cgma
00001 //- Class: CubitString 00002 //- 00003 //- Description: This file defines the CubitString class which is a 00004 //- simple implementation of a character string. Basic functionality 00005 //- is provided as well as equality/inequality tests, subscripting into 00006 //- a string, searching a string for another string. 00007 //- 00008 00009 #if !defined(CUBITSTRING_HPP) 00010 #define CUBITSTRING_HPP 00011 00012 #include <sstream> 00013 #include <vector> 00014 #include <string> 00015 00016 #include "CGMUtilConfigure.h" 00017 00018 // GCC compiler checking of format arguments 00019 // Note: For class member functions, the first argument is the 00020 // implicit 'this' pointer, so if the format string is the 00021 // first explicit argument A should be 2, not 1. 00022 #ifdef __GNUC__ 00023 # define CUBIT_STRING_PRINTF_FORMAT(A,B) __attribute__ ((format (printf, A, B))) 00024 #else 00025 # define CUBIT_STRING_PRINTF_FORMAT(A,B) 00026 #endif 00027 00028 #if defined(_MSC_VER) 00029 #pragma warning(push) 00030 #pragma warning(disable : 4251) // hide warnings about template dll exports 00031 #endif 00032 00034 class CUBIT_UTIL_EXPORT CubitString 00035 { 00036 public: 00038 static const size_t npos; 00039 00040 enum CaseSensitivity 00041 { 00042 CaseInsensitive, 00043 CaseSensitive 00044 }; 00045 00047 CubitString(); 00048 00050 ~CubitString(); 00051 00053 CubitString(const CubitString& s); 00054 00056 CubitString(const char* s); 00057 00058 //- Create a string from a std::string 00059 CubitString(const std::string& s); 00060 00061 CubitString(int i,char c); 00062 //- Create a string from a char 00063 00065 template <typename T> 00066 static CubitString number(const T& i) 00067 { 00068 std::stringstream si; 00069 si << i; 00070 return CubitString(si.str().c_str()); 00071 } 00072 00074 template <typename T> 00075 static T toNumber(const CubitString& str, bool *ok = NULL) 00076 { 00077 std::istringstream ss(str.c_str()); 00078 T result; 00079 bool temp_ok = ss >> result; 00080 if(ok) 00081 (*ok) = temp_ok; 00082 return result; 00083 } 00084 00090 static CubitString number(double f, unsigned int s_length = 0, unsigned int sig_digits = 0); 00091 00093 static CubitString format(const char* fmt, ...) CUBIT_STRING_PRINTF_FORMAT(1,2); 00094 00095 CubitString& operator=(const CubitString& s); 00096 00097 CubitString& operator+=(const CubitString& s); 00098 00099 CUBIT_UTIL_EXPORT friend CubitString operator+(const CubitString& s1, const CubitString& s2); 00100 00101 CUBIT_UTIL_EXPORT friend bool operator<=(const CubitString&, const CubitString&); 00102 CUBIT_UTIL_EXPORT friend bool operator>=(const CubitString&, const CubitString&); 00103 CUBIT_UTIL_EXPORT friend bool operator<(const CubitString&, const CubitString&); 00104 CUBIT_UTIL_EXPORT friend bool operator>(const CubitString&, const CubitString&); 00105 00106 bool operator==(const CubitString &s) const; 00107 bool operator!=(const CubitString &s) const; 00108 //- Predicates: Compare equality/inequality with other CubitStrings or 00109 //- with pointers to a list of characters. 00110 00113 bool compare(const CubitString& s, CaseSensitivity cs = CaseSensitive); 00114 // note case insensitive comparison with unicode is not yet supported 00115 00117 char get_at(size_t pos) const; 00119 void put_at(size_t pos, char c); 00120 00122 CubitString substr(size_t first, size_t count = CubitString::npos) const; 00123 00125 void erase(size_t pos, size_t len = npos); 00126 00128 void replace(size_t pos, size_t len, const CubitString& str); 00129 00131 void replace(const CubitString& to_find, const CubitString& to_replace); 00132 00134 void to_lower(); 00135 static void to_lower(char *string); 00137 void to_upper(); 00138 static void to_upper(char *string); 00139 00141 void trim(); 00142 00145 void simplify(); 00146 00148 void tokenize( char delimiter, std::vector<CubitString> &strings ) const; 00149 00150 00152 size_t find(const CubitString& s, size_t pos = 0) const; 00153 size_t find_first_of(const CubitString& s, size_t pos = 0) const; 00154 size_t find_first(char c, size_t pos = 0) const; 00155 size_t find_last (char c, size_t pos = CubitString::npos) const; 00156 00157 00159 bool ends_with(const CubitString& str) const; 00161 bool starts_with(const CubitString& str) const; 00162 00164 bool is_empty() const; 00165 00167 size_t length() const; 00168 00170 const char *c_str() const; 00171 00173 const std::string& str() const; 00174 00176 void clear(); 00177 00179 void resize(size_t n); 00181 void resize(size_t n, char c); 00182 00183 // UTF-16/UTF-8 unicode conversions to support using Unicode aware Windows APIs. 00184 // Note: wchar_t on non-Windows platforms is UTF-32 00185 #if defined(_WIN32) 00186 static std::wstring toUtf16(const char* str); 00187 static std::wstring toUtf16(const CubitString& str); 00188 static CubitString toUtf8(const wchar_t* str); 00189 #endif 00190 00191 #if defined(_MSC_VER) 00192 static std::wstring toNative(const char* str); 00193 static std::wstring toNative(const CubitString& str); 00194 #else 00195 static CubitString toNative(const char* str); 00196 static CubitString toNative(const CubitString& str); 00197 #endif 00198 00199 static std::wstring toWide(const CubitString& str); 00200 static CubitString toNarrow(const std::wstring& str); 00201 00202 private: 00203 std::string rep; 00204 }; 00205 00206 #if defined(_MSC_VER) 00207 #pragma warning(pop) 00208 #endif 00209 00210 #endif 00211
