubit2DPoint& copy_from ); //- Copy Constructor 00030 Cubit2DPoint( const Cubit2DPoint* copy_from ); //- Copy Constructor 00031 00032 //- Heading: Set and Inquire Functions 00033 void set( const double x, const double y ); 00034 //- Change point components to {x}, {y} 00035 00036 void set( const double xy[2] ); 00037 //- Change point components to xy[0], xy[1] 00038 00039 void set( const Cubit2DPoint& to_copy ); 00040 //- Same as operator=(const Cubit2DPoint&) 00041 00042 double x() const; //- Return x component of point 00043 double y() const; //- Return y component of point 00044 00045 void get_xy( double &x, double &y ); //- Get x, y components 00046 void get_xy( double xy[3] ); //- Get xy array 00047 00048 void x( const double x ); //- Set x component of point 00049 void y( const double y ); //- Set y component of point 00050 00051 void print_me(); 00052 //- Prints out the coordinates of this point. 00053 00054 void min_max( const Cubit2DPoint &pnt2, 00055 double &xmin, double &xmax, 00056 double &ymin, double &ymax ) const; 00057 //- Get min & max coordinates between this point & the 00058 //- passed-in point. Analogous to a 2D bounding box. 00059 00060 void update_min_max( Cubit2DPoint &min, Cubit2DPoint &max ) const; 00061 //- Include this points coordinates in the given min-max bounding box. 00062 00063 CubitBoolean is_on_line_segment( const Cubit2DPoint &end1, 00064 const Cubit2DPoint &end2, 00065 double tol = 1e-10 ) const; 00066 //- Determine if this point is on the line segment defined by end1 00067 //- and end2. Uses a triangle method for speed. Note that in this 00068 //- implementation the tolerance is not how close the point is to 00069 //- the line - rather, it is how small a triangle area needs to be 00070 //- in order to consider its three points co-linear. 00071 00072 Cubit2DPoint &operator=(const Cubit2DPoint &from); 00073 00074 private: 00075 00076 double xVal; //- x component of point. 00077 double yVal; //- y component of point. 00078 }; 00079 00080 inline Cubit2DPoint::Cubit2DPoint(const Cubit2DPoint& copy_from) 00081 : xVal(copy_from.xVal), yVal(copy_from.yVal) 00082 {} 00083 00084 inline Cubit2DPoint::Cubit2DPoint(const Cubit2DPoint* copy_from) 00085 : xVal(copy_from->xVal), yVal(copy_from->yVal) 00086 {} 00087 00088 inline Cubit2DPoint::Cubit2DPoint() 00089 : xVal(0.0), yVal(0.0) 00090 {} 00091 00092 inline Cubit2DPoint::Cubit2DPoint( const double x, 00093 const double y ) 00094 : xVal(x), yVal(y) 00095 {} 00096 00097 inline double Cubit2DPoint::x() const 00098 { return xVal; } 00099 inline double Cubit2DPoint::y() const 00100 { return yVal; } 00101 00102 inline void Cubit2DPoint::x( const double x ) 00103 { xVal = x; } 00104 inline void Cubit2DPoint::y( const double y ) 00105 { yVal = y; } 00106 00107 inline void Cubit2DPoint::set( const double x, 00108 const double y ) 00109 { 00110 xVal = x; 00111 yVal = y; 00112 } 00113 00114 inline void Cubit2DPoint::set( const double xy[2] ) 00115 { 00116 xVal = xy[0]; 00117 yVal = xy[1]; 00118 } 00119 00120 inline Cubit2DPoint& Cubit2DPoint::operator=(const Cubit2DPoint &from) 00121 { 00122 xVal = from.xVal; 00123 yVal = from.yVal; 00124 return *this; 00125 } 00126 00127 inline void Cubit2DPoint::set(const Cubit2DPoint& to_copy) 00128 { 00129 *this = to_copy; 00130 } 00131 00132 #endif 00133 00134
