cgma
00001 #ifndef FACETBOOLINTERFACE_HPP 00002 #define FACETBOOLINTERFACE_HPP 00003 00004 class FacetBody; 00005 class BodySM; 00006 class FacetSurface; 00007 class FacetCurve; 00008 class Curve; 00009 class CubitBox; 00010 00011 #include <vector> 00012 #include "CubitDefines.h" 00013 #include "DLIList.hpp" 00014 #include "../facetbool/cgm/FBStructs.hpp" 00015 00016 class FacetboolInterface { 00017 00018 public: 00019 00020 FacetboolInterface(); 00021 ~FacetboolInterface(); 00022 00023 CubitStatus webcut_FB(BodySM *bodysm_ptr, 00024 std::vector<double>& cutter_verts, 00025 std::vector<int>& cutter_connections, 00026 bool cutter_is_plane, 00027 CubitBoolean delete_bodies, 00028 CubitBoolean &intersects, 00029 DLIList<BodySM*>& results_list); 00030 00031 CubitStatus dofacetboolean(DLIList<BodySM*>& body_list, 00032 BodySM*& newBody, 00033 bool keep_old, 00034 const CubitFacetboolOp op); 00035 00036 CubitStatus dofacetboolean_subtract(BodySM*& tool_body, 00037 DLIList<BodySM*>& from_bodies, 00038 DLIList<BodySM*>& new_bodies, 00039 bool keep_old, 00040 bool* to_be_deleted, 00041 const CubitFacetboolOp op); 00042 00043 CubitStatus dofacetboolean_2bodies(BodySM*& body_in1, 00044 BodySM*& body_in2, 00045 BodySM*& body_out, 00046 bool keep_old, 00047 bool& intersection_found, 00048 const CubitFacetboolOp op); 00049 00050 CubitStatus FB_imprint_with_curves(BodySM*& body_in, 00051 BodySM*& body_out, 00052 bool keep_old); 00053 00054 CubitStatus dofacetboolean_2bodies_imprint(BodySM*& body_in1, 00055 BodySM*& body_in2, 00056 BodySM*& body_out1, 00057 BodySM*& body_out2, 00058 bool keep_old); 00059 00060 CubitStatus make_FB_edge_list(DLIList<Curve*> &ref_edge_list); 00061 00062 void get_edge_list_bbox(CubitBox& edge_list_bbox); 00063 00064 private: 00065 00066 std::vector<FB_Edge*> FB_imprint_edges; 00067 std::vector<FB_Coord*> FB_imprint_edge_coords; 00068 std::vector<FSBoundingBox*> FB_imprint_edge_bboxes; 00069 00070 CubitStatus facetbody_to_facetbool( 00071 DLIList<FacetSurface*> &facet_surf_list, 00072 std::vector<double> &body_verts, 00073 std::vector<int> &body_connections, 00074 std::vector<int> *f_c_indices, 00075 std::vector<FacetSurface *>& fsurfarray, 00076 std::vector<FacetCurve *>& fcurvearray 00077 ); 00078 int findcurve(FacetCurve *curve, std::vector<FacetCurve *>& fcurvearray); 00079 00080 void make_persistents_webcut(BodySM *body_in, 00081 BodySM *body_out1, 00082 BodySM *body_out2, 00083 std::vector<FacetSurface *>& fsurfarray, 00084 std::vector<FacetCurve *>& fcurvearray, 00085 bool *surfs_in_intersection, 00086 bool *surfs_in_subtraction, 00087 bool *curves_in_intersection, 00088 bool *curves_in_subtraction 00089 ); 00090 00091 void make_persistents_imprint(BodySM *body_in, 00092 BodySM *body_out1, 00093 std::vector<FacetSurface *>& fsurfarray, 00094 std::vector<FacetCurve *>& fcurvearray 00095 ); 00096 00097 void make_persistents_boolean(BodySM *body_in, 00098 BodySM *body_out1, 00099 std::vector<FacetSurface *>& fsurfarray, 00100 std::vector<FacetCurve *>& fcurvearray, 00101 bool *surfs_in_intersection, 00102 bool *surfs_in_subtraction, 00103 bool *curves_in_intersection, 00104 bool *curves_in_subtraction, 00105 const CubitFacetboolOp op, 00106 bool body_1 00107 ); 00108 00109 void make_persistent_curves(DLIList<FacetCurve*> fcurvelist, 00110 std::vector<FacetCurve *>& fcurvearray, 00111 int n, 00112 int which_parent = 0); 00113 00114 void make_persistent_surfaces(DLIList<FacetSurface*> fsurfaceslist, 00115 std::vector<FacetSurface *>& fsurfarray, 00116 int n, 00117 int which_parent = 0); 00118 00119 int find_coord(double xx, double yy, double zz); 00120 00121 FSBoundingBox* make_edge_bounding_box(int v0, int v1); 00122 00123 //Separate out the different "lumps" in a given body. Generally, 00124 // lumps are disjoint volumes. They will be converted to separate 00125 // volumes later in the code. 00126 CubitStatus separate_lumps( BodySM *body_ptr, bool is_sheet_body ); 00127 00128 //First call separate_lumps to find the disjoing lumps in the body, 00129 // and then separates the lumps into different bodies. 00130 CubitStatus separate_shells_into_bodies( BodySM *body_ptr, 00131 bool is_sheet_body, 00132 DLIList<BodySM*> &new_bodies ); 00133 00134 }; 00135 00136 #endif
