cgma
00001 #ifndef GMEM_HPP 00002 #define GMEM_HPP 00003 00004 // Include for CubitBoolean 00005 #include "CubitDefines.h" 00006 #include "CGMUtilConfigure.h" 00007 00008 class CubitTransformMatrix; 00009 00010 //- A point in 3D space. 00011 struct GPoint 00012 { 00013 float x; 00014 float y; 00015 float z; 00016 }; 00017 00018 typedef struct 00019 { 00020 GPoint at; 00021 GPoint from; 00022 GPoint up; 00023 float width; 00024 float height; 00025 CubitBoolean isCentered; 00026 } CubitViewParam; 00027 00028 class CUBIT_UTIL_EXPORT GMem 00029 { 00030 private: 00031 // These are made private to make them essentially read-only, 00032 // although you still have direct access to the array elements. 00033 GPoint *pointList; // x, y, z vector 00034 int ptsSize; // size of points vector 00035 int fListSize; // size of facetList vector 00036 int *facetList; // number of points in face, indices of points in face 00037 CubitBoolean pointsConsolidated; 00038 00039 void consolidate_few_points( double tolerance ); 00040 void consolidate_many_points( double tolerance ); 00041 00042 public: 00043 int pointListCount; // number valid points stored in points vector 00044 int fListCount; // number valid integers stored in facetList. 00045 // If you always use triangles, this will be 4 times the number of polygons. 00046 00047 // Constructor/Destructor take care of dynamic memory. 00048 GMem(); 00049 ~GMem(); 00050 00051 // These are high-level functions that don't require you 00052 // to know exactly what the internals are 00053 void allocate_tri(int num_tri); 00054 void allocate_polylines(int num_lines); 00055 void allocate_more_polylines(int num_lines); 00056 void clean_out(); 00057 00058 // The rest give you a little more direct control over the internals 00059 00060 // Whether points at the same coords have been merged 00061 void points_consolidated(CubitBoolean yes_no) 00062 { pointsConsolidated = yes_no; } 00063 CubitBoolean points_consolidated() 00064 { return pointsConsolidated; } 00065 void consolidate_points( double tolerance ); 00066 00067 // Access to the arrays without letting the client 00068 // change the pointer directly. 00069 GPoint* point_list() 00070 { return pointList; } 00071 int* facet_list() 00072 { return facetList; } 00073 00074 // Swap one array for another. Requiring a function call 00075 // instead of direct access makes it more likely that 00076 // dynamic memory and count values will be handled correctly. 00077 // Important!!!!!!!!!!! 00078 // The array passed in must have been allocated by 'new', 00079 // and must not be deleted outside of GMem!!!!! 00080 void replace_point_list(GPoint new_point_list[], int num_valid_points, 00081 int array_size); 00082 void replace_facet_list(int new_facet_list[], int num_valid_entries, 00083 int array_size); 00084 00085 // Read only access to the array sizes 00086 int point_list_size() 00087 { return ptsSize; } 00088 int facet_list_size() 00089 { return fListSize; } 00090 00091 // Copy constructor and operator= 00092 GMem(const GMem& from); 00093 GMem& operator=(const GMem& from); 00094 00095 // transformation functions - transform the display data 00096 void transform(CubitTransformMatrix &transform); 00097 }; 00098 00099 #endif 00100
