cgma
00001 //----------------------------------------------------------------------------- 00002 // 00003 // File: CubitPoint.hpp 00004 // 00005 // Purpose: Point Class used for mesh based geometry and other tools. It is 00006 // primarily used in conjuction with CubitFacet and CubitFacetEdge 00007 // classes. 00008 // 00009 // Notes: Note that this class does not contain any private data. 00010 // All data should be defined within the child classes inherited 00011 // from this class. The current Cubit data class that inherits 00012 // from CubitPoint is CubitPointData. This is done so that 00013 // other applications using CubitPoints can use their own 00014 // point data, but take advantage of the CGM/Cubit functionality. 00015 // Please do not add private data to this class; instead add the 00016 // data to the children and access through virtual functions. 00017 // 00018 // Do not create a CubitPoint directly. For example, don't do: 00019 // CubitPoint *cp = new CubitPoint(...); 00020 // You should instead create the appropriate child class, and 00021 // cast it to a CubitPoint for use. For example: 00022 // CubitPoint *cp = (CubitPoint *) new CubitPointData(...); 00023 // 00024 //----------------------------------------------------------------------------- 00025 00026 #ifndef CUBITPOINT_HPP 00027 #define CUBITPOINT_HPP 00028 00029 // Include for CubitBoolean 00030 #include "CubitDefines.h" 00031 #include "CubitVector.hpp" 00032 #include "DLIList.hpp" 00033 #include "MemoryManager.hpp" 00034 #include "ToolDataUser.hpp" 00035 #include "CubitMatrix.hpp" 00036 #include "FacetEntity.hpp" 00037 class CubitFacet; 00038 class CubitQuadFacet; 00039 class CubitFacetEdge; 00040 class CubitPoint; 00041 class CubitTransformMatrix; 00042 class Surface; 00043 class CubitBox; 00044 00045 class CubitPoint : public FacetEntity 00046 { 00047 private: 00048 00049 static double boxTol; 00050 00051 protected: 00052 00053 int markedFlag; 00054 //-generic marking flag. 00055 00056 CubitVector *surfNormal; 00057 //- The normalized surface normal (if required) 00058 00059 double dCoef; 00060 //- D coeficient in tangent plane equation Ax+By+Cz+D=0 00061 //- where A,B,C is surfNormal 00062 00063 double uVal, vVal, sizeVal; 00064 //- parametric location of point 00065 00066 CubitVector *surfU, *surfV; 00067 //- Orthogonal surface tangent vectors at the point 00068 00069 double *coefVector; 00070 //- coefficients for quadric surface approximation 00071 00072 IttyBit isFeature; 00073 //- set if this point is a feature 00074 00075 public: 00076 00077 CubitPoint(); 00078 virtual ~CubitPoint(); 00079 00080 virtual int id() = 0; 00081 virtual void set_id( int ) {}; 00082 00083 virtual double x() = 0; 00084 virtual double y() = 0; 00085 virtual double z() = 0; 00086 virtual void set( const CubitVector &pos ) = 0; 00087 00088 virtual void marked(int marked) {markedFlag = marked;}; 00089 virtual int marked() {return markedFlag;}; 00090 00091 virtual CubitVector coordinates() const = 0; 00092 virtual void coordinates(double point_array[3]) = 0; 00093 00094 virtual void add_facet( CubitFacet *facet) = 0; 00095 virtual void remove_facet( CubitFacet *facet) = 0; 00096 virtual int num_adj_facets() = 0; 00097 00098 virtual void facets( DLIList<CubitFacet*> &facet_list ) = 0; 00099 virtual void edges( DLIList<CubitFacetEdge*> &edge_list ) = 0; 00100 virtual void points( DLIList<CubitPoint*> &point_list ) = 0; 00101 00102 virtual void tris( DLIList<CubitFacet*> &facet_list ) { facets(facet_list); } 00103 00104 virtual void normal( CubitVector &surf_norm ); 00105 virtual CubitVector normal(); 00106 virtual CubitVector* normal_ptr(); 00107 00108 virtual void set_normal( CubitVector &surf_norm ); 00109 virtual void reset_normal( ); 00110 00111 virtual void d_coef( const double d_coefficient ) {dCoef = d_coefficient;}; 00112 virtual double d_coef() {return dCoef;}; 00113 00114 virtual double u() { return uVal; }; 00115 virtual double v() { return vVal; }; 00116 virtual double size() {return sizeVal; }; 00117 virtual void set_uv( double u, double v ) { uVal = u; vVal = v; }; 00118 virtual void set_uvs(double u, double v, double s) {uVal = u; vVal = v; sizeVal = s; } 00119 //- get and set the u-v coordinates (careful with internal boundaries - see TDFacetBoundarPoint) 00120 virtual CubitStatus get_uv( CubitFacet *facet, double &u, double &v ); 00121 virtual CubitStatus get_uvs( CubitFacet *facet, double &u, double &v, double &s); 00122 //- return the u-v coords with respect to the surface that the facet is on 00123 00124 virtual void du( CubitVector &duvec ); 00125 virtual CubitVector du(); 00126 00127 virtual void dv( CubitVector &dvvec ); 00128 virtual CubitVector dv(); 00129 00130 virtual double *coef_vector( ); 00131 virtual void coef_vector( const CubitMatrix& coef ); 00132 00133 virtual CubitStatus merge_points( CubitPoint *cp, CubitBoolean keep_point = CUBIT_FALSE ); 00134 00135 void shared_facets( CubitPoint* other_point, 00136 CubitFacet*& facet1, 00137 CubitFacet*& facet2 ); 00138 00139 void shared_facets( CubitPoint* other_point, 00140 DLIList<CubitFacet*>& result_list ); 00141 00142 CubitFacetEdge *shared_edge( CubitPoint* other_point ); 00143 00144 00145 void adjacent_points( CubitPoint **adj_points, 00146 int &num_adj_points ); 00147 void adjacent_points( DLIList<CubitPoint*>& result_list ); 00148 //- return array of points sharing adjacent facets 00149 00150 CubitBox bounding_box(); 00151 //-return a box around this point 00152 00153 void facets_on_surf( int surf_id, DLIList<CubitFacet *> &facet_list, 00154 CubitBoolean &on_internal_boundary ); 00155 //- return facets adjacent this point that are on the given surface 00156 //- surf_id is the FacetEvalTool ToolID 00157 00158 CubitVector normal( CubitFacet *facet_ptr ); 00159 CubitVector normal( CubitQuadFacet *qfacet_ptr ); 00160 CubitVector normal( CubitFacetEdge *edge_ptr ); 00161 //- return normal with respect to the facet and edge 00162 00163 CubitVector tangent( CubitFacetEdge *edge_ptr, double mindot ); 00164 //- return tangent with respect to the edge 00165 void next_feature_edges( CubitFacetEdge *this_edge_ptr, 00166 DLIList <CubitFacetEdge *> feature_edge_list ); 00167 //- given a facet boundary edge and this point, get a list 00168 //- of the next fetaure edges at this point 00169 00170 CubitVector project_to_tangent_plane( CubitVector &pt ); 00171 //- Project a point to the tangent plane defined at the CubitPoint 00172 00173 void transform_to_local( CubitVector &glob_vec, 00174 CubitVector &loc_vec ); 00175 void transform_to_global( CubitVector &loc_vec, 00176 CubitVector &glob_vec ); 00177 //- transform a point between local and global system 00178 00179 void define_tangent_vectors(); 00180 //- set up the tangent vectors at the point for quadratic interpolation 00181 00182 void get_parents( DLIList<FacetEntity*> &facet_list ); 00183 00184 void debug_draw( int color = -1, int flush = 1, int draw_uv=0 ); 00185 // debug drawing 00186 00187 void compute_avg_normal(); 00188 //- compute the avg normal at this point based on adjacent facets 00189 00190 CubitFacetEdge *get_edge( CubitPoint *other_point ); 00191 //- return the edge between two points if one exists 00192 00193 void transform(CubitTransformMatrix &tfmat); 00194 void rotate_normal(CubitTransformMatrix &rotmat); 00195 //- apply transformations to the point 00196 00197 CubitStatus check_inverted_facets( const CubitVector& new_position ); 00198 //- Check if moving this CubitPoint to the passed position 00199 //- will invert any adjacent facets. Returns true if no facets 00200 //- will be inverted, false if one or more facets will be 00201 //- inerted when the point is moved. 00202 00203 void set_as_feature() { isFeature = 1; } 00204 CubitBoolean is_feature( ){return (isFeature ? CUBIT_TRUE : CUBIT_FALSE); } 00205 // set and get the isFeature bit 00206 00207 static void set_box_tol( double tol ) {boxTol = tol;} 00208 }; 00209 00210 inline void CubitPoint::coef_vector(const CubitMatrix &input_matrix) 00211 { 00212 if (!coefVector) coefVector = new double[5]; 00213 for (int i=0; i<5; i++) { 00214 coefVector[i] = input_matrix.get(i,0); 00215 } 00216 } 00217 00218 inline void CubitPoint::normal( CubitVector &surf_norm ) 00219 { 00220 if(!surfNormal) surfNormal = new CubitVector (surf_norm); 00221 else *surfNormal = surf_norm; 00222 } 00223 00224 inline CubitVector CubitPoint::normal() 00225 { 00226 if (surfNormal==NULL) compute_avg_normal(); 00227 return *surfNormal; 00228 } 00229 00230 inline CubitVector* CubitPoint::normal_ptr() 00231 { 00232 return surfNormal; 00233 } 00234 00235 inline void CubitPoint::set_normal( CubitVector &surf_norm ) 00236 { 00237 *surfNormal = surf_norm; 00238 } 00239 00240 inline void CubitPoint::reset_normal() 00241 { 00242 compute_avg_normal(); 00243 } 00244 00245 inline void CubitPoint::du( CubitVector &duvec ) 00246 { 00247 if(!surfU) surfU = new CubitVector (duvec); 00248 else *surfU = duvec; 00249 } 00250 00251 inline void CubitPoint::dv( CubitVector &dvvec ) 00252 { 00253 if(!surfV) surfV = new CubitVector (dvvec); 00254 else *surfV = dvvec; 00255 } 00256 00257 inline CubitVector CubitPoint::du() 00258 { 00259 assert(surfU != NULL); 00260 return *surfU; 00261 } 00262 00263 inline CubitVector CubitPoint::dv() 00264 { 00265 assert(surfV != NULL); 00266 return *surfV; 00267 } 00268 00269 inline double *CubitPoint::coef_vector( ) 00270 { 00271 assert (coefVector != NULL); 00272 return coefVector; 00273 } 00274 00275 class CubitPointComparator { 00276 public: 00277 bool operator () (CubitPoint * a, CubitPoint * b) const 00278 { 00279 return ( a->x() < b->x() ) || (a->x()==b->x() && a->y()<b->y()) || (a->x() == b->x() && a->y()==b->y() && a->z() < b->z() ); 00280 } 00281 }; 00282 00283 template <> struct DLIListSorter<CubitPoint*> 00284 { 00285 bool operator()(CubitPoint* a, CubitPoint* b) { return a->id() < b->id(); } 00286 }; 00287 00288 00289 #endif 00290 00291 00292 00293 00294 00295 00296
